  4. (Mqtt) 2.3.4 hat noch jemand damit ein Problem?
5 Beiträge 2 Kommentatoren 291 Aufrufe 2 Beobachtet
  • HumidorH Offline
    HumidorH Offline
    Humidor
    Hallo 👍
    Frage in die Runde, habe auf 2.3.4 upgedatet und seither einen wiederkehrenden Fehler, es werden keine Werte mehr eingelesen / aktualisiert.
    Meine Tests bisher waren downgrade auf 2.3.3 und dann fkt. es einwandfrei, nach Update auf 2.3.4 kommen nach 1-2Tagen keine Werte mehr. Wiederherstellbar.
    das schaut dann so aus:
    mqtt.0	2021-03-11 18:45:38.942	debug	(27026) Client [AMIS] pingreq
    mqtt.0	2021-03-11 18:45:28.142	debug	(27026) Client [AMIS] pingreq
    mqtt.0	2021-03-11 18:45:17.467	debug	(27026) Client [AMIS] pingreq
    mqtt.0	2021-03-11 18:45:06.768	debug	(27026) Client [AMIS] pingreq
    mqtt.0	2021-03-11 18:44:55.918	debug	(27026) Client [AMIS] pingreq
    mqtt.0	2021-03-11 18:44:45.169	debug	(27026) Client [AMIS] pingreq
    mqtt.0	2021-03-11 18:44:34.569	debug	(27026) Client [AMIS] pingreq
    mqtt.0	2021-03-11 18:44:23.769	debug	(27026) Client [AMIS] pingreq
    so wenn es funktioniert:
    mqtt.0	2021-03-11 18:51:07.231	debug	(23924) Client [AMIS] pingreq
    mqtt.0	2021-03-11 18:51:06.895	debug	(23924) stateChange mqtt.0.AMIS: {"val":"{"1.8.0":13846746,"2.8.0":19496162,"3.8.1":10815187,"4.8.1":4812729,"1.7.0":5090,"2.7.0":0,"3.7.0":2461,"4.7.0":0,"1.128.0":0}","ack":true,"t
    mqtt.0	2021-03-11 18:51:03.885	debug	(23924) stateChange mqtt.0.AMIS: {"val":"{"1.8.0":13846742,"2.8.0":19496162,"3.8.1":10815185,"4.8.1":4812729,"1.7.0":5090,"2.7.0":0,"3.7.0":2433,"4.7.0":0,"1.128.0":0}","ack":true,"t
    mqtt.0	2021-03-11 18:51:00.877	debug	(23924) stateChange mqtt.0.AMIS: {"val":"{"1.8.0":13846738,"2.8.0":19496162,"3.8.1":10815183,"4.8.1":4812729,"1.7.0":5098,"2.7.0":0,"3.7.0":2446,"4.7.0":0,"1.128.0":0}","ack":true,"t
    mqtt.0	2021-03-11 18:50:59.746	debug	(23924) system.adapter.admin.0: logging true
    mqtt.0	2021-03-11 18:50:57.875	debug	(23924) stateChange mqtt.0.AMIS: {"val":"{"1.8.0":13846734,"2.8.0":19496162,"3.8.1":10815181,"4.8.1":4812729,"1.7.0":5246,"2.7.0":0,"3.7.0":2426,"4.7.0":0,"1.128.0":0}","ack":true,"
    mqtt.0	2021-03-11 18:50:56.482	debug	(23924) Client [AMIS] pingreq
    mqtt.0	2021-03-11 18:50:54.873	debug	(23924) stateChange mqtt.0.AMIS: {"val":"{"1.8.0":13846728,"2.8.0":19496162,"3.8.1":10815178,"4.8.1":4812729,"1.7.0":5211,"2.7.0":0,"3.7.0":2439,"4.7.0":0,"1.128.0":0}","ack":true,"
    mqtt.0	2021-03-11 18:50:51.877	debug	(23924) stateChange mqtt.0.AMIS: {"val":"{"1.8.0":13846724,"2.8.0":19496162,"3.8.1":10815176,"4.8.1":4812729,"1.7.0":5107,"2.7.0":0,"3.7.0":2449,"4.7.0":0,"1.128.0":0}","ack":true,"
    mqtt.0	2021-03-11 18:50:48.879	debug	(23924) stateChange mqtt.0.AMIS: {"val":"{"1.8.0":13846719,"2.8.0":19496162,"3.8.1":10815174,"4.8.1":4812729,"1.7.0":5097,"2.7.0":0,"3.7.0":2439,"4.7.0":0,"1.128.0":0}","ack":true,"
    mqtt.0	2021-03-11 18:50:45.873	debug	(23924) stateChange mqtt.0.info.connection: {"val":"AMIS","ack":true,"ts":1615485045869,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1615485045869}
    mqtt.0	2021-03-11 18:50:45.846	debug	(23924) Client [AMIS] with keepalive 15 set timeout to 22.5 seconds
    mqtt.0	2021-03-11 18:50:45.694	info	(23924) Client [AMIS] connected with secret 1615485045684_2430
    BG
    • HumidorH Humidor
      Hallo 👍
      M Online
      M Online
      MCU
      @humidor
      Da gibt es schon die Version 2.3.5. Vielleicht mal versuchen? Ansonsten Issue anlegen:
      https://github.com/ioBroker/ioBroker.mqtt/issues
      HumidorH 2 Antworten Letzte Antwort
      • M MCU
        @humidor
        HumidorH Offline
        HumidorH Offline
        Humidor
        @mcu Issue habe ich schon angelegt, war minder erfolgreich.
        2.3.5 ist keine Stable vermute ich mal.
        BG
        • HumidorH Offline
          HumidorH Offline
          Humidor
          @mcu 2.3.3 läuft ohne Macken, dauerhaft
          ich mache jetzt nochmal den Test und stelle auf 2.3.5 um. mal sehen was passiert
          BG
          • M MCU
            @humidor
            HumidorH Offline
            HumidorH Offline
            Humidor
            @mcu 2.3.5 läuft seit gestern problemlos
            habe inzwischen hier so manche Meldung zum Adapter gefunden, die meisten steigen auf Mosquitto um.
            BG
