  4. IoBroker Images für BananaPi, Cubietruck und Cubox i4
134 Beiträge 11 Kommentatoren 25.9k Aufrufe 1 Beobachtet
    #68
    Dann werde ich mir den auch mal ansehen.
      derrapf
      #69
      Sp
      Ich habe jetzt erstmal alle Adapter upgdatet und dann hm-rpc und hm-rega eingerichtet.
      Ich habe jetzt im Log Folgendes; sagt Dir das was?
      hm-rpc.0	2017-01-07 19:24:51.377	info	binrpc -> getParamsetDescription ["IEQ0543545:2","VALUES"]
      hm-rpc.0	2017-01-07 19:24:51.123	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"DIRECTION":{"DEFAULT":0,"FLAGS":3,"ID":"DIRECTION","MAX":3,"MIN":0,"OPERATI
      hm-rpc.0	2017-01-07 19:24:51.121	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-LC-Dim1TPBU-FM.DIMMER.13"
      hm-rpc.0	2017-01-07 19:24:49.487	info	binrpc -> getParamsetDescription ["IEQ0543545:1","VALUES"]
      hm-rpc.0	2017-01-07 19:24:49.313	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"CONFIG_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true
      hm-rpc.0	2017-01-07 19:24:49.311	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-LC-Dim1TPBU-FM.MAINTENANCE.13"
      hm-rpc.0	2017-01-07 19:24:48.026	info	binrpc -> getParamsetDescription ["IEQ0543545:0","VALUES"]
      hm-rpc.0	2017-01-07 19:24:47.825	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"INHIBIT":{"CONTROL":"NONE","DEFAULT":false,"FLAGS":1,"ID":"INHIBIT","MAX":t
      hm-rpc.0	2017-01-07 19:24:47.824	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-LC-Sw2-PB-FM.SWITCH.1"
      hm-rpc.0	2017-01-07 19:24:47.739	info	binrpc -> getParamsetDescription ["HEQ0074086:1","VALUES"]
      hm-rpc.0	2017-01-07 19:24:47.593	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"AES_KEY":{"DEFAULT":0,"FLAGS":0,"ID":"AES_KEY","MAX":127,"MIN":0,"OPERATION
      hm-rpc.0	2017-01-07 19:24:47.591	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-LC-Sw2-PB-FM.MAINTENANCE.1"
      host.ioBroker-BPi	2017-01-07 19:24:46.976	info	object change system.adapter.hm-rega.0
      hm-rpc.0	2017-01-07 19:24:46.587	info	binrpc -> getParamsetDescription ["HEQ0074086:0","VALUES"]
      hm-rpc.0	2017-01-07 19:24:35.359	warn	No image for "HM-LC-Sw1-Pl-DN-R1" found.
      hm-rpc.0	2017-01-07 19:24:35.358	warn	No image for "HM-LC-Sw1-Pl-DN-R1" found.
      hm-rpc.0	2017-01-07 19:24:35.356	warn	No image for "HM-LC-Sw1-Pl-DN-R1" found.
      hm-rpc.0	2017-01-07 19:24:35.344	warn	No image for "HM-SwI-3-FM" found.
      hm-rpc.0	2017-01-07 19:24:35.343	warn	No image for "HM-SwI-3-FM" found.
      hm-rpc.0	2017-01-07 19:24:35.342	warn	No image for "HM-SwI-3-FM" found.
      hm-rpc.0	2017-01-07 19:24:35.339	warn	No image for "HM-SwI-3-FM" found.
      Gruss Ralf
        #70
        @derrapf:
        sagt Dir das was? `
        Nicht ganz!
        Aber da scheinen irgendwelche Geräte noch nicht voll eingebunden zu sein. metadaten und Bilder fehlen.
        Send to developer!
        Mal sehen ob @Bluefox das hier liest, sonst müssen wir ihn mit der Nase drauf stoßen.
          derrapf
          #71
          Also rund laufen ist was anderes.
          Ich hab noch folgende issues:
          1. Ich bekomme das mit dem WLAN nicht hin. Alle anderen Geräte (Handys, Tablets, Laptops, andere Bananpis) am gleichen Router im gleichen Raum haben keinerlei Probleme.
          2. Ich habe auch Abbrueche (speziell wieder bei VIS) selbst wenn ich per Kabel verbandelt bin
          3. EIn paar VIS-Adapter lassen sich nicht installieren, bzw. nur nach mehreren Anläufen.
          4. Die Metro-Widgets sind "kaputt", bzw. werden nicht angezeigt und können auch nicht verwendet werden. Habe sie schon zweimal removed und wieder geadded.
          Gruss Ralf
            #72
            @derrapf:
            Also rund laufen ist was anderes. `
            Hallo Ralf,
            vorweg, ich mag WLAN gar nicht!!
            Wenn während der Installation Aussetzer auftraten sind ggf. Pakete defekt und es kommt zu bleibenden Schäden. Das gleiche kann auch mit der SD-Karte oder deinem BPi zusammenhängen. Ich will jetzt nicht sagen "du bist der einzige, der solche immensen Probleme hat", da werden mir weitere "einzige" an die Gurgel springen, aber der absolute Großteil hat diese Probleme in diesem Umfang nicht.
            Versuchen wir mal die möglichen Ursachen mit ioBroker zu beheben.
            @derrapf:
            EIn paar VIS-Adapter lassen sich nicht installieren, bzw. nur nach mehreren Anläufen. `
            Wie machst du das?
            wie Äußert sich das?
            wie gesagt, defekte Pakete werden immer wieder neu installiert, wenn du nicht vorher mit
            sudo npm cache clean
            dafür sorgst, dass die defekten Pakete aus dem Zwischenspeicher verschwinden.
            @derrapf:
            Die Metro-Widgets sind "kaputt", bzw. werden nicht angezeigt und können auch nicht verwendet werden. Habe sie schon zweimal removed und wieder geadded. `
            dito!
