  4. Test Adapter mihome-vacuum v2.0.x
    6.3k
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 637.5k Aufrufe 118 Beobachtet
  • maeusekingM maeuseking
    @maeuseking sagte in Test Adapter mihome-vacuum v2.0.x:
    Moin!
    Nachdem einige Wochen der Adapter problemlos funktionierte, stürzt er nun an einem erfolgreich Übermittelten Befehl ab. Hat dazu jemand einen Tipp?
    Neuinstallation des Adpaters und Reboot des Saugroboters haben nichts gebracht...
    mihome-vacuum.0	2020-11-18 13:45:13.301	debug	(22494) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-11-18 13:45:13.300	info	(22494) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-11-18 13:45:13.296	debug	(22494) Receive <<< Helo <<< 213100200000000013272a775fb51759ffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2020-11-18 13:45:13.285	info	(22494) New generation or new fw(3.5.8,2516) detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-11-18 13:45:13.283	info	(22494) extend state mop for State control.fan_power
    mihome-vacuum.0	2020-11-18 13:45:13.271	info	(22494) change states from State control.fan_power
    mihome-vacuum.0	2020-11-18 13:45:13.239	debug	(22494) server started on 0.0.0.0:53421
    mihome-vacuum.0	2020-11-18 13:45:13.232	info	(22494) Cloud control disabled
    mihome-vacuum.0	2020-11-18 13:45:13.231	info	(22494) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-11-18 13:45:13.226	debug	(22494) Xiaomi Cloud: Logging in
    mihome-vacuum.0	2020-11-18 13:45:13.224	debug	(22494) load Map creator... true
    mihome-vacuum.0	2020-11-18 13:45:13.169	info	(22494) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.19.1, js-controller: 3.1.6
    mihome-vacuum.0	2020-11-18 13:44:40.465	info	(22435) Terminated (NO_ERROR): Without reason
    mihome-vacuum.0	2020-11-18 13:44:40.464	info	(22435) terminating
    mihome-vacuum.0	2020-11-18 13:44:40.457	error	(22435) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:187:68 at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/states
    mihome-vacuum.0	2020-11-18 13:44:40.456	error	(22435) uncaught exception: Cannot read property 'val' of null
    mihome-vacuum.0	2020-11-18 13:44:40.454	debug	(22435) sendMsg[1] >>> {"id":29,"method":"app_segment_clean","params":[19]}
    mihome-vacuum.0	2020-11-18 13:44:40.453	info	(22435) trigger cleaning segment 19
    mihome-vacuum.0	2020-11-18 13:44:40.449	debug	(22435) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-11-18 13:44:40.447	debug	(22435) stateChange mihome-vacuum.0.rooms.717001010826.roomClean {"val":true,"ack":false,"ts":1605703480443,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1605684698520}
    mihome-vacuum.0	2020-11-18 13:44:33.763	debug	(22435) CLEAN_LOGGING[{"Datum":"18.11","Start":"13:12","Saugzeit":"4 min","Fläche":"7.46 m²","Error":0,"Ende":false},{"Datum":"18.11","Start":"13:01","Saugzeit":"11 min","Fläche":"15.31 m²","Error":0,
    Nach einem neuem Befehl wieder direkter Absturz...
    mihome-vacuum.0	2020-11-18 13:49:20.617	info	(22494) Terminated (NO_ERROR): Without reason
    mihome-vacuum.0	2020-11-18 13:49:20.616	info	(22494) terminating
    mihome-vacuum.0	2020-11-18 13:49:20.608	error	(22494) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:187:68 at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/states
    mihome-vacuum.0	2020-11-18 13:49:20.607	error	(22494) uncaught exception: Cannot read property 'val' of null
    mihome-vacuum.0	2020-11-18 13:49:20.605	debug	(22494) sendMsg[1] >>> {"id":14,"method":"app_segment_clean","params":[19]}
    mihome-vacuum.0	2020-11-18 13:49:20.604	info	(22494) trigger cleaning segment 19
    EDIT:
    Auch ein komplettes Update nach dieser Anleitung
    https://forum.iobroker.net/topic/37020/nodejs-update-iobroker-installation-via-curl-nicht-möglich/51
    hat nichts geändert...
    Das Problem besteht bei mir noch immer. Hat jemand dazu eine Idee?
