  4. [gelöst] Admin Adapter startet nicht mehr: SSL Zertifkate
sslssl-zertifikat
5 Beiträge 2 Kommentatoren 1.6k Aufrufe 2 Beobachtet
    tigiba
    schrieb am zuletzt editiert von tigiba
    Ich war gerade dabei zu versuchen die SSL Zertifikate von meinem Webserver für den IO-Broker wiederzuverwerten indem ich die Pfade auf die PEM files eingefügt habe, jetzt bekomm ich den IO-Broker nicht mehr richtig gestartet, alle paar Sekunden startet er den Admin Adapter neu...
    2020-08-12 18:15:12.539  - info: host.Hostname instance system.adapter.admin.0 started with pid 30855
    2020-08-12 18:15:22.983  - info: admin.0 (30855) starting. Version 4.0.10 in /opt/iobroker/node_modules/iobroker.admin, node: v10.21.0, js-controller: 3.1.6
    2020-08-12 18:15:23.205  - info: admin.0 (30855) requesting all states
    2020-08-12 18:15:23.207  - info: admin.0 (30855) requesting all objects
    2020-08-12 18:15:24.862  - info: admin.0 (30855) received all objects
    2020-08-12 18:15:25.209  - error: admin.0 (30855) HTTPS server could not be started: Error: error:0909006C:PEM routines:get_name:no start line
    2020-08-12 18:15:25.315  - error: admin.0 (30855) uncaught exception: Cannot set property '__server' of undefined
    2020-08-12 18:15:25.316  - error: admin.0 (30855) TypeError: Cannot set property '__server' of undefined
        at __construct (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:795:36)
        at new Web (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:848:7)
        at adapter (/opt/iobroker/node_modules/iobroker.admin/main.js:393:53)
        at adapter.getObjectList (/opt/iobroker/node_modules/iobroker.admin/main.js:451:21)
        at (anonymous function).mget (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:128769)
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        at process._tickCallback (internal/process/next_tick.js:68:7)
    2020-08-12 18:15:25.321  - info: admin.0 (30855) terminating https server on port 8081
    2020-08-12 18:15:25.409  - info: admin.0 (30855) terminating
    2020-08-12 18:15:25.414  - info: admin.0 (30855) Terminated (NO_ERROR): Without reason
    2020-08-12 18:15:26.046  - error: host.Hostname Caught by controller[0]: TypeError: Cannot set property '__server' of undefined
    2020-08-12 18:15:26.049  - error: host.Hostname Caught by controller[0]:     at __construct (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:795:36)
    2020-08-12 18:15:26.050  - error: host.Hostname Caught by controller[0]:     at new Web (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:848:7)
    2020-08-12 18:15:26.050  - error: host.Hostname Caught by controller[0]:     at adapter (/opt/iobroker/node_modules/iobroker.admin/main.js:393:53)
    2020-08-12 18:15:26.051  - error: host.Hostname Caught by controller[0]:     at adapter.getObjectList (/opt/iobroker/node_modules/iobroker.admin/main.js:451:21)
    2020-08-12 18:15:26.051  - error: host.Hostname Caught by controller[0]:     at (anonymous function).mget (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:128769)
    2020-08-12 18:15:26.052  - error: host.Hostname Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    2020-08-12 18:15:26.053  - error: host.Hostname Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    2020-08-12 18:15:26.054  - error: host.Hostname Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
    2020-08-12 18:15:26.055  - info: host.Hostname instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2020-08-12 18:15:26.055  - info: host.Hostname Restart adapter system.adapter.admin.0 because enabled
    Und der Web-Adapter (=vis & flot usw.) ist auch nicht mehr erreichbar...
    • T tigiba
      tigiba
      ah okey jetzt hab ich's geschafft wieder zugriff zu bekommen, indem ich per ssh eine neue instanz des admin adapters gemacht hab:
      iobroker add admin --enabled --port 8083
      und mit der das SSL für die erste admin instanz wieder deaktiviert hab.
      • T tigiba
        tigiba
        Jetzt bin ich ein bischen vorsichtiger vorgegangen und hab nur beim web adapter das ssl aufgedreht. bekomme folgenden fehler:
        2020-08-12 18:33:14.585  - error: web.0 (31333) HTTPS server could not be started: Error: error:0909006C:PEM routines:get_name:no start line
        2020-08-12 18:33:14.587  - error: web.0 (31333) Cannot create webserver
        2020-08-12 18:33:14.593  - info: web.0 (31333) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2020-08-12 18:33:15.133  - error: host.Hostname instance system.adapter.web.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        Was kann ich dagegen tun?
        • T tigiba
          tigiba
          also das Problem waren fehlende Leserechte. Hab diese jetzt mal manuell gesetzt, aber bei zukünftigen automtischen renewals werden die dann wohl wieder fehlen.. Dass muss ich noch rausfinden wie ich das sinnvoller lösen kann dass der IO-Broker die letsencrypt zertifikate lesen darf.
          • T tigiba
            Teller
            @tigiba
            Super Danke, hatte das selbe Problem.
            Lösung
            chmod 775 -R /etc/letsencrypt/live /etc/letsencrypt/archive
            iobroker restart admin.0 -v
