  4. iobroker backup Problem
    6.3k
31 Beiträge 3 Kommentatoren 3.7k Aufrufe 3 Beobachtet
    @highline
    Gar nicht gut.
    Immer sauber herunterfahren. Zur Not mit dem Linux-Affengriff.
    Nochmal frisch rebooten und dann
    dmesg -T
    highline
    pi@raspberrypin:~ $ dmesg -T
    [Thu Apr 29 08:28:56 2021] Booting Linux on physical CPU 0x0
    [Thu Apr 29 08:28:56 2021] Linux version 5.10.17-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:29:51 GMT 2021
    [Thu Apr 29 08:28:56 2021] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    [Thu Apr 29 08:28:56 2021] CPU: div instructions available: patching division code
    [Thu Apr 29 08:28:56 2021] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [Thu Apr 29 08:28:56 2021] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
    [Thu Apr 29 08:28:56 2021] Memory policy: Data cache writealloc
    [Thu Apr 29 08:28:56 2021] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
    [Thu Apr 29 08:28:56 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [Thu Apr 29 08:28:56 2021] Zone ranges:
    [Thu Apr 29 08:28:56 2021]   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
    [Thu Apr 29 08:28:56 2021]   Normal   empty
    [Thu Apr 29 08:28:56 2021] Movable zone start for each node
    [Thu Apr 29 08:28:56 2021] Early memory node ranges
    [Thu Apr 29 08:28:56 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
    [Thu Apr 29 08:28:56 2021] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
    [Thu Apr 29 08:28:56 2021] On node 0 totalpages: 242688
    [Thu Apr 29 08:28:56 2021]   DMA zone: 2133 pages used for memmap
    [Thu Apr 29 08:28:56 2021]   DMA zone: 0 pages reserved
    [Thu Apr 29 08:28:56 2021]   DMA zone: 242688 pages, LIFO batch:63
    [Thu Apr 29 08:28:56 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
    [Thu Apr 29 08:28:56 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
    [Thu Apr 29 08:28:56 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [Thu Apr 29 08:28:56 2021] Built 1 zonelists, mobility grouping on.  Total pages: 240555
    [Thu Apr 29 08:28:56 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Thu Apr 29 08:28:56 2021] Kernel parameter elevator= does not have any effect anymore.
                               Please use sysfs to set IO scheduler for individual devices.
    [Thu Apr 29 08:28:56 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [Thu Apr 29 08:28:56 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [Thu Apr 29 08:28:56 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
    [Thu Apr 29 08:28:56 2021] Memory: 879832K/970752K available (9216K kernel code, 1311K rwdata, 2940K rodata, 1024K init, 860K bss, 25384K reserved, 65536K cma-reserved)
    [Thu Apr 29 08:28:56 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [Thu Apr 29 08:28:56 2021] ftrace: allocating 31910 entries in 63 pages
    [Thu Apr 29 08:28:56 2021] ftrace: allocated 63 pages with 6 groups
    [Thu Apr 29 08:28:56 2021] rcu: Hierarchical RCU implementation.
    [Thu Apr 29 08:28:56 2021] 	Rude variant of Tasks RCU enabled.
    [Thu Apr 29 08:28:56 2021] 	Tracing variant of Tasks RCU enabled.
    [Thu Apr 29 08:28:56 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [Thu Apr 29 08:28:56 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [Thu Apr 29 08:28:56 2021] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=0
    [Thu Apr 29 08:28:56 2021] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    [Thu Apr 29 08:28:56 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    [Thu Apr 29 08:28:56 2021] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    [Thu Apr 29 08:28:56 2021] Switching to timer-based delay loop, resolution 52ns
    [Thu Apr 29 08:28:56 2021] Console: colour dummy device 80x30
    [Thu Apr 29 08:28:56 2021] printk: console [tty1] enabled
    [Thu Apr 29 08:28:56 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    [Thu Apr 29 08:28:56 2021] pid_max: default: 32768 minimum: 301
    [Thu Apr 29 08:28:56 2021] LSM: Security Framework initializing
    [Thu Apr 29 08:28:56 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [Thu Apr 29 08:28:56 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [Thu Apr 29 08:28:56 2021] Disabling memory control group subsystem
    [Thu Apr 29 08:28:56 2021] CPU: Testing write buffer coherency: ok
    [Thu Apr 29 08:28:56 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [Thu Apr 29 08:28:56 2021] Setting up static identity map for 0x100000 - 0x10003c
    [Thu Apr 29 08:28:56 2021] rcu: Hierarchical SRCU implementation.
