  4. Lidl ZigBee SmartHome Artikel mit ZigBee Adapter pairen
    6.3k
zigbeesilvercrestlidl
133 Beiträge 31 Kommentatoren 42.1k Aufrufe 31 Beobachtet
  • L Leviathan09
    @arteck
    zigbee.0	2020-12-22 12:51:46.889	info	(12976) Currently 7 devices are joined:
    zigbee.0	2020-12-22 12:51:46.886	error	(12976) Device 0xec1bbdfffec9518e "TY0202" not described in statesMapping.
    zigbee.0	2020-12-22 12:51:46.885	debug	(12976) Publish available for 0xec1bbdfffec9518e = true
    zigbee.0	2020-12-22 12:51:46.884	debug	(12976) Publish available for 0x00158d0002bfecd8 = true
    zigbee.0	2020-12-22 12:51:46.883	debug	(12976) Publish available for 0x14b457fffe70d67e = true
    zigbee.0	2020-12-22 12:51:46.882	debug	(12976) Publish available for 0x00158d0002bfec0b = true
    zigbee.0	2020-12-22 12:51:46.881	debug	(12976) Publish available for 0x00158d0002bfed01 = true
    zigbee.0	2020-12-22 12:51:46.880	debug	(12976) Publish available for 0x00158d0002bfe412 = true
    zigbee.0	2020-12-22 12:51:46.877	debug	(12976) Publish available for 0x00158d0002bf5120 = true
    zigbee.0	2020-12-22 12:51:46.866	info	(12976) --> transmitPower : normal
    zigbee.0	2020-12-22 12:51:46.865	info	(12976) Unable to disable LED, unsupported function.
    zigbee.0	2020-12-22 12:51:46.863	debug	(12976) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
    zigbee.0	2020-12-22 12:51:46.854	info	(12976) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20201113}}
    zigbee.0	2020-12-22 12:51:46.852	debug	(12976) zigbee-herdsman started
    zigbee.0	2020-12-22 12:51:45.067	debug	(12976) Starting zigbee-herdsman...
    zigbee.0	2020-12-22 12:51:45.064	info	(12976) Starting Zigbee...
    zigbee.0	2020-12-22 12:51:44.934	info	(12976) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.23.0, js-controller: 3.1.6
    Wenn ich versuche ein Update über die Katze zu machen sieht der Log so aus:
    $ ./iobroker upgrade zigbee@1.4.1
    Update zigbee from @1.4.1 to @1.4.1
    NPM version: 6.14.8
    npm install iobroker.zigbee@1.4.1 --loglevel error --prefix "/opt/iobroker" (System call)
    npm
     ERR! code ETARGET
    npm
    ERR! notarget No matching version found for iobroker.zigbee@1.4.1.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-12-22T11_39_14_061Z-debug.log
    Über die github URL im Debug dann so:
    $ ./iobroker url "https://github.com/ioBroker/ioBroker.zigbee" --debug
    install https://github.com/ioBroker/ioBroker.zigbee/tarball/e42df7d0d0086a6338b798ac83084416ff8faf14
    NPM version: 6.14.8
    npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/e42df7d0d0086a6338b798ac83084416ff8faf14 --loglevel error --prefix "/opt/iobroker" (System call)
    + iobroker.zigbee@1.4.1updated 3 packages in 30.403s
    32 packages are looking for funding  run `npm fund` for details
    upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
    Und hier zeigt er zumindest an das die Version 1.4.1 installiert ist
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #112
    @Leviathan09 gestartet wird 1.1.1, nicht 1.4.1.
    Hast du ggf. Master/Slave ?
    A.
    L 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      A.
      Leviathan09
      #113
      @Asgothian Jap, Zigbee Adapter läuft auf dem Slave
      • L Leviathan09
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #114
        @Leviathan09
        hast du eine eigene installation des Adapters auf dem Slave ? Wenn ja, dann muss die meines Wissens weg. Sonst holt er sich den korrekten Adapter nicht vom Master.
        A.
          @Leviathan09
          A.
          Leviathan09
          #115
          @Asgothian Ja, scheinbar war da noch eine eigenen Installation auf dem Slave.
          Hab den ganzen Kram jetzt einfach nochmal deinstalliert auf dem Master und dem Slave und versuche es nun ganz frisch
          • L Offline
            Leviathan09
            #116
            Nachdem ich nun den Adapter auf dem Master und Slave deinstalliert habe und neu nur auf dem Master installiert habe funktioniert nun alles und der BWM wurde erkannt.
            (Habe gleich noch den Stick über ser2net weiter gereicht damit ich kein Slave mehr brauche)
            • L Leviathan09
              mimei
              #117
              Ich habe mir zwei RGB Birnen bei Lidl geholt. Pairen hat soweit ich das Beurteilen kann gut geklappt.
