  4. Test Adaper Tado v0.1.x
tadoadaptertesting team
868 Beiträge 62 Kommentatoren 316.2k Aufrufe 59 Beobachtet
  • C canim
    ich kann es auch über die Katze nicht installieren =(..
    tado.0	2021-02-21 13:35:13.864	warn	(25413) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
    host.raspberrypi	2021-02-21 13:34:47.861	info	Updating repository "Beta (latest)" under "http://download.iobroker.net/sources-dist-latest.json"
    host.raspberrypi	2021-02-21 13:34:43.228	info	iobroker exit 0
    host.raspberrypi	2021-02-21 13:34:41.939	info	iobroker upload [0] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/admin.d.ts admin.d.ts video/mp2t
    host.raspberrypi	2021-02-21 13:34:41.691	info	iobroker upload [1] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/button.png button.png image/png
    host.raspberrypi	2021-02-21 13:34:41.297	info	iobroker upload [2] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/index_m.html index_m.html text/html
    host.raspberrypi	2021-02-21 13:34:41.231	info	iobroker upload [3] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/style.css style.css text/css
    host.raspberrypi	2021-02-21 13:34:40.979	info	iobroker upload [4] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tado.png tado.png image/png
    host.raspberrypi	2021-02-21 13:34:40.884	info	iobroker upload [5] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/words.js words.js application/javascript
    host.raspberrypi	2021-02-21 13:34:40.828	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-02-21T12_34_40_809Z-debug.log
    host.raspberrypi	2021-02-21 13:34:40.826	info	iobroker
    host.raspberrypi	2021-02-21 13:34:40.805	info	iobroker npm ERR! error: Pfadspezifikation 'v0.2.6-2.tar' stimmt mit keinen git-bekannten Dateien überein.npm ERR!
    host.raspberrypi	2021-02-21 13:34:40.804	info	iobroker npm ERR! Command failed: git checkout v0.2.6-2.tar
    host.raspberrypi	2021-02-21 13:34:40.792	info	iobroker npm ERR! code 1
    #757
    @canim Über Kommandozeile funktioniert es.
    C 1 Antwort Letzte Antwort
      canim
      #758
      @thomas-braun sorry wirklich zu doof :D, habs jetzt per zeile installieren können danke!
        MarkusMac
        #759
        Hi, ich hab seit einigen Wochen Probleme mit dem Tado-Adapter - sieht so aus, als würden einige Datenpunkte gelöscht. Nach einem Neustart des Adapters sind sie dann wieder da und alles läuft normal für ein paar Stunden.
        tado.0	2021-02-22 13:56:18.031	info	(2145) state tado.0.328596.Rooms.3.openWindow.durationInSeconds deleted
        tado.0	2021-02-22 13:56:17.935	info	(2145) state tado.0.328596.Rooms.3.setting.power deleted
        tado.0	2021-02-22 13:56:17.934	info	(2145) state tado.0.328596.Rooms.3.overlay.termination.typeSkillBasedApp deleted
        tado.0	2021-02-22 13:56:17.822	info	(2145) state tado.0.328596.Rooms.3.overlay.clearZoneOverlay deleted
        tado.0	2021-02-22 13:56:17.721	info	(2145) state tado.0.328596.Rooms.2.setting.power deleted
        tado.0	2021-02-22 13:56:17.721	info	(2145) state tado.0.328596.Rooms.2.openWindow.durationInSeconds deleted
        tado.0	2021-02-22 13:56:17.237	info	(2145) state tado.0.328596.Rooms.1.setting.power deleted
        tado.0	2021-02-22 13:56:17.217	info	(2145) state tado.0.328596.Rooms.4.overlay.clearZoneOverlay deleted
        tado.0	2021-02-22 13:56:17.127	info	(2145) state tado.0.328596.Rooms.2.overlay.clearZoneOverlay deleted
        tado.0	2021-02-22 13:56:17.115	info	(2145) state tado.0.328596.Rooms.2.overlay.termination.typeSkillBasedApp deleted
        tado.0	2021-02-22 13:56:17.020	info	(2145) state tado.0.328596.Rooms.1.overlay.termination.typeSkillBasedApp deleted
        tado.0	2021-02-22 13:56:16.911	info	(2145) state tado.0.328596.Rooms.1.openWindow.durationInSeconds deleted
        tado.0	2021-02-22 13:56:16.408	info	(2145) state tado.0.328596.Rooms.1.overlay.clearZoneOverlay deleted
        tado.0	2021-02-22 13:56:16.253	info	(2145) state tado.0.328596.Rooms.4.setting.power deleted
        tado.0	2021-02-22 13:56:16.252	info	(2145) state tado.0.328596.Rooms.4.overlay.termination.typeSkillBasedApp deleted
        Das passiert so zwischen 1-4 mal am Tag. Momentan behelfe ich mir, dass ich einen der gelöschten Werte alle 5 Minuten prüfe und, wenn er nicht mehr da ist, den Adapter neu starte. Aber das ist ja keine Dauerlösung. Hat jemand eine Idee, was der Grund für das Löschen der States sein könnte?