            Und nach der Neuinstallation unbedingt .vis neu starten!!
            Ich würde dir gerne helfen ein komplettes problemloses System aufzusetzen, leider weiß ich nicht wo der Fehler liegt, im Moment flicken wir an einem ggf. komplett korrupten System herum (Du weißt das ioBroker aus mehreren zigtausend kleinen Einzeldateien besteht?)
              derrapf
              #73
              Hallo Rainer
              Das Problem ignorieren löst es leider nicht;-)
              Ich wäre auch froh wenn ich ein Kabel verwenden könnte, aber ich kann halt nicht. Mögen hin oder her. WLAN ist die einzige Möglichkeit.
              Abgesehen davon: Ich habe auch Drops mit dem kabelgebundenen Netzwerk. Also ich bin mir nicht wirklich sicher ob's am WLAN liegt.
              Ich hatte mit der alten IOBroker Installation und VIS auch oft Hänger in der Verbindung. Deswegen laufen auf diesem BaPi Scripte, die das Netzwerk restarten bzw. in hartnäckigen Fällen den BaPi rebooten.
              Seit ich ein OpenWRT auf dem Rooter verwende sind diese Hänger aber selten geworden.
              Auch alle anderen Geräte haben keine Probleme mit dem WLAN (u.A. ein Raspberry Pi, ein Tablet, vier Handys, zwei Laptops). Speziell auf dem Laptop hab ich nie irgendwelche Abbrueche bemerkt.
              Als ich vor einem Jahr Jessie mal selber versucht habe auf dem Raspi zu installieren, habe ich exakt den gleichen Effekt gehabt. (unabhängig von IOBroker). Die SSH Session ist ständig abgebrochen. Auch dem Wheezy hatte ich nie!!! Probleme mit der SSH Session.
              Was ist also der Unterschied? Da fallen mir zwei Sachen ein: 1) Das neue System (und ev. andere Treiber) 2) Das verwendete Netzteil, denn so lange ich am Basteln bin verwende ich aktuell ein anderes Netzteil als das, das an dem stabil laufenden BaPi hängt.
              Punkt 2 könnte man ja mal spassehalber ändern.
              Was mich aber irritiert ist, dass auf einmal VIS wieder Abbrueche meldet, obwohl der BaPi inzwischen am Kabel hängt:
              Das hatte ich schon lange nicht mehr.
              ` > Wie machst du das?
              wie Äußert sich das? `
              Das Wie: Ich bin auf den Adapter-Reiter und habe auf das + gedrückt.
              Dann kommt ein Fenster mit Text.
              Oft war es so, dass das Fenster sich nicht beendet hat, oder Fehler gemeldet wurden.
              Ich habe einen Widged Satz dann mal auf der Commandline installiert. Da konnte man sehen, dass das Paket mit wget herunter geladen wurde und dann versucht wurde es zu entpacken. Bei der Gelegenheit hat der Unzip einen Fehler geworfen: Entweder ungültiges Archiv oder Teil eines Archivs bei dem die anderen Teile fehlen. An die anderen Fehlermeldungen die ab und zu noch kamen, kann ich mich nicht mehr erinnern. Auf jeden Fall scheinen jetzt alle Widget-Sätze da zu sein.
              Ich versuche jetzt den Trick mit sudo npm cache clean. Ev. wurden wirklich defekte Paktet heruntergeladen.
              Ich würde ja gerne alles auf der Cpmmandline machen (mir ev. sogar ein script schreiben, das alle Adapter installiert) aber ich weiss nicht auswendig wie die Pakete heissen und man kanns auch nirgends sehen (ausser man installiert im Webui).
              Danke.
              Kannst Du mal bitte parallel schauen ob auf Deinem Image WLAN geht? Wenn ja liegt es an meiner Infrastruktur; wenn nicht ev. doch an Jessie.
              Ich werde solange versuchen die einzelnen Pakete nochmal zu installieren.
              Ist mir bekannt. 72881 aktuell mit Verzeichnissen.
              Gruss Ralf
                derrapf
                #74
                So.
                Habe alles was mit VIS* zu tun hat deleted, den Cache gecleant und alles neu geadded. Diesmal per Script damit ich's öfter machen kann.
                #!/bin/sh
                cd /opt/iobroker
                ./iobroker stop
                ./iobroker add vis
                ./iobroker add vis-metro
                 ./iobroker add vis-rgraph
                 ./iobroker add vis-plumb
                 ./iobroker add vis-players
                 ./iobroker add vis-map
                 ./iobroker add vis-keyboard
                 ./iobroker add vis-lcars
                 ./iobroker add vis-justgage
                 ./iobroker add vis-hqwidgets
                 ./iobroker add vis-jqui-mfd
                 ./iobroker add vis-fancyswitch
                 ./iobroker add vis-colorpicker
                 ./iobroker add vis-canvas-gauges
                 ./iobroker add vis-bars
                 ./iobroker add vis-google-fonts
                 ./iobroker add vis-history
                 ./iobroker start
                Kein Unterschied. Die Metro Widgets funktionieren nicht.
