  4. IObroker zerlegt nach Stromausfall
    6.4k
35 Beiträge 5 Kommentatoren 8.3k Aufrufe 8 Beobachtet
    Danke, hatte ich als unerfahrer Nutzer auch so verstanden. Hatte eben mal was über einen Terminalbefehl gelesen um den ssh zugriff zu aktivieren, aber das ist nur gegoogelt keine Ahnung ob das geht.
    die js.controller installation wirft viele meldungen raus und danach gibt iobroker status nach dem start eine positive rückmeldung. allerdings läuft der admin nicht und lässt sich auch nicht starten. manuell installieren?
     iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.11
    > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
     Cannot read system.config: null (OK when migrating or restoring)
    object 0_userdata.0.example_state created
    object 0_userdata.0 created
    object alias.0 created
    object system.certificates created
    object system.repositories created
    object system.config created
    object enum.functions created
    object enum.rooms created
    object system.group.user created
    object system.group.administrator created
    object _design/system created
    The following notifications happened during sync:
    - Ignoring Directory "admin.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "backitup.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "daswetter.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "devices.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "discovery.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "dwd.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "flot" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "flot.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "influxdb.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "info.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "javascript.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "mqtt.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "pushover.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "radar2.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "shelly.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "simple-api.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "socketio.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "sonoff.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "sourceanalytix.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "sql.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "virtualpowermeter.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis-bars.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis-history.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis-hqwidgets.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis-jqui-mfd.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis-justgage.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis-metro.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis-players.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis-plumb.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis-timeandweather.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis.0" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "web" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "web.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "whatsapp-cmb.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "zigbee.admin" because officially not created as meta object. Please remove directory!
    Renamed repository "default to "stable"
    Renamed repository "latest to "beta"
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
    + iobroker.js-controller@3.2.16
    updated 13 packages in 157.823s
    62 packages are looking for funding
      run `npm fund` for details
       │      New major version of npm available! 6.14.11 → 7.6.1      │
       │   Changelog: https://github.com/npm/cli/releases/tag/v7.6.1   │
       │               Run npm install -g npm to update!               │
    @pete0815 sagte in IObroker zerlegt nach Stromausfall:
    Dazu musst du aber 'von Innen' kommen.
    iobroker list adapters
    iobroker list instances
    bringt?
    ? 2 Antworten Letzte Antwort
      bringt?
      ok thx.
      erzeugt gar keine Rückmeldung
      + instance is alive
        ok thx.
        + instance is alive
        @pete0815
        iobroker add admin
          bringt?
          @thomas-braun said in IObroker zerlegt nach Stromausfall:
          ooooh jetzt verstanden. Mit Terminal ist die lokale Bedienung am RPI gemeint und dann dort ein Terminalfenster öffnen. Hatte das Terminalfenster extern vermutet :man-facepalming:
            @pete0815
            iobroker add admin
            iobroker add admin
            Danke, der admin ist wieder da und per Browser erreichbar. Bisher aber nur mit admin und info Adapter sonst "blank".
            Jetzt den Backitup Adapter installieren und Restore?
            Thomas BraunT ? 2 Antworten Letzte Antwort
              iobroker add admin
              @pete0815 Ja. Die leere Hülle musst du jetzt wieder mit Adaptern füllen. Per Backup ja kein Problem
                iobroker add admin
                @Thomas-Braun
                mir fällt gerade auf, dass er nicht ganz "blank" ist. Meine letzte Textsuche im Adapterfeld ist noch vorhanden.
                Oder kommt das von meinem Browser?
                  ok super teste mal
                    @Thomas-Braun
                    @pete0815 Dürfte vom Browser Cache stammen.
                      ok.
                      Bei den Adaptern/Instanzen stimmt noch etwas nicht. In der Liste der Adapter (Expertenmodus) stehen noch alle meine installierten Adapter mit deren Version und es werden sogar 4 Updates angezeigt (Menü links -> Blaues Feld mit einer 4).
                      In der Liste der Instanzen sind nur admin und info aufgeführt.
                      Habe mir in der Adapterliste backitup gesucht (installiert war/ist 2.0.0) und verfügbar 2.0.3. Wurde dann erfolgreich aktualisiert aber in der Liste der Instanzen tauch er nicht auf.Auch nicht nach Refresh des Browsers. Also Adapter installieren hackt noch, deute ich daraus.
                        ok.
                        @Thomas-Braun
                        habe gerade mal den discovery Adapter manuell aktualisiert/installiert und hier klappt es alles 1a
                          @Thomas-Braun
                          @Thomas-Braun Moment ich glaube hier liegt jetzt ein Fehler durch den Bediener vor
                            benix02
                            @pete0815
                            Hey ho, muss das Thema mal "ausgraben" ;)
                            Habe nach einen harten restart das selbe verhalten, auf meiner iobroker instanz, inc. der gennanten Fehlermeldungen...
                            Da das ganze im Docker läuft, war ich der meinung Container neu anlegen, die Pfade auf dem Host mit geben und gut ist, so wie immer ;).
                            Jedoch zeigt mir der neue Container genau das selbe verhalten.
                            Keiner der Adapter wird angezogen (Bis auf den neuen Admin und die Info) und meine Objekte sind somit auch leer/wech.
                            Was war denn deine Lösung für das Problem? konntest du die quelldaten 1 zu 1 auf einer neuen Instanz nutzen?
                            Danke und Grüße
                            Benix
                            • B benix02
                              @pete0815
                              Danke und Grüße
                              Benix
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @benix02 sagte in IObroker zerlegt nach Stromausfall:
                              Zeige mal dein Log dazu !
                              • GlasfaserG Glasfaser
                                benix02
                                @Glasfaser
                                danke für die schnelle Rückmeldung.
                                Welches Log möchtest du denn sehen?
                                Mit "der gennanten Fehlermeldungen.." meinte ich die leere ausgaben auf list instances/adapter des ursprungs Container.
                                Nach dem händischen installieren der Admin Instanz komme ich wieder wie gewohnt auf das web interface. Jedoch sind die Instanzen bis auf admin und die info alle wech.
                                • B benix02
                                  @Glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @benix02
                                  Hast du es so ?
                                  https://forum.iobroker.net/topic/45934/gelöst-nach-stromausfall-startet-iobroker-nicht-mehr
                                    @benix02
                                    Hast du es so ?
                                    benix02
                                    @glasfaser
                                    Danke... Gleich mal als Favorit angelegt ;)
                                    Danke für den Link. Hat gleich auf Anhieb geklappt. Und nach dem Start kamen die Adapter nach und nach. Und die Objekte sind nun auch wieder voll zählig.
                                    Danke und dir einen schönen Sonntag abend.
