  4. ioBrocker Neustart Änderung
    6.8k
iobrokertelegram adapterneustart
75 Beiträge 8 Kommentatoren 10.3k Aufrufe 8 Beobachtet
  • bergjetB bergjet
    Die zeit vor 2:00
    2021-04-20 00:00:00.023 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: ZEITPLAN JETZT
    2021-04-20 00:00:00.062 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: 1620000
    2021-04-20 00:00:00.063 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: 2580000
    2021-04-20 00:00:00.123 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 9208
    2021-04-20 00:00:01.782 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 00:00:01.845 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 00:00:02.257 - info: daswetter.0 (9208) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 00:00:02.424 - info: daswetter.0 (9208) got wrong data structure! trying to repair...
    2021-04-20 00:00:04.166 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 9249
    2021-04-20 00:00:05.011 - warn: trashschedule.0 (888) no events matches type "Verpackung" with match "Verp". Check configuration of iCal (increase preview) and trashschedule!
    2021-04-20 00:00:08.101 - info: coronavirus-statistics.0 (9249) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 00:00:10.273 - info: daswetter.0 (9208) Terminated (NO_ERROR): Without reason
    2021-04-20 00:00:10.796 - info: daswetter.0 (9208) cleaned everything up...
    2021-04-20 00:00:10.816 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-04-20 00:00:20.402 - info: coronavirus-statistics.0 (9249) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2021-04-20 00:00:20.973 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-04-20 00:15:00.118 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 30009
    2021-04-20 00:15:02.338 - info: daswetter.0 (30009) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 00:15:02.514 - info: daswetter.0 (30009) got wrong data structure! trying to repair...
    2021-04-20 00:15:09.263 - info: daswetter.0 (30009) Terminated (NO_ERROR): Without reason
    2021-04-20 00:15:09.788 - info: daswetter.0 (30009) cleaned everything up...
    2021-04-20 00:15:09.805 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-04-20 00:27:00.064 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: ZufälliglEinschalten
    2021-04-20 00:28:13.865 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 00:28:28.738 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 00:28:28.757 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 00:30:00.101 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 18882
    2021-04-20 00:30:01.864 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 00:30:01.975 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 00:30:02.140 - info: daswetter.0 (18882) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 00:30:02.338 - info: daswetter.0 (18882) got wrong data structure! trying to repair...
    2021-04-20 00:30:04.179 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 18922
    2021-04-20 00:30:08.029 - info: coronavirus-statistics.0 (18922) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 00:30:10.323 - info: daswetter.0 (18882) Terminated (NO_ERROR): Without reason
    2021-04-20 00:30:10.855 - info: daswetter.0 (18882) cleaned everything up...
    2021-04-20 00:30:10.877 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-04-20 00:30:17.555 - info: coronavirus-statistics.0 (18922) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2021-04-20 00:30:18.097 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-04-20 00:30:29.509 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 00:30:29.539 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 00:30:29.581 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 00:30:33.549 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 00:43:00.064 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: ZufälligAusschalten
    2021-04-20 00:45:00.102 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 7696
    2021-04-20 00:45:02.334 - info: daswetter.0 (7696) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 00:45:02.693 - info: daswetter.0 (7696) got wrong data structure! trying to repair...
    2021-04-20 00:45:09.869 - info: daswetter.0 (7696) Terminated (NO_ERROR): Without reason
    2021-04-20 00:45:10.386 - info: daswetter.0 (7696) cleaned everything up...
    2021-04-20 00:45:10.401 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-04-20 01:00:00.122 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 28650
    2021-04-20 01:00:00.192 - warn: husq-automower.0 (30872) updateStatus, result.operatingMode === HOME
    2021-04-20 01:00:00.504 - info: web.0 (1450) <==Disconnect system.user.admin from ::ffff:192.168.1.34 vis.0
    2021-04-20 01:00:00.669 - info: web.0 (1450) <==Disconnect system.user.admin from ::ffff:192.168.1.17 vis.0
    2021-04-20 01:00:01.892 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 01:00:01.956 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 01:00:02.559 - info: daswetter.0 (28650) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 01:00:02.758 - info: daswetter.0 (28650) got wrong data structure! trying to repair...
    2021-04-20 01:00:03.432 - info: web.0 (1450) ==>Connected system.user.admin from ::ffff:192.168.1.34
    2021-04-20 01:00:04.163 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 28755
    2021-04-20 01:00:05.005 - warn: trashschedule.0 (888) no events matches type "Verpackung" with match "Verp". Check configuration of iCal (increase preview) and trashschedule!
    2021-04-20 01:00:05.166 - info: web.0 (1450) ==>Connected system.user.admin from ::ffff:192.168.1.17
    2021-04-20 01:00:08.376 - info: coronavirus-statistics.0 (28755) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 01:00:11.431 - info: daswetter.0 (28650) Terminated (NO_ERROR): Without reason
    2021-04-20 01:00:11.948 - info: daswetter.0 (28650) cleaned everything up...
    2021-04-20 01:00:11.964 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-04-20 01:00:16.789 - info: coronavirus-statistics.0 (28755) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2021-04-20 01:00:17.350 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-04-20 01:15:00.063 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 17524
    2021-04-20 01:15:02.110 - info: daswetter.0 (17524) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 01:15:02.307 - info: daswetter.0 (17524) got wrong data structure! trying to repair...
    2021-04-20 01:15:09.454 - info: daswetter.0 (17524) Terminated (NO_ERROR): Without reason
    2021-04-20 01:15:09.994 - info: daswetter.0 (17524) cleaned everything up...
    2021-04-20 01:15:10.025 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-04-20 01:30:00.063 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 6404
    2021-04-20 01:30:01.671 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 01:30:01.723 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 01:30:02.273 - info: daswetter.0 (6404) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 01:30:02.426 - info: daswetter.0 (6404) got wrong data structure! trying to repair...
    2021-04-20 01:30:04.130 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 6607
    2021-04-20 01:30:07.883 - info: coronavirus-statistics.0 (6607) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 01:30:10.541 - info: daswetter.0 (6404) Terminated (NO_ERROR): Without reason
    2021-04-20 01:30:11.101 - info: daswetter.0 (6404) cleaned everything up...
    2021-04-20 01:30:11.118 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-04-20 01:30:17.117 - info: coronavirus-statistics.0 (6607) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2021-04-20 01:30:17.668 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-04-20 01:45:00.082 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 27457
    2021-04-20 01:45:01.999 - info: daswetter.0 (27457) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 01:45:02.198 - info: daswetter.0 (27457) got wrong data structure! trying to repair...
    2021-04-20 01:45:09.127 - info: daswetter.0 (27457) Terminated (NO_ERROR): Without reason
    2021-04-20 01:45:09.657 - info: daswetter.0 (27457) cleaned everything up...
    2021-04-20 01:45:09.674 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-04-20 02:00:00.015 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: ZEITPLAN JETZT
    2021-04-20 02:00:00.024 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: 600000
    2021-04-20 02:00:00.025 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: 2340000
    2021-04-20 02:00:00.118 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 16135
    2021-04-20 02:00:00.240 - warn: husq-automower.0 (30872) updateStatus, result.operatingMode === HOME
    2021-04-20 02:00:00.408 - info: web.0 (1450) <==Disconnect system.user.admin from ::ffff:192.168.1.17 vis.0
    2021-04-20 02:00:00.518 - info: web.0 (1450) <==Disconnect system.user.admin from ::ffff:192.168.1.34 vis.0
    2021-04-20 02:00:01.737 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 02:00:01.801 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 02:00:01.852 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 02:00:01.874 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 02:00:01.948 - info: homee.0 (30809) initialize 1 homeegrams
    2021-04-20 02:00:02.922 - info: daswetter.0 (16135) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 02:00:03.140 - info: daswetter.0 (16135) got wrong data structure! trying to repair...
    2021-04-20 02:00:03.538 - info: web.0 (1450) ==>Connected system.user.admin from ::ffff:192.168.1.34
    2021-04-20 02:00:04.218 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 16337
    2021-04-20 02:00:05.013 - warn: trashschedule.0 (888) no events matches type "Verpackung" with match "Verp". Check configuration of iCal (increase preview) and trashschedule!
    2021-04-20 02:00:05.105 - info: web.0 (1450) ==>Connected system.user.admin from ::ffff:192.168.1.17
    2021-04-20 02:00:08.263 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 16363
    2021-04-20 02:00:09.190 - info: coronavirus-statistics.0 (16337) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 02:00:11.352 - info: ical.0 (16363) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.1, js-controller: 3.2.16
    2021-04-20 02:00:19.861 - info: ical.0 (16363) processing URL: Müll http://p25-caldav.icloud.com/published/2/Mjc2ODA0MDAwMjc2ODA0MOWAQ_Hp47ycJEgYb0oET12LPeUAOwbTuiHnNWrmHF21ZilCgnWV2zu_3gFQLNJIuNKRi8FkQZJBGf2_bTAS3rjaxgj8VXAGfuiCKKkA0_sxFDWnISlJyUhyvepk5YbXXg
    2021-04-20 02:00:22.276 - warn: trashschedule.0 (888) no events matches type "Verpackung" with match "Verp". Check configuration of iCal (increase preview) and trashschedule!
    2021-04-20 02:00:29.157 - info: ical.0 (16363) Terminated (NO_ERROR): Without reason
    Wo finde ich kernel.log und sys.log?
    @bergjet
    Für den heutigen Tag / das laufende Log:
    cat /var/log/kern.log
    cat /var/log/syslog
    bergjetB 1 Antwort Letzte Antwort
      @bergjet
      cat /var/log/syslog
      bergjetB Offline
      bergjetB Offline
      bergjet
      kernel.log
      Apr 20 02:01:23 raspberrypi kernel: [135707.349180] node invoked oom-killer: gfp_mask=0x400dc2(GFP_KERNEL_ACCOUNT|__GFP_HIGHMEM|__GFP_ZERO), order=0, oom_score_adj=0
      Apr 20 02:01:23 raspberrypi kernel: [135707.349192] CPU: 2 PID: 30402 Comm: node Tainted: G         C        5.10.17-v7l+ #1403
      Apr 20 02:01:23 raspberrypi kernel: [135707.349197] Hardware name: BCM2711
      Apr 20 02:01:23 raspberrypi kernel: [135707.349201] Backtrace:
      Apr 20 02:01:23 raspberrypi kernel: [135707.349223] [<c0b63050>] (dump_backtrace) from [<c0b633e4>] (show_stack+0x20/0x24)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349230]  r7:ffffffff r6:00000000 r5:60000113 r4:c12e69fc
      Apr 20 02:01:23 raspberrypi kernel: [135707.349239] [<c0b633c4>] (show_stack) from [<c0b67774>] (dump_stack+0xcc/0xf8)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349245] [<c0b676a8>] (dump_stack) from [<c0b65a04>] (dump_header+0x64/0x208)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349251]  r10:c120518c r9:00400dc2 r8:00000000 r7:c0e3709c r6:c7f16a00 r5:c9ffbe00
      Apr 20 02:01:23 raspberrypi kernel: [135707.349256]  r4:c7a8dde8 r3:eaf5c060
      Apr 20 02:01:23 raspberrypi kernel: [135707.349265] [<c0b659a0>] (dump_header) from [<c03b6cd0>] (oom_kill_process+0x1b4/0x1c0)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349270]  r7:c0e3709c r6:c7a8dde8 r5:c9ffc380 r4:c9ffbe00
      Apr 20 02:01:23 raspberrypi kernel: [135707.349277] [<c03b6b1c>] (oom_kill_process) from [<c03b7848>] (out_of_memory+0x2b8/0x390)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349282]  r7:c1208580 r6:c1205048 r5:c9ffbe00 r4:c7a8dde8
      Apr 20 02:01:23 raspberrypi kernel: [135707.349290] [<c03b7590>] (out_of_memory) from [<c040a8bc>] (__alloc_pages_nodemask+0x7ec/0x1184)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349296]  r7:c1336790 r6:00001400 r5:00001dec r4:00000000
      Apr 20 02:01:23 raspberrypi kernel: [135707.349304] [<c040a0d0>] (__alloc_pages_nodemask) from [<c03ec934>] (__pte_alloc+0x34/0x168)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349310]  r10:c1205048 r9:00000040 r8:00000255 r7:00000000 r6:c7eaad28 r5:c40a0200
      Apr 20 02:01:23 raspberrypi kernel: [135707.349314]  r4:34acf000
      Apr 20 02:01:23 raspberrypi kernel: [135707.349321] [<c03ec900>] (__pte_alloc) from [<c03f0068>] (handle_mm_fault+0x100c/0x1124)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349326]  r7:00000000 r6:07eaa003 r5:00000000 r4:34acf000
      Apr 20 02:01:23 raspberrypi kernel: [135707.349334] [<c03ef05c>] (handle_mm_fault) from [<c0b739d4>] (do_page_fault+0x144/0x314)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349339]  r10:00000255 r9:00000800 r8:c40a0248 r7:c40a0200 r6:00000a06 r5:34acf000
      Apr 20 02:01:23 raspberrypi kernel: [135707.349343]  r4:c7a8dfb0
      Apr 20 02:01:23 raspberrypi kernel: [135707.349349] [<c0b73890>] (do_page_fault) from [<c0b73c84>] (do_translation_fault+0xe0/0x10c)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349355]  r10:00000000 r9:b6d25258 r8:00000a06 r7:34acf000 r6:c0b73ba4 r5:00000a06
      Apr 20 02:01:23 raspberrypi kernel: [135707.349359]  r4:c120aef8
      Apr 20 02:01:23 raspberrypi kernel: [135707.349366] [<c0b73ba4>] (do_translation_fault) from [<c0214c6c>] (do_DataAbort+0x40/0xc0)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349372]  r9:b6d25258 r8:c7a8dfb0 r7:34acf000 r6:c0b73ba4 r5:00000a06 r4:c120aef8
      Apr 20 02:01:23 raspberrypi kernel: [135707.349379] [<c0214c2c>] (do_DataAbort) from [<c0200da4>] (__dabt_usr+0x44/0x60)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349383] Exception stack(0xc7a8dfb0 to 0xc7a8dff8)
      Apr 20 02:01:23 raspberrypi kernel: [135707.349388] dfa0:                                     34acf000 002f1002 00000000 34acf008
      Apr 20 02:01:23 raspberrypi kernel: [135707.349394] dfc0: b6d257d4 002f1000 0005e1a6 002f0d40 b6d25000 b6d25258 00000000 fffff000
      Apr 20 02:01:23 raspberrypi kernel: [135707.349399] dfe0: b6d2526c bef6d328 b6d25258 b6c4b8d8 40000010 ffffffff
      Apr 20 02:01:23 raspberrypi kernel: [135707.349405]  r8:30c5387d r7:30c5383d r6:ffffffff r5:40000010 r4:b6c4b8d8
      Apr 20 02:01:23 raspberrypi kernel: [135707.349409] Mem-Info:
      Apr 20 02:01:23 raspberrypi kernel: [135707.349421] active_anon:35326 inactive_anon:905949 isolated_anon:0
      Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  active_file:3396 inactive_file:3998 isolated_file:32
      Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  unevictable:4 dirty:39 writeback:0
      Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  slab_reclaimable:3544 slab_unreclaimable:5676
      Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  mapped:3307 shmem:519 pagetables:9482 bounce:0
      Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  free:6738 free_pcp:0 free_cma:0
      Apr 20 02:01:23 raspberrypi kernel: [135707.349431] Node 0 active_anon:141304kB inactive_anon:3623796kB active_file:13584kB inactive_file:15992kB unevictable:16kB isolated(anon):0kB isolated(file):128kB mapped:13228kB dirty:156kB writeback:0kB shmem:2076kB writeback_tmp:0kB kernel_stack:5072kB all_unreclaimable? no
