  5. Fehler in Blocky - und keine Ahnung warum!
39 Beiträge 7 Kommentatoren 5.6k Aufrufe 3 Beobachtet
  • hananH Offline
    hananH Offline
    hanan
    Habe den gleichen Fehler mit dem Dollarzeichen.
    Wollte jetzt auf 5.0.10 zurück, doch ich bekomme nur eine Fehlermeldung.
    Hier das Logfile:
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.javascript@5.10'
    1 verbose cli ]
    2 info using npm@6.14.11
    3 info using node@v12.21.0
    4 verbose npm-session f3bb9104ea94662b
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 200 https://registry.npmjs.org/iobroker.javascript 155ms
    8 silly fetchPackageMetaData error for iobroker.javascript@5.10 No matching version found for iobroker.javascript@5.10.
    9 timing stage:rollbackFailedOptional Completed in 0ms
    10 timing stage:runTopLevelLifecycles Completed in 2934ms
    11 verbose type range
    12 verbose stack iobroker.javascript: No matching version found for iobroker.javascript@5.10.
    12 verbose stack     at pickManifest (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:122:13)
    12 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:24:14
    12 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    12 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
    12 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
    12 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
    12 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
    12 verbose stack     at _drainQueueStep (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
    12 verbose stack     at _drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
    12 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
    12 verbose stack     at Immediate.Async.drainQueues [as _onImmediate] (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
    12 verbose stack     at processImmediate (internal/timers.js:461:21)
    13 verbose cwd /opt/iobroker
    14 verbose Linux 4.19.0-12-amd64
    15 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript@5.10"
    16 verbose node v12.21.0
    17 verbose npm  v6.14.11
    18 error code ETARGET
    19 error notarget No matching version found for iobroker.javascript@5.10.
    20 error notarget In most cases you or one of your dependencies are requesting
    20 error notarget a package version that doesn't exist.
    21 verbose exit [ 1, true ]
    Liebe Grüsse aus der Schweiz
    Andy
    ioBroker auf NUC unter Proxmox, Raspberrymatic-CCU auf NUC unter Proxmox mit RPI-RF-MOD Funkmodul und Omnidiraktional Antenne
    • hananH hanan
      Hier das Logfile:
      1 verbose cli [
      1 verbose cli ]
      wendy2702W Offline
      wendy2702W Offline
      @hanan Wie hast du den Downgrade angestossen?
      iobroker update
      Bitte auf 5.09 gehen.
      • M Michaelnorge
        @wendy2702 Hab ich gemacht, Fehler ist weg! Danke Euch!!!
        wendy2702W Offline
        wendy2702W Offline
        @michaelnorge sagte in Fehler in Blocky - und keine Ahnung warum!:
        Bitte mal Ausgabe von
        iobroker list adapters |grep javascript
        Posten
        • hananH Offline
          hananH Offline
          hanan
          @wendy2702
          cd /opt/iobroker
          npm install iobroker.javascript@5.0.10 --production
          Andy
          • hananH hanan
            @wendy2702
            cd /opt/iobroker
            wendy2702W Offline
            wendy2702W Offline
            @hanan 5.10 geht nicht. War nie auf NPM. Hatte da vorhin leider ein falsche Info bekommen.
            WIe geschrieben bitte 5.09 nutzen
            chucky666C 1 Antwort Letzte Antwort
            • wendy2702W wendy2702
              chucky666C Offline
              chucky666C Offline
              chucky666
              @wendy2702
              ich habe auch einen Fehler
              javascript.0	2021-03-07 13:48:20.003	error	(1230) at processImmediate (internal/timers.js:463:21)
              javascript.0	2021-03-07 13:48:20.003	error	(1230) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
              javascript.0	2021-03-07 13:48:20.003	error	(1230) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17
              javascript.0	2021-03-07 13:48:20.002	error	(1230) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
              javascript.0	2021-03-07 13:48:20.002	error	(1230) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
              javascript.0	2021-03-07 13:48:20.002	error	(1230) at Object.createScript (vm.js:261:10)
              javascript.0	2021-03-07 13:48:20.002	error	(1230) at new Script (vm.js:88:7)
              javascript.0	2021-03-07 13:48:20.002	error	(1230) SyntaxError: missing ) after argument list
              javascript.0	2021-03-07 13:48:20.002	error	(1230) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
              javascript.0	2021-03-07 13:48:20.002	error	(1230) on({id: new RegExp('zigbee\\.0\\.00158d000204790f\\.occupancy' + "$|" + 'zigbee\\.0\\.00158d0001d7adf4\\.opened'$), val: true}, async function (obj) {
              javascript.0	2021-03-07 13:48:20.002	error	at script.js.Vorgarten_Reolink_Cam_Blocky:24
              javascript.0	2021-03-07 13:48:20.002	error	(1230) script.js.Vorgarten_Reolink_Cam_Blocky compile failed:
              • hananH Offline
                hananH Offline
                hanan
                @wendy2702
                Jep, mit 5.0.09 hat es geklappt.
                Andy
                • chucky666C chucky666
                  @wendy2702
                  @chucky666 sagte in Fehler in Blocky - und keine Ahnung warum!:
                  was willst du uns damit sagen?
                  Hast du noch weitere Infos?
                  .occupancy' + "$
                    .occupancy' + "$
                    chucky666C Offline
                    chucky666C Offline
                    chucky666
                    Ich habe das Update gemacht auf 5.11 danach bekomme ich diesen Fehler .
                    Jetzt bin ich zurück auf 5.09 aber leider ist der Fehler immer noch da
                    wendy2702W HomoranH 2 Antworten Letzte Antwort
                      wendy2702W Offline
                      wendy2702W Offline
                      @chucky666 Blockly löschen und neu machen
                        @chucky666
                        den Thread hast du aber gelesen, oder?
