5.8k Beiträge 156 Kommentatoren 4.7m Aufrufe 137 Beobachtet
    banza
    #2112
    Frage zum Statistik-Script, ich möchte mir die Rekordwerte mit Tag anzeigen lassen, laut Skript müsste die Zeile
    let REKORDWERTE_AUSGABEFORMAT="[WERT] im [MONAT] [JAHR]";
    mit [TAG] ergänzt werden. Der Datenpunkt wird dann aber so geschrieben: 9.88 °C am [Tag] Januar 2021
    und das Log zeigt folgendes:
    2021-01-21 01:03:00.287 - warn: javascript.0 (23874) You are assigning a number to the state "0_userdata.0.Wetterstation.Statistik.Rekordwerte.Temperatur_Spitzenhoechstwert" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    2021-01-21 01:03:00.290 - warn: javascript.0 (23874) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1416:20)
    2021-01-21 01:03:00.291 - warn: javascript.0 (23874) at Rekordwerte (script.js.common.wetterstation-statistik:562:9)
    2021-01-21 01:03:00.291 - warn: javascript.0 (23874) at Object.cb (script.js.common.wetterstation-statistik:265:5)
    2021-01-21 01:03:00.292 - warn: javascript.0 (23874) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5297:71)
    2021-01-21 01:03:00.292 - warn: javascript.0 (23874) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:234:41)
    2021-01-21 01:03:00.293 - warn: javascript.0 (23874) at runCallback (timers.js:705:18)
    2021-01-21 01:03:00.293 - warn: javascript.0 (23874) at tryOnImmediate (timers.js:676:5)
    2021-01-21 01:03:00.293 - warn: javascript.0 (23874) at processImmediate (timers.js:658:5)
    2021-01-21 01:03:00.294 - warn: javascript.0 (23874) at process.topLevelDomainCallback (domain.js:126:23)
    2021-01-21 01:03:05.501 - warn: influxdb.0 (23336) Error on writePoint("{"value":"9.88 °C am [Tag] Januar 2021","time":"2021-01-21T00:03:05.341Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"partial write: field type conflict: input field \"value\" on measurement \"0_userdata.0.Wetterstation.Statistik.Rekordwerte.Temperatur_Spitzenhoechstwert\" is type string, already exists as type float dropped=1"}
    / "{\"error\":\"partial write: field type conflict: input field \\\"value\\\" on measurement \\\"0_userdata.0.Wetterstation.Statistik.Rekordwerte.Temperatur_Spitzenhoechstwert\\\" is type string, already exists as type float dropped=1\"}\n"
    2021-01-21 01:03:05.510 - warn: influxdb.0 (23336) Add 0_userdata.0.Wetterstation.Statistik.Rekordwerte.Temperatur_Spitzenhoechstwert to conflicting Points (1 now)
    • A amiethaner
      ich komm hier noch ned ganz klar... wie kann ich denn innerhalb des Freds hier suchen?
      Meine DNT zeigt mir am Display die richtige uhrzeit an - 06:58 die Daten kommen aber mit dem Zeitstempel 05:58 an.
      Kann ich das iwie / iwo ändern?
      a200A Offline
      a200A Offline
      a200
      #2113
      @amiethaner sagte in [Linux Shell-Skript] WLAN-Wetterstation:
      1. Was zeigt dein wetterstation.sh --debug?
      2. Hast du in der WS-App die richtige Zeitzone ausgewählt?
      3. Hat dein Rechner auf dem wetterstation.sh läuft die richtige Uhrzeit?
      Je nachdem (WS, Firmware, Protokoll) wird die Uhrzeit unterschiedlich übertragen (Timestamp in unterschiedlichen Variationen, now, u.ä.). Aber das kann man aus den Debug-Daten sehen.
