  4. JavaScript
  5. Energieanzeige (kWh) über HTML Tabelle - vis
    1.0k
    6.1k
javascripttemplate
696 Beiträge 37 Kommentatoren 211.6k Aufrufe 46 Beobachtet
  • Holger EtzelH Offline
    Holger Etzel
    #591
    bekomme nach Start vom Script folgende Fehlermeldungen:
    javascript.0	2021-03-14 14:06:00.021	error	(2844967) at processTimers (internal/timers.js:497:7)
    javascript.0	2021-03-14 14:06:00.021	error	(2844967) at listOnTimeout (internal/timers.js:554:17)
    javascript.0	2021-03-14 14:06:00.021	error	(2844967) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7)
    javascript.0	2021-03-14 14:06:00.021	error	(2844967) at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11
    javascript.0	2021-03-14 14:06:00.021	error	(2844967) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2021-03-14 14:06:00.020	error	(2844967) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1296:34)
    javascript.0	2021-03-14 14:06:00.020	error	(2844967) at Object.<anonymous> (script.js.System.Status_Geräte_Stromverbrauch:1272:2)
    javascript.0	2021-03-14 14:06:00.014	error	(2844967) at writeHTML (script.js.System.Status_Geräte_Stromverbrauch:662:26)
    javascript.0	2021-03-14 14:06:00.013	error	(2844967) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:800:29)
    javascript.0	2021-03-14 14:06:00.013	error	(2844967) at script.js.System.Status_Geräte_Stromverbrauch:678:77
    javascript.0	2021-03-14 14:06:00.012	error	(2844967) Error in callback: TypeError: Cannot read property 'toString' of null
    javascript.0	2021-03-14 14:05:20.390	error	(2844967) at Script.runInContext (vm.js:130:18)
    javascript.0	2021-03-14 14:05:20.390	error	(2844967) at script.js.System.Status_Geräte_Stromverbrauch:1696:3
    javascript.0	2021-03-14 14:05:20.390	error	(2844967) at script.js.System.Status_Geräte_Stromverbrauch:1275:2
    javascript.0	2021-03-14 14:05:20.390	error	(2844967) at writeHTML (script.js.System.Status_Geräte_Stromverbrauch:662:26)
    javascript.0	2021-03-14 14:05:20.390	error	(2844967) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:800:29)
    javascript.0	2021-03-14 14:05:20.390	error	(2844967) at script.js.System.Status_Geräte_Stromverbrauch:678:77
    javascript.0	2021-03-14 14:05:20.389	error	(2844967) script.js.System.Status_Geräte_Stromverbrauch: TypeError: Cannot read property 'toString' of null
    javascript.0	2021-03-14 14:05:20.388	info	(2844967) script.js.System.Status_Geräte_Stromverbrauch: registered 0 subscriptions and 1 schedule
    javascript.0	2021-03-14 14:05:20.365	info	(2844967) Start javascript script.js.System.Status_Geräte_Stromverbrauch
    Hat jemand eine Idee was das sein könnte?
    Danke schon mal im voraus.
    Holger
    • Holger EtzelH Holger Etzel
      Holger
      liv-in-skyL Offline
      liv-in-skyL Offline
      #592
      @holger-etzel
      es scheint mir auf den ersten blick, dass du geräte hast, die keinen state haben ( fritzdect und shelly)
      kann das sein
      beim shelly energy_current oder energy_voltage
      beim fritzdect entweder fehlt power oder voltage
      ich hoffe, du hast das script nicht mit firefox aus dem forum kopiert - den dann stimmen die zeilennummer nicht mehr - da muss man chrome nehmen
      Holger EtzelH 1 Antwort Letzte Antwort
      • liv-in-skyL liv-in-sky
        @holger-etzel
        kann das sein
        Holger Etzel
        #593
        @liv-in-sky
        ich habe nur shelly-Geräte:
        Plugs, shelly1PM, shelly 2.5 und shelly3EM.
        Wobei der 3EM nicht so wichtig für die Tabelle ist
        Habe das script gespeichert und mit editor geöffnet.
          @liv-in-sky
          liv-in-skyL Offline
          liv-in-skyL Offline
          #594
          @holger-etzel
          wieviele zeilen hat das script im javascript editor ?
            @holger-etzel
            Holger Etzel
            #595
            @liv-in-sky
            bei 1691 ist die letzte Klammer
              @liv-in-sky
              liv-in-skyL Offline
              liv-in-skyL Offline
              #596
              @holger-etzel
              das paßt
              dann mußt du die shelly datenpunkte prüfen ob die states beschrieben sind - viellicht gibt es shelly's, die nicht mehr genutzt werden, oder unbenannt wurden ....
