  3. Entwicklung
  4. Adapter für probe request monitoring
    5.6k
33 Beiträge 7 Kommentatoren 8.1k Aufrufe
  • ruhr70R Offline
    ruhr70R Offline
    ruhr70
    Der nächste Schritt…
    ich habe auf Grund der Fehlermeldung in meinem Post oben nun
    apt-get install git
    ausgeführt und dann erneut versucht den probe-Adapter zu installieren.
    Nun hängt es an der nächsten Stelle (Fehlermeldungen bei der Installation):
    $ ./iobroker url "https://github.com/DerKorb/ioBroker.probemon"
    install https://github.com/DerKorb/ioBroker.probemon/tarball/master
    npm install https://github.com/DerKorb/ioBroker.probemon/tarball/master --production --prefix "/opt/iobroker" (System call)
    ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include <pcap pcap.h="">
    compilation terminated.
    ! make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1
    gyp
    ERR! build error
    gyp
    ERR!
    stack Error: make failed with exit code: 2
    gyp
    ERR!
    stack
    at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp
    ERR!
    stack at emitTwo (events.js:87:13)gyp
    ERR!
    stack
    at ChildProcess.emit (events.js:172:7)gyp
    ERR!
    stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
    gyp
    ERR! System
    Linux 4.4.33-v7+
    gyp
    ERR! command
    "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp
    ERR!
    cwd
    /opt/iobroker/node_modules/iobroker.probemon/node_modules/pcapgyp
    ERR!
    node -v
    v4.6.2gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    ! npm
    ERR! Linux 4.4.33-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/DerKorb/ioBroker.probemon/tarball/master" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.6.2
    npm ERR! npm v2.15.11
    npm
    ERR! code ELIFECYCLE
    npm ERR! pcap@2.0.0 install: node-gyp rebuild
    ! npm ERR! Exit status 1npm
    ERR! npm ERR! Failed at the pcap@2.0.0 install script 'node-gyp rebuild'.
    npm ERR! This is most likely a problem with the pcap package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!
    node-gyp rebuildnpm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs pcap
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR! npm owner ls pcap
    npm ERR!
    There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
    ! ERROR: host.rasp31 Cannot install https://github.com/DerKorb/ioBroker.probemon/tarball/master: 1
    ERROR: process exited with code 25</pcap>
    [EDIT]
    Ich versuche es zu verstehen.
    Sieht so aus als könnte das pcap Module nicht installiert werden
    [https://github.com/mranney/node_pcap](https://github.com/mranney/node_pcap)
      drekrob
      Oh gut dass du es sagst, lib pcap benötigt libpcap-dev als dependency, steht bei denen im README, aber werd ich bei meinem Adapter auch mal noch dazuschreieben.
      • ruhr70R Offline
        ruhr70R Offline
        ruhr70
        Nach:
        apt-get install libpcap-dev
        Konnte ich jetzt den Adapter installieren. :-)
        Es werden allerdings keine Datenpunkte für die gemonitorten Geräte angelegt. :?:
        Interfaces:
        # iw dev
        phy#0
        	Interface mon0
        		ifindex 4
        		wdev 0x2
        		addr 00:00:00:00:00:00
        		type monitor
        	Interface wlan0
        		ifindex 3
        		wdev 0x1
        		addr ec:08:6b:xx:xx:xx
        		type managed
        Einstellungen des dapters:
          drekrob
          schau mal ob im log was verdächtiges steht.
          • ruhr70R Offline
            ruhr70R Offline
            ruhr70
            Ich habe auf Debug gestellt und einen Messpunkt gelöscht und wieder eingerichtet.
            Im Log sehe ich dazu nichts. Beim Starten des Adapters kommt nur:
            	object change system.adapter.probemon.0
              drekrob
              stell sicher, dass der adapter log level auf debug gestellt ist (expertenmodus bei instances).
              Der Adapter sollte beim starten "creating pcap session" loggen.
              Wenn das nicht passiert, geht schon sehr früh was schief.
              Was du machen kannst um bessere Fehlerinfos zu bekommen ist per ssh auf dem Server OS
              node /opt/iobroker/node_modules/iobroker.probemon/main.js
              ausführen. Das sollte dann einen Fehler ausspucken.
              • ruhr70R Offline
                ruhr70R Offline
                ruhr70
                Debug hatte ich eingestellt.
                "creating pcap session" kommt.
