  3. Entwicklung
  4. Adapter für probe request monitoring
    5.6k
33 Beiträge 7 Kommentatoren 8.1k Aufrufe
  • ruhr70R Offline
    ruhr70R Offline
    ruhr70
    Debug hatte ich eingestellt.
    "creating pcap session" kommt.
    Anbei der entsprechende Log:
    host. 2016-11-28 19:05:07.156 debug redis mget 2 2
    host. 2016-11-28 19:05:07.150 debug redis publish io.system.adapter.probemon.0.uptime {"val":2,"ack":true,"ts":1480356307150,"q":0,"from":"system.adapter.probemon.0","lc":1480356307150}
    host. 2016-11-28 19:05:07.148 debug redis publish io.system.adapter.probemon.0.memHeapUsed {"val":10.32,"ack":true,"ts":1480356307148,"q":0,"from":"system.adapter.probemon.0","lc":1480356307148}
    host. 2016-11-28 19:05:07.147 debug redis publish io.system.adapter.probemon.0.memHeapTotal {"val":17.26,"ack":true,"ts":1480356307147,"q":0,"from":"system.adapter.probemon.0","lc":1480356307147}
    host. 2016-11-28 19:05:07.146 debug redis publish io.system.adapter.probemon.0.memRss {"val":27.85,"ack":true,"ts":1480356307145,"q":0,"from":"system.adapter.probemon.0","lc":1480356307145}
    host. 2016-11-28 19:05:07.144 debug redis publish io.system.adapter.probemon.0.connected {"val":true,"ack":true,"ts":1480356307142,"q":0,"from":"system.adapter.probemon.0","lc":1480356307142}
    host. 2016-11-28 19:05:07.141 debug redis publish io.system.adapter.probemon.0.alive {"val":true,"ack":true,"ts":1480356307141,"q":0,"from":"system.adapter.probemon.0","lc":1480356307141}
    host. 2016-11-28 19:05:07.137 debug redis keys 2 .logging
    host. 2016-11-28 19:05:07.133 debug redis psubscribe io.probemon.0.
    probemon.0 2016-11-28 19:05:07.061 info creating pcap session
    probemon.0 2016-11-28 19:05:07.054 info starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.probemon, node: v4.6.2
    host. 2016-11-28 19:05:07.033 debug redis get system.adapter.probemon.0.alive ok: {"val":false,"ack":true,"ts":1480356303002,"q":0,"from":"system.host.rasp31","lc":1480356302907}
    host. 2016-11-28 19:05:07.017 info States connected to redis 172.16.130.210:6379
    probemon.0 2016-11-28 19:05:06.992 debug statesDB connected
    probemon.0 2016-11-28 19:05:06.959 debug objectDB connected
    host.rasp31 2016-11-28 19:05:05.443 info instance system.adapter.probemon.0 started with pid 28155
    host.rasp31 2016-11-28 19:05:03.000 info instance system.adapter.probemon.0 terminated with code 0 (OK)
    host.rasp31 2016-11-28 19:05:02.901 info stopInstance system.adapter.probemon.0 killing pid 15480
    host.rasp31 2016-11-28 19:05:02.900 info stopInstance system.adapter.probemon.0
    probemon.0 2016-11-28 19:05:02.909 info terminating
    probemon.0 2016-11-28 19:05:02.904 info cleaned everything up...
    host.rasp31 2016-11-28 19:05:02.891 info object change system.adapter.probemon.0
    nach:
    node /opt/iobroker/node_modules/iobroker.probemon/main.js
    kommt keine Ausgabe. Nur der Prompt.
    Dann habe ich den Adapter noch einmal gelöscht und wieder eingerichtet (ohen Debug direkt nach der Neueinrichtung):
    probemon.0	2016-11-28 20:02:22.100	info	creating pcap session
    probemon.0	2016-11-28 20:02:22.091	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.probemon, node: v4.6.2
    host.	2016-11-28 20:02:22.037	info	States connected to redis 172.16.130.210:6379
    iobroker	2016-11-28 20:02:20.432	info	exit 0
    iobroker	2016-11-28 20:02:20.430	info	host.rasp31 object system.adapter.probemon.0 created
    host.rasp31	2016-11-28 20:02:20.429	info	instance system.adapter.probemon.0 started with pid 1314
    host.rasp31	2016-11-28 20:02:20.414	info	object change system.adapter.probemon.0
    iobroker	2016-11-28 20:02:20.381	info	host.rasp31 object system.adapter.probemon.0.alive created
    iobroker	2016-11-28 20:02:20.350	info	host.rasp31 object system.adapter.probemon.0.connected created
    iobroker	2016-11-28 20:02:20.319	info	host.rasp31 object system.adapter.probemon.0.memHeapUsed created
    iobroker	2016-11-28 20:02:20.288	info	host.rasp31 object system.adapter.probemon.0.memHeapTotal created
    iobroker	2016-11-28 20:02:20.257	info	host.rasp31 object system.adapter.probemon.0.memRss created
    iobroker	2016-11-28 20:02:20.220	info	host.rasp31 object system.adapter.probemon.0.uptime created
    iobroker	2016-11-28 20:02:20.187	info	host.rasp31 object system.adapter.probemon.upload created
    iobroker	2016-11-28 20:02:20.170	info	host.rasp31 create instance probemon
    iobroker	2016-11-28 20:02:18.385	info	add probemon
    iobroker	2016-11-28 20:01:36.940	info	exit 0
    Datenpunkte für die zu überwachenden Geräte wurden zu keinem Zeitpunkt angelegt.
