  4. Onkyo Adapter funktioniert nicht mehr
    6.4k
20 Beiträge 6 Kommentatoren 1.7k Aufrufe 5 Beobachtet
  • D Darkmann2000
    leider funktionert der Onkyo Adpater nach einem Neustart von Iobroker nicht mehr.
    Die neuste Version ist installiert. Ich habe den Adapter auch schon deinstalliert, leider ohne erfolg.
    Anbei der Debug Log:
    Lieben Gruß
    2021-01-19 20:42:42.069 - debug: onkyo.0 (3996) stateChange onkyo.0.Zone1.Power {"val":true,"ack":false,"ts":1611085362064,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1611085362064}
    2021-01-19 20:42:42.070 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:42:42.070 - debug: onkyo.0 (3996) Value: true
    2021-01-19 20:42:42.070 - debug: onkyo.0 (3996) id: onkyo.0.Zone1.Power
    2021-01-19 20:42:42.070 - debug: onkyo.0 (3996) new_val: PWR01
    2021-01-19 20:42:42.072 - debug: onkyo.0 (3996) stateChange onkyo.0.Zone1.InputSelect {"val":"00","ack":false,"ts":1611085362064,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1611085362064}
    2021-01-19 20:42:42.072 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:42:42.072 - debug: onkyo.0 (3996) Value: 00
    2021-01-19 20:42:42.072 - debug: onkyo.0 (3996) id: onkyo.0.Zone1.InputSelect
    2021-01-19 20:42:42.073 - debug: onkyo.0 (3996) new_val: SLI00
    2021-01-19 20:42:42.074 - debug: onkyo.0 (3996) stateChange onkyo.0.Device.command {"val":"PWR01","ack":false,"ts":1611085362072,"q":0,"from":"system.adapter.onkyo.0","user":"system.user.admin","lc":1611085362072}
    2021-01-19 20:42:42.074 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:42:42.074 - debug: onkyo.0 (3996) Value: PWR01
    2021-01-19 20:42:42.074 - debug: onkyo.0 (3996) id: onkyo.0.Device.command
    2021-01-19 20:42:42.074 - debug: onkyo.0 (3996) newcommand: PWR01
    2021-01-19 20:42:42.076 - error: onkyo.0 (3996) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR01"
    2021-01-19 20:42:42.077 - debug: onkyo.0 (3996) stateChange onkyo.0.Device.command {"val":"SLI00","ack":false,"ts":1611085362073,"q":0,"from":"system.adapter.onkyo.0","user":"system.user.admin","lc":1611085362073}
    2021-01-19 20:42:42.077 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:42:42.077 - debug: onkyo.0 (3996) Value: SLI00
    2021-01-19 20:42:42.077 - debug: onkyo.0 (3996) id: onkyo.0.Device.command
    2021-01-19 20:42:42.077 - debug: onkyo.0 (3996) newcommand: SLI00
    2021-01-19 20:42:42.078 - error: onkyo.0 (3996) Error: ERROR (send_not_connected) Not connected, can't send data: "SLI00"
    2021-01-19 20:43:03.854 - debug: onkyo.0 (3996) stateChange onkyo.0.Zone1.Power {"val":false,"ack":false,"ts":1611085383852,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1611085383852}
    2021-01-19 20:43:03.854 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:43:03.854 - debug: onkyo.0 (3996) Value: false
    2021-01-19 20:43:03.855 - debug: onkyo.0 (3996) id: onkyo.0.Zone1.Power
    2021-01-19 20:43:03.855 - debug: onkyo.0 (3996) new_val: PWR00
    2021-01-19 20:43:03.857 - debug: onkyo.0 (3996) stateChange onkyo.0.Device.command {"val":"PWR00","ack":false,"ts":1611085383856,"q":0,"from":"system.adapter.onkyo.0","user":"system.user.admin","lc":1611085383856}
    2021-01-19 20:43:03.857 - debug: onkyo.0 (3996) ack is not set!
    2021-01-19 20:43:03.857 - debug: onkyo.0 (3996) Value: PWR00
    2021-01-19 20:43:03.857 - debug: onkyo.0 (3996) id: onkyo.0.Device.command
    2021-01-19 20:43:03.857 - debug: onkyo.0 (3996) newcommand: PWR00
    2021-01-19 20:43:03.858 - error: onkyo.0 (3996) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR00"
    @darkmann2000 sagte in Onkyo Adapter funktioniert nicht mehr:
    klappt das nur per Script nicht?
