  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер ModBus
    1.0k
Драйвер ModBus
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
174 Beiträge 25 Kommentatoren 70.9k Aufrufe 2 Beobachtet
  • V Offline
    V Offline
    VictorS
    #86
    @Bluefox:
    Можешь создать в папке node_modules/iobroker.modbus файл port.js:
    А у тебя? `
    А у меня вот что:
    ! root@spy-sh:/opt/iobroker/node_modules/iobroker.modbus# node ./port.js
    ! (node) v8::ObjectTemplate::Set() with non-primitive values is deprecated
    ! (node) and will stop working in the next major release.
    ! ==== JS stack trace =========================================
    ! Security context: 0x310f666cfb51 <js object="">#0#
    ! 1: .node [module.js:583] [pc=0x1fb2eb572ec4] (this=0x2c52d4005619 <an object/with/map/0x285de601a889="">#1#,module=0x92652d61fc1 <a module/with/map/0x285de601b7a9="">#2#,filename=0x92652d5f239 <string[96]: opt/iobroker/node_modules/iobroker.modbus/serialport/build/release/serialport.node="">)
    ! 2: load [module.js:473] [pc=0x1fb2eb53df12] (this=0x92652d61fc1</string[96]:></a> <a module/with/map/0x285de601b7a9="">#2#,filename=0x92652d5f239 <string[96]: opt/iobroker/node_modules/iobroker.modbus/serialport/build/release/serialport.node="">)
    ! 3: tryModuleLoad(aka tryModuleLoad) [module.js:432] [pc=0x1fb2eb53da3d] (this=0x310f66604381 <undefined>,module=0x92652d61fc1</undefined></string[96]:></a> <a module/with/map/0x285de601b7a9="">#2#,filename=0x92652d5f239 <string[96]: opt/iobroker/node_modules/iobroker.modbus/serialport/build/release/serialport.node="">)
    ! 4: _load [module.js:424] [pc=0x1fb2eb535222] (this=0x2c52d4005741 <js function/module/(sharedfunctioninfo/0x12e371b2be99)="">#3#,request=0x92652d5e1e9 <string[96]: opt/iobroker/node_modules/iobroker.modbus/serialport/build/release/serialport.node="">,parent=0x92652d4ded1</string[96]:></js></string[96]:></a> <a module/with/map/0x285de601b7a9="">#4#,isMain=0x310f66604271 <false>)
    ! 5: require [module.js:483] [pc=0x1fb2eb546d93] (this=0x92652d4ded1</false></a> <a module/with/map/0x285de601b7a9="">#4#,path=0x92652d5e1e9 <string[96]: opt/iobroker/node_modules/iobroker.modbus/serialport/build/release/serialport.node="">)
    ! 6: require(aka require) [internal/module.js:20] [pc=0x1fb2eb546ac6] (this=0x310f66604381 <undefined>,path=0x92652d5e1e9 <string[96]: opt/iobroker/node_modules/iobroker.modbus/serialport/build/release/serialport.node="">)
    ! 7: bindings [/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/node_modules/bindings/bindings.js:76] [pc=0x1fb2eb56e3f6] (this=0x310f666e60e1 <js global/object="">#5#,opts=0x12e371ba7c61 <string[15]: serialport.node="">)
    ! 8: /* anonymous / [/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/lib/bindings.js:3] [pc=0x1fb2eb56cf0e] (this=0x92652d45ef9 <an object/with/map/0xc8c151075e9="">#6#,exports=0x92652d45ef9 <an object/with/map/0xc8c151075e9="">#6#,require=0x92652d47551 <js function/require/(sharedfunctioninfo/0x12e371b5d751)="">#7#,module=0x92652d45ea9</js></an></an></string[15]:></js></string[96]:></undefined></string[96]:></a> <a module/with/map/0x285de601b7a9="">#8#,__filename=0x92652d43d31 <string[82]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib/bindings.js="">,__dirname=0x92652d474e9 <string[70]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib="">)
