  2. English
  3. ioBroker general
  4. Tuya Adapter leuchtet gelb
    apollon77A
Geplant Angeheftet Gesperrt Verschoben ioBroker general
501
20 Beiträge 2 Kommentatoren 2.4k Aufrufe 2 Beobachtet
  • A alex84
    @Thomas-Braun
    nein habe ich nicht gelesen. Welche Version sollte man installieren?
    Thomas BraunT
    Thomas BraunT
    @alex84
    Lies dich hier ein:
    https://github.com/Apollon77/ioBroker.tuya
    • A alex84
      @Thomas-Braun
      A
      A
      alex84
      @alex84 ```test
      A 2 Antworten Letzte Antwort
      • A alex84
        @alex84 ```test
        A
        A
        alex84
        @alex84
        2021-01-05 20:30:11.895 - info: daswetter.0 (5099) Terminated (NO_ERROR): Without reason
        2021-01-05 20:30:12.409 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2021-01-05 20:31:02.000 - info: web.0 (1227) <==Disconnect system.user.admin from ::ffff:192.168.178.26 vis.0
        2021-01-05 20:33:55.306 - info: host.raspberrypi "system.adapter.tuya.0" disabled
        2021-01-05 20:33:55.308 - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=true)
        2021-01-05 20:33:55.310 - info: host.raspberrypi stopInstance system.adapter.tuya.0 send kill signal
        2021-01-05 20:33:55.316 - info: tuya.0 (4568) Got terminate signal TERMINATE_YOURSELF
        2021-01-05 20:33:56.126 - info: host.raspberrypi "system.adapter.tuya.0" enabled
        2021-01-05 20:33:56.127 - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=true)
        2021-01-05 20:33:56.129 - info: host.raspberrypi stopInstance system.adapter.tuya.0 send kill signal
        2021-01-05 20:33:56.134 - info: tuya.0 (4568) Got terminate signal TERMINATE_YOURSELF
        2021-01-05 20:33:58.323 - info: tuya.0 (4568) terminating
        2021-01-05 20:33:58.326 - info: tuya.0 (4568) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-01-05 20:33:58.864 - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-01-05 20:34:03.673 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 5151
        2021-01-05 20:34:06.040 - info: tuya.0 (5151) starting. Version 3.5.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v10.23.0, js-controller: 3.1.6
        2021-01-05 20:34:06.096 - info: tuya.0 (5151) Existing devices initialized
        2021-01-05 20:34:06.107 - info: tuya.0 (5151) Listen for local Tuya devices on port 6666
        2021-01-05 20:34:06.108 - info: tuya.0 (5151) Listen for encrypted local Tuya devices on port 6667
        • A alex84
          @alex84 ```test
          A
          A
          alex84
          @alex84
          auf diese Seite war ich schon, da ich kein English kann, verstehe ich nichts was da steht
          • A alex84
            @alex84
            Thomas BraunT
            Thomas BraunT
            @alex84
            The Adapter only works with Tuya and compatible apps as long as their version is <3.14 (!!)
            Der Adapter funktioniert nur mit Tuya (und anderen Apps) wenn deren Versionsnummern unter 3.14 sind.
              @alex84
              A
              A
              alex84
              @Thomas-Braun
              Danke, kannst du mir noch sagen wie ich alte Version installiere.
              • A alex84
                @Thomas-Braun
                Thomas BraunT
                Thomas BraunT
                @alex84
                Keine Ahnung. Musst du dir für dein Mobiltelefon halt irgendwoher besorgen.
                  @alex84
                  A
                  A
                  alex84
                  @Thomas-Braun
                  warum für mobil Telefon? ich habe verstanden, es soll tuya adapter 3.14 sein. oder falsch????
                  • A alex84
                    @Thomas-Braun
                    Thomas BraunT
                    Thomas BraunT
                    @alex84 Nein...
                    Das ganze ist etwas komplexer.
                    Du brauchst auf deinem Mobiltelefon eine Tuya(kompatible) alte App (Version <3.14), deren Datenverkehr wird dann abgehört (dazu muss dann noch ein Proxy auf dem Telefon installiert werden, wodurch eine Man-in-the-middle-Attacke möglich wird).
                      @alex84 Nein...
                      A
                      A
                      alex84
                      @Thomas-Braun
                      ich habe app gefunden, istalliert, proxy instaliert, aber funktioniert immer nicht.
                      habe jetzt so was
                      2021-01-05 22:01:03.317 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:03.318 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:07.819 - info: ical.0 (6288) Terminated (NO_ERROR): Without reason
                      2021-01-05 22:01:08.331 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                      2021-01-05 22:01:13.255 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:13.256 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:23.299 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:23.301 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:33.344 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:33.345 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:36.231 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:36.232 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.917 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.917 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.946 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.947 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.979 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.980 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.981 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.981 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.990 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.991 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.993 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.994 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.995 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:48.995 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.047 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.047 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.048 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.048 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.051 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.052 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.124 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.124 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.125 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.125 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.131 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.131 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.142 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.143 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.145 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.145 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.152 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.152 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.179 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.179 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.205 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.206 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.212 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.212 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.242 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.242 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.245 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.246 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.248 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.248 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.288 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.289 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.292 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:49.292 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.840 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.840 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.841 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.842 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.843 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.843 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.844 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.845 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.938 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.939 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.939 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:55.940 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.017 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.017 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.018 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.018 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.019 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.019 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.020 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.020 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.023 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.024 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.029 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.030 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.047 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.048 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.070 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.071 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.090 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.091 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.095 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.095 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.103 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.103 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.140 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.140 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.143 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.144 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.226 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.227 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.239 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.240 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.260 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.261 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.289 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.290 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.329 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.329 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.368 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.368 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.394 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.394 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.434 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.434 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.470 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.470 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.508 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.508 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.553 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.554 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.579 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.580 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.645 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.646 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.829 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.830 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.830 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.831 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.831 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.832 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.865 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.866 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.929 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.929 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.979 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:56.980 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.038 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.039 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.109 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.109 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.169 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.169 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.183 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.183 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.252 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.253 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.273 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.274 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.306 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.307 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.324 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.325 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.352 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.353 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.374 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:57.374 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:58.631 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:01:58.633 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:04.697 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:04.698 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:05.785 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:05.786 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:15.873 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:15.875 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:22.391 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:22.392 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:22.453 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:22.454 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:22.459 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:22.459 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:25.862 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:25.863 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:26.390 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:26.392 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:38.645 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:38.646 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:45.890 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:45.892 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:55.896 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:02:55.897 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:03:05.908 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:03:05.909 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:03:15.919 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:03:15.920 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:03:25.952 - error: tuya.0 (6269) SSL-Proxy ERROR: Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      2021-01-05 22:03:25.953 - error: tuya.0 (6269) Error: 3069864400:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 46
                      bitte hilf mir
                      • A alex84
                        @Thomas-Braun
                        habe jetzt so was
                        bitte hilf mir
                        Thomas BraunT
                        Thomas BraunT
                        @alex84 Zertifikat installiert?
                          A
                          A
                          alex84
                          @Thomas-Braun
                          ja, alles nach Video Beschreibung gemacht
                          • A alex84
                            @Thomas-Braun
                            Thomas BraunT
                            Thomas BraunT
                            @alex84
                            Wenn es nach Video gemacht ist muss es ja gehen.
                            84.0k
