  4. Iobroker backitup error.. Wo liegt das problem
    6.3k
283 Beiträge 14 Kommentatoren 39.3k Aufrufe 8 Beobachtet
  • Fred FreundF Offline
    Fred Freund
    schrieb am zuletzt editiert von Fred Freund
    einige Access Permissions und Konfigurationsfehler habe ich gefunden und ausgebessert.
    2021-03-23 20:46:25.638 - error: backitup.0 (5704) [iobroker] error on backup process: Error when executing script "zigbee": ReferenceError: timer is not defined Please check the config of backitup and execute "iobroker fix"
    2021-03-23 20:46:25.807 - error: backitup.0 (5704) [iobroker] Error: EACCES: permission denied, mkdir '/opt/iobroker/backups/grafana_tmp/dashboards'
    2021-03-23 20:46:25.811 - error: backitup.0 (5704) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-03-23 20:46:25.811 - error: backitup.0 (5704) unhandled promise rejection: callback is not a function
    2021-03-23 20:46:25.813 - error: backitup.0 (5704) TypeError: callback is not a function
    at Object.command (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:270:9)
    at Immediate.executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:359:26)
    at processImmediate (internal/timers.js:463:21)
    2021-03-23 20:46:25.814 - error: backitup.0 (5704) callback is not a function
    2021-03-23 20:46:25.836 - info: backitup.0 (5704) cleaned everything up...
    2021-03-23 20:46:25.837 - info: backitup.0 (5704) terminating
    2021-03-23 20:46:25.839 - warn: backitup.0 (5704) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2021-03-23 20:46:26.485 - error: host.broker1 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2021-03-23 20:46:26.486 - error: host.broker1 Caught by controller[1]: TypeError: callback is not a function
    2021-03-23 20:46:26.486 - error: host.broker1 Caught by controller[1]: at Object.command (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:270:9)
    2021-03-23 20:46:26.487 - error: host.broker1 Caught by controller[1]: at Immediate.executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:359:26)
    2021-03-23 20:46:26.487 - error: host.broker1 Caught by controller[1]: at processImmediate (internal/timers.js:463:21)
    2021-03-23 20:46:26.488 - error: host.broker1 instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2021-03-23 20:46:26.488 - info: host.broker1 Restart adapter system.adapter.backitup.0 because enabled
    2021-03-23 20:46:56.527 - info: host.broker1 instance system.adapter.backitup.0 started with pid 6348
    2021-03-23 20:46:59.926 - info: backitup.0 (6348) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
    2021-03-23 20:47:00.019 - info: backitup.0 (6348) [iobroker] backup was activated at 02:40 every 1 day(s)
    Könnt ihr mir bitte sagen was hier schief läuft?
    welcher timer im zigbee soll das sein
    Erste Zeile!
    Thx
    many Thx for your support,
    Vielen Dank!
    • Fred FreundF Fred Freund
      Erste Zeile!
      Thx
      @fred-freund sagte in Iobroker backitup error.. Wo liegt das problem:
      iobroker fix
      mal ausgeführt? Ansonsten bräuchte man wohl auch die Konfiguration der einzelnen Backupvarianten, denke ich.
      Fred FreundF 1 Antwort Letzte Antwort
        iobroker fix
        Fred Freund
        Jetzt startet der iobroker 8081nicht mehr, node red lauft aber auf 1880..
        1882 läuft auch nur der Admin nicht..
        Denke habe den unabsichtlich deaktiviert.. Wie drehe ich den wieder auf?
        Vielen Dank!
          @fred-freund
          Was haste denn nun gemacht?
          iobroker status
          iobroker list adapters
          iobroker list instances
            @fred-freund
            iobroker status
            Fred Freund
            Gefunden
            iobroker start admin
            Iobroker fix sagte soll alle adapter disable setzen.. Irrtümlich admin erwischt
            :-) als erstes. LETZTES!
            Man soll nicht Sowas mit einem Tablett machen.
            Vielen Dank!
              Gefunden
              @fred-freund Der fixer sagt, man soll den kompletten iobroker stoppen, nicht nur die Instanzen. Jedenfalls ist das damit gemeint...
              iobroker stop
              ist dein Freund.
                iobroker stop
                ist dein Freund.
                Fred Freund
                io.javascript.0
                 io.mqtt.0
                 io.ping.0
                 io.rpi2.0
                 io.web.0
                 io.zigbee.0
                 io.zwave2.0
                Please stop them first and try again!
                Z. Bsp.
                Soll jetzt backitup neu installieren nochmal fix...
                Kann in opt/iobroker/backup keine Ordner anlegen
                OK bis auf
                Started iobroker ...
                [DEBUG] [mount] - mount successfully completed
                [DEBUG] [mount] - done
                [DEBUG] [iobroker] - host.broker1 1195 states saved
                [DEBUG] [iobroker] - host.broker1 1570 objects saved
                [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_03_23-22_18_13_backupiobroker.tar.gz'
                [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                Vielen Dank!
                  io.javascript.0
                   io.mqtt.0
                   io.ping.0
                   io.rpi2.0
                   io.web.0
                   io.zigbee.0
                   io.zwave2.0
                  Z. Bsp.
                  OK bis auf
                  ls -la /opt/iobroker/backups/
                    Fred Freund
                    drwxrwxr-x+ 2 iobroker iobroker    4096 Mar 23 20:32 .
                    drwxrwxr-x+ 6 iobroker iobroker    4096 Mar 23 21:57 ..
