  4. Beta Test js-controller 3.2.x auf GitHub
    6.7k
js-controller
287 Beiträge 25 Kommentatoren 80.1k Aufrufe 29 Beobachtet
  • apollon77A apollon77
    @ilovegym interessant. Checke ich nachher genauer. Legst mir bitte ein issue an dazu?
    @apollon77 Ok, habs schon, fix kommt gleich
    • sigi234S sigi234
      @apollon77
      Hallo, hier der Bericht:
      Installation unter Windows hat beim 1. Mal nicht geklappt. Nach Neustart und nochmaliger installation dann doch.
      Install Logs:
      *** Welcome to ioBroker. ***
      *** Type 'iobroker help' for list of instructions. ***
      *** For more help see ***
      *** https://github.com/ioBroker/ioBroker.docs ***
      Your environment has been set up for using Node.js 12.20.1 (x64) and npm.
      C:\Program Files\iobroker\Test>iobroker list instances
      internal/modules/cjs/loader.js:818
      throw err;
      Error: Cannot find module 'node-forge'
      Require stack:
      • C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\tools.js
      • C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\setup.js
      • C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\iobroker.js
        ←[90m at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)←[39m
        ←[90m at Function.Module._load (internal/modules/cjs/loader.js:667:27)←[39m
        ←[90m at Module.require (internal/modules/cjs/loader.js:887:19)←[39m
        ←[90m at require (internal/modules/cjs/helpers.js:74:18)←[39m
        at Object.<anonymous> (C:\Program Files\iobroker\Test\node_modules\←[4miobroker.js-controller←[24m\lib\tools.js:7:19)
        ←[90m at Module._compile (internal/modules/cjs/loader.js:999:30)←[39m
        ←[90m at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)←[39m
        ←[90m at Module.load (internal/modules/cjs/loader.js:863:32)←[39m
        ←[90m at Function.Module._load (internal/modules/cjs/loader.js:708:14)←[39m
        ←[90m at Module.require (internal/modules/cjs/loader.js:887:19)←[39m {
        code: ←[32m'MODULE_NOT_FOUND'←[39m,
        requireStack: [
        ←[32m'C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\tools.js'←[39m,
        ←[32m'C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\setup.js'←[39m,
        ←[32m'C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\iobroker.js'←[39m
      C:\Program Files\iobroker\Test>iobroker update
      throw err;
      Require stack:
        requireStack: [
      C:\Program Files\iobroker\Test>iobroker update self
      throw err;
      Require stack:
        requireStack: [
      C:\Program Files\iobroker\Test>npm install ioBroker/ioBroker.js-controller
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      iobroker.js-controller@3.2.1 preinstall C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller
      node lib/preinstallCheck.js
      NPM version: 6.14.8
      iobroker.js-controller@3.2.1 install C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller
      node iobroker.js setup first
      30 file(s) successfully synchronized with ioBroker storage.
      Please DO NOT copy files manually into ioBroker storage directories!
      The following notifications happened during sync:
      • Added 6 Files in Directory "echarts"
      • Added 14 Files in Directory "echarts.admin"
      • Added 10 Files in Directory "iqontrol"
      @root/acme@3.1.0 postinstall C:\Program Files\iobroker\Test\node_modules@root\acme
      node scripts/postinstall
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules\chokidar\node_modules\fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
      npm WARN @date-io/date-fns@1.3.13 requires a peer of date-fns@^2.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN @material-ui/pickers@3.2.10 requires a peer of @material-ui/core@^4.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN @material-ui/pickers@3.2.10 requires a peer of react@^16.8.4 but none is installed. You must install peer dependencies yourself.
      npm WARN @material-ui/pickers@3.2.10 requires a peer of react-dom@^16.8.4 but none is installed. You must install peer dependencies yourself.
      npm WARN babel-eslint@10.1.0 requires a peer of eslint@>= 4.12.1 but none is installed. You must install peer dependencies yourself.
      npm WARN react-transition-group@4.4.1 requires a peer of react@>=16.6.0 but none is installed. You must install peer dependencies yourself.
      npm WARN react-transition-group@4.4.1 requires a peer of react-dom@>=16.6.0 but none is installed. You must install peer dependencies yourself.
      npm WARN rifm@0.7.0 requires a peer of react@>=16.8 but none is installed. You must install peer dependencies yourself.
