  4. Onkyo Adapter funktioniert nicht mehr
    6.4k
20 Beiträge 6 Kommentatoren 1.7k Aufrufe 5 Beobachtet
    Darkmann2000
    leider funktionert der Onkyo Adpater nach einem Neustart von Iobroker nicht mehr.
    Die neuste Version ist installiert. Ich habe den Adapter auch schon deinstalliert, leider ohne erfolg.
    Anbei der Debug Log:
    Lieben Gruß
    2021-01-19 20:42:42.069 - debug: onkyo.0 (3996) stateChange onkyo.0.Zone1.Power {"val":true,"ack":false,"ts":1611085362064,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1611085362064}
    2021-01-19 20:42:42.070 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:42:42.070 - debug: onkyo.0 (3996) Value: true
    2021-01-19 20:42:42.070 - debug: onkyo.0 (3996) id: onkyo.0.Zone1.Power
    2021-01-19 20:42:42.070 - debug: onkyo.0 (3996) new_val: PWR01
    2021-01-19 20:42:42.072 - debug: onkyo.0 (3996) stateChange onkyo.0.Zone1.InputSelect {"val":"00","ack":false,"ts":1611085362064,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1611085362064}
    2021-01-19 20:42:42.072 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:42:42.072 - debug: onkyo.0 (3996) Value: 00
    2021-01-19 20:42:42.072 - debug: onkyo.0 (3996) id: onkyo.0.Zone1.InputSelect
    2021-01-19 20:42:42.073 - debug: onkyo.0 (3996) new_val: SLI00
    2021-01-19 20:42:42.074 - debug: onkyo.0 (3996) stateChange onkyo.0.Device.command {"val":"PWR01","ack":false,"ts":1611085362072,"q":0,"from":"system.adapter.onkyo.0","user":"system.user.admin","lc":1611085362072}
    2021-01-19 20:42:42.074 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:42:42.074 - debug: onkyo.0 (3996) Value: PWR01
    2021-01-19 20:42:42.074 - debug: onkyo.0 (3996) id: onkyo.0.Device.command
    2021-01-19 20:42:42.074 - debug: onkyo.0 (3996) newcommand: PWR01
    2021-01-19 20:42:42.076 - error: onkyo.0 (3996) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR01"
    2021-01-19 20:42:42.077 - debug: onkyo.0 (3996) stateChange onkyo.0.Device.command {"val":"SLI00","ack":false,"ts":1611085362073,"q":0,"from":"system.adapter.onkyo.0","user":"system.user.admin","lc":1611085362073}
    2021-01-19 20:42:42.077 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:42:42.077 - debug: onkyo.0 (3996) Value: SLI00
    2021-01-19 20:42:42.077 - debug: onkyo.0 (3996) id: onkyo.0.Device.command
    2021-01-19 20:42:42.077 - debug: onkyo.0 (3996) newcommand: SLI00
    2021-01-19 20:42:42.078 - error: onkyo.0 (3996) Error: ERROR (send_not_connected) Not connected, can't send data: "SLI00"
    2021-01-19 20:43:03.854 - debug: onkyo.0 (3996) stateChange onkyo.0.Zone1.Power {"val":false,"ack":false,"ts":1611085383852,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1611085383852}
    2021-01-19 20:43:03.854 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:43:03.854 - debug: onkyo.0 (3996) Value: false
    2021-01-19 20:43:03.855 - debug: onkyo.0 (3996) id: onkyo.0.Zone1.Power
    2021-01-19 20:43:03.855 - debug: onkyo.0 (3996) new_val: PWR00
    2021-01-19 20:43:03.857 - debug: onkyo.0 (3996) stateChange onkyo.0.Device.command {"val":"PWR00","ack":false,"ts":1611085383856,"q":0,"from":"system.adapter.onkyo.0","user":"system.user.admin","lc":1611085383856}
    2021-01-19 20:43:03.857 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:43:03.857 - debug: onkyo.0 (3996) Value: PWR00
    2021-01-19 20:43:03.857 - debug: onkyo.0 (3996) id: onkyo.0.Device.command
    2021-01-19 20:43:03.857 - debug: onkyo.0 (3996) newcommand: PWR00
    2021-01-19 20:43:03.858 - error: onkyo.0 (3996) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR00"
    HomoranH 3 Antworten Letzte Antwort
    • D Darkmann2000
      Lieben Gruß
      @darkmann2000 Ist dein Onkyo online?
      Bitte logs nicht als screenshot, sondern als Text in code-tags psten
        Darkmann2000
        schrieb am zuletzt editiert von Darkmann2000
        Hi, sorry für den Log als JPG. Habe ich direkt geändert.
        Der Onkyo ist Online, und per Ping erreichbar.