                Ich hab auch das Log voller Fehler mit denen ich nichts anfangen kann:
                Broker-BPi	2017-01-09 00:36:15.384	info	host.ioBroker-BPi Restart adapter system.adapter.javascript.0 because enabled
                ioBroker-BPi	2017-01-09 00:36:15.379	error	host.ioBroker-BPi instance system.adapter.javascript.0 terminated with code 0 (OK)
                javascript.0	2017-01-09 00:36:15.110	info	javascript.0 received all objects
                javascript.0	2017-01-09 00:36:13.639	info	javascript.0 received all states
                javascript.0	2017-01-09 00:36:10.416	info	javascript.0 requesting all objects
                javascript.0	2017-01-09 00:36:10.415	info	javascript.0 requesting all states
                javascript.0	2017-01-09 00:36:10.413	info	javascript.0 starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
                ioBroker-BPi	2017-01-09 00:36:04.442	info	host.ioBroker-BPi instance system.adapter.javascript.0 started with pid 19274
                ioBroker-BPi	2017-01-09 00:35:34.264	info	host.ioBroker-BPi Restart adapter system.adapter.javascript.0 because enabled
                ioBroker-BPi	2017-01-09 00:35:34.263	error	host.ioBroker-BPi instance system.adapter.javascript.0 terminated with code 0 (OK)
                javascript.0	2017-01-09 00:35:33.832	info	javascript.0 received all objects
                javascript.0	2017-01-09 00:35:32.352	info	javascript.0 received all states
                javascript.0	2017-01-09 00:35:29.197	info	javascript.0 requesting all objects
                javascript.0	2017-01-09 00:35:29.196	info	javascript.0 requesting all states
                javascript.0	2017-01-09 00:35:29.195	info	javascript.0 starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
                ioBroker-BPi	2017-01-09 00:35:23.227	info	host.ioBroker-BPi instance system.adapter.javascript.0 started with pid 19237
                host.ioBroker-BPi	2017-01-09 00:34:52.964	info	Restart adapter system.adapter.javascript.0 because enabled
                host.ioBroker-BPi	2017-01-09 00:34:52.962	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                javascript.0	2017-01-09 00:34:52.860	info	terminating
                javascript.0	2017-01-09 00:34:52.668	error	at Zlib.callback (zlib.js:625:5)
                javascript.0	2017-01-09 00:34:52.668	error	at TransformState.afterTransform (_stream_transform.js:54:12)
                javascript.0	2017-01-09 00:34:52.668	error	at afterTransform (_stream_transform.js:79:3)
                javascript.0	2017-01-09 00:34:52.668	error	at WritableState.onwrite (_stream_writable.js:89:5)
                javascript.0	2017-01-09 00:34:52.668	error	at onwrite (_stream_writable.js:345:7)
                javascript.0	2017-01-09 00:34:52.668	error	at afterWrite (_stream_writable.js:354:3)
                javascript.0	2017-01-09 00:34:52.668	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
                javascript.0	2017-01-09 00:34:52.668	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
                javascript.0	2017-01-09 00:34:52.668	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
                javascript.0	2017-01-09 00:34:52.668	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
                javascript.0	2017-01-09 00:34:52.668	error	at WebSocket.emit (events.js:172:7)
                javascript.0	2017-01-09 00:34:52.668	error	at emitTwo (events.js:87:13)
                javascript.0	2017-01-09 00:34:52.668	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
                javascript.0	2017-01-09 00:34:52.668	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                javascript.0	2017-01-09 00:34:52.668	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
                javascript.0	2017-01-09 00:34:52.668	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
                javascript.0	2017-01-09 00:34:52.668	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:34:52.668	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
                javascript.0	2017-01-09 00:34:52.668	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
                javascript.0	2017-01-09 00:34:52.668	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:34:52.668	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:34:52.668	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
                javascript.0	2017-01-09 00:34:52.668	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
                javascript.0	2017-01-09 00:34:52.668	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                javascript.0	2017-01-09 00:34:52.668	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:34:52.668	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                javascript.0	2017-01-09 00:34:52.668	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:34:52.668	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:34:52.668	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                javascript.0	2017-01-09 00:34:52.668	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                javascript.0	2017-01-09 00:34:52.668	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
                javascript.0	2017-01-09 00:34:52.668	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
                javascript.0	2017-01-09 00:34:52.668	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
                javascript.0	2017-01-09 00:34:52.668	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
                javascript.0	2017-01-09 00:34:52.668	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
                javascript.0	2017-01-09 00:34:52.632	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
                javascript.0	2017-01-09 00:34:52.339	info	received all objects
                javascript.0	2017-01-09 00:34:50.557	info	received all states
                javascript.0	2017-01-09 00:34:47.038	info	requesting all objects
                javascript.0	2017-01-09 00:34:47.030	info	requesting all states
                javascript.0	2017-01-09 00:34:46.999	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
                host.	2017-01-09 00:34:46.826	info	States connected to redis 127.0.0.1:6379
                host.ioBroker-BPi	2017-01-09 00:34:40.532	info	instance system.adapter.javascript.0 started with pid 19182
                host.ioBroker-BPi	2017-01-09 00:34:09.655	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
                host.ioBroker-BPi	2017-01-09 00:34:09.186	info	Restart adapter system.adapter.javascript.0 because enabled
                host.ioBroker-BPi	2017-01-09 00:34:09.183	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                javascript.0	2017-01-09 00:34:09.062	info	terminating
                javascript.0	2017-01-09 00:34:09.010	error	at Zlib.callback (zlib.js:625:5)
                javascript.0	2017-01-09 00:34:09.010	error	at TransformState.afterTransform (_stream_transform.js:54:12)
                javascript.0	2017-01-09 00:34:09.010	error	at afterTransform (_stream_transform.js:79:3)
                javascript.0	2017-01-09 00:34:09.010	error	at WritableState.onwrite (_stream_writable.js:89:5)
                javascript.0	2017-01-09 00:34:09.010	error	at onwrite (_stream_writable.js:345:7)
                javascript.0	2017-01-09 00:34:09.010	error	at afterWrite (_stream_writable.js:354:3)
                javascript.0	2017-01-09 00:34:09.010	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
                javascript.0	2017-01-09 00:34:09.010	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
                javascript.0	2017-01-09 00:34:09.010	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
                javascript.0	2017-01-09 00:34:09.010	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
                javascript.0	2017-01-09 00:34:09.010	error	at WebSocket.emit (events.js:172:7)
                javascript.0	2017-01-09 00:34:09.010	error	at emitTwo (events.js:87:13)
                javascript.0	2017-01-09 00:34:09.010	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
                javascript.0	2017-01-09 00:34:09.010	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                javascript.0	2017-01-09 00:34:09.010	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
                javascript.0	2017-01-09 00:34:09.010	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
                javascript.0	2017-01-09 00:34:09.010	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:34:09.010	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
                javascript.0	2017-01-09 00:34:09.010	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
                javascript.0	2017-01-09 00:34:09.010	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:34:09.010	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:34:09.010	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
                javascript.0	2017-01-09 00:34:09.010	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
