  4. Plötzliche adapter fehler
    6.6k
34 Beiträge 2 Kommentatoren 2.1k Aufrufe 2 Beobachtet
  • B Billy 0
    Adapter "fritzbox"       is not installed.
    Adapter "fritzdect"      is up to date.
    (node:12578) UnhandledPromiseRejectionWarning: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
        at parse (<anonymous>)
        at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)
        at Module.load (internal/modules/cjs/loader.js:863:32)
        at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        at Module.require (internal/modules/cjs/loader.js:887:19)
        at require (internal/modules/cjs/helpers.js:74:18)
        at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:237:27)
        at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:50:14)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:57:41)
        at processImmediate (internal/timers.js:461:21)
    (node:12578) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
    (node:12578) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    scheinabgebrochen zu haben
    Billy 0
    @billy-0
    Adapter "foobar2000"     is not installed.
    Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
        at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:279:27)
        at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:68:14)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:75:41)
    pi@raspberrypi:~ $
    dasselbe...
    • B Billy 0
      @billy-0
      pi@raspberrypi:~ $
      dasselbe...
      @billy-0
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        @billy-0
        Billy 0
        pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        /usr/bin/nodejs
        v12.20.1
        /usr/bin/node
        v12.20.1
        /usr/bin/npm
        7.5.4
        nodejs:
          Installed: 12.20.1-1nodesource1
          Candidate: 12.20.2-1nodesource1
          Version table:
             12.20.2-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         *** 12.20.1-1nodesource1 100
             10.23.1~dfsg-1~deb10u1 500
        pi@raspberrypi:~ $
        npm hab ich eben ausversehen update gemacht
        • B Billy 0
          /usr/bin/nodejs
          v12.20.1
          /usr/bin/node
          v12.20.1
          /usr/bin/npm
          7.5.4
          nodejs:
            Version table:
          pi@raspberrypi:~ $
          @billy-0 sagte in Plötzliche adapter fehler:
          Das solltest du wieder rückgängig machen. npm@7 passt nicht zum ioBroker.
          sudo apt update
          sudo apt upgrade
            sudo apt update
            sudo apt upgrade
            Billy 0
            @thomas-braun Ok ist durchgelaufen
            /usr/bin/nodejs
            v12.20.2
            /usr/bin/node
            v12.20.2
            /usr/bin/npm
            6.14.11
            nodejs:
              Installed: 12.20.2-1nodesource1
              Version table:
             *** 12.20.2-1nodesource1 500
            pi@raspberrypi:~ $
            • B Billy 0
              /usr/bin/nodejs
              v12.20.2
              /usr/bin/node
              v12.20.2
              /usr/bin/npm
              6.14.11
              nodejs:
                Version table:
              pi@raspberrypi:~ $
              Billy 0
              @billy-0 log vom broker
              host.raspberrypi-Server	2021-02-21 12:49:06.918	error	Cannot parse /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: Unexpected token b in JSON at position 2195
              • B Billy 0
                Billy 0
                @billy-0 beim upgrade self bleibts beim fehler
                Thomas BraunT B 2 Antworten Letzte Antwort
                • B Billy 0
                  @billy-0
                  Lösch den Adapter mal und installier den danach neu.
                  • B Billy 0
                    Billy 0
                    Hmm, habe gerade festgestellt das mir die betreffenden Adapter gar nicht mehr in der Adapter ansicht vom iobroker angezeigt werden. Sind nur in der Instanzen ansicht sichtbar... Hilft uns das weiter?
                      @billy-0
                      Billy 0
                      @thomas-braun finde nix zum neu installieren!?
                      • B Billy 0
                        @billy-0
                        iobroker del iobroker.fronius
                        iobroker restart
                        iobroker add iobroker.fronius
                          @billy-0
                          iobroker restart
                          Billy 0
                          pi@raspberrypi:~ $ iobroker del iobroker.fronius
                          Delete adapter "fronius"
                          host.raspberrypi Counted 1 instances of fronius
                          host.raspberrypi Counted 1 meta of fronius
                          host.raspberrypi Counted 1 adapter for fronius
                          host.raspberrypi Counted 4 channels of fronius
                          host.raspberrypi Counted 27 states of fronius
                          host.raspberrypi Counted 14 states of system.adapter.fronius
                          host.raspberrypi Counted 27 states (io.fronius.*) from states
                          host.raspberrypi Counted 14 states (system.adapter.fronius.*) from states
                          host.raspberrypi file fronius.admin deleted
                          host.raspberrypi object fronius deleted
                          host.raspberrypi object fronius.admin deleted
                          host.raspberrypi Deleting 48 object(s).
                          host.raspberrypi Deleting 41 state(s).
                          Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                          You might have to delete it yourself!
                          pi@raspberrypi:~ $ iobroker restart
                          pi@raspberrypi:~ $ iobroker add iobroker.fronius
                          host.raspberrypi install adapter fronius
                          host.raspberrypi error: reading io-package.json SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                          Uncaught Rejection: TypeError: Cannot read property 'common' of undefined
                              at Install.installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:728:25)
                              at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:842:29)
                              at processImmediate (internal/timers.js:463:21)
                          pi@raspberrypi:~ $
                          • B Billy 0
                            pi@raspberrypi:~ $
                            Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931 You might have to delete it yourself!
                            Dann mach das mal.
                              Dann mach das mal.
                              Billy 0
                              Im broker werden mir gar keine adapter mehr zum installieren angezeigt.
                              Keine ahnung wie ich das lösche, sorry
                              • B Billy 0
                                @billy-0
                                iobroker stop
                                iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                                iobroker restart
                                • B Billy 0
                                  Billy 0
                                  Halt kommando zurück, adapter werden angezeigt, aber installieren kommt derselbe fehler
                                    @billy-0
                                    iobroker stop
                                    iobroker restart
                                    Billy 0
                                    pi@raspberrypi:~ $ iobroker stop
                                    pi@raspberrypi:~ $ iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                                    Error: Not exists
                                        at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2252:17)
                                        at ObjectsInMemoryServerClass._rm (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1391:30)
                                        at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                    pi@raspberrypi:~ $
                                    • B Billy 0
                                      Error: Not exists
                                      pi@raspberrypi:~ $
                                      Dann
                                      sudo -u iobroker rm /opt/iobroker/node_modules/iobroker.fronius/io-package.json
                                      • B Billy 0
                                        Error: Not exists
                                        pi@raspberrypi:~ $
                                        Billy 0
                                        pi@raspberrypi:~
                                        • B Billy 0
                                          pi@raspberrypi:~
                                          Billy 0
                                          Ok es installiert
