  4. Cloud Adapter läuft nicht
    2.4k
    4.3k
9 Beiträge 4 Kommentatoren 1.3k Aufrufe
    DomRay
    Gestern habe ich den Cloud Adapter installiert, jedoch bekomme ich Fehler beim starten.
    Ich bekomme folgende Fehlermeldung im Log:
    cloud.0	2017-01-15 10:16:28.944	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
    cloud.0	2017-01-15 10:16:28.944	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
    cloud.0	2017-01-15 10:16:28.944	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    cloud.0	2017-01-15 10:16:28.944	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    cloud.0	2017-01-15 10:16:28.944	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    cloud.0	2017-01-15 10:16:28.944	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    cloud.0	2017-01-15 10:16:28.944	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    cloud.0	2017-01-15 10:16:28.944	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    cloud.0	2017-01-15 10:16:28.944	error	at Socket. (/opt/iobroker/node_modules/iobroker.cloud/main.js:305:37)
    cloud.0	2017-01-15 10:16:28.944	error	at processState (/opt/iobroker/node_modules/iobroker.cloud/main.js:123:32)
    cloud.0	2017-01-15 10:16:28.944	error	TypeError: Cannot read property 'substring' of undefined
    cloud.0	2017-01-15 10:16:28.943	error	uncaught exception: Cannot read property 'substring' of undefined
    Ich habe daraufhin JS-Controller, SocketIO, Admin und Web aktualisiert, jedoch leider ohne Erfolg.
    Momentan habe ich folgende Versionen:
    JS-Controller 0.14.0
    Admin 1.6.8
    SocketIO 1.7.2
    Web 1.7.7
    Ist der Fehler bekannt?
    Danke für die Hilfe.
    geändert: Code in Codetags; Homoran (Mod.)
    • BluefoxB Offline
      BluefoxB Offline
      Du hast ein falsches Objekt was kein Namen hat.
      Werde den Fall prüfen und eine Meldung ausgeben
      • BluefoxB Offline
        BluefoxB Offline
        @Bluefox:
        Werde den Fall prüfen und eine Meldung ausgeben `
        Kannst du om git installieren?
          DomRay
          Meinst du das Revisionssystem git oder etwas anderes?
          Kann schon was installieren, wenn es der Lösungsfindung dienlich ist :D
          apt-get install git
          Was soll ich dann damit überprüfen?
            @DomRay:
            Meinst du das Revisionssystem git oder etwas anderes? `
            etwas anderes:
            du möchtest bitte die neueste Vorab-Version des Cloudadapters von GitHub installieren.
            http://www.iobroker.net/?page_id=5379&l … stallieren
            • eric2905E Offline
              eric2905E Offline
              eric2905
              @DomRay:
              Kann schon was installieren, wenn es der Lösungsfindung dienlich ist :D `
              Nein, Bluefox meinte den Cloud-Adapter aus dem Git installieren.
              Du hast im Admin, Reiter Adapter, oben eine Reihe Symbole.
              Von links nach rechts : Stern, Ausrufezeichen, Kopfhörer (so nenne ich den :D ). Wenn Du den nimmst (Tooltip-Text "Installieren aus eigenem URL"), öffnet sich ein kleines Fenster. Dort gehst Du auf den Reiter "Von Github" und wählst dort den Cloud-Adapter aus. Den Haken bei "Debug-Ausgänge" würde ich setzten - dann siehst Du, was passiert.
              Gruß,
              Eric
              Edit : Rainer war schneller (und ich konnte den Link zur Webseite so schnell nicht finden) :lol:
                @eric2905:
                Kopfhörer (so nenne ich den ) `
                :D Das ist Octocat! Etwas mehr Respekt bitte!
                @eric2905:
                ich konnte den Link zur Webseite so schnell nicht finden `
                Ich war gerade drauf.
                  DomRay
                  Vielen Dank, das war der richtige Tipp!
                  Es war ein altes CUxD Gerät welches das Problem verursacht hat.
                  Muss ich das Debugging wieder raus nehmen und wenn ja wie?
                  • BluefoxB Offline
                    BluefoxB Offline
                    @DomRay:
                    Muss ich das Debugging wieder raus nehmen und wenn ja wie? `
                    Es war kein debuggen. Lase alles so wie es ist