                javascript.0	2017-01-09 00:34:09.010	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                javascript.0	2017-01-09 00:34:09.010	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:34:09.010	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                javascript.0	2017-01-09 00:34:09.010	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:34:09.010	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:34:09.010	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                javascript.0	2017-01-09 00:34:09.010	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                javascript.0	2017-01-09 00:34:09.010	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
                javascript.0	2017-01-09 00:34:09.010	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
                javascript.0	2017-01-09 00:34:09.010	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
                javascript.0	2017-01-09 00:34:09.010	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
                javascript.0	2017-01-09 00:34:09.010	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
                javascript.0	2017-01-09 00:34:08.979	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
                javascript.0	2017-01-09 00:34:08.766	info	received all objects
                dwd.0	2017-01-09 00:34:08.148	info	starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.dwd, node: v4.5.0
                host.	2017-01-09 00:34:07.775	info	States connected to redis 127.0.0.1:6379
                javascript.0	2017-01-09 00:34:06.729	info	received all states
                javascript.0	2017-01-09 00:34:01.862	info	requesting all objects
                javascript.0	2017-01-09 00:34:01.845	info	requesting all states
                javascript.0	2017-01-09 00:34:01.810	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
                host.	2017-01-09 00:34:01.574	info	States connected to redis 127.0.0.1:6379
                host.ioBroker-BPi	2017-01-09 00:34:00.543	info	instance system.adapter.dwd.0 started with pid 19141
                host.ioBroker-BPi	2017-01-09 00:33:55.599	info	instance system.adapter.javascript.0 started with pid 19134
                host.ioBroker-BPi	2017-01-09 00:33:25.511	info	Restart adapter system.adapter.javascript.0 because enabled
                host.ioBroker-BPi	2017-01-09 00:33:25.509	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                javascript.0	2017-01-09 00:33:25.459	info	terminating
                javascript.0	2017-01-09 00:33:25.276	error	at Zlib.callback (zlib.js:625:5)
                javascript.0	2017-01-09 00:33:25.276	error	at TransformState.afterTransform (_stream_transform.js:54:12)
                javascript.0	2017-01-09 00:33:25.276	error	at afterTransform (_stream_transform.js:79:3)
                javascript.0	2017-01-09 00:33:25.276	error	at WritableState.onwrite (_stream_writable.js:89:5)
                javascript.0	2017-01-09 00:33:25.276	error	at onwrite (_stream_writable.js:345:7)
                javascript.0	2017-01-09 00:33:25.276	error	at afterWrite (_stream_writable.js:354:3)
                javascript.0	2017-01-09 00:33:25.276	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
                javascript.0	2017-01-09 00:33:25.276	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
                javascript.0	2017-01-09 00:33:25.276	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
                javascript.0	2017-01-09 00:33:25.276	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
                javascript.0	2017-01-09 00:33:25.276	error	at WebSocket.emit (events.js:172:7)
                javascript.0	2017-01-09 00:33:25.276	error	at emitTwo (events.js:87:13)
                javascript.0	2017-01-09 00:33:25.276	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
                javascript.0	2017-01-09 00:33:25.276	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                javascript.0	2017-01-09 00:33:25.276	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
                javascript.0	2017-01-09 00:33:25.276	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
                javascript.0	2017-01-09 00:33:25.276	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:33:25.276	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
                javascript.0	2017-01-09 00:33:25.276	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
                javascript.0	2017-01-09 00:33:25.276	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:33:25.276	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:33:25.276	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
                javascript.0	2017-01-09 00:33:25.276	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
                javascript.0	2017-01-09 00:33:25.276	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                javascript.0	2017-01-09 00:33:25.276	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:33:25.276	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                javascript.0	2017-01-09 00:33:25.276	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:33:25.276	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:33:25.276	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                javascript.0	2017-01-09 00:33:25.276	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                javascript.0	2017-01-09 00:33:25.276	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
                javascript.0	2017-01-09 00:33:25.276	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
                javascript.0	2017-01-09 00:33:25.276	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
                javascript.0	2017-01-09 00:33:25.276	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
                javascript.0	2017-01-09 00:33:25.276	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
                javascript.0	2017-01-09 00:33:25.248	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
                javascript.0	2017-01-09 00:33:25.037	info	received all objects
                javascript.0	2017-01-09 00:33:23.403	info	received all states
                javascript.0	2017-01-09 00:33:19.894	info	requesting all objects
                javascript.0	2017-01-09 00:33:19.887	info	requesting all states
                javascript.0	2017-01-09 00:33:19.857	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
                host.	2017-01-09 00:33:19.674	info	States connected to redis 127.0.0.1:6379
                host.ioBroker-BPi	2017-01-09 00:33:14.010	info	instance system.adapter.javascript.0 started with pid 19116
                host.ioBroker-BPi	2017-01-09 00:32:43.920	info	Restart adapter system.adapter.javascript.0 because enabled
                host.ioBroker-BPi	2017-01-09 00:32:43.918	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                javascript.0	2017-01-09 00:32:43.868	info	terminating
                javascript.0	2017-01-09 00:32:43.697	error	at Zlib.callback (zlib.js:625:5)
                javascript.0	2017-01-09 00:32:43.697	error	at TransformState.afterTransform (_stream_transform.js:54:12)
                javascript.0	2017-01-09 00:32:43.697	error	at afterTransform (_stream_transform.js:79:3)
                javascript.0	2017-01-09 00:32:43.697	error	at WritableState.onwrite (_stream_writable.js:89:5)
                javascript.0	2017-01-09 00:32:43.697	error	at onwrite (_stream_writable.js:345:7)
                javascript.0	2017-01-09 00:32:43.697	error	at afterWrite (_stream_writable.js:354:3)
                javascript.0	2017-01-09 00:32:43.697	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
                javascript.0	2017-01-09 00:32:43.697	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
                javascript.0	2017-01-09 00:32:43.697	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
                javascript.0	2017-01-09 00:32:43.697	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
                javascript.0	2017-01-09 00:32:43.697	error	at WebSocket.emit (events.js:172:7)
                javascript.0	2017-01-09 00:32:43.697	error	at emitTwo (events.js:87:13)
                javascript.0	2017-01-09 00:32:43.697	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
                javascript.0	2017-01-09 00:32:43.697	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                javascript.0	2017-01-09 00:32:43.697	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
                javascript.0	2017-01-09 00:32:43.697	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
                javascript.0	2017-01-09 00:32:43.697	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:32:43.697	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
                javascript.0	2017-01-09 00:32:43.697	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
