  4. ioBrocker Neustart Änderung
    6.8k
iobrokertelegram adapterneustart
75 Beiträge 8 Kommentatoren 10.3k Aufrufe 8 Beobachtet
    @bergjet
    Log files sagen rund um den Zeitraum was?
    bergjetB Offline
    bergjetB Offline
    bergjet
    Das wird hier in dem Zeitraum angezeigt:
    2021-04-20 02:01:02.962 - error: daswetter.0 (16135) force terminate
    2021-04-20 02:01:02.967 - warn: daswetter.0 (16135) Terminated (UNKNOWN_ERROR): Without reason
    2021-04-20 02:01:24.084 - error: coronavirus-statistics.0 (16337) States database error: read ECONNRESET
    2021-04-20 02:01:24.088 - error: coronavirus-statistics.0 (16337) Objects database error: read ECONNRESET
    2021-04-20 02:01:24.146 - error: trashschedule.0 (888) States database error: read ECONNRESET
    2021-04-20 02:01:24.085 - error: mytime.0 (1496) States database error: read ECONNRESET
    2021-04-20 02:01:24.095 - error: yeelight-2.0 (1443) States database error: read ECONNRESET
    2021-04-20 02:01:24.161 - error: yeelight-2.0 (1443) Objects database error: read ECONNRESET
    2021-04-20 02:01:24.092 - error: vis-inventwo.0 (1087) States database error: read ECONNRESET
    2021-04-20 02:01:24.161 - error: pushover.0 (32154) States database error: read ECONNRESET
    2021-04-20 02:01:24.199 - warn: daswetter.0 (16135) get state error: DB closed
    2021-04-20 02:01:24.139 - error: telegram.0 (7580) States database error: read ECONNRESET
    2021-04-20 02:01:24.187 - warn: ical.0 (16363) get state error: Connection is closed.
    2021-04-20 02:01:24.102 - error: tvprogram.0 (1688) States database error: read ECONNRESET
    2021-04-20 02:01:24.160 - error: rpi2.0 (32345) States database error: read ECONNRESET
    2021-04-20 02:01:24.226 - error: harmony.0 (30738) States database error: read ECONNRESET
    2021-04-20 02:01:24.193 - error: nuki.0 (31935) States database error: read ECONNRESET
    2021-04-20 02:01:24.234 - error: ping.0 (32032) States database error: read ECONNRESET
    2021-04-20 02:01:24.283 - error: homee.0 (30809) Objects database error: read ECONNRESET
    2021-04-20 02:01:24.104 - error: ring.0 (1940) States database error: read ECONNRESET
    2021-04-20 02:01:24.240 - error: husq-automower.0 (30872) States database error: read ECONNRESET
    2021-04-20 02:01:24.123 - error: text2command.0 (659) States database error: read ECONNRESET
    2021-04-20 02:01:24.188 - error: ring.0 (1940) Objects database error: read ECONNRESET
    2021-04-20 02:01:24.285 - error: mqtt.0 (31701) States database error: read ECONNRESET
    2021-04-20 02:01:24.211 - error: meross.0 (31502) States database error: read ECONNRESET
    2021-04-20 02:01:24.304 - error: admin.0 (5108) States database error: read ECONNRESET
    2021-04-20 02:01:24.143 - error: rssfeed.0 (32373) States database error: read ECONNRESET
    2021-04-20 02:01:24.143 - error: node-red.0 (31942) States database error: read ECONNRESET
    2021-04-20 02:01:24.331 - error: node-red.0 (31942) Objects database error: read ECONNRESET
    2021-04-20 02:01:24.283 - error: iot.0 (30959) States database error: read ECONNRESET
    2021-04-20 02:01:24.241 - error: history.0 (30772) States database error: read ECONNRESET
    2021-04-20 02:01:24.262 - error: hue-extended.0 (30820) States database error: read ECONNRESET
    2021-04-20 02:01:24.318 - error: hue.0 (30854) States database error: read ECONNRESET
    2021-04-20 02:01:24.274 - error: samsung.0 (32546) States database error: read ECONNRESET
    2021-04-20 02:01:24.416 - info: homee.0 (30809) DISCONNECTED: "closed by user request"
    2021-04-20 02:01:24.422 - info: homee.0 (30809) cleaned everything up...
    2021-04-20 02:01:24.442 - info: harmony.0 (30738) [END] Terminating
    2021-04-20 02:01:24.434 - info: husq-automower.0 (30872) Logged off.
    2021-04-20 02:01:24.444 - info: admin.0 (5108) terminating http server on port 8081
    2021-04-20 02:01:24.440 - info: vis-inventwo.0 (1087) cleaned everything up...
    2021-04-20 02:01:24.444 - info: ring.0 (1940) Closing Adapter
    2021-04-20 02:01:24.445 - info: trashschedule.0 (888) cleaned everything up...
    2021-04-20 02:01:24.450 - info: sayit.0 (32651) stopping...
    2021-04-20 02:01:24.451 - info: mytime.0 (1496) cleaned everything up...
    2021-04-20 02:01:24.465 - info: tvprogram.0 (1688) cleaned everything up...
    2021-04-20 02:01:24.456 - info: web.0 (1450) terminated http server on port 8082
    2021-04-20 02:01:24.455 - info: yeelight-2.0 (1443) cleaned everything up...
    2021-04-20 02:01:24.442 - info: javascript.0 (31482) Stop script script.js.Badezimmer.Lultfeuchte_prüfen
    2021-04-20 02:01:24.436 - info: husq-automower.0 (30872) cleaned everything up...
    2021-04-20 02:01:24.484 - info: hue-extended.0 (30820) Adapter stopped und unloaded.
    2021-04-20 02:01:24.458 - info: netatmo.0 (31723) cleaned everything up...
    2021-04-20 02:01:24.492 - info: rssfeed.0 (32373) cleaned everything up...
    2021-04-20 02:01:24.486 - info: homee.0 (30809) DISCONNECTED: 1000
    2021-04-20 02:01:24.445 - info: simple-api.0 (32736) terminating http server on port 8087
    2021-04-20 02:01:24.489 - info: hue.0 (30854) cleaned everything up...
    2021-04-20 02:01:24.436 - info: sonos.0 (440) terminating
    2021-04-20 02:01:24.479 - info: javascript.0 (31482) Stop script script.js.Telegram.Button_Telegram
    2021-04-20 02:01:24.479 - info: javascript.0 (31482) Stop script script.js.Waschmaschine.Waschm_Aus
    2021-04-20 02:01:24.480 - info: javascript.0 (31482) Stop script script.js.Waschmaschine.Waschm_Durchschnittsverbr
    2021-04-20 02:01:24.481 - info: javascript.0 (31482) Stop script script.js.Waschmaschine.Waschm_Ein
    2021-04-20 02:01:24.482 - info: javascript.0 (31482) Stop script script.js.common.Badezimmerfenster_schliessen
    2021-04-20 02:01:24.482 - info: javascript.0 (31482) Stop script script.js.common.Büro_Bewegung
    2021-04-20 02:01:24.497 - info: javascript.0 (31482) Stop script script.js.common.Büro_ein_NFC
    2021-04-20 02:01:24.498 - info: javascript.0 (31482) Stop script script.js.common.Büro_verlassen
    2021-04-20 02:01:24.499 - info: javascript.0 (31482) Stop script script.js.common.Corona_Ampel_Tabelle
    2021-04-20 02:01:24.501 - info: javascript.0 (31482) Stop script script.js.common.Corona_Bericht
    2021-04-20 02:01:24.501 - info: javascript.0 (31482) Stop script script.js.common.Dimmer_T1
    2021-04-20 02:01:24.502 - info: javascript.0 (31482) Stop script script.js.common.Dimmer_T4
    2021-04-20 02:01:24.503 - info: javascript.0 (31482) Stop script script.js.common.Garten_Sicherheit_Abschaltung
    2021-04-20 02:01:24.508 - info: javascript.0 (31482) Stop script script.js.common.Garten_Strahler
    2021-04-20 02:01:24.509 - info: javascript.0 (31482) Stop script script.js.common.Hahn_Strahler
    2021-04-20 02:01:24.509 - info: javascript.0 (31482) Stop script script.js.common.Heizraum_Notlicht
    2021-04-20 02:01:24.510 - info: javascript.0 (31482) Stop script script.js.common.Küche_CO2_zu_hoch
    2021-04-20 02:01:24.511 - info: javascript.0 (31482) Stop script script.js.common.Rasenroboter_Startet
    2021-04-20 02:01:24.512 - info: javascript.0 (31482) Stop script script.js.common.Regenabfrage
    2021-04-20 02:01:24.512 - info: javascript.0 (31482) Stop script script.js.common.Schlafz_Fernsehlicht
    2021-04-20 02:01:24.513 - info: javascript.0 (31482) Stop script script.js.common.Schlafzimmerfenster_schliessen
    2021-04-20 02:01:24.514 - info: javascript.0 (31482) Stop script script.js.common.Türklingel_Trigger
    2021-04-20 02:01:24.514 - info: javascript.0 (31482) Stop script script.js.common.WC_Klopapier
    2021-04-20 02:01:24.515 - info: javascript.0 (31482) Stop script script.js.common.Zustand_Kellerschloss
    2021-04-20 02:01:24.515 - info: javascript.0 (31482) Stop script script.js.kamera_scripte.Auslöser
    2021-04-20 02:01:24.515 - info: javascript.0 (31482) Stop script script.js.kamera_scripte.Hole_noch_ein_Bild
    2021-04-20 02:01:24.516 - info: javascript.0 (31482) Stop script script.js.common.Müllabfuhr_Meldung
    2021-04-20 02:01:24.516 - info: javascript.0 (31482) Stop script script.js.common.TelefonMonitor
    2021-04-20 02:01:24.516 - info: javascript.0 (31482) Stop script script.js.common.TelefonFestnetzPushover
    2021-04-20 02:01:24.517 - info: javascript.0 (31482) Stop script script.js.common.AnzeigeGeräte_aktualisieren
    2021-04-20 02:01:24.517 - info: javascript.0 (31482) Stop script script.js.common.Corona_Insidenz
    2021-04-20 02:01:24.517 - info: javascript.0 (31482) Stop script script.js.common.Müllabfuhr_Kalender
    2021-04-20 02:01:24.518 - info: javascript.0 (31482) Stop script script.js.common.Wohnzimmer_Zufall_Licht
    2021-04-20 02:01:24.518 - info: javascript.0 (31482) Stop script script.js.common.Wohnzimmer_ausschalten
    2021-04-20 02:01:24.518 - info: javascript.0 (31482) Stop script script.js.common.Regen-Schnee_Ansage
    2021-04-20 02:01:24.519 - info: javascript.0 (31482) Stop script script.js.common.Zufahrt_Bewegung
    2021-04-20 02:01:24.519 - info: javascript.0 (31482) Stop script script.js.common.ical_Müll-Geburtstag
    2021-04-20 02:01:24.519 - info: javascript.0 (31482) Stop script script.js.kamera_scripte.Tastatur_Telegram
    2021-04-20 02:01:24.540 - info: iot.0 (30959) Connection changed: disconnect
    2021-04-20 02:01:24.310 - error: info.0 (30929) States database error: read ECONNRESET
    2021-04-20 02:01:24.448 - info: node-red.0 (31759) kill node-red task
    2021-04-20 02:01:24.398 - error: info.0 (30929) Objects database error: read ECONNRESET
    2021-04-20 02:01:24.555 - info: info.0 (30929) cleaned everything up...
    2021-04-20 02:01:24.563 - info: nuki.0 (31935) cleaned everything up...
    2021-04-20 02:01:24.594 - info: mqtt.0 (31701) Client [mqtt_b290ef31.e96da] connection closed: disconnected
    2021-04-20 02:01:24.541 - info: iot.0 (30959) Connection lost
    2021-04-20 02:01:24.596 - info: meross.0 (31502) Device: 1909277151525990803048e1e952e718 closed: null
    2021-04-20 02:01:24.600 - info: meross.0 (31502) Device: 2007084978541790818648e1e92385e1 closed: null
    2021-04-20 02:01:24.451 - info: zwave2.0 (1681) Shutting down driver...
    2021-04-20 02:01:24.720 - info: zwave2.0 (1681) Resetting node status...
    2021-04-20 02:01:24.864 - info: node-red.0 (31759) node-red exited with 0
    2021-04-20 02:01:24.925 - error: fakeroku.0 (30678) States database error: read ECONNRESET
    2021-04-20 02:01:25.082 - info: fakeroku.0 (30678) cleaned everything up...
    2021-04-20 02:01:25.080 - error: email.0 (30648) States database error: read ECONNRESET
    2021-04-20 02:01:25.060 - error: alexa2.0 (30618) States database error: read ECONNRESET
    2021-04-20 02:01:25.286 - error: discovery.0 (30596) States database error: read ECONNRESET
    2021-04-20 02:01:25.337 - error: backitup.0 (30581) Objects database error: write EPIPE
    2021-04-20 02:01:25.715 - error: backitup.0 (30581) States database error: read ECONNRESET
    2021-04-20 02:01:25.760 - info: backitup.0 (30581) cleaned everything up...
    2021-04-20 02:01:25.928 - info: homee.0 (30809) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.936 - info: ping.0 (32032) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.938 - info: text2command.0 (659) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.942 - info: javascript.0 (31482) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.943 - info: rpi2.0 (32345) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.946 - info: pushover.0 (32154) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.949 - info: admin.0 (5108) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.951 - info: vis-inventwo.0 (1087) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.944 - info: lgtv.0 (1706) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.953 - info: mqtt.0 (31701) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.957 - info: ring.0 (1940) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.959 - info: coronavirus-statistics.0 (16337) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.961 - info: sayit.0 (32651) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.964 - info: trashschedule.0 (888) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.965 - info: iot.0 (30959) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.968 - info: netatmo.0 (31723) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.973 - info: yeelight-2.0 (1443) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.974 - info: tvprogram.0 (1688) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.971 - info: mytime.0 (1496) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.976 - info: web.0 (1450) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.979 - info: husq-automower.0 (30872) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.942 - info: tr-064.0 (1463) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.983 - info: simple-api.0 (32736) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.981 - info: harmony.0 (30738) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.985 - info: samsung.0 (32546) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.977 - info: geofency.0 (30708) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.994 - info: telegram.0 (7580) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.996 - info: rssfeed.0 (32373) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.998 - info: sonos.0 (440) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:25.998 - info: zwave2.0 (1681) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:26.001 - info: hue-extended.0 (30820) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:26.002 - info: hue.0 (30854) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:26.026 - info: node-red.0 (31759) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:26.060 - info: info.0 (30929) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:26.067 - info: nuki.0 (31935) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:26.601 - info: fakeroku.0 (30678) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:26.837 - info: email.0 (30648) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:26.921 - info: alexa2.0 (30618) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:27.023 - info: discovery.0 (30596) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:27.279 - info: backitup.0 (30581) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:27.661 - info: nuki.0 (31935) Callback-ID successfully removed: 0
    2021-04-20 02:01:29.095 - error: zwave2.0 (1681) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.099 - error: tr-064.0 (1463) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.109 - error: lgtv.0 (1706) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.173 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.178 - error: simple-api.0 (32736) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.175 - error: yeelight-2.0 (1443) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.183 - error: coronavirus-statistics.0 (16337) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.185 - error: vis-inventwo.0 (1087) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.188 - warn: pushover.0 (32154) get state error: DB closed
    2021-04-20 02:01:29.193 - error: web.0 (1450) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.203 - warn: sayit.0 (32651) get state error: DB closed
    2021-04-20 02:01:29.215 - warn: rpi2.0 (32345) get state error: DB closed
    2021-04-20 02:01:29.208 - error: ring.0 (1940) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.229 - error: geofency.0 (30708) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.198 - error: samsung.0 (32546) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.263 - warn: harmony.0 (30738) get state error: DB closed
    2021-04-20 02:01:29.270 - warn: nuki.0 (31935) get state error: DB closed
    2021-04-20 02:01:29.222 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.285 - warn: text2command.0 (659) get state error: DB closed
    2021-04-20 02:01:29.312 - error: meross.0 (31502) States database error: connect ECONNREFUSED 127.0.0.1:9000
    2021-04-20 02:01:29.246 - error: sonos.0 (440) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.331 - error: mqtt.0 (31701) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.332 - error: node-red.0 (31759) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.318 - error: netatmo.0 (31723) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.312 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.383 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.396 - warn: hue-extended.0 (30820) get state error: DB closed
    2021-04-20 02:01:29.281 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.404 - error: ping.0 (32032) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.414 - error: meross.0 (31502) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.421 - error: homee.0 (30809) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.396 - error: trashschedule.0 (888) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.418 - error: info.0 (30929) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.369 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.466 - warn: admin.0 (5108) get state error: Connection is closed.
    2021-04-20 02:01:29.341 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.342 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.343 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.344 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.345 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.346 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.350 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.351 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.352 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.353 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.354 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.355 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.356 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.357 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.358 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.359 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.360 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.361 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.362 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.461 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.462 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.467 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.468 - warn: mqtt.0 (31701) get state error: DB closed
    2021-04-20 02:01:29.507 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.510 - warn: hue.0 (30854) get state error: DB closed
    2021-04-20 02:01:29.494 - error: javascript.0 (31482) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.545 - error: history.0 (30772) States database error: connect ECONNREFUSED 127.0.0.1:9000
    2021-04-20 02:01:29.546 - error: history.0 (30772) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:29.174 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.230 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.231 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.232 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.247 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.248 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.249 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.303 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.304 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.305 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.306 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.307 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.308 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.309 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.310 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.311 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.312 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.373 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.374 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.375 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.376 - warn: mytime.0 (1496) get state error: DB closed
    2021-04-20 02:01:29.353 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.355 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.356 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.357 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.358 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.359 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.360 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.361 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.362 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.476 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.477 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.478 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.479 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.480 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.481 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.482 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.522 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.523 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.524 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.525 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.526 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.527 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.528 - warn: husq-automower.0 (30872) get state error: DB closed
    2021-04-20 02:01:29.273 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.274 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.275 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.276 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.277 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.278 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.279 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.423 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.424 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.425 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.426 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.427 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.428 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.429 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.430 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.431 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.432 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.543 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.544 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.545 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.546 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.547 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.548 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.572 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.573 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.574 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.575 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.576 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.577 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.578 - warn: telegram.0 (7580) get state error: DB closed
    2021-04-20 02:01:29.384 - warn: samsung.0 (32546) redis get samsung.0.Power.on, error - DB closed
    2021-04-20 02:01:29.385 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.387 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.388 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.389 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.390 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.391 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.392 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.479 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.480 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.481 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.482 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.483 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.484 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.485 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.486 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.487 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.488 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.489 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.490 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.553 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.554 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.555 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.556 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.557 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.558 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.559 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.652 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.653 - warn: samsung.0 (32546) get state error: DB closed
    2021-04-20 02:01:29.403 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.405 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.446 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.447 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.448 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.449 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.450 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.451 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.452 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.504 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.505 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.506 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.507 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.508 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.509 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.510 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.511 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.512 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.548 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.549 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.550 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.551 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.552 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.581 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.582 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.583 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.584 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.608 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.609 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.610 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.611 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.648 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.649 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.669 - warn: tvprogram.0 (1688) get state error: DB closed
    2021-04-20 02:01:29.508 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.510 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.511 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.512 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.552 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.553 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.554 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.555 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.556 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.557 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.558 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.559 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.560 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.561 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.562 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.633 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.634 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.635 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.636 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.637 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.647 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.654 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.655 - warn: rssfeed.0 (32373) redis get rssfeed.0.info.lastRequest, error - DB closed
    2021-04-20 02:01:29.655 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.656 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.685 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.686 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.687 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.688 - warn: rssfeed.0 (32373) get state error: DB closed
    2021-04-20 02:01:29.502 - warn: sonos.0 (440) get state error: Connection is closed.
    2021-04-20 02:01:29.573 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.574 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.575 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.576 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.577 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.578 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.579 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.593 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.594 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.595 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.596 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.597 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.621 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.622 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.626 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.627 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.628 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.629 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.630 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.631 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.632 - warn: sonos.0 (440) get state error: DB closed
    2021-04-20 02:01:29.480 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.481 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.482 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.533 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.534 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.535 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.536 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.537 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.538 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.539 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.540 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.541 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.542 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.590 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.591 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.592 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.612 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.618 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.619 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.620 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.623 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.638 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.639 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.652 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.653 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.685 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.686 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.687 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.728 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.729 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.730 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.731 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.732 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.755 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.756 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:29.757 - warn: iot.0 (30959) get state error: DB closed
    2021-04-20 02:01:30.056 - warn: fakeroku.0 (30678) get state error: DB closed
    2021-04-20 02:01:30.297 - warn: email.0 (30648) get state error: DB closed
    2021-04-20 02:01:30.395 - warn: alexa2.0 (30618) get state error: DB closed
    2021-04-20 02:01:30.462 - info: meross.0 (31502) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:30.554 - warn: discovery.0 (30596) get state error: Connection is closed.
    2021-04-20 02:01:30.712 - error: backitup.0 (30581) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:30.782 - warn: backitup.0 (30581) get state error: Connection is closed.
    2021-04-20 02:01:30.789 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.791 - warn: backitup.0 (30581) redis get backitup.0.history.html, error - DB closed
    2021-04-20 02:01:30.792 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.793 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.794 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.795 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.796 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.797 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.798 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.799 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.800 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.801 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.802 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.803 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.804 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.805 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.806 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.807 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.808 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.809 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.810 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.811 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.812 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.813 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.814 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.815 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.816 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.818 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:30.819 - warn: backitup.0 (30581) get state error: DB closed
    2021-04-20 02:01:31.000 - warn: backitup.0 (30581) redis get backitup.0.history.json, error - Connection is closed.
    2021-04-20 02:01:31.658 - warn: backitup.0 (30581) redis get backitup.0.output.line, error - Connection is closed.
    2021-04-20 02:01:31.664 - warn: backitup.0 (30581) redis get backitup.0.output.line, error - Connection is closed.
    2021-04-20 02:01:34.237 - error: samsung.0 (32546) Cannot check object existence of "samsung.0.Power.checkOnOff": Connection is closed.
    2021-04-20 02:01:34.321 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.345 - error: mqtt.0 (31701) Cannot check object existence of "mqtt.0.info.connection": Connection is closed.
    2021-04-20 02:01:34.322 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.324 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.325 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.326 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.327 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.328 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.329 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.330 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.331 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.332 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.333 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.334 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.335 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.336 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.337 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.338 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.339 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.340 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.341 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.342 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.343 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.344 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.345 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.346 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.347 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.348 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.349 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.351 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.353 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.354 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.355 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.356 - warn: meross.0 (31502) get state error: DB closed
    2021-04-20 02:01:34.421 - error: meross.0 (31502) Cannot check object existence of "meross.0.info.connection": Connection is closed.
    2021-04-20 02:01:34.448 - error: sonos.0 (440) Cannot check object existence of "sonos.0.root.192_168_1_26.alive": Connection is closed.
    2021-04-20 02:01:34.557 - error: history.0 (30772) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:34.558 - error: history.0 (30772) States database error: connect ECONNREFUSED 127.0.0.1:9000
    2021-04-20 02:01:35.624 - info: history.0 (30772) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-04-20 02:01:35.719 - error: backitup.0 (30581) Cannot check object existence of "backitup.0.output.line": Connection is closed.
    2021-04-20 02:01:39.568 - error: history.0 (30772) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2021-04-20 02:01:42.003 - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-20 02:01:42.009 - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-20 02:01:42.010 - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
    2021-04-20 02:01:42.010 - info: host.raspberrypi ip addresses: 192.168.1.79 fe80::207a:77fc:33f9:ef62 192.168.1.45 fe80::f8a3:73aa:eebf:4cc8
    2021-04-20 02:01:43.393 - info: host.raspberrypi connected to Objects and States
    2021-04-20 02:01:43.622 - info: host.raspberrypi added notifications configuration of host
    2021-04-20 02:01:44.404 - info: host.raspberrypi 61 instances found
    2021-04-20 02:01:44.508 - info: host.raspberrypi starting 56 instances
    2021-04-20 02:01:44.721 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 18292
    homee, ioBroker, iMac, iPhone, Sonos, Alaxa
      @bergjet
      bergjetB Offline
      bergjetB Offline
      bergjet
      schrieb am zuletzt editiert von bergjet
      Und das
      2021-04-20 02:01:46.731 - error: admin.0 (18292) admin.0 already running
      2021-04-20 02:01:46.734 - warn: admin.0 (18292) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:01:47.470 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:01:47.471 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2021-04-20 02:01:48.716 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 18303
      2021-04-20 02:01:50.195 - error: alexa2.0 (18303) alexa2.0 already running
      2021-04-20 02:01:50.198 - warn: alexa2.0 (18303) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:01:50.855 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:01:50.856 - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
      2021-04-20 02:01:52.575 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 18314
      2021-04-20 02:01:57.369 - info: host.raspberrypi instance scheduled system.adapter.coronavirus-statistics.0 */30 * * * *
      2021-04-20 02:01:57.414 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 18325
      2021-04-20 02:01:57.786 - error: backitup.0 (18314) backitup.0 already running
      2021-04-20 02:01:57.789 - warn: backitup.0 (18314) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:01:58.513 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:01:58.514 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
      2021-04-20 02:02:00.356 - info: coronavirus-statistics.0 (18325) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:00.703 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 18340
      2021-04-20 02:02:01.846 - error: discovery.0 (18340) discovery.0 already running
      2021-04-20 02:02:01.849 - warn: discovery.0 (18340) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:02.546 - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:02.546 - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
      2021-04-20 02:02:04.581 - info: host.raspberrypi instance system.adapter.email.0 started with pid 18351
      2021-04-20 02:02:05.895 - error: email.0 (18351) email.0 already running
      2021-04-20 02:02:05.898 - warn: email.0 (18351) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:06.543 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:06.544 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
      2021-04-20 02:02:08.406 - info: coronavirus-statistics.0 (18325) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2021-04-20 02:02:08.547 - info: host.raspberrypi instance system.adapter.fakeroku.0 started with pid 18362
      2021-04-20 02:02:09.074 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-04-20 02:02:09.720 - error: fakeroku.0 (18362) fakeroku.0 already running
      2021-04-20 02:02:09.723 - warn: fakeroku.0 (18362) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:10.373 - error: host.raspberrypi instance system.adapter.fakeroku.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:10.373 - info: host.raspberrypi Restart adapter system.adapter.fakeroku.0 because enabled
      2021-04-20 02:02:12.716 - info: host.raspberrypi instance system.adapter.geofency.0 started with pid 18373
      2021-04-20 02:02:13.924 - error: geofency.0 (18373) geofency.0 already running
      2021-04-20 02:02:13.926 - warn: geofency.0 (18373) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:14.586 - error: host.raspberrypi instance system.adapter.geofency.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:14.587 - info: host.raspberrypi Restart adapter system.adapter.geofency.0 because enabled
      2021-04-20 02:02:16.575 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 18385
      2021-04-20 02:02:17.494 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 18392
      2021-04-20 02:02:18.214 - error: harmony.0 (18385) harmony.0 already running
      2021-04-20 02:02:18.217 - warn: harmony.0 (18385) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:18.907 - error: host.raspberrypi instance system.adapter.harmony.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:18.908 - info: host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
      2021-04-20 02:02:19.748 - info: admin.0 (18392) starting. Version 5.0.4 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:19.800 - info: admin.0 (18392) requesting all states
      2021-04-20 02:02:19.801 - info: admin.0 (18392) requesting all objects
      2021-04-20 02:02:21.351 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 18411
      2021-04-20 02:02:21.384 - info: host.raspberrypi instance system.adapter.history.0 started with pid 18417
      2021-04-20 02:02:22.050 - info: admin.0 (18392) received all objects
      2021-04-20 02:02:22.784 - info: admin.0 (18392) http server listening on port 8081
      2021-04-20 02:02:22.785 - info: admin.0 (18392) Use link "http://localhost:8081" to configure.
      2021-04-20 02:02:22.869 - error: history.0 (18417) history.0 already running
      2021-04-20 02:02:22.872 - warn: history.0 (18417) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:23.542 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:23.542 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
      2021-04-20 02:02:23.552 - info: alexa2.0 (18411) starting. Version 3.8.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:24.966 - info: host.raspberrypi instance system.adapter.homee.0 started with pid 18437
      2021-04-20 02:02:26.268 - error: homee.0 (18437) homee.0 already running
      2021-04-20 02:02:26.270 - warn: homee.0 (18437) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:26.972 - error: host.raspberrypi instance system.adapter.homee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:26.973 - info: host.raspberrypi Restart adapter system.adapter.homee.0 because enabled
      2021-04-20 02:02:28.011 - info: alexa2.0 (18411) Alexa-Push-Connection established. Disable Polling
      2021-04-20 02:02:28.309 - info: alexa2.0 (18411) Unknown Device, but enabling commands, Try it and report back if commands work.
      2021-04-20 02:02:28.310 - info: alexa2.0 (18411) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
      2021-04-20 02:02:28.310 - info: alexa2.0 (18411) Device-type:A2Y04QPFCANLPQ (TIDAL,PERSISTENT_CONNECTION,TUNE_IN,VOLUME_SETTING,AMAZON_MUSIC,SIRIUSXM,KINDLE_BOOKS,APPLE_MUSIC,SLEEP,DEREGISTER_DEVICE,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,GOLDFISH,DREAM_TRAINING,AUDIO_PLAYER,TIMERS_AND_ALARMS,DEEZER,MUSIC_SKILL,MICROPHONE,AUDIBLE,I_HEART_RADIO,CHANGE_NAME)
      2021-04-20 02:02:28.320 - info: alexa2.0 (18411) Unknown Device, but enabling commands, Try it and report back if commands work.
      2021-04-20 02:02:28.321 - info: alexa2.0 (18411) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
      2021-04-20 02:02:28.321 - info: alexa2.0 (18411) Device-type:A1W2YILXTG9HA7 (TIDAL,PERSISTENT_CONNECTION,TUNE_IN,VOLUME_SETTING,AMAZON_MUSIC,SIRIUSXM,KINDLE_BOOKS,APPLE_MUSIC,REMINDERS,SLEEP,DEREGISTER_DEVICE,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,GOLDFISH,DREAM_TRAINING,AUDIO_PLAYER,TIMERS_AND_ALARMS,DEEZER,MUSIC_SKILL,MICROPHONE,AUDIBLE,I_HEART_RADIO,CHANGE_NAME)
      2021-04-20 02:02:28.552 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 18448
      2021-04-20 02:02:28.648 - info: host.raspberrypi instance system.adapter.hue-extended.0 started with pid 18455
      2021-04-20 02:02:30.772 - error: hue-extended.0 (18455) hue-extended.0 already running
      2021-04-20 02:02:30.775 - warn: hue-extended.0 (18455) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:31.444 - error: host.raspberrypi instance system.adapter.hue-extended.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:31.445 - info: host.raspberrypi Restart adapter system.adapter.hue-extended.0 because enabled
      2021-04-20 02:02:32.693 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 18470
      2021-04-20 02:02:32.725 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 18476
      2021-04-20 02:02:34.088 - info: backitup.0 (18448) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:34.280 - info: backitup.0 (18448) [iobroker] backup was activated at 02:00 every 1 day(s)
      2021-04-20 02:02:34.905 - error: hue.0 (18476) hue.0 already running
      2021-04-20 02:02:34.910 - warn: hue.0 (18476) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:35.135 - info: discovery.0 (18470) starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:35.556 - error: host.raspberrypi instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:35.557 - info: host.raspberrypi Restart adapter system.adapter.hue.0 because enabled
      2021-04-20 02:02:36.572 - info: host.raspberrypi instance system.adapter.husq-automower.0 started with pid 18500
      2021-04-20 02:02:36.628 - info: host.raspberrypi instance system.adapter.email.0 started with pid 18506
      2021-04-20 02:02:38.296 - error: husq-automower.0 (18500) husq-automower.0 already running
      2021-04-20 02:02:38.299 - warn: husq-automower.0 (18500) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:38.458 - info: email.0 (18506) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.email, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:39.004 - error: host.raspberrypi instance system.adapter.husq-automower.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:39.005 - info: host.raspberrypi Restart adapter system.adapter.husq-automower.0 because enabled
      2021-04-20 02:02:40.420 - info: host.raspberrypi instance system.adapter.fakeroku.0 started with pid 18526
      2021-04-20 02:02:40.774 - info: host.raspberrypi instance scheduled system.adapter.ical.0 0 2,4 * * *
      2021-04-20 02:02:40.799 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 18533
      2021-04-20 02:02:42.046 - info: fakeroku.0 (18526) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fakeroku, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:43.033 - info: ical.0 (18533) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:44.636 - info: host.raspberrypi instance scheduled system.adapter.ical.1 5 2,4 * * *
      2021-04-20 02:02:44.654 - info: host.raspberrypi instance system.adapter.ical.1 started with pid 18556
      2021-04-20 02:02:44.681 - info: host.raspberrypi instance system.adapter.geofency.0 started with pid 18562
      2021-04-20 02:02:46.610 - info: geofency.0 (18562) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.geofency, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:46.658 - info: geofency.0 (18562) Adapter got 'Ready' Signal - initiating Main function...
