  4. Upgrade zigbee immer error
    6.7k
zigbee
44 Beiträge 4 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • chucky666C chucky666
    @unclesam sagte in Upgrade zigbee immer error:
    npm list dissolve
    Danke erstmal für eure Hilfe
    Linux iobroker 4.9.0-8-amd64 #1 SMP Debian 4.9.110-3+deb9u6 (2018-10-08) x86_64
    permitted by applicable law.
    Last login: Thu Jan 21 16:09:00 2021 from 192.168.178.112
    root@iobroker:~# cd /opt/iobroker
    root@iobroker:/opt/iobroker# npm remove dissolve
    > serialport@6.2.2 install /opt/iobroker/node_modules/cc-znp/node_modules/serialport
    > prebuild-install || node-gyp rebuild
    prebuild-install WARN install No prebuilt binaries found (target=12.19.0 runtime=node arch=x64 platform=linux)
    make: Verzeichnis „/opt/iobroker/node_modules/cc-znp/node_modules/serialport/build“ wird betreten
      CXX(target) Release/obj.target/serialport/src/serialport.o
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
       v8::String::Utf8Value path(info[0]->ToString());
    In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67:0,
                     from ../../../../nan/nan.h:54,
                     from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
       V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
    /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
    In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8-internal.h:14:0,
                     from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:27,
                     from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,
    /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
                     Local<String> ToString(Isolate* isolate) const);
    /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
    ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
       v8::Local<v8::Object> options = info[1]->ToObject();
    /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2672:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
       V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
    /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 provided
    /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2686:31: note: candidate: v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const
                     Local<Object> ToObject(Isolate* isolate) const);
    /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(2, argv);
    In file included from ../src/./serialport.h:6:0,
    ../../../../nan/nan.h:1740:3: note: declared here
       Call(int argc, v8::Local<v8::Value> argv[]) const {
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
    ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(1, argv);
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
    ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
    ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
    ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
    /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:3499:22: note: declared here
                     bool Set(Local<Value> key, Local<Value> value));
    ../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
    ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
    ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
    ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
    ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
       void init(v8::Handle<v8::Object> target) {
    ../src/serialport.cpp:460:13: error: ‘Handle’ is not a member of ‘v8’
    ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
    ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
    In file included from ../../../../nan/nan.h:54:0,
    ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
     NODE_MODULE(serialport, init);
    /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:727:36: note: in definition of macro ‘NODE_MODULE_X’
           (node::addon_register_func) (regfunc),                          \
    ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
    serialport.target.mk:114: die Regel für Ziel „Release/obj.target/serialport/src/serialport.o“ scheiterte
    make: *** [Release/obj.target/serialport/src/serialport.o] Fehler 1
    make: Verzeichnis „/opt/iobroker/node_modules/cc-znp/node_modules/serialport/build“ wird verlassen
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.9.0-8-amd64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/cc-znp/node_modules/serialport
    gyp ERR! node -v v12.19.0
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/package.json'
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 (node_modules/cc-znp/node_modules/serialport):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    added 20 packages from 15 contributors in 24.688s
    105 packages are looking for funding
      run `npm fund` for details
    root@iobroker:/opt/iobroker# npm remove zigbee-shepherd
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    removed 20 packages in 19.565s
    root@iobroker:/opt/iobroker# npm remove iobroker.zigbee
    npm ERR! code ENOTSUP
    npm ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.19.0","npm":"6.14.8"})
    npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3
    npm ERR! notsup Required: {"node":"~0.10.0"}
    npm ERR! notsup Actual:   {"npm":"6.14.8","node":"12.19.0"}
    npm ERR!     /home/iobroker/.npm/_logs/2021-01-21T15_28_09_865Z-debug.log
    root@iobroker:/opt/iobroker# npm list dissolve
    iobroker@1.0.0 /opt/iobroker
    └─┬ iobroker.zigbee@0.10.3
      └─┬ zigbee-shepherd@0.3.0
        └─┬ zcl-packet@0.2.4
          └─┬ dissolve-chunks@1.3.0
            └── dissolve@0.3.3
    UncleSamU Offline
    UncleSamU Offline
    UncleSam
    @chucky666 Mit dem Risiko, einen riesigen Output zu generieren, kannst du mal ls -la /opt/iobroker/node_modules machen?
    Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
    ♡-lichen Dank an meine Sponsoren
    chucky666C 1 Antwort Letzte Antwort
      npm list dissolve
      gyp ERR! not ok
              └── dissolve@0.3.3
      @chucky666 sagte in Upgrade zigbee immer error
      root@iobroker
      sollte man ja auch vermeiden. Kompilieren als root ist halt ein No-Go.
      UncleSamU 1 Antwort Letzte Antwort
        root@iobroker
        UncleSamU Offline
        UncleSamU Offline
        UncleSam
        @thomas-braun Einverstanden, aber weshalb will der bei einem npm remove etwas kompilieren... ich hätte erwartet, dass der nur entfernt und nichts hinzufügt.
        • UncleSamU UncleSam
          @unclesam @chucky666
          npm greift immer 'liegengebliebene' Dinge auf, bis es erfolgreich erledigt wurde. Offenbar hängt da das serialport-Modul quer und wird immer wieder angefasst.
          Ich würde vielleicht mal den groben Besen versuchen:
          npm cache clean --force
          Natürlich als einfacher user, nicht als root.
            chucky666C Online
            chucky666C Online
            chucky666
            @thomas-braun sagte in Upgrade zigbee immer error:
            I sure hope you know what you are doing.
            Das spuckt er dann aus
              chucky666C Online
              chucky666C Online
              chucky666
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 bignumber.js
              drwxrwxrwx+    2 iobroker iobroker  4096 Jan 21 15:23 .bin
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 binary-extensions
              drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 bindings
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 bl
              drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 blob
              drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 block-stream
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 bluebird
              drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 bluetooth-hci-socket
              drwxrwxrwx+    4 iobroker iobroker  4096 Nov 22  2019 body-parser
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 bonjour-hap
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 boolbase
              drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 bower
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 boxen
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 bplist-parser
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 brace-expansion
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 braces
              drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 browser-process-hrtime
              drwxrwxr-x+    3 iobroker iobroker  4096 Jan  9  2020 browser-serialport
              drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 buffer
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-alloc
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-alloc-unsafe
              drwxrwxrwx+    4 iobroker iobroker  4096 Apr 27  2019 buffer-equal
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-equal-constant-time
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-fill
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-from
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 bufferhelper
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep 14  2018 buffer-shims
              drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 builtins
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 busboy
              drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 bytes
              drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:22 bytesish
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 cacheable-lookup
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 cacheable-request
              drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 cache-base
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 callback-stream
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 call-bind
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 callsite
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 callsites
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 camelcase
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 camelcase-keys
              drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:17 canvas
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 capitalize
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 caseless
              drwxrwxrwx+    6 iobroker iobroker  4096 Jan 21 15:23 cc-znp
              drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 cert-info
              drwxrwxrwx+    3 iobroker iobroker  4096 Apr  7  2019 chai
              drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 chalk
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 chardet
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 charenc
              drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 check-error
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:45 cheerio
              drwxrwxrwx+    3 iobroker iobroker  4096 Apr 27  2019 chip.avr.avr109
              drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 chokidar
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 chownr
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 ci-info
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 class-utils
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 clean-stack
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 cli
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 cli-boxes
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 cli-cursor
              drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 cliff
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cli-truncate
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cliui
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cli-width
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cloneextend
              drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 clone-response
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 cluster-key-slot
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 co
              drwxrwxr-x+    6 iobroker iobroker  4096 Okt 27 12:44 coap
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 coap-packet
              drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 code-point-at
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 coffee-compiler
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 coffee-script
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 collection-visit
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 color
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 color-convert
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 color-name
              drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 colors
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 colorspace
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 color-string
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 color-support
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 combined-stream
              drwxrwxr-x+    3 iobroker iobroker  4096 Jan  9  2020 commander
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 commist
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 component-bind
              drwxrwxr-x+    2 iobroker iobroker  4096 Jun 17  2020 component-emitter
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 component-inherit
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 concat-map
              drwxrwxrwx+    3 iobroker iobroker  4096 Jun 30  2020 concat-stream
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 concentrate
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 configstore
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 connect-flash
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 console-control-strings
              drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 content-disposition
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 content-type
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cookie
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:01 cookie-parser
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cookie-signature
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 copy-descriptor
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 copy-props
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 copy-to
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 core-util-is
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cosmiconfig
              drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 create-react-app
              drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 cron
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 cron-parser
              drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 cross-spawn
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 crypt
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez 11  2018 crypto-js
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 crypto-random-string
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 cssom
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:45 css-select
              drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 cssstyle
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 css-what
              drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 curve25519-n
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cycle
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 d
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 @dabh
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 daemonize2
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 dashdash
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 data-uri-to-buffer
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 data-urls
              drwxrwxrwx+  158 iobroker iobroker  4096 Dez 12  2018 date-fns
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 dateformat
              drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 debounce
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 debug
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 decache
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 decamelize
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 decamelize-keys
              drwxrwxrwx+    3 iobroker iobroker  4096 Jan 15 04:52 decimal.js
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 decode-uri-component
              drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 decompress-response
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 deep-clone
              drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 deep-eql
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 deep-equal
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 deep-extend
              drwxrwxrwx+    4 iobroker iobroker  4096 Jun  6  2019 deep-is
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 default-compare
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 default-user-agent
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 defer-to-connect
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 define-properties
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 define-property
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 degenerator
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 del
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 delayed-stream
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 delegates
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 denque
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 depd
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 destroy
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 detect-file
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 detect-libc
              drwxrwxrwx+    4 iobroker iobroker  4096 Sep 14  2018 dev-null
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 dgram
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 dicer
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 digest-header
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 dir-glob
              drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 diskusage
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 dissolve
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 dissolve-chunks
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 dns-packet
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 domelementtype
              drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 domexception
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:45 domhandler
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 dom-serializer
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:45 domutils
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2018 dotenv
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 dot-prop
              drwxrwxrwx+    6 iobroker iobroker  4096 Okt 11  2018 dropbox-v2-api
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 duplexer
              drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 duplexer2
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 duplexer3
              drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 duplexify
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 each-props
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 ecc-jsbn
              drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 ecdsa-sig-formatter
              drwxrwxrwx+   13 iobroker iobroker  4096 Okt 27 13:17 echarts
              drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 eckles
              drwxrwxrwx+    5 iobroker iobroker  4096 Sep 14  2018 ed25519-hap
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 ee-first
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 elegant-spinner
              drwxrwxr-x+    3 iobroker iobroker  4096 Jan 28  2020 emoji-regex
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 enabled
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 encodeurl
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 end-of-stream
              drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 engine.io
              drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 engine.io-client
              drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 engine.io-parser
              drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:45 entities
              drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 envinfo
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 error-ex
              drwxrwxr-x+   17 iobroker iobroker  4096 Okt 27 12:44 es5-ext
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 es6-iterator
              drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 es6-map
              drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 es6-promise
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 es6-promisify
              drwxrwxr-x+    7 iobroker iobroker  4096 Okt 27 12:44 es6-set
              drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 es6-symbol
              drwxrwxr-x+   13 iobroker iobroker  4096 Jul  1  2020 es-abstract
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 escape-goat
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 escape-html
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 escape-string-regexp
              drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 escodegen
              drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 es-get-iterator
              drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 esprima
              drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 es-to-primitive
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 estraverse
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 esutils
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 etag
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 event-emitter
              drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 eventemitter3
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 event-stream
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 event-target-shim
              drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 execa
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 expand-brackets
              drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 expand-template
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 expand-tilde
              drwxrwxrwx+    4 iobroker iobroker  4096 Nov 22  2019 express
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 express-fileupload
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:01 express-session
              drwxrwxr-x+   13 iobroker iobroker  4096 Okt 27 12:44 ext
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 extend
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 extend-shallow
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 external-editor
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 extglob
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 extract-zip
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 extsprintf
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 eyes
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 fancy-log
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fast-deep-equal
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez  8 11:27 fast-glob
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 fast-json-stable-stringify
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 fast-levenshtein
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez  8 11:27 fastq
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 fast-safe-stringify
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 fastseries
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 fast-srp-hap
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 fast-text-encoding
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 fd-slicer
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 fecha
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 figures
              drwxrwxr-x+    3 iobroker iobroker  4096 Jan 28  2020 file-stream-rotator
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 file-type
              drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 file-uri-to-path
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 fill-range
              drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 finalhandler
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 find-up
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 findup-sync
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 fined
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 flagged-respawn
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 fn.name
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 follow-redirects
              drwxrwxrwx+    2 iobroker iobroker  4096 Jan 15 04:52 foreach
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 forever-agent
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 for-in
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 form-data
              drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 formstream
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 for-own
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 forwarded
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fragment-cache
              drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 @frankjoke
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fresh
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 from
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fs-constants
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 fs-extra
              drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 fs-minipass
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fs.realpath
              drwxrwxrwx+    4 iobroker iobroker  4096 Feb 16  2019 fstream
              drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 fstream-ignore
              drwxrwxrwx+    4 iobroker iobroker  4096 Okt 11  2018 ftp
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 function-bind
              drwxrwxrwx+    2 iobroker iobroker  4096 Jan 15 04:52 futoin-hkdf
              drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 gauge
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 gaxios
              drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:26 gcp-metadata
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 get-caller-file
              drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 get-func-name
              drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 get-intrinsic
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 getpass
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 get-stream
              drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 get-uri
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 get-value
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 github-from-package
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 github-url-from-git
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 glob
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 global-dirs
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 global-modules
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 global-prefix
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 globby
              drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 glob-parent
              drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 glob-stream
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 glogg
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 glossy
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 googleapis
              drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 googleapis-common
              drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 google-auth-library
              drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:26 google-p12-pem
              drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 got
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 graceful-fs
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 greenlock
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 greenlock-store-fs
              drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 gtoken
              drwxrwxr-x+    6 iobroker iobroker  4096 Okt 27 12:44 gulp-cli
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 gulplog
              drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 hap-nodejs
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 hard-rejection
              drwxrwxr-x+    3 iobroker iobroker  4096 Apr 30  2020 @harmonyhub
              drwxrwxr-x+    5 iobroker iobroker  4096 Apr 30  2020 harmonyhubws
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 har-schema
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 har-validator
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 has
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 has-ansi
              drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 has-binary2
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 has-cors
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 has-flag
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 hasha
              drwxrwxrwx+    3 iobroker iobroker  4096 Mai 30  2019 has-symbols
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 has-unicode
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 has-value
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 has-values
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 has-yarn
              drwxrwxr-x+    4 iobroker iobroker  4096 Apr 12  2020 help-me
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 hoek
              drwxrwxrwx+    3 iobroker iobroker  4096 Jan 15 04:52 @homebridge
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 homedir-polyfill
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 hosted-git-info
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 html-encoding-sniffer
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:45 htmlparser2
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 http-cache-semantics
              drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 http-errors
              drwxrwxr-x+    4 iobroker iobroker  4096 Dez  7 10:35 http-proxy
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 http-proxy-middleware
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 http-proxy-response-rewrite
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 https
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 http-signature
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 https-proxy-agent
              drwxrwxr-x+    8 iobroker iobroker  4096 Mai  9  2020 hue-emu
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 humanize-ms
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 human-signals
              drwxrwxrwx+    5 iobroker iobroker  4096 Feb 16  2019 hyperquest
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 i
              drwxrwxrwx+    4 iobroker iobroker  4096 Nov 22  2019 iconv-lite
              drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 ieee754
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 ignore
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez 12 09:04 ignore-walk
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 immediate
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 import-fresh
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 import-lazy
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  8 11:27 import-local
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 imurmurhash
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 indent-string
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 indexof
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 inflight
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 inherits
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 ini
              drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 inquirer
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 inquirer-autosubmit-prompt
              drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 intel-hex
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 interpret
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 invert-kv
              drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:04 @iobroker
              drwxrwxr-x+    8 iobroker iobroker  4096 Okt 27 13:01 iobroker.admin
              drwxrwxrwx+    5 iobroker iobroker  4096 Jan 17 14:40 iobroker.alexa2
              drwxrwxrwx+    7 iobroker iobroker  4096 Dez  7 11:47 iobroker.backitup
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.broadlink
              drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 iobroker.broadlink2
              drwxrwxrwx+    7 iobroker iobroker  4096 Dez 12 09:05 iobroker.cloud
              drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:22 iobroker.daswetter
              drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:13 iobroker.deconz
              drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 iobroker.discovery
              drwxrwxrwx+    6 iobroker iobroker  4096 Jan 12 13:14 iobroker.dwd
              drwxrwxr-x+    6 iobroker iobroker  4096 Jul 24 10:11 iobroker.fb-checkpresence
              drwxrwxrwx+    9 iobroker iobroker  4096 Jan 15 04:53 iobroker.flot
              drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:19 iobroker.fullybrowser
              drwxrwxr-x+    8 iobroker iobroker  4096 Okt 27 12:44 iobroker.fully-tablet-control
              drwxrwxr-x+    8 iobroker iobroker  4096 Mai  1  2020 iobroker.habpanel
              drwxrwxr-x+    4 iobroker iobroker  4096 Apr 30  2020 iobroker.harmony
              drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:25 iobroker.history
              drwxrwxr-x+    8 iobroker iobroker  4096 Mai  9  2020 iobroker.hueemu
              drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:16 iobroker.ical
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.icons-icons8
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 iobroker.icons-mfd-png
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 iobroker.icons-mfd-svg
              drwxrwxr-x+    7 iobroker iobroker  4096 Jun 28  2020 iobroker.info
              drwxrwxrwx+    8 iobroker iobroker  4096 Dez 12 09:05 iobroker.iot
              drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:21 iobroker.javascript
              drwxrwxr-x+    7 iobroker iobroker  4096 Okt 29 04:00 iobroker.js-controller
              drwxrwxrwx+    6 iobroker iobroker  4096 Apr  7  2019 iobroker.milight
              drwxrwxrwx+    6 iobroker iobroker  4096 Jun  6  2019 iobroker.milight-smart-light
              drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:27 iobroker.mobile
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 iobroker.objects-redis
              drwxrwxr-x+    5 iobroker iobroker  4096 Aug 17 16:22 iobroker.onvif
              drwxrwxr-x+    6 iobroker iobroker  4096 Jul  1  2020 iobroker.openligadb
              drwxrwxrwx+    6 iobroker iobroker  4096 Sep  7  2018 iobroker.phantomjs
              drwxrwxr-x+    6 iobroker iobroker  4096 Jul 27 14:35 iobroker.pi-hole
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.radar
              drwxrwxrwx+    6 iobroker iobroker  4096 Jul  1  2020 iobroker.radar2
              drwxrwxr-x+    6 iobroker iobroker  4096 Mär 19  2020 iobroker.rflink
              drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:19 iobroker.shelly
              drwxrwxrwx+    6 iobroker iobroker  4096 Okt 27 13:20 iobroker.simple-api
              drwxrwxr-x+    7 iobroker iobroker  4096 Okt 27 12:45 iobroker.smartcontrol
              drwxrwxr-x+    5 iobroker iobroker  4096 Aug 19 13:54 iobroker.smartgarden
              drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:10 iobroker.socketio
              drwxrwxr-x+    6 iobroker iobroker  4096 Apr 12  2020 iobroker.sonoff
              drwxrwxr-x+    7 iobroker iobroker  4096 Jul  1  2020 iobroker.telegram
              drwxrwxrwx+    6 iobroker iobroker  4096 Dez  9 10:37 iobroker.text2command
              drwxrwxrwx+    5 iobroker iobroker  4096 Nov 24 16:16 iobroker.tr-064
              drwxrwxrwx+    8 iobroker iobroker  4096 Dez 27 10:44 iobroker.trashschedule
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez 11  2018 iobroker.type-detector
              drwxrwxrwx+    5 iobroker iobroker  4096 Apr 15  2019 iobroker.viessmannapi
              drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:11 iobroker.vis
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-bars
              drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-canvas-gauges
              drwxrwxrwx+    6 iobroker iobroker  4096 Dez  8 11:25 iobroker.vis-colorpicker
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-fancyswitch
              drwxrwxrwx+    7 iobroker iobroker  4096 Okt 18  2019 iobroker.vis-history
              drwxrwxrwx+    7 iobroker iobroker  4096 Dez  7 11:29 iobroker.vis-hqwidgets
              drwxrwxrwx+    6 iobroker iobroker  4096 Okt 27 13:23 iobroker.vis-icontwo
              drwxrwxrwx+    6 iobroker iobroker  4096 Dez  8 11:27 iobroker.vis-inventwo
              drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-jqui-mfd
              drwxrwxrwx+    6 iobroker iobroker  4096 Nov 22  2019 iobroker.vis-justgage
              drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-metro
              drwxrwxrwx+    6 iobroker iobroker  4096 Dez  8 17:19 iobroker.vis-players
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-timeandweather
              drwxrwxr-x+    4 iobroker iobroker  4096 Jan  9  2020 iobroker.vis-weather
              drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:13 iobroker.web
              drwxrwxr-x+    8 iobroker iobroker  4096 Jul  1  2020 iobroker.xs1
              drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 iobroker.yahka
              drwxrwxrwx+    9 iobroker iobroker  4096 Nov 25  2019 iobroker.zigbee
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 ioredis
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 ip
              drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 ipaddr.js
              drwxrwxrwx+    2 iobroker iobroker  4096 Jun  6  2019 ip-regex
              drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 is
              drwxrwxrwx+    2 iobroker iobroker  4096 Jun  6  2019 is2
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-absolute
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-accessor-descriptor
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-arguments
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 isarray
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 is-arrayish
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-bigint
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 is-binary-path
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-boolean-object
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2019 is-buffer
              drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 is-callable
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-ci
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-data-descriptor
              drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 is-date-object
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-descriptor
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-docker
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12  2018 isemail
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 isexe
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-extendable
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-extglob
              drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 is-fullwidth-code-point
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-generator-function
              drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 is-glob
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 is-installed-globally
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-map
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-nan
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-negated-glob
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-negative-zero
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-npm
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-number