                Anbei der entsprechende Log:
                host. 2016-11-28 19:05:07.156 debug redis mget 2 2
                host. 2016-11-28 19:05:07.150 debug redis publish io.system.adapter.probemon.0.uptime {"val":2,"ack":true,"ts":1480356307150,"q":0,"from":"system.adapter.probemon.0","lc":1480356307150}
                host. 2016-11-28 19:05:07.148 debug redis publish io.system.adapter.probemon.0.memHeapUsed {"val":10.32,"ack":true,"ts":1480356307148,"q":0,"from":"system.adapter.probemon.0","lc":1480356307148}
                host. 2016-11-28 19:05:07.147 debug redis publish io.system.adapter.probemon.0.memHeapTotal {"val":17.26,"ack":true,"ts":1480356307147,"q":0,"from":"system.adapter.probemon.0","lc":1480356307147}
                host. 2016-11-28 19:05:07.146 debug redis publish io.system.adapter.probemon.0.memRss {"val":27.85,"ack":true,"ts":1480356307145,"q":0,"from":"system.adapter.probemon.0","lc":1480356307145}
                host. 2016-11-28 19:05:07.144 debug redis publish io.system.adapter.probemon.0.connected {"val":true,"ack":true,"ts":1480356307142,"q":0,"from":"system.adapter.probemon.0","lc":1480356307142}
                host. 2016-11-28 19:05:07.141 debug redis publish io.system.adapter.probemon.0.alive {"val":true,"ack":true,"ts":1480356307141,"q":0,"from":"system.adapter.probemon.0","lc":1480356307141}
                host. 2016-11-28 19:05:07.137 debug redis keys 2 .logging
                host. 2016-11-28 19:05:07.133 debug redis psubscribe io.probemon.0.
                probemon.0 2016-11-28 19:05:07.061 info creating pcap session
                probemon.0 2016-11-28 19:05:07.054 info starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.probemon, node: v4.6.2
                host. 2016-11-28 19:05:07.033 debug redis get system.adapter.probemon.0.alive ok: {"val":false,"ack":true,"ts":1480356303002,"q":0,"from":"system.host.rasp31","lc":1480356302907}
                host. 2016-11-28 19:05:07.017 info States connected to redis 172.16.130.210:6379
                probemon.0 2016-11-28 19:05:06.992 debug statesDB connected
                probemon.0 2016-11-28 19:05:06.959 debug objectDB connected
                host.rasp31 2016-11-28 19:05:05.443 info instance system.adapter.probemon.0 started with pid 28155
                host.rasp31 2016-11-28 19:05:03.000 info instance system.adapter.probemon.0 terminated with code 0 (OK)
                host.rasp31 2016-11-28 19:05:02.901 info stopInstance system.adapter.probemon.0 killing pid 15480
                host.rasp31 2016-11-28 19:05:02.900 info stopInstance system.adapter.probemon.0
                probemon.0 2016-11-28 19:05:02.909 info terminating
                probemon.0 2016-11-28 19:05:02.904 info cleaned everything up...
                host.rasp31 2016-11-28 19:05:02.891 info object change system.adapter.probemon.0
                nach:
                kommt keine Ausgabe. Nur der Prompt.
                Dann habe ich den Adapter noch einmal gelöscht und wieder eingerichtet (ohen Debug direkt nach der Neueinrichtung):
                probemon.0	2016-11-28 20:02:22.100	info	creating pcap session
                probemon.0	2016-11-28 20:02:22.091	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.probemon, node: v4.6.2
                host.	2016-11-28 20:02:22.037	info	States connected to redis 172.16.130.210:6379
                iobroker	2016-11-28 20:02:20.432	info	exit 0
                iobroker	2016-11-28 20:02:20.430	info	host.rasp31 object system.adapter.probemon.0 created
                host.rasp31	2016-11-28 20:02:20.429	info	instance system.adapter.probemon.0 started with pid 1314
                host.rasp31	2016-11-28 20:02:20.414	info	object change system.adapter.probemon.0
                iobroker	2016-11-28 20:02:20.381	info	host.rasp31 object system.adapter.probemon.0.alive created
                iobroker	2016-11-28 20:02:20.350	info	host.rasp31 object system.adapter.probemon.0.connected created
                iobroker	2016-11-28 20:02:20.319	info	host.rasp31 object system.adapter.probemon.0.memHeapUsed created
                iobroker	2016-11-28 20:02:20.288	info	host.rasp31 object system.adapter.probemon.0.memHeapTotal created
                iobroker	2016-11-28 20:02:20.257	info	host.rasp31 object system.adapter.probemon.0.memRss created
                iobroker	2016-11-28 20:02:20.220	info	host.rasp31 object system.adapter.probemon.0.uptime created
                iobroker	2016-11-28 20:02:20.187	info	host.rasp31 object system.adapter.probemon.upload created
                iobroker	2016-11-28 20:02:20.170	info	host.rasp31 create instance probemon
                iobroker	2016-11-28 20:02:18.385	info	add probemon
                iobroker	2016-11-28 20:01:36.940	info	exit 0
                Datenpunkte für die zu überwachenden Geräte wurden zu keinem Zeitpunkt angelegt.
                  drekrob
                  wenn die meldung kommt heißt es immerhin schon mal, dass der adapter generell läuft. Dann stimmt was mit dem mac addressen abgleich nicht oder du bekommst die probe-requests nicht.