      Apr 20 02:01:23 raspberrypi kernel: [135707.349442] DMA free:24532kB min:20480kB low:24576kB high:28672kB reserved_highatomic:0KB active_anon:1812kB inactive_anon:567188kB active_file:1012kB inactive_file:4744kB unevictable:0kB writepending:40kB present:786432kB managed:654620kB mlocked:0kB pagetables:1836kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
      Apr 20 02:01:23 raspberrypi kernel: [135707.349448] lowmem_reserve[]: 0 0 3188 0
      Apr 20 02:01:23 raspberrypi kernel: [135707.349484] HighMem free:2420kB min:62552kB low:82976kB high:103400kB reserved_highatomic:0KB active_anon:140040kB inactive_anon:3055932kB active_file:12988kB inactive_file:10932kB unevictable:16kB writepending:116kB present:3264512kB managed:3264512kB mlocked:16kB pagetables:36092kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
      Apr 20 02:01:23 raspberrypi kernel: [135707.349490] lowmem_reserve[]: 0 0 0 0
      Apr 20 02:01:23 raspberrypi kernel: [135707.349522] DMA: 209*4kB (UME) 481*8kB (UMEC) 409*16kB (UME) 194*32kB (UME) 80*64kB (UME) 16*128kB (UM) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 24604kB
      Apr 20 02:01:23 raspberrypi kernel: [135707.349625] HighMem: 148*4kB (UM) 89*8kB (UM) 25*16kB (UM) 6*32kB (UM) 20*64kB (M) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 3176kB
      Apr 20 02:01:23 raspberrypi kernel: [135707.349723] 5758 total pagecache pages
      Apr 20 02:01:23 raspberrypi kernel: [135707.349730] 175 pages in swap cache
      Apr 20 02:01:23 raspberrypi kernel: [135707.349737] Swap cache stats: add 59748, delete 59572, find 4768/8730
      Apr 20 02:01:23 raspberrypi kernel: [135707.349743] Free swap  = 0kB
      Apr 20 02:01:23 raspberrypi kernel: [135707.349749] Total swap = 102396kB
      Apr 20 02:01:23 raspberrypi kernel: [135707.349755] 1012736 pages RAM
      Apr 20 02:01:23 raspberrypi kernel: [135707.349761] 816128 pages HighMem/MovableOnly
      Apr 20 02:01:23 raspberrypi kernel: [135707.349767] 32953 pages reserved
      Apr 20 02:01:23 raspberrypi kernel: [135707.349772] 65536 pages cma reserved
      Apr 20 02:01:23 raspberrypi kernel: [135707.349779] Tasks state (memory values in pages):
      Apr 20 02:01:23 raspberrypi kernel: [135707.349785] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
      Apr 20 02:01:23 raspberrypi kernel: [135707.349799] [    122]     0   122     5310     1101   131072        1             0 systemd-journal
      Apr 20 02:01:23 raspberrypi kernel: [135707.349807] [    148]     0   148     4499      202    49152        0         -1000 systemd-udevd
      Apr 20 02:01:23 raspberrypi kernel: [135707.349818] [    298]   100   298     5604      359    61440        0             0 systemd-timesyn
      Apr 20 02:01:23 raspberrypi kernel: [135707.349825] [    336]     0   336     1987      206    45056        0             0 cron
      Apr 20 02:01:23 raspberrypi kernel: [135707.349833] [    341]   104   341     1639      176    36864        0          -900 dbus-daemon
      Apr 20 02:01:23 raspberrypi kernel: [135707.349841] [    349]   108   349     1640      432    32768        0             0 avahi-daemon
      Apr 20 02:01:23 raspberrypi kernel: [135707.349849] [    350]     0   350     2686      181    45056        0             0 wpa_supplicant
      Apr 20 02:01:23 raspberrypi kernel: [135707.349856] [    359]     0   359     6378      358    45056        4             0 rsyslogd
      Apr 20 02:01:23 raspberrypi kernel: [135707.349864] [    361] 65534   361     1080       85    32768        0             0 thd
      Apr 20 02:01:23 raspberrypi kernel: [135707.349872] [    363]     0   363     6914       90    36864        2             0 rngd
      Apr 20 02:01:23 raspberrypi kernel: [135707.349880] [    371]   108   371     1442       55    32768        8             0 avahi-daemon
      Apr 20 02:01:23 raspberrypi kernel: [135707.349888] [    373]     0   373      923       77    32768        0             0 alsactl
      Apr 20 02:01:23 raspberrypi kernel: [135707.349896] [    383]     0   383     3228      246    53248        0             0 systemd-logind
      Apr 20 02:01:23 raspberrypi kernel: [135707.349904] [    464]     0   464     2751       91    45056       79             0 wpa_supplicant
      Apr 20 02:01:23 raspberrypi kernel: [135707.349911] [    479]     0   479      535       12    28672       20             0 hciattach
      Apr 20 02:01:23 raspberrypi kernel: [135707.349919] [    482]     0   482     2384       71    40960        0             0 bluetoothd
      Apr 20 02:01:23 raspberrypi kernel: [135707.349927] [    547]     0   547      726      228    28672       60             0 dhcpcd
      Apr 20 02:01:23 raspberrypi kernel: [135707.349935] [    553]     0   553     1077       22    32768        0             0 agetty
      Apr 20 02:01:23 raspberrypi kernel: [135707.349942] [    555]     0   555     2682      150    49152        0         -1000 sshd
      Apr 20 02:01:23 raspberrypi kernel: [135707.349950] [  30402]  1001 30402   586177   549850  5492736     2877             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.349958] [  30581]  1001 30581    45284     5149   921600     9869             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.349966] [  30596]  1001 30596    38986     4701   622592     2987             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.349973] [  30618]  1001 30618    45150    10907   770048     3644             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.349981] [  30648]  1001 30648    39337     5230   643072     2828             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.349989] [  30678]  1001 30678    38834     6717   598016     1582             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.349996] [  30708]  1001 30708    39563     8011   610304        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350004] [  30738]  1001 30738    40084     9530   643072        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350011] [  30772]  1001 30772    40070     9700   557056        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350019] [  30809]  1001 30809    42845    11617   733184        2             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350026] [  30820]  1001 30820    42287    16068   643072        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350034] [  30854]  1001 30854    43537    13961   741376        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350042] [  30872]  1001 30872    40476     9257   643072        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350049] [  30929]  1001 30929    45589    15181   745472        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350057] [  30959]  1001 30959    41057    10303   704512        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350065] [  31482]  1001 31482    58032    27676  1118208        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350073] [  31502]  1001 31502    41579    10242   712704        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350080] [  31701]  1001 31701    44816    15632   856064        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350088] [  31723]  1001 31723    41736     9803   671744        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350096] [  31759]  1001 31759    38354     8109   585728        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350104] [  31935]  1001 31935    39537     8623   614400        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350111] [  31942]  1001 31942    58856    28730  1236992        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350119] [  32032]  1001 32032    40009     9640   700416        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350126] [  32154]  1001 32154    39480     8089   626688        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350134] [  32345]  1001 32345    38903     8763   610304        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350141] [  32373]  1001 32373    41231    10602   712704        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350149] [  32546]  1001 32546    39094     8941   655360        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350156] [  32651]  1001 32651    39185     7901   626688        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350164] [  32736]  1001 32736    38878     7986   602112        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350171] [    440]  1001   440    40017     9579   692224        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350179] [    659]  1001   659    39302     8485   630784        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350187] [    888]  1001   888    39670     8754   651264        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350195] [   1087]  1001  1087    38337     7372   581632        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350203] [   1443]  1001  1443    39299     8623   618496        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350211] [   1450]  1001  1450    42483    12549   688128        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350219] [   1463]  1001  1463    42582    12326   790528        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350226] [   1496]  1001  1496    38381     7868   610304        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350234] [   1681]  1001  1681    42361    11271   749568        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350241] [   1688]  1001  1688    42241    12155   741376        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350249] [   1706]  1001  1706    39041     7989   618496        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350257] [   1940]  1001  1940    47010    17102   843776        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350265] [   5108]  1001  5108    46936    17112   876544        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350273] [   7580]  1001  7580    43672    12220   716800        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350282] [  16135]  1001 16135    37555     6788   577536        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350290] [  16337]  1001 16337    40542    10018   663552        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350298] [  16363]  1001 16363    38619     8052   647168        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350305] [  16542]  1001 16542    38988    16908   806912        0             0 node
      Apr 20 02:01:23 raspberrypi kernel: [135707.350314] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=30402,uid=1001
      Apr 20 02:01:23 raspberrypi kernel: [135707.350388] Out of memory: Killed process 30402 (node) total-vm:2344708kB, anon-rss:2189760kB, file-rss:9640kB, shmem-rss:0kB, UID:1001 pgtables:5364kB oom_score_adj:0
      Apr 20 02:01:24 raspberrypi kernel: [135707.559391] oom_reaper: reaped process 30402 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
      Apr 20 13:01:56 raspberrypi kernel: [175340.649230] Bluetooth: hci0: sending frame failed (-49)
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Zone ranges:
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   Normal   empty
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Movable zone start for each node
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Early memory node ranges
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] On node 0 totalpages: 1012736
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 2304 pages used for memmap
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 0 pages reserved
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:11:CE:96 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f546770a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Memory: 3654940K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133860K reserved, 262144K cma-reserved, 3264512K highmem)
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] ftrace: allocating 33942 entries in 67 pages
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] ftrace: allocated 67 pages with 3 groups
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] rcu: Hierarchical RCU implementation.
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
      Apr 20 13:02:10 raspberrypi kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
      Apr 20 13:02:10 raspberrypi kernel: [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
      Apr 20 13:02:10 raspberrypi kernel: [    0.000034] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
      Apr 20 13:02:10 raspberrypi kernel: [    0.000098] bcm2835: system timer (irq = 25)
      Apr 20 13:02:10 raspberrypi kernel: [    0.000750] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      Apr 20 13:02:10 raspberrypi kernel: [    0.000772] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      Apr 20 13:02:10 raspberrypi kernel: [    0.000795] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
      Apr 20 13:02:10 raspberrypi kernel: [    0.000813] Switching to timer-based delay loop, resolution 18ns
      Apr 20 13:02:10 raspberrypi kernel: [    0.001065] Console: colour dummy device 80x30
      Apr 20 13:02:10 raspberrypi kernel: [    0.001808] printk: console [tty1] enabled
      Apr 20 13:02:10 raspberrypi kernel: [    0.001874] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
      Apr 20 13:02:10 raspberrypi kernel: [    0.001928] pid_max: default: 32768 minimum: 301
      Apr 20 13:02:10 raspberrypi kernel: [    0.002109] LSM: Security Framework initializing
      Apr 20 13:02:10 raspberrypi kernel: [    0.002306] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      Apr 20 13:02:10 raspberrypi kernel: [    0.002352] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      Apr 20 13:02:10 raspberrypi kernel: [    0.003929] Disabling memory control group subsystem
      Apr 20 13:02:10 raspberrypi kernel: [    0.004064] CPU: Testing write buffer coherency: ok
      Apr 20 13:02:10 raspberrypi kernel: [    0.004536] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      Apr 20 13:02:10 raspberrypi kernel: [    0.005755] Setting up static identity map for 0x200000 - 0x20003c
      Apr 20 13:02:10 raspberrypi kernel: [    0.005970] rcu: Hierarchical SRCU implementation.
      Apr 20 13:02:10 raspberrypi kernel: [    0.006915] smp: Bringing up secondary CPUs ...
      Apr 20 13:02:10 raspberrypi kernel: [    0.008137] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      Apr 20 13:02:10 raspberrypi kernel: [    0.009502] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      Apr 20 13:02:10 raspberrypi kernel: [    0.010810] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      Apr 20 13:02:10 raspberrypi kernel: [    0.010966] smp: Brought up 1 node, 4 CPUs
      Apr 20 13:02:10 raspberrypi kernel: [    0.011011] SMP: Total of 4 processors activated (432.00 BogoMIPS).
      Apr 20 13:02:10 raspberrypi kernel: [    0.011042] CPU: All CPU(s) started in HYP mode.
      Apr 20 13:02:10 raspberrypi kernel: [    0.011069] CPU: Virtualization extensions available.
      Apr 20 13:02:10 raspberrypi kernel: [    0.011910] devtmpfs: initialized
      Apr 20 13:02:10 raspberrypi kernel: [    0.025725] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
      Apr 20 13:02:10 raspberrypi kernel: [    0.025986] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      Apr 20 13:02:10 raspberrypi kernel: [    0.026040] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      Apr 20 13:02:10 raspberrypi kernel: [    0.033085] pinctrl core: initialized pinctrl subsystem
      Apr 20 13:02:10 raspberrypi kernel: [    0.034183] NET: Registered protocol family 16
      Apr 20 13:02:10 raspberrypi kernel: [    0.038180] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      Apr 20 13:02:10 raspberrypi kernel: [    0.038964] audit: initializing netlink subsys (disabled)
      Apr 20 13:02:10 raspberrypi kernel: [    0.039250] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
      Apr 20 13:02:10 raspberrypi kernel: [    0.039809] thermal_sys: Registered thermal governor 'step_wise'
      Apr 20 13:02:10 raspberrypi kernel: [    0.040494] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      Apr 20 13:02:10 raspberrypi kernel: [    0.040548] hw-breakpoint: maximum watchpoint size is 8 bytes.
