  4. dyson Air purifier Adapter - Tester gesucht
dyson hot pure cool humidifyer
247 Beiträge 33 Kommentatoren 64.5k Aufrufe 30 Beobachtet
  • C cactus-online
    ich habe meinem ioBroker mal ein zweites Interface im Gast-Netz gegönnt. Er findet den Ventilator und liest auch jede Menge aus. Ein paar Fehler werden noch gelogged:
    dysonairpurifier.0	2020-11-30 19:02:58.267	info	(4935) Skipped creating unknown datafield for: [time] Value: |-> 2020-11-30T18:03:11.001Z
    dysonairpurifier.0	2020-11-30 19:02:58.267	info	(4935) Skipped creating unknown datafield for: [msg] Value: |-> ENVIRONMENTAL-CURRENT-SENSOR-DATA
    dysonairpurifier.0	2020-11-30 19:02:58.173	info	(4935) Skipped creating unknown datafield for: [scheduler] Value: |-> {"srsc":"f57d","dstv":"0001","tzid":"0001"}
    dysonairpurifier.0	2020-11-30 19:02:58.172	info	(4935) Skipped creating unknown datafield for: [dial] Value: |-> OFF
    dysonairpurifier.0	2020-11-30 19:02:58.171	info	(4935) Skipped creating unknown datafield for: [state-reason] Value: |-> MODE
    dysonairpurifier.0	2020-11-30 19:02:58.171	info	(4935) Skipped creating unknown datafield for: [mode-reason] Value: |-> ALXA
    dysonairpurifier.0	2020-11-30 19:02:58.170	info	(4935) Skipped creating unknown datafield for: [time] Value: |-> 2020-11-30T18:03:11.000Z
    dysonairpurifier.0	2020-11-30 19:02:58.169	info	(4935) Skipped creating unknown datafield for: [msg] Value: |-> CURRENT-STATE
    dysonairpurifier.0	2020-11-30 19:02:28.267	info	(4935) Skipped creating unknown datafield for: [time] Value: |-> 2020-11-30T18:02:41.001Z
    dysonairpurifier.0	2020-11-30 19:02:28.267	info	(4935) Skipped creating unknown datafield for: [msg] Value: |-> ENVIRONMENTAL-CURRENT-SENSOR-DATA
    dysonairpurifier.0	2020-11-30 19:02:28.174	info	(4935) Skipped creating unknown datafield for: [scheduler] Value: |-> {"srsc":"f57d","dstv":"0001","tzid":"0001"}
    dysonairpurifier.0	2020-11-30 19:02:28.172	info	(4935) Skipped creating unknown datafield for: [dial] Value: |-> OFF
    dysonairpurifier.0	2020-11-30 19:02:28.171	info	(4935) Skipped creating unknown datafield for: [state-reason] Value: |-> MODE
    dysonairpurifier.0	2020-11-30 19:02:28.171	info	(4935) Skipped creating unknown datafield for: [mode-reason] Value: |-> ALXA
    dysonairpurifier.0	2020-11-30 19:02:28.170	info	(4935) Skipped creating unknown datafield for: [time] Value: |-> 2020-11-30T18:02:41.000Z
    dysonairpurifier.0	2020-11-30 19:02:28.169	info	(4935) Skipped creating unknown datafield for: [msg] Value: |-> CURRENT-STATE
    Falls es für irgendwas hilfreich ist.
    Herzlichen Dank für die bisher geleistete Arbeit !!!
    GrizzelbeeG Offline
    GrizzelbeeG Offline
    Grizzelbee
    schrieb am zuletzt editiert von Grizzelbee
    @cactus-online
    Willkommen bei den anonymen dyson-besitzern! ;)
    Und danke für die Infos. Das sind allerdings keine Fehler, sondern Datenfelder, die die dyson-Geräte zwar munter melden, aber keine Infos darüber gibt, was sie bedeuten. Deshalb logge ich sie raus, damit vielleicht irgendwann mal gemand einen Geistesblitz hat, erkennt was die bedeuten und es dann sogar noch hier erzählt.
    Okay - zugegeben - das ist nur ein Teil der Wahrheit. Der andere Teil der Wahrheit ist, das bei state-reason, mode-reason und anderen schon prinzipiell klar ist, was sie bdeuteten, aber sie sind (zumindest in meinen Augen) für den Device-Tree nicht interessant und deshalb nicht implementiert. Wer da anderer Meinung ist: Gerne melden!
    Ich werde irgendwann das logging auch noch etwas ausdünnen.
    viele Grüße
    grizzelbee
    Btw: Hat hier eigentlich jemand mehr als ein Gerät?
    Gianfranco SinistraG 1 Antwort Letzte Antwort
    • GrizzelbeeG Grizzelbee
      @cactus-online
      viele Grüße
      grizzelbee
      Gianfranco SinistraG Offline
      Gianfranco Sinistra
      @Grizzelbee Hi, konntest du mit meinen Loggs, bzgl. dem Humity (Tank leer) was anfangen?
      GrizzelbeeG 1 Antwort Letzte Antwort
      • Gianfranco SinistraG Gianfranco Sinistra
        GrizzelbeeG Offline
        GrizzelbeeG Offline
        Grizzelbee
        @Gianfranco-Sinistra
        Leider noch nicht. :(
        Ich habe in den letzten Wochen genau gar keine Zeit zum programmieren gefunden. Es sind auch noch ein paar zusätzliche Themen durch den Review für die Aufnahme in den Latest-Zweig aufgekommen.
        Ich muss das erst einmal abarbeiten und dann kommen neue Dinge dran. Tut mir leid.
        Aber es ist weiterhin absolut geplant alle diese Dinge mit in den Adapter aufzunehmen.
        Alles nur eine Frage der Zeit.
        viele Grüße
        grizzelbee
          viele Grüße
          grizzelbee
          GrizzelbeeG Offline
          GrizzelbeeG Offline
          Grizzelbee
          Moin Leute,
          die neue Versionn ist endlich online - ich hoffe damit auch in das Latest-Repo Einzug zu erhalten:
          Changelog: 0.7.0 (2021-01-08) (Afraid of the dark)
          (jpwenzel) New: Removing crypto from package dependency list (using Node.js provided version)
          (jpwenzel) New: Introducing unit tests
          (jpwenzel) Fix: General overhaul of readme
          (jpwenzel) Fix: Code refactoring
          (jpwenzel) New: At least NodeJs 10.0.0 is required
          (grizzelbee) Fix: fixed some datafield names - please delete the whole device folder and get them newly created.
          (grizzelbee) Fix: #18 - Fixed creating the indexes when there is no according sensor
          (grizzelbee) Fix: #13 - Displaying Filter life value in hours again
          (grizzelbee) Fix: #13 - Creating additional Filter life value in percent
          (grizzelbee) New: #23 - Introduced new data field AirQuality which represents the worst value of all present indexes.
          (grizzelbee) Fix: removed materializeTab from ioPackage
          (grizzelbee) Fix: calling setState now as callback in createOrExtendObject
          (grizzelbee) New: BREAKING CHANGE! - switched over to the adapter-prototype build-in password encryption. Therefore you'll need to enter your password again in config.
          (grizzelbee) New: At least js-controller 3.0.0 is required
          (grizzelbee) New: At least admin 4.0.9 is required
          (grizzelbee) Fix: Removed non compliant values for ROLE
          (grizzelbee) Fix: calling setState in callback of set/createObject now
          (grizzelbee) Fix: ensuring to clear all timeouts in onUnload-function
          Infos dazu -- wie immer: Gerne! :)
            Moin Leute,
            Kludi
            @Grizzelbee
            Hallo Grizzelbee,
            Ich habe die neue Version ohne Probleme Installiert.
            Ist das Aktuell noch Absicht dass noch nicht alle Steuerungen gehen?
            Ich kann noch nicht: Current fan speed und Current Fan state Steuern.
