  4. Jarvis Startet ohne Weboberfläche.. nach Backup
    2.5k
    4.5k
12 Beiträge 3 Kommentatoren 749 Aufrufe 3 Beobachtet
    michael_4358
    schrieb am zuletzt editiert von michael_4358
    Hey
    ich habe heut emein Broker neu aufgesetzt doch leider startet jarvis ohne Weboberfläche.
    version ist 2.2.0
    seite wird nicht angezeigt...
    2021-05-01 21:40:02.299 - info: jarvis.0 (3096) Got terminate signal TERMINATE_YOURSELF
    2021-05-01 21:40:02.804 - info: host.raspberrypi instance system.adapter.jarvis.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-05-01 21:40:05.460 - info: host.raspberrypi instance system.adapter.jarvis.0 started with pid 3218
    2021-05-01 21:40:06.660 - debug: jarvis.0 (3218) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-05-01 21:40:06.699 - debug: jarvis.0 (3218) Objects client ready ... initialize now
    2021-05-01 21:40:06.702 - debug: jarvis.0 (3218) Objects create System PubSub Client
    2021-05-01 21:40:06.704 - debug: jarvis.0 (3218) Objects create User PubSub Client
    2021-05-01 21:40:06.705 - debug: jarvis.0 (3218) Objects client initialize lua scripts
    2021-05-01 21:40:06.725 - debug: jarvis.0 (3218) Objects connected to redis: 127.0.0.1:9001
    2021-05-01 21:40:06.735 - debug: jarvis.0 (3218) objectDB connected
    2021-05-01 21:40:06.738 - debug: jarvis.0 (3218) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-05-01 21:40:06.750 - debug: jarvis.0 (3218) States create System PubSub Client
    2021-05-01 21:40:06.751 - debug: jarvis.0 (3218) States create User PubSub Client
    2021-05-01 21:40:06.764 - debug: jarvis.0 (3218) States connected to redis: 127.0.0.1:9000
    2021-05-01 21:40:06.765 - debug: jarvis.0 (3218) statesDB connected
    2021-05-01 21:40:07.055 - info: jarvis.0 (3218) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.jarvis, node: v12.22.1, js-controller: 3.2.16
    2021-05-01 21:40:07.113 - info: jarvis.0 (3218) No Backup found for styles, thus backing up initially.
    2021-05-01 21:40:07.188 - info: jarvis.0 (3218) Found Backups for layout.
    2021-05-01 21:40:07.189 - info: jarvis.0 (3218) Found Backups for settings.
    2021-05-01 21:40:07.190 - info: jarvis.0 (3218) Found Backups for devices.
    2021-05-01 21:40:07.387 - info: jarvis.0 (3218) Socket port detected: 8082
    2021-05-01 21:40:53.799 - info: host.raspberrypi "system.adapter.jarvis.0" disabled
    2021-05-01 21:40:53.805 - info: host.raspberrypi stopInstance system.adapter.jarvis.0 (force=false, process=true)
    2021-05-01 21:40:53.813 - info: jarvis.0 (3218) Got terminate signal TERMINATE_YOURSELF
    2021-05-01 21:40:53.815 - info: jarvis.0 (3218) Adapter stopped und unloaded.