      Apr 20 13:02:10 raspberrypi kernel: [    0.040983] Serial: AMBA PL011 UART driver
      Apr 20 13:02:10 raspberrypi kernel: [    0.072819] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      Apr 20 13:02:10 raspberrypi kernel: [    0.090958] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
      Apr 20 13:02:10 raspberrypi kernel: [    0.100971] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
      Apr 20 13:02:10 raspberrypi kernel: [    0.146228] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
      Apr 20 13:02:10 raspberrypi kernel: [    0.150377] vgaarb: loaded
      Apr 20 13:02:10 raspberrypi kernel: [    0.150838] SCSI subsystem initialized
      Apr 20 13:02:10 raspberrypi kernel: [    0.151443] usbcore: registered new interface driver usbfs
      Apr 20 13:02:10 raspberrypi kernel: [    0.151532] usbcore: registered new interface driver hub
      Apr 20 13:02:10 raspberrypi kernel: [    0.151622] usbcore: registered new device driver usb
      Apr 20 13:02:10 raspberrypi kernel: [    0.151972] usb_phy_generic phy: supply vcc not found, using dummy regulator
      Apr 20 13:02:10 raspberrypi kernel: [    0.153863] clocksource: Switched to clocksource arch_sys_counter
      Apr 20 13:02:10 raspberrypi kernel: [    1.152554] VFS: Disk quotas dquot_6.6.0
      Apr 20 13:02:10 raspberrypi kernel: [    1.152679] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      Apr 20 13:02:10 raspberrypi kernel: [    1.152860] FS-Cache: Loaded
      Apr 20 13:02:10 raspberrypi kernel: [    1.153087] CacheFiles: Loaded
      Apr 20 13:02:10 raspberrypi kernel: [    1.163453] NET: Registered protocol family 2
      Apr 20 13:02:10 raspberrypi kernel: [    1.164344] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      Apr 20 13:02:10 raspberrypi kernel: [    1.164506] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
      Apr 20 13:02:10 raspberrypi kernel: [    1.164587] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      Apr 20 13:02:10 raspberrypi kernel: [    1.164673] TCP: Hash tables configured (established 8192 bind 8192)
      Apr 20 13:02:10 raspberrypi kernel: [    1.164845] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      Apr 20 13:02:10 raspberrypi kernel: [    1.164900] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      Apr 20 13:02:10 raspberrypi kernel: [    1.165191] NET: Registered protocol family 1
      Apr 20 13:02:10 raspberrypi kernel: [    1.165911] RPC: Registered named UNIX socket transport module.
      Apr 20 13:02:10 raspberrypi kernel: [    1.165944] RPC: Registered udp transport module.
      Apr 20 13:02:10 raspberrypi kernel: [    1.165972] RPC: Registered tcp transport module.
      Apr 20 13:02:10 raspberrypi kernel: [    1.166000] RPC: Registered tcp NFSv4.1 backchannel transport module.
      Apr 20 13:02:10 raspberrypi kernel: [    1.166037] PCI: CLS 0 bytes, default 64
      Apr 20 13:02:10 raspberrypi kernel: [    1.168924] Initialise system trusted keyrings
      Apr 20 13:02:10 raspberrypi kernel: [    1.169198] workingset: timestamp_bits=14 max_order=20 bucket_order=6
      Apr 20 13:02:10 raspberrypi kernel: [    1.177760] zbud: loaded
      Apr 20 13:02:10 raspberrypi kernel: [    1.179686] FS-Cache: Netfs 'nfs' registered for caching
      Apr 20 13:02:10 raspberrypi kernel: [    1.180481] NFS: Registering the id_resolver key type
      Apr 20 13:02:10 raspberrypi kernel: [    1.180543] Key type id_resolver registered
      Apr 20 13:02:10 raspberrypi kernel: [    1.180572] Key type id_legacy registered
      Apr 20 13:02:10 raspberrypi kernel: [    1.180736] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      Apr 20 13:02:10 raspberrypi kernel: [    1.181775] Key type asymmetric registered
      Apr 20 13:02:10 raspberrypi kernel: [    1.181807] Asymmetric key parser 'x509' registered
      Apr 20 13:02:10 raspberrypi kernel: [    1.182011] bounce: pool size: 64 pages
      Apr 20 13:02:10 raspberrypi kernel: [    1.182067] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      Apr 20 13:02:10 raspberrypi kernel: [    1.182298] io scheduler mq-deadline registered
      Apr 20 13:02:10 raspberrypi kernel: [    1.182329] io scheduler kyber registered
      Apr 20 13:02:10 raspberrypi kernel: [    1.186772] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      Apr 20 13:02:10 raspberrypi kernel: [    1.186824] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
      Apr 20 13:02:10 raspberrypi kernel: [    1.186926] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
      Apr 20 13:02:10 raspberrypi kernel: [    1.187036] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
      Apr 20 13:02:10 raspberrypi kernel: [    1.246001] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
      Apr 20 13:02:10 raspberrypi kernel: [    1.246381] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      Apr 20 13:02:10 raspberrypi kernel: [    1.246419] pci_bus 0000:00: root bus resource [bus 00-ff]
      Apr 20 13:02:10 raspberrypi kernel: [    1.246454] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
      Apr 20 13:02:10 raspberrypi kernel: [    1.246563] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      Apr 20 13:02:10 raspberrypi kernel: [    1.246821] pci 0000:00:00.0: PME# supported from D0 D3hot
      Apr 20 13:02:10 raspberrypi kernel: [    1.250318] PCI: bus0: Fast back to back transfers disabled
      Apr 20 13:02:10 raspberrypi kernel: [    1.250672] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      Apr 20 13:02:10 raspberrypi kernel: [    1.250815] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
      Apr 20 13:02:10 raspberrypi kernel: [    1.251266] pci 0000:01:00.0: PME# supported from D0 D3cold
      Apr 20 13:02:10 raspberrypi kernel: [    1.254766] PCI: bus1: Fast back to back transfers disabled
      Apr 20 13:02:10 raspberrypi kernel: [    1.254880] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      Apr 20 13:02:10 raspberrypi kernel: [    1.254920] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
      Apr 20 13:02:10 raspberrypi kernel: [    1.255023] pci 0000:00:00.0: PCI bridge to [bus 01]
      Apr 20 13:02:10 raspberrypi kernel: [    1.255062] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      Apr 20 13:02:10 raspberrypi kernel: [    1.255500] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      Apr 20 13:02:10 raspberrypi kernel: [    1.255742] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
      Apr 20 13:02:10 raspberrypi kernel: [    1.264103] iproc-rng200 fe104000.rng: hwrng registered
      Apr 20 13:02:10 raspberrypi kernel: [    1.264428] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      Apr 20 13:02:10 raspberrypi kernel: [    1.265307] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
      Apr 20 13:02:10 raspberrypi kernel: [    1.277620] brd: module loaded
      Apr 20 13:02:10 raspberrypi kernel: [    1.289939] loop: module loaded
      Apr 20 13:02:10 raspberrypi kernel: [    1.291604] Loading iSCSI transport class v2.0-870.
      Apr 20 13:02:10 raspberrypi kernel: [    1.294134] libphy: Fixed MDIO Bus: probed
      Apr 20 13:02:10 raspberrypi kernel: [    1.295825] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      Apr 20 13:02:10 raspberrypi kernel: [    1.313931] libphy: bcmgenet MII bus: probed
      Apr 20 13:02:10 raspberrypi kernel: [    1.394006] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      Apr 20 13:02:10 raspberrypi kernel: [    1.395177] usbcore: registered new interface driver r8152
      Apr 20 13:02:10 raspberrypi kernel: [    1.395263] usbcore: registered new interface driver lan78xx
      Apr 20 13:02:10 raspberrypi kernel: [    1.395338] usbcore: registered new interface driver smsc95xx
      Apr 20 13:02:10 raspberrypi kernel: [    1.396962] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
      Apr 20 13:02:10 raspberrypi kernel: [    1.397141] xhci_hcd 0000:01:00.0: xHCI Host Controller
      Apr 20 13:02:10 raspberrypi kernel: [    1.397191] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
      Apr 20 13:02:10 raspberrypi kernel: [    1.400551] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
      Apr 20 13:02:10 raspberrypi kernel: [    1.401898] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
      Apr 20 13:02:10 raspberrypi kernel: [    1.401938] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      Apr 20 13:02:10 raspberrypi kernel: [    1.401975] usb usb1: Product: xHCI Host Controller
      Apr 20 13:02:10 raspberrypi kernel: [    1.402004] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
      Apr 20 13:02:10 raspberrypi kernel: [    1.402035] usb usb1: SerialNumber: 0000:01:00.0
      Apr 20 13:02:10 raspberrypi kernel: [    1.402771] hub 1-0:1.0: USB hub found
      Apr 20 13:02:10 raspberrypi kernel: [    1.402884] hub 1-0:1.0: 1 port detected
      Apr 20 13:02:10 raspberrypi kernel: [    1.403575] xhci_hcd 0000:01:00.0: xHCI Host Controller
      Apr 20 13:02:10 raspberrypi kernel: [    1.403618] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
      Apr 20 13:02:10 raspberrypi kernel: [    1.403663] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      Apr 20 13:02:10 raspberrypi kernel: [    1.404291] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
      Apr 20 13:02:10 raspberrypi kernel: [    1.404331] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      Apr 20 13:02:10 raspberrypi kernel: [    1.404367] usb usb2: Product: xHCI Host Controller
      Apr 20 13:02:10 raspberrypi kernel: [    1.404396] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
      Apr 20 13:02:10 raspberrypi kernel: [    1.404427] usb usb2: SerialNumber: 0000:01:00.0
      Apr 20 13:02:10 raspberrypi kernel: [    1.405166] hub 2-0:1.0: USB hub found
      Apr 20 13:02:10 raspberrypi kernel: [    1.405260] hub 2-0:1.0: 4 ports detected
      Apr 20 13:02:10 raspberrypi kernel: [    1.406957] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      Apr 20 13:02:10 raspberrypi kernel: [    1.407273] dwc_otg: FIQ enabled
      Apr 20 13:02:10 raspberrypi kernel: [    1.407288] dwc_otg: NAK holdoff enabled
      Apr 20 13:02:10 raspberrypi kernel: [    1.407302] dwc_otg: FIQ split-transaction FSM enabled
      Apr 20 13:02:10 raspberrypi kernel: [    1.407320] Module dwc_common_port init
      Apr 20 13:02:10 raspberrypi kernel: [    1.407779] usbcore: registered new interface driver uas
      Apr 20 13:02:10 raspberrypi kernel: [    1.407907] usbcore: registered new interface driver usb-storage
      Apr 20 13:02:10 raspberrypi kernel: [    1.408117] mousedev: PS/2 mouse device common for all mice
      Apr 20 13:02:10 raspberrypi kernel: [    1.409777] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      Apr 20 13:02:10 raspberrypi kernel: [    1.413253] sdhci: Secure Digital Host Controller Interface driver
      Apr 20 13:02:10 raspberrypi kernel: [    1.413288] sdhci: Copyright(c) Pierre Ossman
      Apr 20 13:02:10 raspberrypi kernel: [    1.414041] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
      Apr 20 13:02:10 raspberrypi kernel: [    1.414664] sdhci-pltfm: SDHCI platform and OF driver helper
      Apr 20 13:02:10 raspberrypi kernel: [    1.418816] ledtrig-cpu: registered to indicate activity on CPUs
      Apr 20 13:02:10 raspberrypi kernel: [    1.419176] hid: raw HID events driver (C) Jiri Kosina
      Apr 20 13:02:10 raspberrypi kernel: [    1.419384] usbcore: registered new interface driver usbhid
      Apr 20 13:02:10 raspberrypi kernel: [    1.419414] usbhid: USB HID core driver
      Apr 20 13:02:10 raspberrypi kernel: [    1.425155] Initializing XFRM netlink socket
      Apr 20 13:02:10 raspberrypi kernel: [    1.425218] NET: Registered protocol family 17
      Apr 20 13:02:10 raspberrypi kernel: [    1.425349] Key type dns_resolver registered
      Apr 20 13:02:10 raspberrypi kernel: [    1.425717] Registering SWP/SWPB emulation handler
      Apr 20 13:02:10 raspberrypi kernel: [    1.425910] registered taskstats version 1
      Apr 20 13:02:10 raspberrypi kernel: [    1.425950] Loading compiled-in X.509 certificates
      Apr 20 13:02:10 raspberrypi kernel: [    1.426812] Key type ._fscrypt registered
      Apr 20 13:02:10 raspberrypi kernel: [    1.426843] Key type .fscrypt registered
      Apr 20 13:02:10 raspberrypi kernel: [    1.426871] Key type fscrypt-provisioning registered
      Apr 20 13:02:10 raspberrypi kernel: [    1.438452] uart-pl011 fe201000.serial: there is not valid maps for state default
      Apr 20 13:02:10 raspberrypi kernel: [    1.438794] uart-pl011 fe201000.serial: cts_event_workaround enabled
      Apr 20 13:02:10 raspberrypi kernel: [    1.438887] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
      Apr 20 13:02:10 raspberrypi kernel: [    1.445668] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      Apr 20 13:02:10 raspberrypi kernel: [    1.446729] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      Apr 20 13:02:10 raspberrypi kernel: [    1.446763] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      Apr 20 13:02:10 raspberrypi kernel: [    1.477048] of_cfs_init
      Apr 20 13:02:10 raspberrypi kernel: [    1.477322] of_cfs_init: OK
      Apr 20 13:02:10 raspberrypi kernel: [    1.497315] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      Apr 20 13:02:10 raspberrypi kernel: [    1.499023] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      Apr 20 13:02:10 raspberrypi kernel: [    1.500729] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      Apr 20 13:02:10 raspberrypi kernel: [    1.503764] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      Apr 20 13:02:10 raspberrypi kernel: [    1.505499] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      Apr 20 13:02:10 raspberrypi kernel: [    1.513552] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
      Apr 20 13:02:10 raspberrypi kernel: [    1.515730] Waiting for root device PARTUUID=f546770a-02...
