  4. Problem nach IOT Adapter upgrade
    6.6k
3 Beiträge 2 Kommentatoren 173 Aufrufe 1 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    ich habe eben meinen IOT Adapter auf Version 1.8.16 upgedated.
    Hier das Upgrade log dazu:
    2021-03-21 16:54:56.716  - info: host.iobroker iobroker upgrade iot
    2021-03-21 16:54:58.240  - info: host.iobroker iobroker Update iot from @1.8.13 to @1.8.16
    2021-03-21 16:54:58.255  - info: host.iobroker iobroker host.iobroker Adapter "system.adapter.iot.0" is stopped.
    2021-03-21 16:54:58.282  - info: host.iobroker "system.adapter.iot.0" disabled
    2021-03-21 16:54:58.283  - info: host.iobroker stopInstance system.adapter.iot.0 (force=false, process=true)
    2021-03-21 16:54:58.279  - info: iot.0 (1128) Adapter is disabled => stop
    2021-03-21 16:54:58.288  - info: iot.0 (1128) Got terminate signal TERMINATE_YOURSELF
    2021-03-21 16:54:58.289  - info: iot.0 (1128) terminating
    2021-03-21 16:54:58.289  - info: iot.0 (1128) Terminated (NO_ERROR): Without reason
    2021-03-21 16:54:58.314  - info: iot.0 (1128) Connection changed: disconnect
    2021-03-21 16:54:58.314  - info: iot.0 (1128) Connection lost
    2021-03-21 16:54:58.326  - info: host.iobroker stopInstance system.adapter.iot.0 send kill signal
    2021-03-21 16:54:58.539  - info: host.iobroker iobroker NPM version: 6.14.10npm install iobroker.iot@1.8.16 --loglevel error --prefix "/opt/iobroker" (System call)
    2021-03-21 16:54:58.901  - info: host.iobroker instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
    2021-03-21 16:55:29.414  - info: host.iobroker iobroker Update "system.adapter.iot.0"
    2021-03-21 16:55:29.527  - info: host.iobroker iobroker upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.3886ef11.js.map static/js/runtime-main.3886ef11.js.map application/json
    2021-03-21 16:55:29.593  - info: host.iobroker iobroker upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.3886ef11.js static/js/runtime-main.3886ef11.js application/javascript
    2021-03-21 16:55:29.654  - info: host.iobroker iobroker upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.817b3043.chunk.js.map static/js/main.817b3043.chunk.js.map application/json
    2021-03-21 16:55:29.729  - info: host.iobroker iobroker upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.817b3043.chunk.js static/js/main.817b3043.chunk.js application/javascript
    2021-03-21 16:55:29.787  - info: host.iobroker iobroker upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.6c48dbc2.chunk.js.map static/js/2.6c48dbc2.chunk.js.map application/json
    2021-03-21 16:55:30.126  - info: host.iobroker iobroker upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.6c48dbc2.chunk.js.LICENSE.txt static/js/2.6c48dbc2.chunk.js.LICENSE.txt text/plain
    2021-03-21 16:55:30.230  - info: host.iobroker iobroker upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.6c48dbc2.chunk.js static/js/2.6c48dbc2.chunk.js application/javascript
    2021-03-21 16:55:30.301  - info: host.iobroker iobroker upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
    2021-03-21 16:55:30.387  - info: host.iobroker iobroker upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
    2021-03-21 16:55:30.469  - info: host.iobroker iobroker upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.c04f2d9d.chunk.css.map static/css/2.c04f2d9d.chunk.css.map application/json
    2021-03-21 16:55:30.527  - info: host.iobroker iobroker upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.c04f2d9d.chunk.css static/css/2.c04f2d9d.chunk.css text/css
    2021-03-21 16:55:30.590  - info: host.iobroker iobroker upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
    2021-03-21 16:55:30.660  - info: host.iobroker iobroker upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
    2021-03-21 16:55:30.724  - info: host.iobroker iobroker upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
    2021-03-21 16:55:30.777  - info: host.iobroker iobroker upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    2021-03-21 16:55:30.831  - info: host.iobroker iobroker upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
    2021-03-21 16:55:30.884  - info: host.iobroker iobroker upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
    2021-03-21 16:55:30.936  - info: host.iobroker iobroker upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
    2021-03-21 16:55:30.994  - info: host.iobroker iobroker upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
    2021-03-21 16:55:31.067  - info: host.iobroker iobroker Adapter "iot" updatedhost.iobroker Adapter "system.adapter.iot.0" is started
    2021-03-21 16:55:31.095  - info: host.iobroker "system.adapter.iot.0" enabled
    2021-03-21 16:55:31.307  - info: host.iobroker instance system.adapter.iot.0 started with pid 8505
    2021-03-21 16:55:32.204  - info: host.iobroker iobroker exit 0
    2021-03-21 16:55:32.864  - info: iot.0 (8505) starting. Version 1.8.16 in /opt/iobroker/node_modules/iobroker.iot, node: v12.20.1, js-controller: 3.2.16
    2021-03-21 16:55:32.904  - info: iot.0 (8505) Connecting with axxxx2g.iot.eu-west-1.amazonaws.com
    2021-03-21 16:55:34.828  - info: iot.0 (8505) Connection changed: connect
    2021-03-21 16:55:35.566  - warn: iot.0 (8505) [GHOME] hm-rpc.0.BidCoS-RF.44 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.566  - warn: iot.0 (8505) [GHOME] hm-rpc.0.BidCoS-RF.45 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.593  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0676394.1 is auto added with type  blind.