    [Thu Apr 29 08:28:56 2021] smp: Bringing up secondary CPUs ...
    [Thu Apr 29 08:28:56 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [Thu Apr 29 08:28:56 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [Thu Apr 29 08:28:56 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [Thu Apr 29 08:28:56 2021] smp: Brought up 1 node, 4 CPUs
    [Thu Apr 29 08:28:56 2021] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    [Thu Apr 29 08:28:56 2021] CPU: All CPU(s) started in HYP mode.
    [Thu Apr 29 08:28:56 2021] CPU: Virtualization extensions available.
    [Thu Apr 29 08:28:56 2021] devtmpfs: initialized
    [Thu Apr 29 08:28:56 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    [Thu Apr 29 08:28:56 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [Thu Apr 29 08:28:56 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [Thu Apr 29 08:28:56 2021] pinctrl core: initialized pinctrl subsystem
    [Thu Apr 29 08:28:56 2021] NET: Registered protocol family 16
    [Thu Apr 29 08:28:56 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [Thu Apr 29 08:28:56 2021] audit: initializing netlink subsys (disabled)
    [Thu Apr 29 08:28:56 2021] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
    [Thu Apr 29 08:28:56 2021] thermal_sys: Registered thermal governor 'step_wise'
    [Thu Apr 29 08:28:56 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [Thu Apr 29 08:28:56 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [Thu Apr 29 08:28:56 2021] Serial: AMBA PL011 UART driver
    [Thu Apr 29 08:28:56 2021] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    [Thu Apr 29 08:28:56 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:12:09, variant start
    [Thu Apr 29 08:28:56 2021] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
    [Thu Apr 29 08:28:56 2021] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
    [Thu Apr 29 08:28:56 2021] SCSI subsystem initialized
    [Thu Apr 29 08:28:56 2021] usbcore: registered new interface driver usbfs
    [Thu Apr 29 08:28:56 2021] usbcore: registered new interface driver hub
    [Thu Apr 29 08:28:56 2021] usbcore: registered new device driver usb
    [Thu Apr 29 08:28:56 2021] clocksource: Switched to clocksource arch_sys_counter
    [Thu Apr 29 08:28:57 2021] VFS: Disk quotas dquot_6.6.0
    [Thu Apr 29 08:28:57 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [Thu Apr 29 08:28:57 2021] FS-Cache: Loaded
    [Thu Apr 29 08:28:57 2021] CacheFiles: Loaded
    [Thu Apr 29 08:28:57 2021] NET: Registered protocol family 2
    [Thu Apr 29 08:28:57 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [Thu Apr 29 08:28:57 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [Thu Apr 29 08:28:57 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [Thu Apr 29 08:28:57 2021] TCP: Hash tables configured (established 8192 bind 8192)
    [Thu Apr 29 08:28:57 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [Thu Apr 29 08:28:57 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [Thu Apr 29 08:28:57 2021] NET: Registered protocol family 1
    [Thu Apr 29 08:28:57 2021] RPC: Registered named UNIX socket transport module.
    [Thu Apr 29 08:28:57 2021] RPC: Registered udp transport module.
    [Thu Apr 29 08:28:57 2021] RPC: Registered tcp transport module.