        Ich nutze die derzeit aktuelle Version des Tado-Adapters (0.2.5).
        H 1 Antwort Letzte Antwort
        • F Offline
          Fuxsism
          #760
          @Dutchman
          Leider habe ich auch seit Tagen Probleme mit dem Tado Adapter... das hier läuft bei mir einmal jede Minute durch das Log:
          tado.0	2021-02-27 09:33:57.646	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
          tado.0	2021-02-27 09:33:51.020	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
          tado.0	2021-02-27 09:33:44.416	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
          tado.0	2021-02-27 09:33:37.770	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
          tado.0	2021-02-27 09:33:31.274	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
          tado.0	2021-02-27 09:33:24.782	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
          tado.0	2021-02-27 09:33:18.030	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
          tado.0	2021-02-27 09:33:11.419	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
          tado.0	2021-02-27 09:33:05.075	warn	(7687) Send this info to developer !!! { Unhandable information found in DoHome : "quickActionsEnabled" with value : false
          Und ich hab auch den Eindruck das manche Steuerungen irgendwie nicht mehr funktionieren...
          Seit ihr da noch an dem Problem dran oder habt schon eine Lösung dafür???
          Thomas BraunT H 2 Antworten Letzte Antwort
          • F Fuxsism
            @Dutchman
            #761
            @fuxsism Vom tado wird die Tage vermutlich ein Update kommen. In einer Beta ist die Meldung bereits gefixt.
            F 1 Antwort Letzte Antwort
              Fuxsism
              #762
              @thomas-braun wo bekomm ich denn die Beta??
              • F Fuxsism
                @Dutchman
                HGlab
                #763
                @fuxsism
                Bzgl. warning: Die Änderung wartet auf den Merge des PRs (https://github.com/iobroker-community-adapters/ioBroker.tado/pull/117). Daher einstweilen nur über den Link https://github.com/HGlab01/ioBroker.tado/archive/v0.2.6-2.tar.gz
                Bzgl. "manche Steuerungen irgendwie nicht mehr funktionieren": kann ich nicht bestätigen und auf Basis dieser Fuzzy-Aussage auch ein wenig schwer einzuordnen
                • H HGlab
                  @fuxsism
                  Fuxsism
                  #764
                  @hglab
                  wie kann ich denn die 2.6.2 installieren????
                  • M MarkusMac
                    HGlab
                    #765
                    @markusmac said in Test Adaper Tado v0.1.x:
                    welches Refresh-Invervall ist eingestetllt?
                    Das Löschen eines States erfolgt eigentlich nur dann, wenn nach der 3- oder 5-fachen Refreshtime (weiß gerade nicht auswendig wann genau) der Wert NIE mehr von Tado geliefert wurde. setting.power wird aber von der Tado-API immer geliefert daher ist es bei dir ein Verhalten dass es eigentlich nicht geben dürfte....
                    • F Fuxsism
                      @hglab
                      HGlab
                      schrieb am zuletzt editiert von HGlab
                      #766
                      @fuxsism said in Test Adaper Tado v0.1.x:
                      @hglab
                      Das steht in den letzten 5 Posts direkt über deinem Post; hier
                      https://forum.iobroker.net/topic/25723/test-adaper-tado-v0-1-x/753
                      beginnend
                      F 2 Antworten Letzte Antwort
                      • H HGlab
                        @hglab
                        beginnend
                        Fuxsism
                        #767
                        @hglab krass unglaublich... es scheint echt geklappt zu haben und es werden nicht mehr ständig warn Meldungen ausgegeben... sehr geil!!!!
                        Danke dir für die Hilfe!!!!!