    #1390
    @maeuseking System inkl. NodeJS und ioBroker auf Stand bringen, beobachten, dann ggf. nochmal fragen.
      skorpil
      #1391
      heute hatte ich folgendes Problem:
      • aus mir nicht erfindlichen Gründen hatte sich der Staubsauger selbstständig auf die Werkseinstellungen zurückgesetzt
      • ich mußte ihn in der APP komplett neu installieren
      • dabei war natürlich der alte Token verloren gegangen
      • es gelang mir nicht, den "Xiaomi cloud login" ans Laufen zu bekommen
      • es blieb dann nur der sehr umständliche Weg über das iphone Backup den neuen Token zu finden
      Daher zwei Fragen:
      Hattet ihr das auch schon mal, daß sich der Sauger selstständig auf die Werkseinstellungen zurückgesetzt hat?
      Funktioniert momentan der Cloud Login nicht?
      PS: installierte Version ist die 2.1.1
      • S skorpil
        Daher zwei Fragen:
        #1392
        @skorpil ich hab 4 Stück, alles S5, und noch nie solche Effekte gehabt.
        Gleiche Adapterversion. Funktionieren über die App wie auch iobroker mit dem Adapter.
        Server ist auf Deutsch gestellt.
          skorpil
          #1393
          @ilovegym ich habe 2 der ersten Generation und bis heute auch noch nie sowas erlebt. Vor allem habe ich keine Idee, warum sich der eine zurückgesetzt hat. Bei mir steht schon seit Beginn vor 4 Jahren „China“ als Ländereinstellung in der iPhone App. Und damit habe ich heute den Sauber auch wieder über die App installiert. Über den Adapter geht gar nichts. Er reagiert trotz Servereinstellung China nicht. Auch auf Germany ist nichts passiert. Es werden keine Geräte angezeigt. So häufig muss man da auch die cloud nicht nutzen, um die Geräte zu finden. Vor ca. einem hat es in der gleichen Konstellation geklappt. Jetzt nicht.
          • S skorpil
            #1394
            @skorpil hmm vielleicht ist ja gerade ne maintenance in der china cloud an deinen Servern.. mal warten
            halt schon komisch, dass der sich zurück setzt.. ist die Firmware auf dem aktuellen Stand?
              skorpil
              #1395
              @ilovegym ja, alles aktuell.
              Gruß , Herr Namensvetter,
              auch: Bernd😂
              • D dirkhe
                @schwabe Nein die canvas lib, die benötigt wird, um die Karte zu zeichnen. Aber wenn es jetzt läuft, ist ja alles gut
                Schwabe
                #1396
                @dirkhe
                ...leider ist mein Problem wieder da. Mein Ubuntu System unter Windows war durch zu viel probieren instabil geworden und ich habe das System vor ca. 3 Wochen neu aufgesetzt. Seitdem habe ich alles wieder bei dem mihome-vacuum Adapter probiert, doch er bleibt auf gelb. Auf dem alten System von mir auf dem TinkerBoard läuft er ohne Probleme.
                Ich habe den Adapter auf dem TinkerBoard längere Zeit deaktiviert.
                Ich habe den Adapter mehrfach neu installiert und eingerichtet.
                Ich habe den Sauger ausgeschaltet und wieder eingeschaltet.
                Ich habe den Sauger mehrfach laufen lassen, während der Adapter aktiv war.
                Der Adapter verursacht keine Fehlermeldungen im Log. Der angehängte Log ist von einem manuellen Neustart des Adapters im debug Modus.
                Hat vielleicht noch jemand einen Rat für mich? Vielen Dank im Vorraus.