        • D Darkmann2000
          Lieben Gruß
          @darkmann2000 sagte in Onkyo Adapter funktioniert nicht mehr:
          Dann müssen wir mal graben:
          läuft die Instanz?
          Ampel grün?
            läuft die Instanz?
            Ampel grün?
            Darkmann2000
            Ja, die Instanz läuft und die Ampel ist auf grün.
            • D Darkmann2000
              Lieben Gruß
              klappt das nur per Script nicht?
              Was passiert wenn du direkt in den Objekts änderst
                Darkmann2000
                Die gleiche Fehlermeldung. Habe es auch schon mit true,false, 00,01, PWR00, PWR01 probiert.
                Der reagiert nicht. Über die Onkyo App lässt sich der Verstärker steuern.
                2021-01-19 21:07:42.642 - error: onkyo.0 (13820) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR01"
                2021-01-19 21:07:42.644 - error: onkyo.0 (13820) Error: ERROR (send_not_connected) Not connected, can't send data: "SLI00"
                2021-01-19 21:07:59.823 - error: onkyo.0 (13820) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR00"
                • D Darkmann2000
                  @darkmann2000 Dann kann ich dir erst einmal nicht mehr weiterhelfen.
                  Es wäre tödlich jetzt am Onkyo zu spielen
                    Darkmann2000
                    Danke dir ersteinmal für deine Hilfe.
                    Lieben Gruß
                      Darkmann2000
                      leider bin ich bei dem Onkyo Adapter immer noch nicht weiter.
                      Habe heute folgenden Fehler im Log gesehen:
                      Lieben Gruß
                      2021-01-30 14:55:27.350 - info: host.Server(SmartHome) instance system.adapter.onkyo.0 started with pid 12944
                      2021-01-30 14:55:28.016 - warn: onkyo.0 (12944) Object onkyo.0.Zone1 is invalid: obj.type has an invalid value (object) but has to be one of state, channel, device, enum, host, adapter, instance, meta, config, script, user, group, chart, folder
                      2021-01-30 14:55:28.017 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
                      2021-01-30 14:55:28.018 - warn: onkyo.0 (12944) Object onkyo.0.Zone2 is invalid: obj.type has an invalid value (object) but has to be one of state, channel, device, enum, host, adapter, instance, meta, config, script, user, group, chart, folder
                      2021-01-30 14:55:28.018 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
                      2021-01-30 14:55:28.019 - warn: onkyo.0 (12944) Object onkyo.0.Zone3 is invalid: obj.type has an invalid value (object) but has to be one of state, channel, device, enum, host, adapter, instance, meta, config, script, user, group, chart, folder
                      2021-01-30 14:55:28.019 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
                      2021-01-30 14:55:28.034 - warn: onkyo.0 (12944) Object onkyo.0.Device.MediaState is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2021-01-30 14:55:28.034 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
                      2021-01-30 14:55:28.045 - warn: onkyo.0 (12944) Object onkyo.0.Device.CoverBase64 is invalid: obj.common.type has an invalid value (media.cover) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2021-01-30 14:55:28.046 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
                      2021-01-30 14:55:28.047 - warn: onkyo.0 (12944) Object onkyo.0.Device.CoverURL is invalid: obj.common.type has an invalid value (media.cover) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2021-01-30 14:55:28.047 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
                      2021-01-30 14:55:28.114 - info: onkyo.0 (12944) starting. Version 2.0.3 in C:/iobroker/SmartHome/node_modules/iobroker.onkyo, node: v10.17.0, js-controller: 3.1.6
                      2021-01-30 14:55:28.149 - info: onkyo.0 (12944) Connecting to AVR 192.168.178.26:60128
                      2021-01-30 14:56:30.867 - error: onkyo.0 (12944) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR01"
                      • D Darkmann2000
                        Lieben Gruß
                        danach hat er sich aber verbunden
                          Darkmann2000
                          ja war bei letzten mal auch. Die Ampel ist auch auf grün. Aber bei senden kommt immer (send_not_connected)
                          Sobald ein Befehl gesendet werden soll kommt immer die Fehlermeldung: (12944) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR01"
                          Eigentlich ist er ja verbunden
                          Was bedeutet das? Das war beim letzten mal nicht.
                          • D Darkmann2000
                            Dass die genannten Objekte demnächst nicht mehr erstellt werden und deswegen nicht verwendet werden sollten.
                            Ist aber eine Info für den Entwickler
                              Darkmann2000
                              Ok Danke für die Info.
                              Ich habe Eisbaeeer mal angeschrieben und auf dem Post hier verlinkt. Vielleicht hat er ja noch eine Idee.
                              Vielen Dank für deine Hilfe.
