  4. Kodi App läuft nich binkt immer wieder gelb
    5.6k
31 Beiträge 6 Kommentatoren 3.9k Aufrufe 7 Beobachtet
  • J JJ_1
    @oliverio
    JJ_1
    @jj_1
    habe gerad festgestellt auch wenn ich ein falsches Passwort angebe . Verhät es sich genauso und die Curuser Tasten funktionieren auch mit dem falschen Passwort
    • J JJ_1
      @jj_1
      JJ_1
      @jj_1
      Ahhh. Die Logstufe stand auf info
      • J JJ_1
        @jj_1
        JJ_1
        2021-04-29 15:05:56.598 - debug: kodi.1 (22900) KODI connecting to: 192.168.178.100:9090
        2021-04-29 15:05:56.720 - info: kodi.1 (22900) KODI connected
        2021-04-29 15:05:56.724 - debug: kodi.1 (22900) GetPortWebServer: {"value":8080}
        2021-04-29 15:05:56.794 - debug: kodi.1 (22900) GetNameVersion: {"System.Platform.ATV2":false,"System.Platform.Android":false,"System.Platform.Darwin":false,"System.Platform.IOS":false,"System.Platform.Linux":false,"System.Platform.Linux.RaspberryPi":false,"System.Platform.OSX":false,"System.Platform.Windows":true}
        2021-04-29 15:05:56.799 - debug: kodi.1 (22900) GetVolume: {"muted":false,"volume":100}
        2021-04-29 15:05:56.812 - debug: kodi.1 (22900) Error GetChannels: PVR is not use?{"response":{"code":-32100,"message":"Failed to execute method."}}
        2021-04-29 15:05:58.141 - debug: kodi.1 (22900) Error: Error: Socket error: Invalid WebSocket frame: invalid UTF-8 sequence
        2021-04-29 15:05:58.143 - debug: kodi.1 (22900) Connection closed
        2021-04-29 15:06:03.145 - debug: kodi.1 (22900) KODI connecting to: 192.168.178.100:9090
        2021-04-29 15:06:03.205 - info: kodi.1 (22900) KODI connected
        2021-04-29 15:06:03.208 - debug: kodi.1 (22900) GetPortWebServer: {"value":8080}
        2021-04-29 15:06:03.313 - debug: kodi.1 (22900) GetNameVersion: {"System.Platform.ATV2":false,"System.Platform.Android":false,"System.Platform.Darwin":false,"System.Platform.IOS":false,"System.Platform.Linux":false,"System.Platform.Linux.RaspberryPi":false,"System.Platform.OSX":false,"System.Platform.Windows":true}
        2021-04-29 15:06:03.316 - debug: kodi.1 (22900) GetVolume: {"muted":false,"volume":100}
        2021-04-29 15:06:03.325 - debug: kodi.1 (22900) Error GetChannels: PVR is not use?{"response":{"code":-32100,"message":"Failed to execute method."}}
        2021-04-29 15:06:04.605 - debug: kodi.1 (22900) Error: Error: Socket error: Invalid WebSocket frame: invalid UTF-8 sequence
        2021-04-29 15:06:04.607 - debug: kodi.1 (22900) Connection closed
        2021-04-29 15:06:09.608 - debug: kodi.1 (22900) KODI connecting to: 192.168.178.100:9090
        2021-04-29 15:06:09.701 - info: kodi.1 (22900) KODI connected
        2021-04-29 15:06:09.706 - debug: kodi.1 (22900) GetPortWebServer: {"value":8080}
        2021-04-29 15:06:09.782 - debug: kodi.1 (22900) GetNameVersion: {"System.Platform.ATV2":false,"System.Platform.Android":false,"System.Platform.Darwin":false,"System.Platform.IOS":false,"System.Platform.Linux":false,"System.Platform.Linux.RaspberryPi":false,"System.Platform.OSX":false,"System.Platform.Windows":true}
        2021-04-29 15:06:09.785 - debug: kodi.1 (22900) GetVolume: {"muted":false,"volume":100}
        2021-04-29 15:06:09.797 - debug: kodi.1 (22900) Error GetChannels: PVR is not use?{"response":{"code":-32100,"message":"Failed to execute method."}}
        2021-04-29 15:06:11.053 - debug: kodi.1 (22900) Error: Error: Socket error: Invalid WebSocket frame: invalid UTF-8 sequence
        2021-04-29 15:06:11.056 - debug: kodi.1 (22900) Connection closed
        • J JJ_1
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @jj_1 sagte in Kodi App läuft nich binkt immer wieder gelb:
          GetChannels
          so wie es aussieht hat sich die api von kodi an der stelle minimal verändert
          https://kodi.wiki/view/JSON-RPC_API/v8#PVR.GetChannels (Krypton)
          https://kodi.wiki/view/JSON-RPC_API/v12#PVR.GetChannels (Matrix)
          Aus diesem Grund kann der Adapter die Rückgabewerte nicht richtig verarbeiten und stürzt dann ab.
