IoBroker Alexa Bewegungsmeldern
@kippe Das ist ja nu wirklich nicht so kompliziert nachzubauen, aber bitte :
<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable type="timeout" id="timeout2">timeout2</variable> <variable type="timeout" id="timeout">timeout</variable> </variables> <block type="comment" id="7J#)|bik8LvmnjrCa:bP" x="-238" y="13"> <field name="COMMENT">Trigger: Hue BWM mit state.presence</field> <next> <block type="on" id="1I~;0Y:yWavg}!Vu`ijC"> <field name="OID">hue-extended.0.sensors.048-sensor_gästeklo.state.presence</field> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="controls_if" id="SL=gEl0@-F;HE$91PgUw"> <value name="IF0"> <block type="time_compare" id="9Y_Gf94)F-8#XGl:`83X"> <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation> <field name="OPTION">not between</field> <field name="START_TIME">00:45</field> <field name="END_TIME">06:00</field> </block> </value> <statement name="DO0"> <block type="controls_if" id=",B_A}?YvOt}0/i.hP-Cm"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_operation" id="TVn3J2.T)*85?$D(;KPV"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="wcPphA2T/|x_e+NMiOt*"> <field name="OP">GT</field> <value name="A"> <block type="time_get" id="o-X;YDY_#|#H;,3zkb{i"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">wd</field> </block> </value> <value name="B"> <block type="math_number" id="@U4t2chabh#t}pSLy6p2"> <field name="NUM">5</field> </block> </value> </block> </value> <value name="B"> <block type="time_compare" id="Ev!vC.`Aczyl-`@C}?Y9"> <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation> <field name="OPTION">between</field> <field name="START_TIME">13:00</field> <field name="END_TIME">19:30</field> </block> </value> </block> </value> <statement name="DO0"> <block type="controls_if" id="B^_M;L[V{oCL:k0|+l//"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_compare" id="WkXk=33d[:H@V(o~E{01"> <field name="OP">EQ</field> <value name="A"> <block type="on_source" id="*EV..b~TxK1(jM$sf!KX"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="logic_boolean" id=")Q.dfLHg#qHzh=R?||;$"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_cleartimeout" id="tu~Zah,#*Ka#.s4Y$6`."> <field name="NAME">timeout</field> <next> <block type="comment" id="phnYxQ2_E.DBaywX%DM^"> <field name="COMMENT">Falls Player schon läuft nicht neu starten, sonst Unterbrechung beim Abspielen</field> <next> <block type="controls_if" id="UUmPF.8Y3;P2wCEzuoJS"> <value name="IF0"> <block type="logic_compare" id="/b;+_h=[30_]Ky/jOdc7"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="E!1q@e!(~nYJ*:3dwj-x"> <field name="ATTR">val</field> <field name="OID">alexa2.0.Echo-Devices.G091JJ09ABCVWXYZ.Player.currentState</field> </block> </value> <value name="B"> <block type="logic_boolean" id="}3wY(wHO)/+Ng1B*Y{3P"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="comment" id="PIo:PG8}-H1n02v8:7DZ"> <field name="COMMENT">Falls Lautstärke zu hoch, runterregeln</field> <next> <block type="controls_if" id="lsx72w=9Uz2t1U~|k[my"> <value name="IF0"> <block type="logic_compare" id="|v=z:;;j?QOUk}KemC%d"> <field name="OP">GT</field> <value name="A"> <block type="get_value" id="3g%NALL.