  4. (gelöst)(fritz-dect) Logeintrag ?
6 Beiträge 2 Kommentatoren 184 Aufrufe 2 Beobachtet
  • HumidorH Offline
    HumidorH Offline
    Humidor
    schrieb am zuletzt editiert von Humidor
    Hallo 👍
    hab ein Script und verwende den Schaltkontakt von einem Dect Gerät.
    beim Start von ioBroker bekomme ich diese Meldung
    2021-03-31 08:07:49.357 - warn: javascript.0 (24546) You are assigning a undefined to the state "fritzdect.0.DECT_116300118701.state" which expects a boolean. Please fix your code to use a boolean or change the state type to undefined. This warning might become an error in future versions.
    2021-03-31 08:07:49.374 - warn: javascript.0 (24546) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1422:20)
    2021-03-31 08:07:49.375 - warn: javascript.0 (24546) at Object. (script.js.common.Powerbank:23:5)
    2021-03-31 08:07:49.375 - warn: javascript.0 (24546) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1070:38)
    2021-03-31 08:07:49.376 - warn: javascript.0 (24546) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:487:29)
    2021-03-31 08:07:49.376 - warn: javascript.0 (24546) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5555:41)
    2021-03-31 08:07:49.377 - warn: javascript.0 (24546) at processImmediate (internal/timers.js:461:21)
    2021-03-31 08:07:49.377 - warn: javascript.0 (24546) You are assigning a undefined to the state "fritzdect.0.DECT_087610456373.state" which expects a boolean. Please fix your code to use a boolean or change the state type to undefined. This warning might become an error in future versions.
    2021-03-31 08:07:49.379 - warn: javascript.0 (24546) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1422:20)
    2021-03-31 08:07:49.379 - warn: javascript.0 (24546) at Object. (script.js.common.Powerbank:24:5)
    2021-03-31 08:07:49.380 - warn: javascript.0 (24546) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1070:38)
    2021-03-31 08:07:49.380 - warn: javascript.0 (24546) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:487:29)
    2021-03-31 08:07:49.380 - warn: javascript.0 (24546) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5555:41)
    2021-03-31 08:07:49.381 - warn: javascript.0 (24546) at processImmediate (internal/timers.js:461:21)
    das ist ein bool - state
    muss ich noch eine Konvertierung einfügen??
    <variables>
    <variable id="Wyc]h}Ht6huC^-:6SaQ">LADUNG</variable>
    <variable id="fz3-}yUJ6Z
    H57v_hwl">msg</variable>
    <variable id="=Qw
    /?oX/c9:]kYVO+LT">minOFF</variable>
    <variable id="#av^b]?,?S^.0@Ql^E3">minON</variable>
    <variable type="timeout" id="minOFF">minOFF</variable>
    <variable type="timeout" id="minON">minON</variable>
    </variables>
    <block type="on_ext" id="88i|Y7,;03^~-?v^6gfW" x="-363" y="221">
    <value name="OID0">
    <shadow type="field_oid" id="][;tlYCvhJq1A~~AdFu"> <field name="oid">0_userdata.0.AMIS.Power</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="xd=LRkdUn!n+x_YNOk.x"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_compare" id="^I,ANSYMPY_B3hV7CpLS"> <field name="OP">GT</field> <value name="A"> <block type="get_value" id="g(zD2GVs478rKy+mHs2h"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.AMIS.PVÜberschuss</field> </block> </value> <value name="B"> <block type="math_number" id="cEk!KETW=f)8j;oU.$fP"> <field name="NUM">1000</field> </block> </value> </block> </value> <statement name="DO0"> <block type="controls_if" id="C96(ZSFX8O:c~KYQZEyf"> <value name="IF0"> <block type="logic_negate" id="!Ji@hL03JT?05/xl~(|J"> <value name="BOOL"> <block type="variables_get" id="kgQ-WXETdMYuriB?OV5="> <field name="VAR" id="=Qw*/?oX/c9:]kYVO+LT">minOFF</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="Hjqkazc*-NQy$re4yopf"> <field name="VAR" id="Wy*c]h}Ht6huC^-:6SaQ">LADUNG</field> <value name="VALUE"> <block type="logic_boolean" id="=FAkrl07,9#EklvQDg2r"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="variables_set" id="Am^HOENjQ?/m)1M^SOsP"> <field name="VAR" id="fz3-}yUJ6Z*H57v_hw*l">msg</field> <value name="VALUE"> <block type="text" id="4N|F^E9XSEOmmye]6IcP"> <field name="TEXT">Powerbank - Ladung begonnen</field> </block> </value> <next> <block type="timeouts_settimeout" id="@cx_zFy!SAeA27m9L~$d"> <field name="NAME">minON</field> <field name="DELAY">1</field> <field name="UNIT">min</field> <statement name="STATEMENT"> <block type="variables_set" id="olUlQ#{Z{}D!z9sldla">
    <field name="VAR" id="#av^b]?,?S^.0@Ql^E3">minON</field>
    <block type="logic_null" id="4XmxrdzU6XK#KW15U7ZO"></block>
    </value>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </statement>
    <value name="IF1">
    <block type="logic_operation" id="(r}Hp|dOI705FR^mE(hF">
    <field name="OP">AND</field>
    <value name="A">
    <block type="logic_negate" id="/$og_j)Kkr{oaMM;T9=Z">
    <value name="BOOL">
    <block type="variables_get" id="OcOLi4miAjfWxrzF3Z;m">
    </block>
    </value>
    </block>
    </value>
    <value name="B">