      2021-04-20 02:02:46.699 - info: geofency.0 (18562) http server listening on port 7999
      2021-04-20 02:02:47.831 - info: ical.1 (18556) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:48.689 - info: host.raspberrypi instance system.adapter.info.0 started with pid 18586
      2021-04-20 02:02:48.931 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 18593
      2021-04-20 02:02:49.450 - info: ical.1 (18556) processing URL: Geburtstage http://p25-caldav.icloud.com/published/2/AAAAAAAAAAAAAAAAAAAAAJJnnvDTY6VFWIFDivW_83qBfJz6Q9qd1_Fi2SjnBDo3cLQ4C70Zpg2NxyfyyFGvl1659y2agUpqE7IXc_EB7R0
      2021-04-20 02:02:50.804 - info: ical.0 (18533) processing URL: Müll http://p25-caldav.icloud.com/published/2/Mjc2ODA0MDAwMjc2ODA0MOWAQ_Hp47ycJEgYb0oET12LPeUAOwbTuiHnNWrmHF21ZilCgnWV2zu_3gFQLNJIuNKRi8FkQZJBGf2_bTAS3rjaxgj8VXAGfuiCKKkA0_sxFDWnISlJyUhyvepk5YbXXg
      2021-04-20 02:02:52.578 - info: harmony.0 (18593) starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.harmony, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:52.655 - info: harmony.0 (18593) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
      2021-04-20 02:02:53.043 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 18621
      2021-04-20 02:02:53.162 - error: info.0 (18586) info.0 already running
      2021-04-20 02:02:53.166 - warn: info.0 (18586) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:53.569 - info: host.raspberrypi instance system.adapter.history.0 started with pid 18628
      2021-04-20 02:02:53.855 - error: host.raspberrypi instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:53.856 - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
      2021-04-20 02:02:53.995 - info: harmony.0 (18593) [DISCOVER] Discovered Harmony Hub (192.168.1.84) and will try to connect
      2021-04-20 02:02:54.064 - info: harmony.0 (18593) [CONNECT] Connecting to Harmony Hub (192.168.1.84)
      2021-04-20 02:02:55.042 - info: ical.1 (18556) Terminated (NO_ERROR): Without reason
      2021-04-20 02:02:55.240 - info: harmony.0 (18593) [CONNECT] Connected to Harmony Hub (192.168.1.84)
      2021-04-20 02:02:55.332 - error: iot.0 (18621) iot.0 already running
      2021-04-20 02:02:55.335 - warn: iot.0 (18621) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:02:55.546 - info: history.0 (18628) starting. Version 1.9.12 in /opt/iobroker/node_modules/iobroker.history, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:55.685 - info: host.raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
      2021-04-20 02:02:55.782 - info: history.0 (18628) enabled logging of hue.0.Wohnzimmrr_Hue_white_lamp_1.on (Count=1), Alias=false
      2021-04-20 02:02:55.997 - error: host.raspberrypi instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:02:55.998 - info: host.raspberrypi Restart adapter system.adapter.iot.0 because enabled
      2021-04-20 02:02:56.329 - info: harmony.0 (18593) [PROCESS] Synced hub config for Harmony Hub (192.168.1.84)
      2021-04-20 02:02:56.686 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 18647
      2021-04-20 02:02:56.871 - info: ical.0 (18533) Terminated (NO_ERROR): Without reason
      2021-04-20 02:02:56.998 - info: host.raspberrypi instance system.adapter.homee.0 started with pid 18654
      2021-04-20 02:02:57.581 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2021-04-20 02:02:59.160 - info: homee.0 (18654) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.homee, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:02:59.215 - info: homee.0 (18654) Init homee 192.168.1.74 for user Martin
      2021-04-20 02:02:59.375 - info: homee.0 (18654) CONNECTED
      2021-04-20 02:02:59.762 - error: javascript.0 (18647) javascript.0 already running
      2021-04-20 02:02:59.765 - warn: javascript.0 (18647) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:00.408 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:00.409 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
      2021-04-20 02:03:00.686 - info: host.raspberrypi instance system.adapter.meross.0 started with pid 18673
      2021-04-20 02:03:01.061 - info: homee.0 (18654) initialize 48 nodes
      2021-04-20 02:03:01.487 - info: host.raspberrypi instance system.adapter.hue-extended.0 started with pid 18680
      2021-04-20 02:03:02.960 - error: meross.0 (18673) meross.0 already running
      2021-04-20 02:03:02.964 - warn: meross.0 (18673) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:03.336 - info: homee.0 (18654) initialize 50 homeegrams
      2021-04-20 02:03:04.080 - error: host.raspberrypi instance system.adapter.meross.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:04.080 - info: host.raspberrypi Restart adapter system.adapter.meross.0 because enabled
      2021-04-20 02:03:04.803 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 18695
      2021-04-20 02:03:05.159 - info: hue-extended.0 (18680) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue-extended, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:05.205 - info: hue-extended.0 (18680) Establishing connection to bridge..
      2021-04-20 02:03:05.513 - info: alexa2.0 (18411) Subscribing to states...
      2021-04-20 02:03:05.699 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 18706
      2021-04-20 02:03:05.846 - info: hue-extended.0 (18680) Using polling for state updates.
      2021-04-20 02:03:06.166 - error: mqtt.0 (18695) mqtt.0 already running
      2021-04-20 02:03:06.169 - warn: mqtt.0 (18695) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:06.922 - error: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:06.923 - info: host.raspberrypi Restart adapter system.adapter.mqtt.0 because enabled
      2021-04-20 02:03:07.944 - info: hue.0 (18706) starting. Version 3.5.2 in /opt/iobroker/node_modules/iobroker.hue, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:08.580 - info: host.raspberrypi instance system.adapter.netatmo.0 started with pid 18725
      2021-04-20 02:03:08.921 - info: hue.0 (18706) skip switch: Daylight.configured
      2021-04-20 02:03:08.922 - info: hue.0 (18706) skip switch: Daylight.sunriseoffset
      2021-04-20 02:03:08.923 - info: hue.0 (18706) skip switch: Daylight.sunsetoffset
      2021-04-20 02:03:08.926 - info: hue.0 (18706) skip switch: Büro sensor 2.alert
      2021-04-20 02:03:08.927 - info: hue.0 (18706) skip switch: Büro sensor 2.sensitivity
      2021-04-20 02:03:08.928 - info: hue.0 (18706) skip switch: Büro sensor 2.sensitivitymax
      2021-04-20 02:03:08.928 - info: hue.0 (18706) skip switch: Büro sensor 2.ledindication
      2021-04-20 02:03:08.929 - info: hue.0 (18706) skip switch: Büro sensor 2.usertest
      2021-04-20 02:03:08.931 - info: hue.0 (18706) skip switch: Hue ambient light sensor 2.alert
      2021-04-20 02:03:08.932 - info: hue.0 (18706) skip switch: Hue ambient light sensor 2.tholddark
      2021-04-20 02:03:08.933 - info: hue.0 (18706) skip switch: Hue ambient light sensor 2.tholdoffset
      2021-04-20 02:03:08.933 - info: hue.0 (18706) skip switch: Hue ambient light sensor 2.ledindication
      2021-04-20 02:03:08.934 - info: hue.0 (18706) skip switch: Hue ambient light sensor 2.usertest
      2021-04-20 02:03:08.937 - info: hue.0 (18706) skip switch: Hue temperature sensor 2.alert
      2021-04-20 02:03:08.937 - info: hue.0 (18706) skip switch: Hue temperature sensor 2.ledindication
      2021-04-20 02:03:08.938 - info: hue.0 (18706) skip switch: Hue temperature sensor 2.usertest
      2021-04-20 02:03:08.944 - info: hue.0 (18706) skip switch: EG Gang Schl sensor 1.alert
      2021-04-20 02:03:08.945 - info: hue.0 (18706) skip switch: EG Gang Schl sensor 1.sensitivity
      2021-04-20 02:03:08.945 - info: hue.0 (18706) skip switch: EG Gang Schl sensor 1.sensitivitymax
      2021-04-20 02:03:08.946 - info: hue.0 (18706) skip switch: EG Gang Schl sensor 1.ledindication
      2021-04-20 02:03:08.946 - info: hue.0 (18706) skip switch: EG Gang Schl sensor 1.usertest
      2021-04-20 02:03:09.358 - info: hue.0 (18706) skip switch: Hue ambient light sensor 5.alert
      2021-04-20 02:03:09.359 - info: hue.0 (18706) skip switch: Hue ambient light sensor 5.tholddark
      2021-04-20 02:03:09.360 - info: hue.0 (18706) skip switch: Hue ambient light sensor 5.tholdoffset
      2021-04-20 02:03:09.360 - info: hue.0 (18706) skip switch: Hue ambient light sensor 5.ledindication
      2021-04-20 02:03:09.361 - info: hue.0 (18706) skip switch: Hue ambient light sensor 5.usertest
      2021-04-20 02:03:09.383 - info: hue.0 (18706) skip switch: Hue temperature sensor 5.alert
      2021-04-20 02:03:09.385 - info: hue.0 (18706) skip switch: Hue temperature sensor 5.ledindication
      2021-04-20 02:03:09.385 - info: hue.0 (18706) skip switch: Hue temperature sensor 5.usertest
      2021-04-20 02:03:09.412 - info: host.raspberrypi instance system.adapter.husq-automower.0 started with pid 18732
      2021-04-20 02:03:09.416 - info: hue.0 (18706) skip switch: EG Gang Kue sensor 1.alert
      2021-04-20 02:03:09.417 - info: hue.0 (18706) skip switch: EG Gang Kue sensor 1.sensitivity
      2021-04-20 02:03:09.418 - info: hue.0 (18706) skip switch: EG Gang Kue sensor 1.sensitivitymax
      2021-04-20 02:03:09.418 - info: hue.0 (18706) skip switch: EG Gang Kue sensor 1.ledindication
      2021-04-20 02:03:09.419 - info: hue.0 (18706) skip switch: EG Gang Kue sensor 1.usertest
      2021-04-20 02:03:09.680 - info: hue.0 (18706) skip switch: Hue ambient light sensor 6.alert
      2021-04-20 02:03:09.681 - info: hue.0 (18706) skip switch: Hue ambient light sensor 6.tholddark
      2021-04-20 02:03:09.681 - info: hue.0 (18706) skip switch: Hue ambient light sensor 6.tholdoffset
      2021-04-20 02:03:09.682 - info: hue.0 (18706) skip switch: Hue ambient light sensor 6.ledindication
      2021-04-20 02:03:09.682 - info: hue.0 (18706) skip switch: Hue ambient light sensor 6.usertest
      2021-04-20 02:03:09.685 - info: hue.0 (18706) skip switch: Hue temperature sensor 6.alert
      2021-04-20 02:03:09.686 - info: hue.0 (18706) skip switch: Hue temperature sensor 6.ledindication
      2021-04-20 02:03:09.686 - info: hue.0 (18706) skip switch: Hue temperature sensor 6.usertest
      2021-04-20 02:03:09.689 - info: hue.0 (18706) skip switch: DG Gang sensor 1.alert
      2021-04-20 02:03:09.689 - info: hue.0 (18706) skip switch: DG Gang sensor 1.sensitivity
      2021-04-20 02:03:09.690 - info: hue.0 (18706) skip switch: DG Gang sensor 1.sensitivitymax
      2021-04-20 02:03:09.691 - info: hue.0 (18706) skip switch: DG Gang sensor 1.ledindication
      2021-04-20 02:03:09.691 - info: hue.0 (18706) skip switch: DG Gang sensor 1.usertest
      2021-04-20 02:03:09.704 - info: hue.0 (18706) skip switch: Hue ambient light sensor 7.alert
      2021-04-20 02:03:09.705 - info: hue.0 (18706) skip switch: Hue ambient light sensor 7.tholddark
      2021-04-20 02:03:09.706 - info: hue.0 (18706) skip switch: Hue ambient light sensor 7.tholdoffset
      2021-04-20 02:03:09.706 - info: hue.0 (18706) skip switch: Hue ambient light sensor 7.ledindication
      2021-04-20 02:03:09.707 - info: hue.0 (18706) skip switch: Hue ambient light sensor 7.usertest
      2021-04-20 02:03:09.713 - info: hue.0 (18706) skip switch: Hue temperature sensor 7.alert
      2021-04-20 02:03:09.714 - info: hue.0 (18706) skip switch: Hue temperature sensor 7.ledindication
      2021-04-20 02:03:09.715 - info: hue.0 (18706) skip switch: Hue temperature sensor 7.usertest
      2021-04-20 02:03:09.718 - info: hue.0 (18706) skip switch: Küche sensor 1.alert
      2021-04-20 02:03:09.719 - info: hue.0 (18706) skip switch: Küche sensor 1.sensitivity
      2021-04-20 02:03:09.719 - info: hue.0 (18706) skip switch: Küche sensor 1.sensitivitymax
      2021-04-20 02:03:09.720 - info: hue.0 (18706) skip switch: Küche sensor 1.ledindication
      2021-04-20 02:03:09.721 - info: hue.0 (18706) skip switch: Küche sensor 1.usertest
      2021-04-20 02:03:09.724 - info: hue.0 (18706) skip switch: Hue ambient light sensor 8.alert
      2021-04-20 02:03:09.725 - info: hue.0 (18706) skip switch: Hue ambient light sensor 8.tholddark
      2021-04-20 02:03:09.725 - info: hue.0 (18706) skip switch: Hue ambient light sensor 8.tholdoffset
      2021-04-20 02:03:09.726 - info: hue.0 (18706) skip switch: Hue ambient light sensor 8.ledindication
      2021-04-20 02:03:09.726 - info: hue.0 (18706) skip switch: Hue ambient light sensor 8.usertest
      2021-04-20 02:03:09.729 - info: hue.0 (18706) skip switch: Hue temperature sensor 8.alert
      2021-04-20 02:03:09.730 - info: hue.0 (18706) skip switch: Hue temperature sensor 8.ledindication
      2021-04-20 02:03:09.731 - info: hue.0 (18706) skip switch: Hue temperature sensor 8.usertest
      2021-04-20 02:03:09.733 - info: hue.0 (18706) created/updated 20 sensor channels
      2021-04-20 02:03:09.772 - info: hue.0 (18706) created/updated 20 light channels
      2021-04-20 02:03:09.811 - info: hue.0 (18706) created/updated 25 groups channels
      2021-04-20 02:03:09.837 - info: hue.0 (18706) created/updated 125 scenes
      2021-04-20 02:03:09.837 - info: hue.0 (18706) creating/updating bridge device
      2021-04-20 02:03:10.447 - error: netatmo.0 (18725) netatmo.0 already running
      2021-04-20 02:03:10.451 - warn: netatmo.0 (18725) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:11.116 - error: host.raspberrypi instance system.adapter.netatmo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:11.117 - info: host.raspberrypi Restart adapter system.adapter.netatmo.0 because enabled
      2021-04-20 02:03:11.728 - info: husq-automower.0 (18732) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.husq-automower, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:12.651 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 18751
      2021-04-20 02:03:13.777 - info: husq-automower.0 (18732) Logged off.
      2021-04-20 02:03:13.859 - info: husq-automower.0 (18732) updateStatus mower object is NULL
      2021-04-20 02:03:14.147 - info: husq-automower.0 (18732) Logged on. Checking for mowers.
      2021-04-20 02:03:14.190 - error: node-red.0 (18751) node-red.0 already running
      2021-04-20 02:03:14.193 - warn: node-red.0 (18751) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:14.392 - info: husq-automower.0 (18732) connected, mowersListUpdated, found 2 mower(s)
      2021-04-20 02:03:14.606 - warn: husq-automower.0 (18732) updateStatus, result.operatingMode === HOME
      2021-04-20 02:03:14.779 - info: husq-automower.0 (18732) createSubscriberAsync, idRainSensor; stop due rain not enabled.
      2021-04-20 02:03:14.848 - error: host.raspberrypi instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:14.849 - info: host.raspberrypi Restart adapter system.adapter.node-red.0 because enabled
      2021-04-20 02:03:16.564 - info: host.raspberrypi instance system.adapter.nuki.0 started with pid 18762
      2021-04-20 02:03:18.385 - error: nuki.0 (18762) nuki.0 already running
      2021-04-20 02:03:18.388 - warn: nuki.0 (18762) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:19.036 - error: host.raspberrypi instance system.adapter.nuki.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:19.036 - info: host.raspberrypi Restart adapter system.adapter.nuki.0 because enabled
      2021-04-20 02:03:20.992 - info: host.raspberrypi instance system.adapter.ping.0 started with pid 18773
      2021-04-20 02:03:22.115 - error: ping.0 (18773) ping.0 already running
      2021-04-20 02:03:22.118 - warn: ping.0 (18773) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:22.763 - error: host.raspberrypi instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:22.764 - info: host.raspberrypi Restart adapter system.adapter.ping.0 because enabled
      2021-04-20 02:03:23.884 - info: host.raspberrypi instance system.adapter.info.0 started with pid 18784
      2021-04-20 02:03:24.692 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 18799
      2021-04-20 02:03:26.037 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 18814
      2021-04-20 02:03:26.073 - error: pushover.0 (18799) pushover.0 already running
      2021-04-20 02:03:26.078 - warn: pushover.0 (18799) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:26.901 - error: host.raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:26.902 - info: host.raspberrypi Restart adapter system.adapter.pushover.0 because enabled
      2021-04-20 02:03:27.175 - info: info.0 (18784) starting. Version 1.7.15 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:28.505 - info: info.0 (18784) Reading CPU current speed every 3 seconds.
      2021-04-20 02:03:28.513 - info: info.0 (18784) Reading CPU data every 3 seconds.
      2021-04-20 02:03:28.762 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 19039
      2021-04-20 02:03:29.034 - info: iot.0 (18814) starting. Version 1.8.13 in /opt/iobroker/node_modules/iobroker.iot, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:29.140 - info: iot.0 (18814) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2021-04-20 02:03:28.671 - info: info.0 (18784) Reading disk data every 8 seconds.
      2021-04-20 02:03:29.419 - info: info.0 (18784) Reading user data every 8 seconds.
      2021-04-20 02:03:29.679 - info: info.0 (18784) Reading memory data every 3 seconds.
      2021-04-20 02:03:29.827 - info: info.0 (18784) Reading battery data every 8 seconds.
      2021-04-20 02:03:29.832 - info: info.0 (18784) Reading CPU temp data every 3 seconds.
      2021-04-20 02:03:29.929 - info: info.0 (18784) Reading process data every 8 seconds.
      2021-04-20 02:03:30.833 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 19335
      2021-04-20 02:03:31.315 - error: rpi2.0 (19039) rpi2.0 already running
      2021-04-20 02:03:31.318 - warn: rpi2.0 (19039) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:31.678 - info: iot.0 (18814) Connection changed: connect
      2021-04-20 02:03:32.067 - error: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:32.068 - info: host.raspberrypi Restart adapter system.adapter.rpi2.0 because enabled
      2021-04-20 02:03:32.660 - info: host.raspberrypi instance system.adapter.rssfeed.0 started with pid 19342
      2021-04-20 02:03:34.108 - info: host.raspberrypi instance system.adapter.meross.0 started with pid 19359
      2021-04-20 02:03:34.233 - info: javascript.0 (19335) starting. Version 5.1.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:34.290 - info: javascript.0 (19335) npm install axios --production (System call)
      2021-04-20 02:03:34.465 - error: rssfeed.0 (19342) rssfeed.0 already running
      2021-04-20 02:03:34.468 - warn: rssfeed.0 (19342) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:34.996 - error: rssfeed.0 (19342) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-20 02:03:34.997 - error: rssfeed.0 (19342) unhandled promise rejection: Cannot read property 'debug' of undefined
      2021-04-20 02:03:35.000 - error: rssfeed.0 (19342) TypeError: Cannot read property 'debug' of undefined
      at RssFeed.onUnload (/opt/iobroker/node_modules/iobroker.rssfeed/main.js:65:22)
      at RssFeed.emit (events.js:314:20)
      at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
      at Object.onceWrapper (events.js:421:26)
      at process.emit (events.js:314:20)
      at process.exit (internal/process/per_thread.js:168:15)
      at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
      at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2021-04-20 02:03:35.001 - error: rssfeed.0 (19342) Cannot read property 'debug' of undefined
      2021-04-20 02:03:35.189 - error: host.raspberrypi instance system.adapter.rssfeed.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:35.189 - info: host.raspberrypi Restart adapter system.adapter.rssfeed.0 because enabled
      2021-04-20 02:03:36.568 - info: host.raspberrypi instance system.adapter.samsung.0 started with pid 19399
      2021-04-20 02:03:36.878 - info: meross.0 (19359) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.meross, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:36.962 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 19413
      2021-04-20 02:03:37.526 - info: meross.0 (19359) Device 2007084978541790818648e1e92385e1 initialized
      2021-04-20 02:03:37.885 - info: meross.0 (19359) Device 1909277151525990803048e1e952e718 initialized
      2021-04-20 02:03:38.113 - info: meross.0 (19359) Device: 2007084978541790818648e1e92385e1 connected
      2021-04-20 02:03:38.128 - info: meross.0 (19359) Device: 1909277151525990803048e1e952e718 connected
      2021-04-20 02:03:40.034 - error: samsung.0 (19399) samsung.0 already running
      2021-04-20 02:03:40.037 - warn: samsung.0 (19399) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:40.239 - info: meross.0 (19359) Devices initialized
      2021-04-20 02:03:40.780 - info: host.raspberrypi instance system.adapter.sayit.0 started with pid 19581
      2021-04-20 02:03:40.928 - error: host.raspberrypi instance system.adapter.samsung.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:40.929 - info: host.raspberrypi Restart adapter system.adapter.samsung.0 because enabled
      2021-04-20 02:03:40.943 - info: mqtt.0 (19413) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.mqtt, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:41.489 - info: host.raspberrypi instance system.adapter.netatmo.0 started with pid 19592
      2021-04-20 02:03:43.288 - error: sayit.0 (19581) sayit.0 already running
      2021-04-20 02:03:43.293 - warn: sayit.0 (19581) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:43.618 - info: mqtt.0 (19413) Starting MQTT server on 0.0.0.0:1883
      2021-04-20 02:03:43.967 - error: host.raspberrypi instance system.adapter.sayit.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:43.968 - info: host.raspberrypi Restart adapter system.adapter.sayit.0 because enabled
      2021-04-20 02:03:45.246 - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 19614
      2021-04-20 02:03:45.276 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 19620
      2021-04-20 02:03:45.585 - info: netatmo.0 (19592) starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.netatmo, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:47.342 - error: simple-api.0 (19614) simple-api.0 already running
      2021-04-20 02:03:47.346 - warn: simple-api.0 (19614) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:47.668 - info: node-red.0 (19620) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:48.417 - error: host.raspberrypi instance system.adapter.simple-api.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:48.417 - info: host.raspberrypi Restart adapter system.adapter.simple-api.0 because enabled
      2021-04-20 02:03:48.724 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 19798
      2021-04-20 02:03:49.139 - info: host.raspberrypi instance system.adapter.nuki.0 started with pid 19805
      2021-04-20 02:03:49.739 - info: node-red.0 (19620) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      2021-04-20 02:03:51.663 - error: sonos.0 (19798) sonos.0 already running
      2021-04-20 02:03:51.667 - warn: sonos.0 (19798) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:03:52.125 - info: nuki.0 (19805) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.nuki, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:52.333 - error: host.raspberrypi instance system.adapter.sonos.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:03:52.333 - info: host.raspberrypi Restart adapter system.adapter.sonos.0 because enabled
      2021-04-20 02:03:52.815 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 19837
      2021-04-20 02:03:52.843 - info: host.raspberrypi instance system.adapter.ping.0 started with pid 19843
      2021-04-20 02:03:55.297 - info: nuki.0 (19805) Bridge Info requested: http://192.168.1.11:8080/info?ts=2021-04-20T00:03:55Z&rnr=1461&hash=4874f8c02e68cf7aee191211d3ed37a4c0ac97c43902d7604a218817e70fa75f
      2021-04-20 02:03:56.089 - info: ping.0 (19843) starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.ping, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:03:56.670 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 20017
      2021-04-20 02:03:57.494 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 20026
      2021-04-20 02:03:58.284 - info: nuki.0 (19805) Lock list requested: http://192.168.1.11:8080/list?ts=2021-04-20T00:03:58Z&rnr=53629&hash=5874aa417e47f8a0c6d0bcd00eba91cd46cf4c755b13124dca68ae8d0d1a6e82
      2021-04-20 02:04:00.716 - info: host.raspberrypi instance system.adapter.trashschedule.0 started with pid 20043
      2021-04-20 02:04:01.268 - info: nuki.0 (19805) Server listening to http://192.168.1.79:9092
      2021-04-20 02:04:01.302 - info: pushover.0 (20026) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.pushover, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:02.129 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 20091
      2021-04-20 02:04:02.143 - error: text2command.0 (20017) text2command.0 already running
      2021-04-20 02:04:02.148 - warn: text2command.0 (20017) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:02.340 - error: trashschedule.0 (20043) trashschedule.0 already running
      2021-04-20 02:04:02.343 - warn: trashschedule.0 (20043) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:02.864 - error: host.raspberrypi instance system.adapter.text2command.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:02.865 - info: host.raspberrypi Restart adapter system.adapter.text2command.0 because enabled
      2021-04-20 02:04:03.015 - error: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:03.015 - info: host.raspberrypi Restart adapter system.adapter.trashschedule.0 because enabled
      2021-04-20 02:04:04.363 - info: nuki.0 (19805) Callback successfully set: http://192.168.1.79:9092/api/nuki.0
      2021-04-20 02:04:06.913 - info: host.raspberrypi instance system.adapter.rssfeed.0 started with pid 20261
      2021-04-20 02:04:07.788 - info: host.raspberrypi instance system.adapter.vis-inventwo.0 started with pid 20273
      2021-04-20 02:04:08.196 - error: telegram.0 (19837) telegram.0 already running
      2021-04-20 02:04:08.199 - warn: telegram.0 (19837) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:08.593 - info: rpi2.0 (20091) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:10.703 - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:11.523 - info: javascript.0 (19335) + axios@0.21.1
      added 85 packages from 129 contributors and audited 647 packages in 34.93s
      2021-04-20 02:04:10.703 - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
      2021-04-20 02:04:10.970 - info: host.raspberrypi instance system.adapter.samsung.0 started with pid 20412
      2021-04-20 02:04:13.617 - info: javascript.0 (19335)
      6 packages are looking for funding
      run `npm fund` for details
      2021-04-20 02:04:13.619 - info: javascript.0 (19335) found 0 vulnerabilities
      2021-04-20 02:04:13.812 - info: javascript.0 (19335) requesting all states
      2021-04-20 02:04:13.814 - info: javascript.0 (19335) requesting all objects
      2021-04-20 02:04:13.872 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 20508
      2021-04-20 02:04:15.848 - warn: rssfeed.0 (20261) slow connection to states DB. Still waiting ...
      2021-04-20 02:04:16.082 - warn: vis-inventwo.0 (20273) slow connection to states DB. Still waiting ...
      2021-04-20 02:04:16.439 - info: host.raspberrypi instance system.adapter.web.0 started with pid 20522
      2021-04-20 02:04:16.606 - info: host.raspberrypi instance system.adapter.sayit.0 started with pid 20529
      2021-04-20 02:04:16.973 - warn: samsung.0 (20412) slow connection to states DB. Still waiting ...