      • iobroker.js-controller@3.2.1
        added 63 packages from 32 contributors, updated 1 package and audited 3366 packages in 98.966s
      110 packages are looking for funding
      run npm fund for details
      found 102 vulnerabilities (90 low, 4 moderate, 8 high)
      run npm audit fix to fix them, or npm audit for details
      Aktuelle Logs:
      hm-rpc.1	2021-01-09 09:33:13.985	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:33:13.072	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:31:43.974	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:31:43.063	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:30:13.970	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:30:13.060	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:28:43.949	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:28:43.054	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:27:13.949	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:27:13.045	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:25:43.939	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:25:43.035	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:24:13.910	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:24:13.031	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:23:10.067	warn	(9664) State "hm-rpc.1.00091A49A082FC.1.PRESS_SHORT" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:22:43.899	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:22:43.020	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:22:09.372	warn	(9664) State "hm-rpc.1.00091A49A082FC.1.PRESS_SHORT" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:21:13.889	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:21:13.011	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:19:44.202	warn	(9664) State "hm-rpc.1.00091A49A082FC.1.PRESS_SHORT" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:19:43.874	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:19:43.001	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:18:43.523	warn	(9664) State "hm-rpc.1.00091A49A082FC.1.PRESS_SHORT" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:18:13.877	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:18:12.992	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.1	2021-01-09 09:16:43.859	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      hm-rpc.0	2021-01-09 09:16:42.990	warn	(7112) State "hm-rpc.0.CENTRAL.PONG" has no existing object, this might lead to an error in future versions
      host.Medion(Test)	2021-01-09 09:16:13.400	error	instance system.adapter.ical.1 terminated with code 134 (134)
      host.Medion(Test)	2021-01-09 09:15:58.592	error	instance system.adapter.ical.0 terminated with code 134 (134)
      hm-rpc.1	2021-01-09 09:15:13.852	warn	(9664) State "hm-rpc.1.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
      Platform: Windows
      RAM: 16 GB
      Node.js: v12.20.1
      NPM: 6.14.10
      JS Controler: 3.2.1
      Admin: 4.2.0
      Web: 3.2.0
      Socket.io: 3.0.13
      Script Engine: 4.10.8
      IOT: 1.8.8
      VIS: 1.3.6
      Bericht 2
      Update auf Version 3.2.2 hat problemlos geklappt.
      @sigi234 Also das scheint wieder dieses "Windows wirft npm Pakete weg die es nicht sollte sein ... wenn es dann geklappt hat cool.
      Die "... has no existing object, this might lead to an error in future versions" sind genau die die ich im Text oben gemeint habe. Bitte bei den Adaptern meldem
        @apollon77 Ok, 3.2.2 auf GitHub, mach Sinn FÜR ALLE nochmal zu updaten!!
        SBorgS ? 2 Antworten Letzte Antwort
          SBorgS Offline
          SBorgS Offline
          SBorg
          schrieb am zuletzt editiert von SBorg
          @apollon77 Moin Ingo, dann wolle mer mal weider ;)
          War noch die 3.2.1, aber die Installation (Linux) lief problemlos. Dafür habe ich von etlichen Adaptern:
          shelly.0	2021-01-09 09:45:08.668	error	(13149) Cannot find search "folder" in "system"
          wobei er das beim shelly sogar im 5 Sekunden-Raster wirft. Jetzt wohl kein Problem vom JS-Controller (?), bremst aber das System zum testen extrem aus, da sich auch andere Adapter darüber beschweren.
          GitHub Issue dazu...
          LG SBorg ( SBorg auf GitHub)
          apollon77A 2 Antworten Letzte Antwort
          • SBorgS SBorg
            @SBorg Bitte stoppe Controller nochmal. Mach nochmal „iobroker setup first“ und starte nochmal. Ist’s dann weg?
              @apollon77
              das war also sowas wie ein "stay at 127.0.0.1 (localhost), dont be a 255.255.255.255 (broadcast) " Problem.. :-)
              läuft jetzt. Adapter machen Errors... bin am Auswerten...
