  4. fb-checkpresence.0 Used invalid characters
    6.6k
fb-checkpresencefritz
22 Beiträge 6 Kommentatoren 3.5k Aufrufe 6 Beobachtet
  • A Andi Luma
    @Andi-Luma
    und so sieht es im Log Aus , durchgängig bei jedem Check obwohl die App nicht aktiv ist .
    2020-12-09 00:00:58.568  - ._mwarn. : fb-checkpresence.0 (12267) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F, Dxxx Testuser) changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F_ Dxxx Testuser)
    2020-12-09 00:00:58.579  - ._mwarn. : fb-checkpresence.0 (12267) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F, Dxxx Testuser).meshstate changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F_ Dxxx Testuser).meshstate
    2020-12-09 00:00:58.580  - ._mwarn. : fb-checkpresence.0 (12267) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F, Dxxx Testuser).macaddress changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F_ Dxxx Testuser).macaddress
    2020-12-09 00:00:58.580  - ._mwarn. : fb-checkpresence.0 (12267) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F, Dxxx Testuser).ipaddress changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F_ Dxxx Testuser).ipaddress
    2020-12-09 00:00:58.580  - ._mwarn. : fb-checkpresence.0 (12267) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F, Dxxx Testuser).active changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F_ Dxxx Testuser).active
    2020-12-09 00:00:58.580  - ._mwarn. : fb-checkpresence.0 (12267) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F, Dxxx Testuser).disabled changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F_ Dxxx Testuser).disabled
    2020-12-09 00:00:58.581  - ._mwarn. : fb-checkpresence.0 (12267) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F, Dxxx Testuser).interfacetype changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F_ Dxxx Testuser).interfacetype
    2020-12-09 00:00:58.581  - ._mwarn. : fb-checkpresence.0 (12267) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F, Dxxx Testuser).speed changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F_ Dxxx Testuser).speed
    2020-12-09 00:00:58.581  - ._mwarn. : fb-checkpresence.0 (12267) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F, Dxxx Testuser).guest changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F_ Dxxx Testuser).guest
    2020-12-09 00:00:58.581  - ._mwarn. : fb-checkpresence.0 (12267) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F, Dxxx Testuser).whitelist changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F_ Dxxx Testuser).whitelist
    2020-12-09 00:00:58.581  - ._mwarn. : fb-checkpresence.0 (12267) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F, Dxxx Testuser).blacklist changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G950F_ Dxxx Testuser).blacklist
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    @andi-luma
    Hallo, wie wird denn hier ioBroker mit der Fritzbox betrieben? Normalerweise befinden sich beide im gleichen Netzwerk. Dann sind aber die Devicenamen der Fritzbox andere. Das hier sieht nach einem externen Zugang über MyFritz aus. Was die Fritzbox da macht, weiß ich nicht.
    Auf jeden Fall werden die Devicenamen verunstaltet. Der Adapter in Version 1.1.0 würde maximal Punkte (wie z.B. fritz.box -> fritz-box) durch Bindestriche ersetzen.
    • afuerhoffA afuerhoff
      @andi-luma
      Aiouh
      @afuerhoff
      Hallo, ich hatte dasselbe Problem. Nach einigem Suchen hab ich Folgendes gefunden.
      Wenn auf einem Android device einmal die Fritz App für den VPN Zugang konfiguriert wurde, gibt es in der Fritzbox einen Eintrag dazu unter System-FritzBoxBenutzer-Apps.
      Bei mir war es so, dass dort auch sehr alte Einträge zu Geräten zu finden waren die ich längst nicht mehr nutze. Zu diesen Geräten, die die Fehler im Log produzierten, gab es jedoch unter "letzte Anmeldung" keinen Eintrag für Zeit und Datum.
      Die Lösung: Die leeren Einträge einfach mit dem roten Kreuz rechts daneben löschen.
      Dann im Adapter "synchronize FB Devices" anhaken, speichern und den Adapter neu starten.
      Hoffe das hilft mal jemandem :)
      A afuerhoffA 2 Antworten Letzte Antwort
      • A Aiouh
        @afuerhoff
        Andi Luma
        schrieb am zuletzt editiert von Andi Luma
        @aiouh Danke für den Hinweis , hat aber leider nicht geholfen , das "fehlerhafte" Konto war vor kurzen noch aktiv
        Den FB Adapter gestoppt, den Eintrag aus den Objekten gelöscht ,Adapter neu gestartet, das Objekt wird wieder angelegt , nur leider kommen dann die Fehler auch wieder in log ..