    [Thu Apr 29 08:28:57 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [Thu Apr 29 08:28:57 2021] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    [Thu Apr 29 08:28:57 2021] Initialise system trusted keyrings
    [Thu Apr 29 08:28:57 2021] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [Thu Apr 29 08:28:57 2021] zbud: loaded
    [Thu Apr 29 08:28:57 2021] FS-Cache: Netfs 'nfs' registered for caching
    [Thu Apr 29 08:28:57 2021] NFS: Registering the id_resolver key type
    [Thu Apr 29 08:28:57 2021] Key type id_resolver registered
    [Thu Apr 29 08:28:57 2021] Key type id_legacy registered
    [Thu Apr 29 08:28:57 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [Thu Apr 29 08:28:57 2021] Key type asymmetric registered
    [Thu Apr 29 08:28:57 2021] Asymmetric key parser 'x509' registered
    [Thu Apr 29 08:28:57 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [Thu Apr 29 08:28:57 2021] io scheduler mq-deadline registered
    [Thu Apr 29 08:28:57 2021] io scheduler kyber registered
    [Thu Apr 29 08:28:57 2021] bcm2708_fb soc:fb: FB found 1 display(s)
    [Thu Apr 29 08:28:57 2021] Console: switching to colour frame buffer device 82x26
    [Thu Apr 29 08:28:57 2021] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
    [Thu Apr 29 08:28:57 2021] bcm2835-rng 3f104000.rng: hwrng registered
    [Thu Apr 29 08:28:57 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [Thu Apr 29 08:28:57 2021] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    [Thu Apr 29 08:28:58 2021] brd: module loaded
    [Thu Apr 29 08:28:58 2021] loop: module loaded
    [Thu Apr 29 08:28:58 2021] Loading iSCSI transport class v2.0-870.
    [Thu Apr 29 08:28:58 2021] libphy: Fixed MDIO Bus: probed
    [Thu Apr 29 08:28:58 2021] usbcore: registered new interface driver lan78xx
    [Thu Apr 29 08:28:58 2021] usbcore: registered new interface driver smsc95xx
    [Thu Apr 29 08:28:58 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [Thu Apr 29 08:28:58 2021] Core Release: 2.80a
    [Thu Apr 29 08:28:58 2021] Setting default values for core params
    [Thu Apr 29 08:28:58 2021] Finished setting default values for core params
    [Thu Apr 29 08:28:58 2021] Using Buffer DMA mode
    [Thu Apr 29 08:28:58 2021] Periodic Transfer Interrupt Enhancement - disabled
    [Thu Apr 29 08:28:58 2021] Multiprocessor Interrupt Enhancement - disabled
    [Thu Apr 29 08:28:58 2021] OTG VER PARAM: 0, OTG VER FLAG: 0
    [Thu Apr 29 08:28:58 2021] Dedicated Tx FIFOs mode
    [Thu Apr 29 08:28:58 2021] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7514000 dma = 0xf7514000 len=9024
    [Thu Apr 29 08:28:59 2021] FIQ FSM acceleration enabled for :
                               Non-periodic Split Transactions
                               Periodic Split Transactions
                               High-Speed Isochronous Endpoints
                               Interrupt/Control Split Transaction hack enabled
    [Thu Apr 29 08:28:59 2021] dwc_otg: Microframe scheduler enabled
    [Thu Apr 29 08:28:59 2021] WARN::hcd_init_fiq:457: FIQ on core 1
    [Thu Apr 29 08:28:59 2021] WARN::hcd_init_fiq:458: FIQ ASM at 807be568 length 36
    [Thu Apr 29 08:28:59 2021] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
    [Thu Apr 29 08:28:59 2021] dwc_otg 3f980000.usb: DWC OTG Controller
    [Thu Apr 29 08:28:59 2021] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    [Thu Apr 29 08:28:59 2021] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
    [Thu Apr 29 08:28:59 2021] Init: Port Power? op_state=1
    [Thu Apr 29 08:28:59 2021] Init: Power Port (0)
    [Thu Apr 29 08:28:59 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [Thu Apr 29 08:28:59 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [Thu Apr 29 08:28:59 2021] usb usb1: Product: DWC OTG Controller
    [Thu Apr 29 08:28:59 2021] usb usb1: Manufacturer: Linux 5.10.17-v7+ dwc_otg_hcd
    [Thu Apr 29 08:28:59 2021] usb usb1: SerialNumber: 3f980000.usb
    [Thu Apr 29 08:28:59 2021] hub 1-0:1.0: USB hub found
    [Thu Apr 29 08:28:59 2021] hub 1-0:1.0: 1 port detected
    [Thu Apr 29 08:28:59 2021] dwc_otg: FIQ enabled
    [Thu Apr 29 08:28:59 2021] dwc_otg: NAK holdoff enabled
    [Thu Apr 29 08:28:59 2021] dwc_otg: FIQ split-transaction FSM enabled
    [Thu Apr 29 08:28:59 2021] Module dwc_common_port init
    [Thu Apr 29 08:28:59 2021] usbcore: registered new interface driver usb-storage
    [Thu Apr 29 08:28:59 2021] mousedev: PS/2 mouse device common for all mice