    Was passiert wenn du direkt in den Objekts änderst
      Darkmann2000
      schrieb am zuletzt editiert von Darkmann2000
      Die gleiche Fehlermeldung. Habe es auch schon mit true,false, 00,01, PWR00, PWR01 probiert.
      Der reagiert nicht. Über die Onkyo App lässt sich der Verstärker steuern.
      2021-01-19 21:07:42.642 - error: onkyo.0 (13820) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR01"
      2021-01-19 21:07:42.644 - error: onkyo.0 (13820) Error: ERROR (send_not_connected) Not connected, can't send data: "SLI00"
      2021-01-19 21:07:59.823 - error: onkyo.0 (13820) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR00"
      • D Darkmann2000
        @darkmann2000 Dann kann ich dir erst einmal nicht mehr weiterhelfen.
        Es wäre tödlich jetzt am Onkyo zu spielen
          Darkmann2000
          Danke dir ersteinmal für deine Hilfe.
          Lieben Gruß
            Darkmann2000
            leider bin ich bei dem Onkyo Adapter immer noch nicht weiter.
            Habe heute folgenden Fehler im Log gesehen:
            Lieben Gruß
            2021-01-30 14:55:27.350 - info: host.Server(SmartHome) instance system.adapter.onkyo.0 started with pid 12944
            2021-01-30 14:55:28.016 - warn: onkyo.0 (12944) Object onkyo.0.Zone1 is invalid: obj.type has an invalid value (object) but has to be one of state, channel, device, enum, host, adapter, instance, meta, config, script, user, group, chart, folder
            2021-01-30 14:55:28.017 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
            2021-01-30 14:55:28.018 - warn: onkyo.0 (12944) Object onkyo.0.Zone2 is invalid: obj.type has an invalid value (object) but has to be one of state, channel, device, enum, host, adapter, instance, meta, config, script, user, group, chart, folder
            2021-01-30 14:55:28.018 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
            2021-01-30 14:55:28.019 - warn: onkyo.0 (12944) Object onkyo.0.Zone3 is invalid: obj.type has an invalid value (object) but has to be one of state, channel, device, enum, host, adapter, instance, meta, config, script, user, group, chart, folder
            2021-01-30 14:55:28.019 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
            2021-01-30 14:55:28.034 - warn: onkyo.0 (12944) Object onkyo.0.Device.MediaState is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
            2021-01-30 14:55:28.034 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
            2021-01-30 14:55:28.045 - warn: onkyo.0 (12944) Object onkyo.0.Device.CoverBase64 is invalid: obj.common.type has an invalid value (media.cover) but has to be one of number, string, boolean, array, object, mixed, file, json
            2021-01-30 14:55:28.046 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
            2021-01-30 14:55:28.047 - warn: onkyo.0 (12944) Object onkyo.0.Device.CoverURL is invalid: obj.common.type has an invalid value (media.cover) but has to be one of number, string, boolean, array, object, mixed, file, json
            2021-01-30 14:55:28.047 - warn: onkyo.0 (12944) This object will not be created in future versions. Please report this to the developer.
            2021-01-30 14:55:28.114 - info: onkyo.0 (12944) starting. Version 2.0.3 in C:/iobroker/SmartHome/node_modules/iobroker.onkyo, node: v10.17.0, js-controller: 3.1.6
            2021-01-30 14:55:28.149 - info: onkyo.0 (12944) Connecting to AVR 192.168.178.26:60128
            2021-01-30 14:56:30.867 - error: onkyo.0 (12944) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR01"
            • D Darkmann2000
              Lieben Gruß
              danach hat er sich aber verbunden
                Darkmann2000
                ja war bei letzten mal auch. Die Ampel ist auch auf grün. Aber bei senden kommt immer (send_not_connected)
                Sobald ein Befehl gesendet werden soll kommt immer die Fehlermeldung: (12944) Error: ERROR (send_not_connected) Not connected, can't send data: "PWR01"
                Eigentlich ist er ja verbunden
                Was bedeutet das? Das war beim letzten mal nicht.
                • D Darkmann2000
                  Dass die genannten Objekte demnächst nicht mehr erstellt werden und deswegen nicht verwendet werden sollten.
                  Ist aber eine Info für den Entwickler
                    Darkmann2000
                    Ok Danke für die Info.
                    Ich habe Eisbaeeer mal angeschrieben und auf dem Post hier verlinkt. Vielleicht hat er ja noch eine Idee.
                    Vielen Dank für deine Hilfe.
