  4. [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana
    6.6k
solaredgemodbusgrafana
609 Beiträge 92 Kommentatoren 315.8k Aufrufe 100 Beobachtet
  • HumidorH Humidor
    @wendy2702 wenn alles leer ist, ist der Adapter Gelb (passt), Objekte sind bis auf Info leer
    Log öffent /schließt den Socket, macht sonst nichts (debug)
    modbus.1	2021-02-13 15:31:36.550	debug	(21337) Closing client on purpose.
    modbus.1	2021-02-13 15:31:35.550	debug	(21337) Cleaning up request fifo.
    modbus.1	2021-02-13 15:31:35.550	debug	(21337) Socket closed with error
    modbus.1	2021-02-13 15:31:35.374	info	(21337) Disconnected from slave 192.168.0.98
    modbus.1	2021-02-13 15:31:35.373	debug	(21337) Closing client on purpose.
    modbus.1	2021-02-13 15:31:35.373	info	(21337) Connected to slave 192.168.0.98
    importiere ich die Settings in Holding Registers:
    modbus.1	2021-02-13 15:34:11.228	debug	(21615) sendTo "listUart" to system.adapter.admin.0 from system.adapter.modbus.1
    modbus.1	2021-02-13 15:34:11.228	info	(21615) List of port: [{"path":"/dev/ttyAMA0"}]
    modbus.1	2021-02-13 15:33:56.780	debug	(21615) Closing client on purpose.
    modbus.1	2021-02-13 15:33:55.778	debug	(21615) Cleaning up request fifo.
    modbus.1	2021-02-13 15:33:55.778	debug	(21615) Socket closed with error
    modbus.1	2021-02-13 15:33:55.710	info	(21615) Disconnected from slave 192.168.0.98
    modbus.1	2021-02-13 15:33:55.709	debug	(21615) Closing client on purpose.
    modbus.1	2021-02-13 15:33:55.659	warn	(21615) Poll error count: 7 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
    modbus.1	2021-02-13 15:33:55.658	debug	(21615) Received pdu describes an error.
    modbus.1	2021-02-13 15:33:55.533	debug	(21615) Poll holdingRegs DevID(1) address 40100 - 71 bytes
    modbus.1	2021-02-13 15:33:55.385	debug	(21615) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 15:33:55.385	debug	(21615) Poll device 1
    modbus.1	2021-02-13 15:33:55.384	info	(21615) Connected to slave 192.168.0.98
    die 40100 bleiben leer, es wird nicht gepollt:
    nehme ich die 40100 aus der Instanz raus:
    modbus.1	2021-02-13 15:38:38.887	debug	(21828) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 15:38:38.886	debug	(21828) Poll device 1
    modbus.1	2021-02-13 15:38:37.721	debug	(21828) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 15:38:37.720	debug	(21828) Poll device 1
    modbus.1	2021-02-13 15:38:36.633	debug	(21828) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 15:38:36.633	debug	(21828) Poll device 1
    modbus.1	2021-02-13 15:38:35.468	debug	(21828) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 15:38:35.468	debug	(21828) Poll device 1
    modbus.1	2021-02-13 15:38:34.296	debug	(21828) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 15:38:34.296	debug	(21828) Poll device 1
    modbus.1	2021-02-13 15:38:33.206	debug	(21828) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    schaut aus wie wenn es ohne Fehler läuft.
    dh ab 40100 stimmt was nicht.
    wendy2702W Online
    wendy2702W Online
    @humidor Oha, du hast noch editiert.
    Dann musst du mal in der Anleitung passend zu deiner Firmware schauen ob es diese Register gibt und wie die Einstellungen sind.
    HumidorH 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      HumidorH Offline
      HumidorH Offline
      Humidor
      schrieb am zuletzt editiert von Humidor
      @wendy2702 sagte in [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana:
      ich glaub ja viel, aber nicht dass es spezifisch zu meiner FW eine Doku gibt...
      sollte das diese sein?
      ich denke eher, dass es an den Werten liegt, wo es keine HW gibt, ich habe keinen SW-Gridmeter
      BG
      wendy2702W 2 Antworten Letzte Antwort
      • HumidorH Humidor
        wendy2702W Online
        wendy2702W Online
        @humidor Also bei SMA gab es zu Beginn der Modbus Einführung verschiedene Register für Verschiedene WRs.
        Gibt es denn zu deinem WR eine MODBUS Beschreibung?
        Bei SMA ist es so, wie du im EXCEL sehen kannst, das auch immer die SW Version mit angegeben ist.
        • HumidorH Humidor
          wendy2702W Online
          wendy2702W Online
          @humidor sagte in [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana:
          40100 ist DC Leistung, dafür braucht es keine weitere HW. Die sollte der WR schon selber kennen da an Ihm die Module angeschlossen sind. Du bekommst ja auch Werte für DC Strom und Spannung.
