  4. iobroker stürzt ab, MISCONF Redis is configured to save RDB
    1.9k
iobrokerhostredis
19 Beiträge 4 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • coyoteC Offline
    coyoteC Offline
    coyote
    Hey,
    sporadisch stürzt bei mir iobroker mal ab. Laut LOG sieht es so aus, als könnte REDIS nicht schreiben. Nach manuellem starten des iobroker hosts läuft alles wieder ohne Probleme.
    Jemand ne Idee wo ich da suchen könnte?
    objects/states laufen beide mit REDIS
    Hier noch das LOG dazu:
    2021-04-16 18:54:45.897  - info: javascript.0 (14631) script.js.Fenster_offen_mit_Drehgriff: Anzahl Fenster: 25 - davon Fenster auf: 4
    2021-04-16 18:54:46.336  - info: linux-control.0 (14783) getting data from ZoneminderVM (192.168.66.145:22)
    2021-04-16 18:54:46.841  - info: linux-control.0 (14783) [getConnection] Host 'RepetierPi' (192.168.66.204:22) seems not to be online
    2021-04-16 18:54:49.430  - info: linux-control.0 (14783) [getConnection] Host 'ZoneminderVM' (192.168.66.145:22) seems not to be online
    2021-04-16 18:55:00.056  - info: host.debian instance system.adapter.dwd.0 started with pid 17111
    2021-04-16 18:55:13.097  - info: linux-control.0 (14783) getting data from ioBrokerVM (192.168.66.68:22)
    2021-04-16 18:56:27.004  - info: mqtt.0 (15883) Client [MHI_Wintergarten] connection closed: timeout
    2021-04-16 18:56:27.020  - info: mqtt.0 (15883) Client [MHI_Schlafzimmer] connection closed: timeout
    2021-04-16 18:56:27.020  - info: mqtt.0 (15883) Client [mqttjs_9e5ebda7] connection closed: timeout
    2021-04-16 18:56:27.323  - info: mqtt.0 (15883) Client [MHI_Schlafzimmer] connected with secret 1618592187048_4949
    2021-04-16 18:56:27.314  - info: harmony.0 (28479) [CONNECT] lost Connection to CoyoteHarmonyHub (192.168.66.51)
    2021-04-16 18:56:27.547  - info: mqtt.0 (15883) Client [MHI_Wintergarten] connected with secret 1618592187232_9902
    2021-04-16 18:56:27.550  - info: mqtt.0 (15883) Client [MHI_Schlafzimmer] reconnected. Old secret 1618592187048_4949. New secret 1618592187240_3111
    2021-04-16 18:56:27.556  - info: mqtt.0 (15883) Client [MHI_Wintergarten] reconnected. Old secret 1618592187232_9902. New secret 1618592187241_9511
    2021-04-16 18:56:27.564  - info: mqtt.0 (15883) Client [wasser] reconnected. Old secret 1618584213554_4427. New secret 1618592187241_9273
    2021-04-16 18:56:27.576  - info: mqtt.0 (15883) Client [MHI_Schlafzimmer] reconnected. Old secret 1618592187240_3111. New secret 1618592187253_5446
    2021-04-16 18:56:27.603  - info: mqtt.0 (15883) Client [MHI_Wintergarten] reconnected. Old secret 1618592187241_9511. New secret 1618592187254_7745
    2021-04-16 18:56:27.695  - info: mqtt.0 (15883) Client [MHI_Schlafzimmer] subscribes on "MHI_Schlafzimmer/set/#" with regex /^MHI_Schlafzimmer\.set\..*/
    2021-04-16 18:56:27.700  - info: mqtt.0 (15883) Client [MHI_Schlafzimmer] subscribes on "MHI_Schlafzimmer/set/#"  with regex /^mqtt\.0\.MHI_Schlafzimmer\.set\..*/
    2021-04-16 18:56:27.710  - info: mqtt.0 (15883) Client [MHI_Wintergarten] subscribes on "MHI_Wintergarten/set/#" with regex /^MHI_Wintergarten\.set\..*/
    2021-04-16 18:56:27.711  - info: mqtt.0 (15883) Client [MHI_Wintergarten] subscribes on "MHI_Wintergarten/set/#"  with regex /^mqtt\.0\.MHI_Wintergarten\.set\..*/
    2021-04-16 18:56:28.479  - info: sonoff.0 (15298) Client [Sonoff4ch_2] connection closed: closed
    2021-04-16 18:56:28.958  - info: sonoff.0 (15298) Client [Sonoff4ch_1] reconnected. Old secret 1618588294997_8126. New secret 1618592188219_9040
    2021-04-16 18:56:28.984  - info: sonoff.0 (15298) Client [Sonoff4ch_2] connected with secret 1618592188266_7142
    2021-04-16 18:56:28.986  - info: sonoff.0 (15298) Client [Sonoff4ch_1] reconnected. Old secret 1618592188219_9040. New secret 1618592188278_3421
    2021-04-16 18:56:28.987  - info: sonoff.0 (15298) Client [Sonoff4ch_2] reconnected. Old secret 1618592188266_7142. New secret 1618592188296_5223
    2021-04-16 18:56:28.990  - info: sonoff.0 (15298) Client [Sonoff_DualR2] reconnected. Old secret 1618584205950_8197. New secret 1618592188383_7159
    2021-04-16 18:56:29.001  - info: sonoff.0 (15298) Client [Ultraschall] reconnected. Old secret 1618584207538_5573. New secret 1618592188396_16
    2021-04-16 18:56:29.007  - info: sonoff.0 (15298) Client [Gosund_SP111_2] reconnected. Old secret 1618584203033_6209. New secret 1618592188398_5824
    2021-04-16 18:56:29.007  - info: sonoff.0 (15298) Client [Sonoff4ch_1] reconnected. Old secret 1618592188278_3421. New secret 1618592188413_5550
    2021-04-16 18:56:29.008  - info: sonoff.0 (15298) Client [Sonoff4ch_2] reconnected. Old secret 1618592188296_5223. New secret 1618592188424_8847
    2021-04-16 18:56:29.136  - info: sonoff.0 (15298) Client [Gosund_SP111_2] connection closed: closed
    2021-04-16 18:56:29.140  - info: sonoff.0 (15298) Client [Ultraschall] connection closed: closed
    2021-04-16 18:56:29.140  - info: sonoff.0 (15298) Client [Sonoff_DualR2] connection closed: closed