                    Lieben Gruß
                    EisbaeeerE 1 Antwort Letzte Antwort
                    • D Darkmann2000
                      Lieben Gruß
                      EisbaeeerE Offline
                      EisbaeeerE Offline
                      Eisbaeeer
                      @darkmann2000 Hast du vis installiert? Es gibt da noch ein Bug im Adapter. Wenn kein VIS installiert ist, kann er die Cover-Images nicht abspeichern, da er das Verzeichnis nicht findet. Um die Objekte muss ich mich auch noch kümmern. So langsam nimmt das viel Zeit in Anspruch, die Adapter immer wieder an die neue Struktur bzw. Vorgaben von iobroker anzupassen. Ich verstehe, dass sich iobroker weiter entwickelt, aber man sollte auch an vorhandene Adapter denken und nicht nur automatische Issue-checker scripts über die Adapter laufen lassen, die dem Entwickler dann Arbeit bescheren. Macht schlechte Stimmung. Das mal als feedback für das Core-Team. Grüße Eisbaeeer
                      Kein support per PM. Bitte im Forum Fragen stellen!
                      • EisbaeeerE Eisbaeeer
                        Darkmann2000
                        @eisbaeeer
                        ja, Vis ist installiert.
                        Lieben Gruß Mike
                        • D Darkmann2000
                          @eisbaeeer
                          Lieben Gruß Mike
                          spb1987
                          schrieb am zuletzt editiert von spb1987
                          @darkmann2000
                          @Eisbaeeer
                          Erstmal vielen Dank für den Adapter. Ich nutze ihn jetzt seit ca. 1 Jahr um mich morgens mit Radiomusik wecken zu lassen... bis zum Januar.
                          Ich sehe bei mir die gleichen Probleme wie bereits beschrieben.
                          Da ich aber 3 Instanzen am Laufen habe (2x NCP 302, 1x TX-8270) fiel mir auf, dass der beschriebene Fehler nur im Onkyo.0 Adapter (NCP 302) auftritt. Am zweiten NCP (Onkyo.1) und auch am TX (Onkyo.2) waren keine Auffälligkeiten.
                          Ich habe heute mal quick and dirty mein Wecker-Skript (gar nicht so leicht ein TuneIn Sender im NCP anzusteuern) auf Onkyo.2 geändert und dort logischerweise die IP vom ehem. Onkyo.0 eingegeben.
                          Die ersten Tests sehen gut aus. Ich berichte morgen wie ich geweckt wurde.
                          #edit: Der Wecker hat heute morgen problemlos funktioniert. Wenn ihr ggf. Traces/Logs benötigt, sagt bitte Bescheid, was ihr benötigt. Möchte gerne Helfen.
                          • EisbaeeerE Offline
                            EisbaeeerE Offline
                            Eisbaeeer
                            Hallo zusammen
                            Ich bin derzeit am überlegen, ob ich mir einen neuen Onkyo oder Pioneer zulege. Ich bräuchte jetzt mal Eure Hilfe, da ich den Adapter weiter nutzen möchte bzw. dann auch mit neuen Funktionen erweitern will, die ich derzeit gar nicht habe. Welcher Receiver ist derzeit aktuell mit folgenden Funktionen und nutzt diesen Adapter:
                            • 7.2 mit Möglichkeit zur 2. Zone (Küche sollte separat angesteuert werden (dann bleibt noch 5.1 für das Wohnzimmer).
                            • Wiedergabemöglichkeit von CD, Blueray, digitale Inhalte in der 2. Zone (geht mit dem derzeitigen nicht, das ist derzeit nur mit analogen Quellen möglich)
                            • Netzwerk Streaming dienste (Radio, Amazon, etc.)
                            • Anbindung von Plex (optional)
                            Was könnt ihr mir empfehlen? Was ist gerade der Hype?
                            Derzeit nutze ich einen TX-NR626
                            Bin gespannt. Grüße Eisbaeeer
                            ice987I ostseereiterO 2 Antworten Letzte Antwort
                              Hallo zusammen
                              ice987I Offline
                              ice987I Offline
                              ice987
                              schrieb am zuletzt editiert von ice987
                              @eisbaeeer
                              Ich hab´ einen TX-NR656, wenns ums Testen von neuen Funktionen geht, nur melden! Ich bin auch interessiert an einer Weiterentwicklung des Adapters 😊
                              husqvarna-automower, meteoblue, wiserbyfeller, spritmonitor
                                Hallo zusammen
                                ostseereiterO Offline
                                ostseereiter
                                @eisbaeeer ich habe einen onkyo tx 535 schon etwas älter aber tut es mit deinem Adapter.
                                Gruß OSR
                                Plattform