                @apollon77
                @ilovegym Fehler oder Warnungen?
                  SBorgS Offline
                  SBorgS Offline
                  SBorg
                  @apollon77 sagte in Beta Test js-controller 3.2.x auf GitHub:
                  Leider nein (jetzt mit 3.2.2 probiert). Scheint er auch beim Installieren ordentlich ausgeführt zu haben:
                  (Auszug Ausgabe)...
                  > iobroker.js-controller@3.2.2 install /opt/iobroker/node_modules/iobroker.js-controller
                  > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
                  • SBorgS SBorg
                    (Auszug Ausgabe)...
                    @SBorg ok bitte issue Im GitHub. Checken später. File dB oder redis? Bitte mit rein packen.
                      @Thomas-Braun ok, den kannte ich nicht. Das muss aber eher was bei dir sein. An sich macht der kein ssh. Hast du irgend eine spezielle npmrc oder so? Versuch msl mit kompletter url. Also: „npm i https://github.com/ioBroker/ioBroker.js-controller“
                      @apollon77
                      Ja, lag/liegt an npm@7 (Die kommt mit node15 mit)
                      Zurück auf node14 mit npm@6 läuft die Installation gerade:
                      pi@raspberrypi:/opt/iobroker $ npm install ioBroker/ioBroker.js-controller
                      npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                      Also alles i.O., ich war mit den Versionen zu weit draußen. :-)
                      Wobei ich mit npm@7 Adapter-Updates aus 'latest' machen konnte, offenbar geht das mit git-checkouts nicht mehr in der alten Form. Ich hatte aber soweit ich mich erinnere lange nichts mehr aus git geangelt.
                      [Edit:] Der einzige Adapter, der bei mir aus git kommt zickt jetzt doch rum:
                      npm ERR! Error while executing:
                      npm ERR! /usr/bin/git ls-remote -h -t https://github.com/luca-saggese/samsungtv.git
                      npm ERR!
                      npm ERR! fatal: unable to access 'https://github.com/luca-saggese/samsungtv.git/': gnutls_handshake() failed: The TLS connection was non-properly terminated.
                      npm ERR!
                      npm ERR! exited with error code: 128
                      npm ERR!     /home/iobroker/.npm/_logs/2021-01-09T09_55_27_712Z-debug.log
                        Aktuelle Test Version 3.2.x
                        Veröffentlichungsdatum 09.01.2021
                        Github Link npm install ioBroker/ioBroker.js-controller
                        Hallo mal wieder in die Tester-Runde,
                        mit etwas zeitlicher Verspätung, dafür aber um so besser, starten wir heute den Beta Test des neuen js-controller 3.2 (Releasename "Grace"). Wie auch bei den letzten Versionen starten wir die erste Teststufe direkt von GitHub. Also bitte nur mitmachen wenn Ihr wisst was das heisst :-) Aber auch der Weg zurück ist unten beschrieben.
                        Die unterstützten Node.js Versionen bleiben in diesem Update gleich: 10.x, 12.x und auch 14.x werden offiziell unterstützt. Aufgrund der übergreifenden Adapter-Kompatibilität bleibt die empfohlene Node.js Version für ioBroker aktuell weiterhin auf 12.x. Falls jemand wirklich mit Node.js 15.x experimentieren will, dann bitte AUSSCHLIESSLICH mit npm 6 !! (die npm Leute haben in npm 7 wieder dinge kaputt gemacht. es ist zum heulen)
                        Neben einigen Features haben wir unter der Haube weiter aufgeräumt und sehr viel modernisiert und vereinheitlicht.
                        Auch daran den Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen wurde weiter gearbeitet, was ggf. zu neuen Log-meldungen für bestimmte Fälle führt. Bitte unterstützt hier wieder und legt bei den relevanten Adaptern im GitHub Issues an, damit diese Dinge gefixt werden können.
                        Besonders zu erwähnen ist die Grundlage für das neue Benachrichtigungssystem (kommt dann in einem Admin-Update) und die Reaktivierung von Let's Encrypt zur automatischen Zertifikatsaktualisierung.