                mihome-vacuum.0	2021-03-14 21:05:56.355	debug	(26927) Xiaomi Cloud: Login successful
                mihome-vacuum.0	2021-03-14 21:05:55.108	info	(26927) set nächster Timer: Nicht verfügbar
                mihome-vacuum.0	2021-03-14 21:05:54.616	debug	(26927) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                mihome-vacuum.0	2021-03-14 21:05:54.600	debug	(26927) server started on 0.0.0.0:53421
                mihome-vacuum.0	2021-03-14 21:05:54.597	info	(26927) Cloud control disabled
                mihome-vacuum.0	2021-03-14 21:05:54.597	info	(26927) Expert mode enabled, states created
                mihome-vacuum.0	2021-03-14 21:05:54.595	debug	(26927) Xiaomi Cloud: Logging in
                mihome-vacuum.0	2021-03-14 21:05:54.594	debug	(26927) load Map creator... false
                mihome-vacuum.0	2021-03-14 21:05:54.556	info	(26927) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v15.11.0, js-controller: 3.2.16
                mihome-vacuum.0	2021-03-14 21:05:54.437	debug	(26927) statesDB connected
                mihome-vacuum.0	2021-03-14 21:05:54.437	debug	(26927) States connected to redis: 127.0.0.1:9000
                mihome-vacuum.0	2021-03-14 21:05:54.431	debug	(26927) States create User PubSub Client
                mihome-vacuum.0	2021-03-14 21:05:54.431	debug	(26927) States create System PubSub Client
                mihome-vacuum.0	2021-03-14 21:05:54.428	debug	(26927) Redis States: Use Redis connection: 127.0.0.1:9000
                mihome-vacuum.0	2021-03-14 21:05:54.427	debug	(26927) objectDB connected
                mihome-vacuum.0	2021-03-14 21:05:54.425	debug	(26927) Objects connected to redis: 127.0.0.1:9001
                mihome-vacuum.0	2021-03-14 21:05:54.417	debug	(26927) Objects client initialize lua scripts
                mihome-vacuum.0	2021-03-14 21:05:54.417	debug	(26927) Objects create User PubSub Client
                mihome-vacuum.0	2021-03-14 21:05:54.417	debug	(26927) Objects create System PubSub Client
                mihome-vacuum.0	2021-03-14 21:05:54.416	debug	(26927) Objects client ready ... initialize now
                mihome-vacuum.0	2021-03-14 21:05:54.404	debug	(26927) Redis Objects: Use Redis connection: 127.0.0.1:9001
                host.Server	2021-03-14 21:05:53.954	info	instance system.adapter.mihome-vacuum.0 started with pid 26927
                host.Server	2021-03-14 21:05:51.499	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                mihome-vacuum.0	2021-03-14 21:05:50.984	debug	(26912) system.adapter.admin.0: logging true
                mihome-vacuum.0	2021-03-14 21:05:50.901	info	(26912) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                mihome-vacuum.0	2021-03-14 21:05:50.900	info	(26912) terminating
                host.Server	2021-03-14 21:05:50.900	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
                mihome-vacuum.0	2021-03-14 21:05:50.900	info	(26912) Got terminate signal TERMINATE_YOURSELF
                • S skorpil
                  auch: Bernd😂
                  skorpil
                  #1397
                  Jeder Versuch, sich in der Cloud anzumelden um „Get Devices“ durchzuführen, scheitert.
                  Kann bitte mal jemand testen, ob das bei Euch funktioniert? Ich möchte wissen, ob ich ein Einzelfall bin, oder ob das bei Euch auch so ist.
                  Danke.
                  ? K 2 Antworten Letzte Antwort
                  • S skorpil
                    Danke.
                    #1398
                    @skorpil funktioniert hier einwandfrei, Server Germany.
                    • S skorpil
                      Danke.
                      Kueppert
                      #1399
                      @skorpil funktioniert einwandfrei, Server China
                      • K Kueppert
                        skorpil
                        #1400
                        @kueppert @ilovegym Dankeschön. Dann bin ich wohl der berühmte Einzelfall und habe nicht den Hauch einer Idee, warum das so ist. Einzig könnte ich mir noch vorstellen, dass es ein Port Problem ist, der nicht geöffnet ist. Sonst bin ich mit meinem Latein am Ende. Die Mihome App funktioniert mit den gleichen Zugangsdaten perfekt.
                        • S skorpil
                          Kueppert
                          #1401
                          @skorpil ggf Sonderzeichen im Passwort? Ich meine ich habe meins mal geändert deswegen... ggf PiHole laufen, der die Verbindung blockt? (dann müsste aber auch die MiHome-App geblockt werden vermutlich im WLAN)
                          • K Kueppert
                            skorpil
                            #1402
                            @kueppert danke für die Hinweise. Keine Sonderzeichen im PWD, kein pihole. Keine Ahnung🙈. Der Kreis dreht sich, also das Wartesymbol. Keine Rückmeldung, nichts.
                            • DiginixD Offline
                              DiginixD Offline
                              Diginix
                              #1403
                              @skorpil Schau doch mal ob was in der Browser Konsole (F12) steht wenn du die Geräte aus der Cloud abrufen willst.
                              Sowohl Tab Netzwerk als auch Konsole könnten interessant sein.