      Apr 20 13:02:10 raspberrypi kernel: [    1.554463] random: fast init done
      Apr 20 13:02:10 raspberrypi kernel: [    1.591543] mmc1: new high speed SDIO card at address 0001
      Apr 20 13:02:10 raspberrypi kernel: [    1.621366] mmc0: new ultra high speed DDR50 SDHC card at address 0001
      Apr 20 13:02:10 raspberrypi kernel: [    1.622293] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
      Apr 20 13:02:10 raspberrypi kernel: [    1.624054]  mmcblk0: p1 p2
      Apr 20 13:02:10 raspberrypi kernel: [    1.643630] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      Apr 20 13:02:10 raspberrypi kernel: [    1.643728] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      Apr 20 13:02:10 raspberrypi kernel: [    1.648939] devtmpfs: mounted
      Apr 20 13:02:10 raspberrypi kernel: [    1.657887] Freeing unused kernel memory: 2048K
      Apr 20 13:02:10 raspberrypi kernel: [    1.704212] Run /sbin/init as init process
      Apr 20 13:02:10 raspberrypi kernel: [    1.704243]   with arguments:
      Apr 20 13:02:10 raspberrypi kernel: [    1.704258]     /sbin/init
      Apr 20 13:02:10 raspberrypi kernel: [    1.704271]   with environment:
      Apr 20 13:02:10 raspberrypi kernel: [    1.704286]     HOME=/
      Apr 20 13:02:10 raspberrypi kernel: [    1.704300]     TERM=linux
      Apr 20 13:02:10 raspberrypi kernel: [    1.763919] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      Apr 20 13:02:10 raspberrypi kernel: [    1.956771] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
      Apr 20 13:02:10 raspberrypi kernel: [    1.956820] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      Apr 20 13:02:10 raspberrypi kernel: [    1.956854] usb 1-1: Product: USB2.0 Hub
      Apr 20 13:02:10 raspberrypi kernel: [    1.959352] hub 1-1:1.0: USB hub found
      Apr 20 13:02:10 raspberrypi kernel: [    1.959659] hub 1-1:1.0: 4 ports detected
      Apr 20 13:02:10 raspberrypi kernel: [    2.211568] NET: Registered protocol family 10
      Apr 20 13:02:10 raspberrypi kernel: [    2.212992] Segment Routing with IPv6
      Apr 20 13:02:10 raspberrypi kernel: [    2.293919] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
      Apr 20 13:02:10 raspberrypi kernel: [    2.431120] usb 1-1.4: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
      Apr 20 13:02:10 raspberrypi kernel: [    2.431175] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      Apr 20 13:02:10 raspberrypi kernel: [    2.988872] random: systemd: uninitialized urandom read (16 bytes read)
      Apr 20 13:02:10 raspberrypi kernel: [    2.999027] random: systemd: uninitialized urandom read (16 bytes read)
      Apr 20 13:02:10 raspberrypi kernel: [    3.000962] random: systemd: uninitialized urandom read (16 bytes read)
      Apr 20 13:02:10 raspberrypi kernel: [    3.635553] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      Apr 20 13:02:10 raspberrypi kernel: [    4.292517] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
      Apr 20 13:02:10 raspberrypi kernel: [    4.309745] mc: Linux media interface: v0.10
      Apr 20 13:02:10 raspberrypi kernel: [    4.314982] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
      Apr 20 13:02:10 raspberrypi kernel: [    4.322646] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
      Apr 20 13:02:10 raspberrypi kernel: [    4.332521] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
      Apr 20 13:02:10 raspberrypi kernel: [    4.338136] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      Apr 20 13:02:10 raspberrypi kernel: [    4.340781] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      Apr 20 13:02:10 raspberrypi kernel: [    4.340807] [vc_sm_connected_init]: start
      Apr 20 13:02:10 raspberrypi kernel: [    4.351493] [vc_sm_connected_init]: installed successfully
      Apr 20 13:02:10 raspberrypi kernel: [    4.353460] videodev: Linux video capture interface: v2.00
      Apr 20 13:02:10 raspberrypi kernel: [    4.376442] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      Apr 20 13:02:10 raspberrypi kernel: [    4.404170] bcm2835_audio bcm2835_audio: card created with 8 channels
      Apr 20 13:02:10 raspberrypi kernel: [    4.412571] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      Apr 20 13:02:10 raspberrypi kernel: [    4.429220] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      Apr 20 13:02:10 raspberrypi kernel: [    4.432063] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
      Apr 20 13:02:10 raspberrypi kernel: [    4.445830] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      Apr 20 13:02:10 raspberrypi kernel: [    4.460476] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
      Apr 20 13:02:10 raspberrypi kernel: [    4.461158] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
      Apr 20 13:02:10 raspberrypi kernel: [    4.461994] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
      Apr 20 13:02:10 raspberrypi kernel: [    4.462528] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
      Apr 20 13:02:10 raspberrypi kernel: [    4.462556] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      Apr 20 13:02:10 raspberrypi kernel: [    4.462580] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      Apr 20 13:02:10 raspberrypi kernel: [    4.462603] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      Apr 20 13:02:10 raspberrypi kernel: [    4.462625] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      Apr 20 13:02:10 raspberrypi kernel: [    4.463176] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      Apr 20 13:02:10 raspberrypi kernel: [    4.468471] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      Apr 20 13:02:10 raspberrypi kernel: [    4.468544] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      Apr 20 13:02:10 raspberrypi kernel: [    4.475685] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      Apr 20 13:02:10 raspberrypi kernel: [    4.475728] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      Apr 20 13:02:10 raspberrypi kernel: [    4.480139] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      Apr 20 13:02:10 raspberrypi kernel: [    4.480199] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      Apr 20 13:02:10 raspberrypi kernel: [    4.559212] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      Apr 20 13:02:10 raspberrypi kernel: [    4.694789] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      Apr 20 13:02:10 raspberrypi kernel: [    4.819570] brcmfmac: F1 signature read @0x18000000=0x15264345
      Apr 20 13:02:10 raspberrypi kernel: [    4.834378] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      Apr 20 13:02:10 raspberrypi kernel: [    4.835385] usbcore: registered new interface driver brcmfmac
      Apr 20 13:02:10 raspberrypi kernel: [    4.861081] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
      Apr 20 13:02:10 raspberrypi kernel: [    4.900227] [drm] No displays found. Consider forcing hotplug if HDMI is attached
      Apr 20 13:02:10 raspberrypi kernel: [    4.900387] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
      Apr 20 13:02:10 raspberrypi kernel: [    4.906440] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
      Apr 20 13:02:10 raspberrypi kernel: [    4.924805] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
      Apr 20 13:02:10 raspberrypi kernel: [    4.984562] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
      Apr 20 13:02:10 raspberrypi kernel: [    4.987621] usbcore: registered new interface driver cdc_acm
      Apr 20 13:02:10 raspberrypi kernel: [    4.987640] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      Apr 20 13:02:10 raspberrypi kernel: [    5.108883] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      Apr 20 13:02:10 raspberrypi kernel: [    5.119706] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
      Apr 20 13:02:10 raspberrypi kernel: [    7.150414] uart-pl011 fe201000.serial: no DMA platform data
      Apr 20 13:02:10 raspberrypi kernel: [    7.255281] 8021q: 802.1Q VLAN Support v1.8
      Apr 20 13:02:10 raspberrypi kernel: [    7.412949] random: crng init done
      Apr 20 13:02:10 raspberrypi kernel: [    7.412971] random: 7 urandom warning(s) missed due to ratelimiting
      Apr 20 13:02:10 raspberrypi kernel: [    7.613896] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
      Apr 20 13:02:10 raspberrypi kernel: [    7.633120] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
      Apr 20 13:02:10 raspberrypi kernel: [    7.854737] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
      Apr 20 13:02:10 raspberrypi kernel: [    7.855001] bcmgenet fd580000.ethernet eth0: Link is Down
      Apr 20 13:02:13 raspberrypi kernel: [   10.954205] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
      Apr 20 13:02:13 raspberrypi kernel: [   10.954258] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      Apr 20 13:02:15 raspberrypi kernel: [   13.076567] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
      Apr 20 13:02:16 raspberrypi kernel: [   14.012299] Bluetooth: Core ver 2.22
      Apr 20 13:02:16 raspberrypi kernel: [   14.012405] NET: Registered protocol family 31
      Apr 20 13:02:16 raspberrypi kernel: [   14.012422] Bluetooth: HCI device and connection manager initialized
      Apr 20 13:02:16 raspberrypi kernel: [   14.012452] Bluetooth: HCI socket layer initialized
      Apr 20 13:02:16 raspberrypi kernel: [   14.012474] Bluetooth: L2CAP socket layer initialized
      Apr 20 13:02:16 raspberrypi kernel: [   14.012509] Bluetooth: SCO socket layer initialized
      Apr 20 13:02:16 raspberrypi kernel: [   14.021474] Bluetooth: HCI UART driver ver 2.3
      Apr 20 13:02:16 raspberrypi kernel: [   14.021492] Bluetooth: HCI UART protocol H4 registered
      Apr 20 13:02:16 raspberrypi kernel: [   14.021584] Bluetooth: HCI UART protocol Three-wire (H5) registered
      Apr 20 13:02:16 raspberrypi kernel: [   14.021833] Bluetooth: HCI UART protocol Broadcom registered
      Apr 20 13:02:17 raspberrypi kernel: [   14.216608] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      Apr 20 13:02:17 raspberrypi kernel: [   14.216617] Bluetooth: BNEP filters: protocol multicast
      Apr 20 13:02:17 raspberrypi kernel: [   14.216630] Bluetooth: BNEP socket layer initialized
      pi@raspberrypi:~ $
      sys.log
      pi@raspberrypi:~ $ cat /var/log/syslog
      Apr 20 00:00:54 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="359" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
      Apr 20 00:00:54 raspberrypi systemd[1]: logrotate.service: Succeeded.
      Apr 20 00:00:54 raspberrypi systemd[1]: Started Rotate log files.
      Apr 20 00:00:55 raspberrypi systemd[1]: man-db.service: Succeeded.
      Apr 20 00:00:55 raspberrypi systemd[1]: Started Daily man-db regeneration.
      Apr 20 00:17:01 raspberrypi CRON[717]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1140064
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1083072
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1083072
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 57
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=507.593; max=547.569)Kibits/s
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.866; max=31.423)Mibits/s
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
      Apr 20 00:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
      Apr 20 00:30:54 raspberrypi systemd[1]: Starting Daily apt download activities...
      Apr 20 00:30:55 raspberrypi systemd[1]: apt-daily.service: Succeeded.
      Apr 20 00:30:55 raspberrypi systemd[1]: Started Daily apt download activities.
      Apr 20 01:17:01 raspberrypi CRON[20321]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1160064
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1113312
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1113312
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 58
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=508.219; max=547.569)Kibits/s
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.962; max=31.423)Mibits/s
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
      Apr 20 01:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
      Apr 20 02:01:24 raspberrypi systemd[1]: iobroker.service: Main process exited, code=killed, status=9/KILL
      Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Failed with result 'signal'.
      Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Service RestartSec=100ms expired, scheduling restart.
      Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2.
      Apr 20 02:01:39 raspberrypi systemd[1]: Stopped ioBroker Server.
      Apr 20 02:01:39 raspberrypi systemd[1]: Started ioBroker Server.
      Apr 20 02:01:43 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.chromecast.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.coronavirus-statistics.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.email.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.fakeroku.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.fritzbox.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.geofency.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.harmony.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.homee.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.hue-extended.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.husq-automower.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ical.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ical.1" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.iot.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.material.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.meross.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mobile.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mqtt.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.netatmo.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.node-red.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.nuki.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.pushover.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.rpi2.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.rssfeed.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.samsung.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.sayit.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.simple-api.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.sonos.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.trashschedule.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-canvas-gauges.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-colorpicker.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-fancyswitch.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-hqwidgets.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-inventwo.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-justgage.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-materialdesign.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-metro.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-timeandweather.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.yeelight-2.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.tr-064.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.zwave2.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mytime.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.tvprogram.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.lgtv.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.daswetter.0" for host "raspberrypi"
      Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ring.0" for host "raspberrypi"
      Apr 20 02:01:47 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
      Apr 20 02:01:47 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      Apr 20 02:03:00 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
      Apr 20 02:03:00 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
      Apr 20 02:17:01 raspberrypi CRON[6125]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1200064
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1143072
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1143072
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 60
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=509.294; max=547.569)Kibits/s
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.794; max=31.423)Mibits/s
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
      Apr 20 02:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
      Apr 20 03:01:42 raspberrypi bash[18274]: host.raspberrypi Delete log file iobroker.2021-04-12.log.gz
      Apr 20 03:17:01 raspberrypi CRON[25997]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1220064
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1173312
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1173312
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 61
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=509.866; max=547.569)Kibits/s
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.888; max=31.423)Mibits/s
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
      Apr 20 03:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
      Apr 20 04:17:01 raspberrypi CRON[13137]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1260064
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1203072
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1203072
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 63
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=510.951; max=547.569)Kibits/s
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.811; max=31.423)Mibits/s
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
      Apr 20 04:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
      Apr 20 05:17:01 raspberrypi CRON[828]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1280064
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1232800
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1232800
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 64
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=511.473; max=547.569)Kibits/s
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.900; max=31.423)Mibits/s
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
      Apr 20 05:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
      Apr 20 06:15:15 raspberrypi systemd[1]: Starting Daily apt upgrade and clean activities...
      Apr 20 06:15:17 raspberrypi systemd[1]: apt-daily-upgrade.service: Succeeded.