                @liv-in-sky
                liv-in-skyL Offline
                liv-in-skyL Offline
                #597
                @holger-etzel
                siehe chat nachricht
                  Holger Etzel
                  #598
                  @liv-in-sky
                  bin im Raum
                    @liv-in-sky
                    bin im Raum
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #599
                    @holger-etzel
                    kannst du mir bite den geänderten code im shelly block posten - hab vergessen zu koieren
                      @holger-etzel
                      Holger Etzel
                      #600
                      @liv-in-sky
                      $('shelly.*.*.*.Power').each(function(id, i) {
                              if(existsState(id) && getState(id).val != null ) {
                               anzahl++;
                              var ida = id.split('.');
                                counter++;
                                val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ; // log(val0+"---" +lastID)
                                if (val0 == lastID) {lastID=val0; shellyNumber++; val0=val0+"("+shellyNumber.toString()+")"} else{lastID=val0; shellyNumber=1}
                                val1=getState(ida[0]+"."+ida[1]+"."+ida[2]+".online").val
                                val2=" - "; val3=" - ";
                                if(existsState(id.replace("Power","Energy_Current"))) {     val2=((getState(id.replace("Power","Energy_Current")).val)).toString()+ " A"; }
                                 if(existsState(id.replace("Power","Energy_Voltage"))) { val3=getState(id.replace("Power","Energy_Voltage")).val.toString()+" V"; }
                                val4=getState(id).val.toString()+" W";
                                var val5_1;
                                if (existsState(id.replace("Power","Switch"))) {val5_1= getState(id.replace("Power","Switch")).val;  } else {val5_1= getState(ida[0]+"."+ida[1]+"."+ida[2]+".Relay0.Switch").val;  }
                                val5_1 ? val5=(" <font color=\""+farbeSchalterON+"\"> ")+"ON</font>" : val5=(" <font color=\""+farbeSchalterON+"\"> ")+"OFF</font>";
                                 val6=" - "; val7=" - "; val8=" - "; val9=" - ";
                                 valMarkeDevice="shellyk"
                      sorry war gestern nicht im Forum.
                      Das sollte der code sein.
                      Nochmal vielen, vielen dank für die umfangreiche Hilfe.
                      Holger
                      tugsiT 1 Antwort Letzte Antwort
                        @liv-in-sky
                                 anzahl++;
                                  counter++;
                                  var val5_1;
                        Holger
                        tugsiT Offline
                        tugsiT Offline
                        tugsi
                        #601
                        @holger-etzel sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
                        Es fehlt am Ende dann eine geschweifte Klammer durch :
                        Muss ganz am Ende des Shelly-Abschnittes (hast Du nicht mit angefügt) noch das Ende gesetzt werden:
                        } //ende fritzdect
                        Gesamter Shelly-Abschnitt also:
                         if (shelly){
                        counter=0
                              counter++//=0;
                              val0=""; val1=""; val2="";val3="";val4="";val5="";val6="";val7="";val8="";val9="";
                              tabelleBind();
                              tabelleAusbessern();
                              counter++//=0;
                              val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Shelly</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                              val5="<font color=\""+htmlColorDeviceUeberschrift+"\"></font>";
                              val6="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">kWh Now<"+HTMLbrandSetting+"></font>";
                              val7="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">kWh Monat<"+HTMLbrandSetting+"></font>";
                              val8="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Preis Now<"+HTMLbrandSetting+"></font>";
                              val9="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Preis Monat<"+HTMLbrandSetting+"></font>";
                              tabelleBind();
                        lastID="";
                                 anzahl++;
                                  counter++;
                                   var val5_1;
                                  if (sourceAnalyShelly) {brechneEnergy(val0,getState(id).val)
                                     if (rootCounter){
                                         sammleDaten();
                                    berechneGesamt()
                              zeigeVal1();
                              if (!filterArrAusnahme.includes(val0)) {
                                 tabelleBind();
                                } else{let help=[val0,val1,val2,val3,val4,val5,val6,val7,val8,val9]; filterArrAusnahmeHelp.push(help);}
                        } //ende fritzdect
                        Thomas
                        Master ioBroker in Proxmox als LXC auf 1. Tiny-Lenovo, Proxmox-VM als Slave auf 2. Tinyi-Lenovo mit Zigbee und Monitor zur Visualisierung, Hauptautomatisierung über S7 auf Beckhoff CX, dazu noch Shelly, Homematic...
                        • tugsiT tugsi
                          } //ende fritzdect
                           if (shelly){
                          counter=0
                                counter++//=0;
                                tabelleBind();
                                counter++//=0;
                                tabelleBind();
                          lastID="";
                                   anzahl++;
                                    counter++;
                                     var val5_1;
                                       if (rootCounter){
                                           sammleDaten();
                                      berechneGesamt()
                                zeigeVal1();
                                   tabelleBind();
                          } //ende fritzdect
                          Thomas
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #602
                          @tugsi danke, da hast du recht - aber der codeausschnit war mehr für mich gedacht - zum einbinden ins script im ersten post
                          natrürlich kann man aber deinen "schnippsel" auch selbst ins eigene script kopieren
                            tugsiT Offline
                            tugsiT Offline
                            tugsi
                            #603
                            @liv-in-sky
                            ich war mir da etwas unsicher, da der Beitrag schon ein paar Tage alt war und ich gerade wegen den Shelly´s daran arbeitete und das in deinem Script noch nicht angepasst war.
