  4. [gelöst] synology adapter gelb
    5.9k
synology
59 Beiträge 7 Kommentatoren 8.0k Aufrufe 6 Beobachtet
  • GlasfaserG Glasfaser
    @Alero
    Die Error Meldung ist aber neu ... hat nichts mit deiner anderen Meldung zu tun .
    Was hast du denn verändert .
    Alero
    schrieb am zuletzt editiert von Alero
    @Glasfaser
    Fehler gefunden für die falsche IP.
    hier das neue Log.
    synology.0	2021-01-06 10:37:20.785	debug	(10931) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    synology.0	2021-01-06 10:37:20.784	debug	(10931) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    synology.0	2021-01-06 10:37:20.784	debug	(10931) -----------------------------------------------------------------------------------------------------
    synology.0	2021-01-06 10:37:20.783	error	(10931) *** ERROR : src: sendPolling syno[dsm][getPollingData] To use the adapter, the user must be in the Administrators group! code: 400 message: No such account or incorrect password
    synology.0	2021-01-06 10:37:20.783	debug	(10931) * No response, read next.
    synology.0	2021-01-06 10:37:19.552	debug	(10931) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    synology.0	2021-01-06 10:37:19.552	debug	(10931) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    synology.0	2021-01-06 10:37:19.552	debug	(10931) -----------------------------------------------------------------------------------------------------
    synology.0	2021-01-06 10:37:19.551	error	(10931) *** ERROR : src: sendPolling syno[dsm][getPollingData] To use the adapter, the user must be in the Administrators group! code: 400 message: No such account or incorrect password
    synology.0	2021-01-06 10:37:19.550	debug	(10931) * No response, read next.
    synology.0	2021-01-06 10:37:18.424	debug	(10931) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    synology.0	2021-01-06 10:37:18.423	debug	(10931) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    synology.0	2021-01-06 10:37:18.423	debug	(10931) -----------------------------------------------------------------------------------------------------
    synology.0	2021-01-06 10:37:18.422	error	(10931) *** ERROR : src: sendPolling syno[dsm][getPollingData] To use the adapter, the user must be in the Administrators group! code: 400 message: No such account or incorrect password
    synology.0	2021-01-06 10:37:18.421	debug	(10931) * No response, read next.
    synology.0	2021-01-06 10:37:16.976	silly	(10931) States system redis pmessage system.adapter.synology.0.logLevel/system.adapter.synology.0.logLevel:{"val":"silly","ack":true,"ts":1609925836970,"q":0,"from":"system.adapter.synology.0","lc":1
    synology.0	2021-01-06 10:37:16.955	debug	(10931) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    synology.0	2021-01-06 10:37:16.955	debug	(10931) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    synology.0	2021-01-06 10:37:16.955	debug	(10931) -----------------------------------------------------------------------------------------------------
    synology.0	2021-01-06 10:37:16.458	info	(10931) starting. Version 0.1.18 in /opt/iobroker/node_modules/iobroker.synology, node: v10.20.1
    synology.0	2021-01-06 10:37:16.280	debug	(10931) statesDB connected
    synology.0	2021-01-06 10:37:16.279	debug	(10931) States connected to redis: 127.0.0.1:9000
    synology.0	2021-01-06 10:37:16.275	debug	(10931) States create System PubSub Client
    synology.0	2021-01-06 10:37:16.274	debug	(10931) States create User PubSub Client
    synology.0	2021-01-06 10:37:16.271	debug	(10931) Redis States: Use Redis connection: 127.0.0.1:9000
    synology.0	2021-01-06 10:37:16.271	debug	(10931) objectDB connected
    synology.0	2021-01-06 10:37:16.269	debug	(10931) Objects connected to redis: 127.0.0.1:9001
    synology.0	2021-01-06 10:37:16.263	debug	(10931) Objects client initialize lua scripts
    synology.0	2021-01-06 10:37:16.263	debug	(10931) Objects create User PubSub Client
    synology.0	2021-01-06 10:37:16.262	debug	(10931) Objects create System PubSub Client
    synology.0	2021-01-06 10:37:16.261	debug	(10931) Objects client ready ... initialize now
    synology.0	2021-01-06 10:37:16.249	debug	(10931) Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.iobroker	2021-01-06 10:37:15.898	info	instance system.adapter.synology.0 started with pid 10931
    synology.0	2021-01-06 10:37:16.976	silly	(10931) States system redis pmessage system.adapter.synology.0.logLevel/system.adapter.synology.0.logLevel:{"val":"silly","ack":true,"ts":1609925836970,"q":0,"from":"system.adapter.synology.0","lc":16
    • A Alero
      @Glasfaser
      hier das neue Log.
