  4. Nicht alle Instanzen werden angezeigt
84 Beiträge 7 Kommentatoren 10.1k Aufrufe 6 Beobachtet
  • T THWE12
    @homoran sagte in Nicht alle Instanzen werden angezeigt:
    @thwe12 Das hatte ich befürchtet
    cd /opt/iobroker
    sudo -H npm install iobroker.admin
    iobroker u admin
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ sudo -H npm install iobroker.admin
    > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using request for node-pre-gyp https download
    node-pre-gyp WARN Pre-built binaries not installable for canvas@2.6.1 and node@10.23.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
    node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
    gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/10.23.0"
    gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
    gyp ERR! configure error
    gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
    gyp ERR! System Linux 5.4.79-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v10.23.0
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 5.4.79-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v10.23.0
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 (node_modules/canvas):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    + iobroker.admin@4.2.1
    removed 2 packages and updated 1 package in 29.361s
    17 packages are looking for funding
      run `npm fund` for details
    @thwe12 sagte in Nicht alle Instanzen werden angezeigt:
    gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/10.23.0" gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
    ohhh
    was ist denn da schief gelaufen?
    als root installiert?
    Das wäre was für @Thomas-Braun
    • T THWE12
      cd /opt/iobroker
      iobroker u admin
      gyp ERR! not ok
      pi@raspberrypi:/opt/iobroker $ iobroker u admin
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      Update "system.adapter.admin.0"
      @thwe12 Nach deinem Edit:
      jetzt mal im Browser STRG-F5 und sehen ob es vielleicht doch passt
        ohhh
        THWE12
        ohhh
        Das kann ich dir nicht sagen den habe ich vor 1,5 Jahren aufgesetzt ob das als root war kann ich nicht sagen
        • GlasfaserG Offline
          GlasfaserG Offline
          die Frage ist , warum bekommt er nichts mit
          iobroker version
          angezeigt ...
          HomoranH T 2 Antworten Letzte Antwort
            THWE12
            Nö leider micht :-(
            • GlasfaserG Glasfaser
              iobroker version
              angezeigt ...
              @THWE12
              @glasfaser auch nicht mit iobroker -v?
              ggf. ist die gesamte Installation krumm
              • T THWE12
                Nö leider micht :-(
                GlasfaserG Offline
                GlasfaserG Offline
                #66
                @thwe12
                was ist mit
                iobroker -v
                  @THWE12
                  THWE12
                  #67
                  @THWE12
                  Na dann werde ich wohl nicht herum kommen und das System neu aufzusetzen.
                  Hatte gehopft dieser Kelch geht an mir vorüber
                    iobroker version
                    angezeigt ...
                    THWE12
                    #68
                    @glasfaser sagte in Nicht alle Instanzen werden angezeigt:
                    iobroker version
                    angezeigt ...
                    pi@raspberrypi:~ $ iobroker version
                    3.1.6
                    • T THWE12
                      iobroker version
                      angezeigt ...
                      3.1.6
                      #69
                      @thwe12 und das hatte vor deinen Upgrades nicht geklappt?
                        THWE12
                        #70
                        Jetzt stehe ich auf dem Schlauch.
                        Hatten wir das schon mal versucht??
                        • T THWE12
                          iobroker version
                          angezeigt ...
                          3.1.6
                          #71
                          @thwe12
                          Und wenn du mal von 'unten anfängst' das System zu updaten?
                          Manchmal zieht sich die Installation dann wieder gerade.
                          sudo apt update
                          sudo apt dist-upgrade
                          sudo reboot
                          iobroker stop
                          iobroker fix
                          iobroker update
                          iobroker upgrade
                          Das wäre so meine Vorgehensweise.
                            @thwe12
                            sudo apt update
                            sudo reboot
                            iobroker stop
                            iobroker fix
                            iobroker update
                            iobroker upgrade
                            THWE12
                            #72
                            @thomas-braun sagte in Nicht alle Instanzen werden angezeigt:
        sudo apt update        sudo apt dist-upgrade        sudo reboot
                            sudo apt update
                            sudo reboot
                            bis dahin hab ich jetzt es gemacht aber jetzt kann ich mich nicht mehr einloggen
                            • T THWE12
                              sudo apt update
                              sudo reboot
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #73
                              @thwe12
                              iobroker start
                                @thwe12
                                iobroker start
                                THWE12
                                #74
                                @thwe12
                                iobroker start
                                nach dem reboot bin ich rausgeflogen
                                jetzt geht es aber weiter :-)
                                iobroker stop
                                iobroker fix
                                iobroker update
                                iobroker upgrade
                                • T THWE12
                                  @thwe12
                                  iobroker start
                                  iobroker stop
                                  iobroker fix
                                  iobroker update
                                  iobroker upgrade
                                  THWE12
                                  #75
                                  @thwe12
                                  iobroker start
                                  iobroker stop
                                  iobroker fix
                                  iobroker update
                                  iobroker upgrade
                                  nun ist alles durch aber es hat sich nichts verändert :-(
                                  • T THWE12
                                    @thwe12
                                    iobroker start
                                    iobroker stop
                                    iobroker fix
                                    iobroker update
                                    iobroker upgrade
                                    #76
                                    @thwe12
                                    uname -a
                                    sagt?
                                      @thwe12
                                      uname -a
                                      sagt?
                                      THWE12
                                      #77
                                      uname -a
                                      pi@raspberrypi:~ $ uname -a
                                      Linux raspberrypi 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7l GNU/Linux
                                      • T THWE12
                                        uname -a
                                        #78
                                        @thwe12
                                        Wenn ich mir den Hantier mit sudo / Installation im ~ von root usw. anschaue: Total verfummelt.
                                        Vermutlich ist abreißen und neubauen die beste Lösung. Auch wenn ich da ungern zu rate.
                                        Nur eins: Vermeide den root-Login! Damit zerballerst du dir halt nur das System.
                                        sudo -u iobroker id
                                        sagt?
                                          @thwe12
                                          sudo -u iobroker id
                                          sagt?
                                          THWE12
                                          #79
                                          sudo -u iobroker id
                                          pi@raspberrypi:~ $ sudo -u iobroker id
                                          uid=1001(iobroker) gid=1001(iobroker) Gruppen=1001(iobroker),5(tty),20(dialout),29(audio),44(video),112(bluetooth),997(gpio),998(i2c)
                                          antwort