    [Thu Apr 29 08:28:59 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [Thu Apr 29 08:28:59 2021] sdhci: Secure Digital Host Controller Interface driver
    [Thu Apr 29 08:28:59 2021] sdhci: Copyright(c) Pierre Ossman
    [Thu Apr 29 08:28:59 2021] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
    [Thu Apr 29 08:28:59 2021] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
    [Thu Apr 29 08:28:59 2021] sdhci-pltfm: SDHCI platform and OF driver helper
    [Thu Apr 29 08:28:59 2021] ledtrig-cpu: registered to indicate activity on CPUs
    [Thu Apr 29 08:28:59 2021] hid: raw HID events driver (C) Jiri Kosina
    [Thu Apr 29 08:28:59 2021] usbcore: registered new interface driver usbhid
    [Thu Apr 29 08:28:59 2021] usbhid: USB HID core driver
    [Thu Apr 29 08:28:59 2021] Initializing XFRM netlink socket
    [Thu Apr 29 08:28:59 2021] NET: Registered protocol family 17
    [Thu Apr 29 08:28:59 2021] Key type dns_resolver registered
    [Thu Apr 29 08:28:59 2021] Registering SWP/SWPB emulation handler
    [Thu Apr 29 08:28:59 2021] registered taskstats version 1
    [Thu Apr 29 08:28:59 2021] Loading compiled-in X.509 certificates
    [Thu Apr 29 08:28:59 2021] Key type ._fscrypt registered
    [Thu Apr 29 08:28:59 2021] Key type .fscrypt registered
    [Thu Apr 29 08:28:59 2021] Key type fscrypt-provisioning registered
    [Thu Apr 29 08:28:59 2021] uart-pl011 3f201000.serial: cts_event_workaround enabled
    [Thu Apr 29 08:28:59 2021] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
    [Thu Apr 29 08:28:59 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [Thu Apr 29 08:28:59 2021] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [Thu Apr 29 08:28:59 2021] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
    [Thu Apr 29 08:28:59 2021] sdhost: log_buf @ (ptrval) (f7513000)
    [Thu Apr 29 08:28:59 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [Thu Apr 29 08:28:59 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [Thu Apr 29 08:28:59 2021] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    [Thu Apr 29 08:28:59 2021] of_cfs_init
    [Thu Apr 29 08:28:59 2021] of_cfs_init: OK
    [Thu Apr 29 08:28:59 2021] Waiting for root device PARTUUID=738a4d67-02...
    [Thu Apr 29 08:28:59 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [Thu Apr 29 08:28:59 2021] Indeed it is in host mode hprt0 = 00021501
    [Thu Apr 29 08:28:59 2021] random: fast init done
    [Thu Apr 29 08:28:59 2021] mmc0: host does not support reading read-only switch, assuming write-enable
    [Thu Apr 29 08:28:59 2021] mmc0: new high speed SDXC card at address aaaa
    [Thu Apr 29 08:28:59 2021] mmcblk0: mmc0:aaaa SN128 119 GiB
    [Thu Apr 29 08:28:59 2021] mmc1: new high speed SDIO card at address 0001
    [Thu Apr 29 08:28:59 2021]  mmcblk0: p1 p2
    [Thu Apr 29 08:28:59 2021] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Thu Apr 29 08:28:59 2021] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Thu Apr 29 08:28:59 2021] usb 1-1: new high-speed USB device number 2 using dwc_otg
    [Thu Apr 29 08:28:59 2021] Indeed it is in host mode hprt0 = 00001101
    [Thu Apr 29 08:28:59 2021] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
    [Thu Apr 29 08:28:59 2021] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [Thu Apr 29 08:28:59 2021] hub 1-1:1.0: USB hub found
    [Thu Apr 29 08:28:59 2021] hub 1-1:1.0: 4 ports detected
    [Thu Apr 29 08:28:59 2021] EXT4-fs (mmcblk0p2): recovery complete
    [Thu Apr 29 08:28:59 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Apr 29 08:28:59 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Apr 29 08:28:59 2021] devtmpfs: mounted
    [Thu Apr 29 08:28:59 2021] Freeing unused kernel memory: 1024K
    [Thu Apr 29 08:28:59 2021] Run /sbin/init as init process
    [Thu Apr 29 08:28:59 2021]   with arguments:
    [Thu Apr 29 08:28:59 2021]     /sbin/init
    [Thu Apr 29 08:28:59 2021]   with environment:
    [Thu Apr 29 08:28:59 2021]     HOME=/
    [Thu Apr 29 08:28:59 2021]     TERM=linux
    [Thu Apr 29 08:29:00 2021] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    [Thu Apr 29 08:29:00 2021] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
    [Thu Apr 29 08:29:00 2021] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [Thu Apr 29 08:29:00 2021] hub 1-1.1:1.0: USB hub found
    [Thu Apr 29 08:29:00 2021] hub 1-1.1:1.0: 3 ports detected
    [Thu Apr 29 08:29:00 2021] systemd[1]: System time before build time, advancing clock.