      2021-04-20 02:04:17.019 - info: javascript.0 (19335) received all objects
      2021-04-20 02:04:17.077 - error: vis-inventwo.0 (20273) vis-inventwo.0 already running
      2021-04-20 02:04:17.078 - warn: vis-inventwo.0 (20273) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:17.173 - info: host.raspberrypi instance system.adapter.yeelight-2.0 started with pid 20539
      2021-04-20 02:04:17.239 - info: javascript.0 (19335) received all states
      2021-04-20 02:04:21.492 - info: javascript.0 (19335) Start javascript script.js.Badezimmer.Lultfeuchte_prüfen
      2021-04-20 02:04:21.655 - info: javascript.0 (19335) script.js.Badezimmer.Lultfeuchte_prüfen: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.693 - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 20725
      2021-04-20 02:04:21.685 - info: javascript.0 (19335) Start javascript script.js.Telegram.Button_Telegram
      2021-04-20 02:04:21.694 - info: javascript.0 (19335) script.js.Telegram.Button_Telegram: registered 0 subscriptions and 0 schedules
      2021-04-20 02:04:21.695 - info: javascript.0 (19335) Start javascript script.js.Waschmaschine.Waschm_Aus
      2021-04-20 02:04:21.704 - info: javascript.0 (19335) script.js.Waschmaschine.Waschm_Aus: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.706 - info: javascript.0 (19335) Start javascript script.js.Waschmaschine.Waschm_Durchschnittsverbr
      2021-04-20 02:04:21.712 - info: javascript.0 (19335) script.js.Waschmaschine.Waschm_Durchschnittsverbr: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.713 - info: javascript.0 (19335) Start javascript script.js.Waschmaschine.Waschm_Ein
      2021-04-20 02:04:21.720 - info: javascript.0 (19335) script.js.Waschmaschine.Waschm_Ein: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.721 - info: javascript.0 (19335) Start javascript script.js.common.Badezimmerfenster_schliessen
      2021-04-20 02:04:21.728 - info: javascript.0 (19335) script.js.common.Badezimmerfenster_schliessen: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.729 - info: javascript.0 (19335) Start javascript script.js.common.Büro_Bewegung
      2021-04-20 02:04:21.734 - info: javascript.0 (19335) script.js.common.Büro_Bewegung: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.735 - info: javascript.0 (19335) Start javascript script.js.common.Büro_ein_NFC
      2021-04-20 02:04:21.741 - info: javascript.0 (19335) script.js.common.Büro_ein_NFC: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.742 - info: javascript.0 (19335) Start javascript script.js.common.Büro_verlassen
      2021-04-20 02:04:21.748 - info: javascript.0 (19335) script.js.common.Büro_verlassen: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.749 - info: javascript.0 (19335) Start javascript script.js.common.Corona_Ampel_Tabelle
      2021-04-20 02:04:21.776 - info: javascript.0 (19335) script.js.common.Corona_Ampel_Tabelle: registered 2 subscriptions and 1 schedule
      2021-04-20 02:04:21.777 - info: javascript.0 (19335) Start javascript script.js.common.Corona_Bericht
      2021-04-20 02:04:21.785 - info: javascript.0 (19335) script.js.common.Corona_Bericht: registered 0 subscriptions and 1 schedule
      2021-04-20 02:04:21.786 - info: javascript.0 (19335) Start javascript script.js.common.Dimmer_T1
      2021-04-20 02:04:21.792 - info: javascript.0 (19335) script.js.common.Dimmer_T1: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.793 - info: javascript.0 (19335) Start javascript script.js.common.Dimmer_T4
      2021-04-20 02:04:21.804 - info: javascript.0 (19335) script.js.common.Dimmer_T4: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.806 - info: javascript.0 (19335) Start javascript script.js.common.Garten_Sicherheit_Abschaltung
      2021-04-20 02:04:21.814 - info: javascript.0 (19335) script.js.common.Garten_Sicherheit_Abschaltung: registered 1 subscription and 1 schedule
      2021-04-20 02:04:21.815 - info: javascript.0 (19335) Start javascript script.js.common.Garten_Strahler
      2021-04-20 02:04:21.821 - info: javascript.0 (19335) script.js.common.Garten_Strahler: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.822 - info: javascript.0 (19335) Start javascript script.js.common.Hahn_Strahler
      2021-04-20 02:04:21.848 - info: javascript.0 (19335) script.js.common.Hahn_Strahler: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.851 - info: javascript.0 (19335) Start javascript script.js.common.Heizraum_Notlicht
      2021-04-20 02:04:21.862 - info: javascript.0 (19335) script.js.common.Heizraum_Notlicht: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.863 - info: javascript.0 (19335) Start javascript script.js.common.Küche_CO2_zu_hoch
      2021-04-20 02:04:21.875 - info: javascript.0 (19335) script.js.common.Küche_CO2_zu_hoch: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.876 - info: javascript.0 (19335) Start javascript script.js.common.Rasenroboter_Startet
      2021-04-20 02:04:21.881 - info: javascript.0 (19335) script.js.common.Rasenroboter_Startet: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.882 - info: javascript.0 (19335) Start javascript script.js.common.Regenabfrage
      2021-04-20 02:04:21.904 - info: javascript.0 (19335) script.js.common.Regenabfrage: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.905 - info: javascript.0 (19335) Start javascript script.js.common.Schlafz_Fernsehlicht
      2021-04-20 02:04:21.911 - info: javascript.0 (19335) script.js.common.Schlafz_Fernsehlicht: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.912 - info: javascript.0 (19335) Start javascript script.js.common.Schlafzimmerfenster_schliessen
      2021-04-20 02:04:21.952 - info: javascript.0 (19335) script.js.common.Schlafzimmerfenster_schliessen: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.953 - info: javascript.0 (19335) Start javascript script.js.common.Türklingel_Trigger
      2021-04-20 02:04:21.966 - info: javascript.0 (19335) script.js.common.Türklingel_Trigger: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.967 - info: javascript.0 (19335) Start javascript script.js.common.WC_Klopapier
      2021-04-20 02:04:21.972 - info: javascript.0 (19335) script.js.common.WC_Klopapier: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.973 - info: javascript.0 (19335) Start javascript script.js.common.Zustand_Kellerschloss
      2021-04-20 02:04:21.978 - info: javascript.0 (19335) script.js.common.Zustand_Kellerschloss: registered 1 subscription and 0 schedules
      2021-04-20 02:04:21.979 - info: javascript.0 (19335) Start javascript script.js.kamera_scripte.Auslöser
      2021-04-20 02:04:22.055 - info: javascript.0 (19335) script.js.kamera_scripte.Auslöser: registered 1 subscription and 0 schedules
      2021-04-20 02:04:22.056 - info: javascript.0 (19335) Start javascript script.js.kamera_scripte.Hole_noch_ein_Bild
      2021-04-20 02:04:22.062 - info: javascript.0 (19335) script.js.kamera_scripte.Hole_noch_ein_Bild: registered 1 subscription and 0 schedules
      2021-04-20 02:04:22.091 - info: javascript.0 (19335) Start javascript script.js.kamera_scripte.Tastatur_Telegram
      2021-04-20 02:04:22.097 - info: javascript.0 (19335) script.js.kamera_scripte.Tastatur_Telegram: registered 0 subscriptions and 0 schedules
      2021-04-20 02:04:22.098 - info: javascript.0 (19335) Start javascript script.js.common.Müllabfuhr_Meldung
      2021-04-20 02:04:22.157 - info: javascript.0 (19335) script.js.common.Müllabfuhr_Meldung: registered 0 subscriptions and 2 schedules
      2021-04-20 02:04:22.158 - info: javascript.0 (19335) Start javascript script.js.common.TelefonMonitor
      2021-04-20 02:04:22.163 - info: javascript.0 (19335) script.js.common.TelefonMonitor: registered 1 subscription and 0 schedules
      2021-04-20 02:04:22.164 - info: javascript.0 (19335) Start javascript script.js.common.TelefonFestnetzPushover
      2021-04-20 02:04:22.170 - info: javascript.0 (19335) script.js.common.TelefonFestnetzPushover: registered 1 subscription and 0 schedules
      2021-04-20 02:04:22.203 - info: javascript.0 (19335) Start javascript script.js.common.AnzeigeGeräte_aktualisieren
      2021-04-20 02:04:22.210 - info: javascript.0 (19335) script.js.common.AnzeigeGeräte_aktualisieren: registered 0 subscriptions and 1 schedule
      2021-04-20 02:04:22.210 - info: javascript.0 (19335) Start javascript script.js.common.Corona_Insidenz
      2021-04-20 02:04:22.396 - info: javascript.0 (19335) script.js.common.Corona_Insidenz: registered 1 subscription and 1 schedule
      2021-04-20 02:04:22.396 - info: javascript.0 (19335) Start javascript script.js.common.Müllabfuhr_Kalender
      2021-04-20 02:04:22.422 - info: javascript.0 (19335) script.js.common.Müllabfuhr_Kalender: registered 0 subscriptions and 1 schedule
      2021-04-20 02:04:22.433 - info: javascript.0 (19335) Start javascript script.js.common.Wohnzimmer_Zufall_Licht
      2021-04-20 02:04:22.442 - info: javascript.0 (19335) script.js.common.Wohnzimmer_Zufall_Licht: registered 0 subscriptions and 1 schedule
      2021-04-20 02:04:22.453 - info: javascript.0 (19335) Start javascript script.js.common.Wohnzimmer_ausschalten
      2021-04-20 02:04:22.459 - info: javascript.0 (19335) script.js.common.Wohnzimmer_ausschalten: registered 1 subscription and 0 schedules
      2021-04-20 02:04:22.460 - info: javascript.0 (19335) Start javascript script.js.common.Regen-Schnee_Ansage
      2021-04-20 02:04:22.466 - info: javascript.0 (19335) script.js.common.Regen-Schnee_Ansage: registered 1 subscription and 0 schedules
      2021-04-20 02:04:22.466 - info: javascript.0 (19335) Start javascript script.js.common.Zufahrt_Bewegung
      2021-04-20 02:04:22.472 - info: javascript.0 (19335) script.js.common.Zufahrt_Bewegung: registered 1 subscription and 0 schedules
      2021-04-20 02:04:22.473 - info: javascript.0 (19335) Start javascript script.js.common.ical_Müll-Geburtstag
      2021-04-20 02:04:22.494 - info: javascript.0 (19335) script.js.common.ical_Müll-Geburtstag: registered 2 subscriptions and 1 schedule
      2021-04-20 02:04:23.036 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 20736
      2021-04-20 02:04:23.037 - error: host.raspberrypi instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:23.038 - info: host.raspberrypi Restart adapter system.adapter.vis-inventwo.0 because enabled
      2021-04-20 02:04:24.097 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 20752
      2021-04-20 02:04:24.910 - info: vis.0 (20354) starting. Version 1.3.8 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:25.216 - error: yeelight-2.0 (20539) yeelight-2.0 already running
      2021-04-20 02:04:25.219 - warn: yeelight-2.0 (20539) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:25.254 - error: web.0 (20522) web.0 already running
      2021-04-20 02:04:25.260 - warn: web.0 (20522) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:25.341 - info: host.raspberrypi instance system.adapter.zwave2.0 started with pid 20767
      2021-04-20 02:04:25.401 - info: vis.0 (20354) vis license is OK.
      2021-04-20 02:04:26.369 - error: host.raspberrypi instance system.adapter.yeelight-2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:26.372 - info: host.raspberrypi Restart adapter system.adapter.yeelight-2.0 because enabled
      2021-04-20 02:04:26.677 - error: host.raspberrypi instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:26.677 - info: host.raspberrypi Restart adapter system.adapter.web.0 because enabled
      2021-04-20 02:04:27.176 - info: samsung.0 (20412) starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.samsung, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:27.779 - info: rssfeed.0 (20261) starting. Version 0.0.30 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:27.782 - error: tr-064.0 (20736) tr-064.0 already running
      2021-04-20 02:04:27.786 - warn: tr-064.0 (20736) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:29.202 - info: host.raspberrypi instance system.adapter.mytime.0 started with pid 20962
      2021-04-20 02:04:29.262 - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:29.263 - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
      2021-04-20 02:04:30.182 - info: telegram.0 (20508) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:30.433 - info: simple-api.0 (20725) starting. Version 2.5.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:30.493 - info: simple-api.0 (20725) simpleAPI server listening on port 8087
      2021-04-20 02:04:30.494 - info: simple-api.0 (20725) Allow states only when user is owner: false
      2021-04-20 02:04:30.515 - info: simple-api.0 (20725) http server listening on port 8087
      2021-04-20 02:04:31.505 - info: sonos.0 (20752) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.sonos, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:31.666 - info: sayit.0 (20529) starting. Version 1.12.2 in /opt/iobroker/node_modules/iobroker.sayit, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:31.730 - info: sayit.0 (20529) Upload announce mp3 files
      2021-04-20 02:04:32.146 - info: sayit.0 (20529) All files uploaded
      2021-04-20 02:04:32.214 - info: vis.0 (20354) Terminated (NO_ERROR): Without reason
      2021-04-20 02:04:32.229 - error: mytime.0 (20962) mytime.0 already running
      2021-04-20 02:04:32.232 - warn: mytime.0 (20962) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:32.887 - info: host.raspberrypi instance system.adapter.tvprogram.0 started with pid 21000
      2021-04-20 02:04:32.960 - error: mytime.0 (20962) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-20 02:04:32.963 - error: mytime.0 (20962) unhandled promise rejection: Cannot read property 'debug' of undefined
      2021-04-20 02:04:32.966 - error: mytime.0 (20962) TypeError: Cannot read property 'debug' of undefined
      at Mytime.onUnload (/opt/iobroker/node_modules/iobroker.mytime/main.js:64:22)
      at Mytime.emit (events.js:314:20)
      2021-04-20 02:04:32.967 - error: mytime.0 (20962) Cannot read property 'debug' of undefined
      2021-04-20 02:04:32.995 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 21008
      2021-04-20 02:04:33.403 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
      2021-04-20 02:04:33.838 - warn: node-red.0 (19620) 20 Apr 02:04:33 - [warn] Projekte inaktiviert: editorTheme.projects.enabled=false
      2021-04-20 02:04:33.910 - warn: node-red.0 (19812) slow connection to objects DB. Still waiting ...
      2021-04-20 02:04:34.379 - error: host.raspberrypi instance system.adapter.mytime.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:34.380 - info: host.raspberrypi Restart adapter system.adapter.mytime.0 because enabled
      2021-04-20 02:04:34.496 - info: host.raspberrypi instance system.adapter.trashschedule.0 started with pid 21053
      2021-04-20 02:04:35.250 - error: zwave2.0 (20767) zwave2.0 already running
      2021-04-20 02:04:35.255 - warn: zwave2.0 (20767) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:35.578 - info: mqtt.0 (19413) Client [mqtt_a8916896.f0bd58] connected with secret 1618877075560_6883
      2021-04-20 02:04:36.092 - error: host.raspberrypi instance system.adapter.zwave2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:36.092 - info: host.raspberrypi Restart adapter system.adapter.zwave2.0 because enabled
      2021-04-20 02:04:36.257 - error: tvprogram.0 (21000) tvprogram.0 already running
      2021-04-20 02:04:36.261 - warn: tvprogram.0 (21000) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:36.549 - info: mqtt.0 (19413) Client [mqtt_a8916896.f0bd58] subscribes on topic "test"
      2021-04-20 02:04:36.632 - info: host.raspberrypi instance system.adapter.lgtv.0 started with pid 21205
      2021-04-20 02:04:37.115 - error: tvprogram.0 (21000) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-20 02:04:37.117 - error: tvprogram.0 (21000) unhandled promise rejection: Cannot read property 'debug' of undefined
      2021-04-20 02:04:37.120 - error: tvprogram.0 (21000) TypeError: Cannot read property 'debug' of undefined
      at Tvprogram.onUnload (/opt/iobroker/node_modules/iobroker.tvprogram/main.js:66:22)
      at Tvprogram.emit (events.js:314:20)
      2021-04-20 02:04:37.121 - error: tvprogram.0 (21000) Cannot read property 'debug' of undefined
      2021-04-20 02:04:37.388 - error: host.raspberrypi instance system.adapter.tvprogram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:37.388 - info: host.raspberrypi Restart adapter system.adapter.tvprogram.0 because enabled
      2021-04-20 02:04:38.575 - info: text2command.0 (21008) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.text2command, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:38.805 - error: lgtv.0 (21205) lgtv.0 already running
      2021-04-20 02:04:38.809 - warn: lgtv.0 (21205) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:39.340 - warn: lgtv.0 (21205) redis get lgtv.0.info.connection, error - Connection is closed.
      2021-04-20 02:04:39.353 - error: lgtv.0 (21205) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-20 02:04:39.354 - error: lgtv.0 (21205) unhandled promise rejection: Cannot read property 'debug' of undefined
      2021-04-20 02:04:39.357 - error: lgtv.0 (21205) TypeError: Cannot read property 'debug' of undefined
      at checkCurApp (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:517:17)
      at checkConnection (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:504:13)
      at Object.unload (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:336:13)
      at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8607:29)
      2021-04-20 02:04:39.358 - error: lgtv.0 (21205) Cannot read property 'debug' of undefined
      2021-04-20 02:04:39.366 - error: lgtv.0 (21205) Cannot check object existence of "lgtv.0.info.connection": Connection is closed.
      2021-04-20 02:04:39.367 - warn: lgtv.0 (21205) Could not check object existence of state lgtv.0.info.connection: Cannot check object existence of "lgtv.0.info.connection": Connection is closed.
      2021-04-20 02:04:39.369 - warn: lgtv.0 (21205) get state error: Connection is closed.
      2021-04-20 02:04:39.544 - error: host.raspberrypi instance system.adapter.lgtv.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:39.544 - info: host.raspberrypi Restart adapter system.adapter.lgtv.0 because enabled
      2021-04-20 02:04:39.652 - info: trashschedule.0 (21053) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:39.811 - warn: trashschedule.0 (21053) no events matches type "Verpackung" with match "Verp". Check configuration of iCal (increase preview) and trashschedule!
      2021-04-20 02:04:40.543 - info: host.raspberrypi instance scheduled system.adapter.daswetter.0 */15 * * * *
      2021-04-20 02:04:44.593 - info: host.raspberrypi instance system.adapter.ring.0 started with pid 21397
      2021-04-20 02:04:48.162 - error: ring.0 (21397) ring.0 already running
      2021-04-20 02:04:48.165 - warn: ring.0 (21397) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:04:48.851 - error: host.raspberrypi instance system.adapter.ring.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-04-20 02:04:48.851 - info: host.raspberrypi Restart adapter system.adapter.ring.0 because enabled
      2021-04-20 02:04:53.088 - info: host.raspberrypi instance system.adapter.vis-inventwo.0 started with pid 21582
      2021-04-20 02:04:54.784 - info: vis-inventwo.0 (21582) starting. Version 2.9.2 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:56.432 - info: host.raspberrypi instance system.adapter.yeelight-2.0 started with pid 21601
      2021-04-20 02:04:56.734 - info: host.raspberrypi instance system.adapter.web.0 started with pid 21611
      2021-04-20 02:04:58.986 - info: yeelight-2.0 (21601) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:04:59.302 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 21799
      2021-04-20 02:05:00.393 - info: host.raspberrypi instance system.adapter.ical.1 started with pid 21809
      2021-04-20 02:05:00.717 - info: web.0 (21611) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:05:01.303 - info: web.0 (21611) socket.io server listening on port 8082
      2021-04-20 02:05:01.309 - info: web.0 (21611) http server listening on port 8082
      2021-04-20 02:05:02.410 - info: tr-064.0 (21799) starting. Version 4.2.11 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:05:03.154 - info: ical.1 (21809) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:05:04.429 - info: host.raspberrypi instance system.adapter.mytime.0 started with pid 21839
      2021-04-20 02:05:04.713 - info: ical.1 (21809) processing URL: Geburtstage http://p25-caldav.icloud.com/published/2/AAAAAAAAAAAAAAAAAAAAAJJnnvDTY6VFWIFDivW_83qBfJz6Q9qd1_Fi2SjnBDo3cLQ4C70Zpg2NxyfyyFGvl1659y2agUpqE7IXc_EB7R0
      2021-04-20 02:05:06.133 - info: host.raspberrypi instance system.adapter.zwave2.0 started with pid 21884
      2021-04-20 02:05:06.495 - info: mytime.0 (21839) starting. Version 0.6.1 in /opt/iobroker/node_modules/iobroker.mytime, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:05:06.642 - info: mytime.0 (21839) state mytime.0.info.connection changed: false (ack = true)
      2021-04-20 02:05:06.647 - info: mytime.0 (21839) state mytime.0.info.connection changed: true (ack = true)
      2021-04-20 02:05:06.669 - info: mytime.0 (21839) state mytime.0.Countdown.Test.name changed: Test (ack = true)
      2021-04-20 02:05:06.674 - info: mytime.0 (21839) state mytime.0.Countdown.Test.config changed: {"stopbehaviour":"timer"} (ack = true)
      2021-04-20 02:05:06.678 - info: mytime.0 (21839) state mytime.0.Countdown.Test.end changed: 0 (ack = true)
      2021-04-20 02:05:06.687 - info: mytime.0 (21839) state mytime.0.Countdown.Test.timer changed: 300000 (ack = true)
      2021-04-20 02:05:06.697 - info: mytime.0 (21839) state mytime.0.Countdown.Test.action changed: stop (ack = true)
      2021-04-20 02:05:06.699 - info: mytime.0 (21839) state mytime.0.Countdown.Test.start changed: 0 (ack = true)
      2021-04-20 02:05:06.711 - info: mytime.0 (21839) state mytime.0.Countdown.Test.cmd changed: (ack = true)
      2021-04-20 02:05:07.416 - info: host.raspberrypi instance system.adapter.tvprogram.0 started with pid 22036
      2021-04-20 02:05:09.542 - info: tvprogram.0 (22036) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tvprogram, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:05:09.584 - info: host.raspberrypi instance system.adapter.lgtv.0 started with pid 22056
      2021-04-20 02:05:10.243 - info: zwave2.0 (21884) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:05:10.572 - info: ical.1 (21809) Terminated (NO_ERROR): Without reason
      2021-04-20 02:05:12.787 - info: host.raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
      2021-04-20 02:05:16.224 - info: lgtv.0 (22056) starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.lgtv, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:05:16.255 - info: lgtv.0 (22056) Ready. Configured WebOS TV IP: 192.168.1.12
      2021-04-20 02:05:20.635 - info: host.raspberrypi instance system.adapter.ring.0 started with pid 22282
      2021-04-20 02:05:21.191 - info: web.0 (21611) ==>Connected system.user.admin from ::ffff:192.168.1.17
      2021-04-20 02:05:21.327 - info: zwave2.0 (21884) The driver is ready. Found 1 nodes.
      2021-04-20 02:05:21.336 - info: zwave2.0 (21884) All nodes are ready to use
      2021-04-20 02:05:21.425 - info: zwave2.0 (21884) Node 1: ready to use
      2021-04-20 02:05:24.602 - info: ring.0 (22282) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.ring, node: v12.22.1, js-controller: 3.2.16
      2021-04-20 02:05:24.673 - info: ring.0 (22282) Starting Adapter ring.0 in version 1.2.1
      2021-04-20 02:05:26.912 - info: ring.0 (22282) Starting Ring Device for Id 4242830
      2021-04-20 02:08:51.082 - info: web.0 (21611) ==>Connected system.user.admin from ::ffff:192.168.1.34
      2021-04-20 02:15:00.047 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 3313
      2021-04-20 02:15:01.465 - error: daswetter.0 (3313) daswetter.0 already running
      2021-04-20 02:15:01.469 - warn: daswetter.0 (3313) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-04-20 02:15:03.212 - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      homee, ioBroker, iMac, iPhone, Sonos, Alaxa
      • bergjetB bergjet
        Und das
        2021-04-20 02:01:46.731 - error: admin.0 (18292) admin.0 already running
        2021-04-20 02:01:46.734 - warn: admin.0 (18292) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:01:47.470 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:01:47.471 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
        2021-04-20 02:01:48.716 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 18303
        2021-04-20 02:01:50.195 - error: alexa2.0 (18303) alexa2.0 already running
        2021-04-20 02:01:50.198 - warn: alexa2.0 (18303) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:01:50.855 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:01:50.856 - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
        2021-04-20 02:01:52.575 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 18314
        2021-04-20 02:01:57.369 - info: host.raspberrypi instance scheduled system.adapter.coronavirus-statistics.0 */30 * * * *
        2021-04-20 02:01:57.414 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 18325
        2021-04-20 02:01:57.786 - error: backitup.0 (18314) backitup.0 already running
        2021-04-20 02:01:57.789 - warn: backitup.0 (18314) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:01:58.513 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:01:58.514 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
        2021-04-20 02:02:00.356 - info: coronavirus-statistics.0 (18325) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:00.703 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 18340
        2021-04-20 02:02:01.846 - error: discovery.0 (18340) discovery.0 already running
        2021-04-20 02:02:01.849 - warn: discovery.0 (18340) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:02.546 - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:02.546 - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
        2021-04-20 02:02:04.581 - info: host.raspberrypi instance system.adapter.email.0 started with pid 18351
        2021-04-20 02:02:05.895 - error: email.0 (18351) email.0 already running
        2021-04-20 02:02:05.898 - warn: email.0 (18351) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:06.543 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:06.544 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
        2021-04-20 02:02:08.406 - info: coronavirus-statistics.0 (18325) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2021-04-20 02:02:08.547 - info: host.raspberrypi instance system.adapter.fakeroku.0 started with pid 18362
        2021-04-20 02:02:09.074 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-04-20 02:02:09.720 - error: fakeroku.0 (18362) fakeroku.0 already running
        2021-04-20 02:02:09.723 - warn: fakeroku.0 (18362) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:10.373 - error: host.raspberrypi instance system.adapter.fakeroku.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:10.373 - info: host.raspberrypi Restart adapter system.adapter.fakeroku.0 because enabled
        2021-04-20 02:02:12.716 - info: host.raspberrypi instance system.adapter.geofency.0 started with pid 18373
        2021-04-20 02:02:13.924 - error: geofency.0 (18373) geofency.0 already running
        2021-04-20 02:02:13.926 - warn: geofency.0 (18373) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:14.586 - error: host.raspberrypi instance system.adapter.geofency.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:14.587 - info: host.raspberrypi Restart adapter system.adapter.geofency.0 because enabled
        2021-04-20 02:02:16.575 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 18385
        2021-04-20 02:02:17.494 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 18392
        2021-04-20 02:02:18.214 - error: harmony.0 (18385) harmony.0 already running
        2021-04-20 02:02:18.217 - warn: harmony.0 (18385) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:18.907 - error: host.raspberrypi instance system.adapter.harmony.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:18.908 - info: host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
        2021-04-20 02:02:19.748 - info: admin.0 (18392) starting. Version 5.0.4 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:19.800 - info: admin.0 (18392) requesting all states
        2021-04-20 02:02:19.801 - info: admin.0 (18392) requesting all objects
        2021-04-20 02:02:21.351 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 18411
        2021-04-20 02:02:21.384 - info: host.raspberrypi instance system.adapter.history.0 started with pid 18417
        2021-04-20 02:02:22.050 - info: admin.0 (18392) received all objects
        2021-04-20 02:02:22.784 - info: admin.0 (18392) http server listening on port 8081
        2021-04-20 02:02:22.785 - info: admin.0 (18392) Use link "http://localhost:8081" to configure.
        2021-04-20 02:02:22.869 - error: history.0 (18417) history.0 already running
        2021-04-20 02:02:22.872 - warn: history.0 (18417) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:23.542 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:23.542 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
        2021-04-20 02:02:23.552 - info: alexa2.0 (18411) starting. Version 3.8.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:24.966 - info: host.raspberrypi instance system.adapter.homee.0 started with pid 18437
        2021-04-20 02:02:26.268 - error: homee.0 (18437) homee.0 already running
        2021-04-20 02:02:26.270 - warn: homee.0 (18437) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:26.972 - error: host.raspberrypi instance system.adapter.homee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:26.973 - info: host.raspberrypi Restart adapter system.adapter.homee.0 because enabled
        2021-04-20 02:02:28.011 - info: alexa2.0 (18411) Alexa-Push-Connection established. Disable Polling
        2021-04-20 02:02:28.309 - info: alexa2.0 (18411) Unknown Device, but enabling commands, Try it and report back if commands work.
        2021-04-20 02:02:28.310 - info: alexa2.0 (18411) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
        2021-04-20 02:02:28.310 - info: alexa2.0 (18411) Device-type:A2Y04QPFCANLPQ (TIDAL,PERSISTENT_CONNECTION,TUNE_IN,VOLUME_SETTING,AMAZON_MUSIC,SIRIUSXM,KINDLE_BOOKS,APPLE_MUSIC,SLEEP,DEREGISTER_DEVICE,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,GOLDFISH,DREAM_TRAINING,AUDIO_PLAYER,TIMERS_AND_ALARMS,DEEZER,MUSIC_SKILL,MICROPHONE,AUDIBLE,I_HEART_RADIO,CHANGE_NAME)
        2021-04-20 02:02:28.320 - info: alexa2.0 (18411) Unknown Device, but enabling commands, Try it and report back if commands work.
        2021-04-20 02:02:28.321 - info: alexa2.0 (18411) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
        2021-04-20 02:02:28.321 - info: alexa2.0 (18411) Device-type:A1W2YILXTG9HA7 (TIDAL,PERSISTENT_CONNECTION,TUNE_IN,VOLUME_SETTING,AMAZON_MUSIC,SIRIUSXM,KINDLE_BOOKS,APPLE_MUSIC,REMINDERS,SLEEP,DEREGISTER_DEVICE,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,GOLDFISH,DREAM_TRAINING,AUDIO_PLAYER,TIMERS_AND_ALARMS,DEEZER,MUSIC_SKILL,MICROPHONE,AUDIBLE,I_HEART_RADIO,CHANGE_NAME)
        2021-04-20 02:02:28.552 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 18448
        2021-04-20 02:02:28.648 - info: host.raspberrypi instance system.adapter.hue-extended.0 started with pid 18455
        2021-04-20 02:02:30.772 - error: hue-extended.0 (18455) hue-extended.0 already running
        2021-04-20 02:02:30.775 - warn: hue-extended.0 (18455) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:31.444 - error: host.raspberrypi instance system.adapter.hue-extended.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:31.445 - info: host.raspberrypi Restart adapter system.adapter.hue-extended.0 because enabled
        2021-04-20 02:02:32.693 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 18470
        2021-04-20 02:02:32.725 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 18476
        2021-04-20 02:02:34.088 - info: backitup.0 (18448) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:34.280 - info: backitup.0 (18448) [iobroker] backup was activated at 02:00 every 1 day(s)
        2021-04-20 02:02:34.905 - error: hue.0 (18476) hue.0 already running
        2021-04-20 02:02:34.910 - warn: hue.0 (18476) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:35.135 - info: discovery.0 (18470) starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:35.556 - error: host.raspberrypi instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:35.557 - info: host.raspberrypi Restart adapter system.adapter.hue.0 because enabled
        2021-04-20 02:02:36.572 - info: host.raspberrypi instance system.adapter.husq-automower.0 started with pid 18500
        2021-04-20 02:02:36.628 - info: host.raspberrypi instance system.adapter.email.0 started with pid 18506
        2021-04-20 02:02:38.296 - error: husq-automower.0 (18500) husq-automower.0 already running
        2021-04-20 02:02:38.299 - warn: husq-automower.0 (18500) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:38.458 - info: email.0 (18506) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.email, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:39.004 - error: host.raspberrypi instance system.adapter.husq-automower.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:39.005 - info: host.raspberrypi Restart adapter system.adapter.husq-automower.0 because enabled
        2021-04-20 02:02:40.420 - info: host.raspberrypi instance system.adapter.fakeroku.0 started with pid 18526
        2021-04-20 02:02:40.774 - info: host.raspberrypi instance scheduled system.adapter.ical.0 0 2,4 * * *
        2021-04-20 02:02:40.799 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 18533
        2021-04-20 02:02:42.046 - info: fakeroku.0 (18526) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fakeroku, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:43.033 - info: ical.0 (18533) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:44.636 - info: host.raspberrypi instance scheduled system.adapter.ical.1 5 2,4 * * *
        2021-04-20 02:02:44.654 - info: host.raspberrypi instance system.adapter.ical.1 started with pid 18556
        2021-04-20 02:02:44.681 - info: host.raspberrypi instance system.adapter.geofency.0 started with pid 18562
        2021-04-20 02:02:46.610 - info: geofency.0 (18562) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.geofency, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:46.658 - info: geofency.0 (18562) Adapter got 'Ready' Signal - initiating Main function...
        2021-04-20 02:02:46.699 - info: geofency.0 (18562) http server listening on port 7999
        2021-04-20 02:02:47.831 - info: ical.1 (18556) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:48.689 - info: host.raspberrypi instance system.adapter.info.0 started with pid 18586
        2021-04-20 02:02:48.931 - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 18593
        2021-04-20 02:02:49.450 - info: ical.1 (18556) processing URL: Geburtstage http://p25-caldav.icloud.com/published/2/AAAAAAAAAAAAAAAAAAAAAJJnnvDTY6VFWIFDivW_83qBfJz6Q9qd1_Fi2SjnBDo3cLQ4C70Zpg2NxyfyyFGvl1659y2agUpqE7IXc_EB7R0
        2021-04-20 02:02:50.804 - info: ical.0 (18533) processing URL: Müll http://p25-caldav.icloud.com/published/2/Mjc2ODA0MDAwMjc2ODA0MOWAQ_Hp47ycJEgYb0oET12LPeUAOwbTuiHnNWrmHF21ZilCgnWV2zu_3gFQLNJIuNKRi8FkQZJBGf2_bTAS3rjaxgj8VXAGfuiCKKkA0_sxFDWnISlJyUhyvepk5YbXXg
        2021-04-20 02:02:52.578 - info: harmony.0 (18593) starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.harmony, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:52.655 - info: harmony.0 (18593) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
        2021-04-20 02:02:53.043 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 18621
        2021-04-20 02:02:53.162 - error: info.0 (18586) info.0 already running
        2021-04-20 02:02:53.166 - warn: info.0 (18586) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:53.569 - info: host.raspberrypi instance system.adapter.history.0 started with pid 18628
        2021-04-20 02:02:53.855 - error: host.raspberrypi instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:53.856 - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
        2021-04-20 02:02:53.995 - info: harmony.0 (18593) [DISCOVER] Discovered Harmony Hub (192.168.1.84) and will try to connect
        2021-04-20 02:02:54.064 - info: harmony.0 (18593) [CONNECT] Connecting to Harmony Hub (192.168.1.84)
        2021-04-20 02:02:55.042 - info: ical.1 (18556) Terminated (NO_ERROR): Without reason
        2021-04-20 02:02:55.240 - info: harmony.0 (18593) [CONNECT] Connected to Harmony Hub (192.168.1.84)
        2021-04-20 02:02:55.332 - error: iot.0 (18621) iot.0 already running
        2021-04-20 02:02:55.335 - warn: iot.0 (18621) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:02:55.546 - info: history.0 (18628) starting. Version 1.9.12 in /opt/iobroker/node_modules/iobroker.history, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:55.685 - info: host.raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
        2021-04-20 02:02:55.782 - info: history.0 (18628) enabled logging of hue.0.Wohnzimmrr_Hue_white_lamp_1.on (Count=1), Alias=false
        2021-04-20 02:02:55.997 - error: host.raspberrypi instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:02:55.998 - info: host.raspberrypi Restart adapter system.adapter.iot.0 because enabled
        2021-04-20 02:02:56.329 - info: harmony.0 (18593) [PROCESS] Synced hub config for Harmony Hub (192.168.1.84)
        2021-04-20 02:02:56.686 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 18647
        2021-04-20 02:02:56.871 - info: ical.0 (18533) Terminated (NO_ERROR): Without reason
        2021-04-20 02:02:56.998 - info: host.raspberrypi instance system.adapter.homee.0 started with pid 18654
        2021-04-20 02:02:57.581 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2021-04-20 02:02:59.160 - info: homee.0 (18654) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.homee, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:02:59.215 - info: homee.0 (18654) Init homee 192.168.1.74 for user Martin
        2021-04-20 02:02:59.375 - info: homee.0 (18654) CONNECTED
        2021-04-20 02:02:59.762 - error: javascript.0 (18647) javascript.0 already running
        2021-04-20 02:02:59.765 - warn: javascript.0 (18647) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:00.408 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:00.409 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
        2021-04-20 02:03:00.686 - info: host.raspberrypi instance system.adapter.meross.0 started with pid 18673
        2021-04-20 02:03:01.061 - info: homee.0 (18654) initialize 48 nodes
        2021-04-20 02:03:01.487 - info: host.raspberrypi instance system.adapter.hue-extended.0 started with pid 18680
        2021-04-20 02:03:02.960 - error: meross.0 (18673) meross.0 already running
        2021-04-20 02:03:02.964 - warn: meross.0 (18673) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:03.336 - info: homee.0 (18654) initialize 50 homeegrams
        2021-04-20 02:03:04.080 - error: host.raspberrypi instance system.adapter.meross.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:04.080 - info: host.raspberrypi Restart adapter system.adapter.meross.0 because enabled
        2021-04-20 02:03:04.803 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 18695
        2021-04-20 02:03:05.159 - info: hue-extended.0 (18680) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue-extended, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:05.205 - info: hue-extended.0 (18680) Establishing connection to bridge..