    ! 9: _compile [module.js:556] [pc=0x1fb2eb546270] (this=0x92652d45ea9</string[70]:></string[82]:></a> <a module/with/map/0x285de601b7a9="">#8#,content=0x92652d46b01 <string[784]: 'use/strict';\n\nvar/bindings="require('bindings')('serialport.node');\nvar" listunix="require('./list-unix');\n\nvar" linux="process.platform" !="=" 'win32'/&&/process.platform/'darwin';\n\nfunction/listlinux(callback)/{\n/callback="callback" ||/function(err)/if/(err)/{/this.emit('error',/err)/}\n/}.bind(this);\n/return/listunix(callback);\n};\n\nvar/platformoptions="{};\nif" (process.platform/'win32')/vmin:/1,\n/vtime:/0\n/};\n}\n\nmodule.exports="{\n" close:/bindings.close,\n/drain:/bindings.drain,\n/flush:/bindings.flush,\n/list:/?/listlinux/:/bindings.list,\n/open:/bindings.open,\n/serialportpoller:/bindings.serialportpoller,\n/set:/bindings.set,\n/update:/bindings.update,\n/write:/bindings.write,\n/platformoptions:/platformoptions\n};\n="">,filename=0x92652d43d31 <string[82]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib/bindings.js="">)
    ! 10: .js [module.js:565] [pc=0x1fb2eb53f4eb] (this=0x2c52d4005619 <an object/with/map/0x285de601a889="">#1#,module=0x92652d45ea9</an></string[82]:></string[784]:></a> <a module/with/map/0x285de601b7a9="">#8#,filename=0x92652d43d31 <string[82]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib/bindings.js="">)
    ! 11: load [module.js:473] [pc=0x1fb2eb53df12] (this=0x92652d45ea9</string[82]:></a> <a module/with/map/0x285de601b7a9="">#8#,filename=0x92652d43d31 <string[82]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib/bindings.js="">)
    ! 12: tryModuleLoad(aka tryModuleLoad) [module.js:432] [pc=0x1fb2eb53da3d] (this=0x310f66604381 <undefined>,module=0x92652d45ea9</undefined></string[82]:></a> <a module/with/map/0x285de601b7a9="">#8#,filename=0x92652d43d31 <string[82]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib/bindings.js="">)
    ! 13: _load [module.js:424] [pc=0x1fb2eb535222] (this=0x2c52d4005741 <js function/module/(sharedfunctioninfo/0x12e371b2be99)="">#3#,request=0x12e371b61659 <string[10]: ./bindings="">,parent=0x2c52d40056b9</string[10]:></js></string[82]:></a> <a module/with/map/0x285de601b7a9="">#9#,isMain=0x310f66604271 <false>)
    ! 14: require [module.js:483] [pc=0x1fb2eb546d93] (this=0x2c52d40056b9</false></a> <a module/with/map/0x285de601b7a9="">#9#,path=0x12e371b61659 <string[10]: ./bindings="">)
    ! 15: require(aka require) [internal/module.js:20] [pc=0x1fb2eb546ac6] (this=0x310f66604381 <undefined>,path=0x12e371b61659 <string[10]: ./bindings="">)
    ! 16: /
    anonymous / [/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/lib/serialport.js:16] [pc=0x1fb2eb54b32e] (this=0x2c52d40059f1 <an object/with/map/0xc8c151075e9="">#10#,exports=0x2c52d40059f1 <an object/with/map/0xc8c151075e9="">#10#,require=0x2c52d40057c9 <js function/require/(sharedfunctioninfo/0x12e371b5d751)="">#11#,module=0x2c52d40056b9</js></an></an></string[10]:></undefined></string[10]:></a> <a module/with/map/0x285de601b7a9="">#9#,__filename=0x2c52d4005981 <string[84]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib/serialport.js="">,__dirname=0x2c52d4005959 <string[70]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib="">)
    ! 17: _compile [module.js:556] [pc=0x1fb2eb546270] (this=0x2c52d40056b9</string[70]:></string[84]:></a> <a module/with/map/0x285de601b7a9="">#9#,content=0x2c52d4008f99 <very long/string[13557]="">#12#,filename=0x2c52d4005981 <string[84]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib/serialport.js="">)
    ! 18: .js [module.js:565] [pc=0x1fb2eb53f4eb] (this=0x2c52d4005619 <an object/with/map/0x285de601a889="">#1#,module=0x2c52d40056b9</an></string[84]:></very></a> <a module/with/map/0x285de601b7a9="">#9#,filename=0x2c52d4005981 <string[84]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib/serialport.js="">)
    ! 19: load [module.js:473] [pc=0x1fb2eb53df12] (this=0x2c52d40056b9</string[84]:></a> <a module/with/map/0x285de601b7a9="">#9#,filename=0x2c52d4005981 <string[84]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib/serialport.js="">)
