  4. IOBroker installation auf Raspberry Zero bricht ab.
    6.5k
zero winstallation abgebrochen
24 Beiträge 5 Kommentatoren 4.7k Aufrufe 3 Beobachtet
  • A Andy200877
    @Thomas-Braun
    Ich habe node, nodejs & npm nochmal komplett entfernt. Und mit der heutigen Version installiert...
    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/local/bin/nodejs
    v12.20.0
    /usr/local/bin/node
    v12.20.0
    /usr/local/bin/npm
    6.14.8
    nodejs:
      Installiert:           (keine)
      Installationskandidat: 10.21.0~dfsg-1~deb10u1+rpi1
      Versionstabelle:
         10.21.0~dfsg-1~deb10u1+rpi1 500
    Der Fehler bleibt aber der gleiche :
    cat  /home/pi/.npm/_logs/2020-12-30T16_15_47_012Z-debug.log
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/local/bin/node',
    1 verbose cli   '/usr/local/bin/npm',
    1 verbose cli   'i',
    1 verbose cli   'iobroker',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error'
    1 verbose cli ]
    2 info using npm@6.14.8
    3 info using node@v12.20.0
    4 verbose npm-session 4d563cc70a9829ae
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 silly fetchPackageMetaData error for iobroker@latest Cannot read property 'resolve' of undefined
    8 timing stage:rollbackFailedOptional Completed in 61ms
    9 timing stage:runTopLevelLifecycles Completed in 2111ms
    10 verbose stack TypeError: Cannot read property 'resolve' of undefined
    10 verbose stack     at regFetch (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/index.js:88:23)
    10 verbose stack     at fetchPackument (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/packument.js:42:10)
    10 verbose stack     at packument (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/packument.js:20:10)
    10 verbose stack     at getManifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:22:10)
    10 verbose stack     at manifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:13:10)
    10 verbose stack     at Object.manifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/index.js:17:12)
    10 verbose stack     at Object.Fetcher#manifest [as manifest] (/usr/local/lib/node_modules/npm/node_modules/genfun/lib/genfun.js:15:38)
    10 verbose stack     at manifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetch.js:23:18)
    10 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/pacote/manifest.js:24:12
    10 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:29:24
    10 verbose stack     at Promise._execute (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/debuggability.js:313:9)
    10 verbose stack     at Promise._resolveFromExecutor (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:488:18)
    10 verbose stack     at new Promise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:79:10)
    10 verbose stack     at _inflight (/usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:28:25)
    10 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:22:14
    10 verbose stack     at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    11 verbose cwd /opt/iobroker
    12 verbose Linux 5.4.79+
    13 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "i" "iobroker" "--loglevel" "error"
    14 verbose node v12.20.0
    15 verbose npm  v6.14.8
    16 error Cannot read property 'resolve' of undefined
    17 verbose exit [ 1, true ]
    pi@raspberrypi:~ $ uname -a
    Linux raspberrypi 5.4.79+ #1373 Mon Nov 23 13:18:15 GMT 2020 armv6l GNU/Linux
    pi@raspberrypi:~ $ lsb_release -a
    No LSB modules are available.
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    @Andy200877
    Kommt da was bei raus?
    cd /opt/iobroker
    npm list resolve
      @Andy200877
      cd /opt/iobroker
      npm list resolve
      Andy200877
      @Thomas-Braun
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ npm list resolve
      /opt/iobroker
      └── (empty)
      https://github.com/Andy200877/intex_poollampe
      • A Andy200877
        @Thomas-Braun
        /opt/iobroker
        └── (empty)
        @Andy200877
        date && date -u
        apt policy node-resolve
          @Andy200877
          date && date -u
          Andy200877
          @Thomas-Braun
          g
          pi@raspberrypi:/opt/iobroker $ date && date -u
          Mi 30. Dez 17:28:26 CET 2020
          Mi 30. Dez 16:28:26 UTC 2020
          auch aktuell...
          • A Andy200877
            @Thomas-Braun
            v12.20.0
            /usr/local/bin/node
            v12.20.0
            /usr/local/bin/npm
            6.14.8
            nodejs:
              Versionstabelle:
            1 verbose cli [
            1 verbose cli   'i',
            1 verbose cli ]
            Release:        10
            Codename:       buster
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            @Andy200877 sagte in IOBroker installation auf Raspberry Zero bricht ab.:
            @Thomas-Braun resolve ist kein node-modul oder irgendwas ähnliches. Das ist ein Fehler, der aus javascript (vermutlich die npm CLI) stammt. Ein Funktionsaufruf, der etwa so aussieht:
            irgendwasUndefined.resolve(...)