        2021-04-20 02:03:05.513 - info: alexa2.0 (18411) Subscribing to states...
        2021-04-20 02:03:05.699 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 18706
        2021-04-20 02:03:05.846 - info: hue-extended.0 (18680) Using polling for state updates.
        2021-04-20 02:03:06.166 - error: mqtt.0 (18695) mqtt.0 already running
        2021-04-20 02:03:06.169 - warn: mqtt.0 (18695) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:06.922 - error: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:06.923 - info: host.raspberrypi Restart adapter system.adapter.mqtt.0 because enabled
        2021-04-20 02:03:07.944 - info: hue.0 (18706) starting. Version 3.5.2 in /opt/iobroker/node_modules/iobroker.hue, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:08.580 - info: host.raspberrypi instance system.adapter.netatmo.0 started with pid 18725
        2021-04-20 02:03:08.921 - info: hue.0 (18706) skip switch: Daylight.configured
        2021-04-20 02:03:08.922 - info: hue.0 (18706) skip switch: Daylight.sunriseoffset
        2021-04-20 02:03:08.923 - info: hue.0 (18706) skip switch: Daylight.sunsetoffset
        2021-04-20 02:03:08.926 - info: hue.0 (18706) skip switch: Büro sensor 2.alert
        2021-04-20 02:03:08.927 - info: hue.0 (18706) skip switch: Büro sensor 2.sensitivity
        2021-04-20 02:03:08.928 - info: hue.0 (18706) skip switch: Büro sensor 2.sensitivitymax
        2021-04-20 02:03:08.928 - info: hue.0 (18706) skip switch: Büro sensor 2.ledindication
        2021-04-20 02:03:08.929 - info: hue.0 (18706) skip switch: Büro sensor 2.usertest
        2021-04-20 02:03:08.931 - info: hue.0 (18706) skip switch: Hue ambient light sensor 2.alert
        2021-04-20 02:03:08.932 - info: hue.0 (18706) skip switch: Hue ambient light sensor 2.tholddark
        2021-04-20 02:03:08.933 - info: hue.0 (18706) skip switch: Hue ambient light sensor 2.tholdoffset
        2021-04-20 02:03:08.933 - info: hue.0 (18706) skip switch: Hue ambient light sensor 2.ledindication
        2021-04-20 02:03:08.934 - info: hue.0 (18706) skip switch: Hue ambient light sensor 2.usertest
        2021-04-20 02:03:08.937 - info: hue.0 (18706) skip switch: Hue temperature sensor 2.alert
        2021-04-20 02:03:08.937 - info: hue.0 (18706) skip switch: Hue temperature sensor 2.ledindication
        2021-04-20 02:03:08.938 - info: hue.0 (18706) skip switch: Hue temperature sensor 2.usertest
        2021-04-20 02:03:08.944 - info: hue.0 (18706) skip switch: EG Gang Schl sensor 1.alert
        2021-04-20 02:03:08.945 - info: hue.0 (18706) skip switch: EG Gang Schl sensor 1.sensitivity
        2021-04-20 02:03:08.945 - info: hue.0 (18706) skip switch: EG Gang Schl sensor 1.sensitivitymax
        2021-04-20 02:03:08.946 - info: hue.0 (18706) skip switch: EG Gang Schl sensor 1.ledindication
        2021-04-20 02:03:08.946 - info: hue.0 (18706) skip switch: EG Gang Schl sensor 1.usertest
        2021-04-20 02:03:09.358 - info: hue.0 (18706) skip switch: Hue ambient light sensor 5.alert
        2021-04-20 02:03:09.359 - info: hue.0 (18706) skip switch: Hue ambient light sensor 5.tholddark
        2021-04-20 02:03:09.360 - info: hue.0 (18706) skip switch: Hue ambient light sensor 5.tholdoffset
        2021-04-20 02:03:09.360 - info: hue.0 (18706) skip switch: Hue ambient light sensor 5.ledindication
        2021-04-20 02:03:09.361 - info: hue.0 (18706) skip switch: Hue ambient light sensor 5.usertest
        2021-04-20 02:03:09.383 - info: hue.0 (18706) skip switch: Hue temperature sensor 5.alert
        2021-04-20 02:03:09.385 - info: hue.0 (18706) skip switch: Hue temperature sensor 5.ledindication
        2021-04-20 02:03:09.385 - info: hue.0 (18706) skip switch: Hue temperature sensor 5.usertest
        2021-04-20 02:03:09.412 - info: host.raspberrypi instance system.adapter.husq-automower.0 started with pid 18732
        2021-04-20 02:03:09.416 - info: hue.0 (18706) skip switch: EG Gang Kue sensor 1.alert
        2021-04-20 02:03:09.417 - info: hue.0 (18706) skip switch: EG Gang Kue sensor 1.sensitivity
        2021-04-20 02:03:09.418 - info: hue.0 (18706) skip switch: EG Gang Kue sensor 1.sensitivitymax
        2021-04-20 02:03:09.418 - info: hue.0 (18706) skip switch: EG Gang Kue sensor 1.ledindication
        2021-04-20 02:03:09.419 - info: hue.0 (18706) skip switch: EG Gang Kue sensor 1.usertest
        2021-04-20 02:03:09.680 - info: hue.0 (18706) skip switch: Hue ambient light sensor 6.alert
        2021-04-20 02:03:09.681 - info: hue.0 (18706) skip switch: Hue ambient light sensor 6.tholddark
        2021-04-20 02:03:09.681 - info: hue.0 (18706) skip switch: Hue ambient light sensor 6.tholdoffset
        2021-04-20 02:03:09.682 - info: hue.0 (18706) skip switch: Hue ambient light sensor 6.ledindication
        2021-04-20 02:03:09.682 - info: hue.0 (18706) skip switch: Hue ambient light sensor 6.usertest
        2021-04-20 02:03:09.685 - info: hue.0 (18706) skip switch: Hue temperature sensor 6.alert
        2021-04-20 02:03:09.686 - info: hue.0 (18706) skip switch: Hue temperature sensor 6.ledindication
        2021-04-20 02:03:09.686 - info: hue.0 (18706) skip switch: Hue temperature sensor 6.usertest
        2021-04-20 02:03:09.689 - info: hue.0 (18706) skip switch: DG Gang sensor 1.alert
        2021-04-20 02:03:09.689 - info: hue.0 (18706) skip switch: DG Gang sensor 1.sensitivity
        2021-04-20 02:03:09.690 - info: hue.0 (18706) skip switch: DG Gang sensor 1.sensitivitymax
        2021-04-20 02:03:09.691 - info: hue.0 (18706) skip switch: DG Gang sensor 1.ledindication
        2021-04-20 02:03:09.691 - info: hue.0 (18706) skip switch: DG Gang sensor 1.usertest
        2021-04-20 02:03:09.704 - info: hue.0 (18706) skip switch: Hue ambient light sensor 7.alert
        2021-04-20 02:03:09.705 - info: hue.0 (18706) skip switch: Hue ambient light sensor 7.tholddark
        2021-04-20 02:03:09.706 - info: hue.0 (18706) skip switch: Hue ambient light sensor 7.tholdoffset
        2021-04-20 02:03:09.706 - info: hue.0 (18706) skip switch: Hue ambient light sensor 7.ledindication
        2021-04-20 02:03:09.707 - info: hue.0 (18706) skip switch: Hue ambient light sensor 7.usertest
        2021-04-20 02:03:09.713 - info: hue.0 (18706) skip switch: Hue temperature sensor 7.alert
        2021-04-20 02:03:09.714 - info: hue.0 (18706) skip switch: Hue temperature sensor 7.ledindication
        2021-04-20 02:03:09.715 - info: hue.0 (18706) skip switch: Hue temperature sensor 7.usertest
        2021-04-20 02:03:09.718 - info: hue.0 (18706) skip switch: Küche sensor 1.alert
        2021-04-20 02:03:09.719 - info: hue.0 (18706) skip switch: Küche sensor 1.sensitivity
        2021-04-20 02:03:09.719 - info: hue.0 (18706) skip switch: Küche sensor 1.sensitivitymax
        2021-04-20 02:03:09.720 - info: hue.0 (18706) skip switch: Küche sensor 1.ledindication
        2021-04-20 02:03:09.721 - info: hue.0 (18706) skip switch: Küche sensor 1.usertest
        2021-04-20 02:03:09.724 - info: hue.0 (18706) skip switch: Hue ambient light sensor 8.alert
        2021-04-20 02:03:09.725 - info: hue.0 (18706) skip switch: Hue ambient light sensor 8.tholddark
        2021-04-20 02:03:09.725 - info: hue.0 (18706) skip switch: Hue ambient light sensor 8.tholdoffset
        2021-04-20 02:03:09.726 - info: hue.0 (18706) skip switch: Hue ambient light sensor 8.ledindication
        2021-04-20 02:03:09.726 - info: hue.0 (18706) skip switch: Hue ambient light sensor 8.usertest
        2021-04-20 02:03:09.729 - info: hue.0 (18706) skip switch: Hue temperature sensor 8.alert
        2021-04-20 02:03:09.730 - info: hue.0 (18706) skip switch: Hue temperature sensor 8.ledindication
        2021-04-20 02:03:09.731 - info: hue.0 (18706) skip switch: Hue temperature sensor 8.usertest
        2021-04-20 02:03:09.733 - info: hue.0 (18706) created/updated 20 sensor channels
        2021-04-20 02:03:09.772 - info: hue.0 (18706) created/updated 20 light channels
        2021-04-20 02:03:09.811 - info: hue.0 (18706) created/updated 25 groups channels
        2021-04-20 02:03:09.837 - info: hue.0 (18706) created/updated 125 scenes
        2021-04-20 02:03:09.837 - info: hue.0 (18706) creating/updating bridge device
        2021-04-20 02:03:10.447 - error: netatmo.0 (18725) netatmo.0 already running
        2021-04-20 02:03:10.451 - warn: netatmo.0 (18725) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:11.116 - error: host.raspberrypi instance system.adapter.netatmo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:11.117 - info: host.raspberrypi Restart adapter system.adapter.netatmo.0 because enabled
        2021-04-20 02:03:11.728 - info: husq-automower.0 (18732) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.husq-automower, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:12.651 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 18751
        2021-04-20 02:03:13.777 - info: husq-automower.0 (18732) Logged off.
        2021-04-20 02:03:13.859 - info: husq-automower.0 (18732) updateStatus mower object is NULL
        2021-04-20 02:03:14.147 - info: husq-automower.0 (18732) Logged on. Checking for mowers.
        2021-04-20 02:03:14.190 - error: node-red.0 (18751) node-red.0 already running
        2021-04-20 02:03:14.193 - warn: node-red.0 (18751) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:14.392 - info: husq-automower.0 (18732) connected, mowersListUpdated, found 2 mower(s)
        2021-04-20 02:03:14.606 - warn: husq-automower.0 (18732) updateStatus, result.operatingMode === HOME
        2021-04-20 02:03:14.779 - info: husq-automower.0 (18732) createSubscriberAsync, idRainSensor; stop due rain not enabled.
        2021-04-20 02:03:14.848 - error: host.raspberrypi instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:14.849 - info: host.raspberrypi Restart adapter system.adapter.node-red.0 because enabled
        2021-04-20 02:03:16.564 - info: host.raspberrypi instance system.adapter.nuki.0 started with pid 18762
        2021-04-20 02:03:18.385 - error: nuki.0 (18762) nuki.0 already running
        2021-04-20 02:03:18.388 - warn: nuki.0 (18762) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:19.036 - error: host.raspberrypi instance system.adapter.nuki.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:19.036 - info: host.raspberrypi Restart adapter system.adapter.nuki.0 because enabled
        2021-04-20 02:03:20.992 - info: host.raspberrypi instance system.adapter.ping.0 started with pid 18773
        2021-04-20 02:03:22.115 - error: ping.0 (18773) ping.0 already running
        2021-04-20 02:03:22.118 - warn: ping.0 (18773) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:22.763 - error: host.raspberrypi instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:22.764 - info: host.raspberrypi Restart adapter system.adapter.ping.0 because enabled
        2021-04-20 02:03:23.884 - info: host.raspberrypi instance system.adapter.info.0 started with pid 18784
        2021-04-20 02:03:24.692 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 18799
        2021-04-20 02:03:26.037 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 18814
        2021-04-20 02:03:26.073 - error: pushover.0 (18799) pushover.0 already running
        2021-04-20 02:03:26.078 - warn: pushover.0 (18799) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:26.901 - error: host.raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:26.902 - info: host.raspberrypi Restart adapter system.adapter.pushover.0 because enabled
        2021-04-20 02:03:27.175 - info: info.0 (18784) starting. Version 1.7.15 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:28.505 - info: info.0 (18784) Reading CPU current speed every 3 seconds.
        2021-04-20 02:03:28.513 - info: info.0 (18784) Reading CPU data every 3 seconds.
        2021-04-20 02:03:28.762 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 19039
        2021-04-20 02:03:29.034 - info: iot.0 (18814) starting. Version 1.8.13 in /opt/iobroker/node_modules/iobroker.iot, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:29.140 - info: iot.0 (18814) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
        2021-04-20 02:03:28.671 - info: info.0 (18784) Reading disk data every 8 seconds.
        2021-04-20 02:03:29.419 - info: info.0 (18784) Reading user data every 8 seconds.
        2021-04-20 02:03:29.679 - info: info.0 (18784) Reading memory data every 3 seconds.
        2021-04-20 02:03:29.827 - info: info.0 (18784) Reading battery data every 8 seconds.
        2021-04-20 02:03:29.832 - info: info.0 (18784) Reading CPU temp data every 3 seconds.
        2021-04-20 02:03:29.929 - info: info.0 (18784) Reading process data every 8 seconds.
        2021-04-20 02:03:30.833 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 19335
        2021-04-20 02:03:31.315 - error: rpi2.0 (19039) rpi2.0 already running
        2021-04-20 02:03:31.318 - warn: rpi2.0 (19039) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:31.678 - info: iot.0 (18814) Connection changed: connect
        2021-04-20 02:03:32.067 - error: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:32.068 - info: host.raspberrypi Restart adapter system.adapter.rpi2.0 because enabled
        2021-04-20 02:03:32.660 - info: host.raspberrypi instance system.adapter.rssfeed.0 started with pid 19342
        2021-04-20 02:03:34.108 - info: host.raspberrypi instance system.adapter.meross.0 started with pid 19359
        2021-04-20 02:03:34.233 - info: javascript.0 (19335) starting. Version 5.1.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:34.290 - info: javascript.0 (19335) npm install axios --production (System call)
        2021-04-20 02:03:34.465 - error: rssfeed.0 (19342) rssfeed.0 already running
        2021-04-20 02:03:34.468 - warn: rssfeed.0 (19342) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:34.996 - error: rssfeed.0 (19342) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-04-20 02:03:34.997 - error: rssfeed.0 (19342) unhandled promise rejection: Cannot read property 'debug' of undefined
        2021-04-20 02:03:35.000 - error: rssfeed.0 (19342) TypeError: Cannot read property 'debug' of undefined
        at RssFeed.onUnload (/opt/iobroker/node_modules/iobroker.rssfeed/main.js:65:22)
        at RssFeed.emit (events.js:314:20)
        at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
        at Object.onceWrapper (events.js:421:26)
        at process.emit (events.js:314:20)
        at process.exit (internal/process/per_thread.js:168:15)
        at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
        at processTicksAndRejections (internal/process/task_queues.js:97:5)
        2021-04-20 02:03:35.001 - error: rssfeed.0 (19342) Cannot read property 'debug' of undefined
        2021-04-20 02:03:35.189 - error: host.raspberrypi instance system.adapter.rssfeed.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:35.189 - info: host.raspberrypi Restart adapter system.adapter.rssfeed.0 because enabled
        2021-04-20 02:03:36.568 - info: host.raspberrypi instance system.adapter.samsung.0 started with pid 19399
        2021-04-20 02:03:36.878 - info: meross.0 (19359) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.meross, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:36.962 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 19413
        2021-04-20 02:03:37.526 - info: meross.0 (19359) Device 2007084978541790818648e1e92385e1 initialized
        2021-04-20 02:03:37.885 - info: meross.0 (19359) Device 1909277151525990803048e1e952e718 initialized
        2021-04-20 02:03:38.113 - info: meross.0 (19359) Device: 2007084978541790818648e1e92385e1 connected
        2021-04-20 02:03:38.128 - info: meross.0 (19359) Device: 1909277151525990803048e1e952e718 connected
        2021-04-20 02:03:40.034 - error: samsung.0 (19399) samsung.0 already running
        2021-04-20 02:03:40.037 - warn: samsung.0 (19399) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:40.239 - info: meross.0 (19359) Devices initialized
        2021-04-20 02:03:40.780 - info: host.raspberrypi instance system.adapter.sayit.0 started with pid 19581
        2021-04-20 02:03:40.928 - error: host.raspberrypi instance system.adapter.samsung.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:40.929 - info: host.raspberrypi Restart adapter system.adapter.samsung.0 because enabled
        2021-04-20 02:03:40.943 - info: mqtt.0 (19413) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.mqtt, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:41.489 - info: host.raspberrypi instance system.adapter.netatmo.0 started with pid 19592
        2021-04-20 02:03:43.288 - error: sayit.0 (19581) sayit.0 already running
        2021-04-20 02:03:43.293 - warn: sayit.0 (19581) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:43.618 - info: mqtt.0 (19413) Starting MQTT server on 0.0.0.0:1883
        2021-04-20 02:03:43.967 - error: host.raspberrypi instance system.adapter.sayit.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:43.968 - info: host.raspberrypi Restart adapter system.adapter.sayit.0 because enabled
        2021-04-20 02:03:45.246 - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 19614
        2021-04-20 02:03:45.276 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 19620
        2021-04-20 02:03:45.585 - info: netatmo.0 (19592) starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.netatmo, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:47.342 - error: simple-api.0 (19614) simple-api.0 already running
        2021-04-20 02:03:47.346 - warn: simple-api.0 (19614) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:47.668 - info: node-red.0 (19620) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:48.417 - error: host.raspberrypi instance system.adapter.simple-api.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:48.417 - info: host.raspberrypi Restart adapter system.adapter.simple-api.0 because enabled
        2021-04-20 02:03:48.724 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 19798
        2021-04-20 02:03:49.139 - info: host.raspberrypi instance system.adapter.nuki.0 started with pid 19805
        2021-04-20 02:03:49.739 - info: node-red.0 (19620) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
        2021-04-20 02:03:51.663 - error: sonos.0 (19798) sonos.0 already running
        2021-04-20 02:03:51.667 - warn: sonos.0 (19798) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:03:52.125 - info: nuki.0 (19805) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.nuki, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:52.333 - error: host.raspberrypi instance system.adapter.sonos.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:03:52.333 - info: host.raspberrypi Restart adapter system.adapter.sonos.0 because enabled
        2021-04-20 02:03:52.815 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 19837
        2021-04-20 02:03:52.843 - info: host.raspberrypi instance system.adapter.ping.0 started with pid 19843
        2021-04-20 02:03:55.297 - info: nuki.0 (19805) Bridge Info requested: http://192.168.1.11:8080/info?ts=2021-04-20T00:03:55Z&rnr=1461&hash=4874f8c02e68cf7aee191211d3ed37a4c0ac97c43902d7604a218817e70fa75f
        2021-04-20 02:03:56.089 - info: ping.0 (19843) starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.ping, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:03:56.670 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 20017
        2021-04-20 02:03:57.494 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 20026
        2021-04-20 02:03:58.284 - info: nuki.0 (19805) Lock list requested: http://192.168.1.11:8080/list?ts=2021-04-20T00:03:58Z&rnr=53629&hash=5874aa417e47f8a0c6d0bcd00eba91cd46cf4c755b13124dca68ae8d0d1a6e82
        2021-04-20 02:04:00.716 - info: host.raspberrypi instance system.adapter.trashschedule.0 started with pid 20043
        2021-04-20 02:04:01.268 - info: nuki.0 (19805) Server listening to http://192.168.1.79:9092
        2021-04-20 02:04:01.302 - info: pushover.0 (20026) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.pushover, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:02.129 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 20091
        2021-04-20 02:04:02.143 - error: text2command.0 (20017) text2command.0 already running
        2021-04-20 02:04:02.148 - warn: text2command.0 (20017) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:02.340 - error: trashschedule.0 (20043) trashschedule.0 already running
        2021-04-20 02:04:02.343 - warn: trashschedule.0 (20043) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:02.864 - error: host.raspberrypi instance system.adapter.text2command.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:02.865 - info: host.raspberrypi Restart adapter system.adapter.text2command.0 because enabled
        2021-04-20 02:04:03.015 - error: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:03.015 - info: host.raspberrypi Restart adapter system.adapter.trashschedule.0 because enabled
        2021-04-20 02:04:04.363 - info: nuki.0 (19805) Callback successfully set: http://192.168.1.79:9092/api/nuki.0
        2021-04-20 02:04:06.913 - info: host.raspberrypi instance system.adapter.rssfeed.0 started with pid 20261
        2021-04-20 02:04:07.788 - info: host.raspberrypi instance system.adapter.vis-inventwo.0 started with pid 20273
        2021-04-20 02:04:08.196 - error: telegram.0 (19837) telegram.0 already running
        2021-04-20 02:04:08.199 - warn: telegram.0 (19837) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:08.593 - info: rpi2.0 (20091) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:10.703 - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:11.523 - info: javascript.0 (19335) + axios@0.21.1
        added 85 packages from 129 contributors and audited 647 packages in 34.93s
        2021-04-20 02:04:10.703 - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
        2021-04-20 02:04:10.970 - info: host.raspberrypi instance system.adapter.samsung.0 started with pid 20412
        2021-04-20 02:04:13.617 - info: javascript.0 (19335)
        6 packages are looking for funding
        run `npm fund` for details
        2021-04-20 02:04:13.619 - info: javascript.0 (19335) found 0 vulnerabilities
        2021-04-20 02:04:13.812 - info: javascript.0 (19335) requesting all states
        2021-04-20 02:04:13.814 - info: javascript.0 (19335) requesting all objects
        2021-04-20 02:04:13.872 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 20508
        2021-04-20 02:04:15.848 - warn: rssfeed.0 (20261) slow connection to states DB. Still waiting ...
        2021-04-20 02:04:16.082 - warn: vis-inventwo.0 (20273) slow connection to states DB. Still waiting ...
        2021-04-20 02:04:16.439 - info: host.raspberrypi instance system.adapter.web.0 started with pid 20522
        2021-04-20 02:04:16.606 - info: host.raspberrypi instance system.adapter.sayit.0 started with pid 20529
        2021-04-20 02:04:16.973 - warn: samsung.0 (20412) slow connection to states DB. Still waiting ...
        2021-04-20 02:04:17.019 - info: javascript.0 (19335) received all objects
        2021-04-20 02:04:17.077 - error: vis-inventwo.0 (20273) vis-inventwo.0 already running
        2021-04-20 02:04:17.078 - warn: vis-inventwo.0 (20273) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:17.173 - info: host.raspberrypi instance system.adapter.yeelight-2.0 started with pid 20539
        2021-04-20 02:04:17.239 - info: javascript.0 (19335) received all states
        2021-04-20 02:04:21.492 - info: javascript.0 (19335) Start javascript script.js.Badezimmer.Lultfeuchte_prüfen
        2021-04-20 02:04:21.655 - info: javascript.0 (19335) script.js.Badezimmer.Lultfeuchte_prüfen: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.693 - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 20725
        2021-04-20 02:04:21.685 - info: javascript.0 (19335) Start javascript script.js.Telegram.Button_Telegram
        2021-04-20 02:04:21.694 - info: javascript.0 (19335) script.js.Telegram.Button_Telegram: registered 0 subscriptions and 0 schedules
        2021-04-20 02:04:21.695 - info: javascript.0 (19335) Start javascript script.js.Waschmaschine.Waschm_Aus
        2021-04-20 02:04:21.704 - info: javascript.0 (19335) script.js.Waschmaschine.Waschm_Aus: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.706 - info: javascript.0 (19335) Start javascript script.js.Waschmaschine.Waschm_Durchschnittsverbr
        2021-04-20 02:04:21.712 - info: javascript.0 (19335) script.js.Waschmaschine.Waschm_Durchschnittsverbr: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.713 - info: javascript.0 (19335) Start javascript script.js.Waschmaschine.Waschm_Ein
        2021-04-20 02:04:21.720 - info: javascript.0 (19335) script.js.Waschmaschine.Waschm_Ein: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.721 - info: javascript.0 (19335) Start javascript script.js.common.Badezimmerfenster_schliessen
        2021-04-20 02:04:21.728 - info: javascript.0 (19335) script.js.common.Badezimmerfenster_schliessen: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.729 - info: javascript.0 (19335) Start javascript script.js.common.Büro_Bewegung
        2021-04-20 02:04:21.734 - info: javascript.0 (19335) script.js.common.Büro_Bewegung: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.735 - info: javascript.0 (19335) Start javascript script.js.common.Büro_ein_NFC
        2021-04-20 02:04:21.741 - info: javascript.0 (19335) script.js.common.Büro_ein_NFC: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.742 - info: javascript.0 (19335) Start javascript script.js.common.Büro_verlassen
        2021-04-20 02:04:21.748 - info: javascript.0 (19335) script.js.common.Büro_verlassen: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.749 - info: javascript.0 (19335) Start javascript script.js.common.Corona_Ampel_Tabelle
        2021-04-20 02:04:21.776 - info: javascript.0 (19335) script.js.common.Corona_Ampel_Tabelle: registered 2 subscriptions and 1 schedule
        2021-04-20 02:04:21.777 - info: javascript.0 (19335) Start javascript script.js.common.Corona_Bericht
        2021-04-20 02:04:21.785 - info: javascript.0 (19335) script.js.common.Corona_Bericht: registered 0 subscriptions and 1 schedule
        2021-04-20 02:04:21.786 - info: javascript.0 (19335) Start javascript script.js.common.Dimmer_T1
        2021-04-20 02:04:21.792 - info: javascript.0 (19335) script.js.common.Dimmer_T1: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.793 - info: javascript.0 (19335) Start javascript script.js.common.Dimmer_T4
        2021-04-20 02:04:21.804 - info: javascript.0 (19335) script.js.common.Dimmer_T4: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.806 - info: javascript.0 (19335) Start javascript script.js.common.Garten_Sicherheit_Abschaltung
        2021-04-20 02:04:21.814 - info: javascript.0 (19335) script.js.common.Garten_Sicherheit_Abschaltung: registered 1 subscription and 1 schedule
        2021-04-20 02:04:21.815 - info: javascript.0 (19335) Start javascript script.js.common.Garten_Strahler
        2021-04-20 02:04:21.821 - info: javascript.0 (19335) script.js.common.Garten_Strahler: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.822 - info: javascript.0 (19335) Start javascript script.js.common.Hahn_Strahler
        2021-04-20 02:04:21.848 - info: javascript.0 (19335) script.js.common.Hahn_Strahler: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.851 - info: javascript.0 (19335) Start javascript script.js.common.Heizraum_Notlicht
        2021-04-20 02:04:21.862 - info: javascript.0 (19335) script.js.common.Heizraum_Notlicht: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.863 - info: javascript.0 (19335) Start javascript script.js.common.Küche_CO2_zu_hoch
        2021-04-20 02:04:21.875 - info: javascript.0 (19335) script.js.common.Küche_CO2_zu_hoch: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.876 - info: javascript.0 (19335) Start javascript script.js.common.Rasenroboter_Startet
        2021-04-20 02:04:21.881 - info: javascript.0 (19335) script.js.common.Rasenroboter_Startet: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.882 - info: javascript.0 (19335) Start javascript script.js.common.Regenabfrage
        2021-04-20 02:04:21.904 - info: javascript.0 (19335) script.js.common.Regenabfrage: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.905 - info: javascript.0 (19335) Start javascript script.js.common.Schlafz_Fernsehlicht
        2021-04-20 02:04:21.911 - info: javascript.0 (19335) script.js.common.Schlafz_Fernsehlicht: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.912 - info: javascript.0 (19335) Start javascript script.js.common.Schlafzimmerfenster_schliessen
        2021-04-20 02:04:21.952 - info: javascript.0 (19335) script.js.common.Schlafzimmerfenster_schliessen: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.953 - info: javascript.0 (19335) Start javascript script.js.common.Türklingel_Trigger
        2021-04-20 02:04:21.966 - info: javascript.0 (19335) script.js.common.Türklingel_Trigger: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.967 - info: javascript.0 (19335) Start javascript script.js.common.WC_Klopapier
        2021-04-20 02:04:21.972 - info: javascript.0 (19335) script.js.common.WC_Klopapier: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.973 - info: javascript.0 (19335) Start javascript script.js.common.Zustand_Kellerschloss
        2021-04-20 02:04:21.978 - info: javascript.0 (19335) script.js.common.Zustand_Kellerschloss: registered 1 subscription and 0 schedules
        2021-04-20 02:04:21.979 - info: javascript.0 (19335) Start javascript script.js.kamera_scripte.Auslöser
        2021-04-20 02:04:22.055 - info: javascript.0 (19335) script.js.kamera_scripte.Auslöser: registered 1 subscription and 0 schedules
        2021-04-20 02:04:22.056 - info: javascript.0 (19335) Start javascript script.js.kamera_scripte.Hole_noch_ein_Bild
        2021-04-20 02:04:22.062 - info: javascript.0 (19335) script.js.kamera_scripte.Hole_noch_ein_Bild: registered 1 subscription and 0 schedules
        2021-04-20 02:04:22.091 - info: javascript.0 (19335) Start javascript script.js.kamera_scripte.Tastatur_Telegram
        2021-04-20 02:04:22.097 - info: javascript.0 (19335) script.js.kamera_scripte.Tastatur_Telegram: registered 0 subscriptions and 0 schedules
        2021-04-20 02:04:22.098 - info: javascript.0 (19335) Start javascript script.js.common.Müllabfuhr_Meldung
        2021-04-20 02:04:22.157 - info: javascript.0 (19335) script.js.common.Müllabfuhr_Meldung: registered 0 subscriptions and 2 schedules
        2021-04-20 02:04:22.158 - info: javascript.0 (19335) Start javascript script.js.common.TelefonMonitor
        2021-04-20 02:04:22.163 - info: javascript.0 (19335) script.js.common.TelefonMonitor: registered 1 subscription and 0 schedules
        2021-04-20 02:04:22.164 - info: javascript.0 (19335) Start javascript script.js.common.TelefonFestnetzPushover
        2021-04-20 02:04:22.170 - info: javascript.0 (19335) script.js.common.TelefonFestnetzPushover: registered 1 subscription and 0 schedules
        2021-04-20 02:04:22.203 - info: javascript.0 (19335) Start javascript script.js.common.AnzeigeGeräte_aktualisieren
        2021-04-20 02:04:22.210 - info: javascript.0 (19335) script.js.common.AnzeigeGeräte_aktualisieren: registered 0 subscriptions and 1 schedule
        2021-04-20 02:04:22.210 - info: javascript.0 (19335) Start javascript script.js.common.Corona_Insidenz
        2021-04-20 02:04:22.396 - info: javascript.0 (19335) script.js.common.Corona_Insidenz: registered 1 subscription and 1 schedule
        2021-04-20 02:04:22.396 - info: javascript.0 (19335) Start javascript script.js.common.Müllabfuhr_Kalender
        2021-04-20 02:04:22.422 - info: javascript.0 (19335) script.js.common.Müllabfuhr_Kalender: registered 0 subscriptions and 1 schedule
        2021-04-20 02:04:22.433 - info: javascript.0 (19335) Start javascript script.js.common.Wohnzimmer_Zufall_Licht
        2021-04-20 02:04:22.442 - info: javascript.0 (19335) script.js.common.Wohnzimmer_Zufall_Licht: registered 0 subscriptions and 1 schedule
        2021-04-20 02:04:22.453 - info: javascript.0 (19335) Start javascript script.js.common.Wohnzimmer_ausschalten
        2021-04-20 02:04:22.459 - info: javascript.0 (19335) script.js.common.Wohnzimmer_ausschalten: registered 1 subscription and 0 schedules
        2021-04-20 02:04:22.460 - info: javascript.0 (19335) Start javascript script.js.common.Regen-Schnee_Ansage
        2021-04-20 02:04:22.466 - info: javascript.0 (19335) script.js.common.Regen-Schnee_Ansage: registered 1 subscription and 0 schedules
        2021-04-20 02:04:22.466 - info: javascript.0 (19335) Start javascript script.js.common.Zufahrt_Bewegung
        2021-04-20 02:04:22.472 - info: javascript.0 (19335) script.js.common.Zufahrt_Bewegung: registered 1 subscription and 0 schedules
        2021-04-20 02:04:22.473 - info: javascript.0 (19335) Start javascript script.js.common.ical_Müll-Geburtstag
        2021-04-20 02:04:22.494 - info: javascript.0 (19335) script.js.common.ical_Müll-Geburtstag: registered 2 subscriptions and 1 schedule
        2021-04-20 02:04:23.036 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 20736
        2021-04-20 02:04:23.037 - error: host.raspberrypi instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:23.038 - info: host.raspberrypi Restart adapter system.adapter.vis-inventwo.0 because enabled
        2021-04-20 02:04:24.097 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 20752
        2021-04-20 02:04:24.910 - info: vis.0 (20354) starting. Version 1.3.8 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:25.216 - error: yeelight-2.0 (20539) yeelight-2.0 already running
        2021-04-20 02:04:25.219 - warn: yeelight-2.0 (20539) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:25.254 - error: web.0 (20522) web.0 already running
        2021-04-20 02:04:25.260 - warn: web.0 (20522) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:25.341 - info: host.raspberrypi instance system.adapter.zwave2.0 started with pid 20767
        2021-04-20 02:04:25.401 - info: vis.0 (20354) vis license is OK.