    2021-05-01 21:40:53.816 - info: jarvis.0 (3218) terminating
    2021-05-01 21:40:53.817 - info: jarvis.0 (3218) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-05-01 21:40:53.819 - info: host.raspberrypi stopInstance system.adapter.jarvis.0 send kill signal
    2021-05-01 21:40:54.406 - info: host.raspberrypi instance system.adapter.jarvis.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-05-01 21:40:55.251 - info: host.raspberrypi "system.adapter.jarvis.0" enabled
    2021-05-01 21:40:55.348 - info: host.raspberrypi instance system.adapter.jarvis.0 started with pid 3412
    2021-05-01 21:40:56.478 - debug: jarvis.0 (3412) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-05-01 21:40:56.520 - debug: jarvis.0 (3412) Objects client ready ... initialize now
    2021-05-01 21:40:56.530 - debug: jarvis.0 (3412) Objects create System PubSub Client
    2021-05-01 21:40:56.532 - debug: jarvis.0 (3412) Objects create User PubSub Client
    2021-05-01 21:40:56.534 - debug: jarvis.0 (3412) Objects client initialize lua scripts
    2021-05-01 21:40:56.552 - debug: jarvis.0 (3412) Objects connected to redis: 127.0.0.1:9001
    2021-05-01 21:40:56.562 - debug: jarvis.0 (3412) objectDB connected
    2021-05-01 21:40:56.565 - debug: jarvis.0 (3412) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-05-01 21:40:56.574 - debug: jarvis.0 (3412) States create System PubSub Client
    2021-05-01 21:40:56.575 - debug: jarvis.0 (3412) States create User PubSub Client
    2021-05-01 21:40:56.583 - debug: jarvis.0 (3412) States connected to redis: 127.0.0.1:9000
    2021-05-01 21:40:56.584 - debug: jarvis.0 (3412) statesDB connected
    2021-05-01 21:40:56.972 - info: jarvis.0 (3412) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.jarvis, node: v12.22.1, js-controller: 3.2.16
    2021-05-01 21:40:57.027 - info: jarvis.0 (3412) No Backup found for styles, thus backing up initially.
    2021-05-01 21:40:57.064 - info: jarvis.0 (3412) Found Backups for layout.
    2021-05-01 21:40:57.065 - info: jarvis.0 (3412) Found Backups for settings.
    2021-05-01 21:40:57.066 - info: jarvis.0 (3412) Found Backups for devices.
    2021-05-01 21:40:57.121 - info: jarvis.0 (3412) Socket port detected: 8082
    2021-05-01 21:40:59.712 - info: sonoff.0 (1387) Client [4fachstecker] reconnected. Old secret 1619901629704_8139. New secret 1619901659709_2509
    2021-05-01 21:41:00.377 - info: sonoff.0 (1387) Client [Steck_E_Bike] reconnected. Old secret 1619900501557_9603. New secret 1619901660376_1670
    • M michael_4358
      Hey
      version ist 2.2.0
      crunchipC Abwesend
      crunchipC Abwesend
      @michael_4358 sagte in Jarvis Startet ohne Weboberfläche.. nach Backup:
      hat womöglich etwas mit deinem backup nicht funktioniert
        michael_4358
        @crunchip
        Das wäre ok für mich!
        Aber warum startet die Oberfläche nicht? Oder muss ich den Adapter einmal löschen und neu installieren?
        • M michael_4358
          @crunchip
          crunchipC Abwesend
          crunchipC Abwesend
          was heißt denn startet nicht?
          leeres Bild, drehender Kreisel?
          was zeigt die Browserconsole?
            michael_4358
            @crunchip
            Seite kann nicht angezeigt werden sagt der Browser…
            • M michael_4358
              @crunchip
              M Online
              M Online
              MCU
              Steht denn irgendetwas in den DP's: jarvis.0.devices oder jarvis.0.layout ?
