  4. (gelöst)Telegram
    6.5k
(gelöst)Telegram
25 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • ostseereiterO ostseereiter
    Hallo Freunde hat es jemand von euch auch Telegram adapter ist gelb.
    code_text
    ```telegram.0	2021-04-28 10:14:01.568	error	(30241) Exception-Code: EFATAL: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
    telegram.0	2021-04-28 10:14:01.567	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
    telegram.0	2021-04-28 10:14:01.567	error	at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
    telegram.0	2021-04-28 10:14:01.567	error	at emitErrorNT (internal/streams/destroy.js:92:8)
    telegram.0	2021-04-28 10:14:01.567	error	at TLSSocket.emit (events.js:314:20)
    telegram.0	2021-04-28 10:14:01.567	error	at TLSSocket.socketErrorListener (_http_client.js:427:9)
    telegram.0	2021-04-28 10:14:01.567	error	at ClientRequest.emit (events.js:314:20)
    telegram.0	2021-04-28 10:14:01.567	error	at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
    telegram.0	2021-04-28 10:14:01.567	error	at Request.emit (events.js:314:20)
    telegram.0	2021-04-28 10:14:01.567	error	at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    telegram.0	2021-04-28 10:14:01.567	error	at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
    telegram.0	2021-04-28 10:14:01.567	error	at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
    telegram.0	2021-04-28 10:14:01.567	error	at new RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15)
    telegram.0	2021-04-28 10:14:01.567	error	(30241) RequestError: Error: getaddrinfo EAI_AGAIN api.telegram.org
    telegram.0	2021-04-28 10:14:01.566	error	(30241) unhandled promise rejection: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
    telegram.0	2021-04-28 10:14:01.565	error	(30241) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    telegram.0	2021-04-28 10:13:41.003	info	(30241) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.21.0, js-controller: 3.2.16
    Ahnungsbefreit
    @ostseereiter Natürlich war mein Telegram Adapter auch schon mal "gelb". Aber um Dir helfen zu können, brauchen wir mehr Details: System, Versionen von Adapter und NodeJS, das Übliche halt...
    ostseereiterO 1 Antwort Letzte Antwort
    • A Ahnungsbefreit
      ostseereiterO Offline
      ostseereiter
      @ahnungsbefreit
      hier sind die Angaben
      Platform
      linux
      Betriebssystem
      linux
      Architektur
      x64
      CPUs
      Geschwindigkeit
      1623 MHz
      Modell
      AMD G-T56N Processor
      RAM
      7.27 GB
      System Betriebszeit
      17 T. 13:52:25
      Node.js
      v12.21.0 (Es gibt eine neuere Version: v12.22.1)
      NPM
      6.14.11
      telegram 1.80
      Gruß OSR
      Plattform
        @ahnungsbefreit
        Platform
        linux
        Betriebssystem
        linux
        Architektur
        x64
        CPUs
        Geschwindigkeit
        1623 MHz
        Modell
        RAM
        7.27 GB
        System Betriebszeit
        17 T. 13:52:25
        Node.js
        NPM
        6.14.11
        telegram 1.80
        @ostseereiter
        Da kann wohl
        api.telegram.org
        nicht erreicht werden.
          Ahnungsbefreit
          @ostseereiter Wenn ich Google richtig deute, ist das wohl ein DNS / Netzwerk Problem. Hast Du kürzlich irgendwas geändert?
            @ostseereiter
            Da kann wohl
            api.telegram.org
            ostseereiter
            @thomas-braun sagte in Telegram:
            api.telegram.org
            Ja habe pihole neu instaliert.
            Gruß OSR
            Plattform
              api.telegram.org
              @ostseereiter
              Dann würde ich in der Ecke mal buddeln.
                @ostseereiter
                ostseereiter
                Habe ich abgestellt aber immer noch gelb
                Gruß OSR
                Plattform
                  @ostseereiter
                  Dann mal mit Netzwerk-Grundwerkzeug geschaut?
                  ping api.telegram.org
                  traceroute api.telegram.org
                    @ostseereiter
                    ostseereiter
                    Windows Rechner
                    PS C:\WINDOWS\system32> ping api.telegram.org
                    Ping wird ausgeführt für api.telegram.org [2001:67c:4e8:f004::9] mit 32 Bytes Daten:
                    Antwort von 2001:67c:4e8:f004::9: Zeit=33ms
                    Antwort von 2001:67c:4e8:f004::9: Zeit=30ms
                    Ping-Statistik für 2001:67c:4e8:f004::9:
                        Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                        (0% Verlust),
                    Ca. Zeitangaben in Millisek.:
                        Minimum = 30ms, Maximum = 33ms, Mittelwert = 32ms
                    PS C:\WINDOWS\system32> traceroute api.telegram.org
                    traceroute : Die Benennung "traceroute" wurde nicht als Name eines Cmdlet, einer Funktion, einer Skriptdatei oder
                    eines ausführbaren Programms erkannt. Überprüfen Sie die Schreibweise des Namens, oder ob der Pfad korrekt ist (sofern
                    enthalten), und wiederholen Sie den Vorgang.
