  4. ioBroker verabschiedet sich alle 1,5 Tage
45 Beiträge 7 Kommentatoren 4.8k Aufrufe 7 Beobachtet
  • Christian WöhrleC Christian Wöhrle
    Und wie stell ich das dauerhaft um auf Runlevel 3? Alle Anleitungen die ich finde berufen sich auf init, nicht auf systemd.
    Hier die Ausgabe von Messages.1
    Feb 14 00:00:29 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="353" x-info="https://www$
    Feb 15 00:00:26 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="353" x-info="https://www$
    Feb 16 00:00:26 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="353" x-info="https://www$
    Feb 17 00:00:26 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="353" x-info="https://www$
    Feb 18 00:00:26 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="353" x-info="https://www$
    Feb 19 00:00:26 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="353" x-info="https://www$
    Feb 19 15:17:08 raspberrypi mtp-probe: checking bus 2, device 2: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/00$
    Feb 19 15:17:08 raspberrypi mtp-probe: checking bus 1, device 3: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/00$
    Feb 19 15:17:08 raspberrypi mtp-probe: bus: 1, device: 3 was not an MTP device
    Feb 19 15:17:08 raspberrypi mtp-probe: bus: 2, device: 2 was not an MTP device
    Feb 19 15:17:08 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
    Feb 19 15:17:08 raspberrypi kernel: [    0.000000] Linux version 5.10.11-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8$
    Feb 19 15:17:08 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    Feb 19 15:17:08 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
    Feb 19 15:17:08 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    Feb 19 15:17:08 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
    Feb 19 15:17:08 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
    Feb 19 15:17:08 raspberrypi kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size$
    Feb 19 15:17:08 raspberrypi kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-d$
    Feb 19 15:17:08 raspberrypi kernel: [    0.000000] Zone ranges:
    Feb 19 15:17:08 raspberrypi kernel: [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
    @christian-wöhrle
    sudo raspi-config
    Menüpunkte:
    1 System Options
    S5 Boot / Auto Login
    B1 Console
    Christian WöhrleC 1 Antwort Letzte Antwort
      @christian-wöhrle
      sudo raspi-config
      Menüpunkte:
      1 System Options
      B1 Console
      Christian WöhrleC Offline
      Christian Wöhrle
      @thomas-braun ok, hab ich eingestellt
        Christian Wöhrle
        Bis jetzt ist das Problem nicht wieder aufgetreten.
        Hoffen wir dass es so bleibt :-)
          Christian Wöhrle
          Leider besteht das Problem nach wie vor. Ich kann mir absolut keinen Reim drauf machen.
          Ich füge mal die aktuelle Log ein, da sieht man wieder deutlich dass sich das System wieder startet - allerdings als doppelte Instanz. Auffallend ist auch, dass sich die Zeitmarken stark unterscheiden und nicht der Reihe nach aufgelistet werden.
          log.html
            log.html
            @christian-wöhrle
            Da würde ich jetzt mal ein
            dmesg -T
            daneben legen. Und dann zu den Zeiten wo es Schluckauf gibt mal schauen was da im System passiert.
              @christian-wöhrle
              dmesg -T
              Christian Wöhrle
              @thomas-braun Alles klar, jetzt ist nur das Problem dass ich meistens nicht mitbekomme wenn das passiert.
              GIbts da ne Möglichkeit ne Meldung per Telegram zu erhalten? Am besten per Blockly? Alternative wäre Java Script
              • wendy2702W Online
                wendy2702W Online
                @christian-wöhrle sagte in ioBroker verabschiedet sich alle 1,5 Tage:
                @wendy2702 muss ich da syslog-ng installiert haben?
                Sorry, gerade erst gesehen. Nein, musst du nicht. Das Syslog liegt im gleichen Ordner wie die messages logs.
                  @christian-wöhrle Deswegen gibt es ja timestamps. Die Restarts sieht man ja im log vom iobroker, da müsste ja im kernel.log / dmesg zu diesen Zeitpunkten auch was passieren.
                    Christian Wöhrle
                    wird die kernel.log beim neustart nicht überschrieben?
                    Thomas BraunT Christian WöhrleC 2 Antworten Letzte Antwort
                      @christian-wöhrle Nein.
                      dmesg wird neugefüllt, kernel.log wird kontinuierlich gefüllt, bis logrotate greift.
                        Christian Wöhrle
                        Hier die Ausgabe von syslog:
                        Mar 27 05:28:05 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="398" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
                        Mar 27 05:28:05 raspberrypi systemd[1]: logrotate.service: Succeeded.
                        Mar 27 05:28:05 raspberrypi systemd[1]: Started Rotate log files.
                        Mar 27 05:28:08 raspberrypi systemd[1]: man-db.service: Succeeded.
                        Mar 27 05:28:08 raspberrypi systemd[1]: Started Daily man-db regeneration.
                        Mar 27 05:28:13 raspberrypi systemd[1]: systemd-hostnamed.service: Succeeded.
                        Mar 27 05:28:40 raspberrypi bash[470]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
                        Mar 27 05:28:40 raspberrypi bash[470]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
                        Mar 27 05:29:21 raspberrypi bash[470]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
                        Mar 27 05:29:43 raspberrypi bash[470]: ================================== > LOG REDIRECT system.adapter.logparser.0 => false [Process stopped]
                        Mar 27 05:29:43 raspberrypi bash[470]: ================================== > LOG REDIRECT system.adapter.logparser.0 => false [system.adapter.logparser.0.logging]
                        Mar 27 05:29:56 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
                        Mar 27 05:29:56 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000...
                        Mar 27 05:29:56 raspberrypi systemd[1]: Started User Runtime Directory /run/user/1000.