          Du kannst es mal mit einem der 3 älteren Adapterverionen probieren.
          Wenn das nicht hilft, dann fällt dieser Adapter für dich aus.
          Wie gesagt, evtl kannst du es mit node-red probieren, welches ebenfalls in iobroker integriert werden kann. Auch da gibt es Module für kodi, aber auch hier musst du eher auf die älteren Verionen zurückgreifen, da dort sonst ein ähnlicher Fehler kommt.
          Meine Adapter und Widgets
          Links im Profil
          • OliverIOO OliverIO
            GetChannels
            JJ_1
            @oliverio
            ich habe es swohl mit der 17. matrix probiert ist in beiden Versionen das gleiche Bild. Der log war von Matrix
            J OliverIOO 2 Antworten Letzte Antwort
            • J JJ_1
              @oliverio
              JJ_1
              @jj_1 Mit den 3 älteren geht es auch nicht
              • J JJ_1
                JJ_1
                @jj_1
                Kann man die Abfrage rausschmeisen die brauch ich nicht.
                • J JJ_1
                  @jj_1
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @jj_1
                  das wird schwer.
                  keine ahnung ob auf den daten die da abgefragt werden irgendwas anderes basiert
                  da wurstelt man dann nur im code rum und macht es meist schlimmer.
                  kannst es aber gern probieren:
                  https://github.com/instalator/ioBroker.kodi/blob/c94660abcbb229f17d4258bce4cbd17bbe446636/kodi.js#L581
                  und hoffe darauf, das bei den nachfolgenden befehlen sich nicht auch noch was geändert hat.
                  Links im Profil
                  • J JJ_1
                    @oliverio
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @oliverio
                    verstehe ich nicht ganz
                    17 ist krypton
                    19 ist matrix
                    https://de.wikipedia.org/wiki/Kodi_(Software)#Veröffentlichungen
                    du hast doch geschrieben, das es kode 17 sein muss wegen madvr
                    mein kodi 18 funktioniert mit dem iobroker adapter
                    Links im Profil
                      @oliverio
                      17 ist krypton
                      19 ist matrix
                      JJ_1
                      @oliverio
                      Sorry ist etwas verwirrend.
                      Habe 2 System
                      1. Heim Kino Kodi 17.6
                      2. Büro Rechner mit Matrix. Zum Testen wann ich es auch im Kino umstellen kann. Da muss ich aber erst den Skin und das madvr mit externen
                        Player integrieren.
                      Auf dem Matrix habe ich es einmal zum laufen bekommen doch dann ist mir der ganze RB abgeschhmirt.
                      Nach neuinstallation. Geht es mit Matrix auch nicht mehr. Bin gerade bei den ersten schritten mit RB und
                      JS. Habe früher Assembler und C++ programmiert. Das ist schon eine ganze weile her muss mich erst mal einarbeiten
                      deshalb die vielen blöden Anfänger fragen.
                      • J JJ_1
                        @oliverio
                        Habe 2 System
                          Player integrieren.
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @oliverio
                        Habe 2 System
                          Player integrieren.
                        alles gut. javascript kann etwas verwirrend sein mit deinen Vorkenntnissen. die asynchronität und ereignissteuerung hat mich damals auch einige gehirnverdrehungen gekostet.