    2021-04-16 18:56:29.859  - info: sonoff.0 (15298) Client [Sonoff_DualR2] connected with secret 1618592189734_4668
    2021-04-16 18:56:30.577  - info: iot.0 (14981) Connection changed: disconnect
    2021-04-16 18:56:30.827  - info: iot.0 (14981) Connection lost
    2021-04-16 18:56:30.964  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:30.964  - error: unifi.0 (15238) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:30.985  - error: unifi.0 (15238) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
        at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
        at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    2021-04-16 18:56:30.986  - error: unifi.0 (15238) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.036  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.036  - error: unifi.0 (15238) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.036  - error: unifi.0 (15238) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.037  - error: unifi.0 (15238) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.037  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.037  - error: unifi.0 (15238) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.038  - error: unifi.0 (15238) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.038  - error: unifi.0 (15238) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.038  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.038  - error: unifi.0 (15238) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.039  - error: unifi.0 (15238) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.039  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.039  - error: unifi.0 (15238) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.040  - error: unifi.0 (15238) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.040  - error: unifi.0 (15238) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.040  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.040  - error: unifi.0 (15238) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.041  - error: unifi.0 (15238) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.041  - error: unifi.0 (15238) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.042  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.042  - error: unifi.0 (15238) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.042  - error: unifi.0 (15238) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.043  - error: unifi.0 (15238) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.043  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.043  - error: unifi.0 (15238) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.043  - error: unifi.0 (15238) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.044  - error: unifi.0 (15238) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.044  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.044  - error: unifi.0 (15238) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.045  - error: unifi.0 (15238) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.045  - error: unifi.0 (15238) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.046  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.046  - error: unifi.0 (15238) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.046  - error: unifi.0 (15238) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.046  - error: unifi.0 (15238) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.069  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.069  - error: unifi.0 (15238) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.071  - error: unifi.0 (15238) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.071  - error: unifi.0 (15238) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.167  - error: mqtt.0 (15883) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.609  - error: unifi.0 (15238) [applyJsonLogic] error: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error., stack: ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.796  - error: sonoff.0 (15298) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:30.513  - info: web.0 (18099) ==>Connected system.user.admin from 192.168.66.235
    2021-04-16 18:56:32.363  - error: unifi.0 (15238) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:32.363  - error: unifi.0 (15238) unhandled promise rejection: Cannot read property 'captureException' of undefined
    2021-04-16 18:56:32.498  - error: unifi.0 (15238) TypeError: Cannot read property 'captureException' of undefined
        at Unifi.errorHandling (/opt/iobroker/node_modules/iobroker.unifi/main.js:216:53)
        at Unifi.applyJsonLogic (/opt/iobroker/node_modules/iobroker.unifi/main.js:1271:18)
    2021-04-16 18:56:32.504  - error: unifi.0 (15238) Cannot read property 'captureException' of undefined