        2021-04-20 02:04:26.369 - error: host.raspberrypi instance system.adapter.yeelight-2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:26.372 - info: host.raspberrypi Restart adapter system.adapter.yeelight-2.0 because enabled
        2021-04-20 02:04:26.677 - error: host.raspberrypi instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:26.677 - info: host.raspberrypi Restart adapter system.adapter.web.0 because enabled
        2021-04-20 02:04:27.176 - info: samsung.0 (20412) starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.samsung, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:27.779 - info: rssfeed.0 (20261) starting. Version 0.0.30 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:27.782 - error: tr-064.0 (20736) tr-064.0 already running
        2021-04-20 02:04:27.786 - warn: tr-064.0 (20736) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:29.202 - info: host.raspberrypi instance system.adapter.mytime.0 started with pid 20962
        2021-04-20 02:04:29.262 - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:29.263 - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
        2021-04-20 02:04:30.182 - info: telegram.0 (20508) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:30.433 - info: simple-api.0 (20725) starting. Version 2.5.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:30.493 - info: simple-api.0 (20725) simpleAPI server listening on port 8087
        2021-04-20 02:04:30.494 - info: simple-api.0 (20725) Allow states only when user is owner: false
        2021-04-20 02:04:30.515 - info: simple-api.0 (20725) http server listening on port 8087
        2021-04-20 02:04:31.505 - info: sonos.0 (20752) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.sonos, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:31.666 - info: sayit.0 (20529) starting. Version 1.12.2 in /opt/iobroker/node_modules/iobroker.sayit, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:31.730 - info: sayit.0 (20529) Upload announce mp3 files
        2021-04-20 02:04:32.146 - info: sayit.0 (20529) All files uploaded
        2021-04-20 02:04:32.214 - info: vis.0 (20354) Terminated (NO_ERROR): Without reason
        2021-04-20 02:04:32.229 - error: mytime.0 (20962) mytime.0 already running
        2021-04-20 02:04:32.232 - warn: mytime.0 (20962) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:32.887 - info: host.raspberrypi instance system.adapter.tvprogram.0 started with pid 21000
        2021-04-20 02:04:32.960 - error: mytime.0 (20962) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-04-20 02:04:32.963 - error: mytime.0 (20962) unhandled promise rejection: Cannot read property 'debug' of undefined
        2021-04-20 02:04:32.966 - error: mytime.0 (20962) TypeError: Cannot read property 'debug' of undefined
        at Mytime.onUnload (/opt/iobroker/node_modules/iobroker.mytime/main.js:64:22)
        at Mytime.emit (events.js:314:20)
        2021-04-20 02:04:32.967 - error: mytime.0 (20962) Cannot read property 'debug' of undefined
        2021-04-20 02:04:32.995 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 21008
        2021-04-20 02:04:33.403 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
        2021-04-20 02:04:33.838 - warn: node-red.0 (19620) 20 Apr 02:04:33 - [warn] Projekte inaktiviert: editorTheme.projects.enabled=false
        2021-04-20 02:04:33.910 - warn: node-red.0 (19812) slow connection to objects DB. Still waiting ...
        2021-04-20 02:04:34.379 - error: host.raspberrypi instance system.adapter.mytime.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:34.380 - info: host.raspberrypi Restart adapter system.adapter.mytime.0 because enabled
        2021-04-20 02:04:34.496 - info: host.raspberrypi instance system.adapter.trashschedule.0 started with pid 21053
        2021-04-20 02:04:35.250 - error: zwave2.0 (20767) zwave2.0 already running
        2021-04-20 02:04:35.255 - warn: zwave2.0 (20767) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:35.578 - info: mqtt.0 (19413) Client [mqtt_a8916896.f0bd58] connected with secret 1618877075560_6883
        2021-04-20 02:04:36.092 - error: host.raspberrypi instance system.adapter.zwave2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:36.092 - info: host.raspberrypi Restart adapter system.adapter.zwave2.0 because enabled
        2021-04-20 02:04:36.257 - error: tvprogram.0 (21000) tvprogram.0 already running
        2021-04-20 02:04:36.261 - warn: tvprogram.0 (21000) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:36.549 - info: mqtt.0 (19413) Client [mqtt_a8916896.f0bd58] subscribes on topic "test"
        2021-04-20 02:04:36.632 - info: host.raspberrypi instance system.adapter.lgtv.0 started with pid 21205
        2021-04-20 02:04:37.115 - error: tvprogram.0 (21000) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-04-20 02:04:37.117 - error: tvprogram.0 (21000) unhandled promise rejection: Cannot read property 'debug' of undefined
        2021-04-20 02:04:37.120 - error: tvprogram.0 (21000) TypeError: Cannot read property 'debug' of undefined
        at Tvprogram.onUnload (/opt/iobroker/node_modules/iobroker.tvprogram/main.js:66:22)
        at Tvprogram.emit (events.js:314:20)
        2021-04-20 02:04:37.121 - error: tvprogram.0 (21000) Cannot read property 'debug' of undefined
        2021-04-20 02:04:37.388 - error: host.raspberrypi instance system.adapter.tvprogram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:37.388 - info: host.raspberrypi Restart adapter system.adapter.tvprogram.0 because enabled
        2021-04-20 02:04:38.575 - info: text2command.0 (21008) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.text2command, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:38.805 - error: lgtv.0 (21205) lgtv.0 already running
        2021-04-20 02:04:38.809 - warn: lgtv.0 (21205) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:39.340 - warn: lgtv.0 (21205) redis get lgtv.0.info.connection, error - Connection is closed.
        2021-04-20 02:04:39.353 - error: lgtv.0 (21205) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-04-20 02:04:39.354 - error: lgtv.0 (21205) unhandled promise rejection: Cannot read property 'debug' of undefined
        2021-04-20 02:04:39.357 - error: lgtv.0 (21205) TypeError: Cannot read property 'debug' of undefined
        at checkCurApp (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:517:17)
        at checkConnection (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:504:13)
        at Object.unload (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:336:13)
        at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8607:29)
        2021-04-20 02:04:39.358 - error: lgtv.0 (21205) Cannot read property 'debug' of undefined
        2021-04-20 02:04:39.366 - error: lgtv.0 (21205) Cannot check object existence of "lgtv.0.info.connection": Connection is closed.
        2021-04-20 02:04:39.367 - warn: lgtv.0 (21205) Could not check object existence of state lgtv.0.info.connection: Cannot check object existence of "lgtv.0.info.connection": Connection is closed.
        2021-04-20 02:04:39.369 - warn: lgtv.0 (21205) get state error: Connection is closed.
        2021-04-20 02:04:39.544 - error: host.raspberrypi instance system.adapter.lgtv.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:39.544 - info: host.raspberrypi Restart adapter system.adapter.lgtv.0 because enabled
        2021-04-20 02:04:39.652 - info: trashschedule.0 (21053) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:39.811 - warn: trashschedule.0 (21053) no events matches type "Verpackung" with match "Verp". Check configuration of iCal (increase preview) and trashschedule!
        2021-04-20 02:04:40.543 - info: host.raspberrypi instance scheduled system.adapter.daswetter.0 */15 * * * *
        2021-04-20 02:04:44.593 - info: host.raspberrypi instance system.adapter.ring.0 started with pid 21397
        2021-04-20 02:04:48.162 - error: ring.0 (21397) ring.0 already running
        2021-04-20 02:04:48.165 - warn: ring.0 (21397) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:04:48.851 - error: host.raspberrypi instance system.adapter.ring.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2021-04-20 02:04:48.851 - info: host.raspberrypi Restart adapter system.adapter.ring.0 because enabled
        2021-04-20 02:04:53.088 - info: host.raspberrypi instance system.adapter.vis-inventwo.0 started with pid 21582
        2021-04-20 02:04:54.784 - info: vis-inventwo.0 (21582) starting. Version 2.9.2 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:56.432 - info: host.raspberrypi instance system.adapter.yeelight-2.0 started with pid 21601
        2021-04-20 02:04:56.734 - info: host.raspberrypi instance system.adapter.web.0 started with pid 21611
        2021-04-20 02:04:58.986 - info: yeelight-2.0 (21601) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:04:59.302 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 21799
        2021-04-20 02:05:00.393 - info: host.raspberrypi instance system.adapter.ical.1 started with pid 21809
        2021-04-20 02:05:00.717 - info: web.0 (21611) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:05:01.303 - info: web.0 (21611) socket.io server listening on port 8082
        2021-04-20 02:05:01.309 - info: web.0 (21611) http server listening on port 8082
        2021-04-20 02:05:02.410 - info: tr-064.0 (21799) starting. Version 4.2.11 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:05:03.154 - info: ical.1 (21809) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:05:04.429 - info: host.raspberrypi instance system.adapter.mytime.0 started with pid 21839
        2021-04-20 02:05:04.713 - info: ical.1 (21809) processing URL: Geburtstage http://p25-caldav.icloud.com/published/2/AAAAAAAAAAAAAAAAAAAAAJJnnvDTY6VFWIFDivW_83qBfJz6Q9qd1_Fi2SjnBDo3cLQ4C70Zpg2NxyfyyFGvl1659y2agUpqE7IXc_EB7R0
        2021-04-20 02:05:06.133 - info: host.raspberrypi instance system.adapter.zwave2.0 started with pid 21884
        2021-04-20 02:05:06.495 - info: mytime.0 (21839) starting. Version 0.6.1 in /opt/iobroker/node_modules/iobroker.mytime, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:05:06.642 - info: mytime.0 (21839) state mytime.0.info.connection changed: false (ack = true)
        2021-04-20 02:05:06.647 - info: mytime.0 (21839) state mytime.0.info.connection changed: true (ack = true)
        2021-04-20 02:05:06.669 - info: mytime.0 (21839) state mytime.0.Countdown.Test.name changed: Test (ack = true)
        2021-04-20 02:05:06.674 - info: mytime.0 (21839) state mytime.0.Countdown.Test.config changed: {"stopbehaviour":"timer"} (ack = true)
        2021-04-20 02:05:06.678 - info: mytime.0 (21839) state mytime.0.Countdown.Test.end changed: 0 (ack = true)
        2021-04-20 02:05:06.687 - info: mytime.0 (21839) state mytime.0.Countdown.Test.timer changed: 300000 (ack = true)
        2021-04-20 02:05:06.697 - info: mytime.0 (21839) state mytime.0.Countdown.Test.action changed: stop (ack = true)
        2021-04-20 02:05:06.699 - info: mytime.0 (21839) state mytime.0.Countdown.Test.start changed: 0 (ack = true)
        2021-04-20 02:05:06.711 - info: mytime.0 (21839) state mytime.0.Countdown.Test.cmd changed: (ack = true)
        2021-04-20 02:05:07.416 - info: host.raspberrypi instance system.adapter.tvprogram.0 started with pid 22036
        2021-04-20 02:05:09.542 - info: tvprogram.0 (22036) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tvprogram, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:05:09.584 - info: host.raspberrypi instance system.adapter.lgtv.0 started with pid 22056
        2021-04-20 02:05:10.243 - info: zwave2.0 (21884) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:05:10.572 - info: ical.1 (21809) Terminated (NO_ERROR): Without reason
        2021-04-20 02:05:12.787 - info: host.raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
        2021-04-20 02:05:16.224 - info: lgtv.0 (22056) starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.lgtv, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:05:16.255 - info: lgtv.0 (22056) Ready. Configured WebOS TV IP: 192.168.1.12
        2021-04-20 02:05:20.635 - info: host.raspberrypi instance system.adapter.ring.0 started with pid 22282
        2021-04-20 02:05:21.191 - info: web.0 (21611) ==>Connected system.user.admin from ::ffff:192.168.1.17
        2021-04-20 02:05:21.327 - info: zwave2.0 (21884) The driver is ready. Found 1 nodes.
        2021-04-20 02:05:21.336 - info: zwave2.0 (21884) All nodes are ready to use
        2021-04-20 02:05:21.425 - info: zwave2.0 (21884) Node 1: ready to use
        2021-04-20 02:05:24.602 - info: ring.0 (22282) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.ring, node: v12.22.1, js-controller: 3.2.16
        2021-04-20 02:05:24.673 - info: ring.0 (22282) Starting Adapter ring.0 in version 1.2.1
        2021-04-20 02:05:26.912 - info: ring.0 (22282) Starting Ring Device for Id 4242830
        2021-04-20 02:08:51.082 - info: web.0 (21611) ==>Connected system.user.admin from ::ffff:192.168.1.34
        2021-04-20 02:15:00.047 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 3313
        2021-04-20 02:15:01.465 - error: daswetter.0 (3313) daswetter.0 already running
        2021-04-20 02:15:01.469 - warn: daswetter.0 (3313) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2021-04-20 02:15:03.212 - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        @bergjet Und VOR 2 Uhr? Das ist noch interessanter.
        Auch mal kernel.log und sys.log anschauen.
        bergjetB 1 Antwort Letzte Antwort
          bergjetB Offline
          bergjetB Offline
          bergjet
          schrieb am zuletzt editiert von bergjet
          Die zeit vor 2:00
          2021-04-20 00:00:00.023 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: ZEITPLAN JETZT
          2021-04-20 00:00:00.062 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: 1620000
          2021-04-20 00:00:00.063 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: 2580000
          2021-04-20 00:00:00.123 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 9208
          2021-04-20 00:00:01.782 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 00:00:01.845 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 00:00:02.257 - info: daswetter.0 (9208) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 00:00:02.424 - info: daswetter.0 (9208) got wrong data structure! trying to repair...
          2021-04-20 00:00:04.166 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 9249
          2021-04-20 00:00:05.011 - warn: trashschedule.0 (888) no events matches type "Verpackung" with match "Verp". Check configuration of iCal (increase preview) and trashschedule!
          2021-04-20 00:00:08.101 - info: coronavirus-statistics.0 (9249) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 00:00:10.273 - info: daswetter.0 (9208) Terminated (NO_ERROR): Without reason
          2021-04-20 00:00:10.796 - info: daswetter.0 (9208) cleaned everything up...
          2021-04-20 00:00:10.816 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2021-04-20 00:00:20.402 - info: coronavirus-statistics.0 (9249) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2021-04-20 00:00:20.973 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2021-04-20 00:15:00.118 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 30009
          2021-04-20 00:15:02.338 - info: daswetter.0 (30009) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 00:15:02.514 - info: daswetter.0 (30009) got wrong data structure! trying to repair...
          2021-04-20 00:15:09.263 - info: daswetter.0 (30009) Terminated (NO_ERROR): Without reason
          2021-04-20 00:15:09.788 - info: daswetter.0 (30009) cleaned everything up...
          2021-04-20 00:15:09.805 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2021-04-20 00:27:00.064 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: ZufälliglEinschalten
          2021-04-20 00:28:13.865 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 00:28:28.738 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 00:28:28.757 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 00:30:00.101 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 18882
          2021-04-20 00:30:01.864 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 00:30:01.975 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 00:30:02.140 - info: daswetter.0 (18882) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 00:30:02.338 - info: daswetter.0 (18882) got wrong data structure! trying to repair...
          2021-04-20 00:30:04.179 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 18922
          2021-04-20 00:30:08.029 - info: coronavirus-statistics.0 (18922) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 00:30:10.323 - info: daswetter.0 (18882) Terminated (NO_ERROR): Without reason
          2021-04-20 00:30:10.855 - info: daswetter.0 (18882) cleaned everything up...
          2021-04-20 00:30:10.877 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2021-04-20 00:30:17.555 - info: coronavirus-statistics.0 (18922) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2021-04-20 00:30:18.097 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2021-04-20 00:30:29.509 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 00:30:29.539 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 00:30:29.581 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 00:30:33.549 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 00:43:00.064 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: ZufälligAusschalten
          2021-04-20 00:45:00.102 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 7696
          2021-04-20 00:45:02.334 - info: daswetter.0 (7696) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 00:45:02.693 - info: daswetter.0 (7696) got wrong data structure! trying to repair...
          2021-04-20 00:45:09.869 - info: daswetter.0 (7696) Terminated (NO_ERROR): Without reason
          2021-04-20 00:45:10.386 - info: daswetter.0 (7696) cleaned everything up...
          2021-04-20 00:45:10.401 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2021-04-20 01:00:00.122 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 28650
          2021-04-20 01:00:00.192 - warn: husq-automower.0 (30872) updateStatus, result.operatingMode === HOME
          2021-04-20 01:00:00.504 - info: web.0 (1450) <==Disconnect system.user.admin from ::ffff:192.168.1.34 vis.0
          2021-04-20 01:00:00.669 - info: web.0 (1450) <==Disconnect system.user.admin from ::ffff:192.168.1.17 vis.0
          2021-04-20 01:00:01.892 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 01:00:01.956 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 01:00:02.559 - info: daswetter.0 (28650) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 01:00:02.758 - info: daswetter.0 (28650) got wrong data structure! trying to repair...
          2021-04-20 01:00:03.432 - info: web.0 (1450) ==>Connected system.user.admin from ::ffff:192.168.1.34
          2021-04-20 01:00:04.163 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 28755
          2021-04-20 01:00:05.005 - warn: trashschedule.0 (888) no events matches type "Verpackung" with match "Verp". Check configuration of iCal (increase preview) and trashschedule!
          2021-04-20 01:00:05.166 - info: web.0 (1450) ==>Connected system.user.admin from ::ffff:192.168.1.17
          2021-04-20 01:00:08.376 - info: coronavirus-statistics.0 (28755) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 01:00:11.431 - info: daswetter.0 (28650) Terminated (NO_ERROR): Without reason
          2021-04-20 01:00:11.948 - info: daswetter.0 (28650) cleaned everything up...
          2021-04-20 01:00:11.964 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2021-04-20 01:00:16.789 - info: coronavirus-statistics.0 (28755) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2021-04-20 01:00:17.350 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2021-04-20 01:15:00.063 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 17524
          2021-04-20 01:15:02.110 - info: daswetter.0 (17524) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 01:15:02.307 - info: daswetter.0 (17524) got wrong data structure! trying to repair...
          2021-04-20 01:15:09.454 - info: daswetter.0 (17524) Terminated (NO_ERROR): Without reason
          2021-04-20 01:15:09.994 - info: daswetter.0 (17524) cleaned everything up...
          2021-04-20 01:15:10.025 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2021-04-20 01:30:00.063 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 6404
          2021-04-20 01:30:01.671 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 01:30:01.723 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 01:30:02.273 - info: daswetter.0 (6404) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 01:30:02.426 - info: daswetter.0 (6404) got wrong data structure! trying to repair...
          2021-04-20 01:30:04.130 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 6607
          2021-04-20 01:30:07.883 - info: coronavirus-statistics.0 (6607) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 01:30:10.541 - info: daswetter.0 (6404) Terminated (NO_ERROR): Without reason
          2021-04-20 01:30:11.101 - info: daswetter.0 (6404) cleaned everything up...
          2021-04-20 01:30:11.118 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2021-04-20 01:30:17.117 - info: coronavirus-statistics.0 (6607) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2021-04-20 01:30:17.668 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2021-04-20 01:45:00.082 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 27457
          2021-04-20 01:45:01.999 - info: daswetter.0 (27457) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 01:45:02.198 - info: daswetter.0 (27457) got wrong data structure! trying to repair...
          2021-04-20 01:45:09.127 - info: daswetter.0 (27457) Terminated (NO_ERROR): Without reason
          2021-04-20 01:45:09.657 - info: daswetter.0 (27457) cleaned everything up...
          2021-04-20 01:45:09.674 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2021-04-20 02:00:00.015 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: ZEITPLAN JETZT
          2021-04-20 02:00:00.024 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: 600000
          2021-04-20 02:00:00.025 - info: javascript.0 (31482) script.js.common.Wohnzimmer_Zufall_Licht: 2340000
          2021-04-20 02:00:00.118 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 16135
          2021-04-20 02:00:00.240 - warn: husq-automower.0 (30872) updateStatus, result.operatingMode === HOME
          2021-04-20 02:00:00.408 - info: web.0 (1450) <==Disconnect system.user.admin from ::ffff:192.168.1.17 vis.0
          2021-04-20 02:00:00.518 - info: web.0 (1450) <==Disconnect system.user.admin from ::ffff:192.168.1.34 vis.0
          2021-04-20 02:00:01.737 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 02:00:01.801 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 02:00:01.852 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 02:00:01.874 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 02:00:01.948 - info: homee.0 (30809) initialize 1 homeegrams
          2021-04-20 02:00:02.922 - info: daswetter.0 (16135) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 02:00:03.140 - info: daswetter.0 (16135) got wrong data structure! trying to repair...
          2021-04-20 02:00:03.538 - info: web.0 (1450) ==>Connected system.user.admin from ::ffff:192.168.1.34
          2021-04-20 02:00:04.218 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 16337
          2021-04-20 02:00:05.013 - warn: trashschedule.0 (888) no events matches type "Verpackung" with match "Verp". Check configuration of iCal (increase preview) and trashschedule!
          2021-04-20 02:00:05.105 - info: web.0 (1450) ==>Connected system.user.admin from ::ffff:192.168.1.17
          2021-04-20 02:00:08.263 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 16363
          2021-04-20 02:00:09.190 - info: coronavirus-statistics.0 (16337) starting. Version 0.7.0-4 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 02:00:11.352 - info: ical.0 (16363) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.1, js-controller: 3.2.16
          2021-04-20 02:00:19.861 - info: ical.0 (16363) processing URL: Müll http://p25-caldav.icloud.com/published/2/Mjc2ODA0MDAwMjc2ODA0MOWAQ_Hp47ycJEgYb0oET12LPeUAOwbTuiHnNWrmHF21ZilCgnWV2zu_3gFQLNJIuNKRi8FkQZJBGf2_bTAS3rjaxgj8VXAGfuiCKKkA0_sxFDWnISlJyUhyvepk5YbXXg
          2021-04-20 02:00:22.276 - warn: trashschedule.0 (888) no events matches type "Verpackung" with match "Verp". Check configuration of iCal (increase preview) and trashschedule!
          2021-04-20 02:00:29.157 - info: ical.0 (16363) Terminated (NO_ERROR): Without reason
          Wo finde ich kernel.log und sys.log?