    ! 20: tryModuleLoad(aka tryModuleLoad) [module.js:432] [pc=0x1fb2eb53da3d] (this=0x310f66604381 <undefined>,module=0x2c52d40056b9</undefined></string[84]:></a> <a module/with/map/0x285de601b7a9="">#9#,filename=0x2c52d4005981 <string[84]: opt/iobroker/node_modules/iobroker.modbus/serialport/lib/serialport.js="">)
    ! 21: _load [module.js:424] [pc=0x1fb2eb535222] (this=0x2c52d4005741 <js function/module/(sharedfunctioninfo/0x12e371b2be99)="">#3#,request=0x12e371b5d0d1 <string[10]: serialport="">,parent=0x2c52d400c4c9</string[10]:></js></string[84]:></a> <a module/with/map/0x285de601b7a9="">#13#,isMain=0x310f66604271 <false>)
    ! 22: require [module.js:483] [pc=0x1fb2eb546d93] (this=0x2c52d400c4c9</false></a> <a module/with/map/0x285de601b7a9="">#13#,path=0x12e371b5d0d1 <string[10]: serialport="">)
    ! 23: require(aka require) [internal/module.js:20] [pc=0x1fb2eb546ac6] (this=0x310f66604381 <undefined>,path=0x12e371b5d0d1 <string[10]: serialport="">)
    ! 24: /
    anonymous / [/opt/iobroker/node_modules/iobroker.modbus/port.js:1] [pc=0x1fb2eb54653f] (this=0x2c52d400c699 <an object/with/map/0xc8c151075e9="">#14#,exports=0x2c52d400c699 <an object/with/map/0xc8c151075e9="">#14#,require=0x2c52d400c591 <js function/require/(sharedfunctioninfo/0x12e371b5d751)="">#15#,module=0x2c52d400c4c9</js></an></an></string[10]:></undefined></string[10]:></a> <a module/with/map/0x285de601b7a9="">#13#,__filename=0x2c52d400c649 <string[50]: opt/iobroker/node_modules/iobroker.modbus/port.js="">,__dirname=0x2c52d400c621 <string[42]: opt/iobroker/node_modules/iobroker.modbus="">)
    ! 25: _compile [module.js:556] [pc=0x1fb2eb546270] (this=0x2c52d400c4c9</string[42]:></string[50]:></a> <a module/with/map/0x285de601b7a9="">#13#,content=0x2c52d400c7e9 <string[151]: var/serialport="require('serialport');\nserialport.list(function" (err,/ports)/{\n/console.log(json.stringify(ports,/null,/2));\n/process.exit();\n});\n="">,filename=0x2c52d400c649 <string[50]: opt/iobroker/node_modules/iobroker.modbus/port.js="">)
    ! 26: .js [module.js:565] [pc=0x1fb2eb53f4eb] (this=0x2c52d4005619 <an object/with/map/0x285de601a889="">#1#,module=0x2c52d400c4c9</an></string[50]:></string[151]:></a> <a module/with/map/0x285de601b7a9="">#13#,filename=0x2c52d400c649 <string[50]: opt/iobroker/node_modules/iobroker.modbus/port.js="">)
    ! 27: load [module.js:473] [pc=0x1fb2eb53df12] (this=0x2c52d400c4c9</string[50]:></a> <a module/with/map/0x285de601b7a9="">#13#,filename=0x2c52d400c649 <string[50]: opt/iobroker/node_modules/iobroker.modbus/port.js="">)
    ! 28: tryModuleLoad(aka tryModuleLoad) [module.js:432] [pc=0x1fb2eb53da3d] (this=0x310f66604381 <undefined>,module=0x2c52d400c4c9</undefined></string[50]:></a> <a module/with/map/0x285de601b7a9="">#13#,filename=0x2c52d400c649 <string[50]: opt/iobroker/node_modules/iobroker.modbus/port.js="">)
    ! 29: _load [module.js:424] [pc=0x1fb2eb535222] (this=0x2c52d4005741 <js function/module/(sharedfunctioninfo/0x12e371b2be99)="">#3#,request=0x12e371b53209 <string[50]: opt/iobroker/node_modules/iobroker.modbus/port.js="">,parent=0x310f66604201 <null>,isMain=0x310f666043c1 <true>)
    ! 30: /
    anonymous /(aka / anonymous /) [module.js:590] [pc=0x1fb2eb534cea] (this=0x310f66604381 <undefined>)
    ! 31: run(aka run) [bootstrap_node.js:394] [pc=0x1fb2eb534b68] (this=0x310f66604381 <undefined>,entryFunction=0x12e371b51381 <js function/module.runmain/(sharedfunctioninfo/0x12e371b2cc19)="">#16#)
    ! 32: startup(aka startup) [bootstrap_node.js:149] [pc=0x1fb2eb4448f2] (this=0x310f66604381 <undefined>)
    ! 33: /