                        hat das Blockly vorher existiert?
                        Wenn ja, mit welcher Version hast du das Blockly angelegt?
                        • hananH Offline
                          hananH Offline
                          hanan
                          schrieb am zuletzt editiert von hanan
                          Bin zurück auf Version 5.0.09 und habe den Mehrfach-Trigger-Block gelöscht und neu angelegt. Leider immer noch das $-Zeichen nach dem + ".
                          Hier der Log beim starten dieses Scriptes:
                          javascript.0	2021-03-07 13:58:22.951	error	(21836) at processImmediate (internal/timers.js:463:21)
                          javascript.0	2021-03-07 13:58:22.951	error	(21836) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
                          javascript.0	2021-03-07 13:58:22.951	error	(21836) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17
                          javascript.0	2021-03-07 13:58:22.951	error	(21836) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
                          javascript.0	2021-03-07 13:58:22.951	error	(21836) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
                          javascript.0	2021-03-07 13:58:22.951	error	(21836) at Object.createScript (vm.js:261:10)
                          javascript.0	2021-03-07 13:58:22.951	error	(21836) at new Script (vm.js:88:7)
                          javascript.0	2021-03-07 13:58:22.951	error	(21836) SyntaxError: missing ) after argument list
                          javascript.0	2021-03-07 13:58:22.951	error	(21836) ^^^^^^^^^^^^^^^^
                          javascript.0	2021-03-07 13:58:22.951	error	(21836) on({id: new RegExp('0_userdata\\.0\\.Variablen\\.Uebe...\\.Bewe...' + "$|" + 'scene\\.0\\.Tanz...' + "$|" + 'hm-rpc\\.1\\.0000D\\.1\\.STATE' + "$|" + 'hm-rpc\\.1\\.00
                          javascript.0	2021-03-07 13:58:22.951	error	at script.js.common.Sonstiges.Deko_tanzentes_Tier:1
                          javascript.0	2021-03-07 13:58:22.951	error	(21836) script.js.common.Sonstiges.Deko_tanzentes_Tier compile failed:
                          Andy
                          • hananH hanan
                            @hanan sagte in Fehler in Blocky - und keine Ahnung warum!:
                            danach zwischengespeichert?
                            • hananH Offline
                              hananH Offline
                              hanan
                              @Homoran
                              Habe es nochmals mit zwischenspeichern versucht. Das $-Zeichen bleibt.
                              Andy
                              • hananH hanan
                                @Homoran
                                wendy2702W Offline
                                wendy2702W Offline
                                @Homoran
                                Habe es nochmals zwischenspeichern versucht. Das $-Zeichen bleibt.
                                • hananH Offline
                                  hananH Offline
                                  hanan
                                  @wendy2702 sagte in Fehler in Blocky - und keine Ahnung warum!:
                                  Guter Tipp...
                                  Habe immer noch die Version 5.0.11
                                  Andy
                                    chucky666C Offline
                                    chucky666C Offline
                                    chucky666
                                    @wendy2702
                                    Danke euch , musste 2 Blockys neu machen .
                                    Ich habe die java version 5.09 installiert , Neustart gemacht und dann die betroffenen Blockys neuprogrammiert
                                    erstmal klappt alles
                                    • hananH Offline
                                      hananH Offline
                                      hanan
                                      @wendy2702
                                      Habe jetzt folgenden Zustand und iobroker neu gestartet:
                                      Adapter    "javascript"      :   5.0.11      , installad 5.0.9 [Updateable]
                                      Andy
                                      • hananH hanan
                                        @wendy2702
                                        klingt gut!
                                        und jetzt noch einmal zurück auf LOS!
                                        • hananH Offline
                                          hananH Offline
                                          hanan
                                          @Homoran
                                          Neuse Blockly mit dem Mehrfach-Trigger-Block erstelt und immer noch Fehlermeldung wegen dem $-Zeichen:
                                          javascript.0	2021-03-07 14:40:32.582	error	(8378) at processImmediate (internal/timers.js:463:21)
                                          javascript.0	2021-03-07 14:40:32.582	error	(8378) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
                                          javascript.0	2021-03-07 14:40:32.582	error	(8378) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17
                                          javascript.0	2021-03-07 14:40:32.581	error	(8378) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
                                          javascript.0	2021-03-07 14:40:32.581	error	(8378) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
                                          javascript.0	2021-03-07 14:40:32.581	error	(8378) at Object.createScript (vm.js:261:10)
                                          javascript.0	2021-03-07 14:40:32.581	error	(8378) at new Script (vm.js:88:7)
                                          javascript.0	2021-03-07 14:40:32.581	error	(8378) SyntaxError: missing ) after argument list
                                          javascript.0	2021-03-07 14:40:32.581	error	(8378) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                                          javascript.0	2021-03-07 14:40:32.581	error	(8378) on({id: new RegExp('0_userdata\\.0\\.Variablen\\.Ueber...\\.Bewe...' + "$|" + 'scene\\.0\\.Tanz...'$), change: "ne"}, async function (obj) {
                                          javascript.0	2021-03-07 14:40:32.581	error	at script.js.common.Sonstiges.Deko...:1
                                          javascript.0	2021-03-07 14:40:32.581	error	(8378) script.js.common.Sonstiges.Deko... compile failed:
                                          Gebe jetzt auf und wart mal ab.
                                          Das Skript ist nur für Deko, also Prio 3 mit leichtem negativem WAF welche ich übeleben werde 🙄
                                          Andy