              Dimmen klappt gut, mir fallen jedoch zwei Punkte/Fragen auf:
              • Color funktioniert soweit. Aber was ist die Standardfarbe? Ausser durch factory-reset kriege ich die Lampe nicht in den Ursprungszustand.
              • Was ist der Parameterrange für Colortemp und was ist auch hier der Default? funktioniert dieses Setting überhaupt? sobald ich mal irgendeinen Parameter für Colortemp setze, kriege ich die Lampe ohne Factory-Reset nicht mehr "kräftig"
              Wenn ich noch zu früh bin und sich das beheben wird, einfach sagen. Ich habe Geduld :-)
              Adapter Version: 1.4.0
              W 1 Antwort Letzte Antwort
              • M mimei
                W Offline
                W Offline
                Wurmi
                #118
                @mimei
                @arteck sagte in Lidl ZigBee SmartHome Artikel mit ZigBee Adapter pairen:
                installiert bitte 1.4.1 vom GIT.. bei problemen mit den LIDL klamotten
                vlt hilft dir das schon.
                Wurmi \m/
                X 1 Antwort Letzte Antwort
                • Z zgadgeter
                  @David-Froebus Und wie ist die Version bei dir? Bei mir so wie unten.
                  Dragon
                  schrieb am zuletzt editiert von Dragon
                  #119
                  Etwas spät. Tut mir leid. Aber besser spät als nie...
                  • W Wurmi
                    @mimei
                    Wurmi \m/
                    X Offline
                    X Offline
                    xfinkelx
                    #120
                    @Wurmi said in Lidl ZigBee SmartHome Artikel mit ZigBee Adapter pairen:
                    @mimei
                    Wurmi \m/
                    Hat schon jemand die Steckdose einbinden können? Habe meinen Adapter auf 1.4.1 geupdated, aber der Plug wird nicht gefunden... Kann ich irgendwie testen, ob die Steckdose defekt ist?
                    -1
                    • X xfinkelx
                      @mimei
                      Wurmi \m/
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #121
                      @xfinkelx
                      • welche Steckdose meinst du genau ?
                      • auf welchem Kanal läuft dein Zigbee Netz ?
                      • Welche Adapter Version hast du GENAU installiert (Bitte die Folgende Zeile aus DEINEM Log heraus suchen und posten:
                      A.
                        @xfinkelx
                        A.
                        X Offline
                        X Offline
                        xfinkelx
                        #122
                        @Asgothian said in Lidl ZigBee SmartHome Artikel mit ZigBee Adapter pairen:
                        @xfinkelx
                        A.
                        Hallo, ich meine die hier: https://www.lidl.de/de/silvercrest-steckdose-zwischenstecker-zigbee-smart-home/p355168
                        Kanal ist nr.11
                        08:12:29.567 info (32199) Currently 28 devices are joined:
                        zigbee.0 2021-01-04 08:12:29.547 info (32199) --> transmitPower : normal
                        zigbee.0 2021-01-04 08:12:29.536 info (32199) Disable LED
                        zigbee.0 2021-01-04 08:12:29.524 info (32199) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                        zigbee.0 2021-01-04 08:12:27.161 info (32199) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
                        zigbee.0 2021-01-04 08:12:26.849 info (32199) Starting Zigbee npm ...
                        zigbee.0 2021-01-04 08:12:26.626 info (32199) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.1.6
                        • X xfinkelx
                          @xfinkelx
                          A.
                          Kanal ist nr.11
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #123
                          @xfinkelx
                          Bitte mach folgendes:
                          • Adapter anhalten
                          • Zigbee-Stick abziehen
                          • Zigbee Stick wieder ansteckcen
                          • Adapter starten
                          • Netzwerk in Pairing Mode bringen (nicht Touchlink reset)
                          • Steckdose in der Nähe des Stick anschliessen
                          • Steckdose Resetten
                          • Mit dem Schalter der Dose diese einmal aus und wieder an schalten.
                          Wenn dann immer noch nichts kommt ist davon aus zu gehen das die Dose nicht ok ist.
                          A.
                            @xfinkelx
                            • Adapter anhalten
                            • Adapter starten
                            A.
                            X Offline
                            X Offline
                            xfinkelx
                            #124
                            @xfinkelx
                            • Adapter anhalten
                            • Adapter starten
                            A.
                            Danke für die Hilfe, aber es scheint, dass die Steckdose nicht funktioniert. Im Log ist während des pairings auch nix zu erkennen. Die war reduziert und sicher schon einmal verkauft, so wie die Verpackung aussah...
                            • X xfinkelx
                              @xfinkelx
                              • Adapter anhalten
                              • Adapter starten
                              A.
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #125
                              @xfinkelx bring die weg..oder ab in die Tonne damit
                              • arteckA arteck
                                Stoni
                                #126
                                Moin, ich klinke mich hier Mal ein. Ab nä Woche sind die Zigbee Teile von Lidl wieder im Angebot. Mich interessiert vorrangig die Lichtleiste, bzw das Stimmungslicht.