                        Mar 27 05:29:56 raspberrypi systemd[1]: Starting User Manager for UID 1000...
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Listening on GnuPG network certificate management daemon.
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Reached target Timers.
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Starting D-Bus User Message Bus Socket.
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Listening on GnuPG cryptographic agent and passphrase cache.
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Reached target Paths.
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Listening on D-Bus User Message Bus Socket.
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Reached target Sockets.
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Reached target Basic System.
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Reached target Default.
                        Mar 27 05:29:56 raspberrypi systemd[1]: Started User Manager for UID 1000.
                        Mar 27 05:29:56 raspberrypi systemd[3679]: Startup finished in 296ms.
                        Mar 27 05:29:56 raspberrypi systemd[1]: Started Session 1 of user pi.
                        Mar 27 05:30:14 raspberrypi bash[470]: ================================== > LOG REDIRECT system.adapter.logparser.0 => true [system.adapter.logparser.0.logging]
                        Mar 27 05:30:21 raspberrypi bash[470]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
                        Mar 27 05:31:21 raspberrypi bash[470]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
                        Mar 27 05:32:21 raspberrypi bash[470]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
                        Mar 27 05:33:21 raspberrypi bash[470]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
                        Mar 27 05:34:21 raspberrypi bash[470]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
                        Mar 27 05:35:21 raspberrypi bash[470]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
                        Mar 27 05:35:28 raspberrypi dbus-daemon[367]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.2' (uid$
                        Mar 27 05:35:28 raspberrypi systemd[1]: Starting Authorization Manager...
                        Mar 27 05:35:28 raspberrypi polkitd[7552]: started daemon version 0.105 using authority implementation `local' version `0.105'
                        Mar 27 05:35:28 raspberrypi dbus-daemon[367]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
                          wendy2702W Online
                          wendy2702W Online
                          @christian-wöhrle Glaube da fehlt was. Bisschen wenig im log.
                            Christian Wöhrle
                            schrieb am zuletzt editiert von Christian Wöhrle
                            hier die Ausgabe von kern.log
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Linux version 5.10.11-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (G$
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Zone ranges:
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000]   Normal   empty
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Movable zone start for each node
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Early memory node ranges
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] On node 0 totalpages: 1012480
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000]   DMA zone: 2304 pages used for memmap
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000]   DMA zone: 0 pages reserved
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000]   HighMem zone: 815872 pages, LIFO batch:63
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50636 r8192 d23092 u81920
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] pcpu-alloc: s50636 r8192 d23092 u81920 alloc=20*4096
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010176
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  sm$
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] Memory: 3653920K/4049920K available (10240K kernel code, 1354K rwdata, 3152K rodata, 2048K init, 890K bss, 133856K r$
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] ftrace: allocating 33824 entries in 67 pages
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] ftrace: allocated 67 pages with 3 groups
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] rcu: Hierarchical RCU implementation.
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000]      Rude variant of Tasks RCU enabled.
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000]      Tracing variant of Tasks RCU enabled.
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000035] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000099] bcm2835: system timer (irq = 25)
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000741] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000763] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000786] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                            Mar 26 22:33:07 raspberrypi kernel: [    0.000804] Switching to timer-based delay loop, resolution 18ns
                            Mar 26 22:33:07 raspberrypi kernel: [    0.001050] Console: colour dummy device 80x30
                            Mar 26 22:33:07 raspberrypi kernel: [    0.001781] printk: console [tty1] enabled
                            Mar 26 22:33:07 raspberrypi kernel: [    0.001849] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                            Mar 26 22:33:07 raspberrypi kernel: [    0.001903] pid_max: default: 32768 minimum: 301
                            Mar 26 22:33:07 raspberrypi kernel: [    0.002082] LSM: Security Framework initializing
                            Mar 26 22:33:07 raspberrypi kernel: [    0.002274] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                            Mar 26 22:33:07 raspberrypi kernel: [    0.002319] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                            Mar 26 22:33:07 raspberrypi kernel: [    0.003892] Disabling memory control group subsystem
                            Mar 26 22:33:07 raspberrypi kernel: [    0.004027] CPU: Testing write buffer coherency: ok
                            Mar 26 22:33:07 raspberrypi kernel: [    0.004490] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                            Mar 26 22:33:07 raspberrypi kernel: [    0.005698] Setting up static identity map for 0x200000 - 0x20003c
                            Mar 26 22:33:07 raspberrypi kernel: [    0.005911] rcu: Hierarchical SRCU implementation.
                            Mar 26 22:33:07 raspberrypi kernel: [    0.006832] smp: Bringing up secondary CPUs ...
                            Mar 26 22:33:07 raspberrypi kernel: [    0.008016] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                            Mar 26 22:33:07 raspberrypi kernel: [    0.009352] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                            Mar 26 22:33:07 raspberrypi kernel: [    0.010623] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                            Mar 26 22:33:07 raspberrypi kernel: [    0.010885] smp: Brought up 1 node, 4 CPUs
                            Mar 26 22:33:07 raspberrypi kernel: [    0.010917] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                            Mar 26 22:33:07 raspberrypi kernel: [    0.010947] CPU: All CPU(s) started in HYP mode.
                            Mar 26 22:33:07 raspberrypi kernel: [    0.010974] CPU: Virtualization extensions available.
