  4. IoBroker mit Warema WMS Web Control
127 Beiträge 26 Kommentatoren 50.5k Aufrufe 18 Beobachtet
  • R Offline
    radiorichter
    #85
    Hallo Beisammen, jetzt bräcuhte ich nochmal eure Hilfe, nach umzug vom pi auf den rock mag die Rollosteuerung nicht mehr. Hier mal Auszug aus dem LOG file: pfad/key etzc sollte alles passen. nur findet er keine objekte mehr... steh ein wenig auf dem Schlauch :(
    hm-rpc.1	2019-02-17 10:51:20.220	info	xmlrpc <- listDevices ["hm-rpc.1"]
    javascript.0	2019-02-17 10:51:15.363	debug	script.js.Warema.warema_script(1): {"type":"ack"}
    javascript.0	2019-02-17 10:51:15.362	debug	script.js.Warema.warema_script(1): received message: a
    javascript.0	2019-02-17 10:51:15.351	debug	script.js.Warema.warema_script(1): sending {R04FFFFFF7020152902}
    javascript.0	2019-02-17 10:51:13.717	debug	script.js.Warema.warema_script(1): {"type":"message","payload":{"src":"E5AD07","type":"parameterSetRequest","messagePayload":{"parameter":"0B080009","type":"clock","year":19,"month":2,"day":17,"hour"
    javascript.0	2019-02-17 10:51:13.714	debug	script.js.Warema.warema_script(1): received message: rE5AD0780200B0800091302110A340E060001
    javascript.0	2019-02-17 10:51:10.371	debug	script.js.Warema.warema_script(1): received expected answer: a
    javascript.0	2019-02-17 10:51:10.351	debug	script.js.Warema.warema_script(1): sending {R04FFFFFF7020152902}
    javascript.0	2019-02-17 10:51:05.487	info	script.js.Warema.warema_script(1): Serial Ports: [{"comName":"/dev/ttyS2"},{"manufacturer":"FTDI","serialNumber":"AI04F042","pnpId":"usb-FTDI_FT232R_USB_UART_AI04F042-if00-port0","vendorId":"0403","p
    javascript.0	2019-02-17 10:51:05.349	debug	script.js.Warema.warema_script(1): received expected answer: a
    javascript.0	2019-02-17 10:51:05.319	debug	script.js.Warema.warema_script(1): sending {M%171529}
    javascript.0	2019-02-17 10:51:05.318	debug	script.js.Warema.warema_script(1): received expected answer: a
    javascript.0	2019-02-17 10:51:05.317	debug	script.js.Warema.warema_script(1): {"type":"ack"}
    javascript.0	2019-02-17 10:51:05.317	debug	script.js.Warema.warema_script(1): received message: a
    javascript.0	2019-02-17 10:51:05.295	debug	script.js.Warema.warema_script(1): sending {K401A86E62449D8FFE6BE301ED27377FE9F0}
    javascript.0	2019-02-17 10:51:05.292	info	script.js.Warema.warema_script(1): Stick Version: v37605107
    javascript.0	2019-02-17 10:51:05.291	debug	script.js.Warema.warema_script(1): received expected answer: v
    javascript.0	2019-02-17 10:51:05.290	debug	script.js.Warema.warema_script(1): {"type":"stickVersion","payload":{"version":"37605107"}}
    javascript.0	2019-02-17 10:51:05.289	debug	script.js.Warema.warema_script(1): received message: v37605107
    javascript.0	2019-02-17 10:51:05.276	debug	script.js.Warema.warema_script(1): sending {V}
    javascript.0	2019-02-17 10:51:05.275	debug	script.js.Warema.warema_script(1): received expected answer: gWMS USB-Stick
    javascript.0	2019-02-17 10:51:05.271	debug	script.js.Warema.warema_script(1): {"type":"stickType","payload":{"name":"WMS USB-Stick"}}
    javascript.0	2019-02-17 10:51:05.269	debug	script.js.Warema.warema_script(1): received message: gWMS USB-Stick
    javascript.0	2019-02-17 10:51:05.253	debug	script.js.Warema.warema_script(1): sending {G}
    javascript.0	2019-02-17 10:51:05.251	info	script.js.Warema.warema_script(1): port opened
    javascript.0	2019-02-17 10:51:05.235	info	script.js.Warema.warema_script(1): registered 0 subscriptions and 0 schedules
    javascript.0	2019-02-17 10:51:05.194	info	Start javascript script.js.Warema.warema_script(1)
    javascript.0	2019-02-17 10:50:59.498	warn	script.js.Warema.warema_script(1): closing open serial ports
    • P Pman
      Ändere mal in Zeile 384 "R04" in "R06". Kann sein, dass da ein Fehler im Skript ist. Es war glaube ich noch nicht ganz klar, was genau R04 macht.