                              ..:: So long! Tom ::..
                              S 2 Antworten Letzte Antwort
                              • DiginixD Diginix
                                skorpil
                                #1404
                                @diginix danke. Ich melde mich, bin gerade unterwegs
                                • DiginixD Diginix
                                  skorpil
                                  #1405
                                  @diginix hier ist, was ich mit F12 gefunden habe. Unter Netzwerk war m.E. nichts interessantes. Wohl aber unter KONSOLE (siehe Spoiler). Was bedeutet das? Ich kann es nicht interpretieren.
                                  :8081/#tab-instances/config/system.adapter.mihome-vacuum.2:1 Autofocus processing was blocked because a document's URL has a fragment '#tab-instances/config/system.adapter.mihome-vacuum.2'.
                                  jquery.fancytree-all.js:113 Fancytree@1 Fancytree.filterNodes() leavesOnly option is deprecated since 2.9.0 / 2015-04-19. Use opts.leavesOnly instead.
                                  v @ jquery.fancytree-all.js:113
                                  warn @ jquery.fancytree-all.js:3019
                                  e.ui.fancytree._FancytreeClass.filterNodes @ jquery.fancytree-all.js:7944
                                  (anonymous) @ adminAdapters.js:558
                                  translate.js:24 "Main": {"en": "Main", "de": "Main", "ru": "Main", "pt": "Main", "nl": "Main", "fr": "Main", "es": "Main", "pl": "Main", "it": "Main", "zh-cn": "Main"},
                                  translate.js:24 "Settings": {"en": "Settings", "de": "Settings", "ru": "Settings", "pt": "Settings", "nl": "Settings", "fr": "Settings", "es": "Settings", "pl": "Settings", "it": "Settings", "zh-cn": "Settings"},
                                  translate.js:24 "Map settings": {"en": "Map settings", "de": "Map settings", "ru": "Map settings", "pt": "Map settings", "nl": "Map settings", "fr": "Map settings", "es": "Map settings", "pl": "Map settings", "it": "Map settings", "zh-cn": "Map settings"},
                                  translate.js:24 "Xiaomi cloud login": {"en": "Xiaomi cloud login", "de": "Xiaomi cloud login", "ru": "Xiaomi cloud login", "pt": "Xiaomi cloud login", "nl": "Xiaomi cloud login", "fr": "Xiaomi cloud login", "es": "Xiaomi cloud login", "pl": "Xiaomi cloud login", "it": "Xiaomi cloud login", "zh-cn": "Xiaomi cloud login"},
                                  translate.js:24 "E-mail": {"en": "E-mail", "de": "E-mail", "ru": "E-mail", "pt": "E-mail", "nl": "E-mail", "fr": "E-mail", "es": "E-mail", "pl": "E-mail", "it": "E-mail", "zh-cn": "E-mail"},
                                  translate.js:24 "password": {"en": "password", "de": "password", "ru": "password", "pt": "password", "nl": "password", "fr": "password", "es": "password", "pl": "password", "it": "password", "zh-cn": "password"},
                                  translate.js:24 "server": {"en": "server", "de": "server", "ru": "server", "pt": "server", "nl": "server", "fr": "server", "es": "server", "pl": "server", "it": "server", "zh-cn": "server"},
                                  translate.js:24 "Server": {"en": "Server", "de": "Server", "ru": "Server", "pt": "Server", "nl": "Server", "fr": "Server", "es": "Server", "pl": "Server", "it": "Server", "zh-cn": "Server"},
                                  translate.js:24 "get devices<span></span>": {"en": "get devices<span></span>", "de": "get devices<span></span>", "ru": "get devices<span></span>", "pt": "get devices<span></span>", "nl": "get devices<span></span>", "fr": "get devices<span></span>", "es": "get devices<span></span>", "pl": "get devices<span></span>", "it": "get devices<span></span>", "zh-cn": "get devices<span></span>"},
                                  translate.js:24 "Please get Devices first": {"en": "Please get Devices first", "de": "Please get Devices first", "ru": "Please get Devices first", "pt": "Please get Devices first", "nl": "Please get Devices first", "fr": "Please get Devices first", "es": "Please get Devices first", "pl": "Please get Devices first", "it": "Please get Devices first", "zh-cn": "Please get Devices first"},
                                  translate.js:24 "devices": {"en": "devices", "de": "devices", "ru": "devices", "pt": "devices", "nl": "devices", "fr": "devices", "es": "devices", "pl": "devices", "it": "devices", "zh-cn": "devices"},
                                  translate.js:24 "manuell settings": {"en": "manuell settings", "de": "manuell settings", "ru": "manuell settings", "pt": "manuell settings", "nl": "manuell settings", "fr": "manuell settings", "es": "manuell settings", "pl": "manuell settings", "it": "manuell settings", "zh-cn": "manuell settings"},
                                  translate.js:24 "device": {"en": "device", "de": "device", "ru": "device", "pt": "device", "nl": "device", "fr": "device", "es": "device", "pl": "device", "it": "device", "zh-cn": "device"},