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-number-object
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-obj
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 isobject
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-observable
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-path-cwd
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-path-in-cwd
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-path-inside
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-plain-obj
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-plain-object
              drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 is-potential-custom-element-name
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-promise
              drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 is-regex
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-relative
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-scoped
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-set
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 isstream
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-stream
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-string
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 issue-regex
              drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 is-symbol
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-typedarray
              drwxrwxrwx+    6 iobroker iobroker  4096 Jan 15 04:52 is-typed-array
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-unc-path
              drwxrwxrwx+    3 iobroker iobroker  4096 Jun  6  2019 is-url
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 is-url-superb
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 is-utf8
              drwxrwxrwx+    2 iobroker iobroker  4096 Apr 27  2019 isval
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-weakmap
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-weakset
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-windows
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 is-wsl
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-yarn-global
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 joi
              drwxrwxr-x+    3 iobroker iobroker  4096 Jun 15  2020 @jpgorganizer
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 jsbn
              drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 jsdom
              drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:21 jsonata
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 json-bigint
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 json-buffer
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 jsonfile
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 json-parse-better-errors
              drwxrwxrwx+    9 iobroker iobroker  4096 Aug 31  2018 json-schema
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 json-schema-traverse
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 10  2019 json-stable-stringify-without-jsonify
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 json-stringify-safe
              drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 jsonwebtoken
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 jsprim
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 js-tokens
              drwxrwxr-x+    6 iobroker iobroker  4096 Okt 27 13:04 jszip
              drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 jwa
              drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 jws
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 kew
              drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 keypairs
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 keyv
              drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 kind-of
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 klaw
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 kuler
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 latest-version
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 lcid
              drwxrwxrwx+    6 iobroker iobroker  4096 Jul 20  2019 le-acme-core
              drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 le-challenge-fs
              drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 le-sni-auto
              drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 le-store-certbot
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 leven
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 levn
              drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 lie
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 liftoff
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 lines-and-columns
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 listr
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 listr-input
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 listr-silent-renderer
              drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 listr-update-renderer
              drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 listr-verbose-renderer
              drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 loadavg-windows
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 load-json-file
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 locate-path
              drwxrwxrwx+    3 iobroker iobroker 20480 Aug 31  2018 lodash
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 lodash.defaults
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 lodash.flatten
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 lodash.get
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.includes
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isboolean
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isinteger
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isnumber
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isplainobject
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isstring
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.once
              drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 lodash.sortby
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 lodash.zip
              drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 logform
              drwxrwxrwx+    6 iobroker iobroker  4096 Okt 27 13:19 loglevel
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 log-symbols
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 log-update
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 long-timeout
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 lowercase-keys
              drwxrwxrwx+    3 iobroker iobroker  4096 Jan  9  2020 lru-cache
              drwxrwxr-x+    2 iobroker iobroker  4096 Jan  9  2020 lru_map
              drwxrwxrwx+    4 iobroker iobroker  4096 Mär  2  2019 luxon
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 macaddress
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 make-dir
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 make-iterator
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 map-age-cleaner
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 map-cache
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 map-obj
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 map-stream
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 map-visit
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 matchdep
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 md5
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 mdns-discovery
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 media-typer
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 mem
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 meow
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 merge2
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 merge-descriptors
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 merge-stream
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 methods
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 micromatch
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 mime
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 mime-db
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 mime-types
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 mimic-fn
              drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 mimic-response
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 minimatch
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 minimist
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 minimist-options
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 min-indent
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 minipass
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 minizlib
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 mixin-deep
              drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 mkdirp
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 mkdirp-classic
              drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 moment
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 moment-timezone
              drwxrwxrwx+   10 iobroker iobroker  4096 Dez 11  2018 mqtt
              drwxrwxr-x+    4 iobroker iobroker  4096 Apr 12  2020 mqtt-connection
              drwxrwxr-x+    5 iobroker iobroker  4096 Apr 12  2020 mqtt-packet
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 ms
              drwxrwxrwx+    3 iobroker iobroker  4096 Jan 15 04:52 multicast-dns
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep 14  2018 multicast-dns-service-types
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 mute-stdout
              drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 mute-stream
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 mz
              drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 nan
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 nanomatch
              drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 napi-build-utils
              drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 napi-thread-safe-callback
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 ncp
              drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 nearest-color
              drwxrwxrwx+    8 iobroker iobroker  4096 Dez 12 09:04 needle
              drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 netmask
              drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 net-ping
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 new-github-release-url
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 next-tick
              drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 nimble
              drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 noble
              drwxrwxr-x+    4 iobroker iobroker  4096 Mär 19  2020 node-abi
              drwxrwxrwx+    6 iobroker iobroker  4096 Mai 29  2019 node-addon-api
              drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 node-arp
              drwxrwxrwx+    7 iobroker iobroker  4096 Mai 30  2019 node-bluetooth
              drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 node.extend
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 node-fetch
              drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 node-forge
              drwxrwxrwx+    2 iobroker iobroker  4096 Mär  2  2019 node-ical
              drwxrwxrwx+    5 iobroker iobroker  4096 Dez  8 11:27 @nodelib
              drwxrwxrwx+    5 iobroker iobroker  4096 Jun  6  2019 node-milight-promise
              drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 node-mndp
              drwxrwxrwx+    6 iobroker iobroker  4096 Sep 14  2018 node-persist
              drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 node-pre-gyp
              drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 node-rest-client
              drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 node-schedule
              drwxrwxr-x+    9 iobroker iobroker  4096 Jul  1  2020 node-ssdp
              drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 node-telegram-bot-api
              drwxrwxrwx+    2 iobroker iobroker  4096 Feb 11  2019 node-wol
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 noop-logger
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12 09:04 nopt
              drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 normalize-package-data
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 normalize-path
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 normalize-url
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez  8 11:27 np
              drwxrwxr-x+    9 iobroker iobroker  4096 Jan  9  2020 npm
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez 12 09:04 npm-bundled
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 npmlog
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 npm-name
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12 09:04 npm-normalize-package-bin
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez 12 09:04 npm-packlist
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 npm-run-path
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 nth-check
              drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 number-is-nan
              drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 nwsapi
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 oauth-sign
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 object-assign
              drwxrwxr-x+    4 iobroker iobroker  4096 Jan  9  2020 object.assign
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 object-component
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 object-copy
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 object.defaults
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 object-hash
              drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 object-inspect
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 object-is
              drwxrwxrwx+    3 iobroker iobroker  4096 Mai 30  2019 object-keys
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 object.map
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 object.pick
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 object-visit
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 once
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 onetime
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 one-time
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 on-finished
              drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 on-headers
              drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 onvif
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 open
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 optionator
              drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 ordered-read-streams
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 org-regex
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 osenv
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 os-homedir
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 os-locale
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 os-name
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 os-tmpdir
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 osx-release
              drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 ow
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 package-json
              drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 pac-proxy-agent
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 pac-resolver
              drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 pako
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 parent-module
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:45 parse5
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 parse-filepath
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 parse-json
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 parse-node-version
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 parse-passwd
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 parseqs
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 parseuri
              drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 parseurl
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 pascalcase
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:01 passport
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 passport-local
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 passport.socketio
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 passport-strategy
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 path-dirname
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-exists
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 path-is-absolute
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 path-is-inside
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-key
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-parse
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 path-root
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 path-root-regex
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 path-to-regexp
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-type
              drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 pathval
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 pause
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 pause-stream
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 p-cancelable
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-defer
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 pend
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 performance-now
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 p-event
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-finally
              drwxrwxrwx+    6 iobroker iobroker  4096 Sep  6  2018 phantomjs-prebuilt
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 picomatch
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 pidusage
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 pify
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 ping
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 pinkie
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 pinkie-promise
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-is-promise
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 pkg-dir
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 pkginfo
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-limit
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-locate
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-map
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-memoize
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 posix-character-classes
              drwxrwxr-x+    3 iobroker iobroker  4096 Mär 19  2020 prebuild-install
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 prelude-ls
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 prepend-http
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 pretty-hrtime
              drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 process-nextick-args
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 progress
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 promise-object
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 promise-retryer
              drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 prompt
              drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 proxy-addr
              drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 proxy-agent
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 proxy-from-env
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 psl
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-timeout
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-try
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 pump
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 pumpify
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 punycode
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 pupa
              drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 pyconf
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 q