[*N7)[$oxhd~"> <field name="ATTR">val</field> <field name="OID">alexa2.0.Echo-Devices.G091JJ09ABCVWXYZ.Player.volume</field> </block> </value> <value name="B"> <block type="math_number" id=":+0:;Uv4zJd(CcX7-S0{"> <field name="NUM">15</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="p%)%7Id$(q$Janr_V5|E"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G091JJ0ABCVWXYZ.Player.volume</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="nDFKsEKK;Q).h5u:$sqY"> <field name="NUM">15</field> </block> </value> </block> </statement> <next> <block type="comment" id=")I6Rl)GBk[/x}I{C-o6|"> <field name="COMMENT">Mit Verzögerung, damit Lautstärke gesetzt werden kann</field> <next> <block type="control" id="4J@}M*l/Dnm`0);,m/FW"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation> <field name="OID">alexa2.0.Echo-Devices.G091JJ09ABCVWXYZ.Music-Provider.TuneIn</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">500</field> <field name="UNIT">ms</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="text" id="lbpkn+O!#v-=yRMn.mpc"> <field name="TEXT">N-JOY</field> </block> </value> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </statement> <value name="IF1"> <block type="logic_compare" id="~i3w=PosaBQgdg41{t:%"> <field name="OP">EQ</field> <value name="A"> <block type="on_source" id="0y_#:of[-(2@Uh]I-4n7"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="logic_boolean" id="-f%3p,B!o1AZk#r=7{MG"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <statement name="DO1"> <block type="comment" id="5,t~A;CKD}i6nG[;U(SO"> <field name="COMMENT">Ende Play 3 Min nach letzter Bewegung</field> <next> <block type="timeouts_cleartimeout" id="uj:Y-;|c7^qse`aT[rT{"> <field name="NAME">timeout</field> <next> <block type="timeouts_settimeout" id="TV|%1C6Vx^E_AL(q2N/t"> <field name="NAME">timeout</field> <field name="DELAY">180</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="control" id="$[wMZbcGw,o;o2H*gfU="> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G091JJ09ABCVWXYZ.Player.controlPause</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="C5M;G|iC_N=TV2(;|)F+"> <field name="BOOL">TRUE</field> </block> </value> </block> </statement> </block> </next> </block> </next> </block> </statement> </block> </statement> <value name="IF1"> <block type="logic_operation" id="+$Oud+07Uv.a_zVaXxkl"> <field name="OP">OR</field> <value name="A"> <block type="logic_compare" id="h|YJO@|N{r`FI{AFTiY:"> <field name="OP">LTE</field> <value name="A"> <block type="time_get" id="DcqpbSll-[J}K8oTJuGo"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">wd</field> </block> </value> <value name="B"> <block type="math_number" id="+9Cg]yYyRGi![{@cL%H)"> <field name="NUM">5</field> </block> </value> </block> </value> <value name="B"> <block type="time_compare" id=")_?3M~e3L|A3proZ~+i-"> <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation> <field name="OPTION">not between</field> <field name="START_TIME">13:00</field> <field name="END_TIME">19:30</field> </block> </value> </block> </value> <statement name="DO1"> <block type="controls_if" id="kM]Lsa:+Y3|uYg/dom8k"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_compare" id=")8EX4TKe(9-P9jGqZi#P"> <field name="OP">EQ</field> <value name="A"> <block type="on_source" id="Xk!.jH+lo`%#@6d#ec6z"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="logic_boolean" id="C8yP-GN9]?JFwb{9i^0h"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_cleartimeout" id="Lv3`FDe@^!Q5xk/=oO:/"> <field name="NAME">timeout2</field> <next> <block type="controls_if" id="5RRd,Th6o40BkWHOUDEa"> <value name="IF0"> <block type="logic_compare" id="SO0lsB(TFW`e^MC/5X;T"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="J2)soo#*66[}5m)X@43@"> <field name="ATTR">val</field> <field name="OID">alexa2.0.Echo-Devices.G091JJ09ABCVWXYZ.Player.currentState</field> </block> </value> <value name="B"> <block type="logic_boolean" id="Au#(3|kK3U=0dOE~N=e0"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="controls_if" id="/^e%=9EoAW.Gs:0eNb-}"> <value name="IF0"> <block type="logic_compare" id="=7@Ist9]:jHzfW[p(_l*"> <field name="OP">GT</field> <value name="A"> <block type="get_value" id="wPB]]QA[vR6$*`}!;p9-"> <field name="ATTR">val</field> <field name="OID">alexa2.0.Echo-Devices.G091JJ09ABCVWXYZ.Player.volume</field> </block> </value> <value name="B"> <block type="math_number" id="4LtreCx0o`]$KHu.