                                  translate.js:24 "map": {"en": "map", "de": "map", "ru": "map", "pt": "map", "nl": "map", "fr": "map", "es": "map", "pl": "map", "it": "map", "zh-cn": "map"},
                                  translate.js:24 "enable Map from xiaomi cloud": {"en": "enable Map from xiaomi cloud", "de": "enable Map from xiaomi cloud", "ru": "enable Map from xiaomi cloud", "pt": "enable Map from xiaomi cloud", "nl": "enable Map from xiaomi cloud", "fr": "enable Map from xiaomi cloud", "es": "enable Map from xiaomi cloud", "pl": "enable Map from xiaomi cloud", "it": "enable Map from xiaomi cloud", "zh-cn": "enable Map from xiaomi cloud"},
                                  translate.js:24 "other settings": {"en": "other settings", "de": "other settings", "ru": "other settings", "pt": "other settings", "nl": "other settings", "fr": "other settings", "es": "other settings", "pl": "other settings", "it": "other settings", "zh-cn": "other settings"},
                                  translate.js:24 "Request Intervall": {"en": "Request Intervall", "de": "Request Intervall", "ru": "Request Intervall", "pt": "Request Intervall", "nl": "Request Intervall", "fr": "Request Intervall", "es": "Request Intervall", "pl": "Request Intervall", "it": "Request Intervall", "zh-cn": "Request Intervall"},
                                  translate.js:24 "Use new Map format with roomcolors": {"en": "Use new Map format with roomcolors", "de": "Use new Map format with roomcolors", "ru": "Use new Map format with roomcolors", "pt": "Use new Map format with roomcolors", "nl": "Use new Map format with roomcolors", "fr": "Use new Map format with roomcolors", "es": "Use new Map format with roomcolors", "pl": "Use new Map format with roomcolors", "it": "Use new Map format with roomcolors", "zh-cn": "Use new Map format with roomcolors"},
                                  translate.js:24 "add": {"en": "add", "de": "add", "ru": "add", "pt": "add", "nl": "add", "fr": "add", "es": "add", "pl": "add", "it": "add", "zh-cn": "add"},
                                  translate.js:24 "add timer and choose room channels directly and/or choose rooms,
                                  which finds assigned room channels": {"en": "add timer and choose room channels directly and/or choose rooms,
                                  which finds assigned room channels", "de": "add timer and choose room channels directly and/or choose rooms,
                                  which finds assigned room channels", "ru": "add timer and choose room channels directly and/or choose rooms,
                                  which finds assigned room channels", "pt": "add timer and choose room channels directly and/or choose rooms,
                                  which finds assigned room channels", "nl": "add timer and choose room channels directly and/or choose rooms,
                                  which finds assigned room channels", "fr": "add timer and choose room channels directly and/or choose rooms,
                                  which finds assigned room channels", "es": "add timer and choose room channels directly and/or choose rooms,
                                  which finds assigned room channels", "pl": "add timer and choose room channels directly and/or choose rooms,
                                  which finds assigned room channels", "it": "add timer and choose room channels directly and/or choose rooms,
                                  which finds assigned room channels", "zh-cn": "add timer and choose room channels directly and/or choose rooms,
                                  which finds assigned room channels"},
                                  translate.js:24 "
                                  enabled": {"en": "
                                  enabled", "de": "
                                  enabled", "ru": "
                                  enabled", "pt": "
                                  enabled", "nl": "
                                  enabled", "fr": "
                                  enabled", "es": "
                                  enabled", "pl": "
                                  enabled", "it": "
                                  enabled", "zh-cn": "
                                  enabled"},
                                  translate.js:24 "minute
                                  ": {"en": "minute
                                  ", "de": "minute
                                  ", "ru": "minute
                                  ", "pt": "minute
                                  ", "nl": "minute
                                  ", "fr": "minute
                                  ", "es": "minute
                                  ", "pl": "minute
                                  ", "it": "minute
                                  ", "zh-cn": "minute
                                  translate.js:24 "channels": {"en": "channels", "de": "channels", "ru": "channels", "pt": "channels", "nl": "channels", "fr": "channels", "es": "channels", "pl": "channels", "it": "channels", "zh-cn": "channels"},
                                  index_m.html?2:145 run all....