            Alle andren Sachen wie Oscillation, Nightmode und Continuous Monitoring kann ich steuern.
            Bei mir ist FilterLife Doppelt und bei beiden, wenn man mit der Maus auf wert Geht seht hours.
            Müsste da nicht vielleicht ein % rein?
            viele Grüße
            Kludi
            • K Kludi
              @Grizzelbee
              Hallo Grizzelbee,
              viele Grüße
              Kludi
              GrizzelbeeG Offline
              GrizzelbeeG Offline
              Grizzelbee
              Hi @Kludi,
              danke für dein Feedback!
              Ich habe gerade das unbestimmte Gefühl, dass ich über die lange Zeit und die zum Teil doch immmensen Umbauten das eine oder andere aus den Augen verloren habe. Der FanSpeed sollte jedenfalls funktionieren - aber: Nein - es solten noch nicht alle Steuerungen funktionieren.
              Beim FilterLife, sollte es eigentlich einen Datenpunkt in Prozent geben und einen in Stunden - da mein dyson das aber nicht hat programmiere ich da blind - also danke für den Hinweis, da mich ich noch mal bei.
              Also sammeln wir mal alle (neuen und alten) Fehler ein, fixen die und dann implementiere ich neue Sachen. Alles schön der Reihe nach.
              Ich wäre dankbar, wenn ihr mir für jedes Problem einen Issue auf Githib öffnen würdet ( https://github.com/Grizzelbee/ioBroker.dysonairpurifier/issues ) damit ich den Überblick behalte und die Punkte abarbeiten kann. Ein schneller Blich ob es den Issue (oder etwas verwandtes) schon gibt, schadet natürlich nicht. ;)
              viele Grüße
              Grizzelbee
                Hi @Kludi,
                viele Grüße
                Grizzelbee
                GrizzelbeeG Offline
                GrizzelbeeG Offline
                Grizzelbee
                Hey Zusammen,
                ich habe gerade eine neue Version online gestellt.
                es hat sich wieder mal eine Menge über und unter der Haube getan. Deshalb möchte ich euch bitten gründlich zu testen und auch ein mal einen Blick ins ReadMe und ins ChangeLog zu werfen. Dort versuche ich den jeweils aktuellen Entwicklungsstand festzuhalten.
                Bitte öffnet für alles was ihr findet - seien es Fehler, Fragen oder Wünsche einen aussagekräftigen Issue auf Github. Also mit verwendeter Version, ggf. Log-Auszug, betroffenes Modell, usw. ... Das würde mir wirklich sehr helfen den Überblick zu behalten was noch zu tun ist.
                Die Gute Nachricht für Besitzer eines Heaters oder Humidifiers: Die meisten Datenpunkte sollen jetzt vorhanden sein und die Steuerungen auch funktionieren. Auch wenn ich nicht ausschließen kann, dass irgendwo noch Bugs lauern - ich kann das nun mal nicht selbst testen. Ach ... und ... ja - Es sind ein paar neue Datenpunkte dazu gekommen, deren Namen ich zwar in der App gefunden habe - mehr aber auch nicht. Ich kenne also noch keinen Werteberech oder Einheiten. da würde ich mich über eure Mithilfe (z.B. @Kludi ;) sehr freuen). Das sind im Wesentlichen die im ReadMe von hmod bis wath. (https://github.com/Grizzelbee/ioBroker.dysonairpurifier#product-state)
                Wichtig!
                Ich habe die Android-App mal ein bisschen auseinander genommen und dabei die korrekte Beschreibung einiger Datenpunkte gefunden, die ich vorher anders interpretiert hatte. Es werden also ein paar Datenpunkte verwaisen - löscht bitte einfach direkt alle und lasst sie neu anlegen oder löscht geziehlt was nicht mehr aktualisiert wird.
                Account-Passwort: Ich musste noch einmal an die Verschlüsselung des Passworts in der Konfig ran - das müsst ihr also zwingend noch einmal neu eingeben, weil es aktuell nicht mehr korrekt entschlüsselt werden kann.