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 qs
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 querystring
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 quick-lru
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 random-bytes
              drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 range-parser
              drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 rasha
              drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 raw-body
              drwxrwxrwx+    6 iobroker iobroker  4096 Mai 29  2019 raw-socket
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 rc
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 read
              drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 readable-stream
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 readdirp
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 readline-sync
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 read-pkg
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 read-pkg-up
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 rechoir
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 redent
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 redis-commands
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 redis-errors
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 redis-parser
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 regex-not
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 regexp.prototype.flags
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 registry-auth-token
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 registry-url
              drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 reinterval
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 remove-trailing-separator
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 repeat-element
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 repeat-string
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 replace-homedir
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 request
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 request-progress
              drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 request-promise
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 request-promise-core
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 request-promise-native
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 require-directory
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 require-main-filename
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 requires-port
              drwxrwxr-x+    5 iobroker iobroker  4096 Mai  1  2020 resolve
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  8 11:27 resolve-cwd
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 resolve-dir
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 resolve-from
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 resolve-url
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 respjs
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 responselike
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 restore-cursor
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 ret
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  8 11:27 reusify
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 revalidator
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 rimraf
              drwxrwxrwx+    4 iobroker iobroker  4096 Mai  1  2020 @root
              drwxrwxrwx+    3 iobroker iobroker  4096 Mär  2  2019 rrule
              drwxrwxrwx+    6 iobroker iobroker  4096 Jul 20  2019 rsa-compat
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 run-async
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 run-parallel
              drwxrwxr-x+   20 iobroker iobroker  4096 Mai  1  2020 rxjs
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 safe-buffer
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 safer-buffer
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 safe-regex
              drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 safe-replace
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 @samverschueren
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 sax
              drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 saxes
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 scoped-regex
              drwxrwxr-x+    4 iobroker iobroker  4096 Mai  9  2020 selfsigned
              drwxrwxr-x+    4 iobroker iobroker  4096 Apr 30  2020 semaphore
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 semver
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 semver-diff
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 semver-greatest-satisfied-range
              drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 send
              drwxrwxr-x+   11 iobroker iobroker  4096 Dez  7 10:35 @sentry
              drwxrwxr-x+    4 iobroker iobroker  4096 Mär 19  2020 serialport
              drwxrwxr-x+   12 iobroker iobroker  4096 Mär 19  2020 @serialport
              drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 serve-static
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 set-blocking
              drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 set-immediate-shim
              drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 setprototypeof
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 set-value
              drwxrwxr-x+    8 iobroker iobroker  4096 Aug  8 03:31 sharp
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 shebang-command
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 shebang-regex
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 shelly-iot
              drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 side-channel
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 signal-exit
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 simple-concat
              drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 simple-get
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12  2018 simple-oauth2
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 simple-swizzle
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 @sindresorhus
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 slash
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 slice-ansi
              drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 smart-buffer
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 snapdragon
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 snapdragon-node
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 snapdragon-util
              drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 socket.io
              drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 socket.io-adapter
              drwxrwxr-x+    5 iobroker iobroker  4096 Jun 17  2020 socket.io-client
              drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 socket.io-parser
              drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 socks
              drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 socks-proxy-agent
              drwxrwxrwx+    5 iobroker iobroker  4096 Mai 30  2019 socksv5
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 sorted-array-functions
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 source-map
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 source-map-resolve
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 source-map-support
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 source-map-url
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 sparkles
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 spdx-correct
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 spdx-exceptions
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 spdx-expression-parse
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 spdx-license-ids
              drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 split
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 split2
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 split-string
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 sshpk
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 stack-trace
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 standard-as-callback
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 static-extend
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 statuses
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 stealthy-require
              drwxrwxr-x+    7 iobroker iobroker  4096 Jan  9  2020 stk500
              drwxrwxr-x+    5 iobroker iobroker  4096 Mär 19  2020 stk500-v2
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 stream-combiner
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 streamifier
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 streamsearch
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 stream-shift
              drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 string_decoder
              drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 string.prototype.trimend
              drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 string.prototype.trimstart
              drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 string-width
              drwxrwxr-x+    3 iobroker iobroker  4096 Jan 28  2020 strip-ansi
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 strip-bom
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 strip-final-newline
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 strip-indent
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 strip-json-comments
              drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 suncalc2
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 supports-color
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 supports-hyperlinks
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 sver-compat
              drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 symbol-observable
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 symbol-tree
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 systeminformation
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 @szmarczak
              drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 tar
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 tar-fs
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 11  2018 targz
              drwxrwxrwx+    4 iobroker iobroker  4096 Feb 16  2019 tar-pack
              drwxrwxr-x+    3 iobroker iobroker  4096 Apr 11  2020 tar-stream
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 tcp-ping
              drwxrwxrwx+    3 iobroker iobroker  4096 Jun  6  2019 tcp-port-used
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 terminal-link
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 term-size
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 text-hex
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 thenify
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 thenify-all
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 throttleit
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 through
              drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 through2
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 through2-filter
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 thunkify
              drwxrwxrwx+    2 iobroker iobroker  4096 Jan 15 04:52 thunky
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 time-stamp
              drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 tmp
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 to-absolute-glob
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-array
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-buffer
              drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 toidentifier
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 to-object-path
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 topo
              drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 to-readable-stream
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-regex
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-regex-range
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 tough-cookie
              drwxr-xr-x+    4 iobroker iobroker  4096 Okt 27 13:17 tr46
              drwxrwxrwx+    2 iobroker iobroker  4096 Jun  6  2019 tree-kill
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 trim-newlines
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 triple-beam
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 tr-O64
              drwxrwxr-x+    2 iobroker iobroker  4096 Jan  9  2020 tslib
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 tunnel-agent
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 tweetnacl
              drwxrwxr-x+   26 iobroker iobroker  4096 Okt 27 12:44 type
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 type-check
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 typedarray
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 typedarray-to-buffer
              drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 type-detect
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 type-fest
              drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 type-is
              drwxrwxrwx+   26 iobroker iobroker  4096 Jan 17 14:40 @types
              drwxrwxrwx+    4 iobroker iobroker  4096 Apr  7  2019 typescript
              drwxrwxrwx+    3 iobroker iobroker  4096 Dez 22  2018 typescript-optional
              drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 uid-number
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 uid-safe
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 unc-path-regex
              drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:19 underscore
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 unescape
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 union-value
              drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 unique-stream
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 unique-string
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 universalify
              drwxrwxr-x+    6 iobroker iobroker  4096 Jan 28  2020 unix-dgram
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 unpi
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 unpipe
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 unset-value
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 update-notifier
              drwxrwxr-x+    6 iobroker iobroker  4096 Mär 19  2020 uri-js
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 urix
              drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 urllib
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 url-parse-lax
              drwxrwxrwx+    5 iobroker iobroker  4096 Sep 24  2019 url-template
              drwxrwxrwx+    6 iobroker iobroker  4096 Jul 20  2019 ursa-optional
              drwxrwxrwx+    8 iobroker iobroker  4096 Aug 31  2018 usb
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 use
              drwxrwxrwx+    3 iobroker iobroker  4096 Sep 14  2018 util
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 util-deprecate
              drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 utile
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 utility
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 utils-merge
              drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 uuid
              drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 v8flags
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 validate-npm-package-license
              drwxrwxrwx+    4 iobroker iobroker  4096 Feb 16  2019 validate-npm-package-name
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 vary
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 verror
              drwxrwxrwx+    5 iobroker iobroker  4096 Dez 12  2018 viessmann-api-client
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 vinyl-sourcemaps-apply
              drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 virtual-device-sdk
              drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:21 virtual-tsc
              drwxrwxrwx+    5 iobroker iobroker  4096 Apr  7  2019 vm2
              drwxr-xr-x+    3 iobroker iobroker  4096 Okt 27 13:17 w3c-hr-time
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 w3c-xmlserializer
              drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 wake_on_lan
              drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 weak-daemon
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 webidl-conversions
              drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 websocket-stream
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 whatwg-encoding
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 whatwg-mimetype
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 whatwg-url
              drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 which
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 which-boxed-primitive
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 which-collection
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 which-module
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 which-pm-runs
              drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 which-typed-array
              drwxrwxrwx+    2 iobroker iobroker  4096 Mär 19  2020 wide-align
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 widest-line
              drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 win-release
              drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 winston
              drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 winston-daily-rotate-file
              drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 winston-syslog
              drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 winston-transport
              drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 word-wrap
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 wrap-ansi
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 wrappy
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 write-file-atomic
              drwxrwxr-x+    4 iobroker iobroker  4096 Apr 12  2020 ws
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 xdg-basedir
              drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 xml2js
              drwxrwxr-x+    2 iobroker iobroker  4096 Jun 14  2020 xml2json-light
              drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 xmlbuilder
              drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 xmlchars
              drwxrwxr-x+    5 iobroker iobroker  4096 Jun 17  2020 xmlhttprequest-ssl
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 xml-name-validator
              drwxrwxrwx+    3 iobroker iobroker  4096 Okt 11  2018 xregexp
              drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 xtend
              drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 y18n
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 yallist
              drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 yaml
              drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 yargs
              drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 yargs-parser
              drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 yauzl
              drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 yeast
              drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 yocto-queue
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 21 15:19 zcl-packet
              drwxrwxrwx+    4 iobroker iobroker  4096 Jan 22 06:27 zigbee-shepherd
              drwxrwxrwx+    5 iobroker iobroker  4096 Dez 10  2018 zigbee-shepherd-converters
              drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:17 zrender
              jens@iobroker:/root$
              • UncleSamU Offline
                UncleSamU Offline
                UncleSam
                Wenn in den nächsten Stunden nicht noch jemand mit einer guten Lösung kommt, würde ich vorschlagen: Backup machen, ioBroker Verzeichnis löschen, ioBroker neu installieren und Backup restoren
                Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
                ♡-lichen Dank an meine Sponsoren
                chucky666C 2 Antworten Letzte Antwort
                • chucky666C chucky666
                  @unclesam sagte in Upgrade zigbee immer error:
                  ls -la /opt/iobroker/node_modules
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 bignumber.js
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jan 21 15:23 .bin
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 binary-extensions
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 bindings
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 bl
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 blob
                  drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 block-stream
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 bluebird
                  drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 bluetooth-hci-socket
                  drwxrwxrwx+    4 iobroker iobroker  4096 Nov 22  2019 body-parser
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 bonjour-hap
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 boolbase
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 bower
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 boxen
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 bplist-parser
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 brace-expansion
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 braces
                  drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 browser-process-hrtime
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jan  9  2020 browser-serialport
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 buffer
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-alloc
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-alloc-unsafe
                  drwxrwxrwx+    4 iobroker iobroker  4096 Apr 27  2019 buffer-equal
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-equal-constant-time
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-fill
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-from
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 bufferhelper
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep 14  2018 buffer-shims
                  drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 builtins
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 busboy
                  drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 bytes
                  drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:22 bytesish
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 cacheable-lookup
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 cacheable-request
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 cache-base
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 callback-stream
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 call-bind
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 callsite
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 callsites
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 camelcase
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 camelcase-keys
                  drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:17 canvas
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 capitalize
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 caseless
                  drwxrwxrwx+    6 iobroker iobroker  4096 Jan 21 15:23 cc-znp
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 cert-info
                  drwxrwxrwx+    3 iobroker iobroker  4096 Apr  7  2019 chai
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 chalk
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 chardet
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 charenc
                  drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 check-error
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:45 cheerio
                  drwxrwxrwx+    3 iobroker iobroker  4096 Apr 27  2019 chip.avr.avr109
                  drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 chokidar
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 chownr
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 ci-info
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 class-utils
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 clean-stack
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 cli
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 cli-boxes
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 cli-cursor
                  drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 cliff
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cli-truncate
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cliui
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cli-width
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cloneextend
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 clone-response
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 cluster-key-slot
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 co
                  drwxrwxr-x+    6 iobroker iobroker  4096 Okt 27 12:44 coap
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 coap-packet
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 code-point-at
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 coffee-compiler
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 coffee-script
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 collection-visit
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 color
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 color-convert
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 color-name
                  drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 colors
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 colorspace
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 color-string
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 color-support
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 combined-stream
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jan  9  2020 commander
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 commist
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 component-bind
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jun 17  2020 component-emitter
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 component-inherit
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 concat-map
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jun 30  2020 concat-stream
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 concentrate
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 configstore
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 connect-flash
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 console-control-strings
                  drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 content-disposition
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 content-type
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cookie
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:01 cookie-parser
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cookie-signature
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 copy-descriptor
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 copy-props
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 copy-to
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 core-util-is
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cosmiconfig
                  drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 create-react-app
                  drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 cron
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 cron-parser
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 cross-spawn
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 crypt
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez 11  2018 crypto-js
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 crypto-random-string
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 cssom
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:45 css-select
                  drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 cssstyle
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 css-what
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 curve25519-n
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cycle
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 d
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 @dabh
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 daemonize2
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 dashdash
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 data-uri-to-buffer
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 data-urls
                  drwxrwxrwx+  158 iobroker iobroker  4096 Dez 12  2018 date-fns
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 dateformat
                  drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 debounce
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 debug
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 decache
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 decamelize
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 decamelize-keys
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jan 15 04:52 decimal.js
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 decode-uri-component
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 decompress-response
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 deep-clone
                  drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 deep-eql
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 deep-equal
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 deep-extend
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jun  6  2019 deep-is
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 default-compare
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 default-user-agent
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 defer-to-connect
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 define-properties
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 define-property
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 degenerator
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 del
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 delayed-stream
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 delegates
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 denque
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 depd
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 destroy
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 detect-file
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 detect-libc
                  drwxrwxrwx+    4 iobroker iobroker  4096 Sep 14  2018 dev-null
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 dgram
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 dicer
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 digest-header
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 dir-glob
                  drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 diskusage
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 dissolve
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 dissolve-chunks
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 dns-packet
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 domelementtype
                  drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 domexception
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:45 domhandler
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 dom-serializer
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:45 domutils
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2018 dotenv
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 dot-prop
                  drwxrwxrwx+    6 iobroker iobroker  4096 Okt 11  2018 dropbox-v2-api
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 duplexer
                  drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 duplexer2
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 duplexer3
                  drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 duplexify
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 each-props
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 ecc-jsbn
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 ecdsa-sig-formatter
                  drwxrwxrwx+   13 iobroker iobroker  4096 Okt 27 13:17 echarts
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 eckles
                  drwxrwxrwx+    5 iobroker iobroker  4096 Sep 14  2018 ed25519-hap
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 ee-first
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 elegant-spinner
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jan 28  2020 emoji-regex
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 enabled
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 encodeurl
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 end-of-stream
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 engine.io
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 engine.io-client
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 engine.io-parser
                  drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:45 entities
                  drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 envinfo
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 error-ex
                  drwxrwxr-x+   17 iobroker iobroker  4096 Okt 27 12:44 es5-ext
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 es6-iterator
                  drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 es6-map
                  drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 es6-promise
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 es6-promisify
                  drwxrwxr-x+    7 iobroker iobroker  4096 Okt 27 12:44 es6-set
                  drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 es6-symbol
                  drwxrwxr-x+   13 iobroker iobroker  4096 Jul  1  2020 es-abstract
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 escape-goat
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 escape-html
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 escape-string-regexp
                  drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 escodegen
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 es-get-iterator
                  drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 esprima
                  drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 es-to-primitive
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 estraverse
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 esutils
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 etag
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 event-emitter
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 eventemitter3
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 event-stream
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 event-target-shim
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 execa
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 expand-brackets
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 expand-template
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 expand-tilde
                  drwxrwxrwx+    4 iobroker iobroker  4096 Nov 22  2019 express
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 express-fileupload
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:01 express-session
                  drwxrwxr-x+   13 iobroker iobroker  4096 Okt 27 12:44 ext
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 extend
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 extend-shallow
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 external-editor
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 extglob
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 extract-zip
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 extsprintf
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 eyes
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 fancy-log
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fast-deep-equal
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez  8 11:27 fast-glob
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 fast-json-stable-stringify
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 fast-levenshtein
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez  8 11:27 fastq
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 fast-safe-stringify
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 fastseries
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 fast-srp-hap
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 fast-text-encoding
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 fd-slicer
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 fecha
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 figures
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jan 28  2020 file-stream-rotator
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 file-type
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 file-uri-to-path
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 fill-range
                  drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 finalhandler
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 find-up
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 findup-sync
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 fined
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 flagged-respawn
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 fn.name
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 follow-redirects
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jan 15 04:52 foreach
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 forever-agent
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 for-in
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 form-data
                  drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 formstream
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 for-own
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 forwarded
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fragment-cache
                  drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 @frankjoke
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fresh
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 from
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fs-constants
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 fs-extra
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 fs-minipass
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fs.realpath
                  drwxrwxrwx+    4 iobroker iobroker  4096 Feb 16  2019 fstream
                  drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 fstream-ignore
                  drwxrwxrwx+    4 iobroker iobroker  4096 Okt 11  2018 ftp
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 function-bind
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jan 15 04:52 futoin-hkdf
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 gauge
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 gaxios
                  drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:26 gcp-metadata
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 get-caller-file
                  drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 get-func-name
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 get-intrinsic
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 getpass
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 get-stream
                  drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 get-uri
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 get-value
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 github-from-package
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 github-url-from-git
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 glob
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 global-dirs
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 global-modules
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 global-prefix