                javascript.0	2017-01-09 00:32:43.697	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:32:43.697	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:32:43.697	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
                javascript.0	2017-01-09 00:32:43.697	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
                javascript.0	2017-01-09 00:32:43.697	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                javascript.0	2017-01-09 00:32:43.697	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:32:43.697	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                javascript.0	2017-01-09 00:32:43.697	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:32:43.697	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:32:43.697	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                javascript.0	2017-01-09 00:32:43.697	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                javascript.0	2017-01-09 00:32:43.697	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
                javascript.0	2017-01-09 00:32:43.697	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
                javascript.0	2017-01-09 00:32:43.697	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
                javascript.0	2017-01-09 00:32:43.697	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
                javascript.0	2017-01-09 00:32:43.697	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
                javascript.0	2017-01-09 00:32:43.672	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
                javascript.0	2017-01-09 00:32:43.505	info	received all objects
                javascript.0	2017-01-09 00:32:41.871	info	received all states
                javascript.0	2017-01-09 00:32:38.149	info	requesting all objects
                javascript.0	2017-01-09 00:32:38.142	info	requesting all states
                javascript.0	2017-01-09 00:32:38.112	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
                host.	2017-01-09 00:32:37.925	info	States connected to redis 127.0.0.1:6379
                host.ioBroker-BPi	2017-01-09 00:32:32.288	info	instance system.adapter.javascript.0 started with pid 19080
                host.ioBroker-BPi	2017-01-09 00:32:02.195	info	Restart adapter system.adapter.javascript.0 because enabled
                host.ioBroker-BPi	2017-01-09 00:32:02.193	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                javascript.0	2017-01-09 00:32:02.143	info	terminating
                javascript.0	2017-01-09 00:32:02.024	error	at Zlib.callback (zlib.js:625:5)
                javascript.0	2017-01-09 00:32:02.024	error	at TransformState.afterTransform (_stream_transform.js:54:12)
                javascript.0	2017-01-09 00:32:02.024	error	at afterTransform (_stream_transform.js:79:3)
                javascript.0	2017-01-09 00:32:02.024	error	at WritableState.onwrite (_stream_writable.js:89:5)
                javascript.0	2017-01-09 00:32:02.024	error	at onwrite (_stream_writable.js:345:7)
                javascript.0	2017-01-09 00:32:02.024	error	at afterWrite (_stream_writable.js:354:3)
                javascript.0	2017-01-09 00:32:02.024	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
                javascript.0	2017-01-09 00:32:02.024	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
                javascript.0	2017-01-09 00:32:02.024	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
                javascript.0	2017-01-09 00:32:02.024	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
                javascript.0	2017-01-09 00:32:02.024	error	at WebSocket.emit (events.js:172:7)
                javascript.0	2017-01-09 00:32:02.024	error	at emitTwo (events.js:87:13)
                javascript.0	2017-01-09 00:32:02.024	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
                javascript.0	2017-01-09 00:32:02.024	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                javascript.0	2017-01-09 00:32:02.024	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
                javascript.0	2017-01-09 00:32:02.024	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
                javascript.0	2017-01-09 00:32:02.024	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:32:02.024	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
                javascript.0	2017-01-09 00:32:02.024	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
                javascript.0	2017-01-09 00:32:02.024	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:32:02.024	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:32:02.024	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
                javascript.0	2017-01-09 00:32:02.024	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
                javascript.0	2017-01-09 00:32:02.024	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                javascript.0	2017-01-09 00:32:02.024	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:32:02.024	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                javascript.0	2017-01-09 00:32:02.024	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                javascript.0	2017-01-09 00:32:02.024	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                javascript.0	2017-01-09 00:32:02.024	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                javascript.0	2017-01-09 00:32:02.024	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                javascript.0	2017-01-09 00:32:02.024	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
                javascript.0	2017-01-09 00:32:02.024	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
                javascript.0	2017-01-09 00:32:02.024	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
                javascript.0	2017-01-09 00:32:02.024	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
                javascript.0	2017-01-09 00:32:02.024	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
                javascript.0	2017-01-09 00:32:01.990	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
                javascript.0	2017-01-09 00:32:01.790	info	received all objects
                javascript.0	2017-01-09 00:32:00.307	info	received all states
                javascript.0	2017-01-09 00:31:56.721	info	requesting all objects
                javascript.0	2017-01-09 00:31:56.714	info	requesting all states
                javascript.0	2017-01-09 00:31:56.684	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.5.0
                host.	2017-01-09 00:31:56.511	info	States connected to redis 127.0.0.1:6379
                host.ioBroker-BPi	2017-01-09 00:31:47.851	info	instance system.adapter.javascript.0 started with pid 19043
                host.ioBroker-BPi	2017-01-09 00:31:17.751	info	Restart adapter system.adapter.javascript.0 because enabled
                host.ioBroker-BPi	2017-01-09 00:31:17.749	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                javascript.0	2017-01-09 00:31:17.705	info	terminating
                debug	at Zlib.callback (zlib.js:625:5)
                debug	at TransformState.afterTransform (_stream_transform.js:54:12)
                debug	at afterTransform (_stream_transform.js:79:3)
                debug	at WritableState.onwrite (_stream_writable.js:89:5)
                debug	at onwrite (_stream_writable.js:345:7)
                debug	at afterWrite (_stream_writable.js:354:3)
                debug	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
                debug	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
                debug	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
                debug	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
                debug	at WebSocket.emit (events.js:172:7)
                debug	at emitTwo (events.js:87:13)
                debug	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
                debug	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                debug	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
                debug	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
                debug	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                debug	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
                Auch auffällig: Obwohl oben im Script nur einmal "add vis-players" steht, kommt ein Fehler, dass man den nicht mehrfach installieren kann:
                host.ioBroker-BPi install adapter vis-plumb
                npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.vis-plumb"
                got /opt/iobroker/node_modules/iobroker.vis-plumb/admin
                upload [1] vis-plumb.admin /opt/iobroker/node_modules/iobroker.vis-plumb/admin/plumb.png plumb.png image/png
                upload [0] vis-plumb.admin /opt/iobroker/node_modules/iobroker.vis-plumb/admin/index.html index.html text/html
                Adapter "system.adapter.vis.0" restarted.