                Und jetzt: Viel Spass damit und hoffentlich wenig Fehler!
                viele Grüße
                grizzelbee
                Changelog
                V0.7.1 (2021-02-06) (Horizons)
                (grizzelbee) New: When no host address is given - adapter tries to connect via default hostname of the device
                (grizzelbee) Fix: #13 Filterlifetime is now correctly displayed in hours and percent for devices supporting this
                (grizzelbee) Fix: #48 Fixed countrycodes for UK and USA
                (grizzelbee) Fix: #52 Fixed VOCIndex
                (grizzelbee) Fix: Removed option to control Fan state since it corresponds to the state of the fan in auto-mode. Controlling it is senseless.
                (grizzelbee) Fix: Fixed await..then anti pattern
                (grizzelbee) Fix: Fixed undefined roles
                (grizzelbee) Fix: Fixed some bad promises and moved code to dysonUtils
                (grizzelbee) Fix: Fixed encrypting password using js-controller 3.0 build-in routine
                (grizzelbee) Upd: Added topic "Controlling your device(s)" to readme
                (grizzelbee) Upd: Removed unnecessary saving of MQTT password
                (grizzelbee) Upd: #9 Added some more dyson codes for heaters and humidifiers
                  Hey Zusammen,
                  Wichtig!
                  viele Grüße
                  grizzelbee
                  Changelog
                  GrizzelbeeG Offline
                  GrizzelbeeG Offline
                  Grizzelbee
                  Version 0.7.3 (2021-02-10) (When angels fall)
                  (theimo1221) Fix: #59 added default country
                  (theimo1221) New: added function to mask password to dyson-utils.js
                  (grizzelbee) New: extended config test and error logging
                  (grizzelbee) New: added password to protectedNative in io-package.json
                  (grizzelbee) Fix: fixed showing password in config (leftover from testing/fixing)
                  (grizzelbee) Fix: fixed detection of needed js-controller features
                  (grizzelbee) Fix: fixed detection if IP is given or not
                  (grizzelbee) Upd: creating all data points with await
                  V 0.7.2 (2021-02-10) (Songs of love and death)
                  (grizzelbee) Fix: #59 Fixed bug while loading/saving config which led to wrong values displayed for country and temperature unit
                  (grizzelbee) Upd: switched "Skipping unknown ..." message from info to debug
                    GrizzelbeeG Offline
                    GrizzelbeeG Offline
                    Grizzelbee
                    Hallo Zusammen,
                    für alle, die es bemerkt haben: Der Adapter geht wieder online - für alle, bei denen er einfach durchgelaufen ist: Ihr solltet folgendes Update installieren, damit der Adapter beim nächsten reboot wieder online geht. ;)
                    0.7.5 (2021-02-12) (I won't surrender)
                    (grizzelbee) Fix: #65 Adapter gets online again after changes to dyson cloud API login procedure.
                    (grizzelbee) New: Adapter reconnects with new host address when it gets changed manually
                    0.7.4 (2021-02-10) (Human)
                    (grizzelbee) Fix: fixed adapter traffic light for info.connection
                    (grizzelbee) Fix: Minor fixes
                    Was mich aber interessieren würde:
                    • Welche Punkte sind noch offen? Was müsste dringend noch eingebaut werden?
                    • Funktionieren alle Steuerungen?
                    • Sind alle Datenpunkte einigermaßen plausibel?
                    • Fehlen noch Datenpunkte, die gewünscht sind?
                    Ach ... und ... falls ich mit meiner Bitte mir Issues auf Github zu öffnen jemanden verschreckt habe hier zu schreiben ... das war so nicht gemeint. Es ging bei der Bitte primär um Dinge, die tatsächlich Codeänderungen erfordern. Ich wollte die Diskussion hier nicht abwürgen.
                    integer63I 1 Antwort Letzte Antwort
                      Hallo Zusammen,
                      integer63I Offline
                      integer63I Offline
                      integer63
                      @grizzelbee Erst mal auch von mir: Vielen Dank für diesen Adapter 👍
                      Kurzes Feedback zu 0.8.0, das Problem mit den "doppelten" Werten in einigen Datenpunkten scheint behoben zu sein.