                            Mar 26 22:33:07 raspberrypi kernel: [    0.011804] devtmpfs: initialized
                            Mar 26 22:33:07 raspberrypi kernel: [    0.025487] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                            Mar 26 22:33:07 raspberrypi kernel: [    0.025737] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                            Mar 26 22:33:07 raspberrypi kernel: [    0.025789] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                            Mar 26 22:33:07 raspberrypi kernel: [    0.032476] pinctrl core: initialized pinctrl subsystem
                            Mar 26 22:33:07 raspberrypi kernel: [    0.033548] NET: Registered protocol family 16
                            Mar 26 22:33:07 raspberrypi kernel: [    0.037268] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                            Mar 26 22:33:07 raspberrypi kernel: [    0.038060] audit: initializing netlink subsys (disabled)
                            Mar 26 22:33:07 raspberrypi kernel: [    0.038354] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                            Mar 26 22:33:07 raspberrypi kernel: [    0.038917] thermal_sys: Registered thermal governor 'step_wise'
                            Mar 26 22:33:07 raspberrypi kernel: [    0.039590] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                            Mar 26 22:33:07 raspberrypi kernel: [    0.039644] hw-breakpoint: maximum watchpoint size is 8 bytes.
                            Mar 26 22:33:07 raspberrypi kernel: [    0.040031] Serial: AMBA PL011 UART driver
                            Mar 26 22:33:07 raspberrypi kernel: [    0.072564] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                            Mar 26 22:33:07 raspberrypi kernel: [    0.091033] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-01-27T22:19:57, variant start
                            Mar 26 22:33:07 raspberrypi kernel: [    0.101048] raspberrypi-firmware soc:firmware: Firmware hash is 99d9a48302e4553cff3688692bb7e9ac760a03fa
                            Mar 26 22:33:07 raspberrypi kernel: [    0.145423] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                            Mar 26 22:33:07 raspberrypi kernel: [    0.149583] vgaarb: loaded
                            Mar 26 22:33:07 raspberrypi kernel: [    0.150034] SCSI subsystem initialized
                            Mar 26 22:33:07 raspberrypi kernel: [    0.150274] usbcore: registered new interface driver usbfs
                            Mar 26 22:33:07 raspberrypi kernel: [    0.150349] usbcore: registered new interface driver hub
                            Mar 26 22:33:07 raspberrypi kernel: [    0.150434] usbcore: registered new device driver usb
                            Mar 26 22:33:07 raspberrypi kernel: [    0.150817] usb_phy_generic phy: supply vcc not found, using dummy regulator
                            Mar 26 22:33:07 raspberrypi kernel: [    0.153012] clocksource: Switched to clocksource arch_sys_counter
                            Mar 26 22:33:07 raspberrypi kernel: [    1.179938] VFS: Disk quotas dquot_6.6.0
                            Mar 26 22:33:07 raspberrypi kernel: [    1.180062] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.180261] FS-Cache: Loaded
                            Mar 26 22:33:07 raspberrypi kernel: [    1.180458] CacheFiles: Loaded
                            Mar 26 22:33:07 raspberrypi kernel: [    1.190441] NET: Registered protocol family 2
                            Mar 26 22:33:07 raspberrypi kernel: [    1.191585] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.191652] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.191732] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.191815] TCP: Hash tables configured (established 8192 bind 8192)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.191975] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.192029] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.192305] NET: Registered protocol family 1
                            Mar 26 22:33:07 raspberrypi kernel: [    1.193058] RPC: Registered named UNIX socket transport module.
                            Mar 26 22:33:07 raspberrypi kernel: [    1.193092] RPC: Registered udp transport module.
                            Mar 26 22:33:07 raspberrypi kernel: [    1.193121] RPC: Registered tcp transport module.
                            Mar 26 22:33:07 raspberrypi kernel: [    1.193149] RPC: Registered tcp NFSv4.1 backchannel transport module.
                            Mar 26 22:33:07 raspberrypi kernel: [    1.193187] PCI: CLS 0 bytes, default 64
                            Mar 26 22:33:07 raspberrypi kernel: [    1.196036] Initialise system trusted keyrings
                            Mar 26 22:33:07 raspberrypi kernel: [    1.196289] workingset: timestamp_bits=14 max_order=20 bucket_order=6
                            Mar 26 22:33:07 raspberrypi kernel: [    1.204610] zbud: loaded
                            Mar 26 22:33:07 raspberrypi kernel: [    1.206532] FS-Cache: Netfs 'nfs' registered for caching
                            Mar 26 22:33:07 raspberrypi kernel: [    1.207280] NFS: Registering the id_resolver key type
                            Mar 26 22:33:07 raspberrypi kernel: [    1.207341] Key type id_resolver registered
                            Mar 26 22:33:07 raspberrypi kernel: [    1.207370] Key type id_legacy registered
                            Mar 26 22:33:07 raspberrypi kernel: [    1.207539] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                            Mar 26 22:33:07 raspberrypi kernel: [    1.208581] Key type asymmetric registered
                            Mar 26 22:33:07 raspberrypi kernel: [    1.208612] Asymmetric key parser 'x509' registered
                            Mar 26 22:33:07 raspberrypi kernel: [    1.208818] bounce: pool size: 64 pages
                            Mar 26 22:33:07 raspberrypi kernel: [    1.208891] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.209120] io scheduler mq-deadline registered
                            Mar 26 22:33:07 raspberrypi kernel: [    1.209152] io scheduler kyber registered
                            Mar 26 22:33:07 raspberrypi kernel: [    1.213487] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                            Mar 26 22:33:07 raspberrypi kernel: [    1.213539] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                            Mar 26 22:33:07 raspberrypi kernel: [    1.213641] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                            Mar 26 22:33:07 raspberrypi kernel: [    1.213749] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                            Mar 26 22:33:07 raspberrypi kernel: [    1.275121] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.275500] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                            Mar 26 22:33:07 raspberrypi kernel: [    1.275538] pci_bus 0000:00: root bus resource [bus 00-ff]