    <block type="logic_compare" id="bPnR
    NGD=9w[[cA^9^X[">
    <value name="A">
    <block type="get_value" id="_hhkyNx~18v~?)(!**)o">
    <field name="OID">0_userdata.0.AMIS.Power</field>
    </block>
    </value>
    <value name="B">
    <block type="math_number" id="5MRY5UoiDEY8)T.1WuV8">
    <field name="NUM">0</field>
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <statement name="DO1">
    <block type="variables_set" id="^97%tEk!(DpYK2J2">
    <block type="logic_boolean" id="}slPZ{#?q5/vpfD_POnW">
    </block>
    </value>
    <next>
    <block type="variables_set" id="R6(LcY)|i,.6iYjsOgC/">
    H57v_hwl">msg</field>
    <block type="text" id="tRIbIKQEFa.^gHlJ#2@/">
    <field name="TEXT">Powerbank - Ladung beendet</field>
    </block>
    </value>
    <next>
    <block type="timeouts_settimeout" id="n:EaIT02P6efn{E|q^nV">
    <field name="NAME">minOFF</field>
    <field name="DELAY">10</field>
    <block type="variables_set" id="Il9B
    ga%0nAaSG~NLBM]">
    <block type="logic_null" id="C67`7q0~hj8D~Gb)|,pw"></block>
    </value>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </next>
    </block>
    </statement>
    <next>
    <block type="controls_if" id="@#**0c5{ATvB$6Uj7y^">
    <value name="IF0">
    <block type="logic_compare" id="?Tz?ZRu%A[#1ewH0F]+8">
    <field name="OP">NEQ</field>
    <value name="A">
    <block type="variables_get" id="ycHFiqs^D7BVjGjv6u@:">
    </block>
    </value>
    <value name="B">
    <block type="get_value" id="zzmaJ{OMGtScEPB$wlzY">
    <field name="OID">fritzdect.0.DECT_116300118701.state</field>
    </block>
    </value>
    </block>
    </value>
    <block type="control" id="=ngJ9/h@m~vM8G:~|$@t">
    <block type="variables_get" id="GgGBwA|hAHG!qX:@L8P-">
    <field name="VAR" id="Wyc]h}Ht6huC^-:6SaQ">LADUNG</field>
    </block>
    </value>
    <next>
    <block type="control" id="C0zbKHh,L-b43tc=PbD3">
    <field name="OID">fritzdect.0.DECT_087610456373.state</field>
    <block type="variables_get" id="a,T=8{p{TXZ80^4U{[I4">
    </block>
    </value>
    <next>
    <block type="debug" id="2__pQR[2.EFS9/Ii|jve">
    <value name="TEXT">
    <shadow type="text" id="5c~V%FA97r.wxKWEY/Ua">
    </shadow>
    <block type="variables_get" id="-DW:i8~+q2xA^$l]80H">
    </block>
    </value>
    </block>
    </next>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </xml>
    BG
    • HumidorH Humidor
      Hallo 👍
      <variables>
      <variable id="=Qw
      </variables>
      <value name="OID0">
      </value>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </statement>
      <value name="IF1">
      <value name="A">
      <value name="BOOL">
      </block>
      </value>
      </block>
      </value>
      <value name="B">
      NGD=9w[[cA^9^X[">
      <value name="A">
      </block>
      </value>
      <value name="B">
      </block>
      </value>
      </block>
      </value>
      </block>
      </value>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      ga%0nAaSG~NLBM]">
      </value>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </next>
      </block>
      </statement>
      <next>
      <value name="IF0">
      <value name="A">
      </block>
      </value>
      <value name="B">
      </block>
      </value>
      </block>
      </value>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      <value name="TEXT">
      </shadow>
      </block>
      </value>
      </block>
      </next>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </xml>
      liv-in-skyL Offline
      liv-in-skyL Offline
      @humidor
      der wert ladung scheint nicht definiert zu sein - beim scriptstart ?
      es geht nicht um konvertierung, sondern um undefined - du musst LADUNG "setzen" beim scriptstart - außerhalb eines triggers
      hier ein beispiel - außerhalb des schedule triggers werden die beiden variablen gesetzt
      HumidorH 1 Antwort Letzte Antwort
      • liv-in-skyL liv-in-sky
        @humidor
        HumidorH Offline
        HumidorH Offline
        Humidor
        @liv-in-sky interessant, dh der Adapter läuft noch nicht und das Objekt ist nicht definiert.
        wie kann ich ein Objekt setzen ?
        könnte ich nicht die Java Abarbeitung bis der Adapter läuft zurückhalten?
        BG
        • HumidorH Humidor
          liv-in-skyL Offline
          liv-in-skyL Offline
          @humidor anders herum - die variable LADUNG ist noch nicht definiert und du schreibst die schon in einen datenpunkt
          • HumidorH Humidor
            liv-in-skyL Offline
            liv-in-skyL Offline
            @humidor
            evtl kannst du das hier (außerhalb eines triggers) einfügen - damit ist beim scriptstart der selbe wert definiert, wie ihn der adapter momentan hat - kommt auf den rest des scripte an
              @humidor
              HumidorH Offline
              HumidorH Offline
              Humidor
              @liv-in-sky ach so, verstanden, falsch gedacht
              gemacht, mal sehen, denke damit ist es gelöst, danke!
              BG