      rendgeor
      #86
      @Pman:
      1. Is the binding's code in a central module/github available so that changes/bugfixes can be corrected and to monitor stable versions?
      2. Can the binding used only to read data or also to send data to the WMS station. for example simulationg a sensor?
        TurboKanne
        schrieb am zuletzt editiert von TurboKanne
        #87
        Hallo, mein Smart Home wächst und gedeiht. Nun möchte ich noch die vorhandenen Raffstore der Marke Warema per Google Home Geräte steuern können. Daher bin ich auf diesen älteren Thread gestossen.
        Verstehe ich das richtig, ich brauche:
        Hardware:
        Raspberry Pi 3 (hab schon eins)
        Warema USB Stick (hab ich auch schon - WMS Web Control läuft bei mir gut)
        Google Nest Mini (hab ich natürlich ebenfalls)
        Software:
        ioBroker auf Raspbian --> Wahrscheinlich sowas wie das Image z.B. Raspbian Light Buster?
        Liege ich da richtig, dass es so gelingen kann den Warema Sonnenschutz per Voicecommand zu steuern?
        Was sollte ich ggf. noch berücksichtigen? Kann mir jemand mal leichtverständlich die ersten Schritte nochmal aufzeigen, damit ich einen Einstieg finde. Ich würde mich ja schon durchfummeln, aber ich wäre Happy wenn ich zumindest wüsste ob ich da gedanklich auf dem richtigen Weg bin.
        TurboKanne
        • R Offline
          radiorichter
          #88
          habe die letzten Tag folgendes noch gefunden:
          https://github.com/cornim/wms_webcontrol
          Damit könnte man ohne den WMS Stick das ganze auch bedienen. Heist also direkt an das webcontrol die Befehle schicken und die States empfangen.
          Leider weiß ich aber nicht wie ich ein python script nutze... aber ich bin dran ;)
          • R Offline
            Rapptor33
            #89
            @radiorichter
            einen ioBroker Adapter für das WMS Web Control gibt es aber nicht, oder?
            • R Offline
              radiorichter
              #90
              nein einen Adapter gibt es leider nicht... und wird es vermutlich auch nie geben....
              habe gerade noch folgendes gefunden:
              https://www.npmjs.com/package/warema-wms-venetian-blinds
              vielleicht kommst du damit ja weiter ;)
                droenl
                #91
                Ich habe auch mit dem WMS Stick experimentiert. Leider scheint die "Mesh" Funktionalität nicht für die Steuerbefehle (wie die des WMS Studio) zu gelten. Ist der Empfänger ausser Reichweite, so kommt der Fahrbefehl nicht an. Programmiere ich eine Fernbedienung und löse sie am selben Ort aus, wie vorher den WMS Stick, so funktioniert der Fahrbefehl. Kann ein Fahrbefehl einer Fernbedienung überhaupt untersucht werden? Falls ja: Hat schon jemand geprüft, ob sich diese vom "WMS Studio / Studio Pro" unterscheiden?