        Gib es da keine Chance das Objekt zu "blacklisten" ? ich habe es schon mit Whiteliste versucht ,also den kompletten String aus dem log, mit oder ohen , ändert leider nichts an den Warnungen
        • A Andi Luma
          Aiouh
          @andi-luma Schade, dass das bei Dir nicht geholfen hat. Da kann ich dann leider auch nicht weiterhelfen :(
          Ich poste aber mal meine alten Fehlermeldungen, vielleicht lassen sich ja doch aus dem Namen die "invalid characters" ableiten. Das Problem scheint zumindest kein Einzelfall zu sein.
          Ich hatte ja kein funktionales Problem damit, nur dass mir eben das Log vollgeschrieben wurde.
          fb-checkpresence.0 (8121) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G920F, Abc Xyz).blacklist changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-G920F_ Abc Xyz).blacklist
          fb-checkpresence.0 (8121) Used invalid characters: fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-T530NU, Abc Xyz) changed to fb-checkpresence.0.fb-devices.MyFRITZ!App 2 (Samsung SM-T530NU_ Abc Xyz)
          • A Aiouh
            @afuerhoff
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            @aiouh sagte in fb-checkpresence.0 Used invalid characters:
            @afuerhoff
            Hallo, was mich interessieren würde ist, ob diese Einträge dann auch unter Netzwerk in den Devices in der Fritzbox stehen. Kannst du, falls ja, mal ein Bild posten.
              @afuerhoff
              Aiouh
              @afuerhoff Ich kann Dir leider nur den Stand geben wie es jetzt aussieht, denn die "leeren" habe ich ja schon gelöscht
              • A Aiouh
                afuerhoffA Offline
                afuerhoffA Offline
                afuerhoff
                @aiouh
                Danke. Das hat glaube ich geholfen. Ich selber nutze VPN nicht und kann und will das bei mir nicht nachstellen. Im nächsten Update sehe ich da etwas vor.
                  @aiouh
                  Aiouh
                  @afuerhoff Danke ! Wenn Du einen zum Testen, oder weitere Informationen brauchst, gib Bescheid, mach ich gerne
                  • A Aiouh
                    afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    @aiouh
                    Hallo, habe heute eine neue Testversion auf Github hochgeladen :-)
                      @aiouh
                      Aiouh
                      @afuerhoff OK, schau ich mir morgen an.
                        @aiouh
                        Aiouh
                        @afuerhoff
                        Hallo, installation lief durch, ich bekomme aber jetzt im Log folgende Fehler
                        fb-checkpresence.0	2021-04-02 10:48:42.925	warn	(27422) The state "devices" will not longer exist in a future version. Please use "fb-devices.count" instead!
                        fb-checkpresence.0	2021-04-02 10:48:42.922	warn	(27422) The state "activeDevices" will not longer exist in a future version. Please use "fb-devices.active" instead!
                        fb-checkpresence.0	2021-04-02 10:48:42.921	warn	(27422) The state "blacklist" will not longer exist in a future version. Please use "blacklist.presence" instead!
                        fb-checkpresence.0	2021-04-02 10:48:42.916	warn	(27422) The state "guest" will not longer exist in a future version. Please use "guest.presence" instead!
                        • A Aiouh
                          @afuerhoff
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          @aiouh
                          Hallo, das ist kein Fehler. Das ist ein Hinweis, dass diese States in Zukunft entfallen und du die anderen nutzen sollst.
                          • A Andi Luma
                            @Andi-Luma
                            afuerhoffA Offline
                            afuerhoffA Offline
                            afuerhoff
                            @andi-luma sagte in fb-checkpresence.0 Used invalid characters:
                            @Andi-Luma
                            Hallo, kannst Du die neue Testversion 1.1.3 auf Github mal testen?
                              @aiouh
                              Aiouh
                              schrieb am zuletzt editiert von Aiouh
                              @afuerhoff Soll heissen ich benutze die irgendwo? Kann mich nicht erinnern...Aber ich suche mal. Ansonsten hab ich keinerlei Fehler im log mit 1.1.3
                              • A Aiouh
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                Das heißt es nicht, aber wenn, solltest Du sie so wie angegeben ändern. In einer zunkünftigen Version ändere ich das dann.