                        Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog. Ich hoffe auch diesmal auf Eure tatkräftige Unterstützung, sodass der Latest-Release dann genau so reibungslos verläuft wie bei den letzten Versionen.
                        In Summe sind in diese Version über 560 commits eingeflossen. Dafür bedenke mich diesmal besonders bei @foxriver76, @AlCalzone und natürlich @Bluefox und auch ein paar weiteren Entwicklern für die aktive Mitarbeit an dieser Version!
                        Der js-controller 3.2 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2 ist problemlos möglich. Nur die Node.js Version muss jetzt mindestens 10.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen :-)
                        Installation
                        VOR der Installation
                        Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Die alte Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version installiert werden und sollte alles wieder herstellen.
                        Windows
                        Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden weiss ich gerade nicht wie der aktuelle Prozess ist, da der Windows installer nicht ganz aktuell ist. Bitte hier berichten dann kann ich ergänzen.
                        Linux
                        Für den Beta-Test muss der js-controller direkt per npm installiert werden. Dazu bitte den ioBroker auf dem Server beenden und dann in einer Shell UNBEDINGT in das ioBroker Verzeichnis wechseln (cd /opt/iobroker unter Linux). Dann mittels npm install ioBroker/ioBroker.js-controller den Controller manuell aktualisieren. Bevor ihr loslegt, lest aber bitte erst noch die folgenden Hinweise! Der zweite Post in diesem Thread ist für eine FAQ reserviert. Bitte schaut auch dort gern einmal rein.
                        Achtung: Slave-Systeme zuerst!
                        Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.1 läuft ist es beim Update auf Version 3.2 empfohlen, zuerst die Slave-Systeme zu aktualisieren. Der Master wird als letztes aktualisiert!
                        Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 3.2 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Die Slaves bleiben nach dem Update offline und werden erst wieder funktionieren wenn auch der Master auf die 3.2 aktualisiert wurde!
                        Nötige Adapter-Aktualisierungen
                        Aktuell sind keine Inkompatibilitäten bekannt, damit allerdings Let's encrypt wieder funktioniert benötigt es einige Adapter in "Latest" Versionen von mindestens:
                        • ioBroker.lovelace 1.4.1
                        • ioBroker.simple-api 2.5.2
                        • ioBroker.socketio 3.1.3
                        • ioBroker.telegram 1.7.0
                        • ioBroker.web 3.2.2
                        • ioBroker.admin 4.2.1
                          Bitte checkt aber das die Adapter generell auch in den bisherigen versionen mit dem neuen js-controller tun!
                        Es werden aber, wie oben ausgeführt, einige Adapter ggf Warnungen ins Log schreiben. Falls das Problematisch ist ist aktuell die einzige Option das Loglevel der Instanz auf "Error" zu setzen.
                        Fehler
                        Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                        Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller versuchen.
                        Nach der Installation
                        Nach der Installation den ioBroker wieder starten (z.B. mittels iobroker start).
                        Wenn alles klappt merkt Ihr außer der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
                        Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                        Was hat sich geändert, was besonders ansehen/testen?