                            Mar 26 22:33:07 raspberrypi kernel: [    1.275573] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                            Mar 26 22:33:07 raspberrypi kernel: [    1.275682] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                            Mar 26 22:33:07 raspberrypi kernel: [    1.275937] pci 0000:00:00.0: PME# supported from D0 D3hot
                            Mar 26 22:33:07 raspberrypi kernel: [    1.279379] PCI: bus0: Fast back to back transfers disabled
                            Mar 26 22:33:07 raspberrypi kernel: [    1.279728] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                            Mar 26 22:33:07 raspberrypi kernel: [    1.279872] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                            Mar 26 22:33:07 raspberrypi kernel: [    1.280316] pci 0000:01:00.0: PME# supported from D0 D3cold
                            Mar 26 22:33:07 raspberrypi kernel: [    1.283768] PCI: bus1: Fast back to back transfers disabled
                            Mar 26 22:33:07 raspberrypi kernel: [    1.283845] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                            Mar 26 22:33:07 raspberrypi kernel: [    1.283886] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                            Mar 26 22:33:07 raspberrypi kernel: [    1.283989] pci 0000:00:00.0: PCI bridge to [bus 01]
                            Mar 26 22:33:07 raspberrypi kernel: [    1.284028] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                            Mar 26 22:33:07 raspberrypi kernel: [    1.284445] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.284701] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
                            Mar 26 22:33:07 raspberrypi kernel: [    1.290349] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
                            Mar 26 22:33:07 raspberrypi kernel: [    1.291242] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
                            Mar 26 22:33:07 raspberrypi kernel: [    1.293707] iproc-rng200 fe104000.rng: hwrng registered
                            Mar 26 22:33:07 raspberrypi kernel: [    1.294032] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.294915] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                            Mar 26 22:33:07 raspberrypi kernel: [    1.307814] brd: module loaded
                            Mar 26 22:33:07 raspberrypi kernel: [    1.319798] loop: module loaded
                            Mar 26 22:33:07 raspberrypi kernel: [    1.321461] Loading iSCSI transport class v2.0-870.
                            Mar 26 22:33:07 raspberrypi kernel: [    1.323959] libphy: Fixed MDIO Bus: probed
                            Mar 26 22:33:07 raspberrypi kernel: [    1.325245] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                            Mar 26 22:33:07 raspberrypi kernel: [    1.343042] libphy: bcmgenet MII bus: probed
                            Mar 26 22:33:07 raspberrypi kernel: [    1.433159] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                            Mar 26 22:33:07 raspberrypi kernel: [    1.434300] usbcore: registered new interface driver r8152
                            Mar 26 22:33:07 raspberrypi kernel: [    1.434385] usbcore: registered new interface driver lan78xx
                            Mar 26 22:33:07 raspberrypi kernel: [    1.434476] usbcore: registered new interface driver smsc95xx
                            Mar 26 22:33:07 raspberrypi kernel: [    1.436070] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.436247] xhci_hcd 0000:01:00.0: xHCI Host Controller
                            Mar 26 22:33:07 raspberrypi kernel: [    1.436297] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                            Mar 26 22:33:07 raspberrypi kernel: [    1.439603] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
                            Mar 26 22:33:07 raspberrypi kernel: [    1.440927] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                            Mar 26 22:33:07 raspberrypi kernel: [    1.440968] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                            Mar 26 22:33:07 raspberrypi kernel: [    1.441004] usb usb1: Product: xHCI Host Controller
                            Mar 26 22:33:07 raspberrypi kernel: [    1.441035] usb usb1: Manufacturer: Linux 5.10.11-v7l+ xhci-hcd
                            Mar 26 22:33:07 raspberrypi kernel: [    1.441066] usb usb1: SerialNumber: 0000:01:00.0
                            Mar 26 22:33:07 raspberrypi kernel: [    1.441807] hub 1-0:1.0: USB hub found
                            Mar 26 22:33:07 raspberrypi kernel: [    1.441924] hub 1-0:1.0: 1 port detected
                            Mar 26 22:33:07 raspberrypi kernel: [    1.442611] xhci_hcd 0000:01:00.0: xHCI Host Controller
                            Mar 26 22:33:07 raspberrypi kernel: [    1.442654] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                            Mar 26 22:33:07 raspberrypi kernel: [    1.442699] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                            Mar 26 22:33:07 raspberrypi kernel: [    1.443237] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                            Mar 26 22:33:07 raspberrypi kernel: [    1.443277] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                            Mar 26 22:33:07 raspberrypi kernel: [    1.443312] usb usb2: Product: xHCI Host Controller
                            Mar 26 22:33:07 raspberrypi kernel: [    1.443342] usb usb2: Manufacturer: Linux 5.10.11-v7l+ xhci-hcd
                            Mar 26 22:33:07 raspberrypi kernel: [    1.443373] usb usb2: SerialNumber: 0000:01:00.0
                            Mar 26 22:33:07 raspberrypi kernel: [    1.444104] hub 2-0:1.0: USB hub found
                            Mar 26 22:33:07 raspberrypi kernel: [    1.444191] hub 2-0:1.0: 4 ports detected
                            Mar 26 22:33:07 raspberrypi kernel: [    1.445889] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                            Mar 26 22:33:07 raspberrypi kernel: [    1.446217] dwc_otg: FIQ enabled
                            Mar 26 22:33:07 raspberrypi kernel: [    1.446232] dwc_otg: NAK holdoff enabled
                            Mar 26 22:33:07 raspberrypi kernel: [    1.446246] dwc_otg: FIQ split-transaction FSM enabled
                            Mar 26 22:33:07 raspberrypi kernel: [    1.446264] Module dwc_common_port init
                            Mar 26 22:33:07 raspberrypi kernel: [    1.446678] usbcore: registered new interface driver uas
                            Mar 26 22:33:07 raspberrypi kernel: [    1.446814] usbcore: registered new interface driver usb-storage
                            Mar 26 22:33:07 raspberrypi kernel: [    1.447026] mousedev: PS/2 mouse device common for all mice
                            Mar 26 22:33:07 raspberrypi kernel: [    1.448686] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                            Mar 26 22:33:07 raspberrypi kernel: [    1.452231] sdhci: Secure Digital Host Controller Interface driver
                            Mar 26 22:33:07 raspberrypi kernel: [    1.452266] sdhci: Copyright(c) Pierre Ossman
