  4. Plötzliche adapter fehler
    6.6k
34 Beiträge 2 Kommentatoren 2.1k Aufrufe 2 Beobachtet
  • B Billy 0
    @billy-0
    Adapter "foobar2000"     is not installed.
    Adapter "fritzbox"       is not installed.
    Adapter "fritzdect"      is up to date.
    Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
        at parse (<anonymous>)
        at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)
        at Module.load (internal/modules/cjs/loader.js:863:32)
        at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        at Module.require (internal/modules/cjs/loader.js:887:19)
        at require (internal/modules/cjs/helpers.js:74:18)
        at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:279:27)
        at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:68:14)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:75:41)
        at processImmediate (internal/timers.js:461:21)
    pi@raspberrypi:~ $
    dasselbe...
    @billy-0
    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      @billy-0
      Billy 0
      pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      /usr/bin/nodejs
      v12.20.1
      /usr/bin/node
      v12.20.1
      /usr/bin/npm
      7.5.4
      nodejs:
        Installed: 12.20.1-1nodesource1
        Candidate: 12.20.2-1nodesource1
        Version table:
           12.20.2-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
       *** 12.20.1-1nodesource1 100
           10.23.1~dfsg-1~deb10u1 500
      pi@raspberrypi:~ $
      npm hab ich eben ausversehen update gemacht
      • B Billy 0
        /usr/bin/nodejs
        v12.20.1
        /usr/bin/node
        v12.20.1
        /usr/bin/npm
        7.5.4
        nodejs:
          Version table:
        pi@raspberrypi:~ $
        @billy-0 sagte in Plötzliche adapter fehler:
        Das solltest du wieder rückgängig machen. npm@7 passt nicht zum ioBroker.
        sudo apt update
        sudo apt upgrade
          sudo apt update
          sudo apt upgrade
          Billy 0
          @thomas-braun Ok ist durchgelaufen
          /usr/bin/nodejs
          v12.20.2
          /usr/bin/node
          v12.20.2
          /usr/bin/npm
          6.14.11
          nodejs:
            Installed: 12.20.2-1nodesource1
            Version table:
           *** 12.20.2-1nodesource1 500
          pi@raspberrypi:~ $
          • B Billy 0
            /usr/bin/nodejs
            v12.20.2
            /usr/bin/node
            v12.20.2
            /usr/bin/npm
            6.14.11
            nodejs:
              Version table:
            pi@raspberrypi:~ $
            Billy 0
            @billy-0 log vom broker
            host.raspberrypi-Server	2021-02-21 12:49:06.918	error	Cannot parse /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: Unexpected token b in JSON at position 2195
            • B Billy 0
              Billy 0
              @billy-0 beim upgrade self bleibts beim fehler
              Thomas BraunT B 2 Antworten Letzte Antwort
              • B Billy 0
                @billy-0
                Lösch den Adapter mal und installier den danach neu.
                • B Billy 0
                  Billy 0
                  Hmm, habe gerade festgestellt das mir die betreffenden Adapter gar nicht mehr in der Adapter ansicht vom iobroker angezeigt werden. Sind nur in der Instanzen ansicht sichtbar... Hilft uns das weiter?
                    @billy-0
                    Billy 0
                    @thomas-braun finde nix zum neu installieren!?
                    • B Billy 0
                      @billy-0
                      iobroker del iobroker.fronius
                      iobroker restart
                      iobroker add iobroker.fronius
                        @billy-0
                        iobroker restart
                        Billy 0
                        pi@raspberrypi:~ $ iobroker del iobroker.fronius
                        Delete adapter "fronius"
                        host.raspberrypi Counted 1 instances of fronius
                        host.raspberrypi Counted 1 meta of fronius
                        host.raspberrypi Counted 1 adapter for fronius
                        host.raspberrypi Counted 4 channels of fronius
                        host.raspberrypi Counted 27 states of fronius
                        host.raspberrypi Counted 14 states of system.adapter.fronius
                        host.raspberrypi Counted 27 states (io.fronius.*) from states
                        host.raspberrypi Counted 14 states (system.adapter.fronius.*) from states
                        host.raspberrypi file fronius.admin deleted
                        host.raspberrypi object fronius deleted
                        host.raspberrypi object fronius.admin deleted
                        host.raspberrypi Deleting 48 object(s).
                        host.raspberrypi Deleting 41 state(s).
                        Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                        You might have to delete it yourself!
                        pi@raspberrypi:~ $ iobroker restart
                        pi@raspberrypi:~ $ iobroker add iobroker.fronius
                        host.raspberrypi install adapter fronius
                        host.raspberrypi error: reading io-package.json SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                        Uncaught Rejection: TypeError: Cannot read property 'common' of undefined
                            at Install.installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:728:25)
                            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:842:29)
                            at processImmediate (internal/timers.js:463:21)
                        pi@raspberrypi:~ $
                        • B Billy 0
                          pi@raspberrypi:~ $
                          Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931 You might have to delete it yourself!
                          Dann mach das mal.
                            Dann mach das mal.
                            Billy 0
                            Im broker werden mir gar keine adapter mehr zum installieren angezeigt.
                            Keine ahnung wie ich das lösche, sorry
                            • B Billy 0
                              @billy-0
                              iobroker stop
                              iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                              iobroker restart
                              • B Billy 0
                                Billy 0
                                Halt kommando zurück, adapter werden angezeigt, aber installieren kommt derselbe fehler
                                  @billy-0
                                  iobroker stop
                                  iobroker restart
                                  Billy 0
                                  pi@raspberrypi:~ $ iobroker stop
                                  pi@raspberrypi:~ $ iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                                  Error: Not exists
                                      at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2252:17)
                                      at ObjectsInMemoryServerClass._rm (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1391:30)
                                      at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                  pi@raspberrypi:~ $
                                  • B Billy 0
                                    Error: Not exists
                                    pi@raspberrypi:~ $
                                    Dann
                                    sudo -u iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                                    • B Billy 0
                                      Error: Not exists
                                      pi@raspberrypi:~ $
                                      Billy 0
                                      pi@raspberrypi:~
                                      • B Billy 0
                                        pi@raspberrypi:~
                                        Billy 0
                                        Ok es installiert
                                          Dann
                                          Billy 0
                                          @thomas-braun danke dir, das hat geholfen.
                                          Kannst du mir sagen wie sowas passieren kann oder wie ich abhilfe schaffe?