                              Lieben Gruß
                              EisbaeeerE 1 Antwort Letzte Antwort
                              • D Darkmann2000
                                Lieben Gruß
                                EisbaeeerE Offline
                                EisbaeeerE Offline
                                Eisbaeeer
                                @darkmann2000 Hast du vis installiert? Es gibt da noch ein Bug im Adapter. Wenn kein VIS installiert ist, kann er die Cover-Images nicht abspeichern, da er das Verzeichnis nicht findet. Um die Objekte muss ich mich auch noch kümmern. So langsam nimmt das viel Zeit in Anspruch, die Adapter immer wieder an die neue Struktur bzw. Vorgaben von iobroker anzupassen. Ich verstehe, dass sich iobroker weiter entwickelt, aber man sollte auch an vorhandene Adapter denken und nicht nur automatische Issue-checker scripts über die Adapter laufen lassen, die dem Entwickler dann Arbeit bescheren. Macht schlechte Stimmung. Das mal als feedback für das Core-Team. Grüße Eisbaeeer
                                Kein support per PM. Bitte im Forum Fragen stellen!
                                • EisbaeeerE Eisbaeeer
                                  Darkmann2000
                                  @eisbaeeer
                                  ja, Vis ist installiert.
                                  Lieben Gruß Mike
                                  • D Darkmann2000
                                    @eisbaeeer
                                    Lieben Gruß Mike
                                    spb1987
                                    schrieb am zuletzt editiert von spb1987
                                    @darkmann2000
                                    @Eisbaeeer
                                    Erstmal vielen Dank für den Adapter. Ich nutze ihn jetzt seit ca. 1 Jahr um mich morgens mit Radiomusik wecken zu lassen... bis zum Januar.
                                    Ich sehe bei mir die gleichen Probleme wie bereits beschrieben.
                                    Da ich aber 3 Instanzen am Laufen habe (2x NCP 302, 1x TX-8270) fiel mir auf, dass der beschriebene Fehler nur im Onkyo.0 Adapter (NCP 302) auftritt. Am zweiten NCP (Onkyo.1) und auch am TX (Onkyo.2) waren keine Auffälligkeiten.
                                    Ich habe heute mal quick and dirty mein Wecker-Skript (gar nicht so leicht ein TuneIn Sender im NCP anzusteuern) auf Onkyo.2 geändert und dort logischerweise die IP vom ehem. Onkyo.0 eingegeben.
                                    Die ersten Tests sehen gut aus. Ich berichte morgen wie ich geweckt wurde.
                                    #edit: Der Wecker hat heute morgen problemlos funktioniert. Wenn ihr ggf. Traces/Logs benötigt, sagt bitte Bescheid, was ihr benötigt. Möchte gerne Helfen.
                                    • EisbaeeerE Offline
                                      EisbaeeerE Offline
                                      Eisbaeeer
                                      Hallo zusammen
                                      Ich bin derzeit am überlegen, ob ich mir einen neuen Onkyo oder Pioneer zulege. Ich bräuchte jetzt mal Eure Hilfe, da ich den Adapter weiter nutzen möchte bzw. dann auch mit neuen Funktionen erweitern will, die ich derzeit gar nicht habe. Welcher Receiver ist derzeit aktuell mit folgenden Funktionen und nutzt diesen Adapter:
                                      • 7.2 mit Möglichkeit zur 2. Zone (Küche sollte separat angesteuert werden (dann bleibt noch 5.1 für das Wohnzimmer).
                                      • Wiedergabemöglichkeit von CD, Blueray, digitale Inhalte in der 2. Zone (geht mit dem derzeitigen nicht, das ist derzeit nur mit analogen Quellen möglich)
                                      • Netzwerk Streaming dienste (Radio, Amazon, etc.)
                                      • Anbindung von Plex (optional)
                                      Was könnt ihr mir empfehlen? Was ist gerade der Hype?
                                      Derzeit nutze ich einen TX-NR626
                                      Bin gespannt. Grüße Eisbaeeer
                                      ice987I ostseereiterO 2 Antworten Letzte Antwort
                                        Hallo zusammen
                                        ice987I Offline
                                        ice987I Offline
                                        ice987
                                        schrieb am zuletzt editiert von ice987
                                        @eisbaeeer
                                        Ich hab´ einen TX-NR656, wenns ums Testen von neuen Funktionen geht, nur melden! Ich bin auch interessiert an einer Weiterentwicklung des Adapters 😊
                                        husqvarna-automower, meteoblue, wiserbyfeller, spritmonitor
                                          Hallo zusammen
                                          ostseereiterO Offline
                                          ostseereiter
                                          @eisbaeeer ich habe einen onkyo tx 535 schon etwas älter aber tut es mit deinem Adapter.
                                          Gruß OSR
                                          Plattform