          homee, ioBroker, iMac, iPhone, Sonos, Alaxa
          • bergjetB bergjet
            Die zeit vor 2:00
            @bergjet
            Für den heutigen Tag / das laufende Log:
            cat /var/log/kern.log
            cat /var/log/syslog
              @bergjet
              cat /var/log/syslog
              bergjetB Offline
              bergjetB Offline
              bergjet
              kernel.log
              Apr 20 02:01:23 raspberrypi kernel: [135707.349180] node invoked oom-killer: gfp_mask=0x400dc2(GFP_KERNEL_ACCOUNT|__GFP_HIGHMEM|__GFP_ZERO), order=0, oom_score_adj=0
              Apr 20 02:01:23 raspberrypi kernel: [135707.349192] CPU: 2 PID: 30402 Comm: node Tainted: G         C        5.10.17-v7l+ #1403
              Apr 20 02:01:23 raspberrypi kernel: [135707.349197] Hardware name: BCM2711
              Apr 20 02:01:23 raspberrypi kernel: [135707.349201] Backtrace:
              Apr 20 02:01:23 raspberrypi kernel: [135707.349223] [<c0b63050>] (dump_backtrace) from [<c0b633e4>] (show_stack+0x20/0x24)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349230]  r7:ffffffff r6:00000000 r5:60000113 r4:c12e69fc
              Apr 20 02:01:23 raspberrypi kernel: [135707.349239] [<c0b633c4>] (show_stack) from [<c0b67774>] (dump_stack+0xcc/0xf8)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349245] [<c0b676a8>] (dump_stack) from [<c0b65a04>] (dump_header+0x64/0x208)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349251]  r10:c120518c r9:00400dc2 r8:00000000 r7:c0e3709c r6:c7f16a00 r5:c9ffbe00
              Apr 20 02:01:23 raspberrypi kernel: [135707.349256]  r4:c7a8dde8 r3:eaf5c060
              Apr 20 02:01:23 raspberrypi kernel: [135707.349265] [<c0b659a0>] (dump_header) from [<c03b6cd0>] (oom_kill_process+0x1b4/0x1c0)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349270]  r7:c0e3709c r6:c7a8dde8 r5:c9ffc380 r4:c9ffbe00
              Apr 20 02:01:23 raspberrypi kernel: [135707.349277] [<c03b6b1c>] (oom_kill_process) from [<c03b7848>] (out_of_memory+0x2b8/0x390)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349282]  r7:c1208580 r6:c1205048 r5:c9ffbe00 r4:c7a8dde8
              Apr 20 02:01:23 raspberrypi kernel: [135707.349290] [<c03b7590>] (out_of_memory) from [<c040a8bc>] (__alloc_pages_nodemask+0x7ec/0x1184)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349296]  r7:c1336790 r6:00001400 r5:00001dec r4:00000000
              Apr 20 02:01:23 raspberrypi kernel: [135707.349304] [<c040a0d0>] (__alloc_pages_nodemask) from [<c03ec934>] (__pte_alloc+0x34/0x168)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349310]  r10:c1205048 r9:00000040 r8:00000255 r7:00000000 r6:c7eaad28 r5:c40a0200
              Apr 20 02:01:23 raspberrypi kernel: [135707.349314]  r4:34acf000
              Apr 20 02:01:23 raspberrypi kernel: [135707.349321] [<c03ec900>] (__pte_alloc) from [<c03f0068>] (handle_mm_fault+0x100c/0x1124)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349326]  r7:00000000 r6:07eaa003 r5:00000000 r4:34acf000
              Apr 20 02:01:23 raspberrypi kernel: [135707.349334] [<c03ef05c>] (handle_mm_fault) from [<c0b739d4>] (do_page_fault+0x144/0x314)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349339]  r10:00000255 r9:00000800 r8:c40a0248 r7:c40a0200 r6:00000a06 r5:34acf000
              Apr 20 02:01:23 raspberrypi kernel: [135707.349343]  r4:c7a8dfb0
              Apr 20 02:01:23 raspberrypi kernel: [135707.349349] [<c0b73890>] (do_page_fault) from [<c0b73c84>] (do_translation_fault+0xe0/0x10c)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349355]  r10:00000000 r9:b6d25258 r8:00000a06 r7:34acf000 r6:c0b73ba4 r5:00000a06
              Apr 20 02:01:23 raspberrypi kernel: [135707.349359]  r4:c120aef8
              Apr 20 02:01:23 raspberrypi kernel: [135707.349366] [<c0b73ba4>] (do_translation_fault) from [<c0214c6c>] (do_DataAbort+0x40/0xc0)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349372]  r9:b6d25258 r8:c7a8dfb0 r7:34acf000 r6:c0b73ba4 r5:00000a06 r4:c120aef8
              Apr 20 02:01:23 raspberrypi kernel: [135707.349379] [<c0214c2c>] (do_DataAbort) from [<c0200da4>] (__dabt_usr+0x44/0x60)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349383] Exception stack(0xc7a8dfb0 to 0xc7a8dff8)
              Apr 20 02:01:23 raspberrypi kernel: [135707.349388] dfa0:                                     34acf000 002f1002 00000000 34acf008
              Apr 20 02:01:23 raspberrypi kernel: [135707.349394] dfc0: b6d257d4 002f1000 0005e1a6 002f0d40 b6d25000 b6d25258 00000000 fffff000
              Apr 20 02:01:23 raspberrypi kernel: [135707.349399] dfe0: b6d2526c bef6d328 b6d25258 b6c4b8d8 40000010 ffffffff
              Apr 20 02:01:23 raspberrypi kernel: [135707.349405]  r8:30c5387d r7:30c5383d r6:ffffffff r5:40000010 r4:b6c4b8d8
              Apr 20 02:01:23 raspberrypi kernel: [135707.349409] Mem-Info:
              Apr 20 02:01:23 raspberrypi kernel: [135707.349421] active_anon:35326 inactive_anon:905949 isolated_anon:0
              Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  active_file:3396 inactive_file:3998 isolated_file:32
              Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  unevictable:4 dirty:39 writeback:0
              Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  slab_reclaimable:3544 slab_unreclaimable:5676
              Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  mapped:3307 shmem:519 pagetables:9482 bounce:0
              Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  free:6738 free_pcp:0 free_cma:0
              Apr 20 02:01:23 raspberrypi kernel: [135707.349431] Node 0 active_anon:141304kB inactive_anon:3623796kB active_file:13584kB inactive_file:15992kB unevictable:16kB isolated(anon):0kB isolated(file):128kB mapped:13228kB dirty:156kB writeback:0kB shmem:2076kB writeback_tmp:0kB kernel_stack:5072kB all_unreclaimable? no
              Apr 20 02:01:23 raspberrypi kernel: [135707.349442] DMA free:24532kB min:20480kB low:24576kB high:28672kB reserved_highatomic:0KB active_anon:1812kB inactive_anon:567188kB active_file:1012kB inactive_file:4744kB unevictable:0kB writepending:40kB present:786432kB managed:654620kB mlocked:0kB pagetables:1836kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
              Apr 20 02:01:23 raspberrypi kernel: [135707.349448] lowmem_reserve[]: 0 0 3188 0
              Apr 20 02:01:23 raspberrypi kernel: [135707.349484] HighMem free:2420kB min:62552kB low:82976kB high:103400kB reserved_highatomic:0KB active_anon:140040kB inactive_anon:3055932kB active_file:12988kB inactive_file:10932kB unevictable:16kB writepending:116kB present:3264512kB managed:3264512kB mlocked:16kB pagetables:36092kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
              Apr 20 02:01:23 raspberrypi kernel: [135707.349490] lowmem_reserve[]: 0 0 0 0
              Apr 20 02:01:23 raspberrypi kernel: [135707.349522] DMA: 209*4kB (UME) 481*8kB (UMEC) 409*16kB (UME) 194*32kB (UME) 80*64kB (UME) 16*128kB (UM) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 24604kB
              Apr 20 02:01:23 raspberrypi kernel: [135707.349625] HighMem: 148*4kB (UM) 89*8kB (UM) 25*16kB (UM) 6*32kB (UM) 20*64kB (M) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 3176kB
              Apr 20 02:01:23 raspberrypi kernel: [135707.349723] 5758 total pagecache pages
              Apr 20 02:01:23 raspberrypi kernel: [135707.349730] 175 pages in swap cache
              Apr 20 02:01:23 raspberrypi kernel: [135707.349737] Swap cache stats: add 59748, delete 59572, find 4768/8730
              Apr 20 02:01:23 raspberrypi kernel: [135707.349743] Free swap  = 0kB
              Apr 20 02:01:23 raspberrypi kernel: [135707.349749] Total swap = 102396kB
              Apr 20 02:01:23 raspberrypi kernel: [135707.349755] 1012736 pages RAM
              Apr 20 02:01:23 raspberrypi kernel: [135707.349761] 816128 pages HighMem/MovableOnly
              Apr 20 02:01:23 raspberrypi kernel: [135707.349767] 32953 pages reserved
              Apr 20 02:01:23 raspberrypi kernel: [135707.349772] 65536 pages cma reserved
              Apr 20 02:01:23 raspberrypi kernel: [135707.349779] Tasks state (memory values in pages):
              Apr 20 02:01:23 raspberrypi kernel: [135707.349785] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
              Apr 20 02:01:23 raspberrypi kernel: [135707.349799] [    122]     0   122     5310     1101   131072        1             0 systemd-journal
              Apr 20 02:01:23 raspberrypi kernel: [135707.349807] [    148]     0   148     4499      202    49152        0         -1000 systemd-udevd
              Apr 20 02:01:23 raspberrypi kernel: [135707.349818] [    298]   100   298     5604      359    61440        0             0 systemd-timesyn
              Apr 20 02:01:23 raspberrypi kernel: [135707.349825] [    336]     0   336     1987      206    45056        0             0 cron
              Apr 20 02:01:23 raspberrypi kernel: [135707.349833] [    341]   104   341     1639      176    36864        0          -900 dbus-daemon
              Apr 20 02:01:23 raspberrypi kernel: [135707.349841] [    349]   108   349     1640      432    32768        0             0 avahi-daemon
              Apr 20 02:01:23 raspberrypi kernel: [135707.349849] [    350]     0   350     2686      181    45056        0             0 wpa_supplicant
              Apr 20 02:01:23 raspberrypi kernel: [135707.349856] [    359]     0   359     6378      358    45056        4             0 rsyslogd
              Apr 20 02:01:23 raspberrypi kernel: [135707.349864] [    361] 65534   361     1080       85    32768        0             0 thd
              Apr 20 02:01:23 raspberrypi kernel: [135707.349872] [    363]     0   363     6914       90    36864        2             0 rngd
              Apr 20 02:01:23 raspberrypi kernel: [135707.349880] [    371]   108   371     1442       55    32768        8             0 avahi-daemon
              Apr 20 02:01:23 raspberrypi kernel: [135707.349888] [    373]     0   373      923       77    32768        0             0 alsactl
              Apr 20 02:01:23 raspberrypi kernel: [135707.349896] [    383]     0   383     3228      246    53248        0             0 systemd-logind
              Apr 20 02:01:23 raspberrypi kernel: [135707.349904] [    464]     0   464     2751       91    45056       79             0 wpa_supplicant
              Apr 20 02:01:23 raspberrypi kernel: [135707.349911] [    479]     0   479      535       12    28672       20             0 hciattach
              Apr 20 02:01:23 raspberrypi kernel: [135707.349919] [    482]     0   482     2384       71    40960        0             0 bluetoothd
              Apr 20 02:01:23 raspberrypi kernel: [135707.349927] [    547]     0   547      726      228    28672       60             0 dhcpcd
              Apr 20 02:01:23 raspberrypi kernel: [135707.349935] [    553]     0   553     1077       22    32768        0             0 agetty
              Apr 20 02:01:23 raspberrypi kernel: [135707.349942] [    555]     0   555     2682      150    49152        0         -1000 sshd
              Apr 20 02:01:23 raspberrypi kernel: [135707.349950] [  30402]  1001 30402   586177   549850  5492736     2877             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.349958] [  30581]  1001 30581    45284     5149   921600     9869             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.349966] [  30596]  1001 30596    38986     4701   622592     2987             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.349973] [  30618]  1001 30618    45150    10907   770048     3644             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.349981] [  30648]  1001 30648    39337     5230   643072     2828             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.349989] [  30678]  1001 30678    38834     6717   598016     1582             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.349996] [  30708]  1001 30708    39563     8011   610304        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350004] [  30738]  1001 30738    40084     9530   643072        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350011] [  30772]  1001 30772    40070     9700   557056        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350019] [  30809]  1001 30809    42845    11617   733184        2             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350026] [  30820]  1001 30820    42287    16068   643072        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350034] [  30854]  1001 30854    43537    13961   741376        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350042] [  30872]  1001 30872    40476     9257   643072        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350049] [  30929]  1001 30929    45589    15181   745472        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350057] [  30959]  1001 30959    41057    10303   704512        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350065] [  31482]  1001 31482    58032    27676  1118208        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350073] [  31502]  1001 31502    41579    10242   712704        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350080] [  31701]  1001 31701    44816    15632   856064        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350088] [  31723]  1001 31723    41736     9803   671744        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350096] [  31759]  1001 31759    38354     8109   585728        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350104] [  31935]  1001 31935    39537     8623   614400        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350111] [  31942]  1001 31942    58856    28730  1236992        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350119] [  32032]  1001 32032    40009     9640   700416        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350126] [  32154]  1001 32154    39480     8089   626688        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350134] [  32345]  1001 32345    38903     8763   610304        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350141] [  32373]  1001 32373    41231    10602   712704        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350149] [  32546]  1001 32546    39094     8941   655360        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350156] [  32651]  1001 32651    39185     7901   626688        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350164] [  32736]  1001 32736    38878     7986   602112        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350171] [    440]  1001   440    40017     9579   692224        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350179] [    659]  1001   659    39302     8485   630784        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350187] [    888]  1001   888    39670     8754   651264        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350195] [   1087]  1001  1087    38337     7372   581632        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350203] [   1443]  1001  1443    39299     8623   618496        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350211] [   1450]  1001  1450    42483    12549   688128        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350219] [   1463]  1001  1463    42582    12326   790528        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350226] [   1496]  1001  1496    38381     7868   610304        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350234] [   1681]  1001  1681    42361    11271   749568        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350241] [   1688]  1001  1688    42241    12155   741376        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350249] [   1706]  1001  1706    39041     7989   618496        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350257] [   1940]  1001  1940    47010    17102   843776        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350265] [   5108]  1001  5108    46936    17112   876544        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350273] [   7580]  1001  7580    43672    12220   716800        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350282] [  16135]  1001 16135    37555     6788   577536        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350290] [  16337]  1001 16337    40542    10018   663552        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350298] [  16363]  1001 16363    38619     8052   647168        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350305] [  16542]  1001 16542    38988    16908   806912        0             0 node
              Apr 20 02:01:23 raspberrypi kernel: [135707.350314] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=30402,uid=1001
              Apr 20 02:01:23 raspberrypi kernel: [135707.350388] Out of memory: Killed process 30402 (node) total-vm:2344708kB, anon-rss:2189760kB, file-rss:9640kB, shmem-rss:0kB, UID:1001 pgtables:5364kB oom_score_adj:0
              Apr 20 02:01:24 raspberrypi kernel: [135707.559391] oom_reaper: reaped process 30402 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
              Apr 20 13:01:56 raspberrypi kernel: [175340.649230] Bluetooth: hci0: sending frame failed (-49)
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Zone ranges:
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   Normal   empty
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Movable zone start for each node
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Early memory node ranges
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] On node 0 totalpages: 1012736
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 2304 pages used for memmap
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 0 pages reserved
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:11:CE:96 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f546770a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Memory: 3654940K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133860K reserved, 262144K cma-reserved, 3264512K highmem)
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] ftrace: allocating 33942 entries in 67 pages
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] ftrace: allocated 67 pages with 3 groups
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] rcu: Hierarchical RCU implementation.
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
              Apr 20 13:02:10 raspberrypi kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
              Apr 20 13:02:10 raspberrypi kernel: [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
              Apr 20 13:02:10 raspberrypi kernel: [    0.000034] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
              Apr 20 13:02:10 raspberrypi kernel: [    0.000098] bcm2835: system timer (irq = 25)
              Apr 20 13:02:10 raspberrypi kernel: [    0.000750] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
              Apr 20 13:02:10 raspberrypi kernel: [    0.000772] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
              Apr 20 13:02:10 raspberrypi kernel: [    0.000795] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
              Apr 20 13:02:10 raspberrypi kernel: [    0.000813] Switching to timer-based delay loop, resolution 18ns
              Apr 20 13:02:10 raspberrypi kernel: [    0.001065] Console: colour dummy device 80x30
              Apr 20 13:02:10 raspberrypi kernel: [    0.001808] printk: console [tty1] enabled
              Apr 20 13:02:10 raspberrypi kernel: [    0.001874] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
              Apr 20 13:02:10 raspberrypi kernel: [    0.001928] pid_max: default: 32768 minimum: 301
              Apr 20 13:02:10 raspberrypi kernel: [    0.002109] LSM: Security Framework initializing
              Apr 20 13:02:10 raspberrypi kernel: [    0.002306] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
              Apr 20 13:02:10 raspberrypi kernel: [    0.002352] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
              Apr 20 13:02:10 raspberrypi kernel: [    0.003929] Disabling memory control group subsystem
              Apr 20 13:02:10 raspberrypi kernel: [    0.004064] CPU: Testing write buffer coherency: ok
              Apr 20 13:02:10 raspberrypi kernel: [    0.004536] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
              Apr 20 13:02:10 raspberrypi kernel: [    0.005755] Setting up static identity map for 0x200000 - 0x20003c
              Apr 20 13:02:10 raspberrypi kernel: [    0.005970] rcu: Hierarchical SRCU implementation.
              Apr 20 13:02:10 raspberrypi kernel: [    0.006915] smp: Bringing up secondary CPUs ...
              Apr 20 13:02:10 raspberrypi kernel: [    0.008137] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
              Apr 20 13:02:10 raspberrypi kernel: [    0.009502] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
              Apr 20 13:02:10 raspberrypi kernel: [    0.010810] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
              Apr 20 13:02:10 raspberrypi kernel: [    0.010966] smp: Brought up 1 node, 4 CPUs
              Apr 20 13:02:10 raspberrypi kernel: [    0.011011] SMP: Total of 4 processors activated (432.00 BogoMIPS).
              Apr 20 13:02:10 raspberrypi kernel: [    0.011042] CPU: All CPU(s) started in HYP mode.
              Apr 20 13:02:10 raspberrypi kernel: [    0.011069] CPU: Virtualization extensions available.
              Apr 20 13:02:10 raspberrypi kernel: [    0.011910] devtmpfs: initialized
              Apr 20 13:02:10 raspberrypi kernel: [    0.025725] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
              Apr 20 13:02:10 raspberrypi kernel: [    0.025986] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
              Apr 20 13:02:10 raspberrypi kernel: [    0.026040] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
              Apr 20 13:02:10 raspberrypi kernel: [    0.033085] pinctrl core: initialized pinctrl subsystem
              Apr 20 13:02:10 raspberrypi kernel: [    0.034183] NET: Registered protocol family 16
              Apr 20 13:02:10 raspberrypi kernel: [    0.038180] DMA: preallocated 1024 KiB pool for atomic coherent allocations
              Apr 20 13:02:10 raspberrypi kernel: [    0.038964] audit: initializing netlink subsys (disabled)
              Apr 20 13:02:10 raspberrypi kernel: [    0.039250] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
              Apr 20 13:02:10 raspberrypi kernel: [    0.039809] thermal_sys: Registered thermal governor 'step_wise'
              Apr 20 13:02:10 raspberrypi kernel: [    0.040494] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
              Apr 20 13:02:10 raspberrypi kernel: [    0.040548] hw-breakpoint: maximum watchpoint size is 8 bytes.
              Apr 20 13:02:10 raspberrypi kernel: [    0.040983] Serial: AMBA PL011 UART driver
              Apr 20 13:02:10 raspberrypi kernel: [    0.072819] bcm2835-mbox fe00b880.mailbox: mailbox enabled
              Apr 20 13:02:10 raspberrypi kernel: [    0.090958] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
              Apr 20 13:02:10 raspberrypi kernel: [    0.100971] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
              Apr 20 13:02:10 raspberrypi kernel: [    0.146228] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
              Apr 20 13:02:10 raspberrypi kernel: [    0.150377] vgaarb: loaded
              Apr 20 13:02:10 raspberrypi kernel: [    0.150838] SCSI subsystem initialized
              Apr 20 13:02:10 raspberrypi kernel: [    0.151443] usbcore: registered new interface driver usbfs
              Apr 20 13:02:10 raspberrypi kernel: [    0.151532] usbcore: registered new interface driver hub
              Apr 20 13:02:10 raspberrypi kernel: [    0.151622] usbcore: registered new device driver usb
              Apr 20 13:02:10 raspberrypi kernel: [    0.151972] usb_phy_generic phy: supply vcc not found, using dummy regulator
              Apr 20 13:02:10 raspberrypi kernel: [    0.153863] clocksource: Switched to clocksource arch_sys_counter
              Apr 20 13:02:10 raspberrypi kernel: [    1.152554] VFS: Disk quotas dquot_6.6.0
              Apr 20 13:02:10 raspberrypi kernel: [    1.152679] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
              Apr 20 13:02:10 raspberrypi kernel: [    1.152860] FS-Cache: Loaded
              Apr 20 13:02:10 raspberrypi kernel: [    1.153087] CacheFiles: Loaded
              Apr 20 13:02:10 raspberrypi kernel: [    1.163453] NET: Registered protocol family 2
              Apr 20 13:02:10 raspberrypi kernel: [    1.164344] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
              Apr 20 13:02:10 raspberrypi kernel: [    1.164506] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
              Apr 20 13:02:10 raspberrypi kernel: [    1.164587] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
              Apr 20 13:02:10 raspberrypi kernel: [    1.164673] TCP: Hash tables configured (established 8192 bind 8192)
              Apr 20 13:02:10 raspberrypi kernel: [    1.164845] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
              Apr 20 13:02:10 raspberrypi kernel: [    1.164900] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
              Apr 20 13:02:10 raspberrypi kernel: [    1.165191] NET: Registered protocol family 1
              Apr 20 13:02:10 raspberrypi kernel: [    1.165911] RPC: Registered named UNIX socket transport module.
              Apr 20 13:02:10 raspberrypi kernel: [    1.165944] RPC: Registered udp transport module.
              Apr 20 13:02:10 raspberrypi kernel: [    1.165972] RPC: Registered tcp transport module.
              Apr 20 13:02:10 raspberrypi kernel: [    1.166000] RPC: Registered tcp NFSv4.1 backchannel transport module.
              Apr 20 13:02:10 raspberrypi kernel: [    1.166037] PCI: CLS 0 bytes, default 64
              Apr 20 13:02:10 raspberrypi kernel: [    1.168924] Initialise system trusted keyrings
              Apr 20 13:02:10 raspberrypi kernel: [    1.169198] workingset: timestamp_bits=14 max_order=20 bucket_order=6
              Apr 20 13:02:10 raspberrypi kernel: [    1.177760] zbud: loaded
              Apr 20 13:02:10 raspberrypi kernel: [    1.179686] FS-Cache: Netfs 'nfs' registered for caching
              Apr 20 13:02:10 raspberrypi kernel: [    1.180481] NFS: Registering the id_resolver key type
              Apr 20 13:02:10 raspberrypi kernel: [    1.180543] Key type id_resolver registered
              Apr 20 13:02:10 raspberrypi kernel: [    1.180572] Key type id_legacy registered
              Apr 20 13:02:10 raspberrypi kernel: [    1.180736] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
              Apr 20 13:02:10 raspberrypi kernel: [    1.181775] Key type asymmetric registered
              Apr 20 13:02:10 raspberrypi kernel: [    1.181807] Asymmetric key parser 'x509' registered
              Apr 20 13:02:10 raspberrypi kernel: [    1.182011] bounce: pool size: 64 pages
              Apr 20 13:02:10 raspberrypi kernel: [    1.182067] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
              Apr 20 13:02:10 raspberrypi kernel: [    1.182298] io scheduler mq-deadline registered
              Apr 20 13:02:10 raspberrypi kernel: [    1.182329] io scheduler kyber registered
              Apr 20 13:02:10 raspberrypi kernel: [    1.186772] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
              Apr 20 13:02:10 raspberrypi kernel: [    1.186824] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
              Apr 20 13:02:10 raspberrypi kernel: [    1.186926] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
              Apr 20 13:02:10 raspberrypi kernel: [    1.187036] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
              Apr 20 13:02:10 raspberrypi kernel: [    1.246001] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
              Apr 20 13:02:10 raspberrypi kernel: [    1.246381] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
              Apr 20 13:02:10 raspberrypi kernel: [    1.246419] pci_bus 0000:00: root bus resource [bus 00-ff]
              Apr 20 13:02:10 raspberrypi kernel: [    1.246454] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
              Apr 20 13:02:10 raspberrypi kernel: [    1.246563] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
              Apr 20 13:02:10 raspberrypi kernel: [    1.246821] pci 0000:00:00.0: PME# supported from D0 D3hot
              Apr 20 13:02:10 raspberrypi kernel: [    1.250318] PCI: bus0: Fast back to back transfers disabled
              Apr 20 13:02:10 raspberrypi kernel: [    1.250672] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
              Apr 20 13:02:10 raspberrypi kernel: [    1.250815] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
              Apr 20 13:02:10 raspberrypi kernel: [    1.251266] pci 0000:01:00.0: PME# supported from D0 D3cold
              Apr 20 13:02:10 raspberrypi kernel: [    1.254766] PCI: bus1: Fast back to back transfers disabled
              Apr 20 13:02:10 raspberrypi kernel: [    1.254880] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
              Apr 20 13:02:10 raspberrypi kernel: [    1.254920] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
              Apr 20 13:02:10 raspberrypi kernel: [    1.255023] pci 0000:00:00.0: PCI bridge to [bus 01]
              Apr 20 13:02:10 raspberrypi kernel: [    1.255062] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
              Apr 20 13:02:10 raspberrypi kernel: [    1.255500] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
              Apr 20 13:02:10 raspberrypi kernel: [    1.255742] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
              Apr 20 13:02:10 raspberrypi kernel: [    1.264103] iproc-rng200 fe104000.rng: hwrng registered
              Apr 20 13:02:10 raspberrypi kernel: [    1.264428] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
              Apr 20 13:02:10 raspberrypi kernel: [    1.265307] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
              Apr 20 13:02:10 raspberrypi kernel: [    1.277620] brd: module loaded
              Apr 20 13:02:10 raspberrypi kernel: [    1.289939] loop: module loaded
              Apr 20 13:02:10 raspberrypi kernel: [    1.291604] Loading iSCSI transport class v2.0-870.
              Apr 20 13:02:10 raspberrypi kernel: [    1.294134] libphy: Fixed MDIO Bus: probed
              Apr 20 13:02:10 raspberrypi kernel: [    1.295825] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
              Apr 20 13:02:10 raspberrypi kernel: [    1.313931] libphy: bcmgenet MII bus: probed
              Apr 20 13:02:10 raspberrypi kernel: [    1.394006] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
              Apr 20 13:02:10 raspberrypi kernel: [    1.395177] usbcore: registered new interface driver r8152
              Apr 20 13:02:10 raspberrypi kernel: [    1.395263] usbcore: registered new interface driver lan78xx
              Apr 20 13:02:10 raspberrypi kernel: [    1.395338] usbcore: registered new interface driver smsc95xx
              Apr 20 13:02:10 raspberrypi kernel: [    1.396962] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
              Apr 20 13:02:10 raspberrypi kernel: [    1.397141] xhci_hcd 0000:01:00.0: xHCI Host Controller
              Apr 20 13:02:10 raspberrypi kernel: [    1.397191] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
              Apr 20 13:02:10 raspberrypi kernel: [    1.400551] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
              Apr 20 13:02:10 raspberrypi kernel: [    1.401898] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
              Apr 20 13:02:10 raspberrypi kernel: [    1.401938] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
              Apr 20 13:02:10 raspberrypi kernel: [    1.401975] usb usb1: Product: xHCI Host Controller
              Apr 20 13:02:10 raspberrypi kernel: [    1.402004] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
              Apr 20 13:02:10 raspberrypi kernel: [    1.402035] usb usb1: SerialNumber: 0000:01:00.0
              Apr 20 13:02:10 raspberrypi kernel: [    1.402771] hub 1-0:1.0: USB hub found
              Apr 20 13:02:10 raspberrypi kernel: [    1.402884] hub 1-0:1.0: 1 port detected
              Apr 20 13:02:10 raspberrypi kernel: [    1.403575] xhci_hcd 0000:01:00.0: xHCI Host Controller
              Apr 20 13:02:10 raspberrypi kernel: [    1.403618] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
              Apr 20 13:02:10 raspberrypi kernel: [    1.403663] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
              Apr 20 13:02:10 raspberrypi kernel: [    1.404291] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
              Apr 20 13:02:10 raspberrypi kernel: [    1.404331] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
              Apr 20 13:02:10 raspberrypi kernel: [    1.404367] usb usb2: Product: xHCI Host Controller
              Apr 20 13:02:10 raspberrypi kernel: [    1.404396] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
              Apr 20 13:02:10 raspberrypi kernel: [    1.404427] usb usb2: SerialNumber: 0000:01:00.0
              Apr 20 13:02:10 raspberrypi kernel: [    1.405166] hub 2-0:1.0: USB hub found
              Apr 20 13:02:10 raspberrypi kernel: [    1.405260] hub 2-0:1.0: 4 ports detected
              Apr 20 13:02:10 raspberrypi kernel: [    1.406957] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
              Apr 20 13:02:10 raspberrypi kernel: [    1.407273] dwc_otg: FIQ enabled
              Apr 20 13:02:10 raspberrypi kernel: [    1.407288] dwc_otg: NAK holdoff enabled
              Apr 20 13:02:10 raspberrypi kernel: [    1.407302] dwc_otg: FIQ split-transaction FSM enabled
              Apr 20 13:02:10 raspberrypi kernel: [    1.407320] Module dwc_common_port init
              Apr 20 13:02:10 raspberrypi kernel: [    1.407779] usbcore: registered new interface driver uas
              Apr 20 13:02:10 raspberrypi kernel: [    1.407907] usbcore: registered new interface driver usb-storage
              Apr 20 13:02:10 raspberrypi kernel: [    1.408117] mousedev: PS/2 mouse device common for all mice
              Apr 20 13:02:10 raspberrypi kernel: [    1.409777] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
              Apr 20 13:02:10 raspberrypi kernel: [    1.413253] sdhci: Secure Digital Host Controller Interface driver
              Apr 20 13:02:10 raspberrypi kernel: [    1.413288] sdhci: Copyright(c) Pierre Ossman
              Apr 20 13:02:10 raspberrypi kernel: [    1.414041] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
              Apr 20 13:02:10 raspberrypi kernel: [    1.414664] sdhci-pltfm: SDHCI platform and OF driver helper
              Apr 20 13:02:10 raspberrypi kernel: [    1.418816] ledtrig-cpu: registered to indicate activity on CPUs
              Apr 20 13:02:10 raspberrypi kernel: [    1.419176] hid: raw HID events driver (C) Jiri Kosina
              Apr 20 13:02:10 raspberrypi kernel: [    1.419384] usbcore: registered new interface driver usbhid
              Apr 20 13:02:10 raspberrypi kernel: [    1.419414] usbhid: USB HID core driver
              Apr 20 13:02:10 raspberrypi kernel: [    1.425155] Initializing XFRM netlink socket
              Apr 20 13:02:10 raspberrypi kernel: [    1.425218] NET: Registered protocol family 17
              Apr 20 13:02:10 raspberrypi kernel: [    1.425349] Key type dns_resolver registered
              Apr 20 13:02:10 raspberrypi kernel: [    1.425717] Registering SWP/SWPB emulation handler
              Apr 20 13:02:10 raspberrypi kernel: [    1.425910] registered taskstats version 1
              Apr 20 13:02:10 raspberrypi kernel: [    1.425950] Loading compiled-in X.509 certificates
              Apr 20 13:02:10 raspberrypi kernel: [    1.426812] Key type ._fscrypt registered
              Apr 20 13:02:10 raspberrypi kernel: [    1.426843] Key type .fscrypt registered
              Apr 20 13:02:10 raspberrypi kernel: [    1.426871] Key type fscrypt-provisioning registered
              Apr 20 13:02:10 raspberrypi kernel: [    1.438452] uart-pl011 fe201000.serial: there is not valid maps for state default
              Apr 20 13:02:10 raspberrypi kernel: [    1.438794] uart-pl011 fe201000.serial: cts_event_workaround enabled
              Apr 20 13:02:10 raspberrypi kernel: [    1.438887] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
              Apr 20 13:02:10 raspberrypi kernel: [    1.445668] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
              Apr 20 13:02:10 raspberrypi kernel: [    1.446729] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
              Apr 20 13:02:10 raspberrypi kernel: [    1.446763] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
              Apr 20 13:02:10 raspberrypi kernel: [    1.477048] of_cfs_init
              Apr 20 13:02:10 raspberrypi kernel: [    1.477322] of_cfs_init: OK
              Apr 20 13:02:10 raspberrypi kernel: [    1.497315] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
              Apr 20 13:02:10 raspberrypi kernel: [    1.499023] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
              Apr 20 13:02:10 raspberrypi kernel: [    1.500729] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
              Apr 20 13:02:10 raspberrypi kernel: [    1.503764] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
              Apr 20 13:02:10 raspberrypi kernel: [    1.505499] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
              Apr 20 13:02:10 raspberrypi kernel: [    1.513552] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
              Apr 20 13:02:10 raspberrypi kernel: [    1.515730] Waiting for root device PARTUUID=f546770a-02...