                                  adminConfig.js:17 nochange
                                  adminConfig.js:24 Unknown event: nochange
                                  adminInstances.js:1065 60
                                  translate.js:24 "00": {"en": "00", "de": "00", "ru": "00", "pt": "00", "nl": "00", "fr": "00", "es": "00", "pl": "00", "it": "00", "zh-cn": "00"},
                                  translate.js:24 "01": {"en": "01", "de": "01", "ru": "01", "pt": "01", "nl": "01", "fr": "01", "es": "01", "pl": "01", "it": "01", "zh-cn": "01"},
                                  translate.js:24 "02": {"en": "02", "de": "02", "ru": "02", "pt": "02", "nl": "02", "fr": "02", "es": "02", "pl": "02", "it": "02", "zh-cn": "02"},
                                  translate.js:24 "03": {"en": "03", "de": "03", "ru": "03", "pt": "03", "nl": "03", "fr": "03", "es": "03", "pl": "03", "it": "03", "zh-cn": "03"},
                                  translate.js:24 "04": {"en": "04", "de": "04", "ru": "04", "pt": "04", "nl": "04", "fr": "04", "es": "04", "pl": "04", "it": "04", "zh-cn": "04"},
                                  translate.js:24 "05": {"en": "05", "de": "05", "ru": "05", "pt": "05", "nl": "05", "fr": "05", "es": "05", "pl": "05", "it": "05", "zh-cn": "05"},
                                  translate.js:24 "06": {"en": "06", "de": "06", "ru": "06", "pt": "06", "nl": "06", "fr": "06", "es": "06", "pl": "06", "it": "06", "zh-cn": "06"},
                                  translate.js:24 "07": {"en": "07", "de": "07", "ru": "07", "pt": "07", "nl": "07", "fr": "07", "es": "07", "pl": "07", "it": "07", "zh-cn": "07"},
                                  translate.js:24 "08": {"en": "08", "de": "08", "ru": "08", "pt": "08", "nl": "08", "fr": "08", "es": "08", "pl": "08", "it": "08", "zh-cn": "08"},
                                  translate.js:24 "09": {"en": "09", "de": "09", "ru": "09", "pt": "09", "nl": "09", "fr": "09", "es": "09", "pl": "09", "it": "09", "zh-cn": "09"},
                                  translate.js:24 "10": {"en": "10", "de": "10", "ru": "10", "pt": "10", "nl": "10", "fr": "10", "es": "10", "pl": "10", "it": "10", "zh-cn": "10"},
                                  translate.js:24 "11": {"en": "11", "de": "11", "ru": "11", "pt": "11", "nl": "11", "fr": "11", "es": "11", "pl": "11", "it": "11", "zh-cn": "11"},
                                  translate.js:24 "12": {"en": "12", "de": "12", "ru": "12", "pt": "12", "nl": "12", "fr": "12", "es": "12", "pl": "12", "it": "12", "zh-cn": "12"},
                                  translate.js:24 "13": {"en": "13", "de": "13", "ru": "13", "pt": "13", "nl": "13", "fr": "13", "es": "13", "pl": "13", "it": "13", "zh-cn": "13"},
                                  translate.js:24 "14": {"en": "14", "de": "14", "ru": "14", "pt": "14", "nl": "14", "fr": "14", "es": "14", "pl": "14", "it": "14", "zh-cn": "14"},
                                  translate.js:24 "15": {"en": "15", "de": "15", "ru": "15", "pt": "15", "nl": "15", "fr": "15", "es": "15", "pl": "15", "it": "15", "zh-cn": "15"},
                                  translate.js:24 "16": {"en": "16", "de": "16", "ru": "16", "pt": "16", "nl": "16", "fr": "16", "es": "16", "pl": "16", "it": "16", "zh-cn": "16"},
                                  translate.js:24 "17": {"en": "17", "de": "17", "ru": "17", "pt": "17", "nl": "17", "fr": "17", "es": "17", "pl": "17", "it": "17", "zh-cn": "17"},
                                  translate.js:24 "18": {"en": "18", "de": "18", "ru": "18", "pt": "18", "nl": "18", "fr": "18", "es": "18", "pl": "18", "it": "18", "zh-cn": "18"},