                    In Zeile:1 Zeichen:1
                    + traceroute api.telegram.org
                        + CategoryInfo          : ObjectNotFound: (traceroute:String) [], CommandNotFoundException
                        + FullyQualifiedErrorId : CommandNotFoundException
                    Iobroker Rechner
                    andy@debian:~$ ping api.telegram.org
                    ping: api.telegram.org: Temporärer Fehler bei der Namensauflösung
                    andy@debian:~$ traceroute api.telegram.org
                    Gruß OSR
                    Plattform
                    Thomas BraunT A 2 Antworten Letzte Antwort
                      Windows Rechner
                          (0% Verlust),
                      Iobroker Rechner
                      @ostseereiter
                      Der Windows-Rechner interessiert nicht.
                      Der Linux-Server ist interessant.
                      Wo bekommt der seine DNS-Informationen her?
                      Lokal fix eingetragen oder vom Router?
                        Windows Rechner
                            (0% Verlust),
                        Iobroker Rechner
                        Ahnungsbefreit
                        @ostseereiter Also scheinbar ein DNS Problem.
                          @ostseereiter
                          ostseereiter
                          vom Router
                          Gruß OSR
                          Plattform
                            vom Router
                            @ostseereiter
                            Starte das Netzwerk mal neu:
                            sudo /etc/init.d/networking restart
                            oder
                            sudo systemctl restart networking.service
                              @ostseereiter
                              oder
                              ostseereiter
                              Musste den Rechner komplett neu starten. also Bring und Telegram waren betroffen.
                              Nach dem Neustart alles grün das heißt es hat bestimmt was mit pihole zu tun nun ist natürlich die Frage welche adresse setzte ich dann in den Pihole auf withlist?
                              Gruß OSR
                              Plattform
                                BananaJoeB Offline
                                BananaJoeB Offline
                                BananaJoe
                                @ostseereiter du kannst auch deinen ioBroker-Rechner in die Ausnahmeliste setzen:
                                Im Group-Management - Groups eine Gruppe ByPass erstellen
                                Unter Clients den ioBroker-Host anlegen und der ByPass Gruppe zuordnen (ggf. mit seiner IPv4 und seiner IPv6 Adresse).
                                Der Client darf nur Mitglied in der neuen ByPass Gruppe sein
                                Dann unter AdList hinten bei allen Einträgen die ByPass Gruppe aus eben diesen entfernen (unter Group assignment)
                                • BananaJoeB BananaJoe
                                  BananaJoeB Offline
                                  BananaJoeB Offline
                                  BananaJoe
                                  @bananajoe sagte in Telegram:
                                  Nachtrag: oder du setzt den DNS für den ioBroker eben nicht auf den piHole sondern z.B. auf 8.8.8.8 extern
                                    ostseereiter
                                    @bananajoe
                                    Danke ist soviel Input auf einmal.
                                    wie und wo macht man dies:Nachtrag: oder du setzt den DNS für den ioBroker eben nicht auf den piHole sondern z.B. auf 8.8.8.8 extern?
                                    Gruß OSR
                                    Plattform
                                      @bananajoe
                                      BananaJoeB Offline
                                      BananaJoeB Offline
                                      BananaJoe
                                      @ostseereiter sagte in Telegram:
                                      @bananajoe
                                      Du hast - scheinbar - ein Debian System.
                                      Versuch mal
                                      sudo nano /etc/netplan/00-installer-config.yaml
                                      falls es die Datei nicht gibt schau nach was für Dateien in dem Ordner sind.
                                      Da gibt es dann einen Abschnitt nameservers - da die Adresse ändern und rebooten.
                                      Ist dein System älter könnte es unter
                                      nano /etc/network/interfaces
                                      klappen
                                        @bananajoe
                                        Versuch mal
                                        klappen
                                        ostseereiter
                                        @bananajoe hallo
                                        so sieht es bei mir aus
                                        # This file describes the network interfaces available on your system
                                        # and how to activate them. For more information, see interfaces(5).
                                        source /etc/network/interfaces.d/*
                                        # The loopback network interface
                                        auto lo
                                        iface lo inet loopback
                                        # The primary network interface
                                        allow-hotplug enp3s0
                                        iface enp3s0 inet dhcp
                                        # This is an autoconfigured IPv6 interface
                                        iface enp3s0 inet6 auto
                                        Gruß OSR
                                        Plattform
                                          @bananajoe hallo
                                          auto lo
                                          BananaJoeB Offline
                                          BananaJoeB Offline
                                          BananaJoe
                                          @ostseereiter dann bekommt dein iobroker wohl die IP per DHCP :-)
                                          entweder auf feste Adresse umstellen oder dein DHCP Server muss ihm einen anderen DNS zuweisen.