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 globby
                  drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 glob-parent
                  drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 glob-stream
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 glogg
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 glossy
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 googleapis
                  drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 googleapis-common
                  drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 google-auth-library
                  drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:26 google-p12-pem
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 got
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 graceful-fs
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 greenlock
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 greenlock-store-fs
                  drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 gtoken
                  drwxrwxr-x+    6 iobroker iobroker  4096 Okt 27 12:44 gulp-cli
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 gulplog
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 hap-nodejs
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 hard-rejection
                  drwxrwxr-x+    3 iobroker iobroker  4096 Apr 30  2020 @harmonyhub
                  drwxrwxr-x+    5 iobroker iobroker  4096 Apr 30  2020 harmonyhubws
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 har-schema
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 har-validator
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 has
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 has-ansi
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 has-binary2
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 has-cors
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 has-flag
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 hasha
                  drwxrwxrwx+    3 iobroker iobroker  4096 Mai 30  2019 has-symbols
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 has-unicode
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 has-value
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 has-values
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 has-yarn
                  drwxrwxr-x+    4 iobroker iobroker  4096 Apr 12  2020 help-me
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 hoek
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jan 15 04:52 @homebridge
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 homedir-polyfill
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 hosted-git-info
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 html-encoding-sniffer
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:45 htmlparser2
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 http-cache-semantics
                  drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 http-errors
                  drwxrwxr-x+    4 iobroker iobroker  4096 Dez  7 10:35 http-proxy
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 http-proxy-middleware
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 http-proxy-response-rewrite
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 https
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 http-signature
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 https-proxy-agent
                  drwxrwxr-x+    8 iobroker iobroker  4096 Mai  9  2020 hue-emu
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 humanize-ms
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 human-signals
                  drwxrwxrwx+    5 iobroker iobroker  4096 Feb 16  2019 hyperquest
                  drwxrwxrwx+    4 iobroker iobroker  4096 Nov 22  2019 iconv-lite
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 ieee754
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 ignore
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez 12 09:04 ignore-walk
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 immediate
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 import-fresh
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 import-lazy
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  8 11:27 import-local
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 imurmurhash
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 indent-string
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 indexof
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 inflight
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 inherits
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 ini
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 inquirer
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 inquirer-autosubmit-prompt
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 intel-hex
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 interpret
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 invert-kv
                  drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:04 @iobroker
                  drwxrwxr-x+    8 iobroker iobroker  4096 Okt 27 13:01 iobroker.admin
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jan 17 14:40 iobroker.alexa2
                  drwxrwxrwx+    7 iobroker iobroker  4096 Dez  7 11:47 iobroker.backitup
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.broadlink
                  drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 iobroker.broadlink2
                  drwxrwxrwx+    7 iobroker iobroker  4096 Dez 12 09:05 iobroker.cloud
                  drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:22 iobroker.daswetter
                  drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:13 iobroker.deconz
                  drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 iobroker.discovery
                  drwxrwxrwx+    6 iobroker iobroker  4096 Jan 12 13:14 iobroker.dwd
                  drwxrwxr-x+    6 iobroker iobroker  4096 Jul 24 10:11 iobroker.fb-checkpresence
                  drwxrwxrwx+    9 iobroker iobroker  4096 Jan 15 04:53 iobroker.flot
                  drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:19 iobroker.fullybrowser
                  drwxrwxr-x+    8 iobroker iobroker  4096 Okt 27 12:44 iobroker.fully-tablet-control
                  drwxrwxr-x+    8 iobroker iobroker  4096 Mai  1  2020 iobroker.habpanel
                  drwxrwxr-x+    4 iobroker iobroker  4096 Apr 30  2020 iobroker.harmony
                  drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:25 iobroker.history
                  drwxrwxr-x+    8 iobroker iobroker  4096 Mai  9  2020 iobroker.hueemu
                  drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:16 iobroker.ical
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.icons-icons8
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 iobroker.icons-mfd-png
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 iobroker.icons-mfd-svg
                  drwxrwxr-x+    7 iobroker iobroker  4096 Jun 28  2020 iobroker.info
                  drwxrwxrwx+    8 iobroker iobroker  4096 Dez 12 09:05 iobroker.iot
                  drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:21 iobroker.javascript
                  drwxrwxr-x+    7 iobroker iobroker  4096 Okt 29 04:00 iobroker.js-controller
                  drwxrwxrwx+    6 iobroker iobroker  4096 Apr  7  2019 iobroker.milight
                  drwxrwxrwx+    6 iobroker iobroker  4096 Jun  6  2019 iobroker.milight-smart-light
                  drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:27 iobroker.mobile
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 iobroker.objects-redis
                  drwxrwxr-x+    5 iobroker iobroker  4096 Aug 17 16:22 iobroker.onvif
                  drwxrwxr-x+    6 iobroker iobroker  4096 Jul  1  2020 iobroker.openligadb
                  drwxrwxrwx+    6 iobroker iobroker  4096 Sep  7  2018 iobroker.phantomjs
                  drwxrwxr-x+    6 iobroker iobroker  4096 Jul 27 14:35 iobroker.pi-hole
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.radar
                  drwxrwxrwx+    6 iobroker iobroker  4096 Jul  1  2020 iobroker.radar2
                  drwxrwxr-x+    6 iobroker iobroker  4096 Mär 19  2020 iobroker.rflink
                  drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:19 iobroker.shelly
                  drwxrwxrwx+    6 iobroker iobroker  4096 Okt 27 13:20 iobroker.simple-api
                  drwxrwxr-x+    7 iobroker iobroker  4096 Okt 27 12:45 iobroker.smartcontrol
                  drwxrwxr-x+    5 iobroker iobroker  4096 Aug 19 13:54 iobroker.smartgarden
                  drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:10 iobroker.socketio
                  drwxrwxr-x+    6 iobroker iobroker  4096 Apr 12  2020 iobroker.sonoff
                  drwxrwxr-x+    7 iobroker iobroker  4096 Jul  1  2020 iobroker.telegram
                  drwxrwxrwx+    6 iobroker iobroker  4096 Dez  9 10:37 iobroker.text2command
                  drwxrwxrwx+    5 iobroker iobroker  4096 Nov 24 16:16 iobroker.tr-064
                  drwxrwxrwx+    8 iobroker iobroker  4096 Dez 27 10:44 iobroker.trashschedule
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez 11  2018 iobroker.type-detector
                  drwxrwxrwx+    5 iobroker iobroker  4096 Apr 15  2019 iobroker.viessmannapi
                  drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:11 iobroker.vis
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-bars
                  drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-canvas-gauges
                  drwxrwxrwx+    6 iobroker iobroker  4096 Dez  8 11:25 iobroker.vis-colorpicker
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-fancyswitch
                  drwxrwxrwx+    7 iobroker iobroker  4096 Okt 18  2019 iobroker.vis-history
                  drwxrwxrwx+    7 iobroker iobroker  4096 Dez  7 11:29 iobroker.vis-hqwidgets
                  drwxrwxrwx+    6 iobroker iobroker  4096 Okt 27 13:23 iobroker.vis-icontwo
                  drwxrwxrwx+    6 iobroker iobroker  4096 Dez  8 11:27 iobroker.vis-inventwo
                  drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-jqui-mfd
                  drwxrwxrwx+    6 iobroker iobroker  4096 Nov 22  2019 iobroker.vis-justgage
                  drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-metro
                  drwxrwxrwx+    6 iobroker iobroker  4096 Dez  8 17:19 iobroker.vis-players
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-timeandweather
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jan  9  2020 iobroker.vis-weather
                  drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:13 iobroker.web
                  drwxrwxr-x+    8 iobroker iobroker  4096 Jul  1  2020 iobroker.xs1
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 iobroker.yahka
                  drwxrwxrwx+    9 iobroker iobroker  4096 Nov 25  2019 iobroker.zigbee
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 ioredis
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 ip
                  drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 ipaddr.js
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jun  6  2019 ip-regex
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 is
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jun  6  2019 is2
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-absolute
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-accessor-descriptor
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-arguments
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 isarray
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 is-arrayish
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-bigint
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 is-binary-path
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-boolean-object
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2019 is-buffer
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 is-callable
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-ci
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-data-descriptor
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 is-date-object
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-descriptor
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-docker
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12  2018 isemail
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 isexe
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-extendable
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-extglob
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 is-fullwidth-code-point
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-generator-function
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 is-glob
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 is-installed-globally
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-map
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-nan
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-negated-glob
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-negative-zero
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-npm
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-number
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-number-object
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-obj
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 isobject
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-observable
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-path-cwd
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-path-in-cwd
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-path-inside
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-plain-obj
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-plain-object
                  drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 is-potential-custom-element-name
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-promise
                  drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 is-regex
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-relative
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-scoped
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-set
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 isstream
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-stream
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-string
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 issue-regex
                  drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 is-symbol
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-typedarray
                  drwxrwxrwx+    6 iobroker iobroker  4096 Jan 15 04:52 is-typed-array
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-unc-path
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jun  6  2019 is-url
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 is-url-superb
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 is-utf8
                  drwxrwxrwx+    2 iobroker iobroker  4096 Apr 27  2019 isval
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-weakmap
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-weakset
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-windows
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 is-wsl
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-yarn-global
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 joi
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jun 15  2020 @jpgorganizer
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 jsbn
                  drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 jsdom
                  drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:21 jsonata
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 json-bigint
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 json-buffer
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 jsonfile
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 json-parse-better-errors
                  drwxrwxrwx+    9 iobroker iobroker  4096 Aug 31  2018 json-schema
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 json-schema-traverse
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 10  2019 json-stable-stringify-without-jsonify
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 json-stringify-safe
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 jsonwebtoken
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 jsprim
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 js-tokens
                  drwxrwxr-x+    6 iobroker iobroker  4096 Okt 27 13:04 jszip
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 jwa
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 jws
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 kew
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 keypairs
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 keyv
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 kind-of
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 klaw
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 kuler
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 latest-version
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 lcid
                  drwxrwxrwx+    6 iobroker iobroker  4096 Jul 20  2019 le-acme-core
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 le-challenge-fs
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 le-sni-auto
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 le-store-certbot
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 leven
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 levn
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 lie
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 liftoff
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 lines-and-columns
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 listr
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 listr-input
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 listr-silent-renderer
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 listr-update-renderer
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 listr-verbose-renderer
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 loadavg-windows
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 load-json-file
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 locate-path
                  drwxrwxrwx+    3 iobroker iobroker 20480 Aug 31  2018 lodash
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 lodash.defaults
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 lodash.flatten
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 lodash.get
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.includes
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isboolean
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isinteger
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isnumber
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isplainobject
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isstring
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.once
                  drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 lodash.sortby
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 lodash.zip
                  drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 logform
                  drwxrwxrwx+    6 iobroker iobroker  4096 Okt 27 13:19 loglevel
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 log-symbols
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 log-update
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 long-timeout
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 lowercase-keys
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jan  9  2020 lru-cache
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jan  9  2020 lru_map
                  drwxrwxrwx+    4 iobroker iobroker  4096 Mär  2  2019 luxon
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 macaddress
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 make-dir
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 make-iterator
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 map-age-cleaner
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 map-cache
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 map-obj