                      Ein Frage habe ich noch: Ein Datenpunkt (Oscillation) hat neben ON und OFF auch manchmal den Wert OION - was kann das sein?
                      Thomas
                      • integer63I integer63
                        Thomas
                        GrizzelbeeG Offline
                        GrizzelbeeG Offline
                        Grizzelbee
                        @integer63
                        Zwei Dinge freuen mich gerade:
                        1. Das der Bug weg ist und
                        2. Das ich gerade per Zufall sehe, das der Adapter auch mit mehreren dysons funktioniert. :) Ich habe das zwar gehofft, aber noch keine Rückmeldung dazu bekommen.
                        Das ist eine gute Frage. Das ist ein Wert, den ich während der Entwicklung auch immer mal wieder gesehen und für einen Fehler gehalten habe. Seit geraumer Zeit habe ich ihn nicht mehr gesehen. Also zusammengefasst: Ja - es kann sein das der Wert kommt, ich habe aber keine Idee, was der bedeuten soll.
                        @fastback2000
                        Ich würde gerne als nächstes die Unterstützung der Heater-Modelle verbessern. Kannst du mir einen Überblick geben was funktioniert und was noch fehlt?
                        Deine Idee mit dem Wassertank ist auch noch auf meiner Liste. Vielleicht können wir da auf Github weiter nach suchen:
                        https://github.com/Grizzelbee/ioBroker.dysonairpurifier/issues/21
                        • Gianfranco SinistraG Offline
                          Gianfranco Sinistra
                          Guten Morgen.
                          danke für die Info.
                          bei mir ist nun nur folgendes. ich habe das 0.8.0-pre nun aufgesetzt und neu angemeldet. warum auch immer bleibt der Adapter gelb und der Baum wird nicht ausgefüllt, um die IP eingeben zu können. ausßer "INFO - Connection" ist nichts zu sehen. mehr mals neu installiert. ist es erforderlich die 0.7.5 aufzusetzen?
                            Guten Morgen.
                            danke für die Info.
                            GrizzelbeeG Offline
                            GrizzelbeeG Offline
                            Grizzelbee
                            @gianfranco-sinistra
                            Das Problem ist gerade das dyson mal wieder den Login geändert hat. Und diesmal in einer ziemlich hässlichen Art und Weise
                            Infos dazu finden sich auf github:
                            https://github.com/Grizzelbee/ioBroker.dysonairpurifier/issues/75
                            Es wird eine Weile dauern, bis ich das implementieren kann - ich bin gerade mit etwas anderem beschäftigt.
                            Die gute Nachricht ist aber, das es einen einfachen Trick gibt um die aktuelle Version ans Laufen zu bekommen:
                            1. Stoppe den Adapter
                            2. Öffne die dyson-app auf deinem Handy
                            3. Sobald die App offen ist: starte den Adapter
                            Nachteil dabei: Das ist bei jedem Restart des Adapters notwendig.
                            Wie gesagt: Ich habe eine Idee dazu, die ich in einem neuen Release umsetzen werde, aber ich kann noch keinen Termin nennen.
                              Gianfranco Sinistra
                              @grizzelbee irre, aber geil. hat funktioniert :) Danke und erstmal viel Erfolg bis dahin.
                                @integer63
                                @fastback2000
                                matthias.riedel.9887
                                schrieb am zuletzt editiert von matthias.riedel.9887
                                #66
                                @grizzelbee said in dyson Air purifier Adapter - Tester gesucht:
                                Ich habe gerade den Dyson Pure Hot+Cool eingebunden.