    2021-04-16 18:56:32.516  - error: harmony.0 (28479) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:31.801  - error: sonoff.0 (15298) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.996  - error: sonoff.0 (15298) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:31.997  - error: sonoff.0 (15298) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.230  - error: sonoff.0 (15298) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:32.230  - error: sonoff.0 (15298) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.231  - error: sonoff.0 (15298) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.231  - error: sonoff.0 (15298) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.245  - error: sonoff.0 (15298) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:32.246  - error: sonoff.0 (15298) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.249  - error: sonoff.0 (15298) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.249  - error: sonoff.0 (15298) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.249  - error: sonoff.0 (15298) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:32.249  - error: sonoff.0 (15298) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.250  - error: sonoff.0 (15298) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.250  - error: sonoff.0 (15298) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.250  - error: sonoff.0 (15298) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:32.251  - error: sonoff.0 (15298) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.251  - error: sonoff.0 (15298) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.251  - error: sonoff.0 (15298) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.251  - error: sonoff.0 (15298) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:32.332  - error: sonoff.0 (15298) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.333  - error: sonoff.0 (15298) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.334  - error: sonoff.0 (15298) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.334  - error: sonoff.0 (15298) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:56:32.335  - error: sonoff.0 (15298) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.335  - error: sonoff.0 (15298) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.335  - error: sonoff.0 (15298) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:56:32.336  - error: sonoff.0 (15298) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-04-16 18:57:32.600  - error: web.0 (18099) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:57:32.600  - error: web.0 (18099) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:57:32.601  - error: web.0 (18099) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:57:32.959  - info: web.0 (18099) <==Disconnect system.user.admin from 192.168.66.235 vis.0
    2021-04-16 18:57:38.112  - info: host.debian iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-16 18:57:38.116  - info: host.debian Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-16 18:57:38.117  - info: host.debian hostname: debian, node: v12.22.1
    2021-04-16 18:57:38.117  - info: host.debian ip addresses: 192.168.66.68 fe80::6407:9eff:feb9:ec35
    2021-04-16 18:57:38.304  - info: host.debian connected to Objects and States
    2021-04-16 18:57:38.374  - error: host.debian uncaught exception: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:57:39.330  - info: host.debian iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-16 18:57:39.334  - info: host.debian Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-16 18:57:39.334  - info: host.debian hostname: debian, node: v12.22.1
    2021-04-16 18:57:39.335  - info: host.debian ip addresses: 192.168.66.68 fe80::6407:9eff:feb9:ec35
    2021-04-16 18:57:39.417  - info: host.debian connected to Objects and States
    2021-04-16 18:57:39.458  - error: host.debian uncaught exception: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:57:40.187  - info: host.debian iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-16 18:57:40.189  - info: host.debian Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-16 18:57:40.190  - info: host.debian hostname: debian, node: v12.22.1
    2021-04-16 18:57:40.190  - info: host.debian ip addresses: 192.168.66.68 fe80::6407:9eff:feb9:ec35
    2021-04-16 18:57:40.283  - info: host.debian connected to Objects and States
    2021-04-16 18:57:40.326  - error: host.debian uncaught exception: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:57:41.191  - info: host.debian iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-16 18:57:41.194  - info: host.debian Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-16 18:57:41.195  - info: host.debian hostname: debian, node: v12.22.1
    2021-04-16 18:57:41.195  - info: host.debian ip addresses: 192.168.66.68 fe80::6407:9eff:feb9:ec35
    2021-04-16 18:57:41.272  - info: host.debian connected to Objects and States
    2021-04-16 18:57:41.314  - error: host.debian uncaught exception: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    2021-04-16 18:57:41.978  - info: host.debian iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-16 18:57:41.982  - info: host.debian Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-16 18:57:41.983  - info: host.debian hostname: debian, node: v12.22.1