                        Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
                        • generell siehe Changelog, speziell auch für Features
                        • Alle normalen Funktionalitäten, vor allem Adapter starten, stoppen, restarten, installieren, upgrade einzel/all, Instanzen hinzufügen, löschen, auf anderen Host schieben (npm Installs und auch GitHub installs)
                        • Prüfen und vergleichen der CPU and RAM Nutzung, speziell für den js.controller Prozess an sich
                        • Einige Adapter werden Warnungen ausgeben wenn State-Werte gesetzt werden VOR dem Anlegen von Objekten. Bitte bei den Adapter-Repos melden
                        Speziell die Entwickler sollten bitte die genannten Deprecations anschauen und beachten
                        Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                        3.2.1 (2021-01-09) Release Grace
                        BREAKING CHANGES
                        • None, Supported are nodejs 10.x, 12.x and 14.x (Node.js 15.x is also working in the automated tests, but formally not supported)
                        Features
                        • (raintonr) Update Let's encrypt implementation; all relevent adapters (web and such) need updates to use it! NEEDS NODE.JS 12.x+! (see DOCS LINK TODO)
                        • (bluefox) Restart adapters that use Let's encrypt after certificates were updated
                        • (bluefox) Provide min/max for convert alias functions
                        • (foxriver76) handling major adapter upgrades more carefully (CLI on upgrade will show if it's a major upgrade and major upgrades will be skipped on upgrade all when executed by admin
                        • (AlCalzone) detect and allow short github URL format when (auto-)installing adapters (iobroker url User/repo#branchorcommit)
                        • (foxriber76) Add notification system (see DOCS LINK TODO)
                        • (foxriver76) enhance setup (and setup first) with redis to all port configuration
                        • (foxriver76) set connectionName for redis connections and simulator support (see DOCS LINK TODO)
                        Optimizations and Fixes
                        • (foxriver76) Detect adapter restart loops and stop restarting after 3 crashes (an adapter is considered "working" when no crash by an exception happens within 10 minutes)
                        • (foxriver76) Fix failed logins if username is uppercase, be reworking user logic and caching
                        • (bluefox) Set for def states the quality: QUALITY_SUBS_INITIAL
                        • (AlCalzone) fix npm uninstall loglevel argument
                        • (foxriver76) delete pids.txt when iobroker was stopped
                        • (bluefox) Add missing attributes by multihost if Redis is used for objects/states, Remove unused settings from iobroker-dist.json, Remove pass and user from connection settings. Use options.auth_pass
                        • (AlCalzone) Package-Manager: log which packages were (already) installed
                        • (foxriver76) replace redis "KEYS" command by "SCAN" to optimize redis access performance
                        • (foxriver76) optimize redis library usage to prevent errors on redis outages
                        • (bluefox) Catch errors by plugins load. At least log will work and could be checked for errors.
                        • (foxriver76) allow migration of instances to already existing host
                        • (foxriver76) also allow <adapter>.<instance-nr> for install/add cli command
                        • (AlCalzone) buffer streams that are piped to stdout to fix weird Windows logging cases
                        • (foxriver76/AlCalzone) Optimize upgrade/downgrade logic for adapters, ask for a downgrade only if lower version is to be installed
                        • (foxriver76) allow redis redis migration when changing host of redis - fix bug where process crashes when controller is running when migrating
                        • (bluefox) Catch errors for subscribe on alias without target
                        • (foxriver76) only perform auto scaling on alias if not null
                        • (foxriver76) if repository request fails also use cached sources on updating repository
                        • (foxriver76) prevent host deletion from same host - otherwise it will remove the system.host states but instances will still be on the removed host, because transfer happens to itself
                        • (foxriver76) use instanceObjects from system.adapter.* object instead from io-package.json
                        • (foxriver76) notify of errors on readFileCertificates to show permission problems etc.
                        • (foxriver76) multihost discovery now logs ignored messages on debug and also logs the senders address
                        • (foxriver76) sync up created objects on instance start and instance creation by using helper function in tools.js, e.g. .loglevel was missing on instance creation
                        • (bluefox) Package-Manager: Filter empty packets out to suppress error message
                        • (foxriver76) rename repository names for new installations and on updates to beta/stable
                        • (foxriver76) rewrite collectDiagInfo to Promises and fix minor issue with it
                        • (foxriver76) only scale aliases if target or source is represented by unit %
                        • (foxriver76) create meta.user on file sync cli, if not existing (see DOCS LINK TODO)
                        • (Apollon77) also create meta.user on setup first if not existing
                        • (foxriver76) fix enumInstances used by CLI commands
                        • (foxriver76) when missing rights to access log dir do not crash hard anymore, instead fallback to default directory
                        • (bluefox) Fix error if type of native data changed in the new version from basic type e.g. 'string' to 'object'.