                                Hat jemand Erfahrung, ob sich die Teile in ioB einbinden lassen?
                                Ich habe bislang noch gar keine Zigbee Instanz, geschweige denn ein Gateway. Ich spiele mit dem Gedanken, den Conbee 2 Stick am Raspi zu installieren.
                                Welchen Adapter empfehlt ihr dazu? Den deconz oder den Zigbee Adapter?
                                Gruß Stoni
                                hsteinmeH 1 Antwort Letzte Antwort
                                • S Stoni
                                  Gruß Stoni
                                  hsteinmeH Offline
                                  hsteinmeH Offline
                                  hsteinme
                                  #127
                                  @stoni sagte in Lidl ZigBee SmartHome Artikel mit ZigBee Adapter pairen:
                                  Ich habe keinen Vergleich zwischen den beiden Adaptern. Aber ich kann sagen, dass bei mir Conbee II und deConz bestens zusammen laufen: 2 Dutzend Leuchten, 2 Steckdosen, 17 Schalter und 6 Sensoren - verteilt über 3 Stockwerke.
                                  • Daniel_ND Offline
                                    Daniel_ND Offline
                                    Daniel_N
                                    #128
                                    ich habe auch deconz mit conbee 2 stickl ohne probleme am laufen. nach dem letzten update lassen sich auch die bewegungsmelder von lidl einbinden. ich habe aktuell zu den bwm auch 2 steckdosen erfolgreich eingebunden. sind halt etwas größer als die von osram...
                                    • Daniel_ND Daniel_N
                                      Dragon
                                      #129
                                      @daniel_n funktionieren aber 1000 mal so gut. mit den OSram habe ich in 20cm Entfernung kaum Empfang. Die Lidl Dinger sind top und kosten ein fünftel der Osram Dinger.
                                      • D Dragon
                                        Doc112
                                        #130
                                        Hallo Leute!
                                        Auch wenn das hier etwas Leichenschändung ist fand ich den Beitrag am passensten.
                                        Ich habe mir drei Lidl ZigBee Außenleuchten bestellt und warte auf die Lieferung.
                                        LIVARNO LUX LED-Wandaußenleuchte, »Zigbee Smart Home«
                                        Bildschirmfoto 2021-04-03 um 19.39.08.png (c) LIDL.de
                                        https://www.lidl.de/de/livarno-lux-led-wandaussenleuchte-zigbee-smart-home/p365301
                                        Auf der Zigbee2mqtt Seite habe ich dies aber noch nicht als unterstützt gefunden.
                                        https://www.zigbee2mqtt.io/information/supported_devices.html
                                        So habe ich mal angefangen mich einzulesen, wie man ein unbekannte Gerät einlernt.
                                        https://www.zigbee2mqtt.io/how_tos/how_to_support_new_devices.html
                                        Hierzu fand ich auch dieses YT-Video hilfreich: https://youtu.be/RcxEx5cg0BE
                                        Ich benutze den ConBee2-Stick und einen CC2531 (FW 20201127) in je einem eigenen Adapter da es sonst mit meinen GIRA-Wandschaltern probleme gibt. Beide Adapter sind auf Version 1.4.4 und alles läuft stabil.
                                        Bildschirmfoto 2021-04-03 um 19.26.57.png Bildschirmfoto 2021-04-03 um 19.26.25.png
                                        Nun meine Frage:
                                        Kann ich aus dem Zigbee-Adapter die nötigen Infomationen ziehen um die Wandleuchten in die Liste der kompatiblen Geräte aufnehmen zu lassen? Oder kann ich die Leuchten selbst einpflegen? Ich würde den Adapter mit dem ComBee-Stick bevorzugen.
                                        Bisher habe ich leider keine Anleitung für Neulinge in dem Thema gefunden. Es scheint mir, als ob hierfür eine andere Software wie z.B. den zigbee-herdsman-converters bemühen muss. Ist euch eine Schritt-für-Schritt-Anleitung bekannt?
                                        Ich würde gerne die drei Leuchten bis zum Ablauf der Rückgabefrist zum laufen gebracht haben, deshalb hier schon meine Vorarbeit.
                                        Ich danke schon mal Alle für die Mühen und die Gedult.
                                        Frohe Ostern und ein paar ruhige Tage wünscht
                                        JOHANNES
                                        • D Doc112
                                          Hallo Leute!
                                          Nun meine Frage:
                                          JOHANNES
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #131
                                          @doc112
                                          Ich kann zur Lektüre diesen Wiki Artikel empfehlen. Da sollte erklärt sein wie du mit dem zigbee Adapter an die gewünschten Informationen kommst.
                                          Nach der Einbindung in den herdsman - sauber mit exposes - sollte das Gerät dann auch mit dem zigbee Adapter laufen.
                                          A.