    2021-04-16 18:57:41.983  - info: host.debian ip addresses: 192.168.66.68 fe80::6407:9eff:feb9:ec35
    2021-04-16 18:57:42.078  - info: host.debian connected to Objects and States
    2021-04-16 18:57:42.123  - error: host.debian uncaught exception: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
    Neustart:
    2021-04-16 19:17:46.319  - info: host.debian iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-16 19:17:46.322  - info: host.debian Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-16 19:17:46.322  - info: host.debian hostname: debian, node: v12.22.1
    2021-04-16 19:17:46.322  - info: host.debian ip addresses: 192.168.66.68 fe80::6407:9eff:feb9:ec35
    2021-04-16 19:17:46.395  - info: host.debian connected to Objects and States
    2021-04-16 19:17:46.427  - info: host.debian added notifications configuration of host
    2021-04-16 19:17:47.762  - info: host.debian Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-04-16 19:17:49.737  - info: host.debian 79 instances found
    2021-04-16 19:17:49.864  - info: host.debian starting 61 instances
    2021-04-16 19:17:50.335  - info: host.debian instance system.adapter.admin.0 started with pid 17379
    2021-04-16 19:17:54.505  - info: host.debian instance system.adapter.deconz.0 started with pid 17386
    2021-04-16 19:17:55.813  - info: admin.0 (17379) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-04-16 19:17:55.820  - info: admin.0 (17379) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
    2021-04-16 19:17:55.843  - info: admin.0 (17379) requesting all states
    2021-04-16 19:17:55.844  - info: admin.0 (17379) requesting all objects
    2021-04-16 19:17:56.574  - info: deconz.0 (17386) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-04-16 19:17:56.581  - info: deconz.0 (17386) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.22.1, js-controller: 3.2.16
    2021-04-16 19:17:56.603  - info: deconz.0 (17386) Please wait while adapter is starting
    2021-04-16 19:17:56.726  - info: deconz.0 (17386) deConz Version: 2.10.2; API version: 1.16.0
    2021-04-16 19:17:57.843  - info: admin.0 (17379) received all objects
    2021-04-16 19:17:58.263  - info: host.debian instance scheduled system.adapter.dwd.0 */5 * * * *
    2021-04-16 19:17:58.284  - info: host.debian instance system.adapter.dwd.0 started with pid 17419
    2021-04-16 19:17:59.582  - info: dwd.0 (17419) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-04-16 19:17:59.592  - info: dwd.0 (17419) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.1, js-controller: 3.2.16
    2021-04-16 19:18:00.817  - info: dwd.0 (17419) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-04-16 19:18:02.156  - info: host.debian instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-04-16 19:18:02.852  - info: admin.0 (17379) http server listening on port 8081
    wendy2702W crunchipC 2 Antworten Letzte Antwort
    • coyoteC coyote
      Hey,
      Neustart:
      wendy2702W Offline
      wendy2702W Offline
      @coyote Wie im LOg geschrieben:
      Mal ins Redis log geschaut ?
      Läuft deine Redis Datenbank auf dem gleichen Server?
      coyoteC 2 Antworten Letzte Antwort
      • wendy2702W wendy2702
        coyoteC Offline
        coyoteC Offline
        coyote
        @wendy2702 Im Redis Log steht nichts drin, da hab ich heute Mittag schon geschaut.
        Da es schon so lange her ist, als ich das eingerichtet habe, bin ich mir gerade nicht mehr sicher wie das war, ob es nur auf das gleiche System geschrieben wird oder auf mein NAS, da muss ich morgen mal schauen.
          coyoteC Offline
          coyoteC Offline
          coyote
          @wendy2702 ich habe nochmal nachgeschaut, Redis läuft auf dem gleichen Server wie iobroker.
          • coyoteC coyote
            @coyote
            Könnte mit den Rechten zusammenhängen. Ist der iobroker in der redis-Gruppe drin?
            sudo -u iobroker groups
            coyoteC 1 Antwort Letzte Antwort
              @coyote
              coyoteC Offline
              coyoteC Offline
              coyote
              @thomas-braun japp, ist drin.
              iobroker tty dialout audio video redis bluetooth
              • coyoteC coyote
                @coyote
                Und was steht im redis-log?
                cat /var/log/redis/redis-server.log
                  @coyote
                  coyoteC Offline
                  coyoteC Offline
                  coyote
                  @thomas-braun ich habe mal das rausgesucht von dem Tag. Ich seh da nix, außer die Unterbrechung um 18:58 Uhr am 16 April
                  redis-server.log.1
                  • coyoteC coyote
                    redis-server.log.1
                    @coyote
                    Immer wieder
                    10000 changes in 60 seconds.
                    mir scheint da irgendwas aus dem Ruder zu laufen und 10000 ist der Deckel.