      GlasfaserG Offline
      GlasfaserG Offline
      @Alero sagte in synology adapter gelb:
      code: 400
      Was mich wundert ist der Code 400 , der sonst nicht dabei ist wenn die Administrators group nicht eingehalten wird.
        code: 400
        Alero
        @Glasfaser
        hier noch die EInstellungen meiner syno
        und der gruppe
        Sowohl User als auch pw wurden in den Adapter kopiert um Schreibfehler zu vermeiden.
        Alero
        GlasfaserG da_WoodyD 2 Antworten Letzte Antwort
        • A Alero
          @Glasfaser
          und der gruppe
          Alero
          GlasfaserG Offline
          GlasfaserG Offline
          @Alero
          Bei den retuschierten Screenshots kann man nicht viel erkennen .
          Ich habe gerade im main.js vom Adapter geschaut , die Meldungen sind neu eingepflegt .
          Ich würde dann auch auf die Meldung HTTP 400 Error (Bad Request) tippen das es dann so gemeint ist
          A 2 Antworten Letzte Antwort
            @Alero
            Alero
            @Glasfaser
            die letzten Bilder sollten nur dokumentieren das der User "Hardware" heist und in der Administrators Gruppe vorhanden ist.
            Dan ist es ein Zugrtiffsproblem?
            Alero
            • A Alero
              @haselchen
              scheinbar doch ein falscher user oder pw. Habe es mit dem Admin account meiner synology versucht. gleiches Ergebnis.
              Ich muss doch den User und das PW des Synology account mit adminrechten dort eintragen, oder?
              Alero
              haselchenH Offline
              haselchenH Offline
              haselchen
              Gelöscht
              • A Alero
                @Glasfaser
                und der gruppe
                Alero
                da_WoodyD Offline
                da_WoodyD Offline
                @Alero said in synology adapter gelb:
                und genau da kann passieren, daß am ende ein leerzeichen mitgenommen wird.
                  @Alero
                  Alero
                  hi,
                  vielen Dank noch einmal an alle für die tolle Hilfe.
                  Habe den Fehler gefunden. Habe noch einmal den tread von Glasfaser empfohlen durchgelesen.
                  Der Fehler lag an meiner Syno.
                  "Automatische Blockierung und Kontoschutz aktivieren"
                  Habe jetzt den Aktualisierungswert im Adapter hoch gesetzt. Jetzt geht es.
                  Alero
                  • A Alero
                    hi,
                    Alero
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @Alero sagte in [gelöst] synology adapter gelb:
                    ..... und deshalb der Hinweis von mir .........
                    @Glasfaser sagte in [gelöst] synology adapter gelb:
                    @Alero
                    also ... innerhalb von 5 Minuten den Thread durchlesen ist Sportlich ....
                    hast du alles beachtet ...
                      @Alero
                      Alero
                      @Glasfaser
                      Hast ja recht.
                      Alero
                      • A Alero
                        @Glasfaser
                        Hast ja recht.
                        Alero
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @Alero
                        wollte nur nicht alles neu durchkauen ... ;)
                        und deshalb haben wir auch ( @ilovegym ) einen Thread dafür erstellt .
                        • StM47S Offline
                          StM47S Offline
                          StM47
                          schrieb am zuletzt editiert von StM47
                          erledigt
                          ioBroker im Docker auf Synology DiskStation DS 716+II mit DSM 6.2.1
                          • Lightmanager Air / Lupusec XT2 Plus mit div. Fenster- u. Türkontakten, Rauch- u. Bewegungsmelder / Harmony Hub / Fritzbox 7590 OS7
                          • schaltbare Steckdosen / Alexa Echo Dot 3 / Zigbee USB Stick / diverse Xiaomi Produkte / Xiaomi Yeelight Birnen