    anonymous /(aka / anonymous /) [bootstrap_node.js:509] [pc=0x1fb2eb44274e] (this=0x310f66604201 <null>,process=0x310f666e1949</null></undefined></js></undefined></undefined></true></null></string[50]:></js></string[50]:></a> <a process/with/map/0xc8c15111619="">#17#)
    ! ==== C stack trace ===============================
    ! 1: v8::Template::Set(v8::Localv8::name, v8::Localv8::data, v8::PropertyAttribute)
    ! 2: SerialportPoller::Init(v8::Localv8::object)
    ! 3: init
    ! 4: node::DLOpen(v8::FunctionCallbackInfo v8::valueconst&)
    ! 5: v8::internal::FunctionCallbackArguments::Call(void (
    )(v8::FunctionCallbackInfo v8::valueconst&))
    ! 6: 0x9ee352
    ! 7: 0x9eeb7e
    ! 8: 0x1fb2eb4092a7
    ! 1: .node [module.js:583] [pc=0x1fb2eb572ec4] (this=0x2c52d4005619 <an object/with/map/0x285de601a889="">#1#,module=0x92652d61fc1</an></js></v8::value></v8::value></v8::object></v8::data></v8::name></a> <a module/with/map/0x285de601b7a9="">#2#,filename=0x92652d5f239 <string[96]: opt/iobroker/node_modules/iobroker.modbus/serialport/build/release/serialport.node="">)
    ! 16: /
    ! 24: /
    ! 30: /
    ! 33: /
    ! 3: init
    ! 6: 0x9ee352
    ! 7: 0x9eeb7e
    ! 8: 0x1fb2eb4092a7
    ! undefined</v8::value></v8::value></v8::object></v8::data></v8::name></a></an></js>
      MSapogov
      #87
      @Bluefox:
      var serialport = require('serialport');
      serialport.list(function (err, ports) {
      	console.log(JSON.stringify(ports, null, 2));
      	process.exit();
      Запустить его из консоли `
      У меня вывод такой на ESXi
      ! root@Bee-IoT:/opt/iobroker/node_modules/iobroker.modbus# node port.js:
      module.js:327
          throw err;
      >! Error: Cannot find module 'serialport'
          at Function.Module._resolveFilename (module.js:325:15)
          at Function.Module._load (module.js:276:25)
          at Module.require (module.js:353:17)
          at require (internal/module.js:12:17)
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.modbus/port.js:1:80)
          at Module._compile (module.js:409:26)
          at Object.Module._extensions..js (module.js:416:10)
          at Module.load (module.js:343:32)
          at Function.Module._load (module.js:300:12)
          at Function.Module.runMain (module.js:441:10)</anonymous>
      root@Bee-IoT:/opt/iobroker/node_modules/iobroker.modbus# lsusb -````
      Bus 002 Device 006: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
      Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
      Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
      Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
      root@Bee-IoT:/opt/iobroker/node_modules/iobroker.modbus# node -v
      ! v4.5.0
      ! PS: полазил по папкам внутри драйвера…. запустил
      ! root@Bee-IoT:/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/bin# ./serialport-list.js
      /dev/ttyS0
      /dev/ttyS1
      /dev/ttyS10
      /dev/ttyS11
      /dev/ttyS12
      /dev/ttyS13
      /dev/ttyS14
      /dev/ttyS15
      /dev/ttyS16
      /dev/ttyS17
      /dev/ttyS18
      /dev/ttyS19
      /dev/ttyS2
      /dev/ttyS20
      /dev/ttyS21
      /dev/ttyS22
      /dev/ttyS23
      /dev/ttyS24
      /dev/ttyS25
      /dev/ttyS26
      /dev/ttyS27
      /dev/ttyS28
      /dev/ttyS29
      /dev/ttyS3
      /dev/ttyS30
      /dev/ttyS31
      /dev/ttyS4
      /dev/ttyS5
      /dev/ttyS6
      /dev/ttyS7
      /dev/ttyS8
      /dev/ttyS9
      /dev/ttyUSB0    usb-1a86_USB2.0-Serial-if00-port0       1a86
      • V Offline
        V Offline
        VictorS
        #88
        @Bluefox:
        А у тебя? `
        Насколько я понимаю Вы имеете отношение к разработке данного драйвера? Если так - можно ли дать возможность прямого ввода имени порта, не из списка? Может это поможет?
