  4. Plötzliche adapter fehler
    6.6k
34 Beiträge 2 Kommentatoren 2.1k Aufrufe 2 Beobachtet
    @billy-0
    Okay, das ist sauber.
    iobroker -v
    iobroker status
    iobroker update
    iobroker upgrade
    Billy 0
    pi@raspberrypi:~ $ iobroker -v
    3.1.6
    pi@raspberrypi:~ $ iobroker status
    At least one iobroker host is running.
    Objects type: file
    States  type: file
    • B Billy 0
      3.1.6
      Objects type: file
      States  type: file
      @billy-0
      iobroker stop
      iobroker update
      iobroker upgrade self
      iobroker upgrade
      iobroker start
      • B Billy 0
        3.1.6
        Objects type: file
        States  type: file
        @billy-0
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          @billy-0
          iobroker stop
          iobroker update
          iobroker upgrade
          iobroker start
          Billy 0
          zu spät, update läuft schon ohne iobroker stop
          • B Billy 0
            @billy-0
            Das macht nix.
            Nur das
            erfordert zuvor den Stop des Servers.
              @billy-0
              Das macht nix.
              Nur das
              Billy 0
              Adapter "fritzbox"       is not installed.
              Adapter "fritzdect"      is up to date.
              (node:12578) UnhandledPromiseRejectionWarning: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                  at parse (<anonymous>)
                  at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)
                  at Module.load (internal/modules/cjs/loader.js:863:32)
                  at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                  at Module.require (internal/modules/cjs/loader.js:887:19)
                  at require (internal/modules/cjs/helpers.js:74:18)
                  at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:237:27)
                  at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:50:14)
                  at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:57:41)
                  at processImmediate (internal/timers.js:461:21)
              (node:12578) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
              (node:12578) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
              scheinabgebrochen zu haben
              • B Billy 0
                Billy 0
                @billy-0
                Adapter "foobar2000"     is not installed.
                Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                    at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:279:27)
                    at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:68:14)
                    at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:75:41)
                pi@raspberrypi:~ $
                dasselbe...
                • B Billy 0
                  @billy-0
                  pi@raspberrypi:~ $
                  dasselbe...
                  @billy-0
                    @billy-0
                    Billy 0
                    pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    v12.20.1
                    /usr/bin/node
                    v12.20.1
                    /usr/bin/npm
                    7.5.4
                    nodejs:
                      Installed: 12.20.1-1nodesource1
                      Candidate: 12.20.2-1nodesource1
                      Version table:
                         12.20.2-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                     *** 12.20.1-1nodesource1 100
                         10.23.1~dfsg-1~deb10u1 500
                    pi@raspberrypi:~ $
                    npm hab ich eben ausversehen update gemacht
                    • B Billy 0
                      /usr/bin/nodejs
                      v12.20.1
                      /usr/bin/node
                      v12.20.1
                      /usr/bin/npm
                      7.5.4
                      nodejs:
                        Version table:
                      pi@raspberrypi:~ $
                      @billy-0 sagte in Plötzliche adapter fehler:
                      Das solltest du wieder rückgängig machen. npm@7 passt nicht zum ioBroker.
                      sudo apt update
                      sudo apt upgrade
                        sudo apt update
                        sudo apt upgrade
                        Billy 0
                        @thomas-braun Ok ist durchgelaufen
                        /usr/bin/nodejs
                        v12.20.2
                        /usr/bin/node
                        v12.20.2
                        /usr/bin/npm
                        6.14.11
                        nodejs:
                          Installed: 12.20.2-1nodesource1
                          Version table:
                         *** 12.20.2-1nodesource1 500
                        pi@raspberrypi:~ $
                        • B Billy 0
                          /usr/bin/nodejs
                          v12.20.2
                          /usr/bin/node
                          v12.20.2
                          /usr/bin/npm
                          6.14.11
                          nodejs:
                            Version table:
                          pi@raspberrypi:~ $
                          Billy 0
                          @billy-0 log vom broker
                          host.raspberrypi-Server	2021-02-21 12:49:06.918	error	Cannot parse /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: Unexpected token b in JSON at position 2195
                          • B Billy 0
                            Billy 0
                            @billy-0 beim upgrade self bleibts beim fehler
                            Thomas BraunT B 2 Antworten Letzte Antwort
                            • B Billy 0
                              @billy-0
                              Lösch den Adapter mal und installier den danach neu.
                              • B Billy 0
                                Billy 0
                                Hmm, habe gerade festgestellt das mir die betreffenden Adapter gar nicht mehr in der Adapter ansicht vom iobroker angezeigt werden. Sind nur in der Instanzen ansicht sichtbar... Hilft uns das weiter?
                                  @billy-0
                                  Billy 0
                                  @thomas-braun finde nix zum neu installieren!?
                                  • B Billy 0
                                    @billy-0
                                    iobroker del iobroker.fronius
                                    iobroker restart
                                    iobroker add iobroker.fronius
                                      @billy-0
                                      iobroker restart
                                      Billy 0
                                      pi@raspberrypi:~ $ iobroker del iobroker.fronius
                                      Delete adapter "fronius"
                                      host.raspberrypi Counted 1 instances of fronius
                                      host.raspberrypi Counted 1 meta of fronius
                                      host.raspberrypi Counted 1 adapter for fronius
                                      host.raspberrypi Counted 4 channels of fronius
                                      host.raspberrypi Counted 27 states of fronius
                                      host.raspberrypi Counted 14 states of system.adapter.fronius
                                      host.raspberrypi Counted 27 states (io.fronius.*) from states
                                      host.raspberrypi Counted 14 states (system.adapter.fronius.*) from states
                                      host.raspberrypi file fronius.admin deleted
                                      host.raspberrypi object fronius deleted
                                      host.raspberrypi object fronius.admin deleted
                                      host.raspberrypi Deleting 48 object(s).
                                      host.raspberrypi Deleting 41 state(s).
                                      Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                                      You might have to delete it yourself!
                                      pi@raspberrypi:~ $ iobroker restart
                                      pi@raspberrypi:~ $ iobroker add iobroker.fronius
                                      host.raspberrypi install adapter fronius
                                      host.raspberrypi error: reading io-package.json SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                                      Uncaught Rejection: TypeError: Cannot read property 'common' of undefined
                                          at Install.installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:728:25)
                                          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:842:29)
                                          at processImmediate (internal/timers.js:463:21)
                                      pi@raspberrypi:~ $
                                      • B Billy 0
                                        pi@raspberrypi:~ $
                                        Error deleting adapter fronius from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931 You might have to delete it yourself!
                                        Dann mach das mal.
                                          Dann mach das mal.
                                          Billy 0
                                          Im broker werden mir gar keine adapter mehr zum installieren angezeigt.
                                          Keine ahnung wie ich das lösche, sorry
