  4. SmartMeter Update auf 3.2.0
smartmeterinstalljs controller
11 Beiträge 2 Kommentatoren 717 Aufrufe 2 Beobachtet
  • M Online
    M Online
    MyMeyer
    Hallo, ich bekomme das Update für den Smartmeter auf 3.2.0 nicht hin nachdem ich das Update für JS Controller hatte. Der Smartmeter läuft auf dem Slave ! Hier ein Auszug von dem Update Versuch.
    pi@iobroker-slave:/opt/iobroker $ iobroker upgrade smartmeter
    This upgrade of "smartmeter" will at least introduce the following changes:
    -> 3.2.0:
    Add new protocolSmlInputEncoding option for SML protocol. With this also ascii or base64 based encodings (e.g. with TCP transports) are possible.
    -> 3.1.9:
    optimize stop handling (Sentry IOBROKER-SMARTMETER-10)
    -> 3.1.8:
    prevent last warnings with js-controller 3.2
    -> 3.1.7:
    prevent warnings with js-controller 3.2
    update js-controller dependency to at least require js-controller 2.0.0
    -> 3.1.6:
    update OpenSML lib to support Holley DTZ541 wrongly implemented CRC Algorithm
    -> 3.1.5:
    update dependencies to prevent some crash cases and optimize tcp mode
    -> 3.1.4:
    Would you like to upgrade smartmeter from @3.1.2 to @3.2.0 now? [(y)es, (n)o]: yes
    Update smartmeter from @3.1.2 to @3.2.0
    host.iobroker-slave Adapter "system.adapter.smartmeter.0" is stopped.
    NPM version: 6.14.11
    npm install iobroker.smartmeter@3.2.0 --loglevel error --prefix "/opt/iobroker" (System call)
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of 'ToParityEnum' [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of 'ToStopBitEnum' [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:56,
                     from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    /home/iobroker/.cache/node-gyp/12.20.2/include/node/node.h:737:43: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/12.20.2/include/node/node.h:771:3: note: in expansion of macro 'NODE_MODULE_X'
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/serialport.cpp:486:1: note: in expansion of macro 'NODE_MODULE'
     NODE_MODULE(serialport, init);
    ../src/serialport_unix.cpp: In function 'int setup(int, OpenBaton*)':
    ../src/serialport_unix.cpp:176:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: 'snprintf' output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function 'void EIO_Open(uv_work_t*)':
    ../src/serialport_unix.cpp:86:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: 'snprintf' output 22 or more bytes (assuming 1045) into a destination of size 1024
    │ Manual installation of ioBroker is no longer supported  │
    │ on Linux, OSX and FreeBSD!                              │
    │ Please refer to the documentation on how to install it! │
    │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
    npm ERR! code ELIFECYCLE
    npm ERR! errno 100
    npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`
    npm ERR! Exit status 100
    npm ERR!
    npm ERR! Failed at the iobroker@2.0.3 postinstall script.
    npm ERR!     /home/iobroker/.npm/_logs/2021-02-28T19_46_54_189Z-debug.log
    host.iobroker-slave Cannot install iobroker.smartmeter@3.2.0: 100
    Was kann ich tun ?
    MyMeyer
    >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
    >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
    • M MyMeyer
      -> 3.2.0:
      -> 3.1.9:
      -> 3.1.8:
      -> 3.1.7:
      -> 3.1.6:
      -> 3.1.5:
      -> 3.1.4:
      npm ERR! errno 100
      npm ERR!
      Was kann ich tun ?
      wendy2702W Online
      wendy2702W Online
      @mymeyer
      iobroker -v
      Wenn ich das richtig sehe ist das ein alter JS-Controller auf dem Slave.
      • wendy2702W wendy2702
        @mymeyer
        iobroker -v
        M Online
        M Online
        MyMeyer
        @wendy2702 Hmm,,Stimmt, aber ich hatte das Update auf dem Slave schon gemacht und wurde auch angezeigt unter Hosts.
        Okay. wie gehabt Iobroker auf slave stoppen, dann iobroker update und danach iobroker upgrade self und wieder neu starten den Iobroker. Richtig ?
        MyMeyer
        • M MyMeyer
          wendy2702W Online
          wendy2702W Online
          @mymeyer
          Welche Controller Version läuft denn auf dem Master?
          Upgrade Reihenfolge beachten:
          https://forum.iobroker.net/topic/42385/js-controller-3-2-jetzt-im-stable
            @mymeyer
            M Online
            M Online
            MyMeyer
            @wendy2702 Auf dem Master läuft V 3.2.16
            MyMeyer
            • M MyMeyer
              wendy2702W Online
              wendy2702W Online
              @mymeyer OK.
              Dann die von dir beschriebene Prozedur auf dem Slave ausführen.
                @mymeyer OK.
                M Online
                M Online
                MyMeyer
                @wendy2702 und da kommt dann das Problem.
                i@iobroker-slave:/opt/iobroker $ iobroker upgrade self
                Update js-controller from @3.1.6 to @3.2.16
                npm install iobroker.js-controller@3.2.16 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                npm ERR! errno 100
                npm ERR!
                npm ERR!     /home/iobroker/.npm/_logs/2021-02-28T20_23_51_992Z-debug.log
                host.iobroker-slave Cannot install iobroker.js-controller@3.2.16: 100
                Und nu ?
                MyMeyer
                • M MyMeyer
                  npm ERR! errno 100
                  npm ERR!
                  Und nu ?
                  wendy2702W Online
                  wendy2702W Online
                  @mymeyer
                  which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  uname -a
                    @mymeyer
                    uname -a
                    M Online
                    M Online
                    MyMeyer
                    @wendy2702
                    /usr/bin/nodejs
                    v12.20.2
                    /usr/bin/node
                    v12.20.2
                    /usr/bin/npm
                    6.14.11
                    nodejs:
                      Installed: 12.20.2-1nodesource1
                      Candidate: 12.20.2-1nodesource1
                      Version table:
                     *** 12.20.2-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                         10.23.1~dfsg-1~deb10u1 500
                    pi@iobroker-slave:/opt/iobroker $ uname -a
                    Linux iobroker-slave 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l GNU/Linux
                    MyMeyer
                    • M MyMeyer
                      @wendy2702
                      /usr/bin/nodejs
                      v12.20.2
                      /usr/bin/node
                      v12.20.2
                      /usr/bin/npm
                      6.14.11
                      nodejs:
                        Version table:
                      wendy2702W Online
                      wendy2702W Online
                      @mymeyer
                      ALS ERSTES NATÜRLICH EIN BACKUP MACHEN
                      Wann hast du das letzte mal
                      sudo apt update
                      sudo apt upgrade
                      gemacht? Wenn länger her erstmal updaten.
                      Dann
                      iobroker stop
                      iobroker fix
                      iobroker start
                      Danach erneut JS Controller update probieren.
                      Wenn es immer noch nicht geht
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.js-controller
                        @mymeyer
                        sudo apt update
                        sudo apt upgrade
                        Dann
                        iobroker stop
                        iobroker fix
                        iobroker start
                        cd /opt/iobroker
                        M Online
                        M Online
                        MyMeyer
                        schrieb am zuletzt editiert von MyMeyer
                        @wendy2702 Tja irgendwie will es nicht...
                        Puuhhh...jetzt läuft es nach einem Neustart und dann habe ich den Adapter Smartmeter deinstalliert und wieder neu installiert. JS ist auf 3.2.16 und Smartmeter auf 3.20. :-)
                        Danke Dir !
                        MyMeyer