                    -rw-rwxr--+ 1 iobroker iobroker 3339610 Mar  9 21:18 2021_03_09-21_18_54_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 19:58 historyDB_2021_03_23-19_58_43_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:04 historyDB_2021_03_23-20_04_53_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:06 historyDB_2021_03_23-20_06_28_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:31 historyDB_2021_03_23-20_31_53_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:32 historyDB_2021_03_23-20_32_47_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker     991 Mar 23 19:58 influxDB_2021_03_23-19_58_42_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker     991 Mar 23 20:04 influxDB_2021_03_23-20_04_52_Iobroker1_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker     990 Mar 23 20:06 influxDB_2021_03_23-20_06_27_Iobroker1_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker     989 Mar 23 20:31 influxDB_2021_03_23-20_31_52_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker     990 Mar 23 20:32 influxDB_2021_03_23-20_32_46_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3516990 Mar 23 19:58 iobroker_2021_03_23-19_58_36_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3517122 Mar 23 20:04 iobroker_2021_03_23-20_04_46_Iobroker1_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3517072 Mar 23 20:06 iobroker_2021_03_23-20_06_20_Iobroker1_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3517129 Mar 23 20:31 iobroker_2021_03_23-20_31_45_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3517069 Mar 23 20:32 iobroker_2021_03_23-20_32_40_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker   83731 Mar 23 19:58 zigbee.0_2021_03_23-19_58_43_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker   83731 Mar 23 20:04 zigbee.0_2021_03_23-20_04_53_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker   83731 Mar 23 20:06 zigbee.0_2021_03_23-20_06_28_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker   83736 Mar 23 20:31 zigbee.0_2021_03_23-20_31_53_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker   83736 Mar 23 20:32 zigbee.0_2021_03_23-20_32_47_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker    1669 Mar 23 19:58 zigbee.1_2021_03_23-19_58_43_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker    1669 Mar 23 20:04 zigbee.1_2021_03_23-20_04_53_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker    1669 Mar 23 20:06 zigbee.1_2021_03_23-20_06_28_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker    1669 Mar 23 20:31 zigbee.1_2021_03_23-20_31_53_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker    1669 Mar 23 20:32 zigbee.1_2021_03_23-20_32_47_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 19:58 zigbee.2_2021_03_23-19_58_43_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:04 zigbee.2_2021_03_23-20_04_53_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:06 zigbee.2_2021_03_23-20_06_28_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:31 zigbee.2_2021_03_23-20_31_53_backupiobroker.tar.gz
                    -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:32 zigbee.2_2021_03_23-20_32_47_backupiobroker.tar.gz
                    Ist da jetzt auch Node red backed up, Dh. Die Flows???
                    Danke!
                    Vielen Dank!
                      Danke!
                      @fred-freund
                      Die Datei gibt es ja auch gar nicht. Kann es sein, dass du den Backup-Vorgang im laufenden Betrieb abgeschossen hast?
                        @fred-freund
                        Fred Freund
                        @thomas-braun eigentlich habe ich Nas gewählt.
                        Hier das Nas verzeichnis..
                        Ein altes ist manuell gemacht.. Auch die flows.. Etc.
                        -rwxr--r--  1 1000 1000 3339610 Mär  9 21:25 2021_03_09-21_18_54_backupiobroker.tar.gz
                        -rwxr--r--  1 1000 1000  697099 Nov 28 15:27 CC2531ZNP-Prod.hex
                        -rwxr--r--  1 1000 1000   18318 Mär  9 21:30 flows.json
                        drwxr-xr-x  2 1000 1000    4096 Mär 23 22:22 grafana_tmp
                        -rw-r--r--  1 1000 1000       0 Mär 23 20:36 historyDB_2021_03_23-20_36_04_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 20:46 historyDB_2021_03_23-20_46_25_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 21:59 historyDB_2021_03_23-21_59_26_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 22:02 historyDB_2021_03_23-22_02_05_backupiobroker.tar.gz
                        -rwxr--r--  1 1000 1000       0 Mär 23 22:05 historyDB_2021_03_23-22_05_32_backupiobroker.tar.gz
                        -rwxr--r--  1 1000 1000     977 Mär 23 22:05 influxDB_2021_03_23-22_05_31_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 20:36 iobroker_2021_03_23-20_35_58_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 20:46 iobroker_2021_03_23-20_46_19_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 21:59 iobroker_2021_03_23-21_59_20_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 22:02 iobroker_2021_03_23-22_01_59_backupiobroker.tar.gz
                        -rwxr--r--  1 1000 1000 3520194 Mär 23 22:05 iobroker_2021_03_23-22_05_24_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 22:16 iobroker_2021_03_23-22_16_39_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 22:18 iobroker_2021_03_23-22_18_13_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 22:22 iobroker_2021_03_23-22_22_44_backupiobroker.tar.gz
                        -rwxr--r--  1 1000 1000  585004 Mär 13 21:29 iobroker.current.log
                        -rwxrwxr--+ 1 1000 1000   92404 Mär 14 13:43 iobroker.rtf
                        -rw-rw-r--  1 1000 1000       0 Mär 23 22:37 txt.txt
                        -rw-r--r--  1 1000 1000       0 Mär 23 20:36 zigbee.0_2021_03_23-20_36_04_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 20:46 zigbee.0_2021_03_23-20_46_25_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 21:59 zigbee.0_2021_03_23-21_59_27_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 22:02 zigbee.0_2021_03_23-22_02_05_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 20:36 zigbee.1_2021_03_23-20_36_04_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 20:46 zigbee.1_2021_03_23-20_46_25_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 21:59 zigbee.1_2021_03_23-21_59_27_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 22:02 zigbee.1_2021_03_23-22_02_05_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 20:36 zigbee.2_2021_03_23-20_36_04_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 20:46 zigbee.2_2021_03_23-20_46_25_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 21:59 zigbee.2_2021_03_23-21_59_27_backupiobroker.tar.gz
                        -rw-r--r--  1 1000 1000       0 Mär 23 22:02 zigbee.2_2021_03_23-22_02_05_backupiobroker.tar.gz
                        Vielen Dank!