      IoBroker auf QNAP TS-451, Raspi und NUC
      • a200A a200
        amiethaner
        #2114
        @a200 sagte in [Linux Shell-Skript] WLAN-Wetterstation:
        Zeit, Zeitzone, autom. Sync (funktioniert) und autom. Sommerzeit sind eingestellt. Am PC passt auch alles, aber im Debug sieht man das es dort auch "falsch" kommt.
        Kann es sein das die Station UTC sendet, und dur das Display und WU usw das umrechnet?
        a200A SBorgS 2 Antworten Letzte Antwort
        • A amiethaner
          a200A Offline
          a200A Offline
          a200
          #2115
          Das kann ich dir sagen, wenn ich sehe, was die WS sendet. Wenn sie "now" schickt, dann ist es schon i.O. Anderenfalls muss noch UCT umgerechnet werden. Siehe wetterstation.sub Ab Zeile 295
          • R Rand
            @a200
            So, hat etwas gedauert bis ich die beiden FWs in Sync hatte für den NTP Redirect...
            Musste Zeile 221 auch noch kleiner setzen da mit dem einen Sensor die Länge nur 185 Zeichen war
            Datenstring für ioBroker:
            javascript.0.Wetterstation.Innentemperatur=22.50&javascript.0.Wetterstation.Innenfeuchtigkeit=55&javascript.0.Wetterstation.Druck_absolut=978.09&javascript.0.Wetterstation.Druck_relativ=978.09&javascript.0.Wetterstation.Zeitstempel=21.01.2021%2000:18:58&javascript.0.Wetterstation.Info.FW_Version=GW1000A_V1.6.3&javascript.0.Wetterstation.Info.Wetterstation_Gateway=GW1000_Pro&javascript.0.Wetterstation.Regenstatus=&javascript.0.Wetterstation.UV_Belastung=&javascript.0.Wetterstation.Windrichtung_Text=
            DATA von Wetterstation:
            PASSKEY=SECRET&stationtype=GW1000A_V1.6.3&dateutc=2021-01-20+23:18:58&tempinf=72.5&humidityin=55&baromrelin=28.883&baromabsin=28.883&freq=868M&model=GW1000_Pro
            Debug VAR:
            Installationsverzeichnis: /home/iobroker
            IPP: 192.168.y.z:8087        WS_PORT: 1080           WS_POLL: 30             PRE_DP: javascript.0.Wetterstation
            WEB: HTTP               WS_PROT: Ecowitt        DP50/100: 1 | 0
            Script-Version: V2.1.0  Config-Version: V2.1.0  Sub-Version: V2.1.0
            Sieht ja schon mal ganz gut aus, danke sehr.
            Funktionieren alle bekannten/verfügbaren 868MhZ Sensoren mit dem Skript oder sind da noch welche zu implementieren?
            SBorgS Offline
            SBorgS Offline
            SBorg
            #2116
            @rand sagte in [Linux Shell-Skript] WLAN-Wetterstation:
            Alle wahrscheinlich nicht, da es bestimmt noch "unbekannte" gibt ;)
            Aktuell fehlt noch der DP60. Hier liegt der passende String vom Sensor zwar schon vor, aber es gab halt noch keine auswertbare Daten. Dauert also noch bis zum nächsten Gewitter bei jemandem der auch einen DP60 hat und dann einen String mit Daten zur Verfügung stellen kann.
            LG SBorg ( SBorg auf GitHub)
            R 1 Antwort Letzte Antwort
            • B banza
              SBorgS Offline
              SBorgS Offline
              SBorg
              #2117
              Neue Version des Wetterstation-Statistik-Addons auf GitHub V0.2.1
              • ~Bugfixing Rekordwerte Sitzenhöchst-/-tiefstwert
              Wie immer zu finden im GitHub (wetterstation-statistik.js)
              Update empfohlen, da sonst die Temperatur-Rekordwerte nicht korrekt gesetzt werden können.
              @banza sagte in [Linux Shell-Skript] WLAN-Wetterstation:
              Bitte auch updaten, fixed das Problem.