                        irgendwann geht es aber.
                        Links im Profil
                        • ESP8266E Offline
                          ESP8266E Offline
                          ESP8266
                          schrieb am zuletzt editiert von ESP8266
                          Dann hohle ich mal den Thread wieder aus der Versenkung hoch.
                          Auch ich habe Probleme auf die Neue Adapter Version upzugraden. Selbst die Originale Version vom https://github.com/instalator/iobroker.kodi geht nicht mehr.
                          Die einzigste die noch Funktioniert ist die 2.0.7.
                          Getestet mit Leia 18.7 und Matrix 19.3. auf verschiedenen Geräten.
                          Das komische dabei ist, das es bei manchen Usern funktioniert, das bereitet mir Kopfzerbrechen.
                          Hier eine Debug.log Ausgabe:
                          kodi.1
                          	2022-01-18 11:53:39.323	debug	Connection closed
                          kodi.1
                          	2022-01-18 11:53:39.316	debug	Error: Error: Socket error: Invalid WebSocket frame: invalid UTF-8 sequence
                          kodi.1
                          	2022-01-18 11:53:37.389	debug	Error GetChannels: PVR is not use?{"response":{"code":-32100,"message":"Failed to execute method."}}
                          kodi.1
                          	2022-01-18 11:53:37.382	debug	GetVolume: {"muted":false,"volume":100}
                          kodi.1
                          	2022-01-18 11:53:37.379	debug	GetNameVersion: {"System.Platform.ATV2":false,"System.Platform.Android":true,"System.Platform.Darwin":false,"System.Platform.IOS":false,"System.Platform.Linux":true,"System.Platform.Linux.RaspberryPi":true,"System.Platform.OSX":false,"System.Platform.Windows":false}
                          kodi.1
                          	2022-01-18 11:53:37.344	debug	GetPortWebServer: {"value":8080}
                          kodi.1
                          	2022-01-18 11:53:37.338	info	KODI connected
                          kodi.1
                          	2022-01-18 11:53:37.212	debug	KODI connecting to: 192.168.XX.XX:9090
                          kodi.1
                          	2022-01-18 11:53:32.211	debug	Connection closed
                          kodi.1
                          	2022-01-18 11:53:32.205	debug	Error: Error: Socket error: Invalid WebSocket frame: invalid UTF-8 sequence
                          kodi.1
                          	2022-01-18 11:53:30.141	debug	Error GetChannels: PVR is not use?{"response":{"code":-32100,"message":"Failed to execute method."}}
                          kodi.1
                          	2022-01-18 11:53:30.124	debug	GetVolume: {"muted":false,"volume":100}
                          kodi.1
                          	2022-01-18 11:53:30.121	debug	GetNameVersion: {"System.Platform.ATV2":false,"System.Platform.Android":true,"System.Platform.Darwin":false,"System.Platform.IOS":false,"System.Platform.Linux":true,"System.Platform.Linux.RaspberryPi":true,"System.Platform.OSX":false,"System.Platform.Windows":false}
                          kodi.1
                          	2022-01-18 11:53:30.095	debug	GetPortWebServer: {"value":8080}
                          kodi.1
                          	2022-01-18 11:53:30.090	info	KODI connected
                          kodi.1
                          	2022-01-18 11:53:29.972	debug	KODI connecting to: 192.168.XX.XX:9090
                          kodi.1
                          	2022-01-18 11:53:24.970	debug	Connection closed
                          kodi.1
                          	2022-01-18 11:53:24.962	debug	Error: Error: Socket error: Invalid WebSocket frame: invalid UTF-8 sequence
                          kodi.1
                          	2022-01-18 11:53:23.047	debug	Error GetChannels: PVR is not use?{"response":{"code":-32100,"message":"Failed to execute method."}}
                          kodi.1
                          	2022-01-18 11:53:23.037	debug	GetVolume: {"muted":false,"volume":100}
                          kodi.1
                          	2022-01-18 11:53:23.032	debug	GetNameVersion: {"System.Platform.ATV2":false,"System.Platform.Android":true,"System.Platform.Darwin":false,"System.Platform.IOS":false,"System.Platform.Linux":true,"System.Platform.Linux.RaspberryPi":true,"System.Platform.OSX":false,"System.Platform.Windows":false}
                          kodi.1
                          	2022-01-18 11:53:22.994	debug	GetPortWebServer: {"value":8080}
                          kodi.1
                          	2022-01-18 11:53:22.982	info	KODI connected
                          Wo ist was geändert worden? Das kann nur im Adapter oder im Kodi-WS gewesen sein.