              Apr 20 13:02:10 raspberrypi kernel: [    1.554463] random: fast init done
              Apr 20 13:02:10 raspberrypi kernel: [    1.591543] mmc1: new high speed SDIO card at address 0001
              Apr 20 13:02:10 raspberrypi kernel: [    1.621366] mmc0: new ultra high speed DDR50 SDHC card at address 0001
              Apr 20 13:02:10 raspberrypi kernel: [    1.622293] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
              Apr 20 13:02:10 raspberrypi kernel: [    1.624054]  mmcblk0: p1 p2
              Apr 20 13:02:10 raspberrypi kernel: [    1.643630] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              Apr 20 13:02:10 raspberrypi kernel: [    1.643728] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              Apr 20 13:02:10 raspberrypi kernel: [    1.648939] devtmpfs: mounted
              Apr 20 13:02:10 raspberrypi kernel: [    1.657887] Freeing unused kernel memory: 2048K
              Apr 20 13:02:10 raspberrypi kernel: [    1.704212] Run /sbin/init as init process
              Apr 20 13:02:10 raspberrypi kernel: [    1.704243]   with arguments:
              Apr 20 13:02:10 raspberrypi kernel: [    1.704258]     /sbin/init
              Apr 20 13:02:10 raspberrypi kernel: [    1.704271]   with environment:
              Apr 20 13:02:10 raspberrypi kernel: [    1.704286]     HOME=/
              Apr 20 13:02:10 raspberrypi kernel: [    1.704300]     TERM=linux
              Apr 20 13:02:10 raspberrypi kernel: [    1.763919] usb 1-1: new high-speed USB device number 2 using xhci_hcd
              Apr 20 13:02:10 raspberrypi kernel: [    1.956771] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
              Apr 20 13:02:10 raspberrypi kernel: [    1.956820] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
              Apr 20 13:02:10 raspberrypi kernel: [    1.956854] usb 1-1: Product: USB2.0 Hub
              Apr 20 13:02:10 raspberrypi kernel: [    1.959352] hub 1-1:1.0: USB hub found
              Apr 20 13:02:10 raspberrypi kernel: [    1.959659] hub 1-1:1.0: 4 ports detected
              Apr 20 13:02:10 raspberrypi kernel: [    2.211568] NET: Registered protocol family 10
              Apr 20 13:02:10 raspberrypi kernel: [    2.212992] Segment Routing with IPv6
              Apr 20 13:02:10 raspberrypi kernel: [    2.293919] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
              Apr 20 13:02:10 raspberrypi kernel: [    2.431120] usb 1-1.4: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
              Apr 20 13:02:10 raspberrypi kernel: [    2.431175] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
              Apr 20 13:02:10 raspberrypi kernel: [    2.988872] random: systemd: uninitialized urandom read (16 bytes read)
              Apr 20 13:02:10 raspberrypi kernel: [    2.999027] random: systemd: uninitialized urandom read (16 bytes read)
              Apr 20 13:02:10 raspberrypi kernel: [    3.000962] random: systemd: uninitialized urandom read (16 bytes read)
              Apr 20 13:02:10 raspberrypi kernel: [    3.635553] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              Apr 20 13:02:10 raspberrypi kernel: [    4.292517] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
              Apr 20 13:02:10 raspberrypi kernel: [    4.309745] mc: Linux media interface: v0.10
              Apr 20 13:02:10 raspberrypi kernel: [    4.314982] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
              Apr 20 13:02:10 raspberrypi kernel: [    4.322646] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
              Apr 20 13:02:10 raspberrypi kernel: [    4.332521] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
              Apr 20 13:02:10 raspberrypi kernel: [    4.338136] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
              Apr 20 13:02:10 raspberrypi kernel: [    4.340781] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
              Apr 20 13:02:10 raspberrypi kernel: [    4.340807] [vc_sm_connected_init]: start
              Apr 20 13:02:10 raspberrypi kernel: [    4.351493] [vc_sm_connected_init]: installed successfully
              Apr 20 13:02:10 raspberrypi kernel: [    4.353460] videodev: Linux video capture interface: v2.00
              Apr 20 13:02:10 raspberrypi kernel: [    4.376442] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
              Apr 20 13:02:10 raspberrypi kernel: [    4.404170] bcm2835_audio bcm2835_audio: card created with 8 channels
              Apr 20 13:02:10 raspberrypi kernel: [    4.412571] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
              Apr 20 13:02:10 raspberrypi kernel: [    4.429220] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
              Apr 20 13:02:10 raspberrypi kernel: [    4.432063] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
              Apr 20 13:02:10 raspberrypi kernel: [    4.445830] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
              Apr 20 13:02:10 raspberrypi kernel: [    4.460476] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
              Apr 20 13:02:10 raspberrypi kernel: [    4.461158] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
              Apr 20 13:02:10 raspberrypi kernel: [    4.461994] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
              Apr 20 13:02:10 raspberrypi kernel: [    4.462528] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
              Apr 20 13:02:10 raspberrypi kernel: [    4.462556] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
              Apr 20 13:02:10 raspberrypi kernel: [    4.462580] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
              Apr 20 13:02:10 raspberrypi kernel: [    4.462603] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
              Apr 20 13:02:10 raspberrypi kernel: [    4.462625] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
              Apr 20 13:02:10 raspberrypi kernel: [    4.463176] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
              Apr 20 13:02:10 raspberrypi kernel: [    4.468471] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
              Apr 20 13:02:10 raspberrypi kernel: [    4.468544] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
              Apr 20 13:02:10 raspberrypi kernel: [    4.475685] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
              Apr 20 13:02:10 raspberrypi kernel: [    4.475728] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
              Apr 20 13:02:10 raspberrypi kernel: [    4.480139] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
              Apr 20 13:02:10 raspberrypi kernel: [    4.480199] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
              Apr 20 13:02:10 raspberrypi kernel: [    4.559212] cfg80211: Loading compiled-in X.509 certificates for regulatory database
              Apr 20 13:02:10 raspberrypi kernel: [    4.694789] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
              Apr 20 13:02:10 raspberrypi kernel: [    4.819570] brcmfmac: F1 signature read @0x18000000=0x15264345
              Apr 20 13:02:10 raspberrypi kernel: [    4.834378] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
              Apr 20 13:02:10 raspberrypi kernel: [    4.835385] usbcore: registered new interface driver brcmfmac
              Apr 20 13:02:10 raspberrypi kernel: [    4.861081] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
              Apr 20 13:02:10 raspberrypi kernel: [    4.900227] [drm] No displays found. Consider forcing hotplug if HDMI is attached
              Apr 20 13:02:10 raspberrypi kernel: [    4.900387] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
              Apr 20 13:02:10 raspberrypi kernel: [    4.906440] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
              Apr 20 13:02:10 raspberrypi kernel: [    4.924805] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
              Apr 20 13:02:10 raspberrypi kernel: [    4.984562] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
              Apr 20 13:02:10 raspberrypi kernel: [    4.987621] usbcore: registered new interface driver cdc_acm
              Apr 20 13:02:10 raspberrypi kernel: [    4.987640] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
              Apr 20 13:02:10 raspberrypi kernel: [    5.108883] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
              Apr 20 13:02:10 raspberrypi kernel: [    5.119706] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
              Apr 20 13:02:10 raspberrypi kernel: [    7.150414] uart-pl011 fe201000.serial: no DMA platform data
              Apr 20 13:02:10 raspberrypi kernel: [    7.255281] 8021q: 802.1Q VLAN Support v1.8
              Apr 20 13:02:10 raspberrypi kernel: [    7.412949] random: crng init done
              Apr 20 13:02:10 raspberrypi kernel: [    7.412971] random: 7 urandom warning(s) missed due to ratelimiting
              Apr 20 13:02:10 raspberrypi kernel: [    7.613896] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
              Apr 20 13:02:10 raspberrypi kernel: [    7.633120] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
              Apr 20 13:02:10 raspberrypi kernel: [    7.854737] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
              Apr 20 13:02:10 raspberrypi kernel: [    7.855001] bcmgenet fd580000.ethernet eth0: Link is Down
              Apr 20 13:02:13 raspberrypi kernel: [   10.954205] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
              Apr 20 13:02:13 raspberrypi kernel: [   10.954258] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
              Apr 20 13:02:15 raspberrypi kernel: [   13.076567] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
              Apr 20 13:02:16 raspberrypi kernel: [   14.012299] Bluetooth: Core ver 2.22
              Apr 20 13:02:16 raspberrypi kernel: [   14.012405] NET: Registered protocol family 31
              Apr 20 13:02:16 raspberrypi kernel: [   14.012422] Bluetooth: HCI device and connection manager initialized
              Apr 20 13:02:16 raspberrypi kernel: [   14.012452] Bluetooth: HCI socket layer initialized
              Apr 20 13:02:16 raspberrypi kernel: [   14.012474] Bluetooth: L2CAP socket layer initialized
              Apr 20 13:02:16 raspberrypi kernel: [   14.012509] Bluetooth: SCO socket layer initialized
              Apr 20 13:02:16 raspberrypi kernel: [   14.021474] Bluetooth: HCI UART driver ver 2.3
              Apr 20 13:02:16 raspberrypi kernel: [   14.021492] Bluetooth: HCI UART protocol H4 registered
              Apr 20 13:02:16 raspberrypi kernel: [   14.021584] Bluetooth: HCI UART protocol Three-wire (H5) registered
              Apr 20 13:02:16 raspberrypi kernel: [   14.021833] Bluetooth: HCI UART protocol Broadcom registered
              Apr 20 13:02:17 raspberrypi kernel: [   14.216608] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
              Apr 20 13:02:17 raspberrypi kernel: [   14.216617] Bluetooth: BNEP filters: protocol multicast
              Apr 20 13:02:17 raspberrypi kernel: [   14.216630] Bluetooth: BNEP socket layer initialized
              pi@raspberrypi:~ $
              sys.log
              pi@raspberrypi:~ $ cat /var/log/syslog
              Apr 20 00:00:54 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="359" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
              Apr 20 00:00:54 raspberrypi systemd[1]: logrotate.service: Succeeded.
              Apr 20 00:00:54 raspberrypi systemd[1]: Started Rotate log files.
              Apr 20 00:00:55 raspberrypi systemd[1]: man-db.service: Succeeded.
              Apr 20 00:00:55 raspberrypi systemd[1]: Started Daily man-db regeneration.
              Apr 20 00:17:01 raspberrypi CRON[717]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1140064
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1083072
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1083072
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 57
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=507.593; max=547.569)Kibits/s
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.866; max=31.423)Mibits/s
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
              Apr 20 00:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
              Apr 20 00:30:54 raspberrypi systemd[1]: Starting Daily apt download activities...
              Apr 20 00:30:55 raspberrypi systemd[1]: apt-daily.service: Succeeded.
              Apr 20 00:30:55 raspberrypi systemd[1]: Started Daily apt download activities.
              Apr 20 01:17:01 raspberrypi CRON[20321]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1160064
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1113312
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1113312
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 58
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=508.219; max=547.569)Kibits/s
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.962; max=31.423)Mibits/s
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
              Apr 20 01:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
              Apr 20 02:01:24 raspberrypi systemd[1]: iobroker.service: Main process exited, code=killed, status=9/KILL
              Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Failed with result 'signal'.
              Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Service RestartSec=100ms expired, scheduling restart.
              Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2.
              Apr 20 02:01:39 raspberrypi systemd[1]: Stopped ioBroker Server.
              Apr 20 02:01:39 raspberrypi systemd[1]: Started ioBroker Server.
              Apr 20 02:01:43 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.chromecast.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.coronavirus-statistics.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.email.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.fakeroku.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.fritzbox.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.geofency.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.harmony.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.homee.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.hue-extended.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.husq-automower.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ical.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ical.1" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.iot.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.material.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.meross.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mobile.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mqtt.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.netatmo.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.node-red.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.nuki.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.pushover.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.rpi2.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.rssfeed.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.samsung.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.sayit.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.simple-api.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.sonos.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.trashschedule.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-canvas-gauges.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-colorpicker.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-fancyswitch.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-hqwidgets.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-inventwo.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-justgage.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-materialdesign.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-metro.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-timeandweather.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.yeelight-2.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.tr-064.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.zwave2.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mytime.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.tvprogram.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.lgtv.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.daswetter.0" for host "raspberrypi"
              Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ring.0" for host "raspberrypi"
              Apr 20 02:01:47 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
              Apr 20 02:01:47 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
              Apr 20 02:03:00 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
              Apr 20 02:03:00 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
              Apr 20 02:17:01 raspberrypi CRON[6125]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1200064
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1143072
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1143072
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 60
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=509.294; max=547.569)Kibits/s
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.794; max=31.423)Mibits/s
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
              Apr 20 02:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
              Apr 20 03:01:42 raspberrypi bash[18274]: host.raspberrypi Delete log file iobroker.2021-04-12.log.gz
              Apr 20 03:17:01 raspberrypi CRON[25997]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1220064
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1173312
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1173312
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 61
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=509.866; max=547.569)Kibits/s
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.888; max=31.423)Mibits/s
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
              Apr 20 03:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
              Apr 20 04:17:01 raspberrypi CRON[13137]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1260064
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1203072
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1203072
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 63
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=510.951; max=547.569)Kibits/s
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.811; max=31.423)Mibits/s
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
              Apr 20 04:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
              Apr 20 05:17:01 raspberrypi CRON[828]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1280064
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1232800
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1232800
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 64
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=511.473; max=547.569)Kibits/s
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.900; max=31.423)Mibits/s
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
              Apr 20 05:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
              Apr 20 06:15:15 raspberrypi systemd[1]: Starting Daily apt upgrade and clean activities...
              Apr 20 06:15:17 raspberrypi systemd[1]: apt-daily-upgrade.service: Succeeded.
              Apr 20 06:15:17 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
              Apr 20 06:17:01 raspberrypi CRON[20952]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1320064
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1262560
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1262560
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 66
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=512.471; max=547.569)Kibits/s
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.754; max=31.423)Mibits/s
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
              Apr 20 06:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
              Apr 20 06:25:02 raspberrypi CRON[32245]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily ))
              Apr 20 07:13:29 raspberrypi bash[18274]: Tue, 20 Apr 2021 05:13:29 GMT node-telegram-bot-api deprecated In the future, content-type of files you send will default to "application/octet-stream". See https://github.com/yagop/node-telegram-bot-api/blob/master/doc/usage.md#sending-files for more information on how sending files has been improved and on how to disable this deprecation message altogether. at opt/iobroker/node_modules/iobroker.telegram/main.js:634:20
              Apr 20 07:17:01 raspberrypi CRON[8035]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1340064
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1292800
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1292800
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 67
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=512.947; max=547.569)Kibits/s
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.839; max=31.423)Mibits/s
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
              Apr 20 07:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
              homee, ioBroker, iMac, iPhone, Sonos, Alaxa
              • bergjetB bergjet
                kernel.log
                Apr 20 02:01:23 raspberrypi kernel: [135707.349180] node invoked oom-killer: gfp_mask=0x400dc2(GFP_KERNEL_ACCOUNT|__GFP_HIGHMEM|__GFP_ZERO), order=0, oom_score_adj=0
                Apr 20 02:01:23 raspberrypi kernel: [135707.349192] CPU: 2 PID: 30402 Comm: node Tainted: G         C        5.10.17-v7l+ #1403
                Apr 20 02:01:23 raspberrypi kernel: [135707.349197] Hardware name: BCM2711
                Apr 20 02:01:23 raspberrypi kernel: [135707.349201] Backtrace:
                Apr 20 02:01:23 raspberrypi kernel: [135707.349223] [<c0b63050>] (dump_backtrace) from [<c0b633e4>] (show_stack+0x20/0x24)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349230]  r7:ffffffff r6:00000000 r5:60000113 r4:c12e69fc
                Apr 20 02:01:23 raspberrypi kernel: [135707.349239] [<c0b633c4>] (show_stack) from [<c0b67774>] (dump_stack+0xcc/0xf8)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349245] [<c0b676a8>] (dump_stack) from [<c0b65a04>] (dump_header+0x64/0x208)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349251]  r10:c120518c r9:00400dc2 r8:00000000 r7:c0e3709c r6:c7f16a00 r5:c9ffbe00
                Apr 20 02:01:23 raspberrypi kernel: [135707.349256]  r4:c7a8dde8 r3:eaf5c060
                Apr 20 02:01:23 raspberrypi kernel: [135707.349265] [<c0b659a0>] (dump_header) from [<c03b6cd0>] (oom_kill_process+0x1b4/0x1c0)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349270]  r7:c0e3709c r6:c7a8dde8 r5:c9ffc380 r4:c9ffbe00
                Apr 20 02:01:23 raspberrypi kernel: [135707.349277] [<c03b6b1c>] (oom_kill_process) from [<c03b7848>] (out_of_memory+0x2b8/0x390)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349282]  r7:c1208580 r6:c1205048 r5:c9ffbe00 r4:c7a8dde8
                Apr 20 02:01:23 raspberrypi kernel: [135707.349290] [<c03b7590>] (out_of_memory) from [<c040a8bc>] (__alloc_pages_nodemask+0x7ec/0x1184)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349296]  r7:c1336790 r6:00001400 r5:00001dec r4:00000000
                Apr 20 02:01:23 raspberrypi kernel: [135707.349304] [<c040a0d0>] (__alloc_pages_nodemask) from [<c03ec934>] (__pte_alloc+0x34/0x168)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349310]  r10:c1205048 r9:00000040 r8:00000255 r7:00000000 r6:c7eaad28 r5:c40a0200
                Apr 20 02:01:23 raspberrypi kernel: [135707.349314]  r4:34acf000
                Apr 20 02:01:23 raspberrypi kernel: [135707.349321] [<c03ec900>] (__pte_alloc) from [<c03f0068>] (handle_mm_fault+0x100c/0x1124)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349326]  r7:00000000 r6:07eaa003 r5:00000000 r4:34acf000
                Apr 20 02:01:23 raspberrypi kernel: [135707.349334] [<c03ef05c>] (handle_mm_fault) from [<c0b739d4>] (do_page_fault+0x144/0x314)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349339]  r10:00000255 r9:00000800 r8:c40a0248 r7:c40a0200 r6:00000a06 r5:34acf000
                Apr 20 02:01:23 raspberrypi kernel: [135707.349343]  r4:c7a8dfb0
                Apr 20 02:01:23 raspberrypi kernel: [135707.349349] [<c0b73890>] (do_page_fault) from [<c0b73c84>] (do_translation_fault+0xe0/0x10c)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349355]  r10:00000000 r9:b6d25258 r8:00000a06 r7:34acf000 r6:c0b73ba4 r5:00000a06
                Apr 20 02:01:23 raspberrypi kernel: [135707.349359]  r4:c120aef8
                Apr 20 02:01:23 raspberrypi kernel: [135707.349366] [<c0b73ba4>] (do_translation_fault) from [<c0214c6c>] (do_DataAbort+0x40/0xc0)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349372]  r9:b6d25258 r8:c7a8dfb0 r7:34acf000 r6:c0b73ba4 r5:00000a06 r4:c120aef8
                Apr 20 02:01:23 raspberrypi kernel: [135707.349379] [<c0214c2c>] (do_DataAbort) from [<c0200da4>] (__dabt_usr+0x44/0x60)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349383] Exception stack(0xc7a8dfb0 to 0xc7a8dff8)
                Apr 20 02:01:23 raspberrypi kernel: [135707.349388] dfa0:                                     34acf000 002f1002 00000000 34acf008
                Apr 20 02:01:23 raspberrypi kernel: [135707.349394] dfc0: b6d257d4 002f1000 0005e1a6 002f0d40 b6d25000 b6d25258 00000000 fffff000
                Apr 20 02:01:23 raspberrypi kernel: [135707.349399] dfe0: b6d2526c bef6d328 b6d25258 b6c4b8d8 40000010 ffffffff
                Apr 20 02:01:23 raspberrypi kernel: [135707.349405]  r8:30c5387d r7:30c5383d r6:ffffffff r5:40000010 r4:b6c4b8d8
                Apr 20 02:01:23 raspberrypi kernel: [135707.349409] Mem-Info:
                Apr 20 02:01:23 raspberrypi kernel: [135707.349421] active_anon:35326 inactive_anon:905949 isolated_anon:0
                Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  active_file:3396 inactive_file:3998 isolated_file:32
                Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  unevictable:4 dirty:39 writeback:0
                Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  slab_reclaimable:3544 slab_unreclaimable:5676
                Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  mapped:3307 shmem:519 pagetables:9482 bounce:0
                Apr 20 02:01:23 raspberrypi kernel: [135707.349421]  free:6738 free_pcp:0 free_cma:0
                Apr 20 02:01:23 raspberrypi kernel: [135707.349431] Node 0 active_anon:141304kB inactive_anon:3623796kB active_file:13584kB inactive_file:15992kB unevictable:16kB isolated(anon):0kB isolated(file):128kB mapped:13228kB dirty:156kB writeback:0kB shmem:2076kB writeback_tmp:0kB kernel_stack:5072kB all_unreclaimable? no
                Apr 20 02:01:23 raspberrypi kernel: [135707.349442] DMA free:24532kB min:20480kB low:24576kB high:28672kB reserved_highatomic:0KB active_anon:1812kB inactive_anon:567188kB active_file:1012kB inactive_file:4744kB unevictable:0kB writepending:40kB present:786432kB managed:654620kB mlocked:0kB pagetables:1836kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
                Apr 20 02:01:23 raspberrypi kernel: [135707.349448] lowmem_reserve[]: 0 0 3188 0
                Apr 20 02:01:23 raspberrypi kernel: [135707.349484] HighMem free:2420kB min:62552kB low:82976kB high:103400kB reserved_highatomic:0KB active_anon:140040kB inactive_anon:3055932kB active_file:12988kB inactive_file:10932kB unevictable:16kB writepending:116kB present:3264512kB managed:3264512kB mlocked:16kB pagetables:36092kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
                Apr 20 02:01:23 raspberrypi kernel: [135707.349490] lowmem_reserve[]: 0 0 0 0
                Apr 20 02:01:23 raspberrypi kernel: [135707.349522] DMA: 209*4kB (UME) 481*8kB (UMEC) 409*16kB (UME) 194*32kB (UME) 80*64kB (UME) 16*128kB (UM) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 24604kB
                Apr 20 02:01:23 raspberrypi kernel: [135707.349625] HighMem: 148*4kB (UM) 89*8kB (UM) 25*16kB (UM) 6*32kB (UM) 20*64kB (M) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 3176kB
                Apr 20 02:01:23 raspberrypi kernel: [135707.349723] 5758 total pagecache pages
                Apr 20 02:01:23 raspberrypi kernel: [135707.349730] 175 pages in swap cache
                Apr 20 02:01:23 raspberrypi kernel: [135707.349737] Swap cache stats: add 59748, delete 59572, find 4768/8730
                Apr 20 02:01:23 raspberrypi kernel: [135707.349743] Free swap  = 0kB
                Apr 20 02:01:23 raspberrypi kernel: [135707.349749] Total swap = 102396kB
                Apr 20 02:01:23 raspberrypi kernel: [135707.349755] 1012736 pages RAM
                Apr 20 02:01:23 raspberrypi kernel: [135707.349761] 816128 pages HighMem/MovableOnly
                Apr 20 02:01:23 raspberrypi kernel: [135707.349767] 32953 pages reserved
                Apr 20 02:01:23 raspberrypi kernel: [135707.349772] 65536 pages cma reserved
                Apr 20 02:01:23 raspberrypi kernel: [135707.349779] Tasks state (memory values in pages):
                Apr 20 02:01:23 raspberrypi kernel: [135707.349785] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
                Apr 20 02:01:23 raspberrypi kernel: [135707.349799] [    122]     0   122     5310     1101   131072        1             0 systemd-journal
                Apr 20 02:01:23 raspberrypi kernel: [135707.349807] [    148]     0   148     4499      202    49152        0         -1000 systemd-udevd
                Apr 20 02:01:23 raspberrypi kernel: [135707.349818] [    298]   100   298     5604      359    61440        0             0 systemd-timesyn
                Apr 20 02:01:23 raspberrypi kernel: [135707.349825] [    336]     0   336     1987      206    45056        0             0 cron
                Apr 20 02:01:23 raspberrypi kernel: [135707.349833] [    341]   104   341     1639      176    36864        0          -900 dbus-daemon
                Apr 20 02:01:23 raspberrypi kernel: [135707.349841] [    349]   108   349     1640      432    32768        0             0 avahi-daemon
                Apr 20 02:01:23 raspberrypi kernel: [135707.349849] [    350]     0   350     2686      181    45056        0             0 wpa_supplicant
                Apr 20 02:01:23 raspberrypi kernel: [135707.349856] [    359]     0   359     6378      358    45056        4             0 rsyslogd
                Apr 20 02:01:23 raspberrypi kernel: [135707.349864] [    361] 65534   361     1080       85    32768        0             0 thd
                Apr 20 02:01:23 raspberrypi kernel: [135707.349872] [    363]     0   363     6914       90    36864        2             0 rngd
                Apr 20 02:01:23 raspberrypi kernel: [135707.349880] [    371]   108   371     1442       55    32768        8             0 avahi-daemon
                Apr 20 02:01:23 raspberrypi kernel: [135707.349888] [    373]     0   373      923       77    32768        0             0 alsactl
                Apr 20 02:01:23 raspberrypi kernel: [135707.349896] [    383]     0   383     3228      246    53248        0             0 systemd-logind
                Apr 20 02:01:23 raspberrypi kernel: [135707.349904] [    464]     0   464     2751       91    45056       79             0 wpa_supplicant
                Apr 20 02:01:23 raspberrypi kernel: [135707.349911] [    479]     0   479      535       12    28672       20             0 hciattach
                Apr 20 02:01:23 raspberrypi kernel: [135707.349919] [    482]     0   482     2384       71    40960        0             0 bluetoothd
                Apr 20 02:01:23 raspberrypi kernel: [135707.349927] [    547]     0   547      726      228    28672       60             0 dhcpcd
                Apr 20 02:01:23 raspberrypi kernel: [135707.349935] [    553]     0   553     1077       22    32768        0             0 agetty
                Apr 20 02:01:23 raspberrypi kernel: [135707.349942] [    555]     0   555     2682      150    49152        0         -1000 sshd
                Apr 20 02:01:23 raspberrypi kernel: [135707.349950] [  30402]  1001 30402   586177   549850  5492736     2877             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.349958] [  30581]  1001 30581    45284     5149   921600     9869             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.349966] [  30596]  1001 30596    38986     4701   622592     2987             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.349973] [  30618]  1001 30618    45150    10907   770048     3644             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.349981] [  30648]  1001 30648    39337     5230   643072     2828             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.349989] [  30678]  1001 30678    38834     6717   598016     1582             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.349996] [  30708]  1001 30708    39563     8011   610304        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350004] [  30738]  1001 30738    40084     9530   643072        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350011] [  30772]  1001 30772    40070     9700   557056        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350019] [  30809]  1001 30809    42845    11617   733184        2             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350026] [  30820]  1001 30820    42287    16068   643072        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350034] [  30854]  1001 30854    43537    13961   741376        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350042] [  30872]  1001 30872    40476     9257   643072        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350049] [  30929]  1001 30929    45589    15181   745472        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350057] [  30959]  1001 30959    41057    10303   704512        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350065] [  31482]  1001 31482    58032    27676  1118208        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350073] [  31502]  1001 31502    41579    10242   712704        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350080] [  31701]  1001 31701    44816    15632   856064        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350088] [  31723]  1001 31723    41736     9803   671744        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350096] [  31759]  1001 31759    38354     8109   585728        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350104] [  31935]  1001 31935    39537     8623   614400        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350111] [  31942]  1001 31942    58856    28730  1236992        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350119] [  32032]  1001 32032    40009     9640   700416        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350126] [  32154]  1001 32154    39480     8089   626688        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350134] [  32345]  1001 32345    38903     8763   610304        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350141] [  32373]  1001 32373    41231    10602   712704        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350149] [  32546]  1001 32546    39094     8941   655360        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350156] [  32651]  1001 32651    39185     7901   626688        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350164] [  32736]  1001 32736    38878     7986   602112        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350171] [    440]  1001   440    40017     9579   692224        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350179] [    659]  1001   659    39302     8485   630784        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350187] [    888]  1001   888    39670     8754   651264        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350195] [   1087]  1001  1087    38337     7372   581632        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350203] [   1443]  1001  1443    39299     8623   618496        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350211] [   1450]  1001  1450    42483    12549   688128        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350219] [   1463]  1001  1463    42582    12326   790528        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350226] [   1496]  1001  1496    38381     7868   610304        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350234] [   1681]  1001  1681    42361    11271   749568        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350241] [   1688]  1001  1688    42241    12155   741376        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350249] [   1706]  1001  1706    39041     7989   618496        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350257] [   1940]  1001  1940    47010    17102   843776        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350265] [   5108]  1001  5108    46936    17112   876544        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350273] [   7580]  1001  7580    43672    12220   716800        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350282] [  16135]  1001 16135    37555     6788   577536        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350290] [  16337]  1001 16337    40542    10018   663552        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350298] [  16363]  1001 16363    38619     8052   647168        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350305] [  16542]  1001 16542    38988    16908   806912        0             0 node
                Apr 20 02:01:23 raspberrypi kernel: [135707.350314] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=30402,uid=1001
                Apr 20 02:01:23 raspberrypi kernel: [135707.350388] Out of memory: Killed process 30402 (node) total-vm:2344708kB, anon-rss:2189760kB, file-rss:9640kB, shmem-rss:0kB, UID:1001 pgtables:5364kB oom_score_adj:0
                Apr 20 02:01:24 raspberrypi kernel: [135707.559391] oom_reaper: reaped process 30402 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                Apr 20 13:01:56 raspberrypi kernel: [175340.649230] Bluetooth: hci0: sending frame failed (-49)
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Zone ranges:
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   Normal   empty
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Movable zone start for each node
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Early memory node ranges
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] On node 0 totalpages: 1012736
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 2304 pages used for memmap
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 0 pages reserved
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:11:CE:96 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f546770a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] Memory: 3654940K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133860K reserved, 262144K cma-reserved, 3264512K highmem)
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] ftrace: allocating 33942 entries in 67 pages
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] ftrace: allocated 67 pages with 3 groups
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] rcu: Hierarchical RCU implementation.
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
                Apr 20 13:02:10 raspberrypi kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
                Apr 20 13:02:10 raspberrypi kernel: [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                Apr 20 13:02:10 raspberrypi kernel: [    0.000034] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                Apr 20 13:02:10 raspberrypi kernel: [    0.000098] bcm2835: system timer (irq = 25)
                Apr 20 13:02:10 raspberrypi kernel: [    0.000750] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                Apr 20 13:02:10 raspberrypi kernel: [    0.000772] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                Apr 20 13:02:10 raspberrypi kernel: [    0.000795] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                Apr 20 13:02:10 raspberrypi kernel: [    0.000813] Switching to timer-based delay loop, resolution 18ns
                Apr 20 13:02:10 raspberrypi kernel: [    0.001065] Console: colour dummy device 80x30
                Apr 20 13:02:10 raspberrypi kernel: [    0.001808] printk: console [tty1] enabled
                Apr 20 13:02:10 raspberrypi kernel: [    0.001874] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                Apr 20 13:02:10 raspberrypi kernel: [    0.001928] pid_max: default: 32768 minimum: 301
                Apr 20 13:02:10 raspberrypi kernel: [    0.002109] LSM: Security Framework initializing
                Apr 20 13:02:10 raspberrypi kernel: [    0.002306] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                Apr 20 13:02:10 raspberrypi kernel: [    0.002352] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                Apr 20 13:02:10 raspberrypi kernel: [    0.003929] Disabling memory control group subsystem
                Apr 20 13:02:10 raspberrypi kernel: [    0.004064] CPU: Testing write buffer coherency: ok
                Apr 20 13:02:10 raspberrypi kernel: [    0.004536] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                Apr 20 13:02:10 raspberrypi kernel: [    0.005755] Setting up static identity map for 0x200000 - 0x20003c
                Apr 20 13:02:10 raspberrypi kernel: [    0.005970] rcu: Hierarchical SRCU implementation.
                Apr 20 13:02:10 raspberrypi kernel: [    0.006915] smp: Bringing up secondary CPUs ...
                Apr 20 13:02:10 raspberrypi kernel: [    0.008137] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                Apr 20 13:02:10 raspberrypi kernel: [    0.009502] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                Apr 20 13:02:10 raspberrypi kernel: [    0.010810] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                Apr 20 13:02:10 raspberrypi kernel: [    0.010966] smp: Brought up 1 node, 4 CPUs
                Apr 20 13:02:10 raspberrypi kernel: [    0.011011] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                Apr 20 13:02:10 raspberrypi kernel: [    0.011042] CPU: All CPU(s) started in HYP mode.
                Apr 20 13:02:10 raspberrypi kernel: [    0.011069] CPU: Virtualization extensions available.
                Apr 20 13:02:10 raspberrypi kernel: [    0.011910] devtmpfs: initialized
                Apr 20 13:02:10 raspberrypi kernel: [    0.025725] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                Apr 20 13:02:10 raspberrypi kernel: [    0.025986] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                Apr 20 13:02:10 raspberrypi kernel: [    0.026040] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                Apr 20 13:02:10 raspberrypi kernel: [    0.033085] pinctrl core: initialized pinctrl subsystem
                Apr 20 13:02:10 raspberrypi kernel: [    0.034183] NET: Registered protocol family 16
                Apr 20 13:02:10 raspberrypi kernel: [    0.038180] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                Apr 20 13:02:10 raspberrypi kernel: [    0.038964] audit: initializing netlink subsys (disabled)
                Apr 20 13:02:10 raspberrypi kernel: [    0.039250] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                Apr 20 13:02:10 raspberrypi kernel: [    0.039809] thermal_sys: Registered thermal governor 'step_wise'
                Apr 20 13:02:10 raspberrypi kernel: [    0.040494] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                Apr 20 13:02:10 raspberrypi kernel: [    0.040548] hw-breakpoint: maximum watchpoint size is 8 bytes.
                Apr 20 13:02:10 raspberrypi kernel: [    0.040983] Serial: AMBA PL011 UART driver
                Apr 20 13:02:10 raspberrypi kernel: [    0.072819] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                Apr 20 13:02:10 raspberrypi kernel: [    0.090958] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
                Apr 20 13:02:10 raspberrypi kernel: [    0.100971] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
                Apr 20 13:02:10 raspberrypi kernel: [    0.146228] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                Apr 20 13:02:10 raspberrypi kernel: [    0.150377] vgaarb: loaded
                Apr 20 13:02:10 raspberrypi kernel: [    0.150838] SCSI subsystem initialized
                Apr 20 13:02:10 raspberrypi kernel: [    0.151443] usbcore: registered new interface driver usbfs
                Apr 20 13:02:10 raspberrypi kernel: [    0.151532] usbcore: registered new interface driver hub
                Apr 20 13:02:10 raspberrypi kernel: [    0.151622] usbcore: registered new device driver usb
                Apr 20 13:02:10 raspberrypi kernel: [    0.151972] usb_phy_generic phy: supply vcc not found, using dummy regulator
                Apr 20 13:02:10 raspberrypi kernel: [    0.153863] clocksource: Switched to clocksource arch_sys_counter
                Apr 20 13:02:10 raspberrypi kernel: [    1.152554] VFS: Disk quotas dquot_6.6.0
                Apr 20 13:02:10 raspberrypi kernel: [    1.152679] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                Apr 20 13:02:10 raspberrypi kernel: [    1.152860] FS-Cache: Loaded
                Apr 20 13:02:10 raspberrypi kernel: [    1.153087] CacheFiles: Loaded
                Apr 20 13:02:10 raspberrypi kernel: [    1.163453] NET: Registered protocol family 2
                Apr 20 13:02:10 raspberrypi kernel: [    1.164344] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                Apr 20 13:02:10 raspberrypi kernel: [    1.164506] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                Apr 20 13:02:10 raspberrypi kernel: [    1.164587] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                Apr 20 13:02:10 raspberrypi kernel: [    1.164673] TCP: Hash tables configured (established 8192 bind 8192)
                Apr 20 13:02:10 raspberrypi kernel: [    1.164845] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                Apr 20 13:02:10 raspberrypi kernel: [    1.164900] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                Apr 20 13:02:10 raspberrypi kernel: [    1.165191] NET: Registered protocol family 1
                Apr 20 13:02:10 raspberrypi kernel: [    1.165911] RPC: Registered named UNIX socket transport module.
