  4. js-controller läuft nicht mehr nach Update ioBroker
    2.0k
11 Beiträge 4 Kommentatoren 541 Aufrufe 4 Beobachtet
    Bj 0
    Habe heute auf die neusten Versionen upgedatet und javascript.0 steht immer auf rot. Alles andere läuft, ioBroker fix, Neuinstallation js usw. ausgeführt ohne Erfolg.
    Folgendes steht im Log:
    host.raspberrypi	2021-04-03 00:33:54.826	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2021-04-03 00:33:54.826	error	Caught by controller[0]: }
    host.raspberrypi	2021-04-03 00:33:54.826	error	Caught by controller[0]: ]
    host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
    host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
    host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: requireStack: [
    host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: {
    host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
    host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
    host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
    host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
    host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: Require stack:
    host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: Error: Cannot find module 'typescript'
    host.raspberrypi	2021-04-03 00:33:54.817	error	Caught by controller[0]: ^
    host.raspberrypi	2021-04-03 00:33:54.817	error	Caught by controller[0]: throw err;
    host.raspberrypi	2021-04-03 00:33:54.816	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
    host.raspberrypi	2021-04-03 00:33:54.412	info	instance system.adapter.javascript.0 started with pid 4402
    host.raspberrypi	2021-04-02 23:33:24.376	info	Restart adapter system.adapter.javascript.0 because enabled
    Hat jemand eine Lösung?
    MOD EDIT: LOG IN CODE TAGS </> GESETZT
    • B Bj 0
      @bj-0
      Bitte den Text in CodeTags packen.
      • B Bj 0
        crunchipC Abwesend
        crunchipC Abwesend
        @bj-0 sagte in js-controller läuft nicht mehr nach Update ioBroker:
        die da wären?
        B 2 Antworten Letzte Antwort
          die da wären?
          Bj 0
          @crunchip sagte in js-controller läuft nicht mehr nach Update ioBroker:
          die da wären?
          auf diese Versionen:
          Node.js: v12.22.0
          NPM: 6.14.11
            @bj-0
            Bj 0
            Ich bin neu hier. Wie packe ich Text in CodeTags?
              die da wären?
              Bj 0
              die da wären?
              und:
              ioBroker.admin 4.2.1
              • B Bj 0
                @bj-0
                Text markieren, dann das </> anklicken.
                Oder anders herum:
                Icon anklicken, Text zwischen die Markierung kopieren.
                  Bj 0
                  Also so:
                  host.raspberrypi	2021-04-03 01:44:56.174	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.raspberrypi	2021-04-03 01:44:56.174	error	Caught by controller[0]: }
                  host.raspberrypi	2021-04-03 01:44:56.174	error	Caught by controller[0]: ]
                  host.raspberrypi	2021-04-03 01:44:56.174	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
                  host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
                  host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
                  host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: requireStack: [
                  host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                  host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: {
                  host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                  host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                  host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                  host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                  host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                  host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
                  host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
                  host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
                  host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
                  host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                  host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                  host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
                  host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
                  host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
                  host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
                  host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                  host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                  host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                  host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
                  host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
                  host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
                  host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
                  host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                  host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                  host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
                  host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
                  host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
                  host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: Require stack:
                  host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: Error: Cannot find module 'typescript'
                  host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: ^
                  host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: throw err;
                  host.raspberrypi	2021-04-03 01:44:56.168	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
                  host.raspberrypi	2021-04-03 01:44:55.764	info	instance system.adapter.javascript.0 started with pid 5968
                  • B Bj 0
                    Also so:
                    @bj-0
                    Schaut nicht gut aus. Was sagt
                    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      @bj-0
                      Bj 0
                      @thomas-braun sagte in js-controller läuft nicht mehr nach Update ioBroker:
                      @bj-0
                      nodejs
                      v12.22.0
                      node
                      v12.22.0
                      npm
                      6.14.11
                      nodejs:
                      12.22.0-1nodesource1
                      • B Bj 0
                        @bj-0
                        nodejs
                        v12.22.0
                        node
                        v12.22.0
                        npm
                        6.14.11
                        nodejs:
                        Jan1
                        @bj-0
                        Ist es eigentlich so schwer alles zu posten, das in Code Tags zu packen und auch den Befehle mit, damit man nicht immer raten muss?
                        Da fehlt die Hälfte!