                            Mar 26 22:33:07 raspberrypi kernel: [    1.452982] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                            Mar 26 22:33:07 raspberrypi kernel: [    1.453646] sdhci-pltfm: SDHCI platform and OF driver helper
                            Mar 26 22:33:07 raspberrypi kernel: [    1.457636] ledtrig-cpu: registered to indicate activity on CPUs
                            Mar 26 22:33:07 raspberrypi kernel: [    1.457979] hid: raw HID events driver (C) Jiri Kosina
                            Mar 26 22:33:07 raspberrypi kernel: [    1.458191] usbcore: registered new interface driver usbhid
                            Mar 26 22:33:07 raspberrypi kernel: [    1.458222] usbhid: USB HID core driver
                            Mar 26 22:33:07 raspberrypi kernel: [    1.463425] Initializing XFRM netlink socket
                            Mar 26 22:33:07 raspberrypi kernel: [    1.463487] NET: Registered protocol family 17
                            Mar 26 22:33:07 raspberrypi kernel: [    1.463632] Key type dns_resolver registered
                            Mar 26 22:33:07 raspberrypi kernel: [    1.463993] Registering SWP/SWPB emulation handler
                            Mar 26 22:33:07 raspberrypi kernel: [    1.464173] registered taskstats version 1
                            Mar 26 22:33:07 raspberrypi kernel: [    1.464214] Loading compiled-in X.509 certificates
                            Mar 26 22:33:07 raspberrypi kernel: [    1.465059] Key type ._fscrypt registered
                            Mar 26 22:33:07 raspberrypi kernel: [    1.465090] Key type .fscrypt registered
                            Mar 26 22:33:07 raspberrypi kernel: [    1.465201] Key type fscrypt-provisioning registered
                            Mar 26 22:33:07 raspberrypi kernel: [    1.476440] uart-pl011 fe201000.serial: there is not valid maps for state default
                            Mar 26 22:33:07 raspberrypi kernel: [    1.476763] uart-pl011 fe201000.serial: cts_event_workaround enabled
                            Mar 26 22:33:07 raspberrypi kernel: [    1.476865] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                            Mar 26 22:33:07 raspberrypi kernel: [    1.483240] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
                            Mar 26 22:33:07 raspberrypi kernel: [    1.483987] printk: console [ttyS0] disabled
                            Mar 26 22:33:07 raspberrypi kernel: [    1.484133] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
                            Mar 26 22:33:07 raspberrypi kernel: [    2.753592] printk: console [ttyS0] enabled
                            Mar 26 22:33:07 raspberrypi kernel: [    2.759824] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                            Mar 26 22:33:07 raspberrypi kernel: [    2.768248] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                            Mar 26 22:33:07 raspberrypi kernel: [    2.774399] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                            Mar 26 22:33:07 raspberrypi kernel: [    2.810483] of_cfs_init
                            Mar 26 22:33:07 raspberrypi kernel: [    2.813272] of_cfs_init: OK
                            Mar 26 22:33:07 raspberrypi kernel: [    2.832579] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                            Mar 26 22:33:07 raspberrypi kernel: [    2.839855] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                            Mar 26 22:33:07 raspberrypi kernel: [    2.847143] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                            Mar 26 22:33:07 raspberrypi kernel: [    2.852780] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
                            Mar 26 22:33:07 raspberrypi kernel: [    2.860950] Waiting for root device PARTUUID=b5bd775f-02...
                            Mar 26 22:33:07 raspberrypi kernel: [    2.863442] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                            Mar 26 22:33:07 raspberrypi kernel: [    2.875127] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                            Mar 26 22:33:07 raspberrypi kernel: [    2.920441] random: fast init done
                            Mar 26 22:33:07 raspberrypi kernel: [    2.949703] mmc1: new high speed SDIO card at address 0001
                            Mar 26 22:33:07 raspberrypi kernel: [    3.023386] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
                            Mar 26 22:33:07 raspberrypi kernel: [    3.055098] usb 2-1: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 2.09
                            Mar 26 22:33:07 raspberrypi kernel: [    3.063451] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                            Mar 26 22:33:07 raspberrypi kernel: [    3.070715] usb 2-1: Product: USB3.0 Device
                            Mar 26 22:33:07 raspberrypi kernel: [    3.074990] usb 2-1: Manufacturer: Intenso
                            Mar 26 22:33:07 raspberrypi kernel: [    3.079164] usb 2-1: SerialNumber: 20191413546A1
                            Mar 26 22:33:07 raspberrypi kernel: [    3.106867] scsi host0: uas
                            Mar 26 22:33:07 raspberrypi kernel: [    3.111119] scsi 0:0:0:0: Direct-Access     Intenso  SCSI             0209 PQ: 0 ANSI: 6
                            Mar 26 22:33:07 raspberrypi kernel: [    3.121770] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
                            Mar 26 22:33:07 raspberrypi kernel: [    3.129669] sd 0:0:0:0: [sda] 4096-byte physical blocks
                            Mar 26 22:33:07 raspberrypi kernel: [    3.135419] sd 0:0:0:0: [sda] Write Protect is off
                            Mar 26 22:33:07 raspberrypi kernel: [    3.140304] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
                            Mar 26 22:33:07 raspberrypi kernel: [    3.140791] sd 0:0:0:0: [sda] Disabling FUA
                            Mar 26 22:33:07 raspberrypi kernel: [    3.145094] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
                            Mar 26 22:33:07 raspberrypi kernel: [    3.155063] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
                            Mar 26 22:33:07 raspberrypi kernel: [    3.167389]  sda: sda1 sda2
                            Mar 26 22:33:07 raspberrypi kernel: [    3.173574] sd 0:0:0:0: [sda] Attached SCSI disk
                            Mar 26 22:33:07 raspberrypi kernel: [    3.203060] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                            Mar 26 22:33:07 raspberrypi kernel: [    3.385608] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                            Mar 26 22:33:07 raspberrypi kernel: [    3.393967] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                            Mar 26 22:33:07 raspberrypi kernel: [    3.401230] usb 1-1: Product: USB2.0 Hub
                            Mar 26 22:33:07 raspberrypi kernel: [    3.406877] hub 1-1:1.0: USB hub found
                            Mar 26 22:33:07 raspberrypi kernel: [    3.408058] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                            Mar 26 22:33:07 raspberrypi kernel: [    3.410858] hub 1-1:1.0: 4 ports detected