    2021-03-21 16:55:35.612  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0676385.1 is auto added with type  blind.
    2021-03-21 16:55:35.629  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0675904.1 is auto added with type  blind.
    2021-03-21 16:55:35.644  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0677917.1 is auto added with type  blind.
    2021-03-21 16:55:35.655  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0677541.1 is auto added with type  blind.
    2021-03-21 16:55:35.663  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0677342.1 is auto added with type  blind.
    2021-03-21 16:55:35.672  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ1315278.1 is auto added with type  blind.
    2021-03-21 16:55:35.673  - warn: iot.0 (8505) [GHOME] hm-rpc.0.REQ0862726.5 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.673  - warn: iot.0 (8505) [GHOME] hm-rpc.0.REQ0862726.6 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.685  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ1312100.1 is auto added with type  blind.
    2021-03-21 16:55:35.695  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ1311692.1 is auto added with type  blind.
    2021-03-21 16:55:35.702  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0676146.1 is auto added with type  blind.
    2021-03-21 16:55:35.713  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ1894500.1 is auto added with type  blind.
    2021-03-21 16:55:35.720  - info: iot.0 (8505) [GHOME] hm-rpc.0.MEQ1312290.1 is auto added with type  blind.
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0443245.5 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0442402.5 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0443245.6 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0442402.6 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0443245.1 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0442402.1 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0443245.2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0442402.2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0443245.3 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0442402.3 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0443245.4 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.721  - warn: iot.0 (8505) [GHOME] hm-rpc.0.MEQ0442402.4 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 16:55:35.722  - warn: iot.0 (8505) [GHOME] harmony.0.Wohnzimmer is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    Ich habe keine Ahnung was die "warn" bedeuten sollen.
    Habe mal die States für Harmony activities aus dem Adapter entfernt das es eh nie vernünftig funktioniert hat.
    0649757e-d6d4-4784-9322-bf6cbeee9144-grafik.png 53b87a68-78d4-4e94-acd8-23c3aa27e66b-grafik.png
    Leider kommen im log immer noch diese Meldungen:
    2021-03-21 17:29:29.349  - warn: iot.0 (11862) [GHOME] harmony.0.Wohnzimmer is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:30:58.263  - info: host.iobroker stopInstance system.adapter.iot.0 (force=false, process=true)
    2021-03-21 17:30:58.269  - info: iot.0 (11862) Got terminate signal TERMINATE_YOURSELF
    2021-03-21 17:30:58.270  - info: iot.0 (11862) terminating
    2021-03-21 17:30:58.270  - info: iot.0 (11862) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-21 17:30:58.285  - info: host.iobroker stopInstance system.adapter.iot.0 send kill signal
    2021-03-21 17:30:58.307  - info: iot.0 (11862) Connection changed: disconnect
    2021-03-21 17:30:58.307  - info: iot.0 (11862) Connection lost
    2021-03-21 17:30:58.941  - info: host.iobroker instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-21 17:31:01.417  - info: host.iobroker instance system.adapter.iot.0 started with pid 12133
    2021-03-21 17:31:02.450  - info: iot.0 (12133) starting. Version 1.8.16 in /opt/iobroker/node_modules/iobroker.iot, node: v12.20.1, js-controller: 3.2.16
    2021-03-21 17:31:02.481  - info: iot.0 (12133) Connecting with axxxxg.iot.eu-west-1.amazonaws.com
    2021-03-21 17:31:04.276  - info: iot.0 (12133) Connection changed: connect
    2021-03-21 17:31:04.753  - warn: iot.0 (12133) [GHOME] hm-rpc.0.BidCoS-RF.44 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.753  - warn: iot.0 (12133) [GHOME] hm-rpc.0.BidCoS-RF.45 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.796  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0676394.1 is auto added with type  blind.