    [Thu Apr 29 08:29:00 2021] dwc_otg_handle_wakeup_detected_intr lxstate = 2
    [Thu Apr 29 08:29:00 2021] NET: Registered protocol family 10
    [Thu Apr 29 08:29:00 2021] Segment Routing with IPv6
    [Thu Apr 29 08:29:00 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [Thu Apr 29 08:29:00 2021] systemd[1]: Detected architecture arm.
    [Thu Apr 29 08:29:00 2021] systemd[1]: Set hostname to <raspberrypin>.
    [Thu Apr 29 08:29:01 2021] usb 1-1.1.1: new high-speed USB device number 4 using dwc_otg
    [Thu Apr 29 08:29:01 2021] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
    [Thu Apr 29 08:29:01 2021] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [Thu Apr 29 08:29:01 2021] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
    [Thu Apr 29 08:29:01 2021] libphy: lan78xx-mdiobus: probed
    [Thu Apr 29 08:29:01 2021] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
    [Thu Apr 29 08:29:01 2021] random: systemd: uninitialized urandom read (16 bytes read)
    [Thu Apr 29 08:29:01 2021] systemd[1]: Listening on fsck to fsckd communication Socket.
    [Thu Apr 29 08:29:01 2021] systemd[1]: Listening on Journal Socket.
    [Thu Apr 29 08:29:01 2021] systemd[1]: Mounting RPC Pipe File System...
    [Thu Apr 29 08:29:01 2021] systemd[1]: Mounting Kernel Debug File System...
    [Thu Apr 29 08:29:01 2021] systemd[1]: Listening on Journal Audit Socket.
    [Thu Apr 29 08:29:01 2021] systemd[1]: Created slice system-getty.slice.
    [Thu Apr 29 08:29:01 2021] systemd[1]: Listening on Syslog Socket.
    [Thu Apr 29 08:29:02 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [Thu Apr 29 08:29:03 2021] systemd-journald[113]: Received request to flush runtime journal from PID 1
    [Thu Apr 29 08:29:03 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [Thu Apr 29 08:29:03 2021] mc: Linux media interface: v0.10
    [Thu Apr 29 08:29:03 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [Thu Apr 29 08:29:03 2021] [vc_sm_connected_init]: start
    [Thu Apr 29 08:29:03 2021] [vc_sm_connected_init]: installed successfully
    [Thu Apr 29 08:29:03 2021] videodev: Linux video capture interface: v2.00
    [Thu Apr 29 08:29:03 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [Thu Apr 29 08:29:03 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [Thu Apr 29 08:29:03 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [Thu Apr 29 08:29:03 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [Thu Apr 29 08:29:03 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
    [Thu Apr 29 08:29:03 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [Thu Apr 29 08:29:03 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [Thu Apr 29 08:29:03 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [Thu Apr 29 08:29:03 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [Thu Apr 29 08:29:03 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [Thu Apr 29 08:29:03 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [Thu Apr 29 08:29:03 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [Thu Apr 29 08:29:03 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [Thu Apr 29 08:29:03 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [Thu Apr 29 08:29:03 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [Thu Apr 29 08:29:03 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [Thu Apr 29 08:29:03 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [Thu Apr 29 08:29:03 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [Thu Apr 29 08:29:03 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [Thu Apr 29 08:29:03 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [Thu Apr 29 08:29:03 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [Thu Apr 29 08:29:04 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [Thu Apr 29 08:29:04 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [Thu Apr 29 08:29:04 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