              SBorgS B 3 Antworten Letzte Antwort
              • A amiethaner
                SBorgS Offline
                SBorgS Offline
                SBorg
                #2118
                Wenn du mit Station die Außenheit meinst, nein, die sendet überhaupt keine Uhrzeit, lediglich Messwerte. Das Display macht dann aus den Daten den hier hinlänglich ( ;) ) bekannten Datenstring und schreibt es dann dank NTP-Kontakt (Zeitserver) in eine korrekte Uhrzeit, zumindest in UTC. Diese kann man dann in eine "richtige" dank der Zeitzone umrechnen. Du schreibst zwar Zeitzone ist korrekt, mich würde aber vom Datenempfangs-PC ein timedatectl interessieren (2. Befehl falls nicht Europe/Berlin) :
                • SBorgS SBorg
                  Rand
                  schrieb am zuletzt editiert von Rand
                  #2119
                  @sborg
                  Hi, ok dann warten wir mal.
                  Ich habe jetzt von jedem SensorTyp mal mindestens einen angeschaltet, so sieht es aktuell aus:
                  Messwerteblock: 22.50 20.88 56 56 0 0 270 977.51 977.51 0 5.1 5.5 5.5 5.5 0.00 0 21.01.2021%2014:09:50 GW1000A_V1.6.3 34.55 .9 .9 5.5 GW1000_Pro temp1f 20.90 humidity1 56 temp2f 20.90 humidity2 56 temp3f 20.80 humidity3 56 temp4f 11.20 humidity4 70 soilmoisture2 0 soilmoisture4 0 batt1 Alarm batt2 Alarm batt3 Alarm batt4 Alarm soilbatt2 1.6 soilbatt4 1.6
                  Nicht alle Werte werden unterstützt (abhängig vom Modell der Wetterstation und dem verwendeten Protokoll)!
                  Temperatur Innen        : 22.50 °C
                  Temperatur Aussen       : 20.88 °C
                  Taupunkt                :  °C
                  Chill-Faktor            :  °C
                  Luftfeuchte Innen       : 56 %
                  Luftfeuchte Aussen      : 56 %
                  Windgeschwindkeit       : 0 km/h
                  Windböengeschwindkeit   : 0 km/h
                  max. Windböe            : 34.55 km/h
                  Windrichtung            : 270 °
                  Windrichtung            : W
                  Luftdruck absolut       : 977.51 hPa
                  Luftdruck relativ       : 977.51 hPa
                  Regenrate               : 0 mm/h
                  Regenstatus             : kein Regen
                  Regen seit Regenbeginn  : .9 mm
                  Regen Stunde            : .9 mm
                  Regen Tag               : 5.1 mm
                  Regen Woche             : 5.5 mm
                  Regen Monat             : 5.5 mm
                  Regen Jahr              : 5.5 mm
                  Regen Gesamt            : 5.5 mm
                  Sonnenstrahlung         : 0.00 W/m²
                  UV-Index                : 0
                  Zeitstempel             : 21.01.2021%2014:09:50
                  Firmware                : GW1000A_V1.6.3
                  Batteriestand:          :
                  Gateway-Modell          : GW1000_Pro
                  Zusatzsensoren:
                  temp1f          : 20.90
                  humidity1               : 56
                  temp2f          : 20.90
                  humidity2               : 56
                  temp3f          : 20.80
                  humidity3               : 56
                  temp4f          : 11.20
                  humidity4               : 70
                  soilmoisture2           : 0
                  soilmoisture4           : 0
                  batt1           : Alarm
                  batt2           : Alarm
                  batt3           : Alarm
                  batt4           : Alarm
                  soilbatt2               : 1.6
                  soilbatt4               : 1.6