    2021-03-21 17:31:04.805  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0676385.1 is auto added with type  blind.
    2021-03-21 17:31:04.818  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0675904.1 is auto added with type  blind.
    2021-03-21 17:31:04.833  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0677917.1 is auto added with type  blind.
    2021-03-21 17:31:04.848  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0677541.1 is auto added with type  blind.
    2021-03-21 17:31:04.863  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0677342.1 is auto added with type  blind.
    2021-03-21 17:31:04.874  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ1315278.1 is auto added with type  blind.
    2021-03-21 17:31:04.874  - warn: iot.0 (12133) [GHOME] hm-rpc.0.REQ0862726.5 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.874  - warn: iot.0 (12133) [GHOME] hm-rpc.0.REQ0862726.6 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.888  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ1312100.1 is auto added with type  blind.
    2021-03-21 17:31:04.903  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ1311692.1 is auto added with type  blind.
    2021-03-21 17:31:04.916  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0676146.1 is auto added with type  blind.
    2021-03-21 17:31:04.929  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ1894500.1 is auto added with type  blind.
    2021-03-21 17:31:04.942  - info: iot.0 (12133) [GHOME] hm-rpc.0.MEQ1312290.1 is auto added with type  blind.
    2021-03-21 17:31:04.942  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0443245.5 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.942  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0442402.5 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.942  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0443245.6 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.942  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0442402.6 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.942  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0443245.1 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.943  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0442402.1 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.943  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0443245.2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.943  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0442402.2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.943  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0443245.3 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.943  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0442402.3 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.943  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0443245.4 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.943  - warn: iot.0 (12133) [GHOME] hm-rpc.0.MEQ0442402.4 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.943  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Antenne_AC is a state. It's recommended to add rooms and functionality to channels or devices and not to a state to get auto detected for Google Home. This works only for simple switches.
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Antenne_AC is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Apple_TV is a state. It's recommended to add rooms and functionality to channels or devices and not to a state to get auto detected for Google Home. This works only for simple switches.
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Apple_TV is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Apple_TV-Beamer is a state. It's recommended to add rooms and functionality to channels or devices and not to a state to get auto detected for Google Home. This works only for simple switches.
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Apple_TV-Beamer is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.BluRay-TV is a state. It's recommended to add rooms and functionality to channels or devices and not to a state to get auto detected for Google Home. This works only for simple switches.
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.BluRay-TV is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Das_Hitradio is a state. It's recommended to add rooms and functionality to channels or devices and not to a state to get auto detected for Google Home. This works only for simple switches.
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Das_Hitradio is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Eins_Live is a state. It's recommended to add rooms and functionality to channels or devices and not to a state to get auto detected for Google Home. This works only for simple switches.
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Eins_Live is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.944  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Fernsehen is a state. It's recommended to add rooms and functionality to channels or devices and not to a state to get auto detected for Google Home. This works only for simple switches.
    2021-03-21 17:31:04.945  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Fernsehen is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.945  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Kino is a state. It's recommended to add rooms and functionality to channels or devices and not to a state to get auto detected for Google Home. This works only for simple switches.
    2021-03-21 17:31:04.945  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.Kino is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.945  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.TV-Beamer is a state. It's recommended to add rooms and functionality to channels or devices and not to a state to get auto detected for Google Home. This works only for simple switches.
    2021-03-21 17:31:04.945  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer.activities.TV-Beamer is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    2021-03-21 17:31:04.945  - warn: iot.0 (12133) [GHOME] harmony.0.Wohnzimmer is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    Jemand ne Idee was das schief läuft ?
    • wendy2702W wendy2702
      FredFF Online
      FredFF Online
      FredF
      Most Active Forum Testing
      @wendy2702 sagte in Problem nach IOT Adapter upgrade:
      Du weisst dass das latest/beta ist?
      • FredFF FredF
        wendy2702W Online
        wendy2702W Online
        @fredf ja.
        Dessen bin ich mir bewusst.
        Werde wohl auch ein issue eröffnen sollte sich hier keine Lösung finden .