    [Thu Apr 29 08:29:04 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [Thu Apr 29 08:29:04 2021] usbcore: registered new interface driver brcmfmac
    [Thu Apr 29 08:29:04 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
    [Thu Apr 29 08:29:04 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    [Thu Apr 29 08:29:04 2021] random: crng init done
    [Thu Apr 29 08:29:04 2021] random: 7 urandom warning(s) missed due to ratelimiting
    [Thu Apr 29 08:29:06 2021] uart-pl011 3f201000.serial: no DMA platform data
    [Thu Apr 29 08:29:06 2021] 8021q: 802.1Q VLAN Support v1.8
    [Thu Apr 29 08:29:06 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
    [Thu Apr 29 08:29:06 2021] 8021q: adding VLAN 0 to HW filter on device eth0
    [Thu Apr 29 08:29:06 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [Thu Apr 29 08:29:08 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
    [Thu Apr 29 08:29:13 2021] Bluetooth: Core ver 2.22
    [Thu Apr 29 08:29:13 2021] NET: Registered protocol family 31
    [Thu Apr 29 08:29:13 2021] Bluetooth: HCI device and connection manager initialized
    [Thu Apr 29 08:29:13 2021] Bluetooth: HCI socket layer initialized
    [Thu Apr 29 08:29:13 2021] Bluetooth: L2CAP socket layer initialized
    [Thu Apr 29 08:29:13 2021] Bluetooth: SCO socket layer initialized
    [Thu Apr 29 08:29:13 2021] Bluetooth: HCI UART driver ver 2.3
    [Thu Apr 29 08:29:13 2021] Bluetooth: HCI UART protocol H4 registered
    [Thu Apr 29 08:29:13 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [Thu Apr 29 08:29:13 2021] Bluetooth: HCI UART protocol Broadcom registered
    [Thu Apr 29 08:29:13 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [Thu Apr 29 08:29:13 2021] Bluetooth: BNEP filters: protocol multicast
    [Thu Apr 29 08:29:13 2021] Bluetooth: BNEP socket layer initialized
    • Thomas BraunT Online
      @highline
      dmesg -T | grep -i ext4
      Und bitte Neustarten, die Datei ist ja von 8:irgendwas, da sollte eine aktuelle Uhrzeit in den Timestamps sein.
      H 1 Antwort Letzte Antwort
        @highline
        highline
        pi@raspberrypin:~ $ dmesg -T | grep -i ext4
        [Thu Apr 29 09:00:38 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Thu Apr 29 09:00:41 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Thu Apr 29 09:00:41 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Thu Apr 29 09:00:44 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        • H highline
          @highline
          Deine Zeitzone ist noch auf Londoner Zeit eingestellt.
          Stell das auf Berlin um.
            @highline
            highline
            schrieb am zuletzt editiert von highline
            pi@raspberrypin:~ $ sudo raspi-config
            Current default time zone: 'Europe/Berlin'
            Local time is now:      Thu Apr 29 10:13:05 CEST 2021.
            Universal Time is now:  Thu Apr 29 08:13:05 UTC 2021.
            pi@raspberrypin:~ $ iobroker stop
            pi@raspberrypin:~ $ iobroker backup
            host.raspberrypin 1679 states saved
            host.raspberrypin 1740 objects saved
            /usr/bin/iobroker: line 8:  1609 Killed                  sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
            • H highline
              highline
              Gibt es eventuell noch andere Möglichkeiten das Backup wieder zum laufen zu bekommen? Sonst bleibt nur die Kopie von iobroker-data, richtig?