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 map-stream
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 map-visit
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 matchdep
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 md5
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 mdns-discovery
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 media-typer
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 mem
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 meow
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 merge2
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 merge-descriptors
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 merge-stream
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 methods
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 micromatch
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 mime
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 mime-db
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 mime-types
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 mimic-fn
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 mimic-response
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 minimatch
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 minimist
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 minimist-options
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 min-indent
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 minipass
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 minizlib
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 mixin-deep
                  drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 mkdirp
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 mkdirp-classic
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 moment
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 moment-timezone
                  drwxrwxrwx+   10 iobroker iobroker  4096 Dez 11  2018 mqtt
                  drwxrwxr-x+    4 iobroker iobroker  4096 Apr 12  2020 mqtt-connection
                  drwxrwxr-x+    5 iobroker iobroker  4096 Apr 12  2020 mqtt-packet
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 ms
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jan 15 04:52 multicast-dns
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep 14  2018 multicast-dns-service-types
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 mute-stdout
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 mute-stream
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 mz
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 nan
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 nanomatch
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 napi-build-utils
                  drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 napi-thread-safe-callback
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 ncp
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 nearest-color
                  drwxrwxrwx+    8 iobroker iobroker  4096 Dez 12 09:04 needle
                  drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 netmask
                  drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 net-ping
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 new-github-release-url
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 next-tick
                  drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 nimble
                  drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 noble
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mär 19  2020 node-abi
                  drwxrwxrwx+    6 iobroker iobroker  4096 Mai 29  2019 node-addon-api
                  drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 node-arp
                  drwxrwxrwx+    7 iobroker iobroker  4096 Mai 30  2019 node-bluetooth
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 node.extend
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 node-fetch
                  drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 node-forge
                  drwxrwxrwx+    2 iobroker iobroker  4096 Mär  2  2019 node-ical
                  drwxrwxrwx+    5 iobroker iobroker  4096 Dez  8 11:27 @nodelib
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jun  6  2019 node-milight-promise
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 node-mndp
                  drwxrwxrwx+    6 iobroker iobroker  4096 Sep 14  2018 node-persist
                  drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 node-pre-gyp
                  drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 node-rest-client
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 node-schedule
                  drwxrwxr-x+    9 iobroker iobroker  4096 Jul  1  2020 node-ssdp
                  drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 node-telegram-bot-api
                  drwxrwxrwx+    2 iobroker iobroker  4096 Feb 11  2019 node-wol
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 noop-logger
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12 09:04 nopt
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 normalize-package-data
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 normalize-path
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 normalize-url
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez  8 11:27 np
                  drwxrwxr-x+    9 iobroker iobroker  4096 Jan  9  2020 npm
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez 12 09:04 npm-bundled
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 npmlog
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 npm-name
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12 09:04 npm-normalize-package-bin
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez 12 09:04 npm-packlist
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 npm-run-path
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 nth-check
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 number-is-nan
                  drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 nwsapi
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 oauth-sign
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 object-assign
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jan  9  2020 object.assign
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 object-component
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 object-copy
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 object.defaults
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 object-hash
                  drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 object-inspect
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 object-is
                  drwxrwxrwx+    3 iobroker iobroker  4096 Mai 30  2019 object-keys
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 object.map
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 object.pick
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 object-visit
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 once
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 onetime
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 one-time
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 on-finished
                  drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 on-headers
                  drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 onvif
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 open
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 optionator
                  drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 ordered-read-streams
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 org-regex
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 osenv
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 os-homedir
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 os-locale
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 os-name
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 os-tmpdir
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 osx-release
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 ow
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 package-json
                  drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 pac-proxy-agent
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 pac-resolver
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 pako
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 parent-module
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:45 parse5
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 parse-filepath
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 parse-json
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 parse-node-version
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 parse-passwd
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 parseqs
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 parseuri
                  drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 parseurl
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 pascalcase
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:01 passport
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 passport-local
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 passport.socketio
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 passport-strategy
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 path-dirname
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-exists
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 path-is-absolute
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 path-is-inside
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-key
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-parse
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 path-root
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 path-root-regex
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 path-to-regexp
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-type
                  drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 pathval
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 pause
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 pause-stream
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 p-cancelable
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-defer
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 pend
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 performance-now
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 p-event
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-finally
                  drwxrwxrwx+    6 iobroker iobroker  4096 Sep  6  2018 phantomjs-prebuilt
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 picomatch
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 pidusage
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 pify
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 ping
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 pinkie
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 pinkie-promise
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-is-promise
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 pkg-dir
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 pkginfo
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-limit
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-locate
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-map
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-memoize
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 posix-character-classes
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mär 19  2020 prebuild-install
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 prelude-ls
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 prepend-http
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 pretty-hrtime
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 process-nextick-args
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 progress
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 promise-object
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 promise-retryer
                  drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 prompt
                  drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 proxy-addr
                  drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 proxy-agent
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 proxy-from-env
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 psl
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-timeout
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-try
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 pump
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 pumpify
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 punycode
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 pupa
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 pyconf
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 q
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 qs
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 querystring
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 quick-lru
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 random-bytes
                  drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 range-parser
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 rasha
                  drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 raw-body
                  drwxrwxrwx+    6 iobroker iobroker  4096 Mai 29  2019 raw-socket
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 rc
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 read
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 readable-stream
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 readdirp
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 readline-sync
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 read-pkg
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 read-pkg-up
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 rechoir
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 redent
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 redis-commands
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 redis-errors
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 redis-parser
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 regex-not
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 regexp.prototype.flags
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 registry-auth-token
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 registry-url
                  drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 reinterval
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 remove-trailing-separator
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 repeat-element
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 repeat-string
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 replace-homedir
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 request
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 request-progress
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 request-promise
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 request-promise-core
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 request-promise-native
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 require-directory
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 require-main-filename
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 requires-port
                  drwxrwxr-x+    5 iobroker iobroker  4096 Mai  1  2020 resolve
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  8 11:27 resolve-cwd
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 resolve-dir
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 resolve-from
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 resolve-url
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 respjs
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 responselike
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 restore-cursor
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 ret
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  8 11:27 reusify
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 revalidator
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 rimraf
                  drwxrwxrwx+    4 iobroker iobroker  4096 Mai  1  2020 @root
                  drwxrwxrwx+    3 iobroker iobroker  4096 Mär  2  2019 rrule
                  drwxrwxrwx+    6 iobroker iobroker  4096 Jul 20  2019 rsa-compat
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 run-async
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 run-parallel
                  drwxrwxr-x+   20 iobroker iobroker  4096 Mai  1  2020 rxjs
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 safe-buffer
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 safer-buffer
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 safe-regex
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 safe-replace
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 @samverschueren
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 sax
                  drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 saxes
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 scoped-regex
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mai  9  2020 selfsigned
                  drwxrwxr-x+    4 iobroker iobroker  4096 Apr 30  2020 semaphore
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 semver
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 semver-diff
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 semver-greatest-satisfied-range
                  drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 send
                  drwxrwxr-x+   11 iobroker iobroker  4096 Dez  7 10:35 @sentry
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mär 19  2020 serialport
                  drwxrwxr-x+   12 iobroker iobroker  4096 Mär 19  2020 @serialport
                  drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 serve-static
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 set-blocking
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 set-immediate-shim
                  drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 setprototypeof
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 set-value
                  drwxrwxr-x+    8 iobroker iobroker  4096 Aug  8 03:31 sharp
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 shebang-command
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 shebang-regex
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 shelly-iot
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 side-channel
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 signal-exit
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 simple-concat
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 simple-get
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12  2018 simple-oauth2
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 simple-swizzle
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 @sindresorhus
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 slash
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 slice-ansi
                  drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 smart-buffer
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 snapdragon
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 snapdragon-node
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 snapdragon-util
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 socket.io
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 socket.io-adapter
                  drwxrwxr-x+    5 iobroker iobroker  4096 Jun 17  2020 socket.io-client
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 socket.io-parser
                  drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 socks
                  drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 socks-proxy-agent
                  drwxrwxrwx+    5 iobroker iobroker  4096 Mai 30  2019 socksv5
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 sorted-array-functions
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 source-map
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 source-map-resolve