      Apr 20 06:15:17 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
      Apr 20 06:17:01 raspberrypi CRON[20952]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1320064
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1262560
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1262560
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 66
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=512.471; max=547.569)Kibits/s
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.754; max=31.423)Mibits/s
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
      Apr 20 06:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
      Apr 20 06:25:02 raspberrypi CRON[32245]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily ))
      Apr 20 07:13:29 raspberrypi bash[18274]: Tue, 20 Apr 2021 05:13:29 GMT node-telegram-bot-api deprecated In the future, content-type of files you send will default to "application/octet-stream". See https://github.com/yagop/node-telegram-bot-api/blob/master/doc/usage.md#sending-files for more information on how sending files has been improved and on how to disable this deprecation message altogether. at opt/iobroker/node_modules/iobroker.telegram/main.js:634:20
      Apr 20 07:17:01 raspberrypi CRON[8035]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1340064
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1292800
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1292800
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 67
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=512.947; max=547.569)Kibits/s
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.839; max=31.423)Mibits/s
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
      Apr 20 07:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
      homee, ioBroker, iMac, iPhone, Sonos, Alaxa
      • bergjetB bergjet
        kernel.log
        Apr 20 02:01:23 raspberrypi kernel: [135707.349180] node invoked oom-killer: gfp_mask=0x400dc2(GFP_KERNEL_ACCOUNT|__GFP_HIGHMEM|__GFP_ZERO), order=0, oom_score_adj=0
        Apr 20 02:01:23 raspberrypi kernel: [135707.349192] CPU: 2 PID: 30402 Comm: node Tainted: G         C        5.10.17-v7l+ #1403
        Apr 20 02:01:23 raspberrypi kernel: [135707.349197] Hardware name: BCM2711
        Apr 20 02:01:23 raspberrypi kernel: [135707.349201] Backtrace:
        Apr 20 02:01:23 raspberrypi kernel: [135707.349223] [<c0b63050>] (dump_backtrace) from [<c0b633e4>] (show_stack+0x20/0x24)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349230]  r7:ffffffff r6:00000000 r5:60000113 r4:c12e69fc
        Apr 20 02:01:23 raspberrypi kernel: [135707.349239] [<c0b633c4>] (show_stack) from [<c0b67774>] (dump_stack+0xcc/0xf8)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349245] [<c0b676a8>] (dump_stack) from [<c0b65a04>] (dump_header+0x64/0x208)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349251]  r10:c120518c r9:00400dc2 r8:00000000 r7:c0e3709c r6:c7f16a00 r5:c9ffbe00
        Apr 20 02:01:23 raspberrypi kernel: [135707.349256]  r4:c7a8dde8 r3:eaf5c060
        Apr 20 02:01:23 raspberrypi kernel: [135707.349265] [<c0b659a0>] (dump_header) from [<c03b6cd0>] (oom_kill_process+0x1b4/0x1c0)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349270]  r7:c0e3709c r6:c7a8dde8 r5:c9ffc380 r4:c9ffbe00
        Apr 20 02:01:23 raspberrypi kernel: [135707.349277] [<c03b6b1c>] (oom_kill_process) from [<c03b7848>] (out_of_memory+0x2b8/0x390)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349282]  r7:c1208580 r6:c1205048 r5:c9ffbe00 r4:c7a8dde8
        Apr 20 02:01:23 raspberrypi kernel: [135707.349290] [<c03b7590>] (out_of_memory) from [<c040a8bc>] (__alloc_pages_nodemask+0x7ec/0x1184)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349296]  r7:c1336790 r6:00001400 r5:00001dec r4:00000000
        Apr 20 02:01:23 raspberrypi kernel: [135707.349304] [<c040a0d0>] (__alloc_pages_nodemask) from [<c03ec934>] (__pte_alloc+0x34/0x168)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349310]  r10:c1205048 r9:00000040 r8:00000255 r7:00000000 r6:c7eaad28 r5:c40a0200
        Apr 20 02:01:23 raspberrypi kernel: [135707.349314]  r4:34acf000
        Apr 20 02:01:23 raspberrypi kernel: [135707.349321] [<c03ec900>] (__pte_alloc) from [<c03f0068>] (handle_mm_fault+0x100c/0x1124)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349326]  r7:00000000 r6:07eaa003 r5:00000000 r4:34acf000
        Apr 20 02:01:23 raspberrypi kernel: [135707.349334] [<c03ef05c>] (handle_mm_fault) from [<c0b739d4>] (do_page_fault+0x144/0x314)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349339]  r10:00000255 r9:00000800 r8:c40a0248 r7:c40a0200 r6:00000a06 r5:34acf000
        Apr 20 02:01:23 raspberrypi kernel: [135707.349343]  r4:c7a8dfb0
        Apr 20 02:01:23 raspberrypi kernel: [135707.349349] [<c0b73890>] (do_page_fault) from [<c0b73c84>] (do_translation_fault+0xe0/0x10c)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349355]  r10:00000000 r9:b6d25258 r8:00000a06 r7:34acf000 r6:c0b73ba4 r5:00000a06
        Apr 20 02:01:23 raspberrypi kernel: [135707.349359]  r4:c120aef8
        Apr 20 02:01:23 raspberrypi kernel: [135707.349366] [<c0b73ba4>] (do_translation_fault) from [<c0214c6c>] (do_DataAbort+0x40/0xc0)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349372]  r9:b6d25258 r8:c7a8dfb0 r7:34acf000 r6:c0b73ba4 r5:00000a06 r4:c120aef8
        Apr 20 02:01:23 raspberrypi kernel: [135707.349379] [<c0214c2c>] (do_DataAbort) from [<c0200da4>] (__dabt_usr+0x44/0x60)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349383] Exception stack(0xc7a8dfb0 to 0xc7a8dff8)
        Apr 20 02:01:23 raspberrypi kernel: [135707.349388] dfa0:                                     34acf000 002f1002 00000000 34acf008
        Apr 20 02:01:23 raspberrypi kernel: [135707.349394] dfc0: b6d257d4 002f1000 0005e1a6 002f0d40 b6d25000 b6d25258 00000000 fffff000
        Apr 20 02:01:23 raspberrypi kernel: [135707.349399] dfe0: b6d2526c bef6d328 b6d25258 b6c4b8d8 40000010 ffffffff
        Apr 20 02:01:23 raspberrypi kernel: [135707.349405]  r8:30c5387d r7:30c5383d r6:ffffffff r5:40000010 r4:b6c4b8d8
        Apr 20 02:01:23 raspberrypi kernel: [135707.349409] Mem-Info:
        Apr 20 02:01:23 raspberrypi kernel: [135707.349421] active_anon:35326 inactive_anon:905949 isolated_anon:0
        Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  active_file:3396 inactive_file:3998 isolated_file:32
        Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  unevictable:4 dirty:39 writeback:0
        Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  slab_reclaimable:3544 slab_unreclaimable:5676
        Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  mapped:3307 shmem:519 pagetables:9482 bounce:0
        Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  free:6738 free_pcp:0 free_cma:0
        Apr 20 02:01:23 raspberrypi kernel: [135707.349431] Node 0 active_anon:141304kB inactive_anon:3623796kB active_file:13584kB inactive_file:15992kB unevictable:16kB isolated(anon):0kB isolated(file):128kB mapped:13228kB dirty:156kB writeback:0kB shmem:2076kB writeback_tmp:0kB kernel_stack:5072kB all_unreclaimable? no
        Apr 20 02:01:23 raspberrypi kernel: [135707.349442] DMA free:24532kB min:20480kB low:24576kB high:28672kB reserved_highatomic:0KB active_anon:1812kB inactive_anon:567188kB active_file:1012kB inactive_file:4744kB unevictable:0kB writepending:40kB present:786432kB managed:654620kB mlocked:0kB pagetables:1836kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
        Apr 20 02:01:23 raspberrypi kernel: [135707.349448] lowmem_reserve[]: 0 0 3188 0
        Apr 20 02:01:23 raspberrypi kernel: [135707.349484] HighMem free:2420kB min:62552kB low:82976kB high:103400kB reserved_highatomic:0KB active_anon:140040kB inactive_anon:3055932kB active_file:12988kB inactive_file:10932kB unevictable:16kB writepending:116kB present:3264512kB managed:3264512kB mlocked:16kB pagetables:36092kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
        Apr 20 02:01:23 raspberrypi kernel: [135707.349490] lowmem_reserve[]: 0 0 0 0
        Apr 20 02:01:23 raspberrypi kernel: [135707.349522] DMA: 209*4kB (UME) 481*8kB (UMEC) 409*16kB (UME) 194*32kB (UME) 80*64kB (UME) 16*128kB (UM) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 24604kB
        Apr 20 02:01:23 raspberrypi kernel: [135707.349625] HighMem: 148*4kB (UM) 89*8kB (UM) 25*16kB (UM) 6*32kB (UM) 20*64kB (M) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 3176kB
        Apr 20 02:01:23 raspberrypi kernel: [135707.349723] 5758 total pagecache pages
        Apr 20 02:01:23 raspberrypi kernel: [135707.349730] 175 pages in swap cache
        Apr 20 02:01:23 raspberrypi kernel: [135707.349737] Swap cache stats: add 59748, delete 59572, find 4768/8730
        Apr 20 02:01:23 raspberrypi kernel: [135707.349743] Free swap  = 0kB
        Apr 20 02:01:23 raspberrypi kernel: [135707.349749] Total swap = 102396kB
        Apr 20 02:01:23 raspberrypi kernel: [135707.349755] 1012736 pages RAM
        Apr 20 02:01:23 raspberrypi kernel: [135707.349761] 816128 pages HighMem/MovableOnly
        Apr 20 02:01:23 raspberrypi kernel: [135707.349767] 32953 pages reserved
        Apr 20 02:01:23 raspberrypi kernel: [135707.349772] 65536 pages cma reserved
        Apr 20 02:01:23 raspberrypi kernel: [135707.349779] Tasks state (memory values in pages):
        Apr 20 02:01:23 raspberrypi kernel: [135707.349785] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
        Apr 20 02:01:23 raspberrypi kernel: [135707.349799] [    122]     0   122     5310     1101   131072        1             0 systemd-journal
        Apr 20 02:01:23 raspberrypi kernel: [135707.349807] [    148]     0   148     4499      202    49152        0         -1000 systemd-udevd
        Apr 20 02:01:23 raspberrypi kernel: [135707.349818] [    298]   100   298     5604      359    61440        0             0 systemd-timesyn
        Apr 20 02:01:23 raspberrypi kernel: [135707.349825] [    336]     0   336     1987      206    45056        0             0 cron
        Apr 20 02:01:23 raspberrypi kernel: [135707.349833] [    341]   104   341     1639      176    36864        0          -900 dbus-daemon
        Apr 20 02:01:23 raspberrypi kernel: [135707.349841] [    349]   108   349     1640      432    32768        0             0 avahi-daemon
        Apr 20 02:01:23 raspberrypi kernel: [135707.349849] [    350]     0   350     2686      181    45056        0             0 wpa_supplicant
        Apr 20 02:01:23 raspberrypi kernel: [135707.349856] [    359]     0   359     6378      358    45056        4             0 rsyslogd
        Apr 20 02:01:23 raspberrypi kernel: [135707.349864] [    361] 65534   361     1080       85    32768        0             0 thd
        Apr 20 02:01:23 raspberrypi kernel: [135707.349872] [    363]     0   363     6914       90    36864        2             0 rngd
        Apr 20 02:01:23 raspberrypi kernel: [135707.349880] [    371]   108   371     1442       55    32768        8             0 avahi-daemon
        Apr 20 02:01:23 raspberrypi kernel: [135707.349888] [    373]     0   373      923       77    32768        0             0 alsactl
        Apr 20 02:01:23 raspberrypi kernel: [135707.349896] [    383]     0   383     3228      246    53248        0             0 systemd-logind
        Apr 20 02:01:23 raspberrypi kernel: [135707.349904] [    464]     0   464     2751       91    45056       79             0 wpa_supplicant
        Apr 20 02:01:23 raspberrypi kernel: [135707.349911] [    479]     0   479      535       12    28672       20             0 hciattach
        Apr 20 02:01:23 raspberrypi kernel: [135707.349919] [    482]     0   482     2384       71    40960        0             0 bluetoothd
        Apr 20 02:01:23 raspberrypi kernel: [135707.349927] [    547]     0   547      726      228    28672       60             0 dhcpcd
        Apr 20 02:01:23 raspberrypi kernel: [135707.349935] [    553]     0   553     1077       22    32768        0             0 agetty
        Apr 20 02:01:23 raspberrypi kernel: [135707.349942] [    555]     0   555     2682      150    49152        0         -1000 sshd
        Apr 20 02:01:23 raspberrypi kernel: [135707.349950] [  30402]  1001 30402   586177   549850  5492736     2877             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.349958] [  30581]  1001 30581    45284     5149   921600     9869             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.349966] [  30596]  1001 30596    38986     4701   622592     2987             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.349973] [  30618]  1001 30618    45150    10907   770048     3644             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.349981] [  30648]  1001 30648    39337     5230   643072     2828             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.349989] [  30678]  1001 30678    38834     6717   598016     1582             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.349996] [  30708]  1001 30708    39563     8011   610304        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350004] [  30738]  1001 30738    40084     9530   643072        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350011] [  30772]  1001 30772    40070     9700   557056        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350019] [  30809]  1001 30809    42845    11617   733184        2             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350026] [  30820]  1001 30820    42287    16068   643072        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350034] [  30854]  1001 30854    43537    13961   741376        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350042] [  30872]  1001 30872    40476     9257   643072        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350049] [  30929]  1001 30929    45589    15181   745472        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350057] [  30959]  1001 30959    41057    10303   704512        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350065] [  31482]  1001 31482    58032    27676  1118208        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350073] [  31502]  1001 31502    41579    10242   712704        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350080] [  31701]  1001 31701    44816    15632   856064        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350088] [  31723]  1001 31723    41736     9803   671744        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350096] [  31759]  1001 31759    38354     8109   585728        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350104] [  31935]  1001 31935    39537     8623   614400        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350111] [  31942]  1001 31942    58856    28730  1236992        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350119] [  32032]  1001 32032    40009     9640   700416        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350126] [  32154]  1001 32154    39480     8089   626688        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350134] [  32345]  1001 32345    38903     8763   610304        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350141] [  32373]  1001 32373    41231    10602   712704        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350149] [  32546]  1001 32546    39094     8941   655360        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350156] [  32651]  1001 32651    39185     7901   626688        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350164] [  32736]  1001 32736    38878     7986   602112        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350171] [    440]  1001   440    40017     9579   692224        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350179] [    659]  1001   659    39302     8485   630784        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350187] [    888]  1001   888    39670     8754   651264        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350195] [   1087]  1001  1087    38337     7372   581632        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350203] [   1443]  1001  1443    39299     8623   618496        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350211] [   1450]  1001  1450    42483    12549   688128        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350219] [   1463]  1001  1463    42582    12326   790528        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350226] [   1496]  1001  1496    38381     7868   610304        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350234] [   1681]  1001  1681    42361    11271   749568        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350241] [   1688]  1001  1688    42241    12155   741376        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350249] [   1706]  1001  1706    39041     7989   618496        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350257] [   1940]  1001  1940    47010    17102   843776        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350265] [   5108]  1001  5108    46936    17112   876544        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350273] [   7580]  1001  7580    43672    12220   716800        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350282] [  16135]  1001 16135    37555     6788   577536        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350290] [  16337]  1001 16337    40542    10018   663552        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350298] [  16363]  1001 16363    38619     8052   647168        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350305] [  16542]  1001 16542    38988    16908   806912        0             0 node
        Apr 20 02:01:23 raspberrypi kernel: [135707.350314] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=30402,uid=1001
        Apr 20 02:01:23 raspberrypi kernel: [135707.350388] Out of memory: Killed process 30402 (node) total-vm:2344708kB, anon-rss:2189760kB, file-rss:9640kB, shmem-rss:0kB, UID:1001 pgtables:5364kB oom_score_adj:0
        Apr 20 02:01:24 raspberrypi kernel: [135707.559391] oom_reaper: reaped process 30402 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
        Apr 20 13:01:56 raspberrypi kernel: [175340.649230] Bluetooth: hci0: sending frame failed (-49)
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Zone ranges:
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   Normal   empty
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Movable zone start for each node
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Early memory node ranges
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] On node 0 totalpages: 1012736
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 2304 pages used for memmap
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 0 pages reserved
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:11:CE:96 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f546770a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Memory: 3654940K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133860K reserved, 262144K cma-reserved, 3264512K highmem)
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] ftrace: allocating 33942 entries in 67 pages
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] ftrace: allocated 67 pages with 3 groups
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] rcu: Hierarchical RCU implementation.