                          @fred-freund Der user iobroker hat i.d.R. nicht die UID 1000
                          cat /etc/passwd | grep iobroker
                            Fred Freund
                            pi@broker1:~ $ cat /etc/passwd | grep iobroker
                            iobroker:x:1001:1001::/home/iobroker:/usr/sbin/nologin
                            Raspi! Aber am Nas gibt's den smb User für den share!
                            Vielen Dank!
                              @fred-freund Aber der hat da eine andere UID.
                                Fred Freund
                                Auszug ist oben!
                                Nein abgeschossen hab ich den Vorgang nicht..
                                Werd mal Nas wegnehmen und schauen was er lokal macht... Oder macht er das trotzdem?
                                Braucht man das Javascript bkup?
                                Auch Ohne Javascript..
                                [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_03_23-23_09_27_backupiobroker.tar.gz'
                                [DEBUG] [iobroker] - done
                                [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                                [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                                [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_03_23-23_09_32_backupiobroker"
                                backup: open temp file: open /opt/iobroker/backups/influxDB_2021_03_23-23_09_32_backupiobroker/meta.00.pending: permission denied
                                Vielen Dank!
                                  Auszug ist oben!
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  @fred-freund Versuche mal bitte die Version 2.1.0
                                  • Besuche meine Github Seite
                                  • HowTo Restore ioBroker
                                  • simatecS simatec
                                    Fred Freund
                                    @simatec
                                    [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_03_24-22_45_57_backupiobroker.tar.gz'
                                    [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1,zigbee.2
                                    [DEBUG] [zigbee] - done
                                    [ERROR] [zigbee] - [IGNORED] Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2021_03_24-22_46_03_backupiobroker.tar.gz'
                                    [DEBUG] [cifs] - Copy iobroker_2021_03_24-22_45_57_backupiobroker.tar.gz...
                                    [DEBUG] [cifs] - Copy zigbee.0_2021_03_24-22_46_03_backupiobroker.tar.gz...
                                    [DEBUG] [cifs] - Copy zigbee.1_2021_03_24-22_46_03_backupiobroker.tar.gz...
                                    [DEBUG] [cifs] - Copy zigbee.2_2021_03_24-22_46_03_backupiobroker.tar.gz...
                                    [DEBUG] [cifs] - done
                                    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/home/iobroker","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                                    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                                    [DEBUG] [clean] - done
                                    [DEBUG] [historyHTML] - new history html values created
                                    [DEBUG] [historyHTML] - done
                                    [DEBUG] [historyJSON] - new history json values created
                                    [DEBUG] [historyJSON] - done
                                    [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,
                                    Das Backup hat wieder Größe 0
                                    Der Ordner am smb share
                                    drwxrwxrwx  3 1000 1000      4096 Mär 24 22:46 iobroker
                                    rw-r--r--  1 1000 1000       0 Mär 24 22:39 zigbee.1_2021_03_24-22_39_23_backupiobroker.tar.gz
                                    Vielen Dank!
                                      @simatec
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      @fred-freund
                                      Dann hast du ein Rechteproblem.
                                      Hast du iobroker fix bereits ausgeführt?
                                      • simatecS simatec
                                        @fred-freund
                                        Fred Freund
                                        @simatec
                                        Ja gestern 2x
                                        Mach ich jetzt auch nochmal... Je nachdem welche smb Version ich verwende ändert sich auch die Error Meldung..
                                        2021-03-24 23:00:26.538  - error: backitup.0 (27502) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
                                        Smb 3.1.1
                                        Fix hat nix gebracht... :-(
                                        Vielen Dank!
                                          @simatec
                                          Ja gestern 2x
                                          Smb 3.1.1
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          @fred-freund
                                          Bitte vollständigen Log posten