                • R Offline
                  radiorichter
                  #92
                  so, war leider unfähig python bei mir am rock64 zum laufen zu bekommen aber habe es am PC installiert und den die Befehle mir angesehen welche an das Webcontrol geschickt werden. Leider hab ich nur das Senden der Befehle geschafft, nicht die Werte wieder abzuholen. aber besser als nichts ;)
                  Hab das ganze nun so gemacht, dass ich einfach per Javascript mit dem Exec Block an das Warema schicke und ein kleines Blockly das den Zähler etc erhöht, klappt soweit ganz gut ;) Vielleicht kanns ja jemand auch für sich nutzen ;) Den Zähler setze ich einfach nach erreichen eines bestimmten Wertes wieder auf Anfang, das klappt ganz gut ;)
                  Hier das was geschickt wird:
                  192.168.178.36/protocol.xml?protocol=9099082103020328ffffff&_=1586803111'
                  192.168.178.36/ IP adresse
                  protocol.xml?protocol= fest
                  90 initial
                  99 Zähler +4
                  0821 Fahrbefehl
                  0302 Raum/Rollo wie in App also Raum 03 und Rollo 02 (start bei 0), bei raum größer 9 wird mit zahlen weitergezählt
                  03 Festwert
                  28 Position mal 2 und in Hex umgewandelt
                  ffffff&_ Fahrbefehl
                  1586803111 Zähler +4
                  und hier der Blockly auszug:
                  • W willjoha
                    Kann schon mal passieren das ich zu technisch werde ;) Am Ende der Nachricht ist dies auch diesmal der Fall.
                    Diesen "Code" auszulesen war mein erster Ansatz, da ich wie Pman die Hoffnung hatte das das von Warema eingesetzte Funkprotokoll nicht selbst implementiert ist und damit schon bekannt ist. Soweit ich das jetzt sagen kann ist es eine proprietäre Implementierung die auf aber zumindest auf IEEE 802.15.4 als unterste Schicht basiert.
                    Bei der Analyse bin ich aber darauf gestoßen das der Warema USB Stick die Ver- und Entschlüsselung bereits übernimmt und die Relevanten Teile der Funktelegramme per Serieller Schnittstelle bereitstellt.
                    Nachdem ich nun heute noch meinem WebControl vorgegaukelt habe das mein WMS Stick ein Raffstore ist habe ich zumindest die wichtigsten Teile des Seriellen Protokolls zusammen. Ich versuch es mal einigermaßen verständlich zu beschreiben. Damit sollte dann eine Implementierung für die jeweilige Smarthome Software möglich sein.
                    Benötigt wird dann neben der Software nur noch der Warema WMS Stick (USB Stick) für ca 55€.
                    <size size="150">Alles unten beschriebene ist nicht ausführlich getestet und nur durch Analysen ermittelt. Mit dem WMS Stick können die Geräte auch programmiert werden falsche Nachrichten können daher zu einer Beschädigung eurer Anlage führen. Verwendung daher auf eigene Risiko.</size>
                    Serielle Parameter:
                    Baudrate: 125000
                    Parity: None
                    Data bits: 8
                    Stop bits: 1
                    Nachrichten an und vom WMS Stick sind immer in geschweiften Klammern {} eingeschlossen, Linefeed/Return ist nicht nötig.
                    Die meisten Befehle die man an den USB Stick schickt werden mit "{a}" quittiert. Falls der Befehl nicht verstanden wird kommt ein "{f}" zurück.
                    WMS Stick Prüfen:
                    Ob man mit einem WMS Stick verbunden ist kann man mit folgender Sequenz: "{G}"
                    Der WMS Stick antwortet in diesem Fall nicht mit "{a}" sondern mit "{gWMS USB-Stick}"
                    Die Version des WMS Stick kann mit "{V}" abgefragt werden. in diesem Fall kommt ebenfalls kein "{a}" zurück sondern "{vVVVVVVVV }" wobei VVVVVVVV für die Versionsnummer steht.