                            Nicht bevor nachher den Schnipsel einfach nimmt und sich wundert, warum es nicht läuft ;)
                            • tugsiT tugsi
                              @liv-in-sky
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #604
                              @tugsi
                              mittlerweile ist es angepaßt - alles gut soweit :-)
                              • JB_SullivanJ Offline
                                JB_Sullivan
                                schrieb am zuletzt editiert von JB_Sullivan
                                #605
                                GOOD MORNING - ioBroker ( in Anlehnung an Vietnam ; ) )
                                Ich wollte gerade Heute damit beginnen meine ganzen Energieströme mal ein bisschen zu sortieren. Gut das ich vorher (die nun besser funktionierende) Foren Suche benutzt habe.
                                Da letztes Jahr, im Rahmen meiner PV Anlagen Installation, auch ein neuer Verteilerschrank (3-Reihig) montiert wurde, war ich die letzten Wochen damit beschäftigt diesen ein wenig mit Smart Home Komponenten zu bestücken.
                                Damit bin ich jetzt soweit durch und habe .....
                                • 4 x Shelly 3EM (Jeder Shelly detektiert eine Unterverteilung im Haus [Garten, Küche, Keller, Restliches Gebäude])
                                • 6 x Sonoff POW für einzelne Geräte die über den Adapter Device-Reminder auch auf den Betriebszustand überwacht werden (Trockner, Waschmaschine, Geschirrspüler, 3 x TV Wände mit dem ganzen Multimedia Equipment & Beleuchtung)
                                • Sowie die die üblichen Verdächtigen zur Erfassung der PV Daten (Fronius Adapter) und der Zähler Daten für`s EVU (Discovergy Adapter)
                                • Demnächst wird noch openWB für die Erfassung der Energieströme zum e-Auto montiert.
                                Natürlich ist auch Sourceanalytix im Einsatz.
                                Lange Rede kurzer Sinn:
                                Dieser Thread und alle Teil- und Vorgänger Threads sind ja nun doch sehr umfangreich und verschachtelt.
                                Was ist denn jetzt der aktuelle Stand bezgl. Script und VIS Bild? Hier auf der Seite Beitrag #1?
                                .... oder wie ist der Stand der Dinge?
                                Freue mich schon darauf mit Eurer Vorlage loslegen zu können ;)
                                So, habe mir mal das Script aus Beitrag #1 importiert. Allerdings unterstreicht der Script Editor jede Menge Zeilen und/oder Begriffe ROT, was ja meist der Hinweis auf ein Fehler ist.
                                JavaScript Engine Adapter ist in der Version 5.1.3 installiert.
                                • JB_SullivanJ JB_Sullivan
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #606
                                  @jb_sullivan
                                  auch dir ein good morning - seit der source-analy. adapter wieder gepflegt wird, mache ich eigentlich nix mehr an diesem script - ich bin davon ausgegangen, das der adapter das alles kann
                                  mein script wird deinen fall nicht abdecken - es wurde entwickelt um einzelne devices zu überwachen, den verbrauch zu notieren und anzuzeigen - bei deinem beispiel die sonoff pows - aber nur, wenn nicht die neue baumstriktur des sonoff adapters genutzt wird
                                  @jb_sullivan sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
                                  sowie die die üblichen Verdächtigen zur Erfassung der PV Daten (Fronius Adapter) und der Zähler Daten für`s EVU (Discovergy Adapter)
                                  • damit kann das script nix anfangen
                                  • da bin ich mir garnicht mehr sicher - müßten mit aufgenommen werden können
                                  am besten, du installierst das script und setzt mal pow und shelly auf true und schaust dann mal in der vis, was alles angezeigt wird
                                  zur not können wir auch gerne eine anydesk session machen
                                    @jb_sullivan
                                    JB_Sullivan
                                    #607
                                    @liv-in-sky sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
                                    Ja, werde ich machen und mich mal ein bisschen durchwurschtel. Ich finde halt die ganze, daran hängende VIS Geschichte, mit der automatisch erzeugten Tabellen sehr Charmant.
                                    Ich muss das script nur mal irgendwie runter geladen bekommen. Trotz Chrome zerhackt der Browser mir die Ä,Ü usw. was dann im Script Editor für die roten Unterstreichungen sorgt.
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #608
                                      @jb_sullivan wart nen moment - meld mich
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #609
                                        @jb_sullivan
                                        probier es mal von hier - selbes script https://github.com/liv-in-sky/iobroker-energy-script/blob/main/Energy-script-22-1-21.txt
                                          @jb_sullivan
                                          JB_Sullivan
                                          #610
                                          @liv-in-sky Ja, das sieht schon viel besser aus - auch wenn da im Script Editor noch ein paar Stellen Rot markiert sind - vielleicht kleine Formel "Unsaubarkeiten"?
                                          Naja, ich arbeite mich erst mal ein und gucke was passiert. Wobei du mir ja schon ein bisschen die Hoffnung genommen hast, da ich alle meine Sonoffs auf Tasmota 9.1.x und somit auch in ioB alles auf die neue Struktur angepasst habe.