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 source-map-support
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 source-map-url
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 sparkles
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 spdx-correct
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 spdx-exceptions
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 spdx-expression-parse
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 spdx-license-ids
                  drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 split
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 split2
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 split-string
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 sshpk
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 stack-trace
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 standard-as-callback
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 static-extend
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 statuses
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 stealthy-require
                  drwxrwxr-x+    7 iobroker iobroker  4096 Jan  9  2020 stk500
                  drwxrwxr-x+    5 iobroker iobroker  4096 Mär 19  2020 stk500-v2
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 stream-combiner
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 streamifier
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 streamsearch
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 stream-shift
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 string_decoder
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 string.prototype.trimend
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 string.prototype.trimstart
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 string-width
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jan 28  2020 strip-ansi
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 strip-bom
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 strip-final-newline
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 strip-indent
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 strip-json-comments
                  drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 suncalc2
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 supports-color
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 supports-hyperlinks
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 sver-compat
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 symbol-observable
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 symbol-tree
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 systeminformation
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 @szmarczak
                  drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 tar
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 tar-fs
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 11  2018 targz
                  drwxrwxrwx+    4 iobroker iobroker  4096 Feb 16  2019 tar-pack
                  drwxrwxr-x+    3 iobroker iobroker  4096 Apr 11  2020 tar-stream
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 tcp-ping
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jun  6  2019 tcp-port-used
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 terminal-link
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 term-size
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 text-hex
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 thenify
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 thenify-all
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 throttleit
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 through
                  drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 through2
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 through2-filter
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 thunkify
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jan 15 04:52 thunky
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 time-stamp
                  drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 tmp
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 to-absolute-glob
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-array
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-buffer
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 toidentifier
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 to-object-path
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 topo
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 to-readable-stream
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-regex
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-regex-range
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 tough-cookie
                  drwxr-xr-x+    4 iobroker iobroker  4096 Okt 27 13:17 tr46
                  drwxrwxrwx+    2 iobroker iobroker  4096 Jun  6  2019 tree-kill
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 trim-newlines
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 triple-beam
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 tr-O64
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jan  9  2020 tslib
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 tunnel-agent
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 tweetnacl
                  drwxrwxr-x+   26 iobroker iobroker  4096 Okt 27 12:44 type
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 type-check
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 typedarray
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 typedarray-to-buffer
                  drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 type-detect
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 type-fest
                  drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 type-is
                  drwxrwxrwx+   26 iobroker iobroker  4096 Jan 17 14:40 @types
                  drwxrwxrwx+    4 iobroker iobroker  4096 Apr  7  2019 typescript
                  drwxrwxrwx+    3 iobroker iobroker  4096 Dez 22  2018 typescript-optional
                  drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 uid-number
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 uid-safe
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 unc-path-regex
                  drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:19 underscore
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 unescape
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 union-value
                  drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 unique-stream
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 unique-string
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 universalify
                  drwxrwxr-x+    6 iobroker iobroker  4096 Jan 28  2020 unix-dgram
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 unpi
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 unpipe
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 unset-value
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 update-notifier
                  drwxrwxr-x+    6 iobroker iobroker  4096 Mär 19  2020 uri-js
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 urix
                  drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 urllib
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 url-parse-lax
                  drwxrwxrwx+    5 iobroker iobroker  4096 Sep 24  2019 url-template
                  drwxrwxrwx+    6 iobroker iobroker  4096 Jul 20  2019 ursa-optional
                  drwxrwxrwx+    8 iobroker iobroker  4096 Aug 31  2018 usb
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 use
                  drwxrwxrwx+    3 iobroker iobroker  4096 Sep 14  2018 util
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 util-deprecate
                  drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 utile
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 utility
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 utils-merge
                  drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 uuid
                  drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 v8flags
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 validate-npm-package-license
                  drwxrwxrwx+    4 iobroker iobroker  4096 Feb 16  2019 validate-npm-package-name
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 vary
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 verror
                  drwxrwxrwx+    5 iobroker iobroker  4096 Dez 12  2018 viessmann-api-client
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 vinyl-sourcemaps-apply
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 virtual-device-sdk
                  drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:21 virtual-tsc
                  drwxrwxrwx+    5 iobroker iobroker  4096 Apr  7  2019 vm2
                  drwxr-xr-x+    3 iobroker iobroker  4096 Okt 27 13:17 w3c-hr-time
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 w3c-xmlserializer
                  drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 wake_on_lan
                  drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 weak-daemon
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 webidl-conversions
                  drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 websocket-stream
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 whatwg-encoding
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 whatwg-mimetype
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 whatwg-url
                  drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 which
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 which-boxed-primitive
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 which-collection
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 which-module
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 which-pm-runs
                  drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 which-typed-array
                  drwxrwxrwx+    2 iobroker iobroker  4096 Mär 19  2020 wide-align
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 widest-line
                  drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 win-release
                  drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 winston
                  drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 winston-daily-rotate-file
                  drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 winston-syslog
                  drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 winston-transport
                  drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 word-wrap
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 wrap-ansi
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 wrappy
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 write-file-atomic
                  drwxrwxr-x+    4 iobroker iobroker  4096 Apr 12  2020 ws
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 xdg-basedir
                  drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 xml2js
                  drwxrwxr-x+    2 iobroker iobroker  4096 Jun 14  2020 xml2json-light
                  drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 xmlbuilder
                  drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 xmlchars
                  drwxrwxr-x+    5 iobroker iobroker  4096 Jun 17  2020 xmlhttprequest-ssl
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 xml-name-validator
                  drwxrwxrwx+    3 iobroker iobroker  4096 Okt 11  2018 xregexp
                  drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 xtend
                  drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 y18n
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 yallist
                  drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 yaml
                  drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 yargs
                  drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 yargs-parser
                  drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 yauzl
                  drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 yeast
                  drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 yocto-queue
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 21 15:19 zcl-packet
                  drwxrwxrwx+    4 iobroker iobroker  4096 Jan 22 06:27 zigbee-shepherd
                  drwxrwxrwx+    5 iobroker iobroker  4096 Dez 10  2018 zigbee-shepherd-converters
                  drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:17 zrender
                  jens@iobroker:/root$
                  @chucky666 Wie schaut deine node-Installation aus?
                  chucky666C 1 Antwort Letzte Antwort
                  • UncleSamU UncleSam
                    Wenn in den nächsten Stunden nicht noch jemand mit einer guten Lösung kommt, würde ich vorschlagen: Backup machen, ioBroker Verzeichnis löschen, ioBroker neu installieren und Backup restoren
                    chucky666C Online
                    chucky666C Online
                    chucky666
                    @unclesam
                    Aber wird der Fehler nicht mit gesichert ?
                    UncleSamU 1 Antwort Letzte Antwort
                      chucky666C Online
                      chucky666C Online
                      chucky666
                      6.1.4.8
                      • chucky666C chucky666
                        6.1.4.8
                        @chucky666
                        Was soll das sein? Node6?
                        Ausgabe davon posten:
                        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                          @chucky666
                          chucky666C Online
                          chucky666C Online
                          chucky666
                          @thomas-braun sagte in Upgrade zigbee immer error:
                          usr/bin/nodejs
                          v12.19.0
                          /usr/bin/node
                          v12.19.0
                          /usr/bin/npm
                          6.14.8
                          nodejs:
                            Installiert:           12.19.0-1nodesource1
                            Installationskandidat: 12.19.0-1nodesource1
                            Versionstabelle:
                           *** 12.19.0-1nodesource1 500
                                  500 https://deb.nodesource.com/node_12.x stretch/main amd64 Packages
                               4.8.2~dfsg-1 500
                                  500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
                            usr/bin/nodejs
                            v12.19.0
                            /usr/bin/node
                            v12.19.0
                            /usr/bin/npm
                            6.14.8
                            nodejs:
                              Versionstabelle:
                                 4.8.2~dfsg-1 500
                            @chucky666
                            sudo apt update
                            sudo apt dist-upgrade
                            sudo reboot
                            Und mal schauen, ob du den Stretch nicht langsam hinter dir lassen willst. Der stirbt langsam.
                              @unclesam
                              UncleSamU Offline
                              UncleSamU Offline
                              UncleSam
                              @chucky666 Nein, bei einem Restore werden alle Adapter frisch (in der von dir vor dem Backup verwendeten Version) installiert. Damit sollte der Fehler weg sein.
                              Aber du kannst problemlos noch zuerst ein dist-upgrade machen wie @Thomas-Braun vorschlägt.
                              Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
                              ♡-lichen Dank an meine Sponsoren
                                @chucky666
                                sudo apt update
                                sudo reboot
                                chucky666C Online
                                chucky666C Online
                                chucky666
                                schrieb am zuletzt editiert von chucky666
                                Node.js
                                v12.20.1
                                NPM
                                6.14.10
                                Erledigt und nun ? Nochmal versuchen zu löschen oder zu updaten (zigbee Adapter ) ?
                                host.iobroker	2021-01-22 12:56:19.765	error	iobroker You might have to delete it yourself!
                                host.iobroker	2021-01-22 12:56:19.764	error	iobroker Error deleting adapter zigbee from disk: Error: host.iobroker: Cannot uninstall iobroker.zigbee: 1
                                Das steht immer im log wenn ich ihn löschen will
                                  Node.js
                                  v12.20.1
                                  NPM
                                  6.14.10
                                  @chucky666
                                  Warum kann der nicht gelöscht werden?
                                  Dateisystem in den Seilen?
                                  Rechte verfummelt?
                                  dmesg | grep -i ext4
                                    @chucky666
                                    Rechte verfummelt?
                                    chucky666C Online
                                    chucky666C Online
                                    chucky666
                                    [    2.187949] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                                    [    2.510257] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                                      @chucky666
                                      Das ist in Ordnung.
                                      iobroker update
                                      iobroker upgrade
                                        @chucky666
                                        Das ist in Ordnung.
                                        iobroker update
                                        iobroker upgrade
                                        chucky666C Online
                                        chucky666C Online
                                        chucky666
                                        Versuche ich
                                        Ich habe gerade mal ein paar Updates gemacht , dieser Fehler kommt bei manchen . Hängt das damit zusammen ? ```
                                        ./iobroker upgrade vis
                                        Update vis from @1.2.12 to @1.3.4
                                        NPM version: 6.14.10
                                        npm install iobroker.vis@1.3.4 --loglevel error --prefix "/opt/iobroker" (System call)
                                        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’   v8::String::Utf8Value path(info[0]->ToString());                                                ^In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67:0,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8-internal.h:14:0,                 from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const                 Local<String> ToString(Isolate* isolate) const);                               ^/home/iobroker/.cache/node-gyp/12.20.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided                 Local<String> ToString(Isolate* isolate) const);                               ^/home/iobroker/.cache/node-gyp/12.20.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’   v8::Local<v8::Object> options = info[1]->ToObject();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67:0,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2672:44: note:
                                          Versuche ich
                                          @chucky666
                                          Bitte in CodeTags packen.
                                          Das kann ja keiner lesen so.