                        • (AlCalzone) Remove hardcoded references to GitHub master branch because newer repositories use "main"
                        • (Apollon77, foxriver, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
                        Developer relevant DEPRECATIONS/WARNINGS
                        • (foxriver76) we warn if object not exists when setting a state via adapter.setState. Adjust your code that a state value is NOT set before the object is successfully created. If this deep check is NOT wanted for performance reasons the adapter needs to be initialized with strictObjectChecks = false!! (see DOCS LINK TODO)
                        • (foxriver76) readFile should not validate meta object, we now throw on writeFile if id is no valid meta object
                        • (AlCalzone) update Forbidden ID Characters: use Unicode properties to define which characters are allowed instead of blacklisting. For ASCII the allowed characters are the same as before - for other languages mainly character class of Unicode are allowed! (see DOCS LINK TODO)
                        • (foxriver76) Throw on invalid setState objects; was logged as deprecated before
                        • (foxriver76) remove getMessage shim, no adapter uses it anymore; was logged as deprecated before
                        Developer relevant new Features
                        • (foxriver76) use aes-192-cbc as encryption - backward compatible with current encryption, nothing to do for adapter-developers (see DOCS LINK TODO)
                        • (bluefox) Add system view to filter for "folder" objects
                        • (bluefox) add set/clearTimeout and set/clearInterval to adapter methods and check on unload that they were all cleared and clear if needed with logging, so developers are reminded to clean up!
                        • (AlCalzone) Add ...Async version for getChannels - make sure to check before using or use correct js-controller version dependency!
                        • (Apollon77) modularize databases into own npm packages and basically support adding new types of databases; add deprecation infos and logging to "old legacy" files in lib/states and lib/objects to not be used anymore; requires mostly updates in testing (see DOCS LINK TODO)
                        Developer relevant Optimizations and Fixes
                        • (foxriver76) implement maybeCallback and maybeCallbackWithError and use it in adapter.js
                        • (AlCalzone) use fs-extra instead of mkdirp
                        • (AlCalzone) read JSON files using fs-extra's readJSONSync
                        • (AlCalzone) fix callback definitions in adapter.js, We have signatures for (almost) everything in @types/iobroker and we should use them
                        • (AlCalzone) move from Promises to async/await in some places, use a single readyPromise instead of an array
                        • (bluefox) Added "http" and "stream" options for logs
                        • (foxriver76) migrated ci tests to github actions
                        • (foxriver76) resolve adapter main file as tools.js method
                        • (foxriver76) optimize extendObject with def value
                        • (AlCalzone) Handle existing, but undefined properties in validateSetStateObjectArgument
                        • (foxriver76) also escape + char on regex, it's not forbidden
                        • (bluefox) Set default state only for objects of type "state"
                        • (AlCalzone) include folders in the result of getAdapterObjects
                        • general dependency updates
                        • code style optimizations
                        Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
                        Wie Fehler melden?
                        Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
                        Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
                        Wir wünschen allen viel Spaß beim Testen und vielen Dank für Eure Unterstützung!
                        Ingo
                        @apollon77 Issues:
                        https://github.com/Apollon77/ioBroker.alexa2/issues/603
                        https://github.com/Apollon77/ioBroker.alexa2/issues/604
                        https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/210
                        https://github.com/jack-blackson/ioBroker.countdown/issues/41
                        https://github.com/Matten-Matten/ioBroker.enigma2/issues/45
                        https://github.com/iobroker-community-adapters/ioBroker.proxmox/issues/80
                          @apollon77
                          npm ERR!
                          npm ERR!
                          @Thomas-Braun das ist aber kein Adapter von der url Form her. Da fehlt ioBroker. Im Repo Namen aber ist ja wieder irgend ein npm Fehler.
                            so ist es:
                            wird das Paket in einem Adapter verwendet?
                              so ist es:
                              @Homoran @apollon77
                              Ja, im samsung-tizen Adapter (hab ich aus git) wird das wohl herangezogen. Ich schmeiß den aber gerade aus dem System.
                              Und samsung-community auch.
                              Die beiden hab ich aus git drin, alle anderen Adapter kommen aus 'latest'.
                              • SBorgS SBorg
                                @SBorg 3.2.3 auf GitHub, sollte damit weg sein. Es wurde beim upgrade ein Systemobjekt nicht mit aktualisiert. Solltest bei der Installation jetzt eine Zeile sehen das _design/system aktualisiert wurde
                                  SBorgS Offline
                                  SBorgS Offline
                                  SBorg
                                  Schneller als die Feuerwehr...
                                  Danke, funktioniert jetzt und die Zeile " _design/system" wurde auch angezeigt.