                                  translate.js:24 "19": {"en": "19", "de": "19", "ru": "19", "pt": "19", "nl": "19", "fr": "19", "es": "19", "pl": "19", "it": "19", "zh-cn": "19"},
                                  translate.js:24 "20": {"en": "20", "de": "20", "ru": "20", "pt": "20", "nl": "20", "fr": "20", "es": "20", "pl": "20", "it": "20", "zh-cn": "20"},
                                  translate.js:24 "21": {"en": "21", "de": "21", "ru": "21", "pt": "21", "nl": "21", "fr": "21", "es": "21", "pl": "21", "it": "21", "zh-cn": "21"},
                                  translate.js:24 "22": {"en": "22", "de": "22", "ru": "22", "pt": "22", "nl": "22", "fr": "22", "es": "22", "pl": "22", "it": "22", "zh-cn": "22"},
                                  translate.js:24 "23": {"en": "23", "de": "23", "ru": "23", "pt": "23", "nl": "23", "fr": "23", "es": "23", "pl": "23", "it": "23", "zh-cn": "23"},
                                  translate.js:24 "25": {"en": "25", "de": "25", "ru": "25", "pt": "25", "nl": "25", "fr": "25", "es": "25", "pl": "25", "it": "25", "zh-cn": "25"},
                                  translate.js:24 "30": {"en": "30", "de": "30", "ru": "30", "pt": "30", "nl": "30", "fr": "30", "es": "30", "pl": "30", "it": "30", "zh-cn": "30"},
                                  translate.js:24 "35": {"en": "35", "de": "35", "ru": "35", "pt": "35", "nl": "35", "fr": "35", "es": "35", "pl": "35", "it": "35", "zh-cn": "35"},
                                  translate.js:24 "40": {"en": "40", "de": "40", "ru": "40", "pt": "40", "nl": "40", "fr": "40", "es": "40", "pl": "40", "it": "40", "zh-cn": "40"},
                                  translate.js:24 "45": {"en": "45", "de": "45", "ru": "45", "pt": "45", "nl": "45", "fr": "45", "es": "45", "pl": "45", "it": "45", "zh-cn": "45"},
                                  translate.js:24 "50": {"en": "50", "de": "50", "ru": "50", "pt": "50", "nl": "50", "fr": "50", "es": "50", "pl": "50", "it": "50", "zh-cn": "50"},
                                  translate.js:24 "55": {"en": "55", "de": "55", "ru": "55", "pt": "55", "nl": "55", "fr": "55", "es": "55", "pl": "55", "it": "55", "zh-cn": "55"},
                                  index_m.html?2:187 send to..."xxxx@xx.XXX" (hier stand meine email Adresse) server: -
                                  • DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #1406
                                    @skorpil sagte in Test Adapter mihome-vacuum v2.0.x:
                                    Das müsste die erste Zeile bei Klick auf den "get devices" Button sein. Alles davor dürfte unerheblich sein.
                                    Erst danach kommt bei in der Konsole eine Liste aller Xiaomi Geräte, Sensoren mit ihrer ID, Namen, Status, Token usw.
                                    Da passiert bei dir ja demnach nichts mehr. Steht im normalen iobroker Log was? Gefühlt hat er keinerlei Verbindung zum Xiaomi Cloud Server.
                                    Evtl. hilft auch den Loglevel der Instanz auf Debug zu stellen um an mehr Details zu kommen.
                                    Aber ab jetzt können dir evtl. nur noch die Entwickler helfen. Mit fällt zumindest nichts weiter ein.
                                    • DiginixD Diginix
                                      skorpil
                                      #1407
                                      @diginix Dankeschön. Vielleicht weiß ja jemand anderer noch Rat. Ich hätte getippt, dass hier
                                      die Ursache liegt. Ich hatte sicherheitshalber auch noch malt mit apt-get update u. upgrade die Linux version auf den neuesten Stand gebracht. Das hat aber auch nicht zur Verbesserung beigetragen.