        Есть подозрение что либа которая работает с serial devices (serialport) обламывается при попытке получить какие-то конфигурационные данные с порта, драйвер которого работает не на уровне kernel.
        Или подскажите где настройки на порт лежат, может туда можно в ручном режиме внести информацию о нестандартном порте.
        • BluefoxB Offline
          BluefoxB Offline
          #89
          @VictorS:
          @Bluefox:
          А у тебя? `
          Или подскажите где настройки на порт лежат, может туда можно в ручном режиме внести информацию о нестандартном порте. `
          Попробуй так
          • V Offline
            V Offline
            VictorS
            #90
            @Bluefox:
            @VictorS:
            @Bluefox:
            А у тебя? `
            Или подскажите где настройки на порт лежат, может туда можно в ручном режиме внести информацию о нестандартном порте. Попробуй так
            Попробовал. Порт внес в ручном режимы, но в ответ в логах:
            ! host-spy-sh 2016-11-01 14:49:54.569 error instance system.adapter.modbus.0 terminated with code 0 (OK)
            ! modbus-0 2016-11-01 14:49:54.556 info terminating
            ! TypeError: 2016-11-01 14:49:54.530 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2016-11-01 14:49:54.530 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2016-11-01 14:49:54.530 error at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16)
            ! TypeError: 2016-11-01 14:49:54.530 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
            ! TypeError: 2016-11-01 14:49:54.530 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2016-11-01 14:49:54.530 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2016-11-01 14:49:54.530 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
            ! TypeError: 2016-11-01 14:49:54.530 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
            ! TypeError: 2016-11-01 14:49:54.530 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2016-11-01 14:49:54.530 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
            ! TypeError: 2016-11-01 14:49:54.530 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
            ! TypeError: 2016-11-01 14:49:54.530 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:707:35)
            ! TypeError: 2016-11-01 14:49:54.530 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:773:21
            ! TypeError: 2016-11-01 14:49:54.530 error at /opt/iobroker/node_modules/iobroker.modbus/main.js:1332:13
            ! TypeError: 2016-11-01 14:49:54.530 error at clear (/opt/iobroker/node_modules/iobroker.modbus/main.js:1328:22)
            ! TypeError: 2016-11-01 14:49:54.530 error at Object.start (/opt/iobroker/node_modules/iobroker.modbus/main.js:1738:25)
            ! TypeError: 2016-11-01 14:49:54.530 error Cannot read property 'on' of null
            ! uncaught 2016-11-01 14:49:54.529 error exception: Cannot read property 'on' of null
            ! modbus-0 2016-11-01 14:49:54.521 error Cannot open port "/dev/ttyvirt1" [9600]: TypeError: Cannot read property 'complete' of undefined
            ! modbus-0 2016-11-01 14:49:54.171 info starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.modbus
            Возможно проблема как раз кроется в этой ошибке: Cannot read property 'complete' of undefined
            • V Offline
              V Offline
              VictorS
              #91
              Добрый день,
              отчетик по проблеме с виртуальным драйвером serial порта и modbus драйвером к IOB.
              Проблема описана вот тут: http://stackoverflow.com/questions/3232 … up-in-list
              И кроется в каком-то внутреннем нежелании либы serialport работать с портами сделанными socat и не только.
              Поскольку времени (да и особого опыта в JS) ковырять чужие либы нету, был найден workarround, а именно - устанавливаем на сервере IOB шлюз Modbus RTU <-> Modbus RTU over TCP. http://mbus.sourceforge.net/index.html
              В результате шлюз общается в serial созданным socat, а драйвер IOB modbus видит данные с шлюза по протоколу TCP или RTU over TCP (работают оба варианта).
              Может кому-то пригодится
              • BluefoxB Offline
                BluefoxB Offline
                #92
                @VictorS:
                Добрый день,
                Может кому-то пригодится `
                Отличная новость. Мне надо внести это решение в readme.md
                  MSapogov
                  #93
                  @VictorS:
                  Добрый день,
                  Скомпилил…
                  Запускаю - mbusd -p /dev/ttyUSB0 -s 9600 -m 8N1 -P 502
                  И теперь работает!!! Даже после разрыва RS-485 и восстановлении связи опрос продолжается.