                  javascript.0.Wetterstation.Innentemperatur=22.50&javascript.0.Wetterstation.Aussentemperatur=20.88&javascript.0.Wetterstation.Innenfeuchtigkeit=56&javascript.0.Wetterstation.Aussenfeuchtigkeit=56&javascript.0.Wetterstation.Wind=0&javascript.0.Wetterstation.Wind_max=0&javascript.0.Wetterstation.Windrichtung=270&javascript.0.Wetterstation.Druck_absolut=977.51&javascript.0.Wetterstation.Druck_relativ=977.51&javascript.0.Wetterstation.Regenrate=0&javascript.0.Wetterstation.Regen_Tag=5.1&javascript.0.Wetterstation.Regen_Woche=5.5&javascript.0.Wetterstation.Regen_Monat=5.5&javascript.0.Wetterstation.Regen_Jahr=5.5&javascript.0.Wetterstation.Sonnenstrahlung=0.00&javascript.0.Wetterstation.UV_Index=0&javascript.0.Wetterstation.Zeitstempel=21.01.2021%2014:09:50&javascript.0.Wetterstation.Info.FW_Version=GW1000A_V1.6.3&javascript.0.Wetterstation.Windboeen_max=34.55&javascript.0.Wetterstation.Regen_Event=.9&javascript.0.Wetterstation.Regen_Stunde=.9&javascript.0.Wetterstation.Regen_Total=5.5&javascript.0.Wetterstation.Info.Wetterstation_Gateway=GW1000_Pro&javascript.0.Wetterstation.DP50.1.Temperatur=20.90&javascript.0.Wetterstation.DP50.1.Feuchtigkeit=56&javascript.0.Wetterstation.DP50.2.Temperatur=20.90&javascript.0.Wetterstation.DP50.2.Feuchtigkeit=56&javascript.0.Wetterstation.DP50.3.Temperatur=20.80&javascript.0.Wetterstation.DP50.3.Feuchtigkeit=56&javascript.0.Wetterstation.DP50.4.Temperatur=11.20&javascript.0.Wetterstation.DP50.4.Feuchtigkeit=70&javascript.0.Wetterstation.DP100.2.Bodenfeuchtigkeit=0&javascript.0.Wetterstation.DP100.4.Bodenfeuchtigkeit=0&javascript.0.Wetterstation.DP50.1.Batterie=Alarm&javascript.0.Wetterstation.DP50.2.Batterie=Alarm&javascript.0.Wetterstation.DP50.3.Batterie=Alarm&javascript.0.Wetterstation.DP50.4.Batterie=Alarm&javascript.0.Wetterstation.DP100.2.Batterie=1.6&javascript.0.Wetterstation.DP100.4.Batterie=1.6&javascript.0.Wetterstation.Regenstatus=kein Regen&javascript.0.Wetterstation.UV_Belastung=keine&javascript.0.Wetterstation.Windrichtung_Text=W
                  PASSKEY=geheim&stationtype=GW1000A_V1.6.3&dateutc=2021-01-21+13:09:50&tempinf=72.5&humidityin=56&baromrelin=28.866&baromabsin=28.866&tempf=69.6&humidity=56&winddir=270&windspeedmph=0.00&windgustmph=0.00&maxdailygust=21.47&solarradiation=0.00&uv=0&rainratein=0.000&eventrainin=0.039&hourlyrainin=0.039&dailyrainin=0.201&weeklyrainin=0.220&monthlyrainin=0.220&yearlyrainin=0.220&totalrainin=0.220&temp1f=69.62&humidity1=56&temp2f=69.62&humidity2=56&temp3f=69.44&humidity3=56&temp4f=52.16&humidity4=70&soilmoisture2=0&soilmoisture4=0&pm25_ch1=7.0&pm25_avg_24h_ch1=7.6&lightning_time=&lightning_num=0&lightning=&leak_ch1=0&leak_ch2=0&wh80batt=3.26&wh40batt=1.6&wh26batt=0&batt1=0&batt2=0&batt3=0&batt4=0&soilbatt2=1.6&soilbatt4=1.6&pm25batt1=5&wh57batt=5&leakbatt1=5&leakbatt2=5&freq=868M&model=GW1000_Pro
                  Folgende Sensoren sind vorhanden (von jedem ein oder mehrere aktiv):
                  Froggit	Ecowitt
                  DP1500	GW1000
                  DP40	WH32F
                  DP80 	WH40
                  nn      WS80
                  DP200	WH41
                  DP60	WH57
                  DP70	WH55
                  DP100	WH51
                  DP50	WH31
                  • R Rand
                    @sborg
                    Taupunkt                :  °C
                    Chill-Faktor            :  °C
                    Windrichtung            : W
                    Regenrate               : 0 mm/h
                    Regen Tag               : 5.1 mm
                    Regen Jahr              : 5.5 mm
                    UV-Index                : 0
                    Batteriestand:          :