                                Ich kann das Gerät ein und ausschalten - dysonairpurifier.0.xxxxxxxxxx.MainPower
                                HeaterMode ein / aud funktioniert nicht - dysonairpurifier.0.xxxxxxxxxxx.HeaterMode
                                TemperatureTarget setzten funktioniert nicht - dysonairpurifier.0.xxxxxxx.TemperatureTarget
                                • K Kludi
                                  @Grizzelbee
                                  Hallo Grizzelbee
                                  Heute hatte ich mal Zeit dir die Erfahrungen mit der Version 0.5.1 zu schreiben.
                                  Ich habe den Dyson Pure Cool Link Tower (TP02)
                                  Ich hatte keine Probleme mit der Version.
                                  Der Wert für die Filterlebensdauer wird bei mir immer noch in Stunden dargestellt.
                                  Und wenn der Lüfter aus ist sind leider die Humidity und Temperature weg.
                                  Bevor ich die Neue Version installiert habe, habe ich alle Objekte von Dyson Adapter gelöscht.
                                  Viele Grüße
                                  Kludi
                                  bjoernson
                                  schrieb am zuletzt editiert von bjoernson
                                  #67
                                  @kludi said in dyson Air purifier Adapter - Tester gesucht:
                                  @Kludi ich habe ebenfalls den TP02 und finde es interessant, dass bei dir mehr Sensoren angezeigt werden, als bei mir. Ich kann lediglich auf Dust und VOC zugreifen, was die Luftverschmutzung betrifft. Der Datenpunkt DustIndex ist bei mir aber ohne Funktion. Steht immer auf Good(0). Wie ist das bei dir? Ändern sich Dir die Werte für Feinstaub und DustIndex?
                                  Viele Grüße
                                  bjoernson
                                  GrizzelbeeG K 4 Antworten Letzte Antwort
                                  • B bjoernson
                                    Viele Grüße
                                    bjoernson
                                    GrizzelbeeG Offline
                                    GrizzelbeeG Offline
                                    Grizzelbee
                                    #68
                                    @bjoernson
                                    Ich habe das mal als Bug aufgenommen und komme auf dich zurück, wenn ich das fixe.
                                    https://github.com/Grizzelbee/ioBroker.dysonairpurifier/issues/94
                                      @bjoernson
                                      integer63I Offline
                                      integer63I Offline
                                      integer63
                                      #69
                                      Habe heute einen HP07 Purifier Hot+Cool in Betrieb genommen und bekomme folgende Meldung:
                                      dysonairpurifier.0 2021-04-14 11:46:16.190 warn (16525) Please open an Issue on github if you think your device should be supported.
                                      dysonairpurifier.0 2021-04-14 11:46:16.189 warn (16525) Device with serial number [J8F-EU-PAA6314A] not added, hence it is not supported by this adapter. Product type: [527E]
                                      Habe daraufhin eben ein Issue auf Github aufgemacht.
                                      Danke für den Support!
                                        GrizzelbeeG Offline
                                        GrizzelbeeG Offline
                                        Grizzelbee
                                        #70
                                        @integer63 Perfekt! :) Baue ich ein ...
                                        https://github.com/Grizzelbee/ioBroker.dysonairpurifier/issues/95
                                        • B bjoernson
                                          Viele Grüße
                                          bjoernson
                                          GrizzelbeeG Offline
                                          GrizzelbeeG Offline
                                          Grizzelbee
                                          #71
                                          @bjoernson sagte in dyson Air purifier Adapter - Tester gesucht:
                                          Das hatte ich im ersten Durchgang überlesen.
                                          Wenn Du mit den zusätzlichen Sensoren die xxxIndex (No2, ...) meinst: Das sind künstliche Indizes, die der Adapter schreibt - ähnlich wie die App das ja auch tut. Ich habe da versucht die Werte der App nachzubilden. Das ergibt allerdings natürlich nur bei Geräten Sinn, die die passenden Sensoren auch haben. Deshalb habe ich diesen Fehler in einer späteren Version bereinigt und erzeuge beim TP02 nur noch den DustIndex - das der nicht wirklich funktioniert ist noch niemandem aufgefallen, wie es scheint.
                                          B integer63I 2 Antworten Letzte Antwort