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
        Apr 20 13:02:10 raspberrypi kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
        Apr 20 13:02:10 raspberrypi kernel: [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
        Apr 20 13:02:10 raspberrypi kernel: [    0.000034] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
        Apr 20 13:02:10 raspberrypi kernel: [    0.000098] bcm2835: system timer (irq = 25)
        Apr 20 13:02:10 raspberrypi kernel: [    0.000750] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
        Apr 20 13:02:10 raspberrypi kernel: [    0.000772] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
        Apr 20 13:02:10 raspberrypi kernel: [    0.000795] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
        Apr 20 13:02:10 raspberrypi kernel: [    0.000813] Switching to timer-based delay loop, resolution 18ns
        Apr 20 13:02:10 raspberrypi kernel: [    0.001065] Console: colour dummy device 80x30
        Apr 20 13:02:10 raspberrypi kernel: [    0.001808] printk: console [tty1] enabled
        Apr 20 13:02:10 raspberrypi kernel: [    0.001874] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
        Apr 20 13:02:10 raspberrypi kernel: [    0.001928] pid_max: default: 32768 minimum: 301
        Apr 20 13:02:10 raspberrypi kernel: [    0.002109] LSM: Security Framework initializing
        Apr 20 13:02:10 raspberrypi kernel: [    0.002306] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        Apr 20 13:02:10 raspberrypi kernel: [    0.002352] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        Apr 20 13:02:10 raspberrypi kernel: [    0.003929] Disabling memory control group subsystem
        Apr 20 13:02:10 raspberrypi kernel: [    0.004064] CPU: Testing write buffer coherency: ok
        Apr 20 13:02:10 raspberrypi kernel: [    0.004536] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        Apr 20 13:02:10 raspberrypi kernel: [    0.005755] Setting up static identity map for 0x200000 - 0x20003c
        Apr 20 13:02:10 raspberrypi kernel: [    0.005970] rcu: Hierarchical SRCU implementation.
        Apr 20 13:02:10 raspberrypi kernel: [    0.006915] smp: Bringing up secondary CPUs ...
        Apr 20 13:02:10 raspberrypi kernel: [    0.008137] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        Apr 20 13:02:10 raspberrypi kernel: [    0.009502] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
        Apr 20 13:02:10 raspberrypi kernel: [    0.010810] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
        Apr 20 13:02:10 raspberrypi kernel: [    0.010966] smp: Brought up 1 node, 4 CPUs
        Apr 20 13:02:10 raspberrypi kernel: [    0.011011] SMP: Total of 4 processors activated (432.00 BogoMIPS).
        Apr 20 13:02:10 raspberrypi kernel: [    0.011042] CPU: All CPU(s) started in HYP mode.
        Apr 20 13:02:10 raspberrypi kernel: [    0.011069] CPU: Virtualization extensions available.
        Apr 20 13:02:10 raspberrypi kernel: [    0.011910] devtmpfs: initialized
        Apr 20 13:02:10 raspberrypi kernel: [    0.025725] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
        Apr 20 13:02:10 raspberrypi kernel: [    0.025986] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        Apr 20 13:02:10 raspberrypi kernel: [    0.026040] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        Apr 20 13:02:10 raspberrypi kernel: [    0.033085] pinctrl core: initialized pinctrl subsystem
        Apr 20 13:02:10 raspberrypi kernel: [    0.034183] NET: Registered protocol family 16
        Apr 20 13:02:10 raspberrypi kernel: [    0.038180] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        Apr 20 13:02:10 raspberrypi kernel: [    0.038964] audit: initializing netlink subsys (disabled)
        Apr 20 13:02:10 raspberrypi kernel: [    0.039250] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
        Apr 20 13:02:10 raspberrypi kernel: [    0.039809] thermal_sys: Registered thermal governor 'step_wise'
        Apr 20 13:02:10 raspberrypi kernel: [    0.040494] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        Apr 20 13:02:10 raspberrypi kernel: [    0.040548] hw-breakpoint: maximum watchpoint size is 8 bytes.
        Apr 20 13:02:10 raspberrypi kernel: [    0.040983] Serial: AMBA PL011 UART driver
        Apr 20 13:02:10 raspberrypi kernel: [    0.072819] bcm2835-mbox fe00b880.mailbox: mailbox enabled
        Apr 20 13:02:10 raspberrypi kernel: [    0.090958] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
        Apr 20 13:02:10 raspberrypi kernel: [    0.100971] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
        Apr 20 13:02:10 raspberrypi kernel: [    0.146228] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
        Apr 20 13:02:10 raspberrypi kernel: [    0.150377] vgaarb: loaded
        Apr 20 13:02:10 raspberrypi kernel: [    0.150838] SCSI subsystem initialized
        Apr 20 13:02:10 raspberrypi kernel: [    0.151443] usbcore: registered new interface driver usbfs
        Apr 20 13:02:10 raspberrypi kernel: [    0.151532] usbcore: registered new interface driver hub
        Apr 20 13:02:10 raspberrypi kernel: [    0.151622] usbcore: registered new device driver usb
        Apr 20 13:02:10 raspberrypi kernel: [    0.151972] usb_phy_generic phy: supply vcc not found, using dummy regulator
        Apr 20 13:02:10 raspberrypi kernel: [    0.153863] clocksource: Switched to clocksource arch_sys_counter
        Apr 20 13:02:10 raspberrypi kernel: [    1.152554] VFS: Disk quotas dquot_6.6.0
        Apr 20 13:02:10 raspberrypi kernel: [    1.152679] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        Apr 20 13:02:10 raspberrypi kernel: [    1.152860] FS-Cache: Loaded
        Apr 20 13:02:10 raspberrypi kernel: [    1.153087] CacheFiles: Loaded
        Apr 20 13:02:10 raspberrypi kernel: [    1.163453] NET: Registered protocol family 2
        Apr 20 13:02:10 raspberrypi kernel: [    1.164344] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        Apr 20 13:02:10 raspberrypi kernel: [    1.164506] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
        Apr 20 13:02:10 raspberrypi kernel: [    1.164587] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
        Apr 20 13:02:10 raspberrypi kernel: [    1.164673] TCP: Hash tables configured (established 8192 bind 8192)
        Apr 20 13:02:10 raspberrypi kernel: [    1.164845] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
        Apr 20 13:02:10 raspberrypi kernel: [    1.164900] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
        Apr 20 13:02:10 raspberrypi kernel: [    1.165191] NET: Registered protocol family 1
        Apr 20 13:02:10 raspberrypi kernel: [    1.165911] RPC: Registered named UNIX socket transport module.
        Apr 20 13:02:10 raspberrypi kernel: [    1.165944] RPC: Registered udp transport module.
        Apr 20 13:02:10 raspberrypi kernel: [    1.165972] RPC: Registered tcp transport module.
        Apr 20 13:02:10 raspberrypi kernel: [    1.166000] RPC: Registered tcp NFSv4.1 backchannel transport module.
        Apr 20 13:02:10 raspberrypi kernel: [    1.166037] PCI: CLS 0 bytes, default 64
        Apr 20 13:02:10 raspberrypi kernel: [    1.168924] Initialise system trusted keyrings
        Apr 20 13:02:10 raspberrypi kernel: [    1.169198] workingset: timestamp_bits=14 max_order=20 bucket_order=6
        Apr 20 13:02:10 raspberrypi kernel: [    1.177760] zbud: loaded
        Apr 20 13:02:10 raspberrypi kernel: [    1.179686] FS-Cache: Netfs 'nfs' registered for caching
        Apr 20 13:02:10 raspberrypi kernel: [    1.180481] NFS: Registering the id_resolver key type
        Apr 20 13:02:10 raspberrypi kernel: [    1.180543] Key type id_resolver registered
        Apr 20 13:02:10 raspberrypi kernel: [    1.180572] Key type id_legacy registered
        Apr 20 13:02:10 raspberrypi kernel: [    1.180736] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        Apr 20 13:02:10 raspberrypi kernel: [    1.181775] Key type asymmetric registered
        Apr 20 13:02:10 raspberrypi kernel: [    1.181807] Asymmetric key parser 'x509' registered
        Apr 20 13:02:10 raspberrypi kernel: [    1.182011] bounce: pool size: 64 pages
        Apr 20 13:02:10 raspberrypi kernel: [    1.182067] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
        Apr 20 13:02:10 raspberrypi kernel: [    1.182298] io scheduler mq-deadline registered
        Apr 20 13:02:10 raspberrypi kernel: [    1.182329] io scheduler kyber registered
        Apr 20 13:02:10 raspberrypi kernel: [    1.186772] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
        Apr 20 13:02:10 raspberrypi kernel: [    1.186824] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
        Apr 20 13:02:10 raspberrypi kernel: [    1.186926] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
        Apr 20 13:02:10 raspberrypi kernel: [    1.187036] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
        Apr 20 13:02:10 raspberrypi kernel: [    1.246001] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
        Apr 20 13:02:10 raspberrypi kernel: [    1.246381] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
        Apr 20 13:02:10 raspberrypi kernel: [    1.246419] pci_bus 0000:00: root bus resource [bus 00-ff]
        Apr 20 13:02:10 raspberrypi kernel: [    1.246454] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
        Apr 20 13:02:10 raspberrypi kernel: [    1.246563] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
        Apr 20 13:02:10 raspberrypi kernel: [    1.246821] pci 0000:00:00.0: PME# supported from D0 D3hot
        Apr 20 13:02:10 raspberrypi kernel: [    1.250318] PCI: bus0: Fast back to back transfers disabled
        Apr 20 13:02:10 raspberrypi kernel: [    1.250672] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
        Apr 20 13:02:10 raspberrypi kernel: [    1.250815] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
        Apr 20 13:02:10 raspberrypi kernel: [    1.251266] pci 0000:01:00.0: PME# supported from D0 D3cold
        Apr 20 13:02:10 raspberrypi kernel: [    1.254766] PCI: bus1: Fast back to back transfers disabled
        Apr 20 13:02:10 raspberrypi kernel: [    1.254880] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
        Apr 20 13:02:10 raspberrypi kernel: [    1.254920] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
        Apr 20 13:02:10 raspberrypi kernel: [    1.255023] pci 0000:00:00.0: PCI bridge to [bus 01]
        Apr 20 13:02:10 raspberrypi kernel: [    1.255062] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
        Apr 20 13:02:10 raspberrypi kernel: [    1.255500] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
        Apr 20 13:02:10 raspberrypi kernel: [    1.255742] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
        Apr 20 13:02:10 raspberrypi kernel: [    1.264103] iproc-rng200 fe104000.rng: hwrng registered
        Apr 20 13:02:10 raspberrypi kernel: [    1.264428] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
        Apr 20 13:02:10 raspberrypi kernel: [    1.265307] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
        Apr 20 13:02:10 raspberrypi kernel: [    1.277620] brd: module loaded
        Apr 20 13:02:10 raspberrypi kernel: [    1.289939] loop: module loaded
        Apr 20 13:02:10 raspberrypi kernel: [    1.291604] Loading iSCSI transport class v2.0-870.