                host.ioBroker-BPi object system.adapter.vis-plumb created
                host.ioBroker-BPi create instance vis-plumb
                host.ioBroker-BPi object system.adapter.vis-plumb.0 created
                npm install iobroker.vis-players --production --prefix "/opt/iobroker" (System call)
                host.ioBroker-BPi install adapter vis-players
                npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.vis-players"
                got /opt/iobroker/node_modules/iobroker.vis-players/admin
                upload [0] vis-players.admin /opt/iobroker/node_modules/iobroker.vis-players/admin/players.png players.png image/png
                host.ioBroker-BPi object system.adapter.vis-players created
                host.ioBroker-BPi create instance vis-players
                host.ioBroker-BPi object system.adapter.vis-players.0 created
                host.ioBroker-BPi error: this adapter does not allow multiple instances
                npm install iobroker.vis-map --production --prefix "/opt/iobroker" (System call)
                host.ioBroker-BPi install adapter vis-map
                npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.vis-map"
                got /opt/iobroker/node_modules/iobroker.vis-map/admin
                upload [1] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/vis-map.png vis-map.png image/png
                upload [0] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/index.html index.html text/html
                host.ioBroker-BPi object system.adapter.vis-map created
                host.ioBroker-BPi create instance vis-map
                host.ioBroker-BPi object system.adapter.vis-map.0 created
                npm install iobroker.vis-keyboard --production --prefix "/opt/iobroker" (System call)
                host.ioBroker-BPi install adapter vis-keyboard
                npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.vis-keyboard"
                got /opt/iobroker/node_modules/iobroker.vis-keyboard/admin
                upload [1] vis-keyboard.admin /opt/iobroker/node_modules/iobroker.vis-keyboard/admin/keyboard.png keyboard.png image/png
                upload [0] vis-keyboard.admin /opt/iobroker/node_modules/iobroker.vis-keyboard/admin/index.html index.html text/html
                host.ioBroker-BPi object system.adapter.vis-keyboard created
                host.ioBroker-BPi create instance vis-keyboard
                host.ioBroker-BPi object system.adapter.vis-keyboard.0 created
                npm install iobroker.vis-lcars --production --prefix "/opt/iobroker" (System call)
                Gruss Ralf
                  #75
                  @derrapf:
                  Punkt 2 könnte man ja mal spassehalber ändern. `
                  Punkt 2 ist gar nicht so abwegig.
                  @derrapf:
                  Kannst Du mal bitte parallel schauen ob auf Deinem Image WLAN geht? Wenn ja liegt es an meiner Infrastruktur; `
                  Das klingt interessant und reizt mich irgendwie, aber ich habe an einem BPi kein WLAN.
                  @derrapf:
                  Ev. wurden wirklich defekte Paktet heruntergeladen. `
                  @derrapf:
                  der Unzip einen Fehler geworfen: Entweder ungültiges Archiv oder Teil eines Archivs bei dem die anderen Teile fehlen `
                  also defekt! 😢
                  @derrapf:
                  Ich würde ja gerne alles auf der Cpmmandline machen (mir ev. sogar ein script schreiben, das alle Adapter installiert) aber ich weiss nicht auswendig wie die Pakete heissen `
                  Habe ich für die alten Images auch gemacht (damals hatte ich schon alles vorinstalliert), die Namen bekommst du mit sudo iobroker update
                    derrapf
                    #76
                    Hallo Rainer
                    "ipbroker update" updated den js-controller?
                    Ich trau mich mal. Das hatte schon mal früher meinen IOBroker zerissen. Aber jetzt ist es eh Wurst. Der Produktive läuft ja problemlos.
                    EIns noch: Es nervt total dass beim Restart der stop job für den IOBroker 5Minuten lang läuft. Hast Du das auch? Wie kann man denn das abkürzen?
                    Gruss Ralf
                      #77
                      @derrapf:
                      "ipbroker update" updated den js-controller? `
                      Nein, wie bei "apt-get update" werden nur die neuesten Paketlisten geholt.
                      @derrapf:
                      Es nervt total dass beim Restart der stop job für den IOBroker 5Minuten lang läuft. Hast Du das auch? `
                      Nein - ich habe aber im Moment keinen Dualcore mehr im Einsatz. Es ist zwar lange - aber wirklich soo lange würde ich jetzt aus dem Bauch heraus sagen, sollte es nicht sein.
                      Könnte deine Hardware vielleicht einen Knacks haben?
