  4. NODEmcu K-Type Temp-Fühler in IObroker !? [gelöst]
    6.7k
nodemcu max38155 mqtt
39 Beiträge 2 Kommentatoren 3.7k Aufrufe 2 Beobachtet
  • M MCU
    @qax1 Dann schick mir mal das komplette Script.
    Q Offline
    Q Offline
    Qax1
    schrieb am zuletzt editiert von Qax1
    @mcu ```
    #include <Wire.h>
    #include <SPI.h>
    #include "Adafruit_MAX31855.h"
    #include <ESP8266WiFi.h>
    #include <MQTT.h>
    #define CLK 14 //connect CLK to GPIO14
    #define CS 5 //connect CS to GPIO5
    #define DO 12 //connect DO to GPIO12
    #define client_name "SensorMAX"
    String MCUName = "SensorMax";
    const char ssid[] = "xyz";
    const char pass[] = "xxxxxxxxxxxxxxxxx";
    String Nachricht_MQTT = "";
    String Topic_MQTT = "";
    Adafruit_MAX31855 thermocouple(CLK,CS,DO);
    WiFiClient net;
    MQTTClient client;
    void connect() {
    Serial.print("\nchecking wifi...");
    while (WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
    delay(1000);
    Serial.print("\nconnecting...");
    while (!client.connect(client_name,"MQTTUser","MQTTPassword")) {
    Serial.print(".");
    delay(1000);
    Serial.print("\nconnected!");
    client.subscribe(MCUName + "/+");
    client.publish(MCUName + "/alive","true");
    void messageReceived(String &topic, String &payload) {
    Serial.println("MQTT incoming: " + topic + " - " + payload);
    Topic_MQTT = topic;
    Nachricht_MQTT = payload;
    topic = "";
    payload = "";
    void setup() {
    Serial.begin(9600);
    Serial.println("MAX31855 testing");
    delay(500);
    WiFi.begin(ssid, pass);
    client.begin("192.168.178.30",1883,net); //192.168.178.45
    connect(); //alive wird gesendet
    client.onMessage(messageReceived);
    void loop() {
    Serial.print("Internal Temp = ");
    Serial.println(thermocouple.readInternal());
    delay(100);
    double c = thermocouple.readCelsius();
    if (isnan(c)) {
    Serial.println("Something wrong with thermocouple!");
    } else {
    Serial.print("C = ");
    Serial.println(c);
    client.publish(MCUName + "/InternalTemp",String(c));
    client.loop();
    if (!client.connected()) {
    Serial.println("Neustart!");
    delay(200);
    client.begin("http://192.168.178.30",1883,net);
    client.publish(MCUName + "/connectProblem","Verbindungsproblem gehabt");
    delay(1000);
    • Q Qax1
      @mcu ```
      #include <Wire.h>
      #include <SPI.h>
      #include <MQTT.h>
      WiFiClient net;
      MQTTClient client;
      void connect() {
      Serial.print(".");
      delay(1000);
      Serial.print(".");
      delay(1000);
      Topic_MQTT = topic;
      topic = "";
      payload = "";
      void setup() {
      Serial.begin(9600);
      delay(500);
      void loop() {
      delay(100);
      if (isnan(c)) {
      } else {
      Serial.println(c);
      client.loop();
      delay(200);
      delay(1000);
      MCU
      @qax1 sagte in NODEmcu K-Type Temp-Fühler in IObroker !?:
      noch ändern -> "",""
      Code-tags - erste Zeile frei lassen , sonst versteht er das nicht.
      client.begin("http://192.168.178.30",1883,net); ->client.begin("192.168.178.30",1883,net);
      das http:// entfernen
      Q 1 Antwort Letzte Antwort
      • M MCU
        Q Offline
        Q Offline
        Qax1
        @mcu
        Ok... erledigt
        • Q Qax1
          @mcu
          Ok... erledigt
          MCU
          @qax1 Dann zeig nochmal, aber erste Zeile frei lassen-> Return und dann erst Code-Tag (</>).
          • M MCU
            Q Offline
            Q Offline
            Qax1
            @mcu
            #include <Wire.h>
            #include <SPI.h>
            #include <MQTT.h>
            const char pass[] = "xxxxxxxxxxxxxxxxxxx";
            WiFiClient net;
            MQTTClient client;
            void connect() {
                 Serial.print(".");
                 delay(1000);
                 Serial.print(".");
                 delay(1000);
             Topic_MQTT = topic;
             topic = "";
             payload = "";
            void setup() {
             Serial.begin(9600);
             delay(500);
            void loop() {
              delay(100);
              if (isnan(c)) {
              } else {
                Serial.println(c);
              client.loop();
                 delay(200);
              delay(1000);
            • Q Qax1
              @mcu
              #include <Wire.h>
              #include <SPI.h>
              #include <MQTT.h>
              WiFiClient net;
              MQTTClient client;
              void connect() {
                   Serial.print(".");
                   delay(1000);
                   Serial.print(".");
                   delay(1000);
               Topic_MQTT = topic;
               topic = "";
               payload = "";
              void setup() {
               Serial.begin(9600);
               delay(500);
              void loop() {
                delay(100);
                if (isnan(c)) {
                } else {
                  Serial.println(c);
                client.loop();
                   delay(200);
                delay(1000);
              MCU
              Immer noch nicht geändert:
              while (!client.connect(client_name,"MQTTUser","MQTTPassword")) -> while (!client.connect(client_name,"",""))
              • M MCU
                Q Offline
                Q Offline
                Qax1
                @mcu sagte in NODEmcu K-Type Temp-Fühler in IObroker !?:
                   while (!client.connect(MCUName,"","")) {
                     Serial.print(".");
                     delay(1000);
                so ?
                • Q Qax1
                       Serial.print(".");
                       delay(1000);
                  so ?
                  MCU
                  @qax1
                  dort nicht den client_name ersetzen!
                  • M MCU
                    @qax1
                    Q Offline
                    Q Offline
                    Qax1
                    @mcu
                      while (!client.connect(client_name,"","")) {
                         Serial.print(".");
                         delay(1000);
                    ok
                    • Q Qax1
                      @mcu
                           Serial.print(".");
                           delay(1000);
                      ok
                      MCU
                      @qax1 Dann lass mal laufen. Kommt im ioBroker MQTT was an?
                      Sonst zeige die Einstellungen zum MQTT-Adapter.
                      Meine sind:
                      • M MCU
                        Meine sind:
                        Q Offline
                        Q Offline
                        Qax1
                        @mcu
                        Sau Geil es läuft....
                        Ich kann dir gar nicht genug Danken....
                        Das hätte ich alleine wohl nie hinbekommen 🍻 🍻 🍻
                        • Q Qax1
                          @mcu
                          MCU
                          @qax1
                          Und dann bitte im ersten Post die Überschrift anpassen [gelöst] NODEmcu....
                          • M MCU
                            @qax1
                            Q Offline
                            Q Offline
                            Qax1
                            @mcu
                            Nochmal vielen Dank @mcu für deine Hilfe...
                            Hier ein Bild vom gestrigen Probeheitzen,
                            bin echt überrascht, mit über 600 °C hätte ich nicht gerechnet.
                            Muss24-03-_2021_20-32-53.jpg die Tage mal gegenmessen.
