  4. NODEmcu K-Type Temp-Fühler in IObroker !? [gelöst]
    6.7k
nodemcu max38155 mqtt
39 Beiträge 2 Kommentatoren 3.7k Aufrufe 2 Beobachtet
  • M MCU
    Du musst das Semikolon hier entfernen nach dem define:
    Q Offline
    Q Offline
    Qax1
    @mcu
    Jetzt kommt der Fehler :
    Arduino: 1.8.13 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, WIFI, Only Sketch, 115200"
    MQTT-TEST-1:25:1: error: 'MQTTClient' does not name a type
    MQTTClient client;
    C:\Users\Stefan\Documents\Arduino\MQTT-TEST-1\MQTT-TEST-1.ino: In function 'void connect()':
    MQTT-TEST-1:34:12: error: 'client' was not declared in this scope
    while (!client.connect(client_name,"MQTTUser","MQTTPassword")) {
    MQTT-TEST-1:40:4: error: 'client' was not declared in this scope
    client.subscribe(client_name + "/+");
    MQTT-TEST-1:40:35: error: invalid operands of types 'const char [10]' and 'const char [3]' to binary 'operator+'
    MQTT-TEST-1:41:33: error: invalid operands of types 'const char [10]' and 'const char [7]' to binary 'operator+'
    client.publish(client_name + "/alive","true");
    C:\Users\Stefan\Documents\Arduino\MQTT-TEST-1\MQTT-TEST-1.ino: In function 'void setup()':
    MQTT-TEST-1:59:2: error: 'client' was not declared in this scope
    client.begin("http://192.168.178.30",1883,net); //192.168.178.45
    C:\Users\Stefan\Documents\Arduino\MQTT-TEST-1\MQTT-TEST-1.ino: In function 'void loop()':
    MQTT-TEST-1:75:5: error: 'client' was not declared in this scope
     client.publish(client_name + "/InternalTemp",String(c));
    MQTT-TEST-1:75:34: error: invalid operands of types 'const char [10]' and 'const char [14]' to binary 'operator+'
    MQTT-TEST-1:77:3: error: 'client' was not declared in this scope
    client.loop();
    MQTT-TEST-1:81:6: error: 'werteCount' was not declared in this scope
      werteCount = 0;
    MQTT-TEST-1:86:35: error: invalid operands of types 'const char [10]' and 'const char [16]' to binary 'operator+'
      client.publish(client_name + "/connectProblem","Verbindungsproblem gehabt");
    exit status 1
    Dieser Bericht wäre detaillierter, wenn die Option
    "Ausführliche Ausgabe während der Kompilierung"
    in Datei -> Voreinstellungen aktiviert wäre.
      MCU
      @qax1 Hast du jetzt meine MQTT genutzt? Und hast du das Semikolon entfernt?
      Hier darf nur die IP stehen:
      Also http:// weg
      Q 1 Antwort Letzte Antwort
      • M MCU
        Also http:// weg
        Q Offline
        Q Offline
        Qax1
        @mcu
        Ich habe den PUNKT hinter dem h
        und den Semikolon weg gemacht.
        • Q Qax1
          @mcu
          MCU
          @qax1 Dann entpack jetzt die Datei MQTT.7z und schieb den Ordner MQTT dann in Dokumente/Arduino.
          Und danach oben wieder auf MQTT.h ändern.
          • M MCU
            Q Offline
            Q Offline
            Qax1
            @mcu
            Ok... erledigt... jetzt kommt :
              werteCount = 0;
            exit status 1
            • Q Qax1
              @mcu
                werteCount = 0;
              exit status 1
              Q Offline
              Q Offline
              Qax1
              @MCU
              Ich weiß nicht ob s was zu sagen hat,
              aber ich habe in IObroker im MQTT-Adapter
              keinen Namen / Passwort vergeben.
              • Q Qax1
                @MCU
                MCU
                @mcu Eins nachdem anderen:
                1. String MCUName = "SensorMax"; einfügen nach #define client_name
                2. werteCount = 0; Zeile komplett löschen
                3. bei client.subscribe(client_name : client_name durch MCUName ersetzen
                4. und bei allen client.publish(client_name : client_name durch MCUName ersetzen
                5. beim client.connect"MQTTUser","MQTTPassword" -> "",""
                • M MCU
                  Q Offline
                  Q Offline
                  Qax1
                  @mcu
                  Komplieren läuft jetzt komplett durch...
                    MCU
                    @qax1 Dann schick mir mal das komplette Script.