*9J="> <field name="NUM">15</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="b!~[MFI,#$8l+Py|R?p?"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G091JJ09ABCVWXYZ.Player.volume</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="C./wR?idT%QCGFEIyfP4"> <field name="NUM">15</field> </block> </value> </block> </statement> <next> <block type="control" id="AT(90*:d;BgN@Ts0_pro"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation> <field name="OID">alexa2.0.Echo-Devices.G091JJ09ABCVWXYZ.Music-Provider.TuneIn</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">500</field> <field name="UNIT">ms</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="text" id="l4K:Rp##H8YY3OyQk}Ue"> <field name="TEXT">NDR 2</field> </block> </value> </block> </next> </block> </statement> </block> </next> </block> </statement> <value name="IF1"> <block type="logic_compare" id="gRYg!Y3iXQ3^|lYSs:tw"> <field name="OP">EQ</field> <value name="A"> <block type="on_source" id="redR:R;6V9isp[1OhP*j"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="logic_boolean" id="e3e#[kK^3N:f{scfGpWU"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <statement name="DO1"> <block type="timeouts_cleartimeout" id="*4#f~a2h5GY+e{713XAD"> <field name="NAME">timeout2</field> <next> <block type="timeouts_settimeout" id="t};u;xzvWid{;?6|O^W`"> <field name="NAME">timeout2</field> <field name="DELAY">180</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="control" id="@qH|Z)),O|3IwWHh+ALa"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G091JJ09ABCVWXYZ.Player.controlPause</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="8N-~0VG{8@v:oN+{Ev*P"> <field name="BOOL">TRUE</field> </block> </value> </block> </statement> </block> </next> </block> </statement> </block> </statement> </block> </statement> </block> </statement> </block> </next> </block> </xml>
Hallo TomBo1969
Ich habe jetzt mal Zeit gehabt, und habe dein Blockly so übernommen.
Es läuft auch so Weit alles ok, nur mit den Zeiten für Fußball usw brauche ich nicht.
Es klingt echt blöde, aber könntest du mir Eventuell das Blockly so machen, das der Echo nur von 7-22 Uhr angeht.
Ich würde mich sehr freuen -
@kippe du brauchst doch nur das zweite "Falls" in dem nach den Wochentagen abgefragt wird und dann die Einstellungen um zweiten Sender rausschmeißen.
Das bekommst du schon hin!Und im ersten "Falls" deine Uhrzeiten anpassen natürlich..
Ich habe das mal anders aufgezäumt.
Statt mit Timeout mit Intervall.
So kann ich mir in der VIS anzeigen lassen wie lange das Licht bzw. die Musik noch läuft. -
Halllo
Ist das so richtig
Irgend was geht noch nicht so richtig.
Die Musik fängt nicht an zu spielen -
@kippe Keine Ahnung, setze halt debug outputs und schau im Log, ob das Skript überhaupt getriggert wird, ob es in die richtigen Schleifen läuft und teste auch, ob der Aufruf des Radiosenders überhaupt so funktioniert.
Ist ja ein überschaubares Skript, da kannst du die Fehlereingrenzung gut übenPS. Wenn dein Post zeitnah nach deinem Test geschrieben wurde, dann sollte das Radio, bei den von dir festgelegten Uhrzeiten, auch gar nicht spielen..
Ich verstehe die Welt nicht mehr
Bekomme es einfach nicht gebacken -
@kippe
siehe oben vor dem Postscriptum... -
@kippe Die Lautstärke ist ziemlich niedrig. Da kann man ja gar nichts hören? Da sollte vielleicht 50 und 30 als Werte drin stehen und nicht 5 und 3?
