  4. Ständiges Disconnect des Admins
disconnect admin
8 Beiträge 2 Kommentatoren 632 Aufrufe 1 Beobachtet
    TheDamned
    bei mir diconnected sich ständig der Admin?
    Kann mir jemand sagen, warum?
    bzw. Welche Informationen braucht man um mir zu helfen?
    web.0	2021-01-06 14:02:23.385	info	(12955) <==Disconnect system.user.admin from ::ffff:192.168.178.20 vis.0
    web.0	2021-01-06 14:02:11.339	info	(12955) <==Disconnect system.user.admin from ::ffff:192.168.178.20 flot
    web.0	2021-01-06 14:02:05.997	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.979	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.970	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.954	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.944	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.918	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.770	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.654	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.554	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.438	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.392	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.217	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.165	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:05.154	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:01.762	info	(12955) ==>Connected system.user.admin from ::ffff:192.168.178.20
    web.0	2021-01-06 14:02:01.057	info	(12955) <==Disconnect system.user.admin from ::ffff:192.168.178.20 vis.0
    web.0	2021-01-06 14:02:00.904	info	(12955) <==Disconnect system.user.admin from ::ffff:192.168.178.20 flot
    web.0	2021-01-06 14:02:00.903	info	(12955) <==Disconnect system.user.admin from ::ffff:192.168.178.20 flot
    web.0	2021-01-06 14:02:00.902	info	(12955) <==Disconnect system.user.admin from ::ffff:192.168.178.20 flot
    web.0	2021-01-06 14:02:00.901	info	(12955) <==Disconnect system.user.admin from ::ffff:192.168.178.20 flot
    web.0	2021-01-06 14:02:00.899	info	(12955) <==Disconnect system.user.admin from ::ffff:192.168.178.20 flot
    web.0	2021-01-06 14:02:00.893	info	(12955) <==Disconnect system.user.admin from ::ffff:192.168.178.20 flot
    web.0	2021-01-06 14:02:00.892	info	(12955) <==Disconnect system.user.admin from ::ffff:192.168.178.20 flot
    web.0	2021-01-06 14:02:00.889	info	(12955) <==Disconnect system.user.admin from ::ffff:192.168.178.20 flot
    MOD-Edit: Code in code-tags gesetzt!
    HomoranH T 2 Antworten Letzte Antwort
    • T TheDamned
      @TheDamned sagte in Ständiges Disconnect des Admins:
      Nein!
      wofür brauchst du Hilfe?
      Im log steht nur von welchem Gerät du auf vis oder flot zugreifst
      • T TheDamned
        TheDamned
        oh ok, ich dachte dieses "disconnect" im Log bedeutet, das der Admin sich disconnected.
        Dann habe ich das falsch interpretiert.
        Wenn ich mein VIS starte dann "hängt" es sich manchmal auf und sagt, das keine Verbindung zum Server da ist. Das gleiche passiert mir ständig mit dem VIS-Editor und dem FLOT-Editor.
        Ich sehe da nur diese Eieruhr-Nachbildung (sich drehende Kreise). Das geht dann ca 2-3 Minuten so und dann ist wieder alles da. Das geht Hand in Hand mit diesem Disconnect im Log File.
        Es ist halt etwas nervend, wenn das alle 10 min passiert.
        Dann stelle ich die Frage anders: Warum kommt so oft diese Wartezeit zustande?
        Ich kann da kaum noch was editieren. Oft sind diese Änderungen weg.
        • T TheDamned
          da steht das aber nicht, sondern:
          Web, nicht admin!
          der User heisst admin!
          und hatte sich von der genannten IP in vis eingeloggt!
          Dann hast du ein Netzwerkproblem
            Web, nicht admin!
            TheDamned
            @Homoran Dann wird dieses Netzwerkproblem aber vom Raspberry Pi verursacht, denn sonst steht mein Netz stabil. Ich komme immer überall hin, nur nicht auf den Pi.
            Woran kann das liegen, das der Pi das Netzwerk ständig wegschmeißt?
            • T TheDamned
              WLAN?
                WLAN?
                TheDamned
                @Homoran Ja, WLAN.
                Ich entwickle auf meinem Rechner remote das Projekt.
                Alles geht über WLAN zum Pi.
                Ich vermute, du hast recht. Die Feldstärke des PI liegt (laut Router) zwischen 1 und 3 Balken (von 4).
                Wenn ich diese tolle Antenne aus dem USB ausstecke, dann sind es stabil 2 Balken.
                Ich probier das jetzt mal ohne diese Antenne.
                Oder weißt du zufällig, was ich machen muss, damit der Pi diese Antenne akzeptiert und damit besser funken kann?
                • T TheDamned
                  @Homoran Ja, WLAN.
                  nein - Nimm Kabel