                                  Issue kann zu (https://github.com/ioBroker/ioBroker.js-controller/issues/1165)
                                  Bei der Version meldet er aber noch 3.2.2 ;)
                                  • SBorgS SBorg
                                    @SBorg ja versions increase wollte die IDE noch einen klick aber anderes fenster war davor ... hihi ... jetzt auch fixed
                                    • J Jan1
                                      @apollon77
                                      Das Update hat schon mal geklappt und es scheint auch zu laufen. Hatte aber ein paar Errors beim Update. Könnte einer bitte mal drüber sehen und sagen ob das OK ist, oder ob da was wirklich nicht passt?
                                      Log:
                                      jan@Beelink:/opt/iobroker$ npm install ioBroker/ioBroker.js-controller
                                      > iobroker.js-controller@3.2.1 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                      NPM version: 6.14.10
                                      > usb@1.6.3 install /opt/iobroker/node_modules/usb
                                      > prebuild-install --verbose || node-gyp rebuild
                                      prebuild-install info begin Prebuild-install version 5.3.6
                                      prebuild-install info looking for cached prebuild @ /home/iobroker/.npm/_prebuilds/91abd0-usb-v1.6.3-node-v83-linux-x64.tar.gz
                                      prebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v83-linux-x64.tar.gz
                                      prebuild-install http 404 https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v83-linux-x64.tar.gz
                                      prebuild-install WARN install No prebuilt binaries found (target=14.15.4 runtime=node arch=x64 libc= platform=linux)
                                      make: Verzeichnis „/opt/iobroker/node_modules/usb/build“ wird betreten
                                       CC(target) Release/obj.target/libusb/libusb/libusb/core.o
                                       CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
                                       CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
                                       CC(target) Release/obj.target/libusb/libusb/libusb/io.o
                                       CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
                                       CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
                                       CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
                                       CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
                                       CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
                                       CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
                                      ../libusb/libusb/os/linux_udev.c:40:10: fatal error: libudev.h: Datei oder Verzeichnis nicht gefunden
                                      #include <libudev.h>
                                      compilation terminated.
                                      make: *** [libusb.target.mk:150: Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Fehler 1
                                      make: Verzeichnis „/opt/iobroker/node_modules/usb/build“ wird verlassen
                                      gyp ERR! build error
                                      gyp ERR! stack Error: `make` failed with exit code: 2
                                      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                      gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
                                      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
                                      gyp ERR! System Linux 5.9.0-0.bpo.2-amd64
                                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                      gyp ERR! cwd /opt/iobroker/node_modules/usb
                                      gyp ERR! node -v v14.15.4
                                      gyp ERR! node-gyp -v v5.1.0
                                      gyp ERR! not ok
                                      > iobroker.js-controller@3.2.1 install /opt/iobroker/node_modules/iobroker.js-controller
                                      object 0_userdata.0.example_state created
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                      npm WARN typedoc-plugin-markdown@3.1.1 requires a peer of typedoc@>=0.19.0 < 0.20.0 but none is installed. You must install peer dependencies yourself.
                                      npm WARN typedoc-plugin-no-inherit@1.2.0 requires a peer of typedoc@>=0.16.0 but none is installed. You must install peer dependencies yourself.
                                      npm WARN typedoc-plugin-sourcefile-url@1.0.6 requires a peer of typedoc@>=0.16.0 but none is installed. You must install peer dependencies yourself.
                                      npm WARN typedoc-plugin-markdown@3.1.0 requires a peer of typedoc@>=0.19.0 < 0.20.0 but none is installed. You must install peer dependencies yourself.