                                      • Z Offline
                                        Z Offline
                                        Zwer2k
                                        schrieb am zuletzt editiert von Zwer2k
                                        #1408
                                        bekomme immer wieder folgenden Fehler. Hab Robororock S50.
                                        mihome-vacuum.0	2021-03-20 10:20:41.908	warn	(31187) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        mihome-vacuum.0	2021-03-20 10:20:41.907	info	(31187) terminating
                                        mihome-vacuum.0	2021-03-20 10:20:41.903	error	(31187) The id "32" has an invalid type! Expected "string" or "object", received "number".
                                        mihome-vacuum.0	2021-03-20 10:20:41.903	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
                                        mihome-vacuum.0	2021-03-20 10:20:41.903	error	at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:1089:63
                                        mihome-vacuum.0	2021-03-20 10:20:41.903	error	at Object.callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:512:25)
                                        mihome-vacuum.0	2021-03-20 10:20:41.903	error	at Adapter.setForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6223:17)
                                        mihome-vacuum.0	2021-03-20 10:20:41.903	error	at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:505:19)
                                        mihome-vacuum.0	2021-03-20 10:20:41.903	error	(31187) Error: The id "32" has an invalid type! Expected "string" or "object", received "number".
                                        mihome-vacuum.0	2021-03-20 10:20:41.901	error	(31187) unhandled promise rejection: The id "32" has an invalid type! Expected "string" or "object", received "number".
                                        mihome-vacuum.0	2021-03-20 10:20:41.901	error	(31187) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        mihome-vacuum.0	2021-03-20 10:20:41.900	info	(31187) send message: Method: app_zoned_clean Params: [[27900,26300,30200,28600,1],[23000,25700,27900,29100,1],[25800,21800,27900,25700,1],[23000,21800,25800,23200,1],[23000,21800,23700,25000,1]]
                                        oder
                                        mihome-vacuum.0	2021-03-20 10:42:31.830	warn	(3375) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        mihome-vacuum.0	2021-03-20 10:42:31.828	info	(3375) terminating
                                        mihome-vacuum.0	2021-03-20 10:42:31.824	error	(3375) The id "84" has an invalid type! Expected "string" or "object", received "number".
                                        mihome-vacuum.0	2021-03-20 10:42:31.824	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
                                        mihome-vacuum.0	2021-03-20 10:42:31.824	error	at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:1089:63
                                        mihome-vacuum.0	2021-03-20 10:42:31.824	error	at Object.callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:512:25)
                                        mihome-vacuum.0	2021-03-20 10:42:31.824	error	at Adapter.setForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6223:17)
                                        mihome-vacuum.0	2021-03-20 10:42:31.824	error	at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:505:19)
                                        mihome-vacuum.0	2021-03-20 10:42:31.824	error	(3375) Error: The id "84" has an invalid type! Expected "string" or "object", received "number".
                                        mihome-vacuum.0	2021-03-20 10:42:31.822	error	(3375) unhandled promise rejection: The id "84" has an invalid type! Expected "string" or "object", received "number".
                                        mihome-vacuum.0	2021-03-20 10:42:31.822	error	(3375) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        mihome-vacuum.0	2021-03-20 10:42:31.821	info	(3375) send message: Method: app_goto_target Params: [26400,25500]
                                        Nach dem Absturz bleibt der Adapter meistens ewig gelb bis er wieder online ist.
                                        (3375) connecting, this can take up to 10 minutes ...
                                          Schwabe
                                          #1409
                                          Wenn ich mein Problem noch mal hervorholen darf.
                                          Ich habe 2 ioBroker System. Das "Alte" ist ein TinkerBoard S auf dem ich keinen mihome-vacuum Adpter neuer als 1.1.5 installiert bekomme. Updates brechen mit einer Fehlermeldung ab und ich muss danach den Adapter komplett deinstallieren und neu installieren, doch ansonsten läuft er einwandfrei. Da ich gerne auf mein "Neues" umsteigen möchte, würde ich hier nichts mehr dran ändern wollen.
                                          Das "Neue" ist ein Ubuntu unter Windows. Leider bleibt hier der Adapter bei "gelb" stehen er wird einfach nicht "grün". Ich kann die Serverdaten eintragen, bekomme meinen "Robbi" angezeigt und kann diesen auch übernehmen.
                                          Meine Node.js Version ist 12.21.0, die NPM 6.14.11 und der JS Controller ist auch aktuell.
                                          Thomas BraunT S 2 Antworten Letzte Antwort