                        • H HGlab
                          @hglab
                          beginnend
                          Fuxsism
                          #768
                          @hglab
                          jetzt kommt allerdings dieser Blog:
                          tado.0	2021-02-27 10:21:56.945	info	(12560) state tado.0.575448.Rooms.3.openWindow.durationInSeconds deleted
                          tado.0	2021-02-27 10:21:56.919	info	(12560) state tado.0.575448.Rooms.3.overlay.termination.typeSkillBasedApp deleted
                          tado.0	2021-02-27 10:21:56.893	info	(12560) state tado.0.575448.Rooms.3.overlay.clearZoneOverlay deleted
                          tado.0	2021-02-27 10:21:56.878	info	(12560) state tado.0.575448.Rooms.3.setting.power deleted
                          tado.0	2021-02-27 10:21:56.025	info	(12560) state tado.0.575448.Rooms.2.openWindow.durationInSeconds deleted
                          tado.0	2021-02-27 10:21:56.006	info	(12560) state tado.0.575448.Rooms.2.overlay.termination.typeSkillBasedApp deleted
                          tado.0	2021-02-27 10:21:55.940	info	(12560) state tado.0.575448.Rooms.2.overlay.clearZoneOverlay deleted
                          tado.0	2021-02-27 10:21:55.931	info	(12560) state tado.0.575448.Rooms.2.setting.power deleted
                          tado.0	2021-02-27 10:21:55.112	info	(12560) state tado.0.575448.Rooms.1.openWindow.durationInSeconds deleted
                          tado.0	2021-02-27 10:21:55.087	info	(12560) state tado.0.575448.Rooms.1.overlay.termination.typeSkillBasedApp deleted
                          tado.0	2021-02-27 10:21:55.056	info	(12560) state tado.0.575448.Rooms.1.overlay.clearZoneOverlay deleted
                          tado.0	2021-02-27 10:21:55.050	info	(12560) state tado.0.575448.Rooms.1.setting.power deleted
                          Is das okay so??
                          • F Fuxsism
                            @hglab
                            Is das okay so??
                            HGlab
                            #769
                            @hglab
                            Is das okay so??
                            nein, sollte eigentlich nicht.
                            Du kannst aber gerne mal den Adapter im debug-modus starten und auf Github ein Issue mit dem Log anlegen. Dann sehe ich mir das mal an.
                            Offensichtlich hast du und @MarkusMac das selbe bzw. ähnliche Problem.
                            Ich kann es bei meinen zwei Installationen nicht nachvollziehen aber vielleicht rollt Tado gerade einen API-Change in Wellen aus. Leider sind die Tado-APIs im Sinne breaking changes alles andere als stabil.
                            • H HGlab
                              @hglab
                              Is das okay so??
                              Fuxsism
                              #770
                              @hglab hmmm kann es denn wirklich etwas mit der Polling Zeit zu tun haben???
                              Ich hatte die bei mir auf 2 Sekunden stehen... hab sie jetzt hoch gestellt auf 5 und da scheint es zu laufen???
                              • F Fuxsism
                                HGlab
                                #771
                                @fuxsism
                                ja, 2 Sekunden wird sicher nicht funktonieren. Da wird dir die Tado-API ein DDoS (denial of service) unterstellen und dich blockieren.
                                Alles was unter 30 Sekunden ist würde ich tunlichst vermeiden!
                                Ich denke das sollten wir im Adapter in Zukunft abfedern damit nichts unter 30 Sekunden akzeptiert wird
                                F C 2 Antworten Letzte Antwort
                                • H HGlab
                                  @fuxsism
                                  Fuxsism
                                  #772
                                  @hglab okay... also du meinst ich soll es sogar lieber auf 30 hoch stellen???
                                  H Thomas BraunT 2 Antworten Letzte Antwort
                                  • F Fuxsism
                                    HGlab
                                    #773
                                    jep. Wüsste auch nicht wozu du einen Sync im wenigen Sekunden Takt brauchen kannst. Bei mir sind 60 Sekunden eingestellt und das reicht völlig.
                                    Ich lauf halt auch nicht vom Thermostat (wenn ich dort was umgestellt habe) zum iobroker und schau ob er eh auch schon ein Update hat ;-)
                                    • H HGlab
                                      Fuxsism
                                      #774
                                      @hglab du hast ja recht... ich werde schauen ob es so noch irgendwelche Probleme gibt...
                                      • F Fuxsism
                                        #775
                                        @fuxsism
                                        Betreibst du eine offene Feuerstelle mit dem tado?
                                        Heizungen sind doch allgemein eh träge Systeme, da braucht es auch keine sekündliche Abfrage der Stati. Alle 60 Sekunden sollte dicke ausreichen.
                                        • H HGlab
                                          @fuxsism
                                          cortana
                                          #776
                                          @hglab
                                          Ich persönlich würde eine 60 Sekunden Sperre nicht begrüßen.
                                          Ihr dürft nicht vergessen, dass wir die Geodaten zur lokalisierung verwenden.
                                          Bei mir läuft das polling alle 10 Sekunden.
                                          Bei mir ist hier z.B. meine Wegbeleuchtung damit gekoppelt. Wenn ich jetzt noch eine Verzögerung drinnen habe wird es albern