                    Zusatzsensoren:
                    temp1f          : 20.90
                    humidity1               : 56
                    temp2f          : 20.90
                    humidity2               : 56
                    temp3f          : 20.80
                    humidity3               : 56
                    temp4f          : 11.20
                    humidity4               : 70
                    soilmoisture2           : 0
                    soilmoisture4           : 0
                    batt1           : Alarm
                    batt2           : Alarm
                    batt3           : Alarm
                    batt4           : Alarm
                    soilbatt2               : 1.6
                    soilbatt4               : 1.6
                    Froggit	Ecowitt
                    DP1500	GW1000
                    DP40	WH32F
                    DP80 	WH40
                    nn      WS80
                    DP200	WH41
                    DP60	WH57
                    DP70	WH55
                    DP100	WH51
                    DP50	WH31
                    SBorgS Offline
                    SBorgS Offline
                    SBorg
                    #2120
                    @rand Gibt es noch was was du nicht hast? 😁
                    Sieht für den Anfang aber mal gut aus.
                    Dürfte auch kein massives (außer die üblichen zeitlichen Probleme ;) ) Problem darstellen sie zu integrieren. Heißt dann aber leider auch für dich "Testkaninchen" spielen, denn ich habe meine Samples von Ecowitt schon lange abgeschrieben und @a200 hat auch nur ein paar.
                    Da heißt es also dann String zur Verfügung stellen (es genügt auch ein ./wetterstation.sh --data) und nach dem Update testen...
                    Was mich aktuell wundert ist
                    2.5 Ok, aber macht er kein 10.0 oder sogar 1.0?
                    • SBorgS SBorg
                      Rand
                      #2121
                      @sborg
                      ne, hab die große Rundumbestellung aus USA gemacht, wenn schon denn schon ;)
                      Und Tester spielen ist kein Problem, bin ja froh das ich sie nicht selbst implementieren muss (wobei das mit der Vorarbeit ja auch ginge).
                      Der 2.5 macht tatsächlich nur 2.5, es gibt ein neues Modell WH45 mit "PM2.5, PM10, CO2 concentration, Temperature and Humidity every 60 sec", aber den gabs noch nicht als ich bestellt hab und er ist Schweineteuer ($160).
                      Ich brauche hauptsächlich was für die Erkennung der Holzöfen der Nachbarn, da müssten die reichen.
                      Edit:
                      Eine Frage noch, warum steht eigentlich die Batterie der DP50's auf Alarm?
                      Da sind überall neue drin und
                      sieht doch jetzt auch nicht nach Fehler aus ?
                      • a200A a200
                        amiethaner
                        #2122
                        @a200
                        dateutc=2021-01-21%2014:20:35 kommt um 15:20
                        GET /weatherstation/updateweatherstation.php?ID=ZuHause&PASSWORD=1136&indoortempf=72.7&tempf=57.2&dewptf=33.1&windchillf=57.2&indoorhumidity=27&humidity=40&windspeedmph=0.0&windgustmph=1.1&winddir=248&absbaromin=27.942&baromin=29.714&rainin=0.000&dailyrainin=0.000&weeklyrainin=0.059&monthlyrainin=0.118&yearlyraini
                        n=0.118&solarradiation=38.53&UV=0&dateutc=2021-01-21%2014:20:35&softwaretype=EasyWeatherV1.5.6&action=updateraw&realtime=1&rtfreq=5 HTTP/1.0
                        @SBorg den Befehl hab ich in meinem Docker so nicht drin, den müsst ich dafür jetzt wieder zerlegen.