      drekrob
      wenn die meldung kommt heißt es immerhin schon mal, dass der adapter generell läuft. Dann stimmt was mit dem mac addressen abgleich nicht oder du bekommst die probe-requests nicht.
      Hast du Zugangsdaten fürs Wlan angelegt? Wenn der Stick in keinem Netzwerk ist geht es nicht vermute ich.
      Ich hab den Adapter vorhin überarbeitet, probier mal die neuste Version.
      • ruhr70R Offline
        ruhr70R Offline
        ruhr70
        @drekrob:
        wenn die meldung kommt heißt es immerhin schon mal, dass der adapter generell läuft. Dann stimmt was mit dem mac addressen abgleich nicht oder du bekommst die probe-requests nicht. `
        Die MAC-Adressen werden mit Doppelpunkt eingegeben? ba<emoji seq="1f1e9-1f1ea">🇩🇪</emoji>fe:ba<emoji seq="1f1e9-1f1ea">🇩🇪</emoji>fe ?
        Hat mon0 bei Dir auch die Adresse 00:00:00:00:00:00 ?
        # iw dev
        phy#0
        	Interface mon0
        		ifindex 4
        		wdev 0x2
        		addr 00:00:00:00:00:00
        		type monitor
        @drekrob:
        Hast du Zugangsdaten fürs Wlan angelegt? Wenn der Stick in keinem Netzwerk ist geht es nicht vermute ich. `
        Nein. Habe ich nicht. Ich hatte den Adapter so verstanden, das auf de WLAN Schittstelle gelauscht wird.
        Die Geräte, die ich damit sehen könnte, sind ja auch nicht unbedingt in meinem WLAN eingebucht.
        Sonst hättest Du in der ersten Version ja nicht hunderte Geräte sehen können.
        Morgen melde ich den Stick mal in meinem WLAN an.
        @drekrob:
        Ich hab den Adapter vorhin überarbeitet, probier mal die neuste Version. `
        Installiert. Die Datenpunkte der Geräte werden weiterhin nicht angelegt.
        Dafür gibt es jetzt einen Datenpunkt probemon.0.nsamode.raw_proberequest ;-)
        Allerdings auch ohne Wert.
          drekrob
          mac addressen mit doppelpunkt und kleinbuchstaben.
          Hab gerade noch mal gepusht, war noch ein bug drin.
          Ich vermute, dass du den Stick einwählen musst oder zumindest nen Hotspot aufmachen, da kenn ich mich auch nicht wirklich aus. Würde aber auch die nuller mac erklären.
          Die raw_proberequests sind drin damit du alles Geräte tracken kannst.
          Würde ich gerne noch als bool option in die config setzen, muss mal nachlesen wie das geht.
          • ruhr70R Offline
            ruhr70R Offline
            ruhr70
            Version installiert.
            Doppelpunkt und Kleinbuchstaben…passt.
            Kann das sein, dass sich die Versionsnummern der letzten drei versionen nicht geändert haben (0.0.3)?
            Wird bei Dir bei iwd dev unter mon0 keine 00:00:00:00:00:00 Mac-Adresse angezeigt?
            Wenn nein, welche denn? Die vom WLAN-Stick?
              drekrob
              Bei mir wird eine mac addresse angezeigt. Ich nehme an es ist die vom Stick. Versuch doch erst mal dich in ein wifi einzuwählen.
              • F Offline
                friemelkarl
                Wird der Adapter noch weiterentwickelt?
                Würde den gerne einsetzen.
                • Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  @friemelkarl:
                  Gruß `
                  Sieht nicht so aus, letzte Aktivität im Adapter Repo war 2016 und damit ist der Adapter nicht Lauffähig mit der Aktuellen ioBroker Version.
                  Persönlicher Support
                  Spenden -> paypal.me/J3YC33
                  • F Offline
                    friemelkarl
                    Schade!
                    Aber Danke für die Info!
                    • F Offline
                      friemelkarl
                      Gibt es denn ne andere Möglichkeit mein Vorhaben umzusetzen?
                        Smart86
                        Gibt es hier vielleicht noch jemanden, der den Adapter zum Laufen bekommen hat? Ich habe auch das Problem, dass keine Datenpunkte angelegt werden.
