  4. Test Adapter Nuki-extended v2.0.x
nuki-extended adapternuki
599 Beiträge 65 Kommentatoren 178.1k Aufrufe 51 Beobachtet
    @Paul-OL
    Bitte keine Screenshots sondern als Text (in CodeTags) hier rein.
    #432
    @Thomas-Braun
    Danke für deinen Einsatz. Wie es scheint, brauchte es einige Neustarts oder Minuten um sich zu aktualisieren. Es hat dann einfach nach einiger zeit die Ordner selber angezeigt.
    • ? Offline
      #433
      Aber die Instanz is gelb
      web.0	2021-01-01 20:05:05.480	info	(27951) ==>Connected system.user.admin from ::ffff:192.168.1.153
      javascript.0	2021-01-01 20:04:57.239	info	(19995) script.js.Klingel: registered 1 subscription and 0 schedules
      javascript.0	2021-01-01 20:04:57.227	info	(19995) Start javascript script.js.Klingel
      javascript.0	2021-01-01 20:04:57.212	info	(19995) Stop script script.js.Klingel
      javascript.0	2021-01-01 19:52:40.574	info	(19995) script.js.Klingel: registered 1 subscription and 0 schedules
      javascript.0	2021-01-01 19:52:40.568	info	(19995) Start javascript script.js.Klingel
      javascript.0	2021-01-01 19:52:39.232	info	(19995) Stop script script.js.Klingel
      web.0	2021-01-01 19:50:00.206	info	(27951) <==Disconnect system.user.admin from ::ffff:192.168.1.153 vis.0
      web.0	2021-01-01 19:49:58.738	info	(27951) ==>Connected system.user.admin from ::ffff:192.168.1.153
      nuki-extended.0	2021-01-01 19:49:41.796	info	(13898) Listening for Nuki events on port 51989.
      nuki-extended.0	2021-01-01 19:49:41.794	info	(13898) Polling Nuki Web API deactivated.
      nuki-extended.0	2021-01-01 19:49:39.987	info	(13898) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v12.20.0, js-controller: 3.1.6
      host.raspberrypi	2021-01-01 19:49:37.847	info	instance system.adapter.nuki-extended.0 started with pid 13898
      host.raspberrypi	2021-01-01 19:49:35.356	info	instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      nuki-extended.0	2021-01-01 19:49:34.837	info	(9463) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      nuki-extended.0	2021-01-01 19:49:34.835	info	(9463) terminating
      nuki-extended.0	2021-01-01 19:49:34.834	info	(9463) Adapter stopped und unloaded.
      nuki-extended.0	2021-01-01 19:49:34.830	info	(9463) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2021-01-01 19:49:34.824	info	stopInstance system.adapter.nuki-extended.0 send kill signal
      host.raspberrypi	2021-01-01 19:49:34.822	info	stopInstance system.adapter.nuki-extended.0 (force=false, process=true)
      javascript.0	2021-01-01 19:46:04.217	info	(19995) script.js.NachrichtWohnungsTuer: registered 1 subscription and 0 schedules
      javascript.0	2021-01-01 19:46:04.159	info	(19995) Start javascript script.js.NachrichtWohnungsTuer
      javascript.0	2021-01-01 19:46:01.214	info	(19995) Stop script script.js.NachrichtWohnungsTuer
      web.0	2021-01-01 19:43:06.471	info	(27951) <==Disconnect system.user.admin from ::ffff:192.168.1.153 vis.0
      web.0	2021-01-01 19:43:05.166	info	(27951) ==>Connected system.user.admin from ::ffff:192.168.1.153
      nuki-extended.0	2021-01-01 19:42:35.557	info	(9463) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v12.20.0, js-controller: 3.1.6
      host.raspberrypi	2021-01-01 19:42:33.649	info	instance system.adapter.nuki-extended.0 started with pid 9463
      host.raspberrypi	2021-01-01 19:42:31.173	info	instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      nuki-extended.0	2021-01-01 19:42:30.653	info	(8794) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      nuki-extended.0	2021-01-01 19:42:30.650	info	(8794) terminating
      nuki-extended.0	2021-01-01 19:42:30.644	info	(8794) Adapter stopped und unloaded.
      nuki-extended.0	2021-01-01 19:42:30.633	info	(8794) Got terminate signal TERMINATE_YOURSELF
        #434
        @Paul-OL sagte in Test Adapter Nuki-extended v2.0.x:
        Bei mir wir da gepollt.
          #435
          @Thomas-Braun Was bedeutet gepollt?
          Was muss ich jetzt machen?
          Auserdem , sehe ich, dass es den Zustand "ringState" gibt. Der ändert sich aber nicht zurück auf false.
          Wie soll ich das Klingeln den abgreifen?
          Ich will dass beim Klingeln die Lampe 3 mal leuchtet.
            #436
            @Paul-OL Sprichst du auch beide APIs an?
            nuki bride und nuki web?
            Bei nuki web muss auch ein Intervall gesetzt werden, bei 0 wird nicht gepollt/abgerufen. Ich habe da 10 Sekunden drin.
              #437
              @Thomas-Braun
              Ja, ich habe beide API`s drin.
              Nun habe ich die 10 sekunden eingetragen und es funktioniert besser. Ich werde es weiter beobachten.
              Danke für deinen Einsatz. Ich weiß das zu schätzen.
                mcbarney
                #438
                Ich bin Newbie im Bereich NUKI und IOBROKER und habe da ein Problem.
                ich würde gerne den die variable ringStateUpdate auslesen. Leider bekommen ich diese unter den opener State Variablen nicht angezeigt:
                In dieser Ansicht bekomme ich angezeigt das es an der Tür geklingelt hat:
                Firmwareversionen sind wie folgt:
                Bridge: 2.8.0
                Opener: 1.6.4
                Adapterversion:
                Nuki Extended: 2.3.0
                Admin: 4.1.11
                Ich hoffe ihr könnt mir eventuell mit den Daten schon weiterhelfen.