                    Mit Netz verbinden:
                    Damit der WMS Stick mit euren Geräten im Netzwerk kommunizieren kann benötigt er den Netzwerkschlüssel den bekommt er mit folgendem Befehl:
                    "{K401KKKKKKKKKKKKKKKKKKKKKKKKKKKKKK}"
                    KKKKKKKKKKKKKKKKKKKKKKKKKKKKKK steht hierbei für den AES Schlüssel des Netzwerks. Der WMS Stick quittiert diesen Befehl mit "{a}"
                    Dieser Schlüssel kann auf zwei Wegen ermittelt werden. Option 1 durch mitlauschen der Seriellen Kommunikation zwischen WMS Studio und WMS Stick. Hierfür benötigt ihr aber euer Projekt mit dem die Anlage parametriert wurde. Option 2 WMS Stick per WMS Handsender ins Netzwerk einlernen. Die hierfür nötigen Befehle an den WMS Stick habe ich zwar schon einmal mitgetracet allerdings nicht dokumentiert da ich durch Option 1 schon den Schlüssel hatte. Kann das bei Gelegenheit noch nachholen.
                    Danach muss noch der Funkkanal und die PANID mitgeteilt werden:
                    "{M%CCPPPP}" wobei CC für den Funkkanal (Default: 17) und PPPP für die PANID steht. Das Prozentzeichen könnte noch durch eine Raute (#) ersetzt werden dann empfängt man allerdings keine Broadcasts. Befehlt wird ebenfalls mit "{a}" quittiert.
                    Jetzt seit ihr bereits mit dem Netz verbunden und solltet Broadcast Messages eurer Wetterstation beziehungsweise Zeitsignale eures WebControls oder der WMS Zentrale empfangen.
                    Wetterstations Broadcast:
                    "{rAAAAAA708000WWL1FFFFFFL2FFRRTTFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF}"
                    AAAAAA = SNR (Seriennummer) der Wetterstation in HEX.
                    7080 = Nachrichten Typ hier Wetter
                    WW = Wind, müsste in m/s sein.
                    L1 = Helligkeitswert 1
                    L2 = Helligkeitswert 2 (Wie aus Helligkeitswert 1 und Helligkeitswert 2 korrekt berechnet wird weiß ich noch nicht.)
                    RR = Niederschlag (00: Kein Regen C8: Regen)
                    TT = Temperatur * 10 muss also durch 10 geteilt werden. Wie Temperaturen über 25,4° und unter 0° dargestellt werden weiß ich noch nicht.
                    Datums/Zeit Broadcast:
                    "{rAAAAAA80200B080009YYNNDDHHMM0C060101}"
                    AAAAAA = SNR (Seriennummer) der WMS Zentrale/WebControl in HEX.
                    8020 = Nachrichten Typ hier Datum/Zeit
                    YY = Jahr 2 stellig in HEX
                    NN = Monat in HEX
                    DD = Tag in HEX
                    HH = Stunden in HEX
                    MM = Minuten in HEX
                    "{rAAAAAA80200B080009110A080C240C060101}" entspricht 08.10.2017 12:36
                    WMS Gerät winken lassen:
                    "{R06AAAAAA7050}" an WMS Stick schicken.
                    AAAAAA = SNR (Seriennummer) vom Gerät welches Winken soll in HEX.
                    7050 = Nachrichten Typ hier Winken
                    WMS Stick quittiert mit "{a}"
                    Status Zwischenstecker abfragen:
                    "{R06AAAAAA801001000005}" an WMS Stick schicken.
                    AAAAAA = SNR (Seriennummer) vom abzufragenden Zwischenstecker in HEX.
                    8010 = Nachrichten Typ hier Statusabfrage
                    Zwischenstecker schickt Status:
                    {rAAAAAA801101000003PPWWV1V200}
                    AAAAAA = SNR (Seriennummer) vom abgefragten Zwischenstecker in HEX.
                    8011 = Nachrichten Typ hier Statusantwort
                    PP = Position in % * 2 (HEX) muss daher durch 2 geteilt werden
                    WW = Winkel +127 in HEX. 127 entspricht daher 0°.
                    V1 = Position Volant 1. FF entspricht nicht vorhanden.
                    V2 = Position Volant 2. FF entspricht nicht vorhanden.