                Apr 20 13:02:10 raspberrypi kernel: [    1.165944] RPC: Registered udp transport module.
                Apr 20 13:02:10 raspberrypi kernel: [    1.165972] RPC: Registered tcp transport module.
                Apr 20 13:02:10 raspberrypi kernel: [    1.166000] RPC: Registered tcp NFSv4.1 backchannel transport module.
                Apr 20 13:02:10 raspberrypi kernel: [    1.166037] PCI: CLS 0 bytes, default 64
                Apr 20 13:02:10 raspberrypi kernel: [    1.168924] Initialise system trusted keyrings
                Apr 20 13:02:10 raspberrypi kernel: [    1.169198] workingset: timestamp_bits=14 max_order=20 bucket_order=6
                Apr 20 13:02:10 raspberrypi kernel: [    1.177760] zbud: loaded
                Apr 20 13:02:10 raspberrypi kernel: [    1.179686] FS-Cache: Netfs 'nfs' registered for caching
                Apr 20 13:02:10 raspberrypi kernel: [    1.180481] NFS: Registering the id_resolver key type
                Apr 20 13:02:10 raspberrypi kernel: [    1.180543] Key type id_resolver registered
                Apr 20 13:02:10 raspberrypi kernel: [    1.180572] Key type id_legacy registered
                Apr 20 13:02:10 raspberrypi kernel: [    1.180736] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                Apr 20 13:02:10 raspberrypi kernel: [    1.181775] Key type asymmetric registered
                Apr 20 13:02:10 raspberrypi kernel: [    1.181807] Asymmetric key parser 'x509' registered
                Apr 20 13:02:10 raspberrypi kernel: [    1.182011] bounce: pool size: 64 pages
                Apr 20 13:02:10 raspberrypi kernel: [    1.182067] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                Apr 20 13:02:10 raspberrypi kernel: [    1.182298] io scheduler mq-deadline registered
                Apr 20 13:02:10 raspberrypi kernel: [    1.182329] io scheduler kyber registered
                Apr 20 13:02:10 raspberrypi kernel: [    1.186772] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                Apr 20 13:02:10 raspberrypi kernel: [    1.186824] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                Apr 20 13:02:10 raspberrypi kernel: [    1.186926] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                Apr 20 13:02:10 raspberrypi kernel: [    1.187036] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                Apr 20 13:02:10 raspberrypi kernel: [    1.246001] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                Apr 20 13:02:10 raspberrypi kernel: [    1.246381] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                Apr 20 13:02:10 raspberrypi kernel: [    1.246419] pci_bus 0000:00: root bus resource [bus 00-ff]
                Apr 20 13:02:10 raspberrypi kernel: [    1.246454] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                Apr 20 13:02:10 raspberrypi kernel: [    1.246563] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                Apr 20 13:02:10 raspberrypi kernel: [    1.246821] pci 0000:00:00.0: PME# supported from D0 D3hot
                Apr 20 13:02:10 raspberrypi kernel: [    1.250318] PCI: bus0: Fast back to back transfers disabled
                Apr 20 13:02:10 raspberrypi kernel: [    1.250672] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                Apr 20 13:02:10 raspberrypi kernel: [    1.250815] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                Apr 20 13:02:10 raspberrypi kernel: [    1.251266] pci 0000:01:00.0: PME# supported from D0 D3cold
                Apr 20 13:02:10 raspberrypi kernel: [    1.254766] PCI: bus1: Fast back to back transfers disabled
                Apr 20 13:02:10 raspberrypi kernel: [    1.254880] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                Apr 20 13:02:10 raspberrypi kernel: [    1.254920] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                Apr 20 13:02:10 raspberrypi kernel: [    1.255023] pci 0000:00:00.0: PCI bridge to [bus 01]
                Apr 20 13:02:10 raspberrypi kernel: [    1.255062] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                Apr 20 13:02:10 raspberrypi kernel: [    1.255500] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                Apr 20 13:02:10 raspberrypi kernel: [    1.255742] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
                Apr 20 13:02:10 raspberrypi kernel: [    1.264103] iproc-rng200 fe104000.rng: hwrng registered
                Apr 20 13:02:10 raspberrypi kernel: [    1.264428] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                Apr 20 13:02:10 raspberrypi kernel: [    1.265307] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                Apr 20 13:02:10 raspberrypi kernel: [    1.277620] brd: module loaded
                Apr 20 13:02:10 raspberrypi kernel: [    1.289939] loop: module loaded
                Apr 20 13:02:10 raspberrypi kernel: [    1.291604] Loading iSCSI transport class v2.0-870.
                Apr 20 13:02:10 raspberrypi kernel: [    1.294134] libphy: Fixed MDIO Bus: probed
                Apr 20 13:02:10 raspberrypi kernel: [    1.295825] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                Apr 20 13:02:10 raspberrypi kernel: [    1.313931] libphy: bcmgenet MII bus: probed
                Apr 20 13:02:10 raspberrypi kernel: [    1.394006] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                Apr 20 13:02:10 raspberrypi kernel: [    1.395177] usbcore: registered new interface driver r8152
                Apr 20 13:02:10 raspberrypi kernel: [    1.395263] usbcore: registered new interface driver lan78xx
                Apr 20 13:02:10 raspberrypi kernel: [    1.395338] usbcore: registered new interface driver smsc95xx
                Apr 20 13:02:10 raspberrypi kernel: [    1.396962] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
                Apr 20 13:02:10 raspberrypi kernel: [    1.397141] xhci_hcd 0000:01:00.0: xHCI Host Controller
                Apr 20 13:02:10 raspberrypi kernel: [    1.397191] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                Apr 20 13:02:10 raspberrypi kernel: [    1.400551] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
                Apr 20 13:02:10 raspberrypi kernel: [    1.401898] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                Apr 20 13:02:10 raspberrypi kernel: [    1.401938] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                Apr 20 13:02:10 raspberrypi kernel: [    1.401975] usb usb1: Product: xHCI Host Controller
                Apr 20 13:02:10 raspberrypi kernel: [    1.402004] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                Apr 20 13:02:10 raspberrypi kernel: [    1.402035] usb usb1: SerialNumber: 0000:01:00.0
                Apr 20 13:02:10 raspberrypi kernel: [    1.402771] hub 1-0:1.0: USB hub found
                Apr 20 13:02:10 raspberrypi kernel: [    1.402884] hub 1-0:1.0: 1 port detected
                Apr 20 13:02:10 raspberrypi kernel: [    1.403575] xhci_hcd 0000:01:00.0: xHCI Host Controller
                Apr 20 13:02:10 raspberrypi kernel: [    1.403618] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                Apr 20 13:02:10 raspberrypi kernel: [    1.403663] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                Apr 20 13:02:10 raspberrypi kernel: [    1.404291] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                Apr 20 13:02:10 raspberrypi kernel: [    1.404331] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                Apr 20 13:02:10 raspberrypi kernel: [    1.404367] usb usb2: Product: xHCI Host Controller
                Apr 20 13:02:10 raspberrypi kernel: [    1.404396] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                Apr 20 13:02:10 raspberrypi kernel: [    1.404427] usb usb2: SerialNumber: 0000:01:00.0
                Apr 20 13:02:10 raspberrypi kernel: [    1.405166] hub 2-0:1.0: USB hub found
                Apr 20 13:02:10 raspberrypi kernel: [    1.405260] hub 2-0:1.0: 4 ports detected
                Apr 20 13:02:10 raspberrypi kernel: [    1.406957] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                Apr 20 13:02:10 raspberrypi kernel: [    1.407273] dwc_otg: FIQ enabled
                Apr 20 13:02:10 raspberrypi kernel: [    1.407288] dwc_otg: NAK holdoff enabled
                Apr 20 13:02:10 raspberrypi kernel: [    1.407302] dwc_otg: FIQ split-transaction FSM enabled
                Apr 20 13:02:10 raspberrypi kernel: [    1.407320] Module dwc_common_port init
                Apr 20 13:02:10 raspberrypi kernel: [    1.407779] usbcore: registered new interface driver uas
                Apr 20 13:02:10 raspberrypi kernel: [    1.407907] usbcore: registered new interface driver usb-storage
                Apr 20 13:02:10 raspberrypi kernel: [    1.408117] mousedev: PS/2 mouse device common for all mice
                Apr 20 13:02:10 raspberrypi kernel: [    1.409777] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                Apr 20 13:02:10 raspberrypi kernel: [    1.413253] sdhci: Secure Digital Host Controller Interface driver
                Apr 20 13:02:10 raspberrypi kernel: [    1.413288] sdhci: Copyright(c) Pierre Ossman
                Apr 20 13:02:10 raspberrypi kernel: [    1.414041] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                Apr 20 13:02:10 raspberrypi kernel: [    1.414664] sdhci-pltfm: SDHCI platform and OF driver helper
                Apr 20 13:02:10 raspberrypi kernel: [    1.418816] ledtrig-cpu: registered to indicate activity on CPUs
                Apr 20 13:02:10 raspberrypi kernel: [    1.419176] hid: raw HID events driver (C) Jiri Kosina
                Apr 20 13:02:10 raspberrypi kernel: [    1.419384] usbcore: registered new interface driver usbhid
                Apr 20 13:02:10 raspberrypi kernel: [    1.419414] usbhid: USB HID core driver
                Apr 20 13:02:10 raspberrypi kernel: [    1.425155] Initializing XFRM netlink socket
                Apr 20 13:02:10 raspberrypi kernel: [    1.425218] NET: Registered protocol family 17
                Apr 20 13:02:10 raspberrypi kernel: [    1.425349] Key type dns_resolver registered
                Apr 20 13:02:10 raspberrypi kernel: [    1.425717] Registering SWP/SWPB emulation handler
                Apr 20 13:02:10 raspberrypi kernel: [    1.425910] registered taskstats version 1
                Apr 20 13:02:10 raspberrypi kernel: [    1.425950] Loading compiled-in X.509 certificates
                Apr 20 13:02:10 raspberrypi kernel: [    1.426812] Key type ._fscrypt registered
                Apr 20 13:02:10 raspberrypi kernel: [    1.426843] Key type .fscrypt registered
                Apr 20 13:02:10 raspberrypi kernel: [    1.426871] Key type fscrypt-provisioning registered
                Apr 20 13:02:10 raspberrypi kernel: [    1.438452] uart-pl011 fe201000.serial: there is not valid maps for state default
                Apr 20 13:02:10 raspberrypi kernel: [    1.438794] uart-pl011 fe201000.serial: cts_event_workaround enabled
                Apr 20 13:02:10 raspberrypi kernel: [    1.438887] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                Apr 20 13:02:10 raspberrypi kernel: [    1.445668] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                Apr 20 13:02:10 raspberrypi kernel: [    1.446729] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                Apr 20 13:02:10 raspberrypi kernel: [    1.446763] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                Apr 20 13:02:10 raspberrypi kernel: [    1.477048] of_cfs_init
                Apr 20 13:02:10 raspberrypi kernel: [    1.477322] of_cfs_init: OK
                Apr 20 13:02:10 raspberrypi kernel: [    1.497315] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                Apr 20 13:02:10 raspberrypi kernel: [    1.499023] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                Apr 20 13:02:10 raspberrypi kernel: [    1.500729] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                Apr 20 13:02:10 raspberrypi kernel: [    1.503764] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                Apr 20 13:02:10 raspberrypi kernel: [    1.505499] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                Apr 20 13:02:10 raspberrypi kernel: [    1.513552] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
                Apr 20 13:02:10 raspberrypi kernel: [    1.515730] Waiting for root device PARTUUID=f546770a-02...
                Apr 20 13:02:10 raspberrypi kernel: [    1.554463] random: fast init done
                Apr 20 13:02:10 raspberrypi kernel: [    1.591543] mmc1: new high speed SDIO card at address 0001
                Apr 20 13:02:10 raspberrypi kernel: [    1.621366] mmc0: new ultra high speed DDR50 SDHC card at address 0001
                Apr 20 13:02:10 raspberrypi kernel: [    1.622293] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
                Apr 20 13:02:10 raspberrypi kernel: [    1.624054]  mmcblk0: p1 p2
                Apr 20 13:02:10 raspberrypi kernel: [    1.643630] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                Apr 20 13:02:10 raspberrypi kernel: [    1.643728] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                Apr 20 13:02:10 raspberrypi kernel: [    1.648939] devtmpfs: mounted
                Apr 20 13:02:10 raspberrypi kernel: [    1.657887] Freeing unused kernel memory: 2048K
                Apr 20 13:02:10 raspberrypi kernel: [    1.704212] Run /sbin/init as init process
                Apr 20 13:02:10 raspberrypi kernel: [    1.704243]   with arguments:
                Apr 20 13:02:10 raspberrypi kernel: [    1.704258]     /sbin/init
                Apr 20 13:02:10 raspberrypi kernel: [    1.704271]   with environment:
                Apr 20 13:02:10 raspberrypi kernel: [    1.704286]     HOME=/
                Apr 20 13:02:10 raspberrypi kernel: [    1.704300]     TERM=linux
                Apr 20 13:02:10 raspberrypi kernel: [    1.763919] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                Apr 20 13:02:10 raspberrypi kernel: [    1.956771] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                Apr 20 13:02:10 raspberrypi kernel: [    1.956820] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                Apr 20 13:02:10 raspberrypi kernel: [    1.956854] usb 1-1: Product: USB2.0 Hub
                Apr 20 13:02:10 raspberrypi kernel: [    1.959352] hub 1-1:1.0: USB hub found
                Apr 20 13:02:10 raspberrypi kernel: [    1.959659] hub 1-1:1.0: 4 ports detected
                Apr 20 13:02:10 raspberrypi kernel: [    2.211568] NET: Registered protocol family 10
                Apr 20 13:02:10 raspberrypi kernel: [    2.212992] Segment Routing with IPv6
                Apr 20 13:02:10 raspberrypi kernel: [    2.293919] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
                Apr 20 13:02:10 raspberrypi kernel: [    2.431120] usb 1-1.4: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
                Apr 20 13:02:10 raspberrypi kernel: [    2.431175] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                Apr 20 13:02:10 raspberrypi kernel: [    2.988872] random: systemd: uninitialized urandom read (16 bytes read)
                Apr 20 13:02:10 raspberrypi kernel: [    2.999027] random: systemd: uninitialized urandom read (16 bytes read)
                Apr 20 13:02:10 raspberrypi kernel: [    3.000962] random: systemd: uninitialized urandom read (16 bytes read)
                Apr 20 13:02:10 raspberrypi kernel: [    3.635553] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                Apr 20 13:02:10 raspberrypi kernel: [    4.292517] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                Apr 20 13:02:10 raspberrypi kernel: [    4.309745] mc: Linux media interface: v0.10
                Apr 20 13:02:10 raspberrypi kernel: [    4.314982] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                Apr 20 13:02:10 raspberrypi kernel: [    4.322646] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                Apr 20 13:02:10 raspberrypi kernel: [    4.332521] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                Apr 20 13:02:10 raspberrypi kernel: [    4.338136] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                Apr 20 13:02:10 raspberrypi kernel: [    4.340781] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                Apr 20 13:02:10 raspberrypi kernel: [    4.340807] [vc_sm_connected_init]: start
                Apr 20 13:02:10 raspberrypi kernel: [    4.351493] [vc_sm_connected_init]: installed successfully
                Apr 20 13:02:10 raspberrypi kernel: [    4.353460] videodev: Linux video capture interface: v2.00
                Apr 20 13:02:10 raspberrypi kernel: [    4.376442] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                Apr 20 13:02:10 raspberrypi kernel: [    4.404170] bcm2835_audio bcm2835_audio: card created with 8 channels
                Apr 20 13:02:10 raspberrypi kernel: [    4.412571] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                Apr 20 13:02:10 raspberrypi kernel: [    4.429220] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                Apr 20 13:02:10 raspberrypi kernel: [    4.432063] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                Apr 20 13:02:10 raspberrypi kernel: [    4.445830] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                Apr 20 13:02:10 raspberrypi kernel: [    4.460476] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                Apr 20 13:02:10 raspberrypi kernel: [    4.461158] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                Apr 20 13:02:10 raspberrypi kernel: [    4.461994] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                Apr 20 13:02:10 raspberrypi kernel: [    4.462528] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                Apr 20 13:02:10 raspberrypi kernel: [    4.462556] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                Apr 20 13:02:10 raspberrypi kernel: [    4.462580] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                Apr 20 13:02:10 raspberrypi kernel: [    4.462603] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                Apr 20 13:02:10 raspberrypi kernel: [    4.462625] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                Apr 20 13:02:10 raspberrypi kernel: [    4.463176] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                Apr 20 13:02:10 raspberrypi kernel: [    4.468471] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                Apr 20 13:02:10 raspberrypi kernel: [    4.468544] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                Apr 20 13:02:10 raspberrypi kernel: [    4.475685] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                Apr 20 13:02:10 raspberrypi kernel: [    4.475728] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                Apr 20 13:02:10 raspberrypi kernel: [    4.480139] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                Apr 20 13:02:10 raspberrypi kernel: [    4.480199] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                Apr 20 13:02:10 raspberrypi kernel: [    4.559212] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                Apr 20 13:02:10 raspberrypi kernel: [    4.694789] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                Apr 20 13:02:10 raspberrypi kernel: [    4.819570] brcmfmac: F1 signature read @0x18000000=0x15264345
                Apr 20 13:02:10 raspberrypi kernel: [    4.834378] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                Apr 20 13:02:10 raspberrypi kernel: [    4.835385] usbcore: registered new interface driver brcmfmac
                Apr 20 13:02:10 raspberrypi kernel: [    4.861081] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                Apr 20 13:02:10 raspberrypi kernel: [    4.900227] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                Apr 20 13:02:10 raspberrypi kernel: [    4.900387] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                Apr 20 13:02:10 raspberrypi kernel: [    4.906440] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                Apr 20 13:02:10 raspberrypi kernel: [    4.924805] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                Apr 20 13:02:10 raspberrypi kernel: [    4.984562] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
                Apr 20 13:02:10 raspberrypi kernel: [    4.987621] usbcore: registered new interface driver cdc_acm
                Apr 20 13:02:10 raspberrypi kernel: [    4.987640] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                Apr 20 13:02:10 raspberrypi kernel: [    5.108883] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                Apr 20 13:02:10 raspberrypi kernel: [    5.119706] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                Apr 20 13:02:10 raspberrypi kernel: [    7.150414] uart-pl011 fe201000.serial: no DMA platform data
                Apr 20 13:02:10 raspberrypi kernel: [    7.255281] 8021q: 802.1Q VLAN Support v1.8
                Apr 20 13:02:10 raspberrypi kernel: [    7.412949] random: crng init done
                Apr 20 13:02:10 raspberrypi kernel: [    7.412971] random: 7 urandom warning(s) missed due to ratelimiting
                Apr 20 13:02:10 raspberrypi kernel: [    7.613896] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                Apr 20 13:02:10 raspberrypi kernel: [    7.633120] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                Apr 20 13:02:10 raspberrypi kernel: [    7.854737] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                Apr 20 13:02:10 raspberrypi kernel: [    7.855001] bcmgenet fd580000.ethernet eth0: Link is Down
                Apr 20 13:02:13 raspberrypi kernel: [   10.954205] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                Apr 20 13:02:13 raspberrypi kernel: [   10.954258] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                Apr 20 13:02:15 raspberrypi kernel: [   13.076567] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                Apr 20 13:02:16 raspberrypi kernel: [   14.012299] Bluetooth: Core ver 2.22
                Apr 20 13:02:16 raspberrypi kernel: [   14.012405] NET: Registered protocol family 31
                Apr 20 13:02:16 raspberrypi kernel: [   14.012422] Bluetooth: HCI device and connection manager initialized
                Apr 20 13:02:16 raspberrypi kernel: [   14.012452] Bluetooth: HCI socket layer initialized
                Apr 20 13:02:16 raspberrypi kernel: [   14.012474] Bluetooth: L2CAP socket layer initialized
                Apr 20 13:02:16 raspberrypi kernel: [   14.012509] Bluetooth: SCO socket layer initialized
                Apr 20 13:02:16 raspberrypi kernel: [   14.021474] Bluetooth: HCI UART driver ver 2.3
                Apr 20 13:02:16 raspberrypi kernel: [   14.021492] Bluetooth: HCI UART protocol H4 registered
                Apr 20 13:02:16 raspberrypi kernel: [   14.021584] Bluetooth: HCI UART protocol Three-wire (H5) registered
                Apr 20 13:02:16 raspberrypi kernel: [   14.021833] Bluetooth: HCI UART protocol Broadcom registered
                Apr 20 13:02:17 raspberrypi kernel: [   14.216608] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                Apr 20 13:02:17 raspberrypi kernel: [   14.216617] Bluetooth: BNEP filters: protocol multicast
                Apr 20 13:02:17 raspberrypi kernel: [   14.216630] Bluetooth: BNEP socket layer initialized
                pi@raspberrypi:~ $
                sys.log
                pi@raspberrypi:~ $ cat /var/log/syslog
                Apr 20 00:00:54 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="359" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
                Apr 20 00:00:54 raspberrypi systemd[1]: logrotate.service: Succeeded.
                Apr 20 00:00:54 raspberrypi systemd[1]: Started Rotate log files.
                Apr 20 00:00:55 raspberrypi systemd[1]: man-db.service: Succeeded.
                Apr 20 00:00:55 raspberrypi systemd[1]: Started Daily man-db regeneration.
                Apr 20 00:17:01 raspberrypi CRON[717]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1140064
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1083072
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1083072
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 57
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=507.593; max=547.569)Kibits/s
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.866; max=31.423)Mibits/s
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
                Apr 20 00:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                Apr 20 00:30:54 raspberrypi systemd[1]: Starting Daily apt download activities...
                Apr 20 00:30:55 raspberrypi systemd[1]: apt-daily.service: Succeeded.
                Apr 20 00:30:55 raspberrypi systemd[1]: Started Daily apt download activities.
                Apr 20 01:17:01 raspberrypi CRON[20321]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1160064
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1113312
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1113312
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 58
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=508.219; max=547.569)Kibits/s
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.962; max=31.423)Mibits/s
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
                Apr 20 01:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                Apr 20 02:01:24 raspberrypi systemd[1]: iobroker.service: Main process exited, code=killed, status=9/KILL
                Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Failed with result 'signal'.
                Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Service RestartSec=100ms expired, scheduling restart.
                Apr 20 02:01:39 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2.
                Apr 20 02:01:39 raspberrypi systemd[1]: Stopped ioBroker Server.
                Apr 20 02:01:39 raspberrypi systemd[1]: Started ioBroker Server.
                Apr 20 02:01:43 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.chromecast.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.coronavirus-statistics.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.email.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.fakeroku.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.fritzbox.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.geofency.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.harmony.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.homee.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.hue-extended.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.husq-automower.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ical.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ical.1" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.iot.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.material.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.meross.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mobile.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mqtt.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.netatmo.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.node-red.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.nuki.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.pushover.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.rpi2.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.rssfeed.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.samsung.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.sayit.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.simple-api.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.sonos.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.trashschedule.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-canvas-gauges.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-colorpicker.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-fancyswitch.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-hqwidgets.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-inventwo.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-justgage.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-materialdesign.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-metro.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis-timeandweather.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.yeelight-2.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.tr-064.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.zwave2.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.mytime.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.tvprogram.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.lgtv.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.daswetter.0" for host "raspberrypi"
                Apr 20 02:01:44 raspberrypi bash[18274]: host.raspberrypi check instance "system.adapter.ring.0" for host "raspberrypi"
                Apr 20 02:01:47 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
                Apr 20 02:01:47 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                Apr 20 02:03:00 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
                Apr 20 02:03:00 raspberrypi bash[18274]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
                Apr 20 02:17:01 raspberrypi CRON[6125]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1200064
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1143072
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1143072
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 60
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=509.294; max=547.569)Kibits/s
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.794; max=31.423)Mibits/s
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
                Apr 20 02:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                Apr 20 03:01:42 raspberrypi bash[18274]: host.raspberrypi Delete log file iobroker.2021-04-12.log.gz
                Apr 20 03:17:01 raspberrypi CRON[25997]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1220064
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1173312
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1173312
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 61
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=509.866; max=547.569)Kibits/s
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.888; max=31.423)Mibits/s
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
                Apr 20 03:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                Apr 20 04:17:01 raspberrypi CRON[13137]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1260064
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1203072
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1203072
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 63
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=510.951; max=547.569)Kibits/s
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.811; max=31.423)Mibits/s
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
                Apr 20 04:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                Apr 20 05:17:01 raspberrypi CRON[828]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1280064
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1232800
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1232800
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 64
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=511.473; max=547.569)Kibits/s
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.900; max=31.423)Mibits/s
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
                Apr 20 05:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                Apr 20 06:15:15 raspberrypi systemd[1]: Starting Daily apt upgrade and clean activities...
                Apr 20 06:15:17 raspberrypi systemd[1]: apt-daily-upgrade.service: Succeeded.
                Apr 20 06:15:17 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
                Apr 20 06:17:01 raspberrypi CRON[20952]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1320064
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1262560
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1262560
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 66
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=512.471; max=547.569)Kibits/s
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.754; max=31.423)Mibits/s
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
                Apr 20 06:19:45 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                Apr 20 06:25:02 raspberrypi CRON[32245]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily ))
                Apr 20 07:13:29 raspberrypi bash[18274]: Tue, 20 Apr 2021 05:13:29 GMT node-telegram-bot-api deprecated In the future, content-type of files you send will default to "application/octet-stream". See https://github.com/yagop/node-telegram-bot-api/blob/master/doc/usage.md#sending-files for more information on how sending files has been improved and on how to disable this deprecation message altogether. at opt/iobroker/node_modules/iobroker.telegram/main.js:634:20
                Apr 20 07:17:01 raspberrypi CRON[8035]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: bits received from HRNG source: 1340064
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: bits sent to kernel pool: 1292800
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: entropy added to kernel pool: 1292800
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 67
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: HRNG source speed: (min=191.599; avg=512.947; max=547.569)Kibits/s
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: FIPS tests speed: (min=9.503; avg=23.839; max=31.423)Mibits/s
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
                Apr 20 07:19:45 raspberrypi rngd[363]: stats: Entropy starvations: 0
                @bergjet sagte in ioBrocker Neustart Änderung:
                Apr 20 02:01:23 raspberrypi kernel: [135707.349180] node invoked oom-killer
                Dir geht der Arbeitsspeicher aus.
                Was läuft denn da alles? Vermutlich volle Disko inkl. Desktop?
                bergjetB 1 Antwort Letzte Antwort
                  bergjetB Offline
                  bergjetB Offline
                  bergjet
                  Ich habe noch 56% Ram frei.
                  homee, ioBroker, iMac, iPhone, Sonos, Alaxa
                  HomoranH Thomas BraunT amg_666A 3 Antworten Letzte Antwort
                  • bergjetB bergjet
                    im Moment!
                    aber nicht um 02:01:23
                    @thomas-braun sagte in ioBrocker Neustart Änderung:
                    Meine Glaskugel meint, dass da dein Backitup läuft und reichlich Speicher braucht
                    • bergjetB bergjet
                      @bergjet
                      Um 2 Uhr aber nicht. Da war das System so rappeldicht, das der oom-reaper seine Sense rausgeholt hat und in seiner Verzweiflung überflüssige Prozesse wie 'node' gekillt hat.
                        @bergjet
                        bergjetB Offline
                        bergjetB Offline
                        bergjet
                        Um 02:00 startet backitup.
                        Ist schon verdächtig. Tritt nun eventuell nach einem Update von BackitUp auf, das ich vor einigen Tagen gemacht habe.
                        Ich stelle das einmal auf 03:00 und schaue morgen.
                        • bergjetB bergjet
                          @bergjet Sicherst du nach extern in eine Cloud? Google Drive oder sowas?
                          Da dann besser keine 'geraden Uhrzeiten' nehmen, zu den Zeiten kommen nämlich immer viele Anfragen dort an und sorgt für Trouble.
                          who -r
                          liefert?
                          • bergjetB bergjet
                            amg_666A Offline
                            amg_666A Offline
                            amg_666
                            @bergjet backitup braucht ziemlich viel Ressourcen. Geh doch einfach in die backitup-Instanz und starte mal manuell ein backup und beobachte den Speicher (bzw den Neustart :-) )
                              who -r
                              liefert?
                              bergjetB Offline
                              bergjetB Offline
                              bergjet
                              liefert?
                              pi@raspberrypi:~ $ who -r
                                       Runlevel 5   2021-04-20 13:02
                              pi@raspberrypi:~ $
                              Es wird auf einem NAS, lokal gespeichert.
                              • bergjetB bergjet
                                liefert?
                                pi@raspberrypi:~ $
                                @bergjet
                                Schalte den Raspberry in RunLevel3.
                                Steht im 'Kleinen Linux-Werkzeugkasten' aus meiner Signatur, wie das geht.
                                • bergjetB Offline
                                  bergjetB Offline
                                  bergjet
                                  RunLevel3 bringt keine Änderung.
                                  Wenn ich ein Backup mit dem Terminal mache:
                                  iobroker stop
                                  iobroker backup
                                  klappt es.
                                  Mache ich das Backup über Backitup, kommen die oben genannten Fehler. Es wurde seit dem 14.4. kein Backup mehr automatisch gemacht habe ich nun im Backup-Ordner gesehen.
                                  • bergjetB bergjet
                                    iobroker stop
                                    iobroker backup
                                    klappt es.
                                    @bergjet
                                    Was nimmst du denn alles mit an Backups im Adapter? Zu Fuß über die Konsole ist ja viel weniger dabei als in einem vollgepackten Backitup.
                                      @bergjet
                                      bergjetB Offline
                                      bergjetB Offline
                                      bergjet
                                      Nur iobroker
                                      • bergjetB bergjet
                                        Nur iobroker
                                        @bergjet Kein Javascript?
                                        Zeig mal die Einstellungen im Adapter.
                                        Vielleicht kann @simatec dann was sehen.
                                          bergjetB Offline
                                          bergjetB Offline
                                          bergjet
                                          backitup auf debug
                                          host.raspberrypi-Server	2021-04-20 19:54:58.875	error	Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json'
                                          host.raspberrypi-Server	2021-04-20 19:52:37.526	error	Cannot save backup file /opt/iobroker/iobroker-data/states.json.bak: ENOENT: no such file or directory, rename '/opt/iobroker/iobroker-data/states.json' -> '/opt/iobroker/iobroker-data/states.json.ba
                                          host.raspberrypi-Server	2021-04-20 19:51:39.614	error	Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json'
                                          backitup.0	2021-04-20 19:48:55.948	debug	(659) system.adapter.admin.0: logging true
                                          backitup.0	2021-04-20 19:48:55.904	debug	(659) system.adapter.admin.0: logging false
                                          host.raspberrypi-Server	2021-04-20 19:47:13.405	error	Cannot save backup file /opt/iobroker/iobroker-data/states.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/states.json'
                                          host.raspberrypi-Server	2021-04-20 19:47:09.502	error	Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, rename '/opt/iobroker/iobroker-data/objects.json' -> '/opt/iobroker/iobroker-data/objects.json
                                          host.raspberrypi-Server	2021-04-20 19:47:09.496	error	Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, rename '/opt/iobroker/iobroker-data/objects.json' -> '/opt/iobroker/iobroker-data/objects.json