                    • M MCU
                      Q Offline
                      Q Offline
                      Qax1
                      schrieb am zuletzt editiert von Qax1
                      @mcu ```
                      #include <Wire.h>
                      #include <SPI.h>
                      #include "Adafruit_MAX31855.h"
                      #include <ESP8266WiFi.h>
                      #include <MQTT.h>
                      #define CLK 14 //connect CLK to GPIO14
                      #define CS 5 //connect CS to GPIO5
                      #define DO 12 //connect DO to GPIO12
                      #define client_name "SensorMAX"
                      const char ssid[] = "xyz";
                      const char pass[] = "xxxxxxxxxxxxxxxxx";
                      String Nachricht_MQTT = "";
                      String Topic_MQTT = "";
                      Adafruit_MAX31855 thermocouple(CLK,CS,DO);
                      WiFiClient net;
                      MQTTClient client;
                      void connect() {
                      Serial.print("\nchecking wifi...");
                      while (WiFi.status() != WL_CONNECTED) {
                      Serial.print(".");
                      delay(1000);
                      Serial.print("\nconnecting...");
                      Serial.print(".");
                      delay(1000);
                      Serial.print("\nconnected!");
                      client.subscribe(MCUName + "/+");
                      client.publish(MCUName + "/alive","true");
                      void messageReceived(String &topic, String &payload) {
                      Serial.println("MQTT incoming: " + topic + " - " + payload);
                      Topic_MQTT = topic;
                      Nachricht_MQTT = payload;
                      topic = "";
                      payload = "";
                      void setup() {
                      Serial.begin(9600);
                      Serial.println("MAX31855 testing");
                      delay(500);
                      WiFi.begin(ssid, pass);
                      client.begin("192.168.178.30",1883,net); //192.168.178.45
                      connect(); //alive wird gesendet
                      client.onMessage(messageReceived);
                      void loop() {
                      Serial.print("Internal Temp = ");
                      Serial.println(thermocouple.readInternal());
                      delay(100);
                      double c = thermocouple.readCelsius();
                      if (isnan(c)) {
                      Serial.println("Something wrong with thermocouple!");
                      } else {
                      Serial.print("C = ");
                      Serial.println(c);
                      client.publish(MCUName + "/InternalTemp",String(c));
                      client.loop();
                      if (!client.connected()) {
                      Serial.println("Neustart!");
                      delay(200);
                      client.publish(MCUName + "/connectProblem","Verbindungsproblem gehabt");
                      delay(1000);
                      • Q Qax1
                        @mcu ```
                        #include <Wire.h>
                        #include <SPI.h>
                        #include <MQTT.h>
                        WiFiClient net;
                        MQTTClient client;
                        void connect() {
                        Serial.print(".");
                        delay(1000);
                        Serial.print(".");
                        delay(1000);
                        Topic_MQTT = topic;
                        topic = "";
                        payload = "";
                        void setup() {
                        Serial.begin(9600);
                        delay(500);
                        void loop() {
                        delay(100);
                        if (isnan(c)) {
                        } else {
                        Serial.println(c);
                        client.loop();
                        delay(200);
                        delay(1000);
                        MCU
                        @qax1 sagte in NODEmcu K-Type Temp-Fühler in IObroker !?:
                        noch ändern -> "",""
                        Code-tags - erste Zeile frei lassen , sonst versteht er das nicht.
                        client.begin("http://192.168.178.30",1883,net); ->client.begin("192.168.178.30",1883,net);
                        das http:// entfernen
                        • M MCU
                          Q Offline
                          Q Offline
                          Qax1
                          @mcu
                          Ok... erledigt
                          • Q Qax1
                            @mcu
                            Ok... erledigt
                            MCU
                            @qax1 Dann zeig nochmal, aber erste Zeile frei lassen-> Return und dann erst Code-Tag (</>).
                            • M MCU
                              Q Offline
                              Q Offline
                              Qax1
                              @mcu
                              #include <Wire.h>
                              #include <SPI.h>
                              #include <MQTT.h>
                              const char pass[] = "xxxxxxxxxxxxxxxxxxx";
                              WiFiClient net;
                              MQTTClient client;
                              void connect() {
                                   Serial.print(".");
                                   delay(1000);
                                   Serial.print(".");
                                   delay(1000);
                               Topic_MQTT = topic;
                               topic = "";
                               payload = "";
                              void setup() {
                               Serial.begin(9600);
                               delay(500);
                              void loop() {
                                delay(100);
                                if (isnan(c)) {
                                } else {
                                  Serial.println(c);
                                client.loop();
                                   delay(200);
                                delay(1000);
                              • Q Qax1
                                @mcu
                                #include <Wire.h>
                                #include <SPI.h>
                                #include <MQTT.h>
                                WiFiClient net;
                                MQTTClient client;
                                void connect() {
                                     Serial.print(".");
                                     delay(1000);
                                     Serial.print(".");
                                     delay(1000);
                                 Topic_MQTT = topic;
                                 topic = "";
                                 payload = "";
                                void setup() {
                                 Serial.begin(9600);
                                 delay(500);
                                void loop() {
                                  delay(100);
                                  if (isnan(c)) {
                                  } else {
                                    Serial.println(c);
                                  client.loop();
                                     delay(200);
                                  delay(1000);
                                MCU
                                Immer noch nicht geändert:
                                while (!client.connect(client_name,"MQTTUser","MQTTPassword")) -> while (!client.connect(client_name,"",""))
                                • M MCU
                                  Q Offline
                                  Q Offline
                                  Qax1
                                  @mcu sagte in NODEmcu K-Type Temp-Fühler in IObroker !?:
                                     while (!client.connect(MCUName,"","")) {
                                       Serial.print(".");
                                       delay(1000);
                                  so ?
                                  • Q Qax1
                                         Serial.print(".");
                                         delay(1000);
                                    so ?
                                    MCU
                                    @qax1
                                    dort nicht den client_name ersetzen!
                                    • M MCU
                                      @qax1
                                      Q Offline
                                      Q Offline
                                      Qax1
                                      @mcu
                                        while (!client.connect(client_name,"","")) {
                                           Serial.print(".");
                                           delay(1000);
                                      ok
                                      • Q Qax1
                                        @mcu
                                             Serial.print(".");
                                             delay(1000);
                                        ok
                                        MCU
                                        @qax1 Dann lass mal laufen. Kommt im ioBroker MQTT was an?
                                        Sonst zeige die Einstellungen zum MQTT-Adapter.
                                        Meine sind:
                                        • M MCU
                                          Meine sind:
                                          Q Offline
                                          Q Offline
                                          Qax1
                                          @mcu
                                          Sau Geil es läuft....
                                          Ich kann dir gar nicht genug Danken....
                                          Das hätte ich alleine wohl nie hinbekommen 🍻 🍻 🍻