                    Kodierung von PP, WW, V1 und V2 entspricht der des WMS WebControl Protocols kann daher mit Hilfe des WebControl JavaScripts nachvollzogen werden.
                    Der WMS Handsender kann auch den Grund für den Letzten Fahrbefehl anzeigen (Wind, Niederschlag, Eis, …) ob und wie dies kodiert ist weiß ich noch nicht.
                    Zwischestecker auf Position fahren:
                    "{R06AAAAAA707003PPWWV1V2}"
                    7070 = Nachrichten Typ hier Fahrbefehl
                    PP, WW, V1, V2 wie unter "Status Zwischenstecker abfragen" beschrieben.
                    Zwischenstecker schickt Bestätigung:
                    {rAAAAAA70710010023F02C04DFFFF0C0DFFFF}
                    7071 = Nachrichten Typ hier Bestätigung Fahrbefehl.
                    Genaue Zusammensetzung habe ich hier noch nicht analysiert. Am Ende scheinen zwei Position enthalten zu sein (2 x PPWWV1V2, C04DFFFF0C0DFFFF).
                    Nachdem der Handsender die Ursache anzeigen kann warum ein Fahrbefehl nicht ausgeführt wird wird dies auch noch enthalten sein.
                    rendgeor
                    #93
                    @willjoha
                    Hallo, du schreibst: "Dieser Schlüssel kann auf zwei Wegen ermittelt werden. Option 1 durch mitlauschen der Seriellen Kommunikation zwischen WMS Studio und WMS Stick. Hierfür benötigt ihr aber euer Projekt mit dem die Anlage parametriert wurde."
                    Wie kann man die serielle Kommunikation belauschen?
                    • R Offline
                      Rapptor33
                      #94
                      habe mal eine Adapter Anfrage gestellt, wenn noch jemand Interesse daran hat, bitte Daumen Hoch an der Anfrage 👍
                      GitHub Link
                      • R Rapptor33
                        GitHub Link
                        tombox
                        #95
                        @rapptor33 Ich würde mich der Sache annehmen. Geplant ist das ich mir ein Warema Stick besorge und hoffe das die Reichweite passt. Das WMS Webcontrol sieht zwar einfacher aus für ein Adapter aber es lohnt sich für mich nicht den anzuschaffen oder jemand hat einen über.
                        R 1 Antwort Letzte Antwort
                        • R radiorichter
                          Hallo beisammen,
                          ich bin neu hier und wollte mich erkundigen, ob es möglich ist, das Warema WMS Web Control mit dem iBroker zu verknüpfen, um dann damit per Alexa Sprachsteuerung die Rollos hoch und runter fahren zu können.
                          Hier mal der Link zu Warema: (das soll mal verbaut werden, also Funkaktoren an jedem Rolloschalter +Gateway für webcontrol)
                          https://www.warema.de/Produkte/Steuerun … ontrol.php
                          Da wir gerade beim Hausbau sind und die Alexa bereits in der Wohnung eingezogen ist, möchte ich diese natürlich auch für die zukünftigen elektrischen Rollos verwenden. Hier kommt eben das Warema WMS Web Control ins Spiel, das ganze verbaut der Schwiegervater, somit habe nicht viel Mitspracherecht was verbaut wird, da er das gleiche System zu Hause hat (nur eben nur per App Bedienung).... Leider habe ich im Forum, sowie im WWW nichts gefunden, was mich weitergebracht hätte. Das einzige was ich derzeit gefunden habe, ist die Verknüpfung mit dem Mediola AIO GATEWAY, wovon ich aufgrund der Gebühren jetzt so nicht begeistert bin.
                          Leider bin ich mit dem Thema Ibroker noch nicht wirklich vertraut, also bitte verzeiht mir eventuelle dumme Fragen ;)
                          Danke schon mal!
                          tombox
                          #96
                          @radiorichter Ich habe mal für die wms webcontrol pro gebaut.