        Apr 20 13:02:10 raspberrypi kernel: [    1.294134] libphy: Fixed MDIO Bus: probed
        Apr 20 13:02:10 raspberrypi kernel: [    1.295825] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
        Apr 20 13:02:10 raspberrypi kernel: [    1.313931] libphy: bcmgenet MII bus: probed
        Apr 20 13:02:10 raspberrypi kernel: [    1.394006] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
        Apr 20 13:02:10 raspberrypi kernel: [    1.395177] usbcore: registered new interface driver r8152
        Apr 20 13:02:10 raspberrypi kernel: [    1.395263] usbcore: registered new interface driver lan78xx
        Apr 20 13:02:10 raspberrypi kernel: [    1.395338] usbcore: registered new interface driver smsc95xx
        Apr 20 13:02:10 raspberrypi kernel: [    1.396962] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
        Apr 20 13:02:10 raspberrypi kernel: [    1.397141] xhci_hcd 0000:01:00.0: xHCI Host Controller
        Apr 20 13:02:10 raspberrypi kernel: [    1.397191] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
        Apr 20 13:02:10 raspberrypi kernel: [    1.400551] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
        Apr 20 13:02:10 raspberrypi kernel: [    1.401898] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
        Apr 20 13:02:10 raspberrypi kernel: [    1.401938] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        Apr 20 13:02:10 raspberrypi kernel: [    1.401975] usb usb1: Product: xHCI Host Controller
        Apr 20 13:02:10 raspberrypi kernel: [    1.402004] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
        Apr 20 13:02:10 raspberrypi kernel: [    1.402035] usb usb1: SerialNumber: 0000:01:00.0
        Apr 20 13:02:10 raspberrypi kernel: [    1.402771] hub 1-0:1.0: USB hub found
        Apr 20 13:02:10 raspberrypi kernel: [    1.402884] hub 1-0:1.0: 1 port detected
        Apr 20 13:02:10 raspberrypi kernel: [    1.403575] xhci_hcd 0000:01:00.0: xHCI Host Controller
        Apr 20 13:02:10 raspberrypi kernel: [    1.403618] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
        Apr 20 13:02:10 raspberrypi kernel: [    1.403663] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
        Apr 20 13:02:10 raspberrypi kernel: [    1.404291] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
        Apr 20 13:02:10 raspberrypi kernel: [    1.404331] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        Apr 20 13:02:10 raspberrypi kernel: [    1.404367] usb usb2: Product: xHCI Host Controller
        Apr 20 13:02:10 raspberrypi kernel: [    1.404396] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
        Apr 20 13:02:10 raspberrypi kernel: [    1.404427] usb usb2: SerialNumber: 0000:01:00.0
        Apr 20 13:02:10 raspberrypi kernel: [    1.405166] hub 2-0:1.0: USB hub found
        Apr 20 13:02:10 raspberrypi kernel: [    1.405260] hub 2-0:1.0: 4 ports detected
        Apr 20 13:02:10 raspberrypi kernel: [    1.406957] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        Apr 20 13:02:10 raspberrypi kernel: [    1.407273] dwc_otg: FIQ enabled
        Apr 20 13:02:10 raspberrypi kernel: [    1.407288] dwc_otg: NAK holdoff enabled
        Apr 20 13:02:10 raspberrypi kernel: [    1.407302] dwc_otg: FIQ split-transaction FSM enabled
        Apr 20 13:02:10 raspberrypi kernel: [    1.407320] Module dwc_common_port init
        Apr 20 13:02:10 raspberrypi kernel: [    1.407779] usbcore: registered new interface driver uas
        Apr 20 13:02:10 raspberrypi kernel: [    1.407907] usbcore: registered new interface driver usb-storage
        Apr 20 13:02:10 raspberrypi kernel: [    1.408117] mousedev: PS/2 mouse device common for all mice
        Apr 20 13:02:10 raspberrypi kernel: [    1.409777] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        Apr 20 13:02:10 raspberrypi kernel: [    1.413253] sdhci: Secure Digital Host Controller Interface driver
        Apr 20 13:02:10 raspberrypi kernel: [    1.413288] sdhci: Copyright(c) Pierre Ossman
        Apr 20 13:02:10 raspberrypi kernel: [    1.414041] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
        Apr 20 13:02:10 raspberrypi kernel: [    1.414664] sdhci-pltfm: SDHCI platform and OF driver helper
        Apr 20 13:02:10 raspberrypi kernel: [    1.418816] ledtrig-cpu: registered to indicate activity on CPUs
        Apr 20 13:02:10 raspberrypi kernel: [    1.419176] hid: raw HID events driver (C) Jiri Kosina
        Apr 20 13:02:10 raspberrypi kernel: [    1.419384] usbcore: registered new interface driver usbhid
        Apr 20 13:02:10 raspberrypi kernel: [    1.419414] usbhid: USB HID core driver
        Apr 20 13:02:10 raspberrypi kernel: [    1.425155] Initializing XFRM netlink socket
        Apr 20 13:02:10 raspberrypi kernel: [    1.425218] NET: Registered protocol family 17
        Apr 20 13:02:10 raspberrypi kernel: [    1.425349] Key type dns_resolver registered
        Apr 20 13:02:10 raspberrypi kernel: [    1.425717] Registering SWP/SWPB emulation handler
        Apr 20 13:02:10 raspberrypi kernel: [    1.425910] registered taskstats version 1
        Apr 20 13:02:10 raspberrypi kernel: [    1.425950] Loading compiled-in X.509 certificates
        Apr 20 13:02:10 raspberrypi kernel: [    1.426812] Key type ._fscrypt registered
        Apr 20 13:02:10 raspberrypi kernel: [    1.426843] Key type .fscrypt registered
        Apr 20 13:02:10 raspberrypi kernel: [    1.426871] Key type fscrypt-provisioning registered
        Apr 20 13:02:10 raspberrypi kernel: [    1.438452] uart-pl011 fe201000.serial: there is not valid maps for state default
        Apr 20 13:02:10 raspberrypi kernel: [    1.438794] uart-pl011 fe201000.serial: cts_event_workaround enabled
        Apr 20 13:02:10 raspberrypi kernel: [    1.438887] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
        Apr 20 13:02:10 raspberrypi kernel: [    1.445668] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        Apr 20 13:02:10 raspberrypi kernel: [    1.446729] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
        Apr 20 13:02:10 raspberrypi kernel: [    1.446763] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
        Apr 20 13:02:10 raspberrypi kernel: [    1.477048] of_cfs_init
        Apr 20 13:02:10 raspberrypi kernel: [    1.477322] of_cfs_init: OK
        Apr 20 13:02:10 raspberrypi kernel: [    1.497315] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
        Apr 20 13:02:10 raspberrypi kernel: [    1.499023] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        Apr 20 13:02:10 raspberrypi kernel: [    1.500729] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        Apr 20 13:02:10 raspberrypi kernel: [    1.503764] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
        Apr 20 13:02:10 raspberrypi kernel: [    1.505499] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        Apr 20 13:02:10 raspberrypi kernel: [    1.513552] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
        Apr 20 13:02:10 raspberrypi kernel: [    1.515730] Waiting for root device PARTUUID=f546770a-02...
        Apr 20 13:02:10 raspberrypi kernel: [    1.554463] random: fast init done
        Apr 20 13:02:10 raspberrypi kernel: [    1.591543] mmc1: new high speed SDIO card at address 0001
        Apr 20 13:02:10 raspberrypi kernel: [    1.621366] mmc0: new ultra high speed DDR50 SDHC card at address 0001
        Apr 20 13:02:10 raspberrypi kernel: [    1.622293] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
        Apr 20 13:02:10 raspberrypi kernel: [    1.624054]  mmcblk0: p1 p2
        Apr 20 13:02:10 raspberrypi kernel: [    1.643630] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        Apr 20 13:02:10 raspberrypi kernel: [    1.643728] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        Apr 20 13:02:10 raspberrypi kernel: [    1.648939] devtmpfs: mounted
        Apr 20 13:02:10 raspberrypi kernel: [    1.657887] Freeing unused kernel memory: 2048K
        Apr 20 13:02:10 raspberrypi kernel: [    1.704212] Run /sbin/init as init process
        Apr 20 13:02:10 raspberrypi kernel: [    1.704243]   with arguments:
        Apr 20 13:02:10 raspberrypi kernel: [    1.704258]     /sbin/init
        Apr 20 13:02:10 raspberrypi kernel: [    1.704271]   with environment:
        Apr 20 13:02:10 raspberrypi kernel: [    1.704286]     HOME=/
        Apr 20 13:02:10 raspberrypi kernel: [    1.704300]     TERM=linux
        Apr 20 13:02:10 raspberrypi kernel: [    1.763919] usb 1-1: new high-speed USB device number 2 using xhci_hcd
        Apr 20 13:02:10 raspberrypi kernel: [    1.956771] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
        Apr 20 13:02:10 raspberrypi kernel: [    1.956820] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        Apr 20 13:02:10 raspberrypi kernel: [    1.956854] usb 1-1: Product: USB2.0 Hub
        Apr 20 13:02:10 raspberrypi kernel: [    1.959352] hub 1-1:1.0: USB hub found
        Apr 20 13:02:10 raspberrypi kernel: [    1.959659] hub 1-1:1.0: 4 ports detected
        Apr 20 13:02:10 raspberrypi kernel: [    2.211568] NET: Registered protocol family 10
        Apr 20 13:02:10 raspberrypi kernel: [    2.212992] Segment Routing with IPv6
        Apr 20 13:02:10 raspberrypi kernel: [    2.293919] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
        Apr 20 13:02:10 raspberrypi kernel: [    2.431120] usb 1-1.4: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
        Apr 20 13:02:10 raspberrypi kernel: [    2.431175] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
        Apr 20 13:02:10 raspberrypi kernel: [    2.988872] random: systemd: uninitialized urandom read (16 bytes read)
        Apr 20 13:02:10 raspberrypi kernel: [    2.999027] random: systemd: uninitialized urandom read (16 bytes read)
        Apr 20 13:02:10 raspberrypi kernel: [    3.000962] random: systemd: uninitialized urandom read (16 bytes read)
        Apr 20 13:02:10 raspberrypi kernel: [    3.635553] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Apr 20 13:02:10 raspberrypi kernel: [    4.292517] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
        Apr 20 13:02:10 raspberrypi kernel: [    4.309745] mc: Linux media interface: v0.10
        Apr 20 13:02:10 raspberrypi kernel: [    4.314982] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
        Apr 20 13:02:10 raspberrypi kernel: [    4.322646] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
        Apr 20 13:02:10 raspberrypi kernel: [    4.332521] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
        Apr 20 13:02:10 raspberrypi kernel: [    4.338136] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 13:02:10 raspberrypi kernel: [    4.340781] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        Apr 20 13:02:10 raspberrypi kernel: [    4.340807] [vc_sm_connected_init]: start
        Apr 20 13:02:10 raspberrypi kernel: [    4.351493] [vc_sm_connected_init]: installed successfully
        Apr 20 13:02:10 raspberrypi kernel: [    4.353460] videodev: Linux video capture interface: v2.00
        Apr 20 13:02:10 raspberrypi kernel: [    4.376442] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 13:02:10 raspberrypi kernel: [    4.404170] bcm2835_audio bcm2835_audio: card created with 8 channels
        Apr 20 13:02:10 raspberrypi kernel: [    4.412571] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 13:02:10 raspberrypi kernel: [    4.429220] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 13:02:10 raspberrypi kernel: [    4.432063] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 13:02:10 raspberrypi kernel: [    4.445830] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        Apr 20 13:02:10 raspberrypi kernel: [    4.460476] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
        Apr 20 13:02:10 raspberrypi kernel: [    4.461158] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
        Apr 20 13:02:10 raspberrypi kernel: [    4.461994] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
        Apr 20 13:02:10 raspberrypi kernel: [    4.462528] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
        Apr 20 13:02:10 raspberrypi kernel: [    4.462556] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
        Apr 20 13:02:10 raspberrypi kernel: [    4.462580] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
        Apr 20 13:02:10 raspberrypi kernel: [    4.462603] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
        Apr 20 13:02:10 raspberrypi kernel: [    4.462625] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
        Apr 20 13:02:10 raspberrypi kernel: [    4.463176] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        Apr 20 13:02:10 raspberrypi kernel: [    4.468471] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        Apr 20 13:02:10 raspberrypi kernel: [    4.468544] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        Apr 20 13:02:10 raspberrypi kernel: [    4.475685] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        Apr 20 13:02:10 raspberrypi kernel: [    4.475728] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        Apr 20 13:02:10 raspberrypi kernel: [    4.480139] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        Apr 20 13:02:10 raspberrypi kernel: [    4.480199] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        Apr 20 13:02:10 raspberrypi kernel: [    4.559212] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        Apr 20 13:02:10 raspberrypi kernel: [    4.694789] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        Apr 20 13:02:10 raspberrypi kernel: [    4.819570] brcmfmac: F1 signature read @0x18000000=0x15264345
        Apr 20 13:02:10 raspberrypi kernel: [    4.834378] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        Apr 20 13:02:10 raspberrypi kernel: [    4.835385] usbcore: registered new interface driver brcmfmac
        Apr 20 13:02:10 raspberrypi kernel: [    4.861081] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
        Apr 20 13:02:10 raspberrypi kernel: [    4.900227] [drm] No displays found. Consider forcing hotplug if HDMI is attached
        Apr 20 13:02:10 raspberrypi kernel: [    4.900387] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
        Apr 20 13:02:10 raspberrypi kernel: [    4.906440] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
        Apr 20 13:02:10 raspberrypi kernel: [    4.924805] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
        Apr 20 13:02:10 raspberrypi kernel: [    4.984562] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
        Apr 20 13:02:10 raspberrypi kernel: [    4.987621] usbcore: registered new interface driver cdc_acm
        Apr 20 13:02:10 raspberrypi kernel: [    4.987640] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
        Apr 20 13:02:10 raspberrypi kernel: [    5.108883] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        Apr 20 13:02:10 raspberrypi kernel: [    5.119706] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
        Apr 20 13:02:10 raspberrypi kernel: [    7.150414] uart-pl011 fe201000.serial: no DMA platform data
        Apr 20 13:02:10 raspberrypi kernel: [    7.255281] 8021q: 802.1Q VLAN Support v1.8
        Apr 20 13:02:10 raspberrypi kernel: [    7.412949] random: crng init done
        Apr 20 13:02:10 raspberrypi kernel: [    7.412971] random: 7 urandom warning(s) missed due to ratelimiting
        Apr 20 13:02:10 raspberrypi kernel: [    7.613896] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
        Apr 20 13:02:10 raspberrypi kernel: [    7.633120] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
        Apr 20 13:02:10 raspberrypi kernel: [    7.854737] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
        Apr 20 13:02:10 raspberrypi kernel: [    7.855001] bcmgenet fd580000.ethernet eth0: Link is Down
        Apr 20 13:02:13 raspberrypi kernel: [   10.954205] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
        Apr 20 13:02:13 raspberrypi kernel: [   10.954258] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        Apr 20 13:02:15 raspberrypi kernel: [   13.076567] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
        Apr 20 13:02:16 raspberrypi kernel: [   14.012299] Bluetooth: Core ver 2.22
        Apr 20 13:02:16 raspberrypi kernel: [   14.012405] NET: Registered protocol family 31
        Apr 20 13:02:16 raspberrypi kernel: [   14.012422] Bluetooth: HCI device and connection manager initialized
        Apr 20 13:02:16 raspberrypi kernel: [   14.012452] Bluetooth: HCI socket layer initialized
        Apr 20 13:02:16 raspberrypi kernel: [   14.012474] Bluetooth: L2CAP socket layer initialized
        Apr 20 13:02:16 raspberrypi kernel: [   14.012509] Bluetooth: SCO socket layer initialized
        Apr 20 13:02:16 raspberrypi kernel: [   14.021474] Bluetooth: HCI UART driver ver 2.3
        Apr 20 13:02:16 raspberrypi kernel: [   14.021492] Bluetooth: HCI UART protocol H4 registered
        Apr 20 13:02:16 raspberrypi kernel: [   14.021584] Bluetooth: HCI UART protocol Three-wire (H5) registered
        Apr 20 13:02:16 raspberrypi kernel: [   14.021833] Bluetooth: HCI UART protocol Broadcom registered
        Apr 20 13:02:17 raspberrypi kernel: [   14.216608] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        Apr 20 13:02:17 raspberrypi kernel: [   14.216617] Bluetooth: BNEP filters: protocol multicast
        Apr 20 13:02:17 raspberrypi kernel: [   14.216630] Bluetooth: BNEP socket layer initialized
        pi@raspberrypi:~ $
        sys.log
        pi@raspberrypi:~ $ cat /var/log/syslog
        Apr 20 00:00:54 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="359" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
        Apr 20 00:00:54 raspberrypi systemd[1]: logrotate.service: Succeeded.