            HumidorH Offline
            HumidorH Offline
            Humidor
            @wendy2702
            1	40190	M_AC_Current	AC Current (sum of active phases)	A	uint16be	1	1	0	value		true	false
            1	40194	M_AC_Current_S F	AC Current Scale Factor	SF	int16be	1	1	0	value		true	false
            1	40206	M_AC_Power	Total Real Power (sum of active phases)	W	int16be	1	1	0	value		true	false
            1	40210	M_AC_Power_SF	AC Real Power Scale Factor	SF	int16be	1	1	0	value		true	false
            1	40226	M_Exported	Total Exported Real Energy	Wh	uint32be	2	1	0	value		true	false
            1	40234	M_Imported	Total Imported Real Energy	Wh	uint32be	2	1	0	value		true	false
            1	40242	M_Energy_W_SF	Real Energy Scale Factor	SF	int16be	1	1	0	value		true	false
            ab diesen Werten verursacht es bei mir Fehler, ich erkenne eine Beziehung zu einem Gridmeter (den es bei mir nicht gibt).
            sonst funktionierts! 😁
            jetzt noch die JS Umrechnung verstehen... wohin der Wert geschrieben wird 🤔
            wo findet sich denn das: Solar.Wechselrichter.PVLeistungAktuell
            kann es sein, dass das JS-Script nicht läuft (habs gestartet...) ??
            BG
            • HumidorH Humidor
              @wendy2702
              wendy2702W Online
              wendy2702W Online
              Da stimme ich dir zu. Das kann der WR nicht wissen.
              Auch mit 40100 ?
              Du hast jetzt im Ordner Javascript.0 einen Unterordner "Solar/Wechselrichter". Darin sollte der DP sein.
              So in etwa:
                Auch mit 40100 ?
                So in etwa:
                HumidorH Offline
                HumidorH Offline
                Humidor
                @wendy2702 ja bis 40107
                und auch der Wert ist da !!! 😁
                BG
                • HumidorH Humidor
                  wendy2702W Online
                  wendy2702W Online
                  @humidor Sehr schön.
                  Dann kannst du dich ja jetzt mit Visualisierung und/oder Statistiken beschäftigen ;-)
                  Nebenbei, hast du einen Speicher?
                    HumidorH Offline
                    HumidorH Offline
                    Humidor
                    @wendy2702 kein Speicher, am Raspi4 läuft alles auf einer SSD
                    bin noch offen was die End-HW wird, Syno hat mir zu wenig Power und mein kann keine Docker.
                    BG
                    • HumidorH Humidor
                      Batteriespeicher an der PV
                        HumidorH Offline
                        HumidorH Offline
                        Humidor
                        @homoran 😂 neee, hab noch keinen, kommt aber!
                        Frage: JS quietscht bei suncalc, woher kommt das?
                        var suncalc = require('suncalc'),
                        BG
                        wendy2702W HomoranH 2 Antworten Letzte Antwort
                        • HumidorH Humidor
                          wendy2702W Online
                          wendy2702W Online
                          @humidor Trage mal im Javascript Adapter bei zusätzliche Module: "suncalc" ein
                          • HumidorH Humidor
                            @humidor ich höre nichts quietschen ;-)
                            ist in js drin.
                              ist in js drin.
                              HumidorH Offline
                              HumidorH Offline
                              Humidor
                              #66
                              @homoran @wendy2702
                              klappt noch nicht?
                              Bildschirmfoto 2021-02-13 um 16.35.30.png Bildschirmfoto 2021-02-13 um 16.36.40.png
                              @Homoran diese rote schleuder Bremsspur...da quietschts 😇
                              habs zumindes schon geschafft die Zeit in Grafana rein zu bringen 😊
                              BG
                              HomoranH wendy2702W 2 Antworten Letzte Antwort
                              • HumidorH Humidor
                                @homoran @wendy2702
                                klappt noch nicht?
                                #67
                                jetzt hör ich es auch!
                                ignorieren!
                                • HumidorH Humidor
                                  @homoran @wendy2702
                                  klappt noch nicht?
                                  wendy2702W Online
                                  wendy2702W Online
                                  #68
                                  @humidor Achso, stör dich nicht an der Linie.
                                  Die Berechnung hat ja funktioniert wie man am Azimut sieht.
                                    HumidorH Offline
                                    HumidorH Offline
                                    Humidor
                                    #69
                                    @wendy2702 für was sind die anderen Werte?
                                    BG
                                    • HumidorH Humidor
                                      wendy2702W Online
                                      wendy2702W Online
                                      #70
                                      @humidor
                                      Naja,
                                      einer wird in dem Grafana View verwendet damit du den Sonnenstand in einer Grafik sehen kannst im Vergleich zur PV Produktion.
                                      Der dritte Wert ist eine Art Prognose was du ungefähr an Leistung erzeugen kannst. Dafür muss du aber am Anfang vom Script paar Daten eingeben.
                                      var modtilt =       30;     //Dachneigung in Grad (Solar panel's tilt angle)
                                      var modazi =        315;    //Ausrichtung des Hauses in Grad zB SSW (Solar panel's azimut)
                                      var modsufrace =    121.0;   //Paneloberfläche in m2 (Solar panel's surface in sq. meters)
                                      var modeff =        0.211;  //Annäherung an Panel-Wirkungsgrad zB 18 Prozent (modules efficiency correction)
                                        @humidor
                                        Naja,
                                        HumidorH Offline
                                        HumidorH Offline
                                        Humidor
                                        #71
                                        @wendy2702 OK, das klappt bei mir nicht, zu komplex.
                                        BG
                                        • HumidorH Humidor
                                          wendy2702W Online
                                          wendy2702W Online
                                          #72
                                          @humidor Geht bei mir auch nicht.
                                          Verschiedene Ausrichtungen mit unterschiedlichen Modulen und Anzahl an Modulen.
                                          Benutze nur den Wert für den Anzeige in Grafana.
