  4. Probleme mit hs100-Adapter
51 Beiträge 8 Kommentatoren 7.4k Aufrufe 6 Beobachtet
  • A Arctic63
    @arteck sorry, bin neu in der Materie, weiss noch nicht wer was hier braucht :-)
    hier mal der letzte Stopp.
    host.raspberrypi4-iob	2021-04-13 10:32:14.561	error	Caught by controller[0]: TCP 192.168.0.129:9999 Error: TCP Timeout after 10000ms
    hs100.0	2021-04-13 10:32:13.979	warn	(7442) Terminated (UNCAUGHT_EXCEPTION): Without reason
    hs100.0	2021-04-13 10:32:13.978	info	(7442) terminating
    hs100.0	2021-04-13 10:32:13.977	info	(7442) cleaned everything up...
    hs100.0	2021-04-13 10:32:13.970	warn	at processTimers (internal/timers.js:497:7)
    hs100.0	2021-04-13 10:32:13.970	warn	at listOnTimeout (internal/timers.js:554:17)
    hs100.0	2021-04-13 10:32:13.970	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
    hs100.0	2021-04-13 10:32:13.970	warn	192.168.0.129:9999 {"system":{"get_sysinfo":{}}}
    hs100.0	2021-04-13 10:32:13.970	warn	(7442) Info Message setDevice: Error: TCP Timeout after 10000ms
    hs100.0	2021-04-13 10:32:13.964	error	192.168.0.129:9999 {"emeter":{"get_realtime":{}}}
    hs100.0	2021-04-13 10:32:13.964	error	(7442) TCP Timeout after 10000ms
    hs100.0	2021-04-13 10:32:13.964	error	at processTimers (internal/timers.js:497:7)
    hs100.0	2021-04-13 10:32:13.964	error	at listOnTimeout (internal/timers.js:554:17)
    hs100.0	2021-04-13 10:32:13.964	error	at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
    hs100.0	2021-04-13 10:32:13.964	error	(7442) Error: TCP Timeout after 10000ms
    hs100.0	2021-04-13 10:32:13.963	error	192.168.0.129:9999 {"emeter":{"get_realtime":{}}}
    hs100.0	2021-04-13 10:32:13.963	error	(7442) unhandled promise rejection: TCP Timeout after 10000ms
    hs100.0	2021-04-13 10:32:13.962	error	(7442) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2021-04-13 10:31:33.234	info	(7442) Start with IP : 192.168.0.129
    hs100.0	2021-04-13 10:31:33.173	info	(7442) Start with IP : 192.168.0.5
    hs100.0	2021-04-13 10:31:33.137	info	(7442) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.22.1, js-controller: 3.2.16
    host.raspberrypi4-iob	2021-04-13 10:31:31.911	info	instance system.adapter.hs100.0 started with pid 7442
    host.raspberrypi4-iob	2021-04-13 10:31:01.893	info	Restart adapter system.adapter.hs100.0 because enabled
    host.raspberrypi4-iob	2021-04-13 10:31:01.893	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.raspberrypi4-iob	2021-04-13 10:31:01.893	error	Caught by controller[2]: }
    Mod-Edit: Code in </> Code-Tag gepackt!
    arteckA Offline
    arteckA Offline
    arteck
    @arctic63 sagte in Probleme mit hs100-Adapter:
    das ist das problem .. da kann ich aber nix machen.. das passiert nicht im adapter sondern ausserhalb...
    Wlan gecheckt ?? vielleicht spinnt die Dose ?
    • arteckA arteck
      Arctic63
      @arteck mit dem Wlan ist soweit alles ok, die eine Dose ist 2m vom Router und die andere 5m vom Router entfernt, ist doch dann aber merkwürdig das die beiden Dosen gleichzeitig aussteigen.
      • surfer09S Offline
        surfer09S Offline
        surfer09
        Guten Morgen zusammen,
        gibt es zu diesem Problem schon Neuigkeiten? Ein bisschen merkwürdig ist das ja schon, dass mehrere hier das Problem haben... somit offenbar kein Einzelfall, was mich indirekt auch etwas beruhigt :-)
        Gruß surfer ;-)
        • arteckA Offline
          arteckA Offline
          arteck
          also alle jubel Jahre hab ichs auch... es scheint aber von den Dosen zu kommen.
          • surfer09S Offline
            surfer09S Offline
            surfer09
            schrieb am zuletzt editiert von surfer09
            @arteck: Dann müsste er aber doch bei Verbindung den totalNow Wert übertragen?! Bei mir kommt da nichts mehr an, obwohl sich der Zeitstempel aktualisiert.
            Wenn es "nur" diese zwischenzeitlichen Abbrüche wären, könnte ich damit ja noch leben...