                            Mar 26 22:33:07 raspberrypi kernel: [    3.417710] EXT4-fs (sda2): write access will be enabled during recovery
                            Mar 26 22:33:07 raspberrypi kernel: [    3.743052] usb 1-1.2: new full-speed USB device number 3 using xhci_hcd
                            Mar 26 22:33:07 raspberrypi kernel: [    3.882164] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
                            Mar 26 22:33:07 raspberrypi kernel: [    3.890707] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                            Mar 26 22:33:07 raspberrypi kernel: [    3.898167] usb 1-1.2: Product: ConBee II
                            Mar 26 22:33:07 raspberrypi kernel: [    3.902254] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
                            Mar 26 22:33:07 raspberrypi kernel: [    3.909529] usb 1-1.2: SerialNumber: DE2400331
                            Mar 26 22:33:07 raspberrypi kernel: [    4.013058] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
                            Mar 26 22:33:07 raspberrypi kernel: [    4.147897] usb 1-1.4: New USB device found, idVendor=6901, idProduct=2701, bcdDevice= 1.00
                            Mar 26 22:33:07 raspberrypi kernel: [    4.156434] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                            Mar 26 22:33:07 raspberrypi kernel: [    4.175340] input: HID 6901:2701 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.$
                            Mar 26 22:33:07 raspberrypi kernel: [    4.191879] EXT4-fs (sda2): orphan cleanup on readonly fs
                            Mar 26 22:33:07 raspberrypi kernel: [    4.245268] EXT4-fs (sda2): 1 orphan inode deleted
                            Mar 26 22:33:07 raspberrypi kernel: [    4.250155] EXT4-fs (sda2): recovery complete
                            Mar 26 22:33:07 raspberrypi kernel: [    4.254959] hid-generic 0003:6901:2701.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 6901:2701] on usb-0000:01:00.0-1.4/input0
                            Mar 26 22:33:07 raspberrypi kernel: [    4.276246] input: HID 6901:2701 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.$
                            Mar 26 22:33:07 raspberrypi kernel: [    4.292615] input: HID 6901:2701 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/us$
                            Mar 26 22:33:07 raspberrypi kernel: [    4.373361] input: HID 6901:2701 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1$
                            Mar 26 22:33:07 raspberrypi kernel: [    4.390145] hid-generic 0003:6901:2701.0002: input,hidraw1: USB HID v1.10 Mouse [HID 6901:2701] on usb-0000:01:00.0-1.4/input1
                            Mar 26 22:33:07 raspberrypi kernel: [    4.531654] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                            Mar 26 22:33:07 raspberrypi kernel: [    4.539545] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                            Mar 26 22:33:07 raspberrypi kernel: [    4.579948] devtmpfs: mounted
                            Mar 26 22:33:07 raspberrypi kernel: [    4.591769] Freeing unused kernel memory: 2048K
                            Mar 26 22:33:07 raspberrypi kernel: [    4.596699] Run /sbin/init as init process
                            Mar 26 22:33:07 raspberrypi kernel: [    4.600873]   with arguments:
                            Mar 26 22:33:07 raspberrypi kernel: [    4.600888]     /sbin/init
                            Mar 26 22:33:07 raspberrypi kernel: [    4.600902]   with environment:
                            Mar 26 22:33:07 raspberrypi kernel: [    4.600916]     HOME=/
                            Mar 26 22:33:07 raspberrypi kernel: [    4.600930]     TERM=linux
                            Mar 26 22:33:07 raspberrypi kernel: [    5.590404] NET: Registered protocol family 10
                            Mar 26 22:33:07 raspberrypi kernel: [    5.596355] Segment Routing with IPv6
                            Mar 26 22:33:07 raspberrypi kernel: [    6.652772] random: systemd: uninitialized urandom read (16 bytes read)
                            Mar 26 22:33:07 raspberrypi kernel: [    6.707612] random: systemd: uninitialized urandom read (16 bytes read)
                            Mar 26 22:33:07 raspberrypi kernel: [    6.723209] random: systemd: uninitialized urandom read (16 bytes read)
                            Mar 26 22:33:07 raspberrypi kernel: [    9.173083] EXT4-fs (sda2): re-mounted. Opts: (null)
                            Mar 26 22:33:07 raspberrypi kernel: [    9.988654] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                            Mar 26 22:33:07 raspberrypi kernel: [    9.989211] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                            Mar 26 22:33:07 raspberrypi kernel: [    9.989737] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                            Mar 26 22:33:07 raspberrypi kernel: [    9.990269] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                            Mar 26 22:33:07 raspberrypi kernel: [   10.036876] random: crng init done
                            Mar 26 22:33:07 raspberrypi kernel: [   10.036890] random: 7 urandom warning(s) missed due to ratelimiting
                            Mar 26 22:33:07 raspberrypi kernel: [   10.048252] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                            Mar 26 22:33:07 raspberrypi kernel: [   10.050274] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                            Mar 26 22:33:07 raspberrypi kernel: [   10.050298] [vc_sm_connected_init]: start
                            Mar 26 22:33:07 raspberrypi kernel: [   10.070760] [vc_sm_connected_init]: installed successfully
                            Mar 26 22:33:07 raspberrypi kernel: [   10.087673] mc: Linux media interface: v0.10
                            Mar 26 22:33:07 raspberrypi kernel: [   10.192120] videodev: Linux video capture interface: v2.00
                            Mar 26 22:33:07 raspberrypi kernel: [   10.290053] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                            Mar 26 22:33:07 raspberrypi kernel: [   10.302608] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                            Mar 26 22:33:07 raspberrypi kernel: [   10.304798] bcm2835_audio bcm2835_audio: card created with 8 channels
