  4. NODEmcu K-Type Temp-Fühler in IObroker !? [gelöst]
    6.7k
nodemcu max38155 mqtt
39 Beiträge 2 Kommentatoren 3.7k Aufrufe 2 Beobachtet
  • Q Qax1
    @mcu
    Ok... erledigt
    MCU
    @qax1 Dann zeig nochmal, aber erste Zeile frei lassen-> Return und dann erst Code-Tag (</>).
    Q 1 Antwort Letzte Antwort
    • M MCU
      Q Offline
      Q Offline
      Qax1
      @mcu
      #include <Wire.h>
      #include <SPI.h>
      #include "Adafruit_MAX31855.h"
      #include <ESP8266WiFi.h>
      #include <MQTT.h>
      #define CLK 14          //connect CLK to GPIO14
      #define CS 5             //connect CS to GPIO5
      #define DO 12           //connect DO to GPIO12
      #define client_name "SensorMAX"
      String MCUName = "SensorMax";
      const char ssid[] = "xyz";
      const char pass[] = "xxxxxxxxxxxxxxxxxxx";
      String Nachricht_MQTT = "";
      String Topic_MQTT = "";
      Adafruit_MAX31855 thermocouple(CLK,CS,DO);
      WiFiClient net;
      MQTTClient client;
      void connect() {
         Serial.print("\nchecking wifi...");
         while (WiFi.status() != WL_CONNECTED) {
           Serial.print(".");
           delay(1000);
         Serial.print("\nconnecting...");
         while (!client.connect(client_name,"MQTTUser","MQTTPassword")) {
           Serial.print(".");
           delay(1000);
         Serial.print("\nconnected!");
         client.subscribe(MCUName + "/+");
         client.publish(MCUName + "/alive","true");
      void messageReceived(String &topic, String &payload) {
       Serial.println("MQTT incoming: " + topic + " - " + payload);
       Topic_MQTT = topic;
       Nachricht_MQTT = payload;
       topic = "";
       payload = "";
      void setup() {
       Serial.begin(9600);
       Serial.println("MAX31855 testing");
       delay(500);
       WiFi.begin(ssid, pass);
       client.begin("192.168.178.30",1883,net); //192.168.178.45
       connect(); //alive wird gesendet
       client.onMessage(messageReceived);
      void loop() {
        Serial.print("Internal Temp = ");
        Serial.println(thermocouple.readInternal());
        delay(100);
        double c = thermocouple.readCelsius();
        if (isnan(c)) {
          Serial.println("Something wrong with thermocouple!");
        } else {
          Serial.print("C = ");
          Serial.println(c);
          client.publish(MCUName + "/InternalTemp",String(c));
        client.loop();
        if (!client.connected()) {
           Serial.println("Neustart!");
           delay(200);
           client.publish(MCUName + "/connectProblem","Verbindungsproblem gehabt");
        delay(1000);
      • Q Qax1
        @mcu
        #include <Wire.h>
        #include <SPI.h>
        #include <MQTT.h>
        WiFiClient net;
        MQTTClient client;
        void connect() {
             Serial.print(".");
             delay(1000);
             Serial.print(".");
             delay(1000);
         Topic_MQTT = topic;
         topic = "";
         payload = "";
        void setup() {
         Serial.begin(9600);
         delay(500);
        void loop() {
          delay(100);
          if (isnan(c)) {
          } else {
            Serial.println(c);
          client.loop();
             delay(200);
          delay(1000);
        MCU
        @qax1 sagte in NODEmcu K-Type Temp-Fühler in IObroker !?:
        Immer noch nicht geändert:
        while (!client.connect(client_name,"MQTTUser","MQTTPassword")) -> while (!client.connect(client_name,"",""))
        • M MCU
          Q Offline
          Q Offline
          Qax1
          @mcu sagte in NODEmcu K-Type Temp-Fühler in IObroker !?:
             while (!client.connect(MCUName,"","")) {
               Serial.print(".");
               delay(1000);
          so ?
          • Q Qax1
                 Serial.print(".");
                 delay(1000);
            so ?
            MCU
            @qax1
            dort nicht den client_name ersetzen!
            • M MCU
              @qax1
              Q Offline
              Q Offline
              Qax1
              @mcu
                while (!client.connect(client_name,"","")) {
                   Serial.print(".");
                   delay(1000);
              ok
              • Q Qax1
                @mcu
                     Serial.print(".");
                     delay(1000);
                ok
                MCU
                @qax1 Dann lass mal laufen. Kommt im ioBroker MQTT was an?
                Sonst zeige die Einstellungen zum MQTT-Adapter.
                Meine sind:
                • M MCU
                  Meine sind:
                  Q Offline
                  Q Offline
                  Qax1
                  @mcu
                  Sau Geil es läuft....
                  Ich kann dir gar nicht genug Danken....
                  Das hätte ich alleine wohl nie hinbekommen 🍻 🍻 🍻
                  • Q Qax1
                    @mcu
                    MCU
                    @qax1
                    Und dann bitte im ersten Post die Überschrift anpassen [gelöst] NODEmcu....
                    • M MCU
                      @qax1
                      Q Offline
                      Q Offline
                      Qax1
                      @mcu
                      Nochmal vielen Dank @mcu für deine Hilfe...
                      Hier ein Bild vom gestrigen Probeheitzen,
                      bin echt überrascht, mit über 600 °C hätte ich nicht gerechnet.
                      Muss24-03-_2021_20-32-53.jpg die Tage mal gegenmessen.