            • surfer09S surfer09
              arteckA Offline
              arteckA Offline
              arteck
              @surfer09 jetzt kann ich dir folgen
              installiere nochmal .. und nochmal debug info bitte
              surfer09S 1 Antwort Letzte Antwort
              • arteckA arteck
                surfer09S Offline
                surfer09S Offline
                surfer09
                @arteck Guten Morgen, anbei nochmal die Ausgabe mit debug-LOG
                hs100.0	2021-04-25 10:51:20.049	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:51:19.759	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:51:19.468	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:51:19.032	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:51:19
                hs100.0	2021-04-25 10:50:54.051	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:50:53.761	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:50:53.471	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:50:53.035	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:50:53
                hs100.0	2021-04-25 10:50:28.070	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:50:27.779	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:50:27.488	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:50:27.052	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:50:27
                hs100.0	2021-04-25 10:50:02.086	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:50:01.796	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:50:01.506	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:50:01.070	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:50:01
                hs100.0	2021-04-25 10:49:35.886	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:49:35.596	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:49:35.309	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:49:34.907	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:49:34
                hs100.0	2021-04-25 10:49:09.605	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:49:09.315	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:49:09.025	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:49:08.589	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:49:08
                hs100.0	2021-04-25 10:48:43.316	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:48:43.025	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:48:42.741	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:48:42.299	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:48:42
                hs100.0	2021-04-25 10:48:17.190	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:48:16.890	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:48:16.600	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:48:16.165	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:48:16
                hs100.0	2021-04-25 10:47:50.896	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:47:50.606	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:47:50.315	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:47:49.880	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:47:49
                hs100.0	2021-04-25 10:47:24.757	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:47:24.466	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:47:24.178	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:47:23.740	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:47:23
                hs100.0	2021-04-25 10:46:58.621	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:46:58.331	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:46:58.040	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:46:57.605	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:46:57
                hs100.0	2021-04-25 10:46:32.490	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:46:32.200	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:46:31.909	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:46:31.474	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:46:31
                hs100.0	2021-04-25 10:46:06.364	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:46:06.074	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:46:05.784	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:46:05.348	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:46:05
                hs100.0	2021-04-25 10:45:40.237	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:45:39.947	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:45:39.657	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:45:39.221	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:45:39
                hs100.0	2021-04-25 10:45:14.109	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:45:13.818	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:45:13.527	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:45:13.092	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:45:13
                hs100.0	2021-04-25 10:44:47.836	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:44:47.545	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:44:47.255	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:44:46.964	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:44:46
                hs100.0	2021-04-25 10:44:21.707	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:44:21.416	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:44:21.126	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:44:20.690	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:44:20
                hs100.0	2021-04-25 10:43:55.579	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:43:55.288	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:43:54.998	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:43:54.562	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:43:54
                hs100.0	2021-04-25 10:43:29.455	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:43:29.161	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:43:28.870	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:43:28.435	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:43:28
                hs100.0	2021-04-25 10:43:03.177	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:43:02.887	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:43:02.596	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:43:02.161	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:43:02
                hs100.0	2021-04-25 10:42:37.049	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:42:36.758	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:42:36.468	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:42:36.033	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:42:36
                hs100.0	2021-04-25 10:42:10.921	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:42:10.631	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:42:10.342	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:42:09.905	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:42:09
                hs100.0	2021-04-25 10:41:44.793	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:41:44.503	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:41:44.213	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:41:43.777	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:41:43
                hs100.0	2021-04-25 10:41:18.375	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:41:18.084	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:41:17.794	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:41:17.358	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:41:17
                hs100.0	2021-04-25 10:40:52.102	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:40:51.812	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:40:51.522	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:40:51.086	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:40:51
                hs100.0	2021-04-25 10:40:25.829	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:40:25.539	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:40:25.249	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:40:24.813	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:40:24
                hs100.0	2021-04-25 10:39:59.555	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:39:59.265	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:39:58.974	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:39:58.539	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = true update = 2021.4.25 10:39:58
                hs100.0	2021-04-25 10:39:33.282	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:39:32.993	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:39:32.702	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:39:32.266	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = false update = 2021.4.25 10:39:32
                hs100.0	2021-04-25 10:39:07.009	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:39:06.719	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:39:06.428	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:39:05.992	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = false update = 2021.4.25 10:39:05
                hs100.0	2021-04-25 10:38:40.870	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:38:40.580	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:38:40.290	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:38:39.855	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = false update = 2021.4.25 10:38:39
                hs100.0	2021-04-25 10:38:14.597	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:38:14.307	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:38:14.017	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:38:13.581	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = false update = 2021.4.25 10:38:13
                hs100.0	2021-04-25 10:37:48.325	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                hs100.0	2021-04-25 10:37:48.034	debug	(7680) Month value Model : HS110(EU) IP : 192.168.1.181
                hs100.0	2021-04-25 10:37:47.744	debug	(7680) Refresh Data HS110 192.168.1.181
                hs100.0	2021-04-25 10:37:47.308	debug	(7680) Refresh 192.168.1.181 Model = HS110(EU) state = false update = 2021.4.25 10:37:47
                hs100.0	2021-04-25 10:37:22.053	debug	(7680) Day value for Model : HS110(EU) Energy : 0 IP : 192.168.1.181
                • arteckA Offline
                  arteckA Offline
                  arteck
                  die Dose scheint die Daten verloren zu haben.. siehtst du was in der App ?? Tagesverbrauchswerte ?
                  • arteckA arteck
                    surfer09S Offline
                    surfer09S Offline
                    surfer09
                    @arteck Du hast Recht! In der App werden die Werte auch nicht mehr angezeigt. Scheinbar seit dem letzten Firmware Update... Zumindest habe ich das Problem seit dem Update. !
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @surfer09 ahhh siehste
                      • surfer09S Offline
                        surfer09S Offline
                        surfer09
                        Nach Rücksprache mit dem TP-Link Support sollen die Dosen einmal zurückgesetzt werden und dann wieder die Daten liefern. Zurückgesetzt habe ich sie jetzt, mal sehen, ob die Daten jetzt wieder geliefert werden.