                            Mar 26 22:33:07 raspberrypi kernel: [   10.305496] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                            Mar 26 22:33:07 raspberrypi kernel: [   10.317240] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                            Mar 26 22:33:07 raspberrypi kernel: [   10.320543] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                            Mar 26 22:33:07 raspberrypi kernel: [   10.405072] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                            Mar 26 22:33:07 raspberrypi kernel: [   10.408578] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                            Mar 26 22:33:07 raspberrypi kernel: [   10.416025] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                            Mar 26 22:33:07 raspberrypi kernel: [   10.419068] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                            Mar 26 22:33:07 raspberrypi kernel: [   10.420243] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                            Mar 26 22:33:07 raspberrypi kernel: [   10.420278] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                            Mar 26 22:33:07 raspberrypi kernel: [   10.420303] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                            Mar 26 22:33:07 raspberrypi kernel: [   10.420328] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                            Mar 26 22:33:07 raspberrypi kernel: [   10.420351] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                            Mar 26 22:33:07 raspberrypi kernel: [   10.420626] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                            Mar 26 22:33:07 raspberrypi kernel: [   10.425320] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                            Mar 26 22:33:07 raspberrypi kernel: [   10.425392] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                            Mar 26 22:33:07 raspberrypi kernel: [   10.435324] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                            Mar 26 22:33:07 raspberrypi kernel: [   10.435369] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                            Mar 26 22:33:07 raspberrypi kernel: [   10.461614] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                            Mar 26 22:33:07 raspberrypi kernel: [   10.461658] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                            Mar 26 22:33:07 raspberrypi kernel: [   10.467980] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                            Mar 26 22:33:07 raspberrypi kernel: [   10.532361] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                            Mar 26 22:33:07 raspberrypi kernel: [   10.681219] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
                            Mar 26 22:33:07 raspberrypi kernel: [   10.690469] usbcore: registered new interface driver cdc_acm
                            Mar 26 22:33:07 raspberrypi kernel: [   10.690487] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                            Mar 26 22:33:07 raspberrypi kernel: [   10.765564] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                            Mar 26 22:33:07 raspberrypi kernel: [   10.853319] brcmfmac: F1 signature read @0x18000000=0x15264345
                            Mar 26 22:33:07 raspberrypi kernel: [   10.864057] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                            Mar 26 22:33:07 raspberrypi kernel: [   10.864863] usbcore: registered new interface driver brcmfmac
                            Mar 26 22:33:07 raspberrypi kernel: [   10.910279] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                            Mar 26 22:33:07 raspberrypi kernel: [   11.043072] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                            Mar 26 22:33:07 raspberrypi kernel: [   11.043199] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                            Mar 26 22:33:07 raspberrypi kernel: [   11.048176] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                            Mar 26 22:33:07 raspberrypi kernel: [   11.155101] sd 0:0:0:0: Attached scsi generic sg0 type 0
                            Mar 26 22:33:07 raspberrypi kernel: [   11.155251] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                            Mar 26 22:33:07 raspberrypi kernel: [   11.163966] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01$
                            Mar 26 22:33:07 raspberrypi kernel: [   13.498392] uart-pl011 fe201000.serial: no DMA platform data
                            Mar 26 22:33:07 raspberrypi kernel: [   13.894220] 8021q: 802.1Q VLAN Support v1.8
                            Mar 26 22:33:07 raspberrypi kernel: [   14.413084] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
                            Mar 26 22:33:08 raspberrypi kernel: [   14.654710] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                            Mar 26 22:33:09 raspberrypi kernel: [   16.114416] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                            Mar 26 22:33:09 raspberrypi kernel: [   16.114691] bcmgenet fd580000.ethernet eth0: Link is Down
                            Mar 26 22:33:13 raspberrypi kernel: [   20.313179] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                            Mar 26 22:33:13 raspberrypi kernel: [   20.313210] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                            Mar 26 22:33:14 raspberrypi kernel: [   20.886065] Bluetooth: Core ver 2.22
                            Mar 26 22:33:14 raspberrypi kernel: [   20.886127] NET: Registered protocol family 31
                            Mar 26 22:33:14 raspberrypi kernel: [   20.886134] Bluetooth: HCI device and connection manager initialized
                            Mar 26 22:33:14 raspberrypi kernel: [   20.886150] Bluetooth: HCI socket layer initialized
                            Mar 26 22:33:14 raspberrypi kernel: [   20.886160] Bluetooth: L2CAP socket layer initialized
                            Mar 26 22:33:14 raspberrypi kernel: [   20.886175] Bluetooth: SCO socket layer initialized
                            Mar 26 22:33:14 raspberrypi kernel: [   20.936445] Bluetooth: HCI UART driver ver 2.3
                            Mar 26 22:33:14 raspberrypi kernel: [   20.936456] Bluetooth: HCI UART protocol H4 registered
                            Mar 26 22:33:14 raspberrypi kernel: [   20.936511] Bluetooth: HCI UART protocol Three-wire (H5) registered
                            Mar 26 22:33:14 raspberrypi kernel: [   20.939344] Bluetooth: HCI UART protocol Broadcom registered
                            Mar 26 22:33:14 raspberrypi kernel: [   21.471353] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                            Mar 26 22:33:14 raspberrypi kernel: [   21.471362] Bluetooth: BNEP filters: protocol multicast
                            Mar 26 22:33:14 raspberrypi kernel: [   21.471375] Bluetooth: BNEP socket layer initialized
                            Mar 26 22:33:15 raspberrypi kernel: [   22.394420] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.$
                            Hier dann der Reboot:
                            Mar 27 05:36:02 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
                            Mar 27 05:36:02 raspberrypi kernel: [    0.000000] Linux version 5.10.11-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (G$
                            Mar 27 05:36:02 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                            Mar 27 05:36:02 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
                            Mar 27 05:36:02 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                            Mar 27 05:36:02 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