                Wenn nicht sagt mir bitte welche Infos ihr noch von mir braucht.
                Vielen Dank und Grüße
                Dirk
                Dr. BakteriusD 1 Antwort Letzte Antwort
                • M mcbarney
                  Bridge: 2.8.0
                  Opener: 1.6.4
                  Adapterversion:
                  Admin: 4.1.11
                  Dirk
                  Dr. BakteriusD Online
                  Dr. Bakterius
                  #439
                  @mcbarney Bist du auch im richtigen Ordner? Ich habe zwar keinen Opener, aber mir sieht das sehr danach aus, dass du im Ordner vom Smartlock suchst. Wie sieht denn die Ordnerstruktur (inkl. Unterordner) unter nuki-extended.0 aus?
                  Thomas BraunT M 2 Antworten Letzte Antwort
                    #440
                    @dr-bakterius
                    Ich glaube hier wäre eine Antwort günstiger:
                    https://forum.iobroker.net/topic/41357/nuki-ringstateupdate-nicht-verfügbar?_=1611504536016
                      mcbarney
                      #441
                      @dr-bakterius hi vielen Dank schonmal für deine Rückmeldung. Lass uns hier weitermachen:
                      Habe dort nochmal einen Screenshot von der Strucktur hinterlegt.
                      Dirk
                      G 1 Antwort Letzte Antwort
                      • M mcbarney
                        Dirk
                        gizmodlx
                        #442
                        Hi zusammen! Ich bin bei meinen bisherigen Recherchen leider zu keiner Antwort gekommen. Gibt es eine Möglichkeit, die Nuki-Ereignisse (Öffnung durch Person X, Schließung durch Person Y) abzufragen und sich dann entsprechend benachrichtigen zu lassen?
                        Ich kenne die Benachrichtigungsoption in der NUKI-App. Mir geht es aber darum, diese Nachrichten auch im ioBroker entsprechend zu verarbeiten. Und dazu finde ich einfach nichts.
                        • JackDanielJ Online
                          JackDanielJ Online
                          JackDaniel
                          #443
                          hmm ja müsste gehen, bei diesem adapter hast du ja unter jedem benutzer einen dp datelastActive was man als auslöser verwenden könnte, und mit dem dp lastAction vom schloss könnte man identifizieren was gemacht wurde
                          Carpe diem
                          G 2 Antworten Letzte Antwort
                          • JackDanielJ JackDaniel
                            gizmodlx
                            #444
                            @jackdaniel Prima! Danke für den Tipp. Das sieht in der Tat vielversprechend aus. Schaue ich mir mal an.
                            In der Doku vom Adapter findet man auch Infos zu einem Knoten "notifications". Allerdings finde ich den partout nicht.
                            • G gizmodlx
                              Dr. Bakterius
                              #445
                              @gizmodlx sagte in Test Adapter Nuki-extended v2.0.x:
                              Hier?
                                Hier?
                                gizmodlx
                                #446
                                @dr-bakterius Ok, da hab ich mich unklar ausgedrückt :-)
                                Die "Notifications" hab ich auch im Baum "Info" gefunden, nicht jedoch die in der Doku erwähnten "notifications.notificationindex...."
                                  gizmodlx
                                  #447
                                  @jackdaniel said in Test Adapter Nuki-extended v2.0.x:
                                  Leider scheinen diese Infos nicht zeitnah aktualisiert zu werden - trotz Abrufintervall von 10 Sekunden habe ich teils nach Stunden hier noch kein Status-Update. Ich vermute das lässt sich so derzeit nicht sinnvoll nutzen.
                                  • G gizmodlx
                                    Dr. Bakterius
                                    #448
                                    @gizmodlx Bis auf 'referenceId' und 'secret' ist doch alles da. Zumindest bei mir...
                                      gizmodlx
                                      schrieb am zuletzt editiert von gizmodlx
                                      #449
                                      @dr-bakterius stimmt. ich hatte fälschlicherweise nach den Channelnamen gesucht. Aber irgendwie scheint da leider auch nix brauchbares dabei zu sein. schon seltsam, da Nuki selbst die Notifications ja nutzt und auch zeitnah verschickt
                                      Also laut "webApiLast" werden die Infos regelmäßig (wie konfiguriert) synchronisiert. Im Log ist auch kein Fehler erkennbar.
                                      Trotzdem ist "dateUpdated" in dem Userzweig komplett veraltet (Stand vor 10 Stunden). Sollten die Userinfos nicht ebenfalls synchronisiert werden und somit den gleichen Timestamp wie "webApiLast" haben?
                                      • G gizmodlx
                                        Dr. Bakterius
                                        #450
                                        Das stimmt leider. Bei mir wurde mein letzter Unlock von gestern Nachmittag bis jetzt nicht übernommen. Ist derzeit also leider unnutzbar. 😞
                                          gizmodlx
                                          #451
                                          @dr-bakterius Danke für die Rückmeldung. Dann liegt es zumindest nicht an meiner Config :-)
                                          @Zefau Vielleicht könntest du das in einer der nächsten Versionen berücksichtigen? Ebenfalls hilfreich für die Automatisierung wäre, wenn man auf die Informationen der Historie die man über die Adapter-Webseite ja grundsätzlich abrufen kann (die scheinen auch aktuell zu sein), direkt in ioBroker zugreifen könnte.