        Apr 20 00:00:54 raspberrypi systemd[1]: Started Rotate log files.
        Apr 20 00:00:55 raspberrypi systemd[1]: man-db.service: Succeeded.
        Apr 20 00:00:55 raspberrypi systemd[1]: Started Daily man-db regeneration.
        Apr 20 00:17:01 raspberrypi CRON[717]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1140064
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1083072
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1083072
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 57
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=507.593; max=547.569)Kibits/s
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.866; max=31.423)Mibits/s
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
        Apr 20 00:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
        Apr 20 00:30:54 raspberrypi systemd[1]: Starting Daily apt download activities...
        Apr 20 00:30:55 raspberrypi systemd[1]: apt-daily.service: Succeeded.
        Apr 20 00:30:55 raspberrypi systemd[1]: Started Daily apt download activities.
        Apr 20 01:17:01 raspberrypi CRON[20321]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1160064
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1113312
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1113312
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 58
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=508.219; max=547.569)Kibits/s
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.962; max=31.423)Mibits/s
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
        Apr 20 01:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
        Apr 20 02:01:24 raspberrypi systemd[1]: iobroker.service: Main process exited, code=killed, status=9/KILL
        Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Failed with result 'signal'.
        Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Service RestartSec=100ms expired, scheduling restart.
        Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2.
        Apr 20 02:01:39 raspberrypi systemd[1]: Stopped ioBroker Server.
        Apr 20 02:01:39 raspberrypi systemd[1]: Started ioBroker Server.
        Apr 20 02:01:43 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.chromecast.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.coronavirus-statistics.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.email.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.fakeroku.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.fritzbox.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.geofency.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.harmony.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.homee.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.hue-extended.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.husq-automower.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ical.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ical.1" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.iot.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.material.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.meross.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mobile.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mqtt.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.netatmo.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.node-red.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.nuki.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.pushover.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.rpi2.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.rssfeed.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.samsung.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.sayit.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.simple-api.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.sonos.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.trashschedule.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-canvas-gauges.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-colorpicker.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-fancyswitch.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-hqwidgets.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-inventwo.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-justgage.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-materialdesign.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-metro.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-timeandweather.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.yeelight-2.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.tr-064.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.zwave2.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mytime.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.tvprogram.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.lgtv.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.daswetter.0" for host "raspberrypi"
        Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ring.0" for host "raspberrypi"
        Apr 20 02:01:47 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
        Apr 20 02:01:47 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
        Apr 20 02:03:00 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
        Apr 20 02:03:00 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
        Apr 20 02:17:01 raspberrypi CRON[6125]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1200064
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1143072
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1143072
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 60
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=509.294; max=547.569)Kibits/s
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.794; max=31.423)Mibits/s
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
        Apr 20 02:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
        Apr 20 03:01:42 raspberrypi bash[18274]: host.raspberrypi Delete log file iobroker.2021-04-12.log.gz
        Apr 20 03:17:01 raspberrypi CRON[25997]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1220064
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1173312
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1173312
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 61
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=509.866; max=547.569)Kibits/s
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.888; max=31.423)Mibits/s
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
        Apr 20 03:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
        Apr 20 04:17:01 raspberrypi CRON[13137]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1260064
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1203072
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1203072
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 63
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=510.951; max=547.569)Kibits/s
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.811; max=31.423)Mibits/s
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
        Apr 20 04:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
        Apr 20 05:17:01 raspberrypi CRON[828]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1280064
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1232800
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1232800
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 64
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=511.473; max=547.569)Kibits/s
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.900; max=31.423)Mibits/s
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
        Apr 20 05:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
        Apr 20 06:15:15 raspberrypi systemd[1]: Starting Daily apt upgrade and clean activities...
        Apr 20 06:15:17 raspberrypi systemd[1]: apt-daily-upgrade.service: Succeeded.
        Apr 20 06:15:17 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
        Apr 20 06:17:01 raspberrypi CRON[20952]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1320064
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1262560
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1262560
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 66
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=512.471; max=547.569)Kibits/s
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.754; max=31.423)Mibits/s
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
        Apr 20 06:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
        Apr 20 06:25:02 raspberrypi CRON[32245]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily ))
        Apr 20 07:13:29 raspberrypi bash[18274]: Tue, 20 Apr 2021 05:13:29 GMT node-telegram-bot-api deprecated In the future, content-type of files you send will default to "application/octet-stream". See https://github.com/yagop/node-telegram-bot-api/blob/master/doc/usage.md#sending-files for more information on how sending files has been improved and on how to disable this deprecation message altogether. at opt/iobroker/node_modules/iobroker.telegram/main.js:634:20
        Apr 20 07:17:01 raspberrypi CRON[8035]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1340064
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1292800
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1292800
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 67
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=512.947; max=547.569)Kibits/s
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.839; max=31.423)Mibits/s
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
        Apr 20 07:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
        @bergjet sagte in ioBrocker Neustart Änderung:
        Apr 20 02:01:23 raspberrypi kernel: [135707.349180] node invoked oom-killer
        Dir geht der Arbeitsspeicher aus.
        Was läuft denn da alles? Vermutlich volle Disko inkl. Desktop?
        bergjetB 1 Antwort Letzte Antwort
          bergjetB Offline
          bergjetB Offline
          bergjet
          Ich habe noch 56% Ram frei.
          homee, ioBroker, iMac, iPhone, Sonos, Alaxa
          HomoranH Thomas BraunT amg_666A 3 Antworten Letzte Antwort
          • bergjetB bergjet
            im Moment!
            aber nicht um 02:01:23
            @thomas-braun sagte in ioBrocker Neustart Änderung:
            Meine Glaskugel meint, dass da dein Backitup läuft und reichlich Speicher braucht
            • bergjetB bergjet
              @bergjet
              Um 2 Uhr aber nicht. Da war das System so rappeldicht, das der oom-reaper seine Sense rausgeholt hat und in seiner Verzweiflung überflüssige Prozesse wie 'node' gekillt hat.
                @bergjet
                bergjetB Offline
                bergjetB Offline
                bergjet
                Um 02:00 startet backitup.
                Ist schon verdächtig. Tritt nun eventuell nach einem Update von BackitUp auf, das ich vor einigen Tagen gemacht habe.
                Ich stelle das einmal auf 03:00 und schaue morgen.
                • bergjetB bergjet
                  @bergjet Sicherst du nach extern in eine Cloud? Google Drive oder sowas?
                  Da dann besser keine 'geraden Uhrzeiten' nehmen, zu den Zeiten kommen nämlich immer viele Anfragen dort an und sorgt für Trouble.
                  who -r
                  liefert?
                  • bergjetB bergjet
                    amg_666A Offline
                    amg_666A Offline
                    amg_666
                    @bergjet backitup braucht ziemlich viel Ressourcen. Geh doch einfach in die backitup-Instanz und starte mal manuell ein backup und beobachte den Speicher (bzw den Neustart :-) )
                      who -r
                      liefert?
                      bergjetB Offline
                      bergjetB Offline
                      bergjet
                      liefert?
                      pi@raspberrypi:~ $ who -r
                               Runlevel 5   2021-04-20 13:02
                      pi@raspberrypi:~ $
                      Es wird auf einem NAS, lokal gespeichert.
                      • bergjetB bergjet
                        liefert?
                        pi@raspberrypi:~ $
                        @bergjet
                        Schalte den Raspberry in RunLevel3.
                        Steht im 'Kleinen Linux-Werkzeugkasten' aus meiner Signatur, wie das geht.
                        • bergjetB Offline
                          bergjetB Offline
                          bergjet
                          RunLevel3 bringt keine Änderung.
                          Wenn ich ein Backup mit dem Terminal mache:
                          iobroker stop
                          iobroker backup
                          klappt es.
                          Mache ich das Backup über Backitup, kommen die oben genannten Fehler. Es wurde seit dem 14.4. kein Backup mehr automatisch gemacht habe ich nun im Backup-Ordner gesehen.
                          • bergjetB bergjet
                            iobroker stop
                            iobroker backup
                            klappt es.
                            @bergjet
                            Was nimmst du denn alles mit an Backups im Adapter? Zu Fuß über die Konsole ist ja viel weniger dabei als in einem vollgepackten Backitup.
                              @bergjet
                              bergjetB Offline
                              bergjetB Offline
                              bergjet
                              Nur iobroker
                              • bergjetB bergjet
                                Nur iobroker
                                @bergjet Kein Javascript?
                                Zeig mal die Einstellungen im Adapter.
                                Vielleicht kann @simatec dann was sehen.
                                  bergjetB Offline
                                  bergjetB Offline
                                  bergjet
                                  backitup auf debug
                                  host.raspberrypi-Server	2021-04-20 19:54:58.875	error	Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json'
                                  host.raspberrypi-Server	2021-04-20 19:52:37.526	error	Cannot save backup file /opt/iobroker/iobroker-data/states.json.bak: ENOENT: no such file or directory, rename '/opt/iobroker/iobroker-data/states.json' -> '/opt/iobroker/iobroker-data/states.json.ba
                                  host.raspberrypi-Server	2021-04-20 19:51:39.614	error	Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json'
                                  backitup.0	2021-04-20 19:48:55.948	debug	(659) system.adapter.admin.0: logging true
                                  backitup.0	2021-04-20 19:48:55.904	debug	(659) system.adapter.admin.0: logging false
                                  host.raspberrypi-Server	2021-04-20 19:47:13.405	error	Cannot save backup file /opt/iobroker/iobroker-data/states.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/states.json'
                                  host.raspberrypi-Server	2021-04-20 19:47:09.502	error	Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, rename '/opt/iobroker/iobroker-data/objects.json' -> '/opt/iobroker/iobroker-data/objects.json
                                  host.raspberrypi-Server	2021-04-20 19:47:09.496	error	Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, rename '/opt/iobroker/iobroker-data/objects.json' -> '/opt/iobroker/iobroker-data/objects.json
                                  • Thomas BraunT Online
                                    @bergjet
                                    ls -la /opt/iobroker/iobroker-data
                                      @bergjet
                                      bergjetB Offline
                                      bergjetB Offline
                                      bergjet
                                      pi@raspberrypi:~ $ ls -la /opt/iobroker/iobroker-data
                                      insgesamt 32756
                                      drwxrwxr-x+ 13 iobroker iobroker     4096 Apr 20 20:21 .
                                      drwxrwxr-x+ 10 iobroker iobroker     4096 Apr 20 17:59 ..
                                      drwxrwxr-x+  2 iobroker iobroker     4096 Apr 20 20:14 backup-objects
                                      drwxrwxr-x+ 73 iobroker iobroker     4096 Apr  3 14:15 files
                                      drwxrwxr-x+ 96 iobroker iobroker     4096 Apr 20 00:34 history
                                      -rw-rwxr--+  1 iobroker iobroker     3645 Dez 10 19:46 iobroker.json
                                      drwxrwxr-x+  2 iobroker iobroker     4096 Dez 10 20:07 lgtv_0
                                      drwxrwxr-x+  4 iobroker iobroker     4096 Apr 13 14:20 node-red
                                      -rw-rwxr--+  1 iobroker iobroker      198 Apr 20 20:12 notifications.json
                                      -rw-rw-r--+  1 iobroker iobroker 13337514 Apr 20 20:21 objects.json
                                      -rw-rw-r--+  1 iobroker iobroker 13337514 Apr 20 20:21 objects.json.bak
                                      drwxrwxr-x+  3 iobroker iobroker     4096 Mär 29 21:52 ring_0
                                      drwxrwxr-x+  2 iobroker iobroker     4096 Dez 10 20:17 sayit
                                      drwxrwxr-x+  2 iobroker iobroker     4096 Mär  3 11:03 sonosCache
                                      -rw-rw-r--+  1 iobroker iobroker  3397945 Apr 20 20:21 states.json
                                      -rw-rw-r--+  1 iobroker iobroker  3397979 Apr 20 20:20 states.json.bak
                                      drwxrwxr-x+  3 iobroker iobroker     4096 Dez 10 21:14 tmp
                                      drwxrwxr-x+  3 iobroker iobroker     4096 Jän 21 20:30 tvprogram
                                      drwxrwxr-x+  3 iobroker iobroker     4096 Feb  5 16:10 zwave2.0
                                      pi@raspberrypi:~ $
                                      • bergjetB bergjet
                                        insgesamt 32756
                                        pi@raspberrypi:~ $
                                        @bergjet
                                        Hmmm. Widersprüchlich. Die Dateien sind ja (jetzt?) vorhanden.
                                        Fällt mir nix gescheites zu ein.
                                        Grüße in die Alpen-Republik.
                                          @bergjet
                                          bergjetB Offline
                                          bergjetB Offline
                                          bergjet
                                          schrieb am zuletzt editiert von bergjet
                                          @thomas-braun 🏔
                                          Ich kann zwar jetzt ein Backup über backitup machen, aber der Biobroker startet neu und es kommt obige Error Meldung.
                                          host.raspberrypi	2021-04-20 20:38:22.824	error	Server Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, rename '/opt/iobroker/iobroker-data/objects.json' -> '/opt/iobroker/iobroker-data/object
                                          Danach sind auch nur noch 23% Ram frei.