                        derrapf
                        #78
                        Hallo Rainer
                        Erstmal die Guten Nachichten. Ich habe jetzt nochmal per Script alles was mit VIS zu tun hat deleted.
                        Interessanterweise wurden da nochmal Dateien gelöscht, obwohl eigentlich die Adapter schon offiziell über die Weboberfläche deleted wurden.
                        Ich habe das Script dann sicherheitshalber zweimal laufen lassen.
                        Danach den Cache gecleant und wieder das Script zum Hinzufügen der Adapter über Nacht laufen lassen.
                        Dann reboot.
                        Jetzt sind die Metro Widgets da!!
                        Allerdings habe ich immer noch Probleme mit VIS:
                        Selbst mit Kabel am Bapi kommt immer wieder das hier:
                        und danach wird der Verbindungsfehler angezeigt (siehe Bild in dem anderen Post).
                        Im Log kommt auch weiterhin der Fehler
                        host.ioBroker-BPi	2017-01-09 13:31:15.697	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
                        javascript.0	2017-01-09 13:31:15.652	info	terminating
                        javascript.0	2017-01-09 13:31:15.630	error	at Zlib.callback (zlib.js:625:5)
                        javascript.0	2017-01-09 13:31:15.630	error	at TransformState.afterTransform (_stream_transform.js:54:12)
                        javascript.0	2017-01-09 13:31:15.630	error	at afterTransform (_stream_transform.js:79:3)
                        javascript.0	2017-01-09 13:31:15.630	error	at WritableState.onwrite (_stream_writable.js:89:5)
                        javascript.0	2017-01-09 13:31:15.630	error	at onwrite (_stream_writable.js:345:7)
                        javascript.0	2017-01-09 13:31:15.630	error	at afterWrite (_stream_writable.js:354:3)
                        javascript.0	2017-01-09 13:31:15.630	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:249:5
                        javascript.0	2017-01-09 13:31:15.630	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:368:7
                        javascript.0	2017-01-09 13:31:15.630	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:536:18
                        javascript.0	2017-01-09 13:31:15.630	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:841:10)
                        javascript.0	2017-01-09 13:31:15.630	error	at WebSocket.emit (events.js:172:7)
                        javascript.0	2017-01-09 13:31:15.630	error	at emitTwo (events.js:87:13)
                        javascript.0	2017-01-09 13:31:15.630	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
                        javascript.0	2017-01-09 13:31:15.630	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                        javascript.0	2017-01-09 13:31:15.630	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
                        javascript.0	2017-01-09 13:31:15.630	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
                        javascript.0	2017-01-09 13:31:15.630	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        javascript.0	2017-01-09 13:31:15.630	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
                        javascript.0	2017-01-09 13:31:15.630	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
                        javascript.0	2017-01-09 13:31:15.630	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        javascript.0	2017-01-09 13:31:15.630	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                        javascript.0	2017-01-09 13:31:15.630	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
                        javascript.0	2017-01-09 13:31:15.630	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
                        javascript.0	2017-01-09 13:31:15.630	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                        javascript.0	2017-01-09 13:31:15.630	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                        javascript.0	2017-01-09 13:31:15.630	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                        javascript.0	2017-01-09 13:31:15.630	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        javascript.0	2017-01-09 13:31:15.630	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                        javascript.0	2017-01-09 13:31:15.630	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                        javascript.0	2017-01-09 13:31:15.630	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                        javascript.0	2017-01-09 13:31:15.630	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:316:37)
                        javascript.0	2017-01-09 13:31:15.630	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2600:20)
                        javascript.0	2017-01-09 13:31:15.630	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2575:41)
                        javascript.0	2017-01-09 13:31:15.630	error	at Object.module.exports.compiler.fromSource (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler/coffee-compiler.js:31:38)
                        javascript.0	2017-01-09 13:31:15.630	error	TypeError: coffee.helpers.prettyErrorMessage is not a function
                        javascript.0	2017-01-09 13:31:15.605	error	uncaught exception: coffee.helpers.prettyErrorMessage is not a function
                        javascript.0	2017-01-09 13:31:15.441	info	received all objects
                        javascript.0	2017-01-09 13:31:13.984	info	received all states
                        Ich kann mir nicht vorstellen, dass die Hardware einen Schuss haben sollte (welchen denn?). Dann würde ja gar nichts gehen.
                        Ich kann aber auch gerne mal einen anderen Bapi verwenden.
                        Bei Dir beendet sich der Bapi schneller wenn Du "sudo restart" eingibst? Hast das mal gemacht?
                        Das einzge was mir jetzt noch einfällt ist, dass ich mir ein Script baue das den Bapi auf Stand bringt und Iobroker updated und ich danach nochmal mit Deinem Image anfange.
                        Dazu muss ich mir noch alle Konfigurationsdateien und Scripte aufs NAS kopieren und das dann mounten.
                        Gruss Ralf
                          #79
                          Hallo Ralf,
                          @derrapf:
                          Bei Dir beendet sich der Bapi schneller wenn Du "sudo restart" eingibst? Hast das mal gemacht? `
                          Ich habe keinen BPi (Standard) aktiv. Den habe ich nur zur Erstellung des Images aktiviert gehabt.
                          Wenn du nicht als root auf der Konsole bist MUSST du immer mit sudo arbeiten.
                          Gerade die Befehle stop, start und update, install usw. funktionieren sonst nicht.
                          @derrapf:
                          Ich kann mir nicht vorstellen, dass die Hardware einen Schuss haben sollte (welchen denn?). Dann würde ja gar nichts gehen. `
                          ich könnte mir vorstellen, dass es bei einigen Hardwareschäden, die noch nicht final sind, z.B. bei Speicherproblemen einzelner Zellen oder eines internen controllers (Netzwerk??), der langsam in die Knie geht schon zu solchen Phänomenen kommen könnte.