              • M MCU
                michael_4358
                @mcu
                [{"title":"","tabs":[{"title":"Allgemein","icon":"mdi-apps","id":"6b8de6f3-b557-4dfa-926b-0436877f32b6","index":0,"widgetsEdges":true,"columns":[[{"moduleConfig":{"apikey":"https://www.daswetter.com/wetter_Haltern+am+See-Europa-Deutschland-Nordrhein+Westfalen--1-26703.html","localid":"45721","forecastWind":false},"devices":[],"module":"DateTime","title":"Uhrzeit","justification":"center","id":"bd4c7a0c-f7c0-4ab3-81e7-88dd76ce85d1","icon":"mdi-clock-time-four-outline","index":0},{"moduleConfig":{"apikey":"http://api.daswetter.com/index.php?api_lang=de&localidad=26703&affiliate_id=52nlpjyaze33&v=2.0","localid":"45721","display":"overview"},"devices":[],"module":"Weather","title":"4358 Haltern","id":"8277fb09-095b-496b-9cba-343a4a8ca382","icon":"mdi-weather-sunny","index":1},{"moduleConfig":{},"devices":[{"type":"device","deviceId":"95535b5e-a476-4dcf-8446-c327de7f3c70","lastUpdate":false,"label":"Restabfall","primaryStateKey":"Restabfall","showState":true,"actionElement":null},{"type":"device","deviceId":"95535b5e-a476-4dcf-8446-c327de7f3c70","primaryStateKey":"Gelbetonne","label":"Gelbetonne","lastUpdate":false,"showState":true,"actionElement":null},{"type":"device","deviceId":"95535b5e-a476-4dcf-8446-c327de7f3c70","primaryStateKey":"Grünetonne","label":"Grünetonne","lastUpdate":false,"showState":true,"actionElement":null},{"type":"device","deviceId":"95535b5e-a476-4dcf-8446-c327de7f3c70","primaryStateKey":"Papier","label":"Papier","lastUpdate":false,"showState":true,"actionElement":null}],"module":"StateListHorizontal","title":"Recycle","id":"351fc313-c29e-4fdf-9f15-cb6debc1f91e","justification":"center","icon":"mdi-recycle","index":2},{"moduleConfig":{},"devices":[{"type":"device","deviceId":"0bd8ee95-cea2-4847-8328-c39d83a7c1db","secondaryStatesKeys":[],"primaryStateKey":"Jar_Heim_CO2","showState":true,"actionElement":null,"label":"Co 2"},{"type":"device","deviceId":"0bd8ee95-cea2-4847-8328-c39d83a7c1db","label":"Geräuschpegel","secondaryStatesKeys":[],"primaryStateKey":"Jar_Heim_Dezi","showState":true,"actionElement":null},{"type":"device","deviceId":"0bd8ee95-cea2-4847-8328-c39d83a7c1db","secondaryStatesKeys":[],"primaryStateKey":"Jar_Heim_LuftDruck","showState":true,"actionElement":null,"label":"Luftdruck"},{"type":"device","deviceId":"0bd8ee95-cea2-4847-8328-c39d83a7c1db","label":"Luftfeuchtigkeit","primaryStateKey":"Jar_LuftFeuchte","showState":true,"actionElement":null}],"module":"StateListHorizontal","title":"Heim Status","justification":"center","id":"bf445e53-2dac-4142-89a7-4e3b92cdb99d","icon":"mdi-thermostat","index":3}]]},{"title":"Scripte","icon":"mdi-code-braces","columns":[[{"moduleConfig":{},"devices":[{"type":"device","deviceId":"2795e9d6-64e7-4700-a736-572525d1d143","actionElement":"SwitchAction","primaryStateKey":"KüchenParty","showState":false,"bodyStateKey":"KüchenParty","bodyElement":"LastChangeBody","label":"Party","secondaryStatesKeys":["KüchenParty"],"LastChangeBodyConfig":{"KüchenParty-time":"ts"}},{"type":"divider"},{"type":"device","deviceId":"2795e9d6-64e7-4700-a736-572525d1d143","label":"Romantik","secondaryStatesKeys":["Romantik"],"showState":false,"actionElement":"SwitchAction","bodyStateKey":"Romantik","bodyElement":"LastChangeBody","primaryStateKey":"Romantik"}],"module":"StateList","title":"Küche","id":"1c0cd1d0-615f-4766-a81e-4352bb45441c","icon":"mdi-code-braces","index":0},{"moduleConfig":{},"devices":[{"type":"device","deviceId":"c26d2ccb-c4cf-4476-8835-3d11acdca20f","actionElement":"SwitchAction","showState":false,"secondaryStatesKeys":["WohnzimmerParty"],"bodyStateKey":"WohnzimmerParty","bodyElement":"LastChangeBody","primaryStateKey":"WohnzimmerParty","label":"Party"},{"type":"divider","bodyStateKey":"WohnzimmerParty","bodyElement":"LastChangeBody","primaryStateKey":"WohnzimmerParty","showState":true,"actionElement":null},{"type":"device","deviceId":"c26d2ccb-c4cf-4476-8835-3d11acdca20f","secondaryStatesKeys":["Heimelich"],"primaryStateKey":"Heimelich","actionElement":"SwitchAction","bodyStateKey":"Heimelich","bodyElement":"LastChangeBody","showState":false,"label":"Heimelich"}],"module":"StateList","title":"Wohnzimmer","id":"f6b5ee82-699d-4bc2-89b1-701a93246b46","icon":"mdi-code-braces","index":1},{"moduleConfig":{},"devices":[{"type":"device","deviceId":"9ba8a5f3-ea25-46c5-91a1-166d61b272e9","label":"Müll","showState":false,"secondaryStatesKeys":["Muell"],"actionElement":"SwitchAction","bodyStateKey":"Muell","bodyElement":"LastChangeBody","primaryStateKey":"Muell"},{"type":"divider","bodyStateKey":"Muell","bodyElement":"LastChangeBody","primaryStateKey":"Muell","showState":true,"actionElement":null},{"type":"device","deviceId":"9ba8a5f3-ea25-46c5-91a1-166d61b272e9","label":"Kaminlüfter","bodyStateKey":"Kamin","primaryStateKey":"Kamin","secondaryStatesKeys":["Kamin"],"actionElement":"SwitchAction","bodyElement":"LastChangeBody","showState":false}],"module":"StateList","title":"Allgemeine Sripte","id":"4e366bd3-f62b-4c5d-b4bc-d6e71f828920","icon":"mdi-code-braces","index":2}]],"id":"541925b3-aa62-475d-bebc-0ff82492e990","index":1,"widgetsEdges":false},{"title":"Räume","icon":"mdi-warehouse","columns":[[{"moduleConfig":{},"devices":[{"type":"device","deviceId":"bad_1e299","primaryStateKey":"pressure","label":"Luftdruck","lastUpdate":false,"showState":true,"actionElement":null},{"type":"device","deviceId":"bad_1e299","primaryStateKey":"temperature","label":"Temperatur","lastUpdate":false,"showState":true,"actionElement":null},{"type":"device","deviceId":"bad_1e299","primaryStateKey":"humidity","label":"Luftfeuchtigkeit","lastUpdate":false,"showState":true,"actionElement":null},{"type":"device","deviceId":"bad_1e299","primaryStateKey":"battery","label":"Akku","lastUpdate":false,"showState":true,"actionElement ":null},{"type":"device","deviceId":"heizungbad_5cc21","label":"Heizung","secondaryStatesKeys":[],"actionElement":"SwitchAction","primaryStateKey":"SET","showState":true,"lastUpdate":false}],"module":"StateListHorizontal","title":"Bad Info","id":"f5cda1da-8a0b-42d6-b564-bc8d6e5b8fe3","icon":"mdi-information-variant","justification":"center","index":0}]],"id":"654226cb-2962-4c7e-91b9-4875c3355cca","index":2}],"id":"0","index":0}]
                • M michael_4358
                  @mcu
                  M Online
                  M Online
                  MCU
                  @michael_4358 Hast du die Browserdaten gelöscht und den Web-Adapter neu gestartet, nach dem Restore (jarvis)?
                  • M MCU
                    michael_4358
                    @mcu
                    Mit Browser Daten meinst du Cache usw?
                    • M michael_4358
                      @mcu
                      M Online
                      M Online
                      MCU
                      @michael_4358 Ja
                      M 2 Antworten Letzte Antwort
                      • M MCU
                        @michael_4358 Ja
                        michael_4358
                        @mcu
                        • M MCU
                          @michael_4358 Ja
                          michael_4358
                          @mcu
                          Hab es!
                          Den Hacken bei selbst Verwaltung (oder wie das heißt) raus Port auf 8082 und fertig