                  Hast du Zugangsdaten fürs Wlan angelegt? Wenn der Stick in keinem Netzwerk ist geht es nicht vermute ich.
                  Ich hab den Adapter vorhin überarbeitet, probier mal die neuste Version.
                  • ruhr70R Offline
                    ruhr70R Offline
                    ruhr70
                    @drekrob:
                    wenn die meldung kommt heißt es immerhin schon mal, dass der adapter generell läuft. Dann stimmt was mit dem mac addressen abgleich nicht oder du bekommst die probe-requests nicht. `
                    Die MAC-Adressen werden mit Doppelpunkt eingegeben? ba<emoji seq="1f1e9-1f1ea">🇩🇪</emoji>fe:ba<emoji seq="1f1e9-1f1ea">🇩🇪</emoji>fe ?
                    Hat mon0 bei Dir auch die Adresse 00:00:00:00:00:00 ?
                    # iw dev
                    phy#0
                    	Interface mon0
                    		ifindex 4
                    		wdev 0x2
                    		type monitor
                    @drekrob:
                    Hast du Zugangsdaten fürs Wlan angelegt? Wenn der Stick in keinem Netzwerk ist geht es nicht vermute ich. `
                    Nein. Habe ich nicht. Ich hatte den Adapter so verstanden, das auf de WLAN Schittstelle gelauscht wird.
                    Die Geräte, die ich damit sehen könnte, sind ja auch nicht unbedingt in meinem WLAN eingebucht.
                    Sonst hättest Du in der ersten Version ja nicht hunderte Geräte sehen können.
                    Morgen melde ich den Stick mal in meinem WLAN an.
                    @drekrob:
                    Ich hab den Adapter vorhin überarbeitet, probier mal die neuste Version. `
                    Installiert. Die Datenpunkte der Geräte werden weiterhin nicht angelegt.
                    Dafür gibt es jetzt einen Datenpunkt probemon.0.nsamode.raw_proberequest ;-)
                    Allerdings auch ohne Wert.
                      drekrob
                      mac addressen mit doppelpunkt und kleinbuchstaben.
                      Hab gerade noch mal gepusht, war noch ein bug drin.
                      Ich vermute, dass du den Stick einwählen musst oder zumindest nen Hotspot aufmachen, da kenn ich mich auch nicht wirklich aus. Würde aber auch die nuller mac erklären.
                      Die raw_proberequests sind drin damit du alles Geräte tracken kannst.
                      Würde ich gerne noch als bool option in die config setzen, muss mal nachlesen wie das geht.
                      • ruhr70R Offline
                        ruhr70R Offline
                        ruhr70
                        Version installiert.
                        Doppelpunkt und Kleinbuchstaben…passt.
                        Kann das sein, dass sich die Versionsnummern der letzten drei versionen nicht geändert haben (0.0.3)?
                        Wird bei Dir bei iwd dev unter mon0 keine 00:00:00:00:00:00 Mac-Adresse angezeigt?
                        Wenn nein, welche denn? Die vom WLAN-Stick?
                          drekrob
                          Bei mir wird eine mac addresse angezeigt. Ich nehme an es ist die vom Stick. Versuch doch erst mal dich in ein wifi einzuwählen.
                          • F Offline
                            friemelkarl
                            Wird der Adapter noch weiterentwickelt?
                            Würde den gerne einsetzen.
                            • Jey CeeJ Online
                              Jey CeeJ Online
                              Jey Cee
                              @friemelkarl:
                              Gruß `
                              Sieht nicht so aus, letzte Aktivität im Adapter Repo war 2016 und damit ist der Adapter nicht Lauffähig mit der Aktuellen ioBroker Version.
                              Persönlicher Support
                              Spenden -> paypal.me/J3YC33
                              • F Offline
                                friemelkarl
                                Schade!
                                Aber Danke für die Info!
                                • F Offline
                                  friemelkarl
                                  Gibt es denn ne andere Möglichkeit mein Vorhaben umzusetzen?
                                    Smart86
                                    Gibt es hier vielleicht noch jemanden, der den Adapter zum Laufen bekommen hat? Ich habe auch das Problem, dass keine Datenpunkte angelegt werden.