                    Ich denke aber auch das 10000 Änderungen in 60 Sekunden ungewöhnlich viel ist. Was hast du denn da laufen, was so viele Änderungen auslöst?
                    Also bei mir schaut das wesentlich entspannter aus:
                    519:M 21 Apr 2021 17:40:30.142 * Background saving terminated with success
                    519:M 21 Apr 2021 17:45:31.001 * 10 changes in 300 seconds. Saving...
                    519:M 21 Apr 2021 17:45:31.003 * Background saving started by pid 19801
                    19801:C 21 Apr 2021 17:45:31.158 * DB saved on disk
                    19801:C 21 Apr 2021 17:45:31.161 * RDB: 0 MB of memory used by copy-on-write
                    519:M 21 Apr 2021 17:45:31.204 * Background saving terminated with success
                    519:M 21 Apr 2021 17:50:32.021 * 10 changes in 300 seconds. Saving...
                    519:M 21 Apr 2021 17:50:32.023 * Background saving started by pid 20001
                    20001:C 21 Apr 2021 17:50:32.149 * DB saved on disk
                    20001:C 21 Apr 2021 17:50:32.151 * RDB: 0 MB of memory used by copy-on-write
                    519:M 21 Apr 2021 17:50:32.225 * Background saving terminated with success
                      @coyote
                      Immer wieder
                      coyoteC Offline
                      coyoteC Offline
                      coyote
                      schrieb am zuletzt editiert von coyote
                      ok, gut. Das habe ich auch gesehen, mich eben nur gewundert, dass es tagelang so läuft.
                      Das ist in jedem Log so.
                      Aber ok, du hast schon recht, dass ist schon viel.
                      Gute Frage was das ist, was so viele Änderungen macht. Ne Idee wo ich da nachsehen könnte?
                      Du hast aber auch objects und states aud Redis?
                      • coyoteC coyote
                        @coyote
                        pi@raspberrypi:~ $ iobroker status
                        Objects type: file
                        States  type: redis
                        Von den Objects wurde mal irgendwann abgeraten die in redis zu packen. Ich weiß aber nicht mehr wo ich das gelesen habe.
                          @coyote
                          Objects type: file
                          States  type: redis
                          coyoteC Offline
                          coyoteC Offline
                          coyote
                          @thomas-braun ah ok, vllt liegt da das Problem.
                          Ich hatte ganz am Anfang in der Testphase schon komplett umgestellt. Ich schau mal, ob ich das ohne Problem wieder umstellen kann auf nur "states"
                          • coyoteC coyote
                            Hey,
                            Neustart:
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @coyote glaub eher das zuvor eher ein Netzwerk Problem vorliegt, aufgrund deiner reconnects
                              coyoteC Offline
                              coyoteC Offline
                              coyote
                              @crunchip hm, auch noch ne Idee, aber das sind alles WLAN Geräte.
                              Habe leider noch keinen richtigen Zusammenhang finden können bzw. wann genau das Problem auftritt
                              • coyoteC coyote
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @coyote sagte in iobroker stürzt ab, MISCONF Redis is configured to save RDB:
                                alles WLAN Geräte
                                Eben, verbinden sich neu , z.b nem anderen Kanal
                                  alles WLAN Geräte
                                  coyoteC Offline
                                  coyoteC Offline
                                  coyote
                                  @crunchip seltsamerweise aber "nur" 10 Geräte von min 20 🤔
                                  Blöd irgendwie festzustellen, was genau das ist
                                  • coyoteC coyote
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @coyote kann am schlechten wlan signal liegen.
                                    Kenn deine Gegebenheiten nicht.
                                      coyoteC Offline
                                      coyoteC Offline
                                      coyote
                                      @crunchip Naja, deshalb sag ich ja, schwer zu sagen. Habe 4 Unifi APs im Haus und einen Outdoor.
                                      Die Geräte sind auch noch mit unterschiedlichen APs verbunden.
                                      • coyoteC coyote
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @coyote so wie bei mir, allerdings nur 2 AP's innen, 1er aussen.
                                        Hatte auch ne zeitlang gekämpft mit den ständigen reconnects, Handy ständig neu verbunden...etc.
                                        Mittlerweile läuft es aber ganz gut.