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.2.1 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.2.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/fsevents):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 (node_modules/usb):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 install: `prebuild-install --verbose || node-gyp rebuild`
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                      + iobroker.js-controller@3.2.1
                                      added 34 packages from 7 contributors, removed 46 packages, updated 12 packages and moved 1 package in 226.615s
                                      80 packages are looking for funding
                                       run `npm fund` for details
                                      @Jan1 Versuch du mal "iobroker fix" ... an sich installieren wir inzwischen libudev mit was bei dir angeblich fehlt
                                        @apollon77 cool ;-)
                                        habe gerade eine flammneue Installation zu testen aufgesetzt, auf der kommt bei
                                        pi@ioBroker-rock64:/opt/iobroker$ npm install ioBroker/ioBroker.js-controller
                                        jede menge EAccess
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/acme-dns-01-cli
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/acme-v2
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bind        ing-abstract/node_modules/ms
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bind        ing-abstract/node_modules/debug
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bind        ing-mock/node_modules/ms
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bind        ing-mock/node_modules/debug
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bind        ings/node_modules/ms
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bind        ings/node_modules/debug
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/pars        er-byte-length
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/pars        er-cctalk
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/pars        er-delimiter
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/pars        er-readline
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/pars        er-ready
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/pars        er-regex
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stre        am/node_modules/ms
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stre        am/node_modules/debug
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/node
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker/adapte        r-core
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-regex
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/aproba
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/base64-js
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bluebird
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/chownr
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/code-point-at
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/console-control-        strings
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/core-util-is
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/deep-extend
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/delegates
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/detect-libc
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dgram
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/expand-template
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/file-uri-to-path
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bindings
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/fs-constants
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/github-from-pack        age
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/has-unicode
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ieee754
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/inherits
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ini
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ip
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/isarray
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lodash
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/async
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mimic-response
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/decompress-respo        nse
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/minimist
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp-classic
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ms
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/debug
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/nan
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/napi-build-utils
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/netmask
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_m        odules/ms
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_m        odules/debug
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/noop-logger
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/number-is-nan
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-fullwidth-cod        e-point
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-assign
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/process-nextick-        args
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/        node_modules/safe-buffer
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/safe-buffer
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dns-packet
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns-discovery
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/semver
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-abi
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_        modules/ms
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_        modules/debug
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-blocking
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/signal-exit
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-concat
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/n        ode_modules/safe-buffer
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-ansi
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string-width
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-json-comme        nts
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/rc
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tunnel-agent
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/util-deprecate
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules/        readable-stream
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/are-we-there-yet
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_        modules/readable-stream
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/which-pm-runs
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wide-align
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/gauge
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/npmlog
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wrappy
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/once
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/end-of-stream
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/pump
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-get
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/prebuild-install
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/camelcase
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/path-exists
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/require-main        -filename
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/which-module
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/wrap-ansi
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/cliui
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/y18n
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs-parser
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/le-acme-core/node_modules/rsa-compat
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/mkdirp
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/p-try
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/p-limit
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/p-locate
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/locate-path
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/find-up
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pyconf
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/le-store-certbot
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/rsa-compat
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/utile/node_modules/mkdirp
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/vinyl-sourcemaps-apply/node_modules/source-map
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.objects-redis
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/greenlock
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/node-forge
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@root
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker
                                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/tar/node_modules
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (c        urrent: {"os":"linux","arch":"arm64"})
                                        npm ERR! code EACCES
                                        npm ERR! syscall access
                                        npm ERR! path /opt/iobroker/node_modules/acme-dns-01-cli
                                        npm ERR! errno -13
                                        npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/acme-dns-01-cli'
                                        npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/acme-dns-01-cli'] {
                                        npm ERR!   errno: -13,
                                        npm ERR!   code: 'EACCES',
                                        npm ERR!   syscall: 'access',
                                        npm ERR!   path: '/opt/iobroker/node_modules/acme-dns-01-cli'
                                        npm ERR! }
                                        npm ERR!
                                        npm ERR! The operation was rejected by your operating system.
                                        npm ERR! It is likely you do not have the permissions to access this file as the current user
                                        npm ERR!
                                        npm ERR! If you believe this might be a permissions issue, please double-check the
                                        npm ERR! permissions of the file and its containing directories, or try running
                                        npm ERR! the command again as root/Administrator.
                                        npm ERR!     /home/pi/.npm/_logs/2021-01-09T10_49_28_240Z-debug.log
                                          @apollon77 cool ;-)
                                          jede menge EAccess
                                          npm ERR! errno -13
                                          npm ERR! }
                                          npm ERR!
                                          npm ERR!
                                          @Homoran Hast Du dich NACH der Installation und VOR dem nächsten kommando auch ausgeloggtt und frisch eingeloggt wie es der Installer verlangt? ;-) Ich tippe nein