              Noch eine andere Info: Nach dem iobroker backup-Befehl kommt
              dann läuft RAM und Swap voll/über:
              MiB Mem :    924.2 total,     20.7 free,    890.6 used,     12.9 buff/cache
              MiB Swap:    100.0 total,      0.0 free,    100.0 used.      2.9 avail Mem
              nach einer Weile fängt sich RAM/SWAP wieder und dann läuft bis zum sudo reboot in einer Schleife dies ab:
              Objects database error: read ECONNRESET
               Objects database error: connect ECONNREFUSED 127.0.0.1:9001
               States database error: connect ECONNREFUSED 127.0.0.1:9000
              normal sieht es so aus
              MiB Mem :    924.2 total,    293.3 free,    376.4 used,    254.5 buff/cache
              MiB Swap:    100.0 total,    100.0 free,      0.0 used.    540.0 avail Mem
              • H highline
                @highline
                1GB Ram ist halt äußerst knapp bemessen.
                ps aux | grep -i xorg
                liefert?
                  @highline
                  liefert?
                  highline
                  pi@raspberrypin:~ $ ps aux | grep -i xorg
                  pi        1892  0.0  0.0   7348   500 pts/0    S+   14:50   0:00 grep --color=auto -i xorg
                  • H highline
                    @highline
                    Okay, dann läuft schon mal kein X mit.
                    Wieviel Zeug liegt denn im iobroker an?
                    iobroker list instances | grep +
                    H HomoranH 2 Antworten Letzte Antwort
                      @highline
                      highline
                      pi@raspberrypin:~ $ iobroker list instances | grep +
                      + system.adapter.admin.0                  : admin                 : raspberrypin                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.info.0                   : info                  : raspberrypin                             -  enabled
                      + system.adapter.javascript.0             : javascript            : raspberrypin                             -  enabled
                      + system.adapter.modbus.0                 : modbus                : raspberrypin                             -  enabled
                      + system.adapter.netatmo.0                : netatmo               : raspberrypin                             -  enabled
                      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypin                             -  enabled
                      + system.adapter.sql.0                    : sql                   : raspberrypin                             -  enabled
                      + system.adapter.web.0                    : web                   : raspberrypin                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                        @highline
                        @thomas-braun sagte in iobroker backup Problem:
                        das ist ja wirklich nicht viel.
                        Da fällt mir nur noch die Möglichkeit ein, dass in jedem Backup auch die alten backups nochmal gesichert werden und daher das backup viel zu groß sein könnte.
                          highline
                          Ich habe die alten Backups aus dem Ordner gelöscht, das Verhalten bleibt leider gleich
                          • H Offline
                            highline
                            Ich habe jetzt einen zweiten neuen raspi aufgesetzt, iobroker installiert und danach einfach den Order iobroker-data vom alten raspi auf den neuen kopiert.
                            Nach dem Start des iobroker auf dem neuen raspi läuft dieser auch und zeigt Objekte an, jedoch keine Instanzen. Muss der hostname des neuen raspi dem alten entsprechen oder was kann ich tun?
                            • H highline
                              @highline
                              iobroker stop
                              iobroker host this
                              iobroker start
                              Das simple kopieren des Ordners ist allerdings soweit ich weiß nur die halbe Miete, da sind u. U. noch Links zu fixen.
                                @highline
                                iobroker stop
                                iobroker host this
                                iobroker start
                                highline
                                Danke dir, die Instanzen sind da, teilweise noch rot, ich sehe im Log das er nun die Adapter installiert....
                                  @highline Das ist das normale Verhalten. Abwarten.
                                    highline
                                    Alle Adapter laufen, außer sql: Error: SQLITE_CORRUPT: database disk image is malformed
                                    • Instanz sql.1 installiert und auf diese umgestellt, gleicher Fehler
                                    • Instanz sql.0 und sql.1 gelöscht, sql.0 neu installiert, gleicher Fehler
                                    • iobroker fix, gleicher Fehler
                                      Was kann ich noch tun?
                                    • H highline
                                      @highline
                                      Google bemüht:
                                      https://www.databasefilerecovery.com/blog/sqlite-error-database-disk-image-is-malformed.html
                                      Das Problem hat nichts mit dem ioBroker oder den Adaptern zu tun.
                                        @highline
                                        Google bemüht:
                                        highline
                                        ok danke, ich würde eher lieber sql in iobroker komplett neu aufsetzen, ich brauche keine historischen Daten, wie kann ich die Datenbank "loswerden"?
                                        • H highline
                                          highline
                                          habe es hinbekommen
                                          • Adapter löschen und dann aber eben auch
                                          • die db im Ordner sqlite löschen
                                          • Neuinstallation des Adapters