            • AlCalzoneA AlCalzone
              @AlCalzone
              Okay, mir war nicht ganz klar ob das aus node, Javascript oder aus dem OS stammt. Da gibt es ja jeweils entsprechendes.
              Bei Javascript bin ich aber raus, da hab ich keinen Plan von.
                @AlCalzone
                Andy200877
                @Thomas-Braun sagte in IOBroker installation auf Raspberry Zero bricht ab.:
                Trotzdem vielen Dank für Deine Hilfe....
                Ich bin gerade dabei das Image mal neu aufzuspielen.
                • A Andy200877
                  @Andy200877 Welches Image?
                    Andy200877
                    @Thomas-Braun
                    Raspberry Buster minimal...
                    • A Andy200877
                      @Thomas-Braun
                      @Andy200877
                      Und dann installierst du über den Einzeiler?
                        @Andy200877
                        Andy200877
                        @Thomas-Braun
                        Ja... läuft jetzt.... g
                        Debian Buster Minimal OS über "Raspberry Pi Imager" installiert.
                        Direkt am PC im Boot Ordner der SD-Karte die Dateien "ssh" und "wpa_supplicant.conf" erstellt.
                        Danach SD-Karte wieder in den Zero gesteckt.
                        Über SSH verbunden und erstmal ein "sudo apt-get update" und "sudo apt-get upgrade" gemacht.
                        • Reboot
                        • unter raspi-config erstmal alles eingestellt (timezone, Sprache,...)
                        Brachte keine Ausgabe, da ja noch nix installiert ist...
                        Also nach Deiner Anleitung Node usw. installiert :
                        wget https://unofficial-builds.nodejs.org/download/release/v12.20.0/node-v12.20.0-linux-armv6l.tar.xz
                        tar -xvf node-v12.20.0-linux-armv6l.tar.xz
                        cd node-v12.20.0-linux-armv6l/
                        sudo cp -R * /usr/local/
                        sudo ln -s /usr/local/bin/node /usr/local/bin/nodejs
                        sudo reboot
                        Danach nochmal
                        pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                        v12.20.0
                        /usr/local/bin/node
                        v12.20.0
                        /usr/local/bin/npm
                        6.14.8
                        nodejs:
                          Versionstabelle:
                        Installation von IoBroker lief dann normal durch...
                        curl -sLf https://iobroker.net/install.sh | bash -
                        • A Andy200877
                          @Thomas-Braun
                          • Reboot
                          sudo reboot
                          Danach nochmal
                          v12.20.0
                          /usr/local/bin/node
                          v12.20.0
                          /usr/local/bin/npm
                          6.14.8
                          nodejs:
                            Versionstabelle:
                          @Andy200877 Okay, so war das ja auch gedacht...
                          Was hast du denn im ersten Versuch anders gemacht?
                            Andy200877
                            @Thomas-Braun Keine Ahnung... ich denke ich habe mir vorher irgendwann mal etwas zerschossen. Der Pi lief schon ein paar Monate und ich habe mit codesend + miflora mqtt "herumgespielt."
                            • A Andy200877
                              @Andy200877 Danke für die Rückmeldung das die manuelle Installation von nodeJS wie in meiner Doku beschrieben funktioniert. Bislang war das nämlich nur Theorie, mangels entsprechender Hardware in meinem Fundus.
                              M 2 Antworten Letzte Antwort
                                mguenther
                                Feedback von mir - auch ich habe auf einen RP ZeroW iobroker mit den neusten node.js und npm durch den von dir angegeben Weg installiert - danke
                                  mguenther
                                  was mache ich denn, wenn ich auf einem ZeroW Node-Red am Laufen habe, ich jetzt noch iobroker mit aufspielen möchte und folgende Situation habe:
                                  • M mguenther
                                    @mguenther sagte in IOBroker installation auf Raspberry Zero bricht ab.:
                                    ist das dein Ernst?
                                    auf einem Zero mit 512MB RAM?
                                    zu deiner Frage:
                                    da fehlt der symlink
                                      ist das dein Ernst?
                                      zu deiner Frage:
                                      mguenther
                                      ich teste gerade, wie ich die Daten von dem einen PI in den anderen bekomme. Das wäre eine Möglichkeit. Ich kapiere die MQTT Einrichtung auf dem NibePi unter Node-Red momentan nicht