                        • A amiethaner
                          @a200
                          SBorgS Offline
                          SBorgS Offline
                          SBorg
                          #2123
                          @amiethaner Das ist korrekt so, also hat der Container eine falsche Zeitzone (meine irgendwo mal gelesen zu haben, dass diese nicht vom Host übernommen wird). Du müsstest aber die korrekte beim Aufruf mit übergeben können:
                          docker run -e TZ="Europe/Berlin" ...
                          Bin aber kein Docker-Experte ;)
                          • R Rand
                            @sborg
                            Edit:
                            SBorgS Offline
                            SBorgS Offline
                            SBorg
                            #2124
                            @rand Ok, dann erst mal den DP200/WH41 mit PM2.5 + 24h-Durchschnitt ;)
                            Mini-Fehler im Shell-Skript. Habe ich eben gefixt und sollte mit der kommenden Version funktionieren. Kann es aber nicht testen... 🙃
                            • SBorgS SBorg
                              amiethaner
                              #2125
                              @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                              Hät ich drin. Gut aber is auch ned schlimm. Der WErt letzte übertragung ist ja ned überlebensnotwenig, und in Grafana/Influx passt ja alles.
                              • SBorgS SBorg
                                da_WoodyD Online
                                da_WoodyD Online
                                #2126
                                @sborg i know, faulheit gehört bestraft...
                                ich dachte, ich bin schon auf der 1.4, dachte aber nur. is ja zeit, irgendwann halt ws_update...
                                woody@ioBroker:/home/iobroker$ ./ws_updater.sh
                                 'bc' installiert: ✓
                                 'jq' installiert: ✓
                                  Updater ist nur f▒r Versionen ab V1.4.0 !
                                wetterstation.js hab ich schon drüberlaufen lassen.
                                die frage: soll ich da jetzt die aktuellen wetterstation.sh, wetterstation.sub, wetterstation.conf (angepasst) drüberspielen?
                                R SBorgS 2 Antworten Letzte Antwort
                                • da_WoodyD da_Woody
                                   'bc' installiert: ✓
                                   'jq' installiert: ✓
                                  Rand
                                  #2127
                                  @a200
                                  Noch eine Frage, bekomme keinen Taupunkt und keinen Chillfaktor errechnet.
                                  Ist da noch was zu tun oder klappt das mit meiner HW nicht?
                                  Frage nur weil ich es dann aus dem Grafana Dashboard rausschmeissen würde...
                                  • R Rand
                                    @a200
                                    da_WoodyD Online
                                    da_WoodyD Online
                                    #2128
                                    @rand hast du auf ecowitt eingestellt? da gibts das nicht...
                                      Rand
                                      #2129
                                      @da_woody
                                      Ah ok, das war mir nicht bewusst, danke :)
                                      • Rene55R Offline
                                        Rene55R Offline
                                        Rene55
                                        #2130
                                        Mich würde mal interessieren, wie das Script an die Daten der Zusatzsensoren kommt. Ich hätte spass an einem DP60, wenn es nicht zuviel sonstigen Aufwand bedarf.
                                        a200A 1 Antwort Letzte Antwort
                                        • Rene55R Rene55
                                          a200A Offline
                                          a200A Offline
                                          a200
                                          #2131
                                          @rene55 @da_Woody @Rand
                                          Die Berechnung von Winchill und Taupunkt bei ecowitt ist fertig. Wird von @SBorg wahrscheinlich in der nächsten Version ausgerollt.
                                          @Rene55 Schick mir mal die debug-Ausgabe. Wenn ich sehe was DP60 liefert, dann kann ich auch den Sensor einbauen.
                                          da_WoodyD R 2 Antworten Letzte Antwort