                  Даже после перезапуска mbusd опрос взобновляется через Reconnect time в настройках.
                  Спасибо!
                  PS: Правильно ли я понял, что если я буду добавлять еще устройства на эту линию RS-485 в паралель, с другими ID, то мне необходимо добавлять еще драйвера modbus.1, modbus.2 и.т.д. Со своими настройками для каждго устройства, интервал опроса, Reconnect time ...
                  А параметрах соединения TCP, Адресс, порт, и тип Master остаются неизменными?
                  • V Offline
                    V Offline
                    VictorS
                    #94
                    @MSapogov:
                    PS: Правильно ли я понял, что если я буду добавлять еще устройства на эту линию RS-485 в паралель, с другими ID, то мне необходимо добавлять еще драйвера modbus.1, modbus.2 и.т.д. Со своими настройками для каждго устройства, интервал опроса, Reconnect time …
                    А параметрах соединения TCP, Адресс, порт, и тип Master остаются неизменными? `
                    Да, так и есть. Для каждого Modbus ID свой экземпляр драйвера. Сам mbusd поддерживает несколько одновременных TCP-соединений.
                    • H Offline
                      Haus
                      #95
                      Ошибка при обновлении
                      iobroker 2016-11-09 07:18:34.694 info exit 0
                      iobroker 2016-11-09 07:18:34.667 info Adapter "modbus" updated
                      iobroker 2016-11-09 07:18:34.512 info upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/img/plc_back.png img/plc_back.png image/png
                      iobroker 2016-11-09 07:18:34.433 info upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index.html index.html text/html
                      iobroker 2016-11-09 07:18:34.344 info upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.css lib/css/jsgrid-theme.css text/css
                      iobroker 2016-11-09 07:18:34.254 info upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.min.css lib/css/jsgrid-theme.min.css text/css
                      iobroker 2016-11-09 07:18:34.179 info upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.css lib/css/jsgrid.css text/css
                      iobroker 2016-11-09 07:18:34.114 info upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.min.css lib/css/jsgrid.min.css text/css
                      iobroker 2016-11-09 07:18:34.039 info upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-de.js lib/js/grid.locale-de.js application/javascript
                      iobroker 2016-11-09 07:18:33.971 info upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-ru.js lib/js/grid.locale-ru.js application/javascript
                      iobroker 2016-11-09 07:18:33.888 info upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.js lib/js/jsgrid.js application/javascript
                      iobroker 2016-11-09 07:18:33.754 info upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.min.js lib/js/jsgrid.min.js application/javascript
                      host.Server-PC 2016-11-09 07:18:33.737 info object change system.adapter.modbus.0
                      iobroker 2016-11-09 07:18:33.721 info Update "system.adapter.modbus.0"
                      iobroker 2016-11-09 07:18:33.626 info upload [10] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                      iobroker 2016-11-09 07:18:33.589 info got /opt/iobroker/node_modules/iobroker.modbus/admin
                      iobroker 2016-11-09 07:18:33.268 info npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/debug,npm WARN unmet dependency which is version 2.3.0
                      iobroker 2016-11-09 07:18:33.262 info WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack requires debug@'~2.2.0' but will load
                      iobroker 2016-11-09 07:18:33.250 info npm
                      iobroker 2016-11-09 07:18:26.658 info npm install --production --prefix "/opt/iobroker/node_modules/iobroker.modbus" (System call)
                      iobroker 2016-11-09 07:18:26.072 info npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/debug,npm WARN unmet dependency which is version 2.3.0
                      iobroker 2016-11-09 07:18:26.065 info WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack requires debug@'~2.2.0' but will load
                      iobroker 2016-11-09 07:18:26.058 info npm
                      iobroker 2016-11-09 07:17:18.870 info npm install iobroker.modbus --production --prefix "/opt/iobroker" (System call)
                      iobroker 2016-11-09 07:17:16.912 info upgrade modbus
                      js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
                      admin: 3.6.0
                      javascript: 4.1.10
                      web: 2.4.1 vis: 1.1.10
                      cloud: 2.6.2
                      Server: DELL FX170 / linux: Debian 9.5 Stretch
                      Adapter: MegaD-2561, Mega-ES…
                      • BluefoxB Offline
                        BluefoxB Offline
                        #96
                        @Haus:
                        ! iobroker 2016-11-09 07:18:34.694 info exit 0 iobroker 2016-11-09 07:18:34.667 info Adapter "modbus" updated iobroker 2016-11-09 07:18:34.512 info upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/img/plc_back.png img/plc_back.png image/png iobroker 2016-11-09 07:18:34.433 info upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index.html index.html text/html iobroker 2016-11-09 07:18:34.344 info upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.css lib/css/jsgrid-theme.css text/css iobroker 2016-11-09 07:18:34.254 info upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.min.css lib/css/jsgrid-theme.min.css text/css iobroker 2016-11-09 07:18:34.179 info upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.css lib/css/jsgrid.css text/css iobroker 2016-11-09 07:18:34.114 info upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.min.css lib/css/jsgrid.min.css text/css iobroker 2016-11-09 07:18:34.039 info upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-de.js lib/js/grid.locale-de.js application/javascript iobroker 2016-11-09 07:18:33.971 info upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-ru.js lib/js/grid.locale-ru.js application/javascript iobroker 2016-11-09 07:18:33.888 info upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.js lib/js/jsgrid.js application/javascript iobroker 2016-11-09 07:18:33.754 info upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.min.js lib/js/jsgrid.min.js application/javascript host.Server-PC 2016-11-09 07:18:33.737 info object change system.adapter.modbus.0 iobroker 2016-11-09 07:18:33.721 info Update "system.adapter.modbus.0" iobroker 2016-11-09 07:18:33.626 info upload [10] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png iobroker 2016-11-09 07:18:33.589 info got /opt/iobroker/node_modules/iobroker.modbus/admin iobroker 2016-11-09 07:18:33.268 info npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/debug,npm WARN unmet dependency which is version 2.3.0 iobroker 2016-11-09 07:18:33.262 info WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack requires debug@'~2.2.0' but will load iobroker 2016-11-09 07:18:33.250 info npm iobroker 2016-11-09 07:18:26.658 info npm install --production --prefix "/opt/iobroker/node_modules/iobroker.modbus" (System call) iobroker 2016-11-09 07:18:26.072 info npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/debug,npm WARN unmet dependency which is version 2.3.0 iobroker 2016-11-09 07:18:26.065 info WARN unmet dependency /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack requires debug@'~2.2.0' but will load iobroker 2016-11-09 07:18:26.058 info npm iobroker 2016-11-09 07:17:18.870 info npm install iobroker.modbus --production --prefix "/opt/iobroker" (System call) iobroker 2016-11-09 07:17:16.912 info upgrade modbus `
                        Игнорировать.
                        • L Offline
                          leshyi
                          #97
                          Коллеги, не могу разобраться…
                          Оборудование:
                          Raspberry pi2
                          iobroker.admin 1.6.6
                          js-controller 0.13.2
                          iobroker.modbus 0.4.7
                          ОВЕН ПЛК150
                          Настройки:
                          ПЛК150: Modbus slave id 1
                          iobroker.modbus: master
                          Переменные все float начиная с первого адреса.
                          Проблема:
                          В ПЛК первая переменная REAL: 14655.73
                          iobroker первая переменная (Float (Big Endian)) 14600.24
                          C остальными такая же беда…
                          Читаю другими средствами, все совпадает. Чистый вывод iobroker.modbus нигде не нашел как увидеть, даже в debug. String (Zero end) выводит какую-то ерунду...
                          Скриншот:
                          ! ![](</s><URL url=)<link_text text="https://4.downloader.disk.yandex.ru/dis ... 9127195a6b">https://4.downloader.disk.yandex.ru/disk/c3ca535dfa58336381d0937fb6660e9eeb8178b05bc74b0fa32fcb895ddf2ccc/58470c13/XGn0l5evRjfE4mkLQiECFfCGje_dBUTHUzY2X_mHX_c00lPD1EEz3Bb4XSc3R94PJJjsFCrrZnGZGInNRpcWtQ%3D%3D?uid=0&filename=2016-12-06_18-04-26.png&disposition=inline&hash=&limit=0&content_type=image%2Fpng&fsize=180743&hid=73c5d9980ea0f4cee1db84f47ddeb706&media_type=image&tknv=v2&etag=d46c1b9fa0aaa38c6ad36b9127195a6b</link_text>" />
                          • BluefoxB Offline
                            BluefoxB Offline
                            #98
                            @leshyi:
                            Оборудование:
                            Raspberry pi2
                            ОВЕН ПЛК150
                            Настройки:
                            Проблема:
                            Скриншот:
                            ! ![](</s><URL url=)<link_text text="https://4.downloader.disk.yandex.ru/dis ... 9127195a6b">https://4.downloader.disk.yandex.ru/disk/c3ca535dfa58336381d0937fb6660e9eeb8178b05bc74b0fa32fcb895ddf2ccc/58470c13/XGn0l5evRjfE4mkLQiECFfCGje_dBUTHUzY2X_mHX_c00lPD1EEz3Bb4XSc3R94PJJjsFCrrZnGZGInNRpcWtQ%3D%3D?uid=0&filename=2016-12-06_18-04-26.png&disposition=inline&hash=&limit=0&content_type=image%2Fpng&fsize=180743&hid=73c5d9980ea0f4cee1db84f47ddeb706&media_type=image&tknv=v2&etag=d46c1b9fa0aaa38c6ad36b9127195a6b</link_text>" /> ` А адреса какие? С нуля или с 1 начинаются?