                            Mar 27 05:36:02 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
                              Mar 26 22:33:07 raspberrypi kernel: [ 4.191879] EXT4-fs (sda2): orphan cleanup on readonly fs Mar 26 22:33:07 raspberrypi kernel: [ 4.245268] EXT4-fs (sda2): 1 orphan inode deleted
                              Auf /dev/sda2 ist das Dateisystem angeschossen.
                                Christian Wöhrle
                                Ich bin mir jetzt nicht sicher was ich damit anfangen kann. Ist das eine Frage oder eine Aussage die mir etwas sagen soll?
                                lsusb -t sagt:
                                /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
                                    |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 5000M
                                /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
                                    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
                                        |__ Port 2: Dev 6, If 0, Class=Communications, Driver=cdc_acm, 12M
                                        |__ Port 2: Dev 6, If 1, Class=CDC Data, Driver=cdc_acm, 12M
                                        |__ Port 4: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.             5M
                                        |__ Port 4: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 1.             5M
                                Ich habe an Bus 02 eine Festplatte hängen, auf der der Broker läuft.
                                Sonst nur einen Conbee II Stick der per Deconz abgefragt wird.
                                  lsusb -t sagt:
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @christian-wöhrle Ich würde behaupten die Aussage von @Thomas-Braun weist dich darauf hin das eines deiner Dateisysteme (Ja, Linux nutzt mehrere davon) nicht mehr in Ordnung sind.
                                  Welches betroffen ist kannst du mit dem Befehl "mount" auf der Konsole abfragen. (ich vermute das du einen Eintrag ähnlich wie diesen findest:)
                                  /dev/sda2 on / type ext4 (rw,noatime,data=ordered)
                                  Ich gehe im Moment davon aus das es sich um deine USB Festplatte handelt die ein Problem hat. Es kann sein das nur das Dateisystem auf Grund von unsachgemässem "entfernen" der Festplatte geschädigt ist, aber auch das die Platte selber ein Problem hat.
                                  A.
                                  • AsgothianA Asgothian
                                    A.
                                    Christian Wöhrle
                                    @asgothian
                                    aha, das ist sehr interessant. Das sagt mount:
                                    /dev/sda2 on / type ext4 (rw,noatime)
                                    devtmpfs on /dev type devtmpfs (rw,relatime,size=1826960k,nr_inodes=97608,mode=755)
                                    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
                                    proc on /proc type proc (rw,relatime)
                                    securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
                                    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
                                    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
                                    tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
                                    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
                                    tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
                                    cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
                                    cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
                                    none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
                                    cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
                                    cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
                                    cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
                                    cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
                                    cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
                                    cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
                                    cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
                                    cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
                                    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
                                    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
                                    mqueue on /dev/mqueue type mqueue (rw,relatime)
                                    debugfs on /sys/kernel/debug type debugfs (rw,relatime)
                                    configfs on /sys/kernel/config type configfs (rw,relatime)
                                    /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
                                    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=391808k,mode=700,uid=1000,gid=1000)
                                    Die Festplatte an sich glaube ich nicht. Ich hatte den Broker auf einer SD-Karte am laufen. Aufgrund der anhaltenden Fehler dachte ich auch dass die Karte einen knacks hat und bin dann auf die Festplatte gewechselt. Leider ist das Problem das Gleich. Was ist dein Rat? Backup anlegen und Platte komplett platt machen, Raspbian OS neu installieren, IOBroker neu installieren und Backup einlesen? Oder lässt sich das Dateisystem reparieren? Dazu hätte man den Befehl sudo touch /forcefsck lt. https://www.rustimation.eu/index.php/filesystem-reparieren/.
                                      @asgothian
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      @christian-wöhrle
                                      • Wie bist du auf die Festplatte gewechselt ? Hast du neu installiert oder die bestehende Installation von der Karte herunter kopiert ?
                                      • Hat dein PI ggf. Probleme mit der Stromversorgung ?
                                      A
                                        @christian-wöhrle
                                        A
                                        Christian Wöhrle
                                        @asgothian
                                        Ich habe Raspberry os lite neu installiert. Stromversorung: 5V / 3A
                                          @christian-wöhrle
                                          A
                                          Christian Wöhrle
                                          @asgothian
                                          Die Stromversorgung müsste doch ausreichen und richtig sein, oder?
                                          AsgothianA Thomas BraunT 2 Antworten Letzte Antwort