                          Gerne mal testen ob es für andere Nutzer auch geht
                          https://forum.iobroker.net/topic/45197/test-warema-wms-webcontroller-v0-0-1
                          • T tombox
                            Rapptor33
                            schrieb am zuletzt editiert von Rapptor33
                            #97
                            @tombox Hallo, sorry die späte Meldung. Ja werde das gerne testen, super das du dich darum bemühst 👍
                            Ich habe leider noch den alten webcontrol, der wird ja ohne email account betrieben.
                            Wäre es möglich den Adapter auch für die ältere Webcontrol version zu adaptieren?
                            Könnte auch ein Webcontrol zur Verfügung stellen!
                            • R Rapptor33
                              tombox
                              #98
                              @rapptor33 Schwierig ich habe mal gesehen wie die app lokal kommnuiziert und das sind alles verschlüsselte hex nachrichten.
                              • T tombox
                                Murph
                                schrieb am zuletzt editiert von Murph
                                #99
                                @tombox Hi, da ich auch die ältere Version der/des WMS Webcontrol habe würde ich mich natürlich auch seeeehr über einen adaptierten Adapter freuen! 😊
                                Oder anders gefragt, da die ganz oben beschriebene Methode ja schon eine Weile her ist, funktioniert die Vorgehensweise mit dem Stick noch?
                                Wäre ja eine Alternative da ich den Stick hier sowieso rum liegen habe... 🙄
                                • M Murph
                                  Bender275
                                  #100
                                  ich habe eine Warema Markise mit Volant und Wetterstation.
                                  Diese wird aktuell mit der schwarzen Fernbedienung WMS Handsender bedient.
                                  Wie ist da aktuell der Stand? Man liest einerseits immer wieder von Web Control, aber auch dem WMS Stick; andererseits nur davon, Werte zu senden, aber nicht abzurufen.
                                  Der WMS Stick muss anscheinend auch in das System eingelernt werden.
                                  Daher die Frage: Ist es möglich,
                                  1. den WMS Stick mit der FB anzulernen, oder brauche ich Warema dazu?
                                  2. Diesen dann am Raspi mit iobroker zum laufen zu bringen?
                                  3. Die Werte der Wetterstation auszulesen? Hier handelt es sich um Regen, Sonnenstärke, Temperatur und Wind - wäre schon echt praktisch, wenn das ginge und
                                  4. Darüber dann die Markise UND den Volant zu steuern?
                                  Danke!
                                  Viele Grüße
                                  • B Bender275
                                    Danke!
                                    Viele Grüße
                                    tombox
                                    #101
                                    @bender275 Meine Empfehlung ist das die WebControl zu verkaufen und gegen eine WebControl Pro zu tauschen aber zum neu programmieren brauchst du dein WMS Stick. Für die Pro gibt es dann ein Adapter
                                    • T tombox
                                      Bender275
                                      schrieb am zuletzt editiert von Bender275
                                      #102
                                      @tombox Ich habe noch gar keine Web Control - d.h. ich brauche die WebControl Pro und den Stick?
                                      Ist das die hier?
                                      https://www.ams-elektro.com/Installationsmaterial/Sonstiges-Installationsmaterial/Tor-Rollladenantriebe-Pumpen-Ventilatoren/Zubehoer-fuer-Tor-Rollladenantriebe/Warema-WMS-WebControl-pro-2020920::2135778.html?MODsid=aqarmdqdap0i1banptufro7vjk
                                      Wie würde der Adapter heißen? Ich finde gerade nix mit WMS oder Warema.
                                      • B Bender275
                                        Ist das die hier?
                                        tombox
                                        #103
                                        @bender275 jap genau der gibt es auch für 255€ der ist noch nicht im latest aber bald
                                        • T tombox
                                          Bender275
                                          #104
                                          @tombox
                                          Puh, dann brauche ich ja noch den Stick für 50€...
                                          Kann man das dann selbst alles (evtl. mit dem WMS Studio) anlernen, oder brauche ich Warema oder den Monteur dazu?
                                          Hat jemand nen Screenshot, wie die Werte von der Wetterstation dargestellt werden?