                          @derrapf:
                          Das einzge was mir jetzt noch einfällt ist, dass ich mir ein Script baue das den Bapi auf Stand bringt und Iobroker updated und ich danach nochmal mit Deinem Image anfange. `
                          Klingt gut:
                          Zuerst das dateisystem expandieren, dann mit````
                          sudo apt-get update && apt-get upgrade
                          Dann am besten ebenfalls aus der Konsole ioBroker aktualisieren:
                          cd /opt/iobroker
                          sudo iobroker stop
                          sudo iobroker upgrade
                          sudo iobroker start
                          ~~@derrapf:~~
                          > Dazu muss ich mir noch alle Konfigurationsdateien und Scripte aufs NAS kopieren und das dann mounten. `
                          noch mehr WLAN traffic???
                          Viel Glück!
                          • Jeeper.atJ Offline
                            Jeeper.atJ Offline
                            Jeeper.at
                            #80
                            Der Websocket Error ist voriges Jahr im November mal hineingekommen.
                            Dazu gibt es folgenden Thread:
                            http://forum.iobroker.net/viewtopic.php?f=22&t=4221
                            Der Fehler ist nach wie vor vorhanden.
                            Lg
                            Günther
                              derrapf
                              #81
                              Hi Rainer
                              @Homoran:
                              Ich habe keinen BPi (Standard) aktiv. Den habe ich nur zur Erstellung des Images aktiviert gehabt. `
                              Mist. Dann hab ich keine Referenz.
                              @Homoran:
                              Gerade die Befehle stop, start und update, install usw. funktionieren sonst nicht. `
                              Ich bin aktuell immer root. Und ich habe auch sudo davor geschrieben.
                              @Homoran:
                              ich könnte mir vorstellen, dass es bei einigen Hardwareschäden, die noch nicht final sind, z.B. bei Speicherproblemen einzelner Zellen oder eines internen controllers (Netzwerk??), der langsam in die Knie geht schon zu solchen Phänomenen kommen könnte. `
                              OK. Dann tausche ich einfach mal die PIs.
                              @Homoran:
                              Zuerst das dateisystem expandieren, dann mitsudo apt-get update && apt-get upgradeLinux auf den neuesten Stand bringen. `
                              Ist das ne gute Idee? Der letzte sudo apt-get upgrade hat das System auf die Bretter gebracht.
                              Obwohl…vielleicht hatte das ja auch mi den WLAN Drops zu tun...
                              @Homoran:
                              cd /opt/iobroker
                              sudo iobroker stop
                              sudo iobroker start
                              Das aktualisiert dann nur die installierten Adapter, richtig?
                              @Homoran:
                              @derrapf:
                              Dazu muss ich mir noch alle Konfigurationsdateien und Scripte aufs NAS kopieren und das dann mounten. noch mehr WLAN traffic???
                              Nein! Ich sagte doch: Der BaPi hängt jetzt erstmal für die Konfiguration am Kabel!!
                              Aber das scheint ja auch nicht viel zu nützen…
                              @Homoran:
                              Viel Glück! `
                              Danke!
                              Ich melde mich. Kann aber ein bischen dauern. Habe heute wieder angefangen zu arbeiten.
                              Gruss Ralf
                                Jeeper.atJ Offline
                                Jeeper.at
                                #82
                                Nur für den Fall, das mein Post eine Seite vorher untergegangen ist (haben gerade zeitgleich geschrieben).
                                Lg
                                Günther
                                  derrapf
                                  #83
                                  Hallo Günther
                                  Danke für den Hinweis. Ist tatsächlich untergegangen.
                                  Ich schau mir den Thread heute abend gleich mal an.
                                  Gruss Ralf
                                    derrapf
                                    #84
                                    Hallo Rainer
                                    Ich habe jetzt nochmal ganz von vorne angefangen.
                                    Dein Image aufgepielt und /etc/defaut/keyboard auf de gesetzt.
                                    Dann sudo reboot.
                                    Ergebnis:````
                                    A stop job is running for LSB: starts ioBroker (5min/5min)
                                    Das heisst aus irgendwelchen Gründen braucht das Beenden des iobroker 5 Minuten!
                                    Das kann doch nicht sein. Da ist irgendwas fault.
                                    Das müsstest Du auch reprduzieren können.
                                    Ich habe jetzt leider zu weng Linux KnowHow um zu wissen was man dagegen tut. Aber ev. weiss das jemand anders.
                                    Was mir aufällt: Warum heisst es "starts iobroker" wenn ich den Rechner runterfahre? Ist da irgendwo vielleicht was falsch konfiguriert?
                                    Gruss Ralf
                                      derrapf
                                      #85
                                      Nächster Statusbericht
                                      • Dein Image auf die Karte gespielt (jetzt das dritte Mal)
                                      • Plattenplatz erweitert
                                      • Password angepasst
                                      • Tastatur auf deutsch umgestellt
                                      Dann:
                                      • apt-get upfate
                                      • apt-get upgrade
                                      Der bringt am Ende aber zig Fehler:
                                      U.a.
                                      Bin ich zu doof das System upzugraden? Mach ich was falsch?
                                      Kan mir da jemand weiter helfen?
                                      Auf jeden Fall ist nach dem Reboot alles am A….
                                      Das sieht dann so aus:
                                      Gruss Ralf
                                        #86
                                        Du bist sicher dass du einen BananaPi hast ;-)
                                        der BPi hat einen A20 SOC, da müssten oben 2 Pinguine sein, oder ist das schon ein Folgescreen, den ich nie sehe weil ich nur mit putty arbeite?
                                        @derrapf:
                                        Kan mir da jemand weiter helfen? `
                                        Oder ist die Kiste doch defekt?
                                        Ich denke, dass ich sonst morgen ein neues Image mache ;-)
                                        dann kann ich wenigstens parallel testen.
                                          #87
                                          Ein neues BPi-Image ist auf der Website!
                                          Läuft bei mir, aber anscheinend funktioniert das Erstinstallscript nicht.
                                          Bitte um feedback!
