  4. wifilight in den Objekten nicht sichtbar
5 Beiträge 3 Kommentatoren 629 Aufrufe 3 Beobachtet
  • bummB Offline
    bummB Offline
    bumm
    schrieb am zuletzt editiert von bumm
    Hallo Zusammen
    Ich habe mir paar LED Strips bei Aliexpress bestellt. Die werden über WiFi mit dem App Magic Home gesteuert. Läuft super.
    Für die Steuerung mit ioBroker habe ich WifiLight installiert. Dies ist ins den Instanzen Grün und konnte die Geräte such finde.
    Doch leider finde ich unter Objekte Garnichts in Wifilight.
    In den Log kommt folgendes.
    code_text
    ``wifilight.0	2021-04-30 10:04:31.498	error	(31114) wrong device type. not yet supported!
    wifilight.0	2021-04-30 10:04:31.497	error	(31114) wrong device type. not yet supported!
    wifilight.0	2021-04-30 10:04:31.495	error	Known types are: LW12, LD382A, LD686, LD382, UFO, MiLight, MiLightRGB, MiLightW
    wifilight.0	2021-04-30 10:04:31.495	error	(31114) config.device.type "" (AK001-ZJ2145) is not a known device type. Skipping this device!
    wifilight.0	2021-04-30 10:04:31.494	error	Known types are: LW12, LD382A, LD686, LD382, UFO, MiLight, MiLightRGB, MiLightW
    wifilight.0	2021-04-30 10:04:31.494	error	(31114) config.device.type "" (AK001-ZJ2145) is not a known device type. Skipping this device!
    wifilight.0	2021-04-30 10:04:31.366	info	(31114) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.wifilight, node: v12.22.1, js-controller: 3.2.16
    wifilight.0	2021-04-30 10:04:26.947	info	(31010) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    wifilight.0	2021-04-30 10:04:26.945	info	(31010) terminating
    wifilight.0	2021-04-30 10:04:26.942	info	(31010) Got terminate signal TERMINATE_YOURSELF
    wifilight.0	2021-04-30 10:04:22.576	error	(31010) wrong device type. not yet supported!
    wifilight.0	2021-04-30 10:04:22.575	error	Known types are: LW12, LD382A, LD686, LD382, UFO, MiLight, MiLightRGB, MiLightW
    wifilight.0	2021-04-30 10:04:22.575	error	(31010) config.device.type "" (AK001-ZJ2145) is not a known device type. Skipping this device!
    wifilight.0	2021-04-30 10:04:22.574	error	Known types are: LW12, LD382A, LD686, LD382, UFO, MiLight, MiLightRGB, MiLightW
    wifilight.0	2021-04-30 10:04:22.574	error	(31010) config.device.type "" (AK001-ZJ2145) is not a known device type. Skipping this device!
    wifilight.0	2021-04-30 10:04:22.464	info	(31010) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.wifilight, node: v12.22.1, js-controller: 3.2.16
    wifilight.0	2021-04-30 10:04:18.107	info	(22196) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    wifilight.0	2021-04-30 10:04:18.106	info	(22196) terminating
    wifilight.0	2021-04-30 10:04:18.104	info	(22196) Got terminate signal TERMINATE_YOURSELF`
    Kann mir da jemand helfen.
    Grüsse Stefan
    • C Offline
      Cino
      @bumm said in wifilight in den Objekten nicht sichtbar:
      Laut Log wird das Gerät nicht unterstützt.
      IOB@RPI4
      Shelly, Zigbee, ebus
      bummB 1 Antwort Letzte Antwort
      • C Cino
        bummB Offline
        bummB Offline
        bumm
        @cino
        Kennst du eine Alternative?
        Gruss Stefan
        • bummB bumm
          @cino
          Gruss Stefan
          @bumm du hast bei TYP nix in der Adapter Config eingetragen, schreib da mal eins von den Unterstützten Geräten rein, teste mal durch.
          Schau, welcher Port offen ist, an dem Teil.
            bummB Offline
            bummB Offline
            bumm
            @ilovegym Danke viel mal, dass wahr genau das Problem.
            Danke Danke Danke