                          Denn dann würde die 2.0.7. auch nicht laufen.
                          • C Offline
                            cybtrash
                            schrieb am zuletzt editiert von cybtrash
                            Bei mir läuft das Addon (v2.0.8) auch nicht richtig.
                            Im LOG erscheint alle paar Sekunden die Nachricht, dass die Verbindung neu aufgebaut wurde.
                            Stelle ich LOG auf "Alles" ist das der Fehler, bei dem das Addon abstürzt und neu startet:
                            2022-11-10 16:23:26.105 debug Connection closed
                            2022-11-10 16:23:26.101 debug Error: Error: Socket error: Invalid WebSocket frame: invalid UTF-8 sequence
                            2022-11-10 16:23:25.015 debug GetVolume: {"muted":false,"volume":55}
                            2022-11-10 16:23:25.012 debug GetNameVersion: {"System.Platform.ATV2":false,"System.Platform.Android":false,"System.Platform.Darwin":false,"System.Platform.IOS":false,"System.Platform.Linux":true,"System.Platform.Linux.RaspberryPi":true,"System.Platform.OSX":false,"System.Platform.Windows":false}
                            2022-11-10 16:23:24.955 debug GetPortWebServer: {"value":8080}
                            2022-11-10 16:23:24.946 info KODI connected
                            • C cybtrash
                              sigi234S Online
                              sigi234S Online
                              @cybtrash
                              Welche Kodi Version?
                              Zeig mal die Einstellungen vom Adapter und Kodi Dienste
                              ESP8266E 1 Antwort Letzte Antwort
                              • sigi234S sigi234
                                @cybtrash
                                ESP8266E Offline
                                ESP8266E Offline
                                ESP8266
                                Endlich bin ich nicht mehr alleine.
                                Es lässt sich ja auch kein Trigger absetzen in der 2.0.8 Version.
                                Auch bei Matrix 19.4 auf einem Nvidia Shield das gleiche verhalten.
                                siehe https://github.com/iobroker-community-adapters/iobroker.kodi/issues/6
                                • apollon77A Offline
                                  Also wer mit versuchen will ... oben genanntes Issue
                                  • apollon77A apollon77
                                    ESP8266E Offline
                                    ESP8266E Offline
                                    ESP8266
                                    @apollon77 , es funzt. Hatte aber gut 10 Min. vom Github gedauert.
                                    Danke nochmals für deine Mühe.....👍
                                      Ok, bitte auf GitHub nochmal ein Debu-Log posten das ich mal schauen kann.
                                      Ich aktualisiere dann noch kleinkram am Projekt und werde die nächsten tage neue Version veröffentlichen.
                                      Für die hier mitlesenden: Scheinbar sendet Kodi an einer Stelle ungültige Zeichen raus, wo sich die Websocket-Library (an sich zurecht) gestört hat. Ich habe jetzt den Check ausgeschaltet - welche Nebeneffekte das hat sehen wir vllt noch ;-)
                                      Am Ende aber ein Thema von Kodi ... aber naja.
                                      Ingo
                                      • ESP8266E Offline
                                        ESP8266E Offline
                                        ESP8266
                                        @apollon77 , das Log ist 7,5 MB groß. Da wird auch mein NAS mit ausgelesen.
                                        Das kann ich nicht ausschalten. Ich werde den Pfad in Kodi nicht löschen.
                                        Das wird jetzt auch alles gefunden.
                                        Wohin mit dem Log? Mein NAS Inhalt geht keinen was an....ausser dir.
                                        • ESP8266E ESP8266
                                          @esp8266 Dann Email an iobroker@fischer-ka.de mit Verweis aufs Github issue oder hier her als Link