                            • L Offline
                              leshyi
                              #99
                              с 1…
                              В ПЛК адреса вообще не ставятся... там по порядку...
                              Есть скрипт, написанный на ruby, читает идеально. Там адреса с 1.
                              Вообще, если в iobroker.modbus ставить первый адрес 0 - ругается.
                              • BluefoxB Offline
                                BluefoxB Offline
                                #100
                                @leshyi:
                                с 1…
                                Вообще, если в iobroker.modbus ставить первый адрес 0 - ругается. `
                                А у тебя какие настройки адресов? Alias или нет?
                                • L Offline
                                  leshyi
                                  #101
                                  нет, не alias…
                                  При alias адреса считаются с 40002... ситуация та же...
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    #102
                                    @leshyi:
                                    нет, не alias…
                                    При alias адреса считаются с 40002... ситуация та же... `
                                    Вот этом и проблема. Alias начинаются с 1.
                                    Покажи настройки обоих устройств.
                                    И что, ни по адресу 2 или 3 тоже ничего нет?
                                    Что за адресация такая у овена? Не алиас, но с единицы.
                                    • L Offline
                                      leshyi
                                      #103
                                      Если бы…
                                      Перед тем как писать, перепробовал все... и с alias, и без.. и с 0, и с 1, и с 2, и с 40001, и с 40000, и с 40002
                                      Более менее близкий результат: с 1 без alias и с 40002 с alias... При этом результаты в обоих случаях одинаковые в точности, но не соответствуют ПЛК... сдвиг не помогает...
                                      В ПЛК же настроек адресов Modbus вообще нет. Это скорее не ОВЕН, а Codesys 2.3... Просто добавляем модуль Modbus (slave), указываем адрес устройства (в данном случае 1), ставим порт (502).
                                      Дальше добавляем переменные. в том порядке как добавили, они и встают начиная с 1 адреса и занимают соответствующий размер.
                                      Самое главное, библиотека Ruby Modbus выдавала четкий результат в соответствии со спецификацией Modbus, и все работало...
                                      Поищу код на ruby...
                                      Еще вопрос: реально увидеть изначальный ответ в Modbus в iobroker?
                                      • BluefoxB Offline
                                        BluefoxB Offline
                                        #104
                                        @leshyi:
                                        Еще вопрос: реально увидеть изначальный ответ в Modbus в iobroker? `
                                        А debug включал?
                                        http://www.iobroker.net/docu/?page_id=2991&lang=ru (в конце)
                                        • L Offline
                                          leshyi
                                          #105
                                          В итоге заработало вот так…. метод тыка...
                                          Вопрос был в типах переменных...
                                          ! ![](</s><URL url=)<link_text text="https://3.downloader.disk.yandex.ru/dis ... d4619486ef">https://3.downloader.disk.yandex.ru/disk/33316f878bf0c0f92f0a79ebb4b92b0bfef7ce6eb4d047cd0991c99e3786b303/5848a99b/XGn0l5evRjfE4mkLQiECFY8STJ-p9RKQv9kfKf9-UKwJc_s1v1eSJYuPo4MI-TrXqubXGZw5JrlMnsuJMV4u5w%3D%3D?uid=0&filename=2016-12-07_23-29-43.png&disposition=inline&hash=&limit=0&content_type=image%2Fpng&fsize=79001&hid=cf1d1013be1183be6978b9e29201e6b6&media_type=image&tknv=v2&etag=6524f79167d915b1412869d4619486ef</link_text>" />